What is wrong with my sig? [use static image]
gunderwood
Post by gunderwood »
Why won't it show up as a img?
It's a dynamical image ... it's not supported by IMG tag (only gif,jpg,png, ...)
gunderwood
toTOW wrote:It's a dynamical image ... it's not supported by IMG tag (only gif,jpg,png, ...)
Ok, how do I fix it? I have seen this used on other sigs. I took the code directly off of the site (they give it as an example).
codysluder
Post by codysluder »
gunderwood wrote:Ok, how do I fix it? I have seen this used on other sigs. I took the code directly off of the site (they give it as an example).
The example may work on some bulletin boards but not in this software. You have to have one of the filetypes mentioned by toTOW.
gunderwood
That was what I was afraid of. I decided to just use a link instead. Thanks.
I modified the thread title.
If you're good enough at PHP, you could parse stanford text files and generate an image in a supported format with gd (for example) ... :roll:
