Hello everyone :)
JungleOnion
Hello everyone :)
Hope you are doing fine. I got very interested in the project and decided to jump in to see how it works because the pure idea sounds very nice to me. Hopefully not too utopical but we'll see.
But anyway, I decided to start folding at the protein viewer looks very cool.
I have a problem though, I enabled my GPU to start folding but the status says its ready but what does that mean? Do I have to configure something? Almost everything is saying "unknown" and the client I it says the worker and collection servers are 0.0.0.0. I am folding with my CPU though and everything there seems to look fine.
Any help much appreciated, don't mean to double a post or post it in the wrong section but I can't seem to find a solution.
ChristianVirtual
Re: Hello everyone :)
Welcome JungleOnion
Good to see you joining.
Regarding your GPU please give us more background information. What OS do you use, what GPU.
Most info we would need are in the log file you could copy from the FAHControl program.
The first 100 lines or so...once we see that we can help better.
Welcome to foldingforum.org, JungleOnion.
First guess: You're probably running Windows 10.
Microsoft distributes the drivers for your GPU but they only distribute the portions that are essential to Windows. You probably need to download the same driver from the GPU manufacturer which will also install the components needed by FAH.
JungleOnion
Thank you for your replies, well I am actually folding on OSX 10.10 and its doing good. I have a NVIDIA GeForce GT 750M 1024MB
I have CUDA installed not sure if I need something else as far as drivers.
These are my specs and even though I have CUDA installed it says its not detected.
This might be the most relevant log, hopefully it helps thank you guys.
Mod edit: added Code tags to log sections
*********************** Log Started 2016-08-09T05:28:59Z ***********************
05:28:59:************************* Folding@home Client *************************
05:28:59: Website: http://folding.stanford.edu/
05:28:59: Copyright: (c) 2009-2014 Stanford University
05:28:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:28:59: Args: --child --lifeline 69 --respawn
05:28:59: Config: /Library/Application Support/FAHClient/config.xml
05:28:59:******************************** Build ********************************
05:28:59: Version: 7.4.4
05:28:59: Date: Mar 4 2014
05:28:59: Time: 20:27:54
05:28:59: SVN Rev: 4130
05:28:59: Branch: fah/trunk/client
05:28:59: Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
05:28:59: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
05:28:59: -fno-unsafe-math-optimizations -msse3 -arch x86_64
05:28:59: -mmacosx-version-min=10.6
05:28:59: Platform: darwin 10.8.0
05:28:59: Bits: 64
05:28:59: Mode: Release
05:28:59:******************************* System ********************************
05:28:59: CPU: Intel(R) Core(TM) i5-4570S CPU @ 2.90GHz
05:28:59: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
05:28:59: CPUs: 4
05:28:59: Memory: 8.00GiB
05:28:59:Free Memory: 5.97GiB
05:28:59: Threads: POSIX_THREADS
05:28:59: OS Version: 10.10
05:28:59:Has Battery: false
05:28:59: On Battery: false
05:28:59: UTC Offset: -6
05:28:59: PID: 508
05:28:59: CWD: /Library/Application Support/FAHClient
05:28:59: OS: Darwin 14.3.0 x86_64
05:28:59: OS Arch: AMD64
05:28:59: GPUs: 1
05:28:59: GPU 0: NVIDIA:3 GK107M [GeForce GT 750M Mac Edition]
05:28:59: CUDA: Not detected
05:28:59:***********************************************************************Code: Select all
05:28:59:<config>
05:28:59: <!-- Network -->
05:28:59: <proxy v=':8080'/>
05:28:59:
05:28:59: <!-- User Information -->
05:28:59: <passkey v='********************************'/>
05:28:59: <team v='30'/>
05:28:59: <user v='JungleOnion_ALL_1PdLWsvxd21dFrDTiNrimtEeiSibPWqbop '/>
05:28:59:
05:28:59: <!-- Folding Slots -->
05:28:59: <slot id='0' type='CPU'/>
05:28:59: <slot id='1' type='GPU'/>
05:28:59:</config>
05:28:59:Trying to access database...
05:28:59:Successfully acquired database lock
05:28:59:Enabled folding slot 00: READY cpu:2
05:28:59:Enabled folding slot 01: READY gpu:0:GK107M [GeForce GT 750M Mac Edition]
05:28:59:WU00:FS00:Starting
05:28:59:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/web.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 704 -lifeline 508 -checkpoint 15 -np 2
05:28:59:WU00:FS00:Started FahCore on PID 509
05:28:59:WU00:FS00:Core PID:510
05:28:59:WU00:FS00:FahCore 0xa4 started
05:29:00:WU00:FS00:0xa4:
05:29:00:WU00:FS00:0xa4:*------------------------------*
05:29:00:WU00:FS00:0xa4:Folding@Home Gromacs Core
05:29:00:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
05:29:00:WU00:FS00:0xa4:Preparing to commence simulation
05:29:00:WU00:FS00:0xa4:- Ensuring status. Please wait.
