Failed to connect to 171.64.65.99
I'm having problems with the server named above. My cpu is supposed to send to and (I presume) get its next job from this server. Unfortunately, there is no uploading going on; and, so, there is no downloading going on either. I believe I may see a problem with its current, unsent but finished, job. Looking just below the "Next Attempt" line in the main Control window("Status" Tab), the next three lines below ("Assigned," "Time Out," and "Expiration") all show after their the exact same time, which is: 2016-07-30T10:10:46Z.
It makes sense that an expired job might not be sent back in; but, usually downloads occur before the final few seconds of processing a job, and they sit there, actually downloaded, waiting for the old job to finish, at which point the new job begins. So this looks like the server may be down (there is no collection server assigned in this case), but the server shows as being up. So, I don't know what the hell to do. I tried changing the number of cores for the cpu from 5 to 4, then back again several minutes later, to no effect.
Re: Failed to connect to 171.64.65.99
171.64.65.99 has been set to "accepting" which means no new WUs will be distributed from it. The assignment server SHOULD inform your client that new work must be obtained elsewhere.
The client SHOULD also discard any WU which has not been returned by the (final) deadline.
This has nothing to do with whether or not a previous WU will be uploaded to the server that originally assigned the WU.
Post your log showing the problem.
Bruce may have confused this WS with another. The WS is currently set to "full" and "accepting" which means it should be accepting connections both for returns and new assignments. However the Net Load is above 1000, and has been since earlier today. That usually indicates a problem on the server, I will notify the person responsible for it.
However, as he pointed out that should not prevent you from being assigned another WU from a different WS. Post your log showing the problem of getting a new WU.
In the time since I posted the original problem, I didn't check back here (in the Forum) until now. Yesterday afternoon, I just gave up that things would change, so I set everything to finish and came back many hours later, after all GPU jobs were done. At that point I uninstalled and reinstalled both the client and control files. A new cpu job was downloaded; but when I came back again (hours later) it had finished that first cpu job, but was sitting awaiting for another job, but it had at least sent off the results of that first job. The cpu since then has been sitting vacant all zeros for work and collection server designations. I've tried a few times, last night, morning, and now this afternoon to get another job by pausing then restarting it, but to no avail.
This is a linux system. Mint 17.3, with a i6700k processor. I can't remember exactly how to post a log file. I've tried copy and paste, but that ends up with way too many characters and doesn't insert the scrollable box one usually sees.
Past the log between [code]...[/code] tags and then delete whatever is repetitive or not applicable to the issue being discussed until it's within the limits. (See also the link in the signature block of my previous post.)
Ah, ok. So far as I can tell, it's attempting to get jobs from servers that OBVIOUSLY are not coded as 0.0.0.0, as shows up on the Status tab.
You can see the non-functioning servers are now 171.67.108.45:8080, and 171.64.65.35:80, or so it appears to me. Those two servers showing errors have remained the same since the beginning of the log.
00:19:57:WU03:FS02:0x18:*********************** Log Started 2016-08-02T00:19:57Z ***********************
00:19:57:WU03:FS02:0x18:Project: 9679 (Run 1, Clone 23, Gen 30)
00:19:57:WU03:FS02:0x18:Unit: 0x00000021ab436c9b56de69bfcef9a832
00:19:57:WU03:FS02:0x18:CPU: 0x00000000000000000000000000000000
00:19:57:WU03:FS02:0x18:Machine: 2
00:19:57:WU03:FS02:0x18:Reading tar file core.xml
00:19:57:WU03:FS02:0x18:Reading tar file integrator.xml
00:19:57:WU03:FS02:0x18:Reading tar file state.xml
00:19:57:WU03:FS02:0x18:Reading tar file system.xml
00:19:57:WU03:FS02:0x18:Digital signatures verified
00:19:57:WU03:FS02:0x18:Folding@home GPU core18
00:19:57:WU03:FS02:0x18:Version 0.0.4
00:19:59:WU03:FS02:0x18:Completed 0 out of 2000000 steps (0%)
00:19:59:WU03:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:20:00:WU04:FS03:0x21:Completed 0 out of 1600000 steps (0%)
00:20:00:WU04:FS03:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:20:04:WU00:FS02:Upload 29.74%
00:20:11:WU03:FS02:0x18:Completed 20000 out of 2000000 steps (1%)
00:20:11:WU00:FS02:Upload 50.99%
00:20:17:WU00:FS02:Upload 68.37%
00:20:23:WU03:FS02:0x18:Completed 40000 out of 2000000 steps (2%)
00:20:24:WU00:FS02:Upload 90.77%
00:20:35:WU03:FS02:0x18:Completed 60000 out of 2000000 steps (3%)
00:20:39:WU00:FS02:Upload complete
00:20:39:WU00:FS02:Server responded WORK_ACK (400)
00:20:39:WU00:FS02:Final credit estimate, 146183.00 points
00:20:40:WU00:FS02:Cleaning up
00:20:47:WU03:FS02:0x18:Completed 80000 out of 2000000 steps (4%)
00:20:48:WU02:FS01:0x18:Completed 250000 out of 5000000 steps (5%)
00:20:59:WU03:FS02:0x18:Completed 100000 out of 2000000 steps (5%)
00:21:11:WU03:FS02:0x18:Completed 120000 out of 2000000 steps (6%)
00:21:23:WU03:FS02:0x18:Completed 140000 out of 2000000 steps (7%)
00:21:35:WU03:FS02:0x18:Completed 160000 out of 2000000 steps (8%)
00:21:47:WU03:FS02:0x18:Completed 180000 out of 2000000 steps (9%)
00:21:59:WU03:FS02:0x18:Completed 200000 out of 2000000 steps (10%)
00:22:02:WU04:FS03:0x21:Completed 16000 out of 1600000 steps (1%)
00:22:11:WU03:FS02:0x18:Completed 220000 out of 2000000 steps (11%)
00:22:22:WU02:FS01:0x18:Completed 300000 out of 5000000 steps (6%)
00:22:23:WU03:FS02:0x18:Completed 240000 out of 2000000 steps (12%)
00:22:35:WU03:FS02:0x18:Completed 260000 out of 2000000 steps (13%)
00:22:47:WU03:FS02:0x18:Completed 280000 out of 2000000 steps (14%)
00:22:59:WU03:FS02:0x18:Completed 300000 out of 2000000 steps (15%)
00:23:11:WU03:FS02:0x18:Completed 320000 out of 2000000 steps (16%)
00:23:23:WU03:FS02:0x18:Completed 340000 out of 2000000 steps (17%)
00:23:35:WU03:FS02:0x18:Completed 360000 out of 2000000 steps (18%)
00:23:47:WU03:FS02:0x18:Completed 380000 out of 2000000 steps (19%)
00:23:55:WU02:FS01:0x18:Completed 350000 out of 5000000 steps (7%)
00:23:59:WU03:FS02:0x18:Completed 400000 out of 2000000 steps (20%)
00:24:04:WU04:FS03:0x21:Completed 32000 out of 1600000 steps (2%)
00:24:11:WU03:FS02:0x18:Completed 420000 out of 2000000 steps (21%)
00:24:23:WU03:FS02:0x18:Completed 440000 out of 2000000 steps (22%)
00:24:35:WU03:FS02:0x18:Completed 460000 out of 2000000 steps (23%)
00:24:47:WU03:FS02:0x18:Completed 480000 out of 2000000 steps (24%)
00:24:59:WU03:FS02:0x18:Completed 500000 out of 2000000 steps (25%)
00:25:11:WU03:FS02:0x18:Completed 520000 out of 2000000 steps (26%)
00:25:23:WU03:FS02:0x18:Completed 540000 out of 2000000 steps (27%)
00:25:30:WU02:FS01:0x18:Completed 400000 out of 5000000 steps (8%)
00:25:35:WU03:FS02:0x18:Completed 560000 out of 2000000 steps (28%)
00:25:47:WU03:FS02:0x18:Completed 580000 out of 2000000 steps (29%)
00:25:59:WU03:FS02:0x18:Completed 600000 out of 2000000 steps (30%)
00:26:08:WU04:FS03:0x21:Completed 48000 out of 1600000 steps (3%)
00:26:12:WU03:FS02:0x18:Completed 620000 out of 2000000 steps (31%)
00:26:24:WU03:FS02:0x18:Completed 640000 out of 2000000 steps (32%)
00:26:36:WU03:FS02:0x18:Completed 660000 out of 2000000 steps (33%)
00:26:48:WU03:FS02:0x18:Completed 680000 out of 2000000 steps (34%)
00:27:00:WU03:FS02:0x18:Completed 700000 out of 2000000 steps (35%)
00:27:02:WU02:FS01:0x18:Completed 450000 out of 5000000 steps (9%)
00:27:12:WU03:FS02:0x18:Completed 720000 out of 2000000 steps (36%)
00:27:24:WU03:FS02:0x18:Completed 740000 out of 2000000 steps (37%)
00:27:36:WU03:FS02:0x18:Completed 760000 out of 2000000 steps (38%)
00:27:48:WU03:FS02:0x18:Completed 780000 out of 2000000 steps (39%)
00:28:00:WU03:FS02:0x18:Completed 800000 out of 2000000 steps (40%)
00:28:11:WU04:FS03:0x21:Completed 64000 out of 1600000 steps (4%)
00:28:13:WU03:FS02:0x18:Completed 820000 out of 2000000 steps (41%)
00:28:25:WU03:FS02:0x18:Completed 840000 out of 2000000 steps (42%)
00:28:34:WU02:FS01:0x18:Completed 500000 out of 5000000 steps (10%)
00:28:37:WU03:FS02:0x18:Completed 860000 out of 2000000 steps (43%)
00:28:49:WU03:FS02:0x18:Completed 880000 out of 2000000 steps (44%)
00:29:01:WU03:FS02:0x18:Completed 900000 out of 2000000 steps (45%)
00:29:13:WU03:FS02:0x18:Completed 920000 out of 2000000 steps (46%)
00:29:25:WU03:FS02:0x18:Completed 940000 out of 2000000 steps (47%)
00:29:37:WU03:FS02:0x18:Completed 960000 out of 2000000 steps (48%)
00:29:49:WU03:FS02:0x18:Completed 980000 out of 2000000 steps (49%)
00:30:01:WU03:FS02:0x18:Completed 1000000 out of 2000000 steps (50%)
00:30:09:WU02:FS01:0x18:Completed 550000 out of 5000000 steps (11%)
00:30:13:WU04:FS03:0x21:Completed 80000 out of 1600000 steps (5%)
00:30:13:WU03:FS02:0x18:Completed 1020000 out of 2000000 steps (51%)
00:30:25:WU03:FS02:0x18:Completed 1040000 out of 2000000 steps (52%)
00:30:37:WU03:FS02:0x18:Completed 1060000 out of 2000000 steps (53%)
00:30:49:WU03:FS02:0x18:Completed 1080000 out of 2000000 steps (54%)
00:31:01:WU03:FS02:0x18:Completed 1100000 out of 2000000 steps (55%)
00:31:13:WU03:FS02:0x18:Completed 1120000 out of 2000000 steps (56%)
00:31:25:WU03:FS02:0x18:Completed 1140000 out of 2000000 steps (57%)
00:31:37:WU03:FS02:0x18:Completed 1160000 out of 2000000 steps (58%)
00:31:42:WU02:FS01:0x18:Completed 600000 out of 5000000 steps (12%)
00:31:49:WU03:FS02:0x18:Completed 1180000 out of 2000000 steps (59%)
00:32:01:WU03:FS02:0x18:Completed 1200000 out of 2000000 steps (60%)
00:32:14:WU03:FS02:0x18:Completed 1220000 out of 2000000 steps (61%)
00:32:17:WU04:FS03:0x21:Completed 96000 out of 1600000 steps (6%)
00:32:26:WU03:FS02:0x18:Completed 1240000 out of 2000000 steps (62%)
00:32:38:WU03:FS02:0x18:Completed 1260000 out of 2000000 steps (63%)
00:32:50:WU03:FS02:0x18:Completed 1280000 out of 2000000 steps (64%)
00:33:02:WU03:FS02:0x18:Completed 1300000 out of 2000000 steps (65%)
00:33:08:FS00:Paused
00:33:14:WU03:FS02:0x18:Completed 1320000 out of 2000000 steps (66%)
00:33:16:WU02:FS01:0x18:Completed 650000 out of 5000000 steps (13%)
00:33:18:FS00:Unpaused
00:33:18:WU01:FS00:Connecting to 171.67.108.45:8080
00:33:20:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:33:20:WU01:FS00:Connecting to 171.64.65.35:80
00:33:20:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:33:20:ERROR:WU01:FS00:Exception: Could not get an assignment
00:33:26:WU03:FS02:0x18:Completed 1340000 out of 2000000 steps (67%)
00:33:38:WU03:FS02:0x18:Completed 1360000 out of 2000000 steps (68%)
00:33:50:WU03:FS02:0x18:Completed 1380000 out of 2000000 steps (69%)
00:34:02:WU03:FS02:0x18:Completed 1400000 out of 2000000 steps (70%)
00:34:14:WU03:FS02:0x18:Completed 1420000 out of 2000000 steps (71%)
00:34:20:WU04:FS03:0x21:Completed 112000 out of 1600000 steps (7%)
00:34:26:WU03:FS02:0x18:Completed 1440000 out of 2000000 steps (72%)
00:34:38:WU03:FS02:0x18:Completed 1460000 out of 2000000 steps (73%)
00:34:48:WU02:FS01:0x18:Completed 700000 out of 5000000 steps (14%)
00:34:50:WU03:FS02:0x18:Completed 1480000 out of 2000000 steps (74%)
00:34:56:WU01:FS00:Connecting to 171.67.108.45:8080
00:34:56:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:34:56:WU01:FS00:Connecting to 171.64.65.35:80
00:34:56:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:34:56:ERROR:WU01:FS00:Exception: Could not get an assignment
00:35:02:WU03:FS02:0x18:Completed 1500000 out of 2000000 steps (75%)
00:35:14:WU03:FS02:0x18:Completed 1520000 out of 2000000 steps (76%)
00:35:26:WU03:FS02:0x18:Completed 1540000 out of 2000000 steps (77%)
00:35:38:WU03:FS02:0x18:Completed 1560000 out of 2000000 steps (78%)
00:35:50:WU03:FS02:0x18:Completed 1580000 out of 2000000 steps (79%)
00:36:02:WU03:FS02:0x18:Completed 1600000 out of 2000000 steps (80%)
00:36:15:WU03:FS02:0x18:Completed 1620000 out of 2000000 steps (81%)
00:36:20:WU02:FS01:0x18:Completed 750000 out of 5000000 steps (15%)
00:36:23:WU04:FS03:0x21:Completed 128000 out of 1600000 steps (8%)
00:36:27:WU03:FS02:0x18:Completed 1640000 out of 2000000 steps (82%)
00:36:39:WU03:FS02:0x18:Completed 1660000 out of 2000000 steps (83%)
00:36:51:WU03:FS02:0x18:Completed 1680000 out of 2000000 steps (84%)
00:37:03:WU03:FS02:0x18:Completed 1700000 out of 2000000 steps (85%)
00:37:15:WU03:FS02:0x18:Completed 1720000 out of 2000000 steps (86%)
00:37:27:WU03:FS02:0x18:Completed 1740000 out of 2000000 steps (87%)
00:37:33:WU01:FS00:Connecting to 171.67.108.45:8080
00:37:33:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:37:33:WU01:FS00:Connecting to 171.64.65.35:80
00:37:34:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:37:34:ERROR:WU01:FS00:Exception: Could not get an assignment
00:37:39:WU03:FS02:0x18:Completed 1760000 out of 2000000 steps (88%)
00:37:51:WU03:FS02:0x18:Completed 1780000 out of 2000000 steps (89%)
00:37:55:WU02:FS01:0x18:Completed 800000 out of 5000000 steps (16%)
00:38:03:WU03:FS02:0x18:Completed 1800000 out of 2000000 steps (90%)
00:38:15:WU03:FS02:0x18:Completed 1820000 out of 2000000 steps (91%)
00:38:26:WU04:FS03:0x21:Completed 144000 out of 1600000 steps (9%)
00:38:27:WU03:FS02:0x18:Completed 1840000 out of 2000000 steps (92%)
00:38:39:WU03:FS02:0x18:Completed 1860000 out of 2000000 steps (93%)
00:38:51:WU03:FS02:0x18:Completed 1880000 out of 2000000 steps (94%)
00:39:03:WU03:FS02:0x18:Completed 1900000 out of 2000000 steps (95%)
00:39:16:WU03:FS02:0x18:Completed 1920000 out of 2000000 steps (96%)
00:39:27:WU02:FS01:0x18:Completed 850000 out of 5000000 steps (17%)
00:39:28:WU03:FS02:0x18:Completed 1940000 out of 2000000 steps (97%)
00:39:40:WU03:FS02:0x18:Completed 1960000 out of 2000000 steps (98%)
00:39:52:WU03:FS02:0x18:Completed 1980000 out of 2000000 steps (99%)
00:40:04:WU03:FS02:0x18:Completed 2000000 out of 2000000 steps (100%)
00:40:04:WU00:FS02:Connecting to 171.67.108.45:80
00:40:04:WU03:FS02:0x18:Saving result file logfile_01.txt
00:40:04:WU03:FS02:0x18:Saving result file checkpointState.xml
00:40:04:WU00:FS02:Assigned to work server 171.64.65.98
00:40:04:WU00:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GM200 [GeForce GTX 980 Ti] from 171.64.65.98
00:40:04:WU00:FS02:Connecting to 171.64.65.98:8080
00:40:04:WU03:FS02:0x18:Saving result file checkpt.crc
00:40:04:WU03:FS02:0x18:Saving result file log.txt
00:40:04:WU03:FS02:0x18:Saving result file positions.xtc
00:40:04:WU03:FS02:0x18:Folding@home Core Shutdown: FINISHED_UNIT
00:40:05:WU00:FS02:Downloading 15.72MiB
00:40:05:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:40:05:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:9679 run:1 clone:23 gen:30 core:0x18 unit:0x00000021ab436c9b56de69bfcef9a832
00:40:05:WU03:FS02:Uploading 748.76KiB to 171.67.108.155
00:40:05:WU03:FS02:Connecting to 171.67.108.155:8080
00:40:07:WU00:FS02:Download complete
00:40:07:WU00:FS02:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9704 run:42 clone:12 gen:194 core:0x21 unit:0x0000010bab404162553ec2462444bf15
00:40:07:WU00:FS02:Starting
00:40:07:WU00:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1345 -checkpoint 30 -gpu 1 -gpu-vendor nvidia
00:40:07:WU00:FS02:Started FahCore on PID 5525
00:40:07:WU00:FS02:Core PID:5529
00:40:07:WU00:FS02:FahCore 0x21 started
00:40:07:WU00:FS02:0x21:*********************** Log Started 2016-08-02T00:40:07Z ***********************
00:40:07:WU00:FS02:0x21:Project: 9704 (Run 42, Clone 12, Gen 194)
00:40:07:WU00:FS02:0x21:Unit: 0x0000010bab404162553ec2462444bf15
00:40:07:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
00:40:07:WU00:FS02:0x21:Machine: 2
00:40:07:WU00:FS02:0x21:Reading tar file core.xml
00:40:07:WU00:FS02:0x21:Reading tar file system.xml
00:40:07:WU03:FS02:Upload complete
00:40:08:WU03:FS02:Server responded WORK_ACK (400)
00:40:08:WU03:FS02:Final credit estimate, 5323.00 points
00:40:08:WU03:FS02:Cleaning up
00:40:08:WU00:FS02:0x21:Reading tar file integrator.xml
00:40:08:WU00:FS02:0x21:Reading tar file state.xml
00:40:09:WU00:FS02:0x21:Digital signatures verified
00:40:09:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
00:40:09:WU00:FS02:0x21:Version 0.0.17
00:40:28:WU04:FS03:0x21:Completed 160000 out of 1600000 steps (10%)
00:40:43:WU00:FS02:0x21:Completed 0 out of 640000 steps (0%)
00:40:43:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:41:01:WU02:FS01:0x18:Completed 900000 out of 5000000 steps (18%)
00:41:47:WU01:FS00:Connecting to 171.67.108.45:8080
00:41:48:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:41:48:WU01:FS00:Connecting to 171.64.65.35:80
00:41:48:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:41:48:ERROR:WU01:FS00:Exception: Could not get an assignment
00:42:04:WU00:FS02:0x21:Completed 6400 out of 640000 steps (1%)
00:42:32:WU04:FS03:0x21:Completed 176000 out of 1600000 steps (11%)
00:42:34:WU02:FS01:0x18:Completed 950000 out of 5000000 steps (19%)
00:43:25:WU00:FS02:0x21:Completed 12800 out of 640000 steps (2%)
00:44:06:WU02:FS01:0x18:Completed 1000000 out of 5000000 steps (20%)
00:44:34:WU04:FS03:0x21:Completed 192000 out of 1600000 steps (12%)
00:44:47:WU00:FS02:0x21:Completed 19200 out of 640000 steps (3%)
00:45:40:WU02:FS01:0x18:Completed 1050000 out of 5000000 steps (21%)
00:46:11:WU00:FS02:0x21:Completed 25600 out of 640000 steps (4%)
00:46:37:WU04:FS03:0x21:Completed 208000 out of 1600000 steps (13%)
00:47:13:WU02:FS01:0x18:Completed 1100000 out of 5000000 steps (22%)
00:47:34:WU00:FS02:0x21:Completed 32000 out of 640000 steps (5%)
00:48:39:WU01:FS00:Connecting to 171.67.108.45:8080
00:48:39:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:48:39:WU01:FS00:Connecting to 171.64.65.35:80
00:48:39:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:48:39:ERROR:WU01:FS00:Exception: Could not get an assignment
00:48:40:WU04:FS03:0x21:Completed 224000 out of 1600000 steps (14%)
00:48:47:WU02:FS01:0x18:Completed 1150000 out of 5000000 steps (23%)
00:48:56:WU00:FS02:0x21:Completed 38400 out of 640000 steps (6%)
00:50:18:WU00:FS02:0x21:Completed 44800 out of 640000 steps (7%)
00:50:19:WU02:FS01:0x18:Completed 1200000 out of 5000000 steps (24%)
00:50:42:WU04:FS03:0x21:Completed 240000 out of 1600000 steps (15%)
00:51:40:WU00:FS02:0x21:Completed 51200 out of 640000 steps (8%)
00:51:52:WU02:FS01:0x18:Completed 1250000 out of 5000000 steps (25%)
00:52:46:WU04:FS03:0x21:Completed 256000 out of 1600000 steps (16%)
00:53:01:WU00:FS02:0x21:Completed 57600 out of 640000 steps (9%)
00:53:26:WU02:FS01:0x18:Completed 1300000 out of 5000000 steps (26%)
00:54:23:WU00:FS02:0x21:Completed 64000 out of 640000 steps (10%)
00:54:48:WU04:FS03:0x21:Completed 272000 out of 1600000 steps (17%)
00:54:58:WU02:FS01:0x18:Completed 1350000 out of 5000000 steps (27%)
00:55:44:WU00:FS02:0x21:Completed 70400 out of 640000 steps (11%)
00:56:33:WU02:FS01:0x18:Completed 1400000 out of 5000000 steps (28%)
00:56:52:WU04:FS03:0x21:Completed 288000 out of 1600000 steps (18%)
00:57:05:WU00:FS02:0x21:Completed 76800 out of 640000 steps (12%)
00:58:05:WU02:FS01:0x18:Completed 1450000 out of 5000000 steps (29%)
00:58:30:WU00:FS02:0x21:Completed 83200 out of 640000 steps (13%)
00:58:55:WU04:FS03:0x21:Completed 304000 out of 1600000 steps (19%)
00:59:37:WU02:FS01:0x18:Completed 1500000 out of 5000000 steps (30%)
00:59:44:WU01:FS00:Connecting to 171.67.108.45:8080
00:59:45:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:59:45:WU01:FS00:Connecting to 171.64.65.35:80
00:59:45:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:59:45:ERROR:WU01:FS00:Exception: Could not get an assignment
00:59:51:WU00:FS02:0x21:Completed 89600 out of 640000 steps (14%)
01:00:57:WU04:FS03:0x21:Completed 320000 out of 1600000 steps (20%)
01:01:12:WU02:FS01:0x18:Completed 1550000 out of 5000000 steps (31%)
01:01:12:WU00:FS02:0x21:Completed 96000 out of 640000 steps (15%)
01:02:34:WU00:FS02:0x21:Completed 102400 out of 640000 steps (16%)
01:02:44:WU02:FS01:0x18:Completed 1600000 out of 5000000 steps (32%)
01:03:01:WU04:FS03:0x21:Completed 336000 out of 1600000 steps (21%)
01:03:56:WU00:FS02:0x21:Completed 108800 out of 640000 steps (17%)
01:04:19:WU02:FS01:0x18:Completed 1650000 out of 5000000 steps (33%)
01:05:04:WU04:FS03:0x21:Completed 352000 out of 1600000 steps (22%)
01:05:17:WU00:FS02:0x21:Completed 115200 out of 640000 steps (18%)
01:05:51:WU02:FS01:0x18:Completed 1700000 out of 5000000 steps (34%)
01:06:38:WU00:FS02:0x21:Completed 121600 out of 640000 steps (19%)
01:07:07:WU04:FS03:0x21:Completed 368000 out of 1600000 steps (23%)
01:07:23:WU02:FS01:0x18:Completed 1750000 out of 5000000 steps (35%)
01:08:00:WU00:FS02:0x21:Completed 128000 out of 640000 steps (20%)
01:08:58:WU02:FS01:0x18:Completed 1800000 out of 5000000 steps (36%)
01:09:10:WU04:FS03:0x21:Completed 384000 out of 1600000 steps (24%)
01:09:21:WU00:FS02:0x21:Completed 134400 out of 640000 steps (21%)
01:10:30:WU02:FS01:0x18:Completed 1850000 out of 5000000 steps (37%)
01:10:42:WU00:FS02:0x21:Completed 140800 out of 640000 steps (22%)
01:11:12:WU04:FS03:0x21:Completed 400000 out of 1600000 steps (25%)
01:12:03:WU00:FS02:0x21:Completed 147200 out of 640000 steps (23%)
01:12:04:WU02:FS01:0x18:Completed 1900000 out of 5000000 steps (38%)
01:13:16:WU04:FS03:0x21:Completed 416000 out of 1600000 steps (26%)
01:13:25:WU00:FS02:0x21:Completed 153600 out of 640000 steps (24%)
01:13:36:WU02:FS01:0x18:Completed 1950000 out of 5000000 steps (39%)
01:14:47:WU00:FS02:0x21:Completed 160000 out of 640000 steps (25%)
01:15:09:WU02:FS01:0x18:Completed 2000000 out of 5000000 steps (40%)
01:15:18:WU04:FS03:0x21:Completed 432000 out of 1600000 steps (27%)
01:16:12:WU00:FS02:0x21:Completed 166400 out of 640000 steps (26%)
01:16:43:WU02:FS01:0x18:Completed 2050000 out of 5000000 steps (41%)
01:17:23:WU04:FS03:0x21:Completed 448000 out of 1600000 steps (28%)
01:17:33:WU00:FS02:0x21:Completed 172800 out of 640000 steps (27%)
01:17:41:WU01:FS00:Connecting to 171.67.108.45:8080
01:17:41:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:17:41:WU01:FS00:Connecting to 171.64.65.35:80
01:17:42:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:17:42:ERROR:WU01:FS00:Exception: Could not get an assignment
01:18:15:WU02:FS01:0x18:Completed 2100000 out of 5000000 steps (42%)
01:18:54:WU00:FS02:0x21:Completed 179200 out of 640000 steps (28%)
01:19:25:WU04:FS03:0x21:Completed 464000 out of 1600000 steps (29%)
01:19:49:WU02:FS01:0x18:Completed 2150000 out of 5000000 steps (43%)
01:20:15:WU00:FS02:0x21:Completed 185600 out of 640000 steps (29%)
01:21:21:WU02:FS01:0x18:Completed 2200000 out of 5000000 steps (44%)
01:21:28:WU04:FS03:0x21:Completed 480000 out of 1600000 steps (30%)
01:21:36:WU00:FS02:0x21:Completed 192000 out of 640000 steps (30%)
01:22:54:WU02:FS01:0x18:Completed 2250000 out of 5000000 steps (45%)
01:22:58:WU00:FS02:0x21:Completed 198400 out of 640000 steps (31%)
01:23:32:WU04:FS03:0x21:Completed 496000 out of 1600000 steps (31%)
01:24:19:WU00:FS02:0x21:Completed 204800 out of 640000 steps (32%)
01:24:28:WU02:FS01:0x18:Completed 2300000 out of 5000000 steps (46%)
01:25:34:WU04:FS03:0x21:Completed 512000 out of 1600000 steps (32%)
01:25:39:WU00:FS02:0x21:Completed 211200 out of 640000 steps (33%)
01:26:00:WU02:FS01:0x18:Completed 2350000 out of 5000000 steps (47%)
01:27:01:WU00:FS02:0x21:Completed 217600 out of 640000 steps (34%)
01:27:36:WU02:FS01:0x18:Completed 2400000 out of 5000000 steps (48%)
01:27:38:WU04:FS03:0x21:Completed 528000 out of 1600000 steps (33%)
01:28:22:WU00:FS02:0x21:Completed 224000 out of 640000 steps (35%)
01:29:08:WU02:FS01:0x18:Completed 2450000 out of 5000000 steps (49%)
01:29:42:WU04:FS03:0x21:Completed 544000 out of 1600000 steps (34%)
01:29:43:WU00:FS02:0x21:Completed 230400 out of 640000 steps (36%)
01:30:41:WU02:FS01:0x18:Completed 2500000 out of 5000000 steps (50%)
01:31:05:WU00:FS02:0x21:Completed 236800 out of 640000 steps (37%)
01:31:44:WU04:FS03:0x21:Completed 560000 out of 1600000 steps (35%)
01:32:17:WU02:FS01:0x18:Completed 2550000 out of 5000000 steps (51%)
01:32:30:WU00:FS02:0x21:Completed 243200 out of 640000 steps (38%)
01:33:48:WU04:FS03:0x21:Completed 576000 out of 1600000 steps (36%)
01:33:49:WU02:FS01:0x18:Completed 2600000 out of 5000000 steps (52%)
01:33:51:WU00:FS02:0x21:Completed 249600 out of 640000 steps (39%)
01:35:12:WU00:FS02:0x21:Completed 256000 out of 640000 steps (40%)
01:35:23:WU02:FS01:0x18:Completed 2650000 out of 5000000 steps (53%)
01:35:51:WU04:FS03:0x21:Completed 592000 out of 1600000 steps (37%)
01:36:34:WU00:FS02:0x21:Completed 262400 out of 640000 steps (41%)
01:36:55:WU02:FS01:0x18:Completed 2700000 out of 5000000 steps (54%)
01:37:55:WU04:FS03:0x21:Completed 608000 out of 1600000 steps (38%)
01:37:57:WU00:FS02:0x21:Completed 268800 out of 640000 steps (42%)
01:38:27:WU02:FS01:0x18:Completed 2750000 out of 5000000 steps (55%)
01:39:18:WU00:FS02:0x21:Completed 275200 out of 640000 steps (43%)
01:39:57:WU04:FS03:0x21:Completed 624000 out of 1600000 steps (39%)
01:40:02:WU02:FS01:0x18:Completed 2800000 out of 5000000 steps (56%)
01:40:39:WU00:FS02:0x21:Completed 281600 out of 640000 steps (44%)
01:41:34:WU02:FS01:0x18:Completed 2850000 out of 5000000 steps (57%)
01:42:00:WU04:FS03:0x21:Completed 640000 out of 1600000 steps (40%)
01:42:01:WU00:FS02:0x21:Completed 288000 out of 640000 steps (45%)
01:43:08:WU02:FS01:0x18:Completed 2900000 out of 5000000 steps (58%)
01:43:22:WU00:FS02:0x21:Completed 294400 out of 640000 steps (46%)
01:44:04:WU04:FS03:0x21:Completed 656000 out of 1600000 steps (41%)
01:44:40:WU02:FS01:0x18:Completed 2950000 out of 5000000 steps (59%)
01:44:43:WU00:FS02:0x21:Completed 300800 out of 640000 steps (47%)
01:46:04:WU00:FS02:0x21:Completed 307200 out of 640000 steps (48%)
01:46:06:WU04:FS03:0x21:Completed 672000 out of 1600000 steps (42%)
01:46:12:WU02:FS01:0x18:Completed 3000000 out of 5000000 steps (60%)
01:46:43:WU01:FS00:Connecting to 171.67.108.45:8080
01:46:44:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:46:44:WU01:FS00:Connecting to 171.64.65.35:80
01:46:44:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:46:44:ERROR:WU01:FS00:Exception: Could not get an assignment
01:47:26:WU00:FS02:0x21:Completed 313600 out of 640000 steps (49%)
01:47:47:WU02:FS01:0x18:Completed 3050000 out of 5000000 steps (61%)
01:48:10:WU04:FS03:0x21:Completed 688000 out of 1600000 steps (43%)
01:48:47:WU00:FS02:0x21:Completed 320000 out of 640000 steps (50%)
01:49:19:WU02:FS01:0x18:Completed 3100000 out of 5000000 steps (62%)
01:50:12:WU04:FS03:0x21:Completed 704000 out of 1600000 steps (44%)
01:50:12:WU00:FS02:0x21:Completed 326400 out of 640000 steps (51%)
01:50:53:WU02:FS01:0x18:Completed 3150000 out of 5000000 steps (63%)
01:51:33:WU00:FS02:0x21:Completed 332800 out of 640000 steps (52%)
01:52:14:WU04:FS03:0x21:Completed 720000 out of 1600000 steps (45%)
01:52:25:WU02:FS01:0x18:Completed 3200000 out of 5000000 steps (64%)
01:52:54:WU00:FS02:0x21:Completed 339200 out of 640000 steps (53%)
01:53:58:WU02:FS01:0x18:Completed 3250000 out of 5000000 steps (65%)
01:54:15:WU00:FS02:0x21:Completed 345600 out of 640000 steps (54%)
01:54:18:WU04:FS03:0x21:Completed 736000 out of 1600000 steps (46%)
01:55:32:WU02:FS01:0x18:Completed 3300000 out of 5000000 steps (66%)
01:55:36:WU00:FS02:0x21:Completed 352000 out of 640000 steps (55%)
01:56:21:WU04:FS03:0x21:Completed 752000 out of 1600000 steps (47%)
01:56:57:WU00:FS02:0x21:Completed 358400 out of 640000 steps (56%)
01:57:04:WU02:FS01:0x18:Completed 3350000 out of 5000000 steps (67%)
01:58:18:WU00:FS02:0x21:Completed 364800 out of 640000 steps (57%)
01:58:25:WU04:FS03:0x21:Completed 768000 out of 1600000 steps (48%)
01:58:39:WU02:FS01:0x18:Completed 3400000 out of 5000000 steps (68%)
01:59:38:WU00:FS02:0x21:Completed 371200 out of 640000 steps (58%)
02:00:12:WU02:FS01:0x18:Completed 3450000 out of 5000000 steps (69%)
02:00:27:WU04:FS03:0x21:Completed 784000 out of 1600000 steps (49%)
02:00:59:WU00:FS02:0x21:Completed 377600 out of 640000 steps (59%)
02:01:44:WU02:FS01:0x18:Completed 3500000 out of 5000000 steps (70%)
02:02:20:WU00:FS02:0x21:Completed 384000 out of 640000 steps (60%)
02:02:29:WU04:FS03:0x21:Completed 800000 out of 1600000 steps (50%)
02:03:18:WU02:FS01:0x18:Completed 3550000 out of 5000000 steps (71%)
02:03:41:WU00:FS02:0x21:Completed 390400 out of 640000 steps (61%)
02:04:33:WU04:FS03:0x21:Completed 816000 out of 1600000 steps (51%)
02:04:50:WU02:FS01:0x18:Completed 3600000 out of 5000000 steps (72%)
02:05:02:WU00:FS02:0x21:Completed 396800 out of 640000 steps (62%)
02:06:24:WU02:FS01:0x18:Completed 3650000 out of 5000000 steps (73%)
02:06:28:WU00:FS02:0x21:Completed 403200 out of 640000 steps (63%)
02:06:36:WU04:FS03:0x21:Completed 832000 out of 1600000 steps (52%)
02:07:50:WU00:FS02:0x21:Completed 409600 out of 640000 steps (64%)
02:07:57:WU02:FS01:0x18:Completed 3700000 out of 5000000 steps (74%)
02:08:41:WU04:FS03:0x21:Completed 848000 out of 1600000 steps (53%)
02:09:10:WU00:FS02:0x21:Completed 416000 out of 640000 steps (65%)
02:09:29:WU02:FS01:0x18:Completed 3750000 out of 5000000 steps (75%)
02:10:31:WU00:FS02:0x21:Completed 422400 out of 640000 steps (66%)
02:10:43:WU04:FS03:0x21:Completed 864000 out of 1600000 steps (54%)
02:11:04:WU02:FS01:0x18:Completed 3800000 out of 5000000 steps (76%)
02:11:52:WU00:FS02:0x21:Completed 428800 out of 640000 steps (67%)
02:12:36:WU02:FS01:0x18:Completed 3850000 out of 5000000 steps (77%)
02:12:45:WU04:FS03:0x21:Completed 880000 out of 1600000 steps (55%)
02:13:13:WU00:FS02:0x21:Completed 435200 out of 640000 steps (68%)
02:14:10:WU02:FS01:0x18:Completed 3900000 out of 5000000 steps (78%)
02:14:34:WU00:FS02:0x21:Completed 441600 out of 640000 steps (69%)
02:14:49:WU04:FS03:0x21:Completed 896000 out of 1600000 steps (56%)
02:15:43:WU02:FS01:0x18:Completed 3950000 out of 5000000 steps (79%)
02:15:55:WU00:FS02:0x21:Completed 448000 out of 640000 steps (70%)
02:16:51:WU04:FS03:0x21:Completed 912000 out of 1600000 steps (57%)
02:17:15:WU02:FS01:0x18:Completed 4000000 out of 5000000 steps (80%)
02:17:16:WU00:FS02:0x21:Completed 454400 out of 640000 steps (71%)
02:18:37:WU00:FS02:0x21:Completed 460800 out of 640000 steps (72%)
02:18:49:WU02:FS01:0x18:Completed 4050000 out of 5000000 steps (81%)
02:18:55:WU04:FS03:0x21:Completed 928000 out of 1600000 steps (58%)
02:19:57:WU00:FS02:0x21:Completed 467200 out of 640000 steps (73%)
02:20:22:WU02:FS01:0x18:Completed 4100000 out of 5000000 steps (82%)
02:20:57:WU04:FS03:0x21:Completed 944000 out of 1600000 steps (59%)
02:21:19:WU00:FS02:0x21:Completed 473600 out of 640000 steps (74%)
02:21:56:WU02:FS01:0x18:Completed 4150000 out of 5000000 steps (83%)
02:22:40:WU00:FS02:0x21:Completed 480000 out of 640000 steps (75%)
02:22:59:WU04:FS03:0x21:Completed 960000 out of 1600000 steps (60%)
02:23:28:WU02:FS01:0x18:Completed 4200000 out of 5000000 steps (84%)
02:24:04:WU00:FS02:0x21:Completed 486400 out of 640000 steps (76%)
02:25:00:WU02:FS01:0x18:Completed 4250000 out of 5000000 steps (85%)
02:25:03:WU04:FS03:0x21:Completed 976000 out of 1600000 steps (61%)
02:25:25:WU00:FS02:0x21:Completed 492800 out of 640000 steps (77%)
02:26:35:WU02:FS01:0x18:Completed 4300000 out of 5000000 steps (86%)
02:26:46:WU00:FS02:0x21:Completed 499200 out of 640000 steps (78%)
02:27:05:WU04:FS03:0x21:Completed 992000 out of 1600000 steps (62%)
02:28:07:WU02:FS01:0x18:Completed 4350000 out of 5000000 steps (87%)
02:28:07:WU00:FS02:0x21:Completed 505600 out of 640000 steps (79%)
02:29:09:WU04:FS03:0x21:Completed 1008000 out of 1600000 steps (63%)
02:29:28:WU00:FS02:0x21:Completed 512000 out of 640000 steps (80%)
02:29:41:WU02:FS01:0x18:Completed 4400000 out of 5000000 steps (88%)
02:30:49:WU00:FS02:0x21:Completed 518400 out of 640000 steps (81%)
02:31:11:WU04:FS03:0x21:Completed 1024000 out of 1600000 steps (64%)
02:31:13:WU02:FS01:0x18:Completed 4450000 out of 5000000 steps (89%)
02:32:09:WU00:FS02:0x21:Completed 524800 out of 640000 steps (82%)
02:32:45:WU02:FS01:0x18:Completed 4500000 out of 5000000 steps (90%)
02:33:14:WU04:FS03:0x21:Completed 1040000 out of 1600000 steps (65%)
02:33:30:WU00:FS02:0x21:Completed 531200 out of 640000 steps (83%)
02:33:42:WU01:FS00:Connecting to 171.67.108.45:8080
02:33:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:33:42:WU01:FS00:Connecting to 171.64.65.35:80
02:33:43:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:33:43:ERROR:WU01:FS00:Exception: Could not get an assignment
02:34:20:WU02:FS01:0x18:Completed 4550000 out of 5000000 steps (91%)
02:34:51:WU00:FS02:0x21:Completed 537600 out of 640000 steps (84%)
02:35:18:WU04:FS03:0x21:Completed 1056000 out of 1600000 steps (66%)
02:35:52:WU02:FS01:0x18:Completed 4600000 out of 5000000 steps (92%)
02:36:12:WU00:FS02:0x21:Completed 544000 out of 640000 steps (85%)
02:37:20:WU04:FS03:0x21:Completed 1072000 out of 1600000 steps (67%)
02:37:26:WU02:FS01:0x18:Completed 4650000 out of 5000000 steps (93%)
02:37:33:WU00:FS02:0x21:Completed 550400 out of 640000 steps (86%)
02:38:54:WU00:FS02:0x21:Completed 556800 out of 640000 steps (87%)
02:38:54:FS00:Paused
02:38:57:FS00:Unpaused
02:38:57:WU01:FS00:Connecting to 171.67.108.45:8080
02:38:58:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:38:58:WU01:FS00:Connecting to 171.64.65.35:80
02:38:58:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:38:58:ERROR:WU01:FS00:Exception: Could not get an assignment
02:38:59:WU02:FS01:0x18:Completed 4700000 out of 5000000 steps (94%)
02:39:24:WU04:FS03:0x21:Completed 1088000 out of 1600000 steps (68%)
02:40:18:WU00:FS02:0x21:Completed 563200 out of 640000 steps (88%)
02:40:31:WU02:FS01:0x18:Completed 4750000 out of 5000000 steps (95%)
02:40:34:WU01:FS00:Connecting to 171.67.108.45:8080
02:40:35:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:40:35:WU01:FS00:Connecting to 171.64.65.35:80
02:40:35:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:40:35:ERROR:WU01:FS00:Exception: Could not get an assignment
02:41:26:WU04:FS03:0x21:Completed 1104000 out of 1600000 steps (69%)
02:41:39:WU00:FS02:0x21:Completed 569600 out of 640000 steps (89%)
02:42:05:WU02:FS01:0x18:Completed 4800000 out of 5000000 steps (96%)
02:43:00:WU00:FS02:0x21:Completed 576000 out of 640000 steps (90%)
02:43:12:WU01:FS00:Connecting to 171.67.108.45:8080
02:43:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:43:12:WU01:FS00:Connecting to 171.64.65.35:80
02:43:12:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:43:12:ERROR:WU01:FS00:Exception: Could not get an assignment
02:43:29:WU04:FS03:0x21:Completed 1120000 out of 1600000 steps (70%)
02:43:37:WU02:FS01:0x18:Completed 4850000 out of 5000000 steps (97%)
02:44:20:WU00:FS02:0x21:Completed 582400 out of 640000 steps (91%)
Those two servers are not WS's but Assignment Servers. They do not hold work to be assigned, just match up your system's request based on the configuration set for that folding slot to a WS. The "Empty work server" message means no WS has WU's that will fill that request.
Please post the beginning of the log that shows the system info and folding configuration.
The 0.0.0.0 that you see on the status tab has NOTHING to do with getting an new assignment.
Your configuration (which Joe just requested) is passed to an Assignment Server whose job it is to Assign you to a Work Server that has WUs you can process. As Joe said, that depends on how well your system matches up with the WUs that need to be processed ... and if no suitable Work Server can be found, you get the "Empty Work Server assignment" message.
See the link in the signature block of my first post on this page.
Ok. Here is the log from the top:
About 2.5 hours' worth.
]*********************** Log Started 2016-08-01T03:14:05Z ***********************
03:14:05:************************* Folding@home Client *************************
03:14:05: Website: http://folding.stanford.edu/
03:14:05: Copyright: (c) 2009-2014 Stanford University
03:14:05: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:14:05: Args: --child --lifeline 1343 /etc/fahclient/config.xml --run-as
03:14:05: fahclient --pid-file=/var/run/fahclient.pid --daemon
03:14:05: Config: /etc/fahclient/config.xml
03:14:05:******************************** Build ********************************
03:14:05: Version: 7.4.4
03:14:05: Date: Mar 4 2014
03:14:05: Time: 12:02:38
03:14:05: SVN Rev: 4130
03:14:05: Branch: fah/trunk/client
03:14:05: Compiler: GNU 4.4.7
03:14:05: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
03:14:05: -fno-unsafe-math-optimizations -msse2
03:14:05: Platform: linux2 3.2.0-1-amd64
03:14:05: Bits: 64
03:14:05: Mode: Release
03:14:05:******************************* System ********************************
03:14:05: CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
03:14:05: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
03:14:05: CPUs: 8
03:14:05: Memory: 31.34GiB
03:14:05:Free Memory: 30.76GiB
03:14:05: Threads: POSIX_THREADS
03:14:05: OS Version: 3.19
03:14:05:Has Battery: false
03:14:05: On Battery: false
03:14:05: UTC Offset: -7
03:14:05: PID: 1345
03:14:05: CWD: /var/lib/fahclient
03:14:05: OS: Linux 3.19.0-32-generic x86_64
03:14:05: OS Arch: AMD64
03:14:05: GPUs: 3
03:14:05: GPU 0: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
03:14:05: GPU 1: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
03:14:05: GPU 2: NVIDIA:5 GM204 [GeForce GTX 970]
03:14:05: CUDA: 5.2
03:14:05:CUDA Driver: 7000
03:14:05:***********************************************************************
03:14:05:<config>
03:14:05: <!-- Network -->
03:14:05: <proxy v=':8080'/>
03:14:05:
03:14:05: <!-- Slot Control -->
03:14:05: <power v='light'/>
03:14:05:
03:14:05: <!-- User Information -->
03:14:05: <passkey v='********************************'/>
03:14:05: <user v='RABishop'/>
03:14:05:
03:14:05: <!-- Folding Slots -->
03:14:05: <slot id='0' type='CPU'>
03:14:05: <cpus v='8'/>
03:14:05: </slot>
03:14:05:</config>
03:14:05:Switching to user fahclient
03:14:05:Trying to access database...
03:14:05:Successfully acquired database lock
03:14:05:Enabled folding slot 00: READY cpu:8
03:14:05:WU00:FS00:Starting
03:14:05:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1345 -checkpoint 15 -np 8
03:14:05:WU00:FS00:Started FahCore on PID 1354
03:14:05:WU00:FS00:Core PID:1358
03:14:05:WU00:FS00:FahCore 0xa4 started
03:14:05:WU00:FS00:0xa4:
03:14:05:WU00:FS00:0xa4:*------------------------------*
03:14:05:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:14:05:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:14:05:WU00:FS00:0xa4:Preparing to commence simulation
03:14:05:WU00:FS00:0xa4:- Looking at optimizations...
03:14:05:WU00:FS00:0xa4:- Files status OK
03:14:05:WU00:FS00:0xa4:- Expanded 825702 -> 1403132 (decompressed 169.9 percent)
03:14:05:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825702 data_size=1403132, decompressed_data_size=1403132 diff=0
03:14:05:WU00:FS00:0xa4:- Digital signature verified
03:14:05:WU00:FS00:0xa4:Project: 9036 (Run 356, Clone 2, Gen 364)
03:14:05:WU00:FS00:0xa4:Assembly optimizations on if available.
03:14:05:WU00:FS00:0xa4:Entering M.D.
03:14:11:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
03:15:01:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
03:15:17:Saving configuration to /etc/fahclient/config.xml
03:15:17:<config>
03:15:17: <!-- Network -->
03:15:17: <proxy v=':8080'/>
03:15:17:
03:15:17: <!-- Slot Control -->
03:15:17: <power v='light'/>
03:15:17:
03:15:17: <!-- User Information -->
03:15:17: <passkey v='********************************'/>
03:15:17: <user v='RABishop'/>
03:15:17:
03:15:17: <!-- Folding Slots -->
03:15:17: <slot id='0' type='CPU'>
03:15:17: <cpus v='8'/>
03:15:17: <next-unit-percentage v='100'/>
03:15:17: </slot>
03:15:17:</config>
03:15:49:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
03:16:07:Saving configuration to /etc/fahclient/config.xml
03:16:07:<config>
03:16:07: <!-- Network -->
03:16:07: <proxy v=':8080'/>
03:16:07:
03:16:07: <!-- Slot Control -->
03:16:07: <power v='light'/>
03:16:07:
03:16:07: <!-- User Information -->
03:16:07: <passkey v='********************************'/>
03:16:07: <user v='RABishop'/>
03:16:07:
03:16:07: <!-- Folding Slots -->
03:16:07: <slot id='0' type='CPU'>
03:16:07: <cpus v='8'/>
03:16:07: <next-unit-percentage v='100'/>
03:16:07: </slot>
03:16:07:</config>
03:16:29:Adding folding slot 01: PAUSED gpu:0:GM200 [GeForce GTX 980 Ti] (waiting for idle)
03:16:29:Adding folding slot 02: PAUSED gpu:1:GM200 [GeForce GTX 980 Ti] (waiting for idle)
03:16:29:Adding folding slot 03: PAUSED gpu:2:GM204 [GeForce GTX 970] (waiting for idle)
03:16:29:Saving configuration to /etc/fahclient/config.xml
03:16:29:<config>
03:16:29: <!-- Network -->
03:16:29: <proxy v=':8080'/>
03:16:29:
03:16:29: <!-- Slot Control -->
03:16:29: <power v='light'/>
03:16:29:
03:16:29: <!-- User Information -->
03:16:29: <passkey v='********************************'/>
03:16:29: <user v='RABishop'/>
03:16:29:
03:16:29: <!-- Folding Slots -->
03:16:29: <slot id='0' type='CPU'>
03:16:29: <cpus v='8'/>
03:16:29: <next-unit-percentage v='100'/>
03:16:29: </slot>
03:16:29: <slot id='1' type='GPU'>
03:16:29: </slot>
03:16:29: <slot id='2' type='GPU'>
03:16:29: </slot>
03:16:29: <slot id='3' type='GPU'>
03:16:29: </slot>
03:16:29:</config>
03:16:36:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
03:17:08:Saving configuration to /etc/fahclient/config.xml
03:17:08:<config>
03:17:08: <!-- Network -->
03:17:08: <proxy v=':8080'/>
03:17:08:
03:17:08: <!-- Slot Control -->
03:17:08: <power v='light'/>
03:17:08:
03:17:08: <!-- User Information -->
03:17:08: <passkey v='********************************'/>
03:17:08: <user v='RABishop'/>
03:17:08:
03:17:08: <!-- Folding Slots -->
03:17:08: <slot id='0' type='CPU'>
03:17:08: <cpus v='8'/>
03:17:08: <next-unit-percentage v='100'/>
03:17:08: </slot>
03:17:08: <slot id='1' type='GPU'>
03:17:08: </slot>
03:17:08: <slot id='2' type='GPU'>
03:17:08: </slot>
03:17:08: <slot id='3' type='GPU'>
03:17:08: </slot>
03:17:08:</config>
03:17:16:Saving configuration to /etc/fahclient/config.xml
03:17:16:<config>
03:17:16: <!-- Network -->
03:17:16: <proxy v=':8080'/>
03:17:16:
03:17:16: <!-- Slot Control -->
03:17:16: <power v='light'/>
03:17:16:
03:17:16: <!-- User Information -->
03:17:16: <passkey v='********************************'/>
03:17:16: <user v='RABishop'/>
03:17:16:
03:17:16: <!-- Folding Slots -->
03:17:16: <slot id='0' type='CPU'>
03:17:16: <cpus v='5'/>
03:17:16: <next-unit-percentage v='100'/>
03:17:16: </slot>
03:17:16: <slot id='1' type='GPU'>
03:17:16: </slot>
03:17:16: <slot id='2' type='GPU'>
03:17:16: </slot>
03:17:16: <slot id='3' type='GPU'>
03:17:16: </slot>
03:17:16:</config>
03:17:16:FS00:Shutting core down
03:17:20:WU00:FS00:0xa4:Client no longer detected. Shutting down core.
03:17:20:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:17:20:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:17:21:WU00:FS00:Starting
03:17:21:WARNING:WU00:FS00:Changed SMP threads from 8 to 5 this can cause some work units to fail
03:17:21:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1345 -checkpoint 15 -np 5
03:17:21:WU00:FS00:Started FahCore on PID 2615
03:17:21:WU00:FS00:Core PID:2619
03:17:21:WU00:FS00:FahCore 0xa4 started
03:17:21:WU00:FS00:0xa4:
03:17:21:WU00:FS00:0xa4:*------------------------------*
03:17:21:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:17:21:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:17:21:WU00:FS00:0xa4:Preparing to commence simulation
03:17:21:WU00:FS00:0xa4:- Looking at optimizations...
03:17:21:WU00:FS00:0xa4:- Files status OK
03:17:21:WU00:FS00:0xa4:- Expanded 825702 -> 1403132 (decompressed 169.9 percent)
03:17:21:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825702 data_size=1403132, decompressed_data_size=1403132 diff=0
03:17:21:WU00:FS00:0xa4:- Digital signature verified
03:17:21:WU00:FS00:0xa4:Project: 9036 (Run 356, Clone 2, Gen 364)
03:17:21:WU00:FS00:0xa4:Assembly optimizations on if available.
03:17:21:WU00:FS00:0xa4:Entering M.D.
03:17:27:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
03:17:35:WU01:FS01:Connecting to 171.67.108.45:80
03:17:35:WU01:FS01:Assigned to work server 171.64.65.92
03:17:35:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.64.65.92
03:17:35:WU01:FS01:Connecting to 171.64.65.92:8080
03:17:35:WU02:FS02:Connecting to 171.67.108.45:80
03:17:35:WU01:FS01:Downloading 2.93MiB
03:17:35:WU03:FS03:Connecting to 171.67.108.45:80
03:17:35:WU02:FS02:Assigned to work server 140.163.4.242
03:17:35:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GM200 [GeForce GTX 980 Ti] from 140.163.4.242
03:17:35:WU02:FS02:Connecting to 140.163.4.242:8080
03:17:35:WU03:FS03:Assigned to work server 171.64.65.98
03:17:35:WU03:FS03:Requesting new work unit for slot 03: READY gpu:2:GM204 [GeForce GTX 970] from 171.64.65.98
03:17:35:WU03:FS03:Connecting to 171.64.65.98:8080
03:17:35:WU02:FS02:Downloading 4.22MiB
03:17:36:WU03:FS03:Downloading 15.72MiB
03:17:36:WU01:FS01:Download complete
03:17:36:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9162 run:284 clone:0 gen:42 core:0x18 unit:0x00000036ab40415c5674817ae8e4cc9a
03:17:36:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah
03:17:36:WU01:FS01:Connecting to web.stanford.edu:80
03:17:36:WU01:FS01:FahCore 18: Downloading 2.77MiB
03:17:38:WU02:FS02:Download complete
03:17:38:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11403 run:0 clone:9 gen:261 core:0x21 unit:0x0000015e8ca304f255ed4f1c70261c27
03:17:38:WU02:FS02:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah
03:17:38:WU02:FS02:Connecting to web.stanford.edu:80
03:17:39:WU03:FS03:Download complete
03:17:39:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9704 run:48 clone:11 gen:126 core:0x21 unit:0x000000b5ab404162553ec33606ae73ab
03:17:39:WU02:FS02:FahCore 21: Downloading 3.23MiB
03:17:40:WU01:FS01:FahCore 18: Download complete
03:17:40:WU01:FS01:Valid core signature
03:17:40:WU01:FS01:Unpacked 7.68MiB to cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18
03:17:40:WU01:FS01:Starting
03:17:40:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 1345 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:17:40:WU01:FS01:Started FahCore on PID 2627
03:17:40:WU01:FS01:Core PID:2631
03:17:40:WU01:FS01:FahCore 0x18 started
03:17:40:WU02:FS02:FahCore 21: Download complete
03:17:40:WU02:FS02:Valid core signature
03:17:40:WU02:FS02:Unpacked 7.94MiB to cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21
03:17:40:WU02:FS02:Starting
03:17:40:WU02:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1345 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
03:17:40:WU02:FS02:Started FahCore on PID 2634
03:17:40:WU02:FS02:Core PID:2638
03:17:40:WU02:FS02:FahCore 0x21 started
03:17:40:WU03:FS03:Starting
03:17:40:WU03:FS03:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 03 -suffix 01 -version 704 -lifeline 1345 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
03:17:40:WU03:FS03:Started FahCore on PID 2641
03:17:40:WU03:FS03:Core PID:2645
03:17:40:WU03:FS03:FahCore 0x21 started
03:17:40:WU01:FS01:0x18:*********************** Log Started 2016-08-01T03:17:40Z ***********************
03:17:40:WU01:FS01:0x18:Project: 9162 (Run 284, Clone 0, Gen 42)
03:17:40:WU01:FS01:0x18:Unit: 0x00000036ab40415c5674817ae8e4cc9a
03:17:40:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
03:17:40:WU01:FS01:0x18:Machine: 1
03:17:40:WU01:FS01:0x18:Reading tar file core.xml
03:17:40:WU01:FS01:0x18:Reading tar file system.xml
03:17:40:WU01:FS01:0x18:Reading tar file integrator.xml
03:17:40:WU01:FS01:0x18:Reading tar file state.xml
03:17:41:WU01:FS01:0x18:Digital signatures verified
03:17:41:WU01:FS01:0x18:Folding@home GPU core18
03:17:41:WU01:FS01:0x18:Version 0.0.4
03:17:41:WU02:FS02:0x21:*********************** Log Started 2016-08-01T03:17:40Z ***********************
03:17:41:WU02:FS02:0x21:Project: 11403 (Run 0, Clone 9, Gen 261)
03:17:41:WU02:FS02:0x21:Unit: 0x0000015e8ca304f255ed4f1c70261c27
03:17:41:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
03:17:41:WU02:FS02:0x21:Machine: 2
03:17:41:WU02:FS02:0x21:Reading tar file core.xml
03:17:41:WU02:FS02:0x21:Reading tar file system.xml
03:17:41:WU02:FS02:0x21:Reading tar file integrator.xml
03:17:41:WU02:FS02:0x21:Reading tar file state.xml
03:17:41:WU03:FS03:0x21:*********************** Log Started 2016-08-01T03:17:40Z ***********************
03:17:41:WU03:FS03:0x21:Project: 9704 (Run 48, Clone 11, Gen 126)
03:17:41:WU03:FS03:0x21:Unit: 0x000000b5ab404162553ec33606ae73ab
03:17:41:WU03:FS03:0x21:CPU: 0x00000000000000000000000000000000
03:17:41:WU03:FS03:0x21:Machine: 3
03:17:41:WU03:FS03:0x21:Reading tar file core.xml
03:17:41:WU03:FS03:0x21:Reading tar file system.xml
03:17:41:WU02:FS02:0x21:Digital signatures verified
03:17:41:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
03:17:41:WU02:FS02:0x21:Version 0.0.17
03:17:42:WU03:FS03:0x21:Reading tar file integrator.xml
03:17:42:WU03:FS03:0x21:Reading tar file state.xml
03:17:44:WU03:FS03:0x21:Digital signatures verified
03:17:44:WU03:FS03:0x21:Folding@home GPU Core21 Folding@home Core
03:17:44:WU03:FS03:0x21:Version 0.0.17
03:17:48:WU02:FS02:0x21:Completed 0 out of 5000000 steps (0%)
03:17:48:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:17:51:WU01:FS01:0x18:Completed 0 out of 2500000 steps (0%)
03:17:51:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:18:06:Saving configuration to /etc/fahclient/config.xml
03:18:06:<config>
03:18:06: <!-- Folding Core -->
03:18:06: <checkpoint v='30'/>
03:18:06:
03:18:06: <!-- Network -->
03:18:06: <proxy v=':8080'/>
03:18:06:
03:18:06: <!-- Slot Control -->
03:18:06: <pause-on-battery v='false'/>
03:18:06: <power v='full'/>
03:18:06:
03:18:06: <!-- User Information -->
03:18:06: <passkey v='********************************'/>
03:18:06: <user v='RABishop'/>
03:18:06:
03:18:06: <!-- Folding Slots -->
03:18:06: <slot id='0' type='CPU'>
03:18:06: <cpus v='5'/>
03:18:06: <next-unit-percentage v='100'/>
03:18:06: </slot>
03:18:06: <slot id='1' type='GPU'>
03:18:06: </slot>
03:18:06: <slot id='2' type='GPU'>
03:18:06: </slot>
03:18:06: <slot id='3' type='GPU'>
03:18:06: </slot>
03:18:06:</config>
03:18:09:Saving configuration to /etc/fahclient/config.xml
03:18:09:<config>
03:18:09: <!-- Folding Core -->
03:18:09: <checkpoint v='30'/>
03:18:09:
03:18:09: <!-- Network -->
03:18:09: <proxy v=':8080'/>
03:18:09:
03:18:09: <!-- Slot Control -->
03:18:09: <pause-on-battery v='false'/>
03:18:09: <power v='full'/>
03:18:09:
03:18:09: <!-- User Information -->
03:18:09: <passkey v='********************************'/>
03:18:09: <user v='RABishop'/>
03:18:09:
03:18:09: <!-- Folding Slots -->
03:18:09: <slot id='0' type='CPU'>
03:18:09: <cpus v='5'/>
03:18:09: <next-unit-percentage v='100'/>
03:18:09: </slot>
03:18:09: <slot id='1' type='GPU'>
03:18:09: </slot>
03:18:09: <slot id='2' type='GPU'>
03:18:09: </slot>
03:18:09: <slot id='3' type='GPU'>
03:18:09: </slot>
03:18:09:</config>
03:18:38:WU03:FS03:0x21:Completed 0 out of 640000 steps (0%)
03:18:38:WU03:FS03:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:18:39:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
03:18:50:WU01:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
03:19:46:WU01:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
03:19:50:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
03:20:16:WU02:FS02:0x21:Completed 50000 out of 5000000 steps (1%)
03:20:42:WU01:FS01:0x18:Completed 75000 out of 2500000 steps (3%)
03:20:50:WU03:FS03:0x21:Completed 6400 out of 640000 steps (1%)
03:21:02:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
03:21:38:WU01:FS01:0x18:Completed 100000 out of 2500000 steps (4%)
03:22:12:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
03:22:37:WU01:FS01:0x18:Completed 125000 out of 2500000 steps (5%)
03:22:56:WU02:FS02:0x21:Completed 100000 out of 5000000 steps (2%)
03:23:02:WU03:FS03:0x21:Completed 12800 out of 640000 steps (2%)
03:23:23:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
03:23:33:WU01:FS01:0x18:Completed 150000 out of 2500000 steps (6%)
03:24:29:WU01:FS01:0x18:Completed 175000 out of 2500000 steps (7%)
03:24:35:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
03:25:14:WU03:FS03:0x21:Completed 19200 out of 640000 steps (3%)
03:25:25:WU01:FS01:0x18:Completed 200000 out of 2500000 steps (8%)
03:25:38:WU02:FS02:0x21:Completed 150000 out of 5000000 steps (3%)
03:25:50:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
03:26:25:WU01:FS01:0x18:Completed 225000 out of 2500000 steps (9%)
03:27:02:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
03:27:21:WU01:FS01:0x18:Completed 250000 out of 2500000 steps (10%)
03:27:26:WU03:FS03:0x21:Completed 25600 out of 640000 steps (4%)
03:28:15:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
03:28:16:WU01:FS01:0x18:Completed 275000 out of 2500000 steps (11%)
03:28:19:WU02:FS02:0x21:Completed 200000 out of 5000000 steps (4%)
03:29:12:WU01:FS01:0x18:Completed 300000 out of 2500000 steps (12%)
03:29:27:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
03:29:38:WU03:FS03:0x21:Completed 32000 out of 640000 steps (5%)
03:30:12:WU01:FS01:0x18:Completed 325000 out of 2500000 steps (13%)
03:30:40:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
03:30:59:WU02:FS02:0x21:Completed 250000 out of 5000000 steps (5%)
03:31:08:WU01:FS01:0x18:Completed 350000 out of 2500000 steps (14%)
03:31:51:WU03:FS03:0x21:Completed 38400 out of 640000 steps (6%)
03:31:53:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
03:32:04:WU01:FS01:0x18:Completed 375000 out of 2500000 steps (15%)
03:33:00:WU01:FS01:0x18:Completed 400000 out of 2500000 steps (16%)
03:33:05:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
03:33:41:WU02:FS02:0x21:Completed 300000 out of 5000000 steps (6%)
03:33:59:WU01:FS01:0x18:Completed 425000 out of 2500000 steps (17%)
03:34:03:WU03:FS03:0x21:Completed 44800 out of 640000 steps (7%)
