Add second gpu to fold
stiv88
Post by stiv88 »
Hi all, today i bought new gpu and i want fold with. Can someone wrote how to add it to folding? I must have enabled SLI?
980ti
Thanks.
Re: Add second gpu to fold
Welcome to the folding forum.
Adding a GPU to folding basically requires your to add the GPU to your system, install the full drivers downloaded from the nVidia or AMD-ATI site as appropriate, and install the folding client. If you have the folding client already installed, an uninstall followed by a reinstall is recommended after a change in hardware.
Some of the details will depend on which OS you are running, and in the case of Linux may involve manually downloading the GPUs.txt file if it is not automatically updated during installation of the folding client.
stiv88
Post by stiv88 »
I have all drivers installed. Both cards works good in games. I have enabled SLI mode in driver.
But in folding only one card work - http://i.imgur.com/GAFSNlY.png look at gpu usage.
Im running on windows 10 pro.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Post by rwh202 »
You'll need to add a second GPU slot to get both folding - folding doesn't make use of sli or crossfire and will run a separate task on each GPU.
stiv88
Post by stiv88 »
How i can add second GPU slot?
stiv88 wrote:How i can add second GPU slot?
Did you follow the directions Joe_H posted above?
rwh202
3x GTX 1080 Ti
3x GTX 1060
Post by rwh202 »
An uninstall and reinstall is probably the safest method, but configure>slots>add>GPU should work too
stiv88
Post by stiv88 »
reinstall with delete data works. thanks for help. :ewink:
