I am having trouble getting my two GPUs to both fold.
Bosses_Boss
Hardware configuration: i7 5820k 4.4GHz under custom loop, 2GHz MSI 1070 Gaming, 1.6GHz 980 Ti Gaming, Corsair AXi 1500
http://ca.pcpartpicker.com/list/GKHvVY
Waiting on a mobo RMA to get my F@H server up.
Post by Bosses_Boss »
I have a 1070 and a 980 Ti in the same system that I want to use for folding. I have done this before when I had a 980 Ti and a 970. Worked just fine, now I can't get them to work. Do I have to use a 10 series GPU for it to show up?
I want to use the 980 Ti for 24/7 folding while I gaming on the 1070 and when I don't game I will have the 1070 fold.
BIOS detects both cards, MSI Afterburner does as well.
What do I have to do to make this work?
Thank you
i7 5820k [4.4GHz] | MSI 1070 Gaming | MSI 980 Ti Sea Hawk | Corsair AXi 1500 | Custom 480mm CPU waterloop
Re: I am having trouble getting my two GPUs to both fold.
Re-install the client so that it auto detects the new hardware.
ChristianVirtual
Post by ChristianVirtual »
Welcome Bosses_Boss
Looks like you have the same mix of GPU as I have. I assume you use Windows while I use Linux for folding. Both 980TI and 1070 can perfectly be installed in the same system. Given power supply and cooling is sufficient.
What would be helpful if you could share the driver version you are using and the first 100 lines of the folding logfile. Showing us more details about your system and what GPUs are detected.
That link might be helpful viewtopic.php?f=24&t=26036
Bosses_Boss
ChristianVirtual wrote:Welcome Bosses_Boss
Thank you so much for the reply. I am looking through your link, I found it before making the post.
Driver version as in F@H version? That is 7.4.4.
I will look for the log file now. Where would that be exactly? EDIT: I am an idiot... Sorry
*********************** Log Started 2016-08-02T14:31:20Z ***********************
14:31:20:************************* Folding@home Client *************************
14:31:20:      Website: http://folding.stanford.edu/
14:31:20:    Copyright: (c) 2009-2014 Stanford University
14:31:20:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:31:20:         Args: --open-web-control
14:31:20:       Config: C:/Users/Bosses/AppData/Roaming/FAHClient/config.xml
14:31:20:******************************** Build ********************************
14:31:20:      Version: 7.4.4
14:31:20:         Date: Mar 4 2014
14:31:20:         Time: 20:26:54
14:31:20:      SVN Rev: 4130
14:31:20:       Branch: fah/trunk/client
14:31:20:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:31:20:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:31:20:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:31:20:     Platform: win32 XP
14:31:20:         Bits: 32
14:31:20:         Mode: Release
14:31:20:******************************* System ********************************
14:31:20:          CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
14:31:20:       CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
14:31:20:         CPUs: 12
14:31:20:       Memory: 31.90GiB
14:31:20:  Free Memory: 24.85GiB
14:31:20:      Threads: WINDOWS_THREADS
14:31:20:   OS Version: 6.2
14:31:20:  Has Battery: false
14:31:20:   On Battery: false
14:31:20:   UTC Offset: -6
14:31:20:          PID: 6252
14:31:20:          CWD: C:/Users/Bosses/AppData/Roaming/FAHClient
14:31:20:           OS: Windows 10 Home
14:31:20:      OS Arch: AMD64
14:31:20:         GPUs: 3
14:31:20:        GPU 0: UNSUPPORTED: NV3 [PCI]
14:31:20:        GPU 1: NVIDIA:5 GP104 [GeForce GTX 1070]
14:31:20:        GPU 2: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
14:31:20:         CUDA: 6.1
14:31:20:  CUDA Driver: 8000
14:31:20:Win32 Service: false
14:31:20:***********************************************************************
14:31:20:<config>
14:31:20:  <service-description v='Folding@home Client'/>
14:31:20:  <service-restart v='true'/>
14:31:20:  <service-restart-delay v='5000'/>
14:31:20:
14:31:20:  <!-- Client Control -->
14:31:20:  <client-threads v='6'/>
14:31:20:  <cycle-rate v='4'/>
14:31:20:  <cycles v='-1'/>
14:31:20:  <data-directory v='.'/>
14:31:20:  <disable-sleep-when-active v='true'/>
14:31:20:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
14:31:20:  <exit-when-done v='false'/>
14:31:20:  <fold-anon v='false'/>
14:31:20:  <open-web-control v='true'/>
14:31:20:
14:31:20:  <!-- Configuration -->
14:31:20:  <config-rotate v='true'/>
14:31:20:  <config-rotate-dir v='configs'/>
14:31:20:  <config-rotate-max v='16'/>
14:31:20:
14:31:20:  <!-- Debugging -->
14:31:20:  <assignment-servers>
14:31:20:    assign3.stanford.edu:8080 assign4.stanford.edu:80
14:31:20:  </assignment-servers>
14:31:20:  <auth-as v='true'/>
14:31:20:  <capture-directory v='capture'/>
14:31:20:  <capture-on-error v='false'/>
14:31:20:  <capture-packets v='false'/>
14:31:20:  <capture-requests v='false'/>
14:31:20:  <capture-responses v='false'/>
14:31:20:  <capture-sockets v='false'/>
14:31:20:  <core-exec v='FahCore_$type'/>
14:31:20:  <core-wrapper-exec v='FAHCoreWrapper'/>
14:31:20:  <debug-sockets v='false'/>
14:31:20:  <exception-locations v='true'/>
14:31:20:  <gpu-assignment-servers>
14:31:20:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
14:31:20:  </gpu-assignment-servers>
14:31:20:  <stack-traces v='false'/>
14:31:20:
14:31:20:  <!-- Error Handling -->
14:31:20:  <max-slot-errors v='10'/>
14:31:20:  <max-unit-errors v='5'/>
14:31:20:
14:31:20:  <!-- Folding Core -->
14:31:20:  <checkpoint v='5'/>
14:31:20:  <core-dir v='cores'/>
14:31:20:  <core-priority v='idle'/>
14:31:20:  <cpu-affinity v='false'/>
14:31:20:  <cpu-usage v='100'/>
14:31:20:  <gpu-usage v='100'/>
14:31:20:  <no-assembly v='false'/>
14:31:20:
14:31:20:  <!-- Folding Slot Configuration -->
14:31:20:  <cause v='ANY'/>
14:31:20:  <client-subtype v='STDCLI'/>
14:31:20:  <client-type v='normal'/>
14:31:20:  <cpu-species v='X86_PENTIUM_II'/>
14:31:20:  <cpu-type v='AMD64'/>
14:31:20:  <cpus v='-1'/>
14:31:20:  <gpu v='true'/>
14:31:20:  <max-packet-size v='normal'/>
14:31:20:  <os-species v='UNKNOWN'/>
14:31:20:  <os-type v='WIN32'/>
14:31:20:  <project-key v='0'/>
14:31:20:  <smp v='true'/>
14:31:20:
14:31:20:  <!-- GUI -->
14:31:20:  <gui-enabled v='true'/>
14:31:20:
14:31:20:  <!-- HTTP Server -->
14:31:20:  <allow v='127.0.0.1'/>
14:31:20:  <connection-timeout v='60'/>
14:31:20:  <deny v='0/0'/>
14:31:20:  <http-addresses v='0:7396'/>
14:31:20:  <https-addresses v=''/>
14:31:20:  <max-connect-time v='900'/>
14:31:20:  <max-connections v='800'/>
14:31:20:  <max-request-length v='52428800'/>
14:31:20:  <min-connect-time v='300'/>
14:31:20:  <threads v='12'/>
14:31:20:
14:31:20:  <!-- Logging -->
14:31:20:  <log v='log.txt'/>
14:31:20:  <log-color v='false'/>
14:31:20:  <log-crlf v='true'/>
14:31:20:  <log-date v='false'/>
14:31:20:  <log-date-periodically v='21600'/>
14:31:20:  <log-debug v='true'/>
14:31:20:  <log-domain v='false'/>
14:31:20:  <log-header v='true'/>
14:31:20:  <log-level v='true'/>
14:31:20:  <log-no-info-header v='true'/>
14:31:20:  <log-redirect v='false'/>
14:31:20:  <log-rotate v='true'/>
14:31:20:  <log-rotate-dir v='logs'/>
14:31:20:  <log-rotate-max v='16'/>
14:31:20:  <log-short-level v='false'/>
14:31:20:  <log-simple-domains v='true'/>
14:31:20:  <log-thread-id v='false'/>
14:31:20:  <log-thread-prefix v='true'/>
14:31:20:  <log-time v='true'/>
14:31:20:  <log-to-screen v='true'/>
14:31:20:  <log-truncate v='false'/>
14:31:20:  <verbosity v='5'/>
14:31:20:
14:31:20:  <!-- Network -->
14:31:20:  <proxy v=':8080'/>
14:31:20:  <proxy-enable v='false'/>
14:31:20:  <proxy-pass v=''/>
14:31:20:  <proxy-user v=''/>
14:31:20:
14:31:20:  <!-- Process Control -->
14:31:20:  <child v='false'/>
14:31:20:  <daemon v='false'/>
14:31:20:  <pid v='false'/>
14:31:20:  <pid-file v='Folding@home Client.pid'/>
14:31:20:  <respawn v='false'/>
14:31:20:  <service v='false'/>
14:31:20:
14:31:20:  <!-- Remote Command Server -->
14:31:20:  <command-address v='0.0.0.0'/>
14:31:20:  <command-allow-no-pass v='127.0.0.1'/>
14:31:20:  <command-deny-no-pass v='0/0'/>
14:31:20:  <command-enable v='true'/>
14:31:20:  <command-port v='36330'/>
14:31:20:
14:31:20:  <!-- Slot Control -->
14:31:20:  <idle v='false'/>
14:31:20:  <max-shutdown-wait v='60'/>
14:31:20:  <pause-on-battery v='true'/>
14:31:20:  <pause-on-start v='false'/>
14:31:20:  <paused v='false'/>
14:31:20:  <power v='full'/>
14:31:20:
14:31:20:  <!-- User Information -->
14:31:20:  <machine-id v='0'/>
14:31:20:  <passkey v='********************************'/>
14:31:20:  <team v='225605'/>