03:34:17:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
03:34:55:WU01:FS01:0x18:Completed 450000 out of 2500000 steps (18%)
03:35:29:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
03:35:51:WU01:FS01:0x18:Completed 475000 out of 2500000 steps (19%)
03:36:16:WU03:FS03:0x21:Completed 51200 out of 640000 steps (8%)
03:36:21:WU02:FS02:0x21:Completed 350000 out of 5000000 steps (7%)
03:36:39:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
03:36:48:WU01:FS01:0x18:Completed 500000 out of 2500000 steps (20%)
03:37:47:WU01:FS01:0x18:Completed 525000 out of 2500000 steps (21%)
03:37:48:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
03:38:29:WU03:FS03:0x21:Completed 57600 out of 640000 steps (9%)
03:38:43:WU01:FS01:0x18:Completed 550000 out of 2500000 steps (22%)
03:38:59:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
03:39:03:WU02:FS02:0x21:Completed 400000 out of 5000000 steps (8%)
03:39:40:WU01:FS01:0x18:Completed 575000 out of 2500000 steps (23%)
03:40:09:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
03:40:36:WU01:FS01:0x18:Completed 600000 out of 2500000 steps (24%)
03:40:41:WU03:FS03:0x21:Completed 64000 out of 640000 steps (10%)
03:41:18:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
03:41:36:WU01:FS01:0x18:Completed 625000 out of 2500000 steps (25%)
03:41:43:WU02:FS02:0x21:Completed 450000 out of 5000000 steps (9%)
03:42:28:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
03:42:32:WU01:FS01:0x18:Completed 650000 out of 2500000 steps (26%)
03:42:54:WU03:FS03:0x21:Completed 70400 out of 640000 steps (11%)
03:43:28:WU01:FS01:0x18:Completed 675000 out of 2500000 steps (27%)
03:43:38:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
03:44:23:WU02:FS02:0x21:Completed 500000 out of 5000000 steps (10%)
03:44:24:WU01:FS01:0x18:Completed 700000 out of 2500000 steps (28%)
03:44:49:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
03:45:07:WU03:FS03:0x21:Completed 76800 out of 640000 steps (12%)
03:45:23:WU01:FS01:0x18:Completed 725000 out of 2500000 steps (29%)
03:45:59:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
03:46:20:WU01:FS01:0x18:Completed 750000 out of 2500000 steps (30%)
03:47:05:WU02:FS02:0x21:Completed 550000 out of 5000000 steps (11%)
03:47:09:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
03:47:16:WU01:FS01:0x18:Completed 775000 out of 2500000 steps (31%)
03:47:26:WU03:FS03:0x21:Completed 83200 out of 640000 steps (13%)
03:48:12:WU01:FS01:0x18:Completed 800000 out of 2500000 steps (32%)
03:48:22:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
03:49:11:WU01:FS01:0x18:Completed 825000 out of 2500000 steps (33%)
03:49:34:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
03:49:39:WU03:FS03:0x21:Completed 89600 out of 640000 steps (14%)
03:49:45:WU02:FS02:0x21:Completed 600000 out of 5000000 steps (12%)
03:50:08:WU01:FS01:0x18:Completed 850000 out of 2500000 steps (34%)
03:50:58:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
03:51:04:WU01:FS01:0x18:Completed 875000 out of 2500000 steps (35%)
03:51:53:WU03:FS03:0x21:Completed 96000 out of 640000 steps (15%)
03:52:01:WU01:FS01:0x18:Completed 900000 out of 2500000 steps (36%)
03:52:19:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
03:52:28:WU02:FS02:0x21:Completed 650000 out of 5000000 steps (13%)
03:53:01:WU01:FS01:0x18:Completed 925000 out of 2500000 steps (37%)
03:53:39:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
03:53:58:WU01:FS01:0x18:Completed 950000 out of 2500000 steps (38%)
03:54:06:WU03:FS03:0x21:Completed 102400 out of 640000 steps (16%)
03:54:55:WU01:FS01:0x18:Completed 975000 out of 2500000 steps (39%)
03:55:00:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
03:55:09:WU02:FS02:0x21:Completed 700000 out of 5000000 steps (14%)
03:55:51:WU01:FS01:0x18:Completed 1000000 out of 2500000 steps (40%)
03:56:17:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
03:56:19:WU03:FS03:0x21:Completed 108800 out of 640000 steps (17%)
03:56:51:WU01:FS01:0x18:Completed 1025000 out of 2500000 steps (41%)
03:57:39:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
03:57:48:WU01:FS01:0x18:Completed 1050000 out of 2500000 steps (42%)
03:57:50:WU02:FS02:0x21:Completed 750000 out of 5000000 steps (15%)
03:58:33:WU03:FS03:0x21:Completed 115200 out of 640000 steps (18%)
03:58:45:WU01:FS01:0x18:Completed 1075000 out of 2500000 steps (43%)
03:58:53:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
03:59:41:WU01:FS01:0x18:Completed 1100000 out of 2500000 steps (44%)
04:00:08:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
04:00:32:WU02:FS02:0x21:Completed 800000 out of 5000000 steps (16%)
04:00:41:WU01:FS01:0x18:Completed 1125000 out of 2500000 steps (45%)
04:00:46:WU03:FS03:0x21:Completed 121600 out of 640000 steps (19%)
04:01:25:WU00:FS00:0xa4:Completed 90000 out of 250000 steps (36%)
04:01:38:WU01:FS01:0x18:Completed 1150000 out of 2500000 steps (46%)
04:02:34:WU01:FS01:0x18:Completed 1175000 out of 2500000 steps (47%)
04:02:41:WU00:FS00:0xa4:Completed 92500 out of 250000 steps (37%)
04:02:58:WU03:FS03:0x21:Completed 128000 out of 640000 steps (20%)
04:03:12:WU02:FS02:0x21:Completed 850000 out of 5000000 steps (17%)
04:03:31:WU01:FS01:0x18:Completed 1200000 out of 2500000 steps (48%)
04:03:55:WU00:FS00:0xa4:Completed 95000 out of 250000 steps (38%)
04:04:30:WU01:FS01:0x18:Completed 1225000 out of 2500000 steps (49%)
04:05:11:WU03:FS03:0x21:Completed 134400 out of 640000 steps (21%)
04:05:11:WU00:FS00:0xa4:Completed 97500 out of 250000 steps (39%)
04:05:27:WU01:FS01:0x18:Completed 1250000 out of 2500000 steps (50%)
04:05:54:WU02:FS02:0x21:Completed 900000 out of 5000000 steps (18%)
04:06:23:WU01:FS01:0x18:Completed 1275000 out of 2500000 steps (51%)
04:06:30:WU00:FS00:0xa4:Completed 100000 out of 250000 steps (40%)
04:07:20:WU01:FS01:0x18:Completed 1300000 out of 2500000 steps (52%)
04:07:25:WU03:FS03:0x21:Completed 140800 out of 640000 steps (22%)
04:08:03:WU00:FS00:0xa4:Completed 102500 out of 250000 steps (41%)
04:08:20:WU01:FS01:0x18:Completed 1325000 out of 2500000 steps (53%)
04:08:35:WU02:FS02:0x21:Completed 950000 out of 5000000 steps (19%)
04:09:17:WU01:FS01:0x18:Completed 1350000 out of 2500000 steps (54%)
04:09:17:WU00:FS00:0xa4:Completed 105000 out of 250000 steps (42%)
04:09:38:WU03:FS03:0x21:Completed 147200 out of 640000 steps (23%)
04:10:13:WU01:FS01:0x18:Completed 1375000 out of 2500000 steps (55%)
04:10:29:WU00:FS00:0xa4:Completed 107500 out of 250000 steps (43%)
04:11:09:WU01:FS01:0x18:Completed 1400000 out of 2500000 steps (56%)
04:11:15:WU02:FS02:0x21:Completed 1000000 out of 5000000 steps (20%)
04:11:40:WU00:FS00:0xa4:Completed 110000 out of 250000 steps (44%)
04:11:52:WU03:FS03:0x21:Completed 153600 out of 640000 steps (24%)
04:12:09:WU01:FS01:0x18:Completed 1425000 out of 2500000 steps (57%)
04:12:52:WU00:FS00:0xa4:Completed 112500 out of 250000 steps (45%)
04:13:05:WU01:FS01:0x18:Completed 1450000 out of 2500000 steps (58%)
04:13:57:WU02:FS02:0x21:Completed 1050000 out of 5000000 steps (21%)
04:14:01:WU01:FS01:0x18:Completed 1475000 out of 2500000 steps (59%)
04:14:03:WU00:FS00:0xa4:Completed 115000 out of 250000 steps (46%)
04:14:05:WU03:FS03:0x21:Completed 160000 out of 640000 steps (25%)
04:14:57:WU01:FS01:0x18:Completed 1500000 out of 2500000 steps (60%)
04:15:15:WU00:FS00:0xa4:Completed 117500 out of 250000 steps (47%)
04:15:57:WU01:FS01:0x18:Completed 1525000 out of 2500000 steps (61%)
04:16:24:WU03:FS03:0x21:Completed 166400 out of 640000 steps (26%)
04:16:26:WU00:FS00:0xa4:Completed 120000 out of 250000 steps (48%)
04:16:37:WU02:FS02:0x21:Completed 1100000 out of 5000000 steps (22%)
04:16:53:WU01:FS01:0x18:Completed 1550000 out of 2500000 steps (62%)
04:17:36:WU00:FS00:0xa4:Completed 122500 out of 250000 steps (49%)
04:17:49:WU01:FS01:0x18:Completed 1575000 out of 2500000 steps (63%)
04:18:38:WU03:FS03:0x21:Completed 172800 out of 640000 steps (27%)
04:18:45:WU01:FS01:0x18:Completed 1600000 out of 2500000 steps (64%)
04:18:47:WU00:FS00:0xa4:Completed 125000 out of 250000 steps (50%)
04:19:19:WU02:FS02:0x21:Completed 1150000 out of 5000000 steps (23%)
04:19:44:WU01:FS01:0x18:Completed 1625000 out of 2500000 steps (65%)
04:19:59:WU00:FS00:0xa4:Completed 127500 out of 250000 steps (51%)
04:20:40:WU01:FS01:0x18:Completed 1650000 out of 2500000 steps (66%)
04:20:50:WU03:FS03:0x21:Completed 179200 out of 640000 steps (28%)
04:21:12:WU00:FS00:0xa4:Completed 130000 out of 250000 steps (52%)
04:21:36:WU01:FS01:0x18:Completed 1675000 out of 2500000 steps (67%)
04:21:59:WU02:FS02:0x21:Completed 1200000 out of 5000000 steps (24%)
04:22:24:WU00:FS00:0xa4:Completed 132500 out of 250000 steps (53%)
04:22:32:WU01:FS01:0x18:Completed 1700000 out of 2500000 steps (68%)
04:23:03:WU03:FS03:0x21:Completed 185600 out of 640000 steps (29%)
04:23:32:WU01:FS01:0x18:Completed 1725000 out of 2500000 steps (69%)
04:23:37:WU00:FS00:0xa4:Completed 135000 out of 250000 steps (54%)
04:24:28:WU01:FS01:0x18:Completed 1750000 out of 2500000 steps (70%)
04:24:40:WU02:FS02:0x21:Completed 1250000 out of 5000000 steps (25%)
04:24:48:WU00:FS00:0xa4:Completed 137500 out of 250000 steps (55%)
04:25:16:WU03:FS03:0x21:Completed 192000 out of 640000 steps (30%)
04:25:24:WU01:FS01:0x18:Completed 1775000 out of 2500000 steps (71%)
04:25:58:WU00:FS00:0xa4:Completed 140000 out of 250000 steps (56%)
04:26:20:WU01:FS01:0x18:Completed 1800000 out of 2500000 steps (72%)
04:27:08:WU00:FS00:0xa4:Completed 142500 out of 250000 steps (57%)
04:27:20:WU01:FS01:0x18:Completed 1825000 out of 2500000 steps (73%)
04:27:21:WU02:FS02:0x21:Completed 1300000 out of 5000000 steps (26%)
04:27:29:WU03:FS03:0x21:Completed 198400 out of 640000 steps (31%)
04:28:16:WU01:FS01:0x18:Completed 1850000 out of 2500000 steps (74%)
04:28:18:WU00:FS00:0xa4:Completed 145000 out of 250000 steps (58%)
04:29:12:WU01:FS01:0x18:Completed 1875000 out of 2500000 steps (75%)
04:29:28:WU00:FS00:0xa4:Completed 147500 out of 250000 steps (59%)
04:29:43:WU03:FS03:0x21:Completed 204800 out of 640000 steps (32%)
04:30:02:WU02:FS02:0x21:Completed 1350000 out of 5000000 steps (27%)
04:30:08:WU01:FS01:0x18:Completed 1900000 out of 2500000 steps (76%)
04:30:40:WU00:FS00:0xa4:Completed 150000 out of 250000 steps (60%)
04:31:08:WU01:FS01:0x18:Completed 1925000 out of 2500000 steps (77%)
04:31:53:WU00:FS00:0xa4:Completed 152500 out of 250000 steps (61%)
04:31:56:WU03:FS03:0x21:Completed 211200 out of 640000 steps (33%)
04:32:04:WU01:FS01:0x18:Completed 1950000 out of 2500000 steps (78%)
04:32:44:WU02:FS02:0x21:Completed 1400000 out of 5000000 steps (28%)
04:33:00:WU01:FS01:0x18:Completed 1975000 out of 2500000 steps (79%)
04:33:06:WU00:FS00:0xa4:Completed 155000 out of 250000 steps (62%)
04:33:56:WU01:FS01:0x18:Completed 2000000 out of 2500000 steps (80%)
04:34:10:WU03:FS03:0x21:Completed 217600 out of 640000 steps (34%)
04:34:20:WU00:FS00:0xa4:Completed 157500 out of 250000 steps (63%)
04:34:56:WU01:FS01:0x18:Completed 2025000 out of 2500000 steps (81%)
04:35:24:WU02:FS02:0x21:Completed 1450000 out of 5000000 steps (29%)
04:35:33:WU00:FS00:0xa4:Completed 160000 out of 250000 steps (64%)
04:35:52:WU01:FS01:0x18:Completed 2050000 out of 2500000 steps (82%)
