GTX Titan X Pascal
GTX Titan X Pascal
Please to add Nvidia GTX Titan X Pascal to GPU.txt.
Re: GTX Titan X Pascal
Please read this topic and provide the information requested - viewtopic.php?f=83&t=26208#p262894. Without information such as a device ID, new cards can not be added to GPUs.txt.
Already enabled a few weeks ago. Is this not working for you? Please post more info about what is not working.DMMD wrote:Please to add Nvidia GTX Titan X Pascal to GPU.txt.
For reference, the device ID is 0x1b00. GPU-Z screen shot on this reviewers page. Thanks.
Please add Tesla P100-SXM2 as well.
here is the info :
Timestamp : Thu Aug 18 14:33:23 2016
Driver Version : 361.83
Attached GPUs : 4
GPU 0000:05:00.0
Product Name : Tesla P100-SXM2-16GB
Product Brand : Tesla
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 1920
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0322716102370
GPU UUID : GPU-b769a9bc-0202-94b1-613c-4514c80e7c56
Minor Number : 0
VBIOS Version : 86.00.1C.00.01
MultiGPU Board : No
Board ID : 0x500
GPU Part Number : 900-2H403-0000-000
Inforom Version
Image Version : H403.0201.00.04
OEM Object : 1.1
ECC Object : 4.1
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
Device Id : 0x15F910DE
Bus Id : 0000:05:00.0
Sub System Id : 0x116B10DE
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons
Idle : Not Active
Applications Clocks Setting : Active
SW Power Cap : Not Active
HW Slowdown : Not Active
Sync Boost : Not Active
Unknown : Not Active
FB Memory Usage
Total : 16280 MiB
Used : 0 MiB
Free : 16280 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 2 MiB
Free : 16382 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Aggregate
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending : No
Temperature
GPU Current Temp : 44 C
GPU Shutdown Temp : 85 C
GPU Slowdown Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 39.75 W
Power Limit : 300.00 W
Default Power Limit : 300.00 W
Enforced Power Limit : 300.00 W
Min Power Limit : 150.00 W
Max Power Limit : 300.00 W
Clocks
Graphics : 1336 MHz
SM : 1336 MHz
Memory : 715 MHz
Video : 1202 MHz
Applications Clocks
Graphics : 1328 MHz
Memory : 715 MHz
Default Applications Clocks
Graphics : 1328 MHz
Memory : 715 MHz
Max Clocks
Graphics : 1480 MHz
SM : 1480 MHz
Memory : 715 MHz
Video : 1480 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
here is the info :
Attached GPUs : 4
GPU 0000:05:00.0
Driver Model
Current : N/A
Pending : N/A
Minor Number : 0
MultiGPU Board : No
Board ID : 0x500
Inforom Version
OEM Object : 1.1
ECC Object : 4.1
GPU Operation Mode
Current : N/A
Pending : N/A
PCI
Bus : 0x05
Device : 0x00
Domain : 0x0000
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : N/A
Idle : Not Active
FB Memory Usage
Total : 16280 MiB
Used : 0 MiB
Free : 16280 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 2 MiB
Free : 16382 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Aggregate
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
Total : 0
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending : No
Temperature
Power Readings
Clocks
Graphics : 1336 MHz
SM : 1336 MHz
Memory : 715 MHz
Video : 1202 MHz
Applications Clocks
Graphics : 1328 MHz
Memory : 715 MHz
Graphics : 1328 MHz
Memory : 715 MHz
Max Clocks
Graphics : 1480 MHz
SM : 1480 MHz
Memory : 715 MHz
Video : 1480 MHz
Clock Policy
Auto Boost : N/A
Processes : None
Already enabled as well, but I didn't have the description at the time. I will update the xxx part.
0x10de:0x15f9:2:5:GP100GL [xxx]