14:31:20:  <user v='Bosses_Boss'/>
14:31:20:
14:31:20:  <!-- Web Server -->
14:31:20:  <web-allow v='127.0.0.1'/>
14:31:20:  <web-deny v='0/0'/>
14:31:20:  <web-enable v='true'/>
14:31:20:
14:31:20:  <!-- Web Server Sessions -->
14:31:20:  <session-cookie v='sid'/>
14:31:20:  <session-lifetime v='86400'/>
14:31:20:  <session-timeout v='3600'/>
14:31:20:
14:31:20:  <!-- Work Unit Control -->
14:31:20:  <dump-after-deadline v='true'/>
14:31:20:  <max-queue v='16'/>
14:31:20:  <max-units v='0'/>
14:31:20:  <next-unit-percentage v='99'/>
14:31:20:  <stall-detection-enabled v='false'/>
14:31:20:  <stall-percent v='5'/>
14:31:20:  <stall-timeout v='1800'/>
14:31:20:
14:31:20:  <!-- Folding Slots -->
14:31:20:  <slot id='0' type='CPU'>
14:31:20:    <cpus v='5'/>
14:31:20:    <pause-on-start v='true'/>
14:31:20:  </slot>
14:31:20:  <slot id='1' type='GPU'>
14:31:20:    <max-packet-size v='big'/>
14:31:20:  </slot>
14:31:20:</config>
Oh and I know I got the power to run the system, I am running my system on a Corsair AXi 1500w PSU, and have checked the connections to be sure as well.
F@H and program screenshots - https://imgur.com/a/UBuND
PC - http://i.imgur.com/HskumRF.jpg
Bosses_Boss
7im wrote:Re-install the client so that it auto detects the new hardware.
Tried this, did not work. Any other ideas?
He asked about the video driver version from NVidia, especially because Windows 10 has a bad habit of replacing the OEM NV driver that works with a Win 10 driver that doesn't work for folding.
To avoid future problems, you will want to disable video driver updates from MS, and then reinstall the NV drivers.
Please return the logging verbosity to the default of 3. The higher level does not provide any extra useful information and actually gets in the way of troubleshooting a problem.
Bosses_Boss
7im wrote:He asked about the video driver version from NVidia, especially because Windows 10 has a bad habit of replacing the OEM NV driver that works with a Win 10 driver that doesn't work for folding.
I have that disabled. Unless MS has re-enabled which I wouldn't be surprised about.
I have updated to a new driver trying to figure this out as well, didn't change. Also tried to reinstall NV driver and FAH client at the same time.
Bosses_Boss
Joe_H wrote:Please return the logging verbosity to the default of 3. The higher level does not provide any extra useful information and actually gets in the way of troubleshooting a problem.
Ah okay, this is my troubleshooting, TRY ALL THE THINGS :p Will this change the log and do you want me to copy it here again?
Bosses_Boss wrote:Will this change the log and do you want me to copy it here again?
I do. If possible, edit your previous post.
Was your reinstall of the NV driver a "clean" install?
Bosses_Boss
Thanks for the reply, updated log.
It wasn't a clean install. I will do that now.
Edit: still not working.
Remove this for the GPU:
ChristianVirtual
Can you please add few more lines after you stopped in the log above ? There will be a list of detected GPUs and the assigned slots. Just for completes.
Some lines like. "Enabled folding slot 01: READY gpu:1:GP104 [GeForce GTX 1070] "
What happen if you just try to add a new GPU slot ? Or two (to cover the unsupported audio part of the 1070 identified as GPU).
What is different to my setup: I have the 980Ti as first card behind the CPU. But based on you description of want 24/7 on 980TI and 1070 for gaming/folding your physical setup seems matching.
Bosses_Boss
7im wrote:Remove this for the GPU:
Yeah I just wanted to see what it did. Removed it now.
Bosses_Boss
ChristianVirtual wrote:Can you please add few more lines after you stopped in the log above ? There will be a list of detected GPUs and the assigned slots. Just for completes.
I am so sorry, I've had a shitty day with ear aches and a migraine headache and am not at my best. I reread the first link you sent me and it had the walkthrough to add a GPU slot.
I just added a GPU slot for GPU 2 [which in the log is the 980 Ti] now and it worked, flawlessly. I don't know how I either forgot this process last time or the 970 was immediately picked up by FAH.
Thank you, I am so sorry for wasting everyones time. She's chugging away now. http://i.imgur.com/uZDve1U.png
Again,
Thank you!
Sincerely,
Bosses_Boss