05:29:03:WU01:FS01:Connecting to 171.67.108.45:80
05:29:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:29:04:WU01:FS01:Connecting to 171.67.108.204:80
05:29:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:29:04:ERROR:WU01:FS01:Exception: Could not get an assignment
05:29:05:WU01:FS01:Connecting to 171.67.108.45:80
05:29:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:29:05:WU01:FS01:Connecting to 171.67.108.204:80
05:29:06:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:29:06:ERROR:WU01:FS01:Exception: Could not get an assignment
05:29:09:WU00:FS00:0xa4:- Looking at optimizations...
05:29:11:WU00:FS00:0xa4:- Files status OK
05:29:11:WU00:FS00:0xa4:- Expanded 825833 -> 1401112 (decompressed 169.6 percent)
05:29:11:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825833 data_size=1401112, decompressed_data_size=1401112 diff=0
05:29:11:WU00:FS00:0xa4:- Digital signature verified
05:29:11:WU00:FS00:0xa4:Project: 9034 (Run 117, Clone 5, Gen 12)
05:29:27:WU00:FS00:0xa4:Assembly optimizations on if available.
05:29:27:WU00:FS00:0xa4:Entering M.D.
05:29:32:WU00:FS00:0xa4:Using Gromacs checkpoints
05:29:33:WU00:FS00:0xa4:Mapping NT from 2 to 2
05:29:33:WU00:FS00:0xa4:Resuming from checkpoint
05:29:33:WU00:FS00:0xa4:Verified 00/wudata_01.log
05:29:34:WU00:FS00:0xa4:Verified 00/wudata_01.trr
05:29:34:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
05:29:35:WU00:FS00:0xa4:Verified 00/wudata_01.edr
05:29:35:WU00:FS00:0xa4:Completed 236950 out of 250000 steps (94%)
05:30:05:WU01:FS01:Connecting to 171.67.108.45:80
05:30:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:30:05:WU01:FS01:Connecting to 171.67.108.204:80
05:30:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:30:05:ERROR:WU01:FS01:Exception: Could not get an assignment
05:30:13:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
05:31:42:WU01:FS01:Connecting to 171.67.108.45:80
05:31:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:31:43:WU01:FS01:Connecting to 171.67.108.204:80
05:31:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:31:43:ERROR:WU01:FS01:Exception: Could not get an assignment
05:33:03:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
05:34:19:WU01:FS01:Connecting to 171.67.108.45:80
05:34:20:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:34:20:WU01:FS01:Connecting to 171.67.108.204:80
05:34:20:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:34:20:ERROR:WU01:FS01:Exception: Could not get an assignment
05:35:53:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
05:38:33:WU01:FS01:Connecting to 171.67.108.45:80
05:38:34:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:38:34:WU01:FS01:Connecting to 171.67.108.204:80
05:38:34:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: Connection refused
05:38:34:ERROR:WU01:FS01:Exception: Could not get an assignment
05:38:39:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
05:41:26:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
05:41:26:WU02:FS00:Connecting to 171.67.108.45:8080
05:41:27:WU02:FS00:Assigned to work server 171.67.108.158
05:41:27:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.67.108.158
05:41:27:WU02:FS00:Connecting to 171.67.108.158:8080
05:41:28:WU02:FS00:Downloading 807.27KiB
05:41:29:WU02:FS00:Download complete
05:41:29:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9035
OS X is the source of the problem. GPU folding on OS X is not currently available. The background is that until last year there was a bug in the OS X implementation of OpenCL that was only fixed last year. Since then there has been no update on whether that will result in a working folding core for GPU's on OS X.
You may be able to do GPU folding using Windows through Boot Camp. That would have your Mac booted natively into Windows and would only require that you use video drivers listed as compatible with that environment.
ChristianVirtual
And here we have the problem: no GPU folding supported at this point in time for us Mac user; we are CPU only.
Historically the driver implementation from Apple was not sufficient for the needs of FAH; meanwhile that seems solved (and reported working with the OpenMM framework). Assuming due to higher priorities in Development no GPU core yet made it to Macs.
That's why I have my GPU-folding systems running under Linux.
JungleOnion
Thank you for the clarification. I was wondering how to install linux or windows as a dual boot or triple boot, I will keep looking how to properly do one and definitely start folding with my GPU hopefullyJoe_H wrote:OS X is the source of the problem. GPU folding on OS X is not currently available. The background is that until last year there was a bug in the OS X implementation of OpenCL that was only fixed last year. Since then there has been no update on whether that will result in a working folding core for GPU's on OS X.
JungleOnion
It sucks that there is no support for OSX but well...I know is not a good OS for mining or folding or even gamingChristianVirtual wrote:And here we have the problem: no GPU folding supported at this point in time for us Mac user; we are CPU only.
Points at Stanford are not like mining ... they're representative of donations.JungleOnion wrote:How much are points valued or how do they work? I will go through the forums to see what can I find about that.
There are 3rd party mining sites that award virtual currency based on FAH's points, but we don't officially support them.
JungleOnion
Oh I understand, like bitcrystals?bruce wrote:Points at Stanford are not like mining ... they're representative of donations.JungleOnion wrote:How much are points valued or how do they work? I will go through the forums to see what can I find about that.