04:36:23:WU03:FS03:0x21:Completed 224000 out of 640000 steps (35%)
04:36:43:WU00:FS00:0xa4:Completed 162500 out of 250000 steps (65%)
04:36:48:WU01:FS01:0x18:Completed 2075000 out of 2500000 steps (83%)
04:37:44:WU01:FS01:0x18:Completed 2100000 out of 2500000 steps (84%)
04:37:53:WU00:FS00:0xa4:Completed 165000 out of 250000 steps (66%)
04:38:04:WU02:FS02:0x21:Completed 1500000 out of 5000000 steps (30%)
04:38:37:WU03:FS03:0x21:Completed 230400 out of 640000 steps (36%)
04:38:44:WU01:FS01:0x18:Completed 2125000 out of 2500000 steps (85%)
04:39:03:WU00:FS00:0xa4:Completed 167500 out of 250000 steps (67%)
04:39:40:WU01:FS01:0x18:Completed 2150000 out of 2500000 steps (86%)
04:40:13:WU00:FS00:0xa4:Completed 170000 out of 250000 steps (68%)
04:40:36:WU01:FS01:0x18:Completed 2175000 out of 2500000 steps (87%)
04:40:46:WU02:FS02:0x21:Completed 1550000 out of 5000000 steps (31%)
04:40:50:WU03:FS03:0x21:Completed 236800 out of 640000 steps (37%)
04:41:24:WU00:FS00:0xa4:Completed 172500 out of 250000 steps (69%)
04:41:32:WU01:FS01:0x18:Completed 2200000 out of 2500000 steps (88%)
04:42:32:WU01:FS01:0x18:Completed 2225000 out of 2500000 steps (89%)
04:42:36:WU00:FS00:0xa4:Completed 175000 out of 250000 steps (70%)
04:43:07:WU03:FS03:0x21:Completed 243200 out of 640000 steps (38%)
04:43:26:WU02:FS02:0x21:Completed 1600000 out of 5000000 steps (32%)
04:43:28:WU01:FS01:0x18:Completed 2250000 out of 2500000 steps (90%)
04:43:46:WU00:FS00:0xa4:Completed 177500 out of 250000 steps (71%)
04:44:24:WU01:FS01:0x18:Completed 2275000 out of 2500000 steps (91%)
04:44:56:WU00:FS00:0xa4:Completed 180000 out of 250000 steps (72%)
04:45:20:WU01:FS01:0x18:Completed 2300000 out of 2500000 steps (92%)
04:45:20:WU03:FS03:0x21:Completed 249600 out of 640000 steps (39%)
04:46:08:WU02:FS02:0x21:Completed 1650000 out of 5000000 steps (33%)
04:46:09:WU00:FS00:0xa4:Completed 182500 out of 250000 steps (73%)
04:46:20:WU01:FS01:0x18:Completed 2325000 out of 2500000 steps (93%)
04:47:16:WU01:FS01:0x18:Completed 2350000 out of 2500000 steps (94%)
04:47:22:WU00:FS00:0xa4:Completed 185000 out of 250000 steps (74%)
04:47:34:WU03:FS03:0x21:Completed 256000 out of 640000 steps (40%)
04:48:12:WU01:FS01:0x18:Completed 2375000 out of 2500000 steps (95%)
04:48:33:WU00:FS00:0xa4:Completed 187500 out of 250000 steps (75%)
04:48:48:WU02:FS02:0x21:Completed 1700000 out of 5000000 steps (34%)
04:49:08:WU01:FS01:0x18:Completed 2400000 out of 2500000 steps (96%)
04:49:43:WU00:FS00:0xa4:Completed 190000 out of 250000 steps (76%)
04:49:47:WU03:FS03:0x21:Completed 262400 out of 640000 steps (41%)
04:50:08:WU01:FS01:0x18:Completed 2425000 out of 2500000 steps (97%)
04:50:53:WU00:FS00:0xa4:Completed 192500 out of 250000 steps (77%)
04:51:04:WU01:FS01:0x18:Completed 2450000 out of 2500000 steps (98%)
04:51:29:WU02:FS02:0x21:Completed 1750000 out of 5000000 steps (35%)
04:52:00:WU01:FS01:0x18:Completed 2475000 out of 2500000 steps (99%)
04:52:01:WU03:FS03:0x21:Completed 268800 out of 640000 steps (42%)
04:52:05:WU00:FS00:0xa4:Completed 195000 out of 250000 steps (78%)
04:52:56:WU01:FS01:0x18:Completed 2500000 out of 2500000 steps (100%)
04:52:57:WU04:FS01:Connecting to 171.67.108.45:80
04:52:57:WU04:FS01:Assigned to work server 171.67.108.159
04:52:57:WU04:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM200 [GeForce GTX 980 Ti] from 171.67.108.159
04:52:57:WU04:FS01:Connecting to 171.67.108.159:8080
04:52:58:WU04:FS01:Downloading 19.26MiB
04:53:00:WU01:FS01:0x18:Saving result file logfile_01.txt
04:53:00:WU01:FS01:0x18:Saving result file checkpointState.xml
04:53:01:WU01:FS01:0x18:Saving result file checkpt.crc
04:53:01:WU01:FS01:0x18:Saving result file log.txt
04:53:01:WU01:FS01:0x18:Saving result file positions.xtc
04:53:01:WU04:FS01:Download complete
04:53:01:WU04:FS01:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:9152 run:16 clone:0 gen:374 core:0x18 unit:0x000001a4ab436c9f56623c6095c403d9
04:53:01:WU01:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
04:53:01:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:53:01:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9162 run:284 clone:0 gen:42 core:0x18 unit:0x00000036ab40415c5674817ae8e4cc9a
04:53:01:WU01:FS01:Uploading 5.54MiB to 171.64.65.92
04:53:01:WU01:FS01:Connecting to 171.64.65.92:8080
04:53:01:WU04:FS01:Starting
04:53:01:WU04:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 04 -suffix 01 -version 704 -lifeline 1345 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
04:53:01:WU04:FS01:Started FahCore on PID 3112
04:53:01:WU04:FS01:Core PID:3116
04:53:01:WU04:FS01:FahCore 0x18 started
04:53:02:WU04:FS01:0x18:*********************** Log Started 2016-08-01T04:53:01Z ***********************
04:53:02:WU04:FS01:0x18:Project: 9152 (Run 16, Clone 0, Gen 374)
04:53:02:WU04:FS01:0x18:Unit: 0x000001a4ab436c9f56623c6095c403d9
04:53:02:WU04:FS01:0x18:CPU: 0x00000000000000000000000000000000
04:53:02:WU04:FS01:0x18:Machine: 1
04:53:02:WU04:FS01:0x18:Reading tar file core.xml
04:53:02:WU04:FS01:0x18:Reading tar file integrator.xml
04:53:02:WU04:FS01:0x18:Reading tar file state.xml
04:53:02:WU04:FS01:0x18:Reading tar file system.xml
04:53:02:WU04:FS01:0x18:Digital signatures verified
04:53:02:WU04:FS01:0x18:Folding@home GPU core18
04:53:02:WU04:FS01:0x18:Version 0.0.4
04:53:07:WU01:FS01:Upload 58.67%
04:53:11:WU04:FS01:0x18:Completed 0 out of 2500000 steps (0%)
04:53:11:WU04:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:53:15:WU00:FS00:0xa4:Completed 197500 out of 250000 steps (79%)
04:53:18:WU01:FS01:Upload complete
04:53:18:WU01:FS01:Server responded WORK_ACK (400)
04:53:18:WU01:FS01:Final credit estimate, 37507.00 points
04:53:18:WU01:FS01:Cleaning up
04:54:07:WU04:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
04:54:10:WU02:FS02:0x21:Completed 1800000 out of 5000000 steps (36%)
04:54:14:WU03:FS03:0x21:Completed 275200 out of 640000 steps (43%)
04:54:28:WU00:FS00:0xa4:Completed 200000 out of 250000 steps (80%)
04:55:00:WU04:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
04:55:41:WU00:FS00:0xa4:Completed 202500 out of 250000 steps (81%)
04:55:54:WU04:FS01:0x18:Completed 75000 out of 2500000 steps (3%)
04:56:28:WU03:FS03:0x21:Completed 281600 out of 640000 steps (44%)
04:56:47:WU04:FS01:0x18:Completed 100000 out of 2500000 steps (4%)
04:56:50:WU02:FS02:0x21:Completed 1850000 out of 5000000 steps (37%)
04:56:53:WU00:FS00:0xa4:Completed 205000 out of 250000 steps (82%)
04:57:44:WU04:FS01:0x18:Completed 125000 out of 2500000 steps (5%)
04:58:05:WU00:FS00:0xa4:Completed 207500 out of 250000 steps (83%)
04:58:38:WU04:FS01:0x18:Completed 150000 out of 2500000 steps (6%)
04:58:41:WU03:FS03:0x21:Completed 288000 out of 640000 steps (45%)
04:59:18:WU00:FS00:0xa4:Completed 210000 out of 250000 steps (84%)
04:59:31:WU04:FS01:0x18:Completed 175000 out of 2500000 steps (7%)
04:59:32:WU02:FS02:0x21:Completed 1900000 out of 5000000 steps (38%)
05:00:25:WU04:FS01:0x18:Completed 200000 out of 2500000 steps (8%)
05:00:31:WU00:FS00:0xa4:Completed 212500 out of 250000 steps (85%)
05:00:53:WU03:FS03:0x21:Completed 294400 out of 640000 steps (46%)
05:01:21:WU04:FS01:0x18:Completed 225000 out of 2500000 steps (9%)
05:01:43:WU00:FS00:0xa4:Completed 215000 out of 250000 steps (86%)
05:02:12:WU02:FS02:0x21:Completed 1950000 out of 5000000 steps (39%)
05:02:15:WU04:FS01:0x18:Completed 250000 out of 2500000 steps (10%)
05:02:57:WU00:FS00:0xa4:Completed 217500 out of 250000 steps (87%)
05:03:06:WU03:FS03:0x21:Completed 300800 out of 640000 steps (47%)
05:03:08:WU04:FS01:0x18:Completed 275000 out of 2500000 steps (11%)
05:04:01:WU04:FS01:0x18:Completed 300000 out of 2500000 steps (12%)
05:04:10:WU00:FS00:0xa4:Completed 220000 out of 250000 steps (88%)
05:04:52:WU02:FS02:0x21:Completed 2000000 out of 5000000 steps (40%)
05:04:58:WU04:FS01:0x18:Completed 325000 out of 2500000 steps (13%)
05:05:18:WU03:FS03:0x21:Completed 307200 out of 640000 steps (48%)
05:05:23:WU00:FS00:0xa4:Completed 222500 out of 250000 steps (89%)
05:05:51:WU04:FS01:0x18:Completed 350000 out of 2500000 steps (14%)
05:06:36:WU00:FS00:0xa4:Completed 225000 out of 250000 steps (90%)
05:06:45:WU04:FS01:0x18:Completed 375000 out of 2500000 steps (15%)
05:07:32:WU03:FS03:0x21:Completed 313600 out of 640000 steps (49%)
05:07:35:WU02:FS02:0x21:Completed 2050000 out of 5000000 steps (41%)
05:07:38:WU04:FS01:0x18:Completed 400000 out of 2500000 steps (16%)
05:07:49:WU00:FS00:0xa4:Completed 227500 out of 250000 steps (91%)
05:08:35:WU04:FS01:0x18:Completed 425000 out of 2500000 steps (17%)
05:08:59:WU00:FS00:0xa4:Completed 230000 out of 250000 steps (92%)
05:09:28:WU04:FS01:0x18:Completed 450000 out of 2500000 steps (18%)
05:09:45:WU03:FS03:0x21:Completed 320000 out of 640000 steps (50%)
05:10:11:WU00:FS00:0xa4:Completed 232500 out of 250000 steps (93%)
05:10:15:WU02:FS02:0x21:Completed 2100000 out of 5000000 steps (42%)
05:10:22:WU04:FS01:0x18:Completed 475000 out of 2500000 steps (19%)
05:11:15:WU04:FS01:0x18:Completed 500000 out of 2500000 steps (20%)
05:11:23:WU00:FS00:0xa4:Completed 235000 out of 250000 steps (94%)
05:12:04:WU03:FS03:0x21:Completed 326400 out of 640000 steps (51%)
05:12:12:WU04:FS01:0x18:Completed 525000 out of 2500000 steps (21%)
05:12:33:WU00:FS00:0xa4:Completed 237500 out of 250000 steps (95%)
05:12:57:WU02:FS02:0x21:Completed 2150000 out of 5000000 steps (43%)
05:13:06:WU04:FS01:0x18:Completed 550000 out of 2500000 steps (22%)
05:13:43:WU00:FS00:0xa4:Completed 240000 out of 250000 steps (96%)
05:13:59:WU04:FS01:0x18:Completed 575000 out of 2500000 steps (23%)
05:14:17:WU03:FS03:0x21:Completed 332800 out of 640000 steps (52%)
05:14:52:WU04:FS01:0x18:Completed 600000 out of 2500000 steps (24%)
05:14:53:WU00:FS00:0xa4:Completed 242500 out of 250000 steps (97%)
05:15:37:WU02:FS02:0x21:Completed 2200000 out of 5000000 steps (44%)
05:15:50:WU04:FS01:0x18:Completed 625000 out of 2500000 steps (25%)
05:16:02:WU00:FS00:0xa4:Completed 245000 out of 250000 steps (98%)
05:16:31:WU03:FS03:0x21:Completed 339200 out of 640000 steps (53%)
05:16:43:WU04:FS01:0x18:Completed 650000 out of 2500000 steps (26%)
05:17:12:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
05:17:36:WU04:FS01:0x18:Completed 675000 out of 2500000 steps (27%)
05:18:17:WU02:FS02:0x21:Completed 2250000 out of 5000000 steps (45%)
05:18:21:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
05:18:21:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:18:22:WU01:FS00:Connecting to 171.67.108.45:8080
05:18:22:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:18:22:WU01:FS00:Connecting to 171.64.65.35:80
05:18:23:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:18:23:ERROR:WU01:FS00:Exception: Could not get an assignment
05:18:23:WU01:FS00:Connecting to 171.67.108.45:8080
05:18:23:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:18:23:WU01:FS00:Connecting to 171.64.65.35:80
05:18:30:WU04:FS01:0x18:Completed 700000 out of 2500000 steps (28%)
05:18:31:WU00:FS00:0xa4:
05:18:31:WU00:FS00:0xa4:Finished Work Unit:
05:18:31:WU00:FS00:0xa4:- Reading up to 811560 from "00/wudata_01.trr": Read 811560
05:18:31:WU00:FS00:0xa4:trr file hash check passed.
