The XP machine, is a desktop with a "BFG R6600GT 128mb DDR3, AGP, from 2006. Is this too ancient for FAH to see, & can it be config. for FAH manually????
Okay I found the configure & Identity.
while in configure 'slots' says '0 cpu' so it's not using the GPU, I saw where the 'radio button' for GPU, should I check this & make no other changes, or add/change values?