05:18:31:WU00:FS00:0xa4:- Reading up to 745672 from "00/wudata_01.xtc": Read 745672
05:18:31:WU00:FS00:0xa4:xtc file hash check passed.
05:18:31:WU00:FS00:0xa4:edr file hash check passed.
05:18:31:WU00:FS00:0xa4:logfile size: 23248
05:18:31:WU00:FS00:0xa4:Leaving Run
05:18:34:WU00:FS00:0xa4:- Writing 1582968 bytes of core data to disk...
05:18:35:WU00:FS00:0xa4:Done: 1582456 -> 1537595 (compressed to 97.1 percent)
05:18:35:WU00:FS00:0xa4: ... Done.
05:18:44:WU03:FS03:0x21:Completed 345600 out of 640000 steps (54%)
05:18:52:WU00:FS00:0xa4:- Shutting down core
05:18:52:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
05:18:55:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:18:55:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9036 run:356 clone:2 gen:364 core:0xa4 unit:0x00000193ab436c9e56982cecc99d5be8
05:18:55:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
05:18:55:WU00:FS00:Connecting to 171.67.108.158:8080
05:18:58:WU00:FS00:Upload complete
05:18:58:WU00:FS00:Server responded WORK_ACK (400)
05:18:58:WU00:FS00:Final credit estimate, 1730.00 points
05:18:58:WU00:FS00:Cleaning up
05:19:23:WU01:FS00:Connecting to 171.67.108.45:8080
05:19:23:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:19:23:WU01:FS00:Connecting to 171.64.65.35:80
05:19:23:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:19:23:ERROR:WU01:FS00:Exception: Could not get an assignment
05:19:25:WU04:FS01:0x18:Completed 725000 out of 2500000 steps (29%)
05:20:18:WU04:FS01:0x18:Completed 750000 out of 2500000 steps (30%)
05:20:57:WU03:FS03:0x21:Completed 352000 out of 640000 steps (55%)
05:20:58:WU02:FS02:0x21:Completed 2300000 out of 5000000 steps (46%)
05:21:00:WU01:FS00:Connecting to 171.67.108.45:8080
05:21:01:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:21:01:WU01:FS00:Connecting to 171.64.65.35:80
05:21:01:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:21:01:ERROR:WU01:FS00:Exception: Could not get an assignment
05:21:11:WU04:FS01:0x18:Completed 775000 out of 2500000 steps (31%)
05:22:04:WU04:FS01:0x18:Completed 800000 out of 2500000 steps (32%)
05:22:59:WU04:FS01:0x18:Completed 825000 out of 2500000 steps (33%)
05:23:09:WU03:FS03:0x21:Completed 358400 out of 640000 steps (56%)
05:23:38:WU02:FS02:0x21:Completed 2350000 out of 5000000 steps (47%)
05:23:38:WU01:FS00:Connecting to 171.67.108.45:8080
05:23:38:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:23:38:WU01:FS00:Connecting to 171.64.65.35:80
05:23:38:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:23:38:ERROR:WU01:FS00:Exception: Could not get an assignment
05:23:52:WU04:FS01:0x18:Completed 850000 out of 2500000 steps (34%)
05:24:45:WU04:FS01:0x18:Completed 875000 out of 2500000 steps (35%)
05:25:20:WU03:FS03:0x21:Completed 364800 out of 640000 steps (57%)
05:25:38:WU04:FS01:0x18:Completed 900000 out of 2500000 steps (36%)
05:26:18:WU02:FS02:0x21:Completed 2400000 out of 5000000 steps (48%)
05:26:34:WU04:FS01:0x18:Completed 925000 out of 2500000 steps (37%)
05:27:27:WU04:FS01:0x18:Completed 950000 out of 2500000 steps (38%)
05:27:33:WU03:FS03:0x21:Completed 371200 out of 640000 steps (58%)
05:27:52:WU01:FS00:Connecting to 171.67.108.45:8080
05:27:54:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:27:54:WU01:FS00:Connecting to 171.64.65.35:80
05:27:54:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:27:54:ERROR:WU01:FS00:Exception: Could not get an assignment
05:28:20:WU04:FS01:0x18:Completed 975000 out of 2500000 steps (39%)
05:28:57:WU02:FS02:0x21:Completed 2450000 out of 5000000 steps (49%)
05:29:13:WU04:FS01:0x18:Completed 1000000 out of 2500000 steps (40%)
05:29:46:WU03:FS03:0x21:Completed 377600 out of 640000 steps (59%)
05:30:08:WU04:FS01:0x18:Completed 1025000 out of 2500000 steps (41%)
05:31:01:WU04:FS01:0x18:Completed 1050000 out of 2500000 steps (42%)
05:31:37:WU02:FS02:0x21:Completed 2500000 out of 5000000 steps (50%)
05:31:54:WU04:FS01:0x18:Completed 1075000 out of 2500000 steps (43%)
05:31:59:WU03:FS03:0x21:Completed 384000 out of 640000 steps (60%)
05:32:47:WU04:FS01:0x18:Completed 1100000 out of 2500000 steps (44%)
05:33:43:WU04:FS01:0x18:Completed 1125000 out of 2500000 steps (45%)
05:34:12:WU03:FS03:0x21:Completed 390400 out of 640000 steps (61%)
05:34:17:WU02:FS02:0x21:Completed 2550000 out of 5000000 steps (51%)
05:34:35:WU04:FS01:0x18:Completed 1150000 out of 2500000 steps (46%)
05:34:43:WU01:FS00:Connecting to 171.67.108.45:8080
05:34:44:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:34:44:WU01:FS00:Connecting to 171.64.65.35:80
05:34:44:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:34:44:ERROR:WU01:FS00:Exception: Could not get an assignment
05:35:28:WU04:FS01:0x18:Completed 1175000 out of 2500000 steps (47%)
05:36:21:WU04:FS01:0x18:Completed 1200000 out of 2500000 steps (48%)
05:36:25:WU03:FS03:0x21:Completed 396800 out of 640000 steps (62%)
05:36:56:WU02:FS02:0x21:Completed 2600000 out of 5000000 steps (52%)
05:37:17:WU04:FS01:0x18:Completed 1225000 out of 2500000 steps (49%)
05:38:10:WU04:FS01:0x18:Completed 1250000 out of 2500000 steps (50%)
05:38:41:WU03:FS03:0x21:Completed 403200 out of 640000 steps (63%)
05:39:03:WU04:FS01:0x18:Completed 1275000 out of 2500000 steps (51%)
05:39:37:WU02:FS02:0x21:Completed 2650000 out of 5000000 steps (53%)
05:39:56:WU04:FS01:0x18:Completed 1300000 out of 2500000 steps (52%)
05:40:51:WU04:FS01:0x18:Completed 1325000 out of 2500000 steps (53%)
05:40:54:WU03:FS03:0x21:Completed 409600 out of 640000 steps (64%)
05:41:44:WU04:FS01:0x18:Completed 1350000 out of 2500000 steps (54%)
05:42:17:WU02:FS02:0x21:Completed 2700000 out of 5000000 steps (54%)
05:42:37:WU04:FS01:0x18:Completed 1375000 out of 2500000 steps (55%)
05:43:06:WU03:FS03:0x21:Completed 416000 out of 640000 steps (65%)
05:43:30:WU04:FS01:0x18:Completed 1400000 out of 2500000 steps (56%)
05:44:25:WU04:FS01:0x18:Completed 1425000 out of 2500000 steps (57%)
05:44:56:WU02:FS02:0x21:Completed 2750000 out of 5000000 steps (55%)
05:45:18:WU03:FS03:0x21:Completed 422400 out of 640000 steps (66%)
05:45:18:WU04:FS01:0x18:Completed 1450000 out of 2500000 steps (58%)
05:45:49:WU01:FS00:Connecting to 171.67.108.45:8080
05:45:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:45:49:WU01:FS00:Connecting to 171.64.65.35:80
05:45:49:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
rwh202
3x GTX 1080 Ti
3x GTX 1060
Re: Failed to connect to 171.64.65.99
I would hazard a guess that setting the cpu to 5 threads is the issue, much like 7 and 11 threads results in no assignment due to being primes. Maybe try setting it to 4 and see how things go?
@rwj20203:17:21:WARNING:WU00:FS00:Changed SMP threads from 8 to 5 this can cause some work units to fail
You might be right, but I'm not sure it's the 5, but rather the fact that an active WU was changed. [Those two problems are not well understood.]
@RABishop
I would recommend you set your CPU count to 5 BEFORE downloading a WU or after a FINISH (on the CPU slot, at least)
... then: config + slot + edit the CPU slot + change the number to 5 at the top of the next screen.
I am not certain which other CPU projects are active at the moment that can take an assignment request for CPU:5, however some of the the Project 9031-40 WU's failed at a multiple of 5. So that WS does not assign to requests for CPU:5 due to the higher failure rate. Not all WU's from these projects will fail when run on CPU:5, but enough will that the restriction was set.
Yeah. I don't get the whole thing about a "PRIME" number of slots not working for CPUs either. For a while, people were posting in here that it was only the "higher" levels of primes that weren't working, for unknown reasons. Since all primes are "odd" by definitions, except of course for 2, which knocks out every even prime, maybe it's any prime NOW beyond 3. Or, maybe it's just any odd number. One thing I did do, which was something I had never done before, was to add all 3 GPU slots at once. Naturally, I had to add them one-by-one, but I only saved them all together, once. That left the number of CPU slots at 8, which I then knocked back down to 5 at one fell swoop. Apparently that was ok for the one job already running, but then left the CPU hanging out there.
I have two GPUs (the TIs) both finishing in 9 minutes or so. I've set them to finish. After they do, I'll remove them and the CPU slot. Then I'll add the CPU back with 7 slots, and save it. Then I'll add each of the TIs back, individually (which should draw the CPU back down to 5), and then I'll see how that works. The last GPU won't finish for about 6 hours. I'll set it to finish too. Maybe it was just adding (saving) all the GPUs at once that confused this to start with. Whatever the case, I won't be adding (saving) more than one GPU at a time, ever again. Thanks for your help. I'll let you know.
I tried what I said I would. But adding the two GPUs with a -1, each, one at a time didn't adjust the CPU slots, since (apparently) once you override and set the CPU at a set number, the adjustments to CPU slots don't happen automatically after that when the GPUs are added. Obviously, both the CPU and GPU have to be set at -1 or adjustments do not occur. I'm on a different machine now, and it too had the same problem. Simply setting CPU from 5 to 4 seems to have cleared that one up. However, a third machine had the CPU running fine with 9 cores, but one of the GPUs was stuck. I set that CPU to 8, removed the GPU, and added it back in. All seems well for that one, for now. Of course, who knows once it finishes something and attempts to upload. I have a fourth machine I'm about to check. I've noticed my daily totals going down over the week and today, so that 4th one probably has a problem too.
It appears what this boils down to is that CPU jobs just really need to be running on an even number of cores, unless maybe you just have one each of CPU and GPU. It might be best to just tell people that.
I was wrong. This fourth machine is working just fine with 9 CPU slots and 3 GPUs--mysteriouser and mysteriouser. So the one that had the stalled CPU with 5 threads running (except for maybe the brand name of memory) had the same processor, motherboard, and other specs. The one that had the stalled GPU with the CPU running ok with 9 threads is basically the same as this machine, except for some differences in GPUs. I had to change the last machine to 8 threads to get the stalled GPU to work on the other machine, but on this one, no adjustments were required. Both these are x99s, but one is ASUS, the other ASRock. Same processors, memory amounts and configurations. I don't get it.
