Failed to get assignment 171.67.108.45:80 171.67.108.204:80
ThunderRd
Post by ThunderRd »
I have been getting this output for the last week or so on a machine that has been running the client 24/7 for years. Can I conclude that the WUs have finally dried up? If that's the case, I'll shut it down.
This machine is running an older card, a GT440. It produced around 3000 ppd until now.
*********************** Log Started 2016-07-21T07:51:29Z ***********************
07:51:29:************************* Folding@home Client *************************
07:51:29:      Website: http://folding.stanford.edu/
07:51:29:    Copyright: (c) 2009-2014 Stanford University
07:51:29:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:51:29:         Args:
07:51:29:       Config: C:/Documents and Settings/admin/Application
07:51:29:               Data/FAHClient/config.xml
07:51:29:******************************** Build ********************************
07:51:29:      Version: 7.4.4
07:51:29:         Date: Mar 4 2014
07:51:29:         Time: 20:26:54
07:51:29:      SVN Rev: 4130
07:51:29:       Branch: fah/trunk/client
07:51:29:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
07:51:29:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
07:51:29:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
07:51:29:     Platform: win32 XP
07:51:29:         Bits: 32
07:51:29:         Mode: Release
07:51:29:******************************* System ********************************
07:51:29:          CPU: Intel(R) Pentium(R) D CPU 3.00GHz
07:51:29:       CPU ID: GenuineIntel Family 15 Model 6 Stepping 5
07:51:29:         CPUs: 2
07:51:29:       Memory: 2.00GiB
07:51:29:  Free Memory: 1.26GiB
07:51:29:      Threads: WINDOWS_THREADS
07:51:29:   OS Version: 5.1
07:51:29:  Has Battery: false
07:51:29:   On Battery: false
07:51:29:   UTC Offset: 7
07:51:29:          PID: 676
07:51:29:          CWD: C:/Documents and Settings/admin/Application Data/FAHClient
07:51:29:           OS: Microsoft Windows XP Service Pack 3
07:51:29:      OS Arch: X86
07:51:29:         GPUs: 1
07:51:29:        GPU 0: NVIDIA:2 GF108 [GeForce GT 440]
07:51:29:         CUDA: 2.1
07:51:29:  CUDA Driver: 8000
07:51:29:Win32 Service: false
07:51:29:***********************************************************************
07:51:29:<config>
07:51:29:  <service-description v='Folding@home Client'/>
07:51:29:  <service-restart v='true'/>
07:51:29:  <service-restart-delay v='5000'/>
07:51:29:
07:51:29:  <!-- Client Control -->
07:51:29:  <client-threads v='6'/>
07:51:29:  <cycle-rate v='4'/>
07:51:29:  <cycles v='-1'/>
07:51:29:  <data-directory v='.'/>
07:51:29:  <disable-sleep-when-active v='true'/>
07:51:29:  <exec-directory v='d:\Program Files\FAHClient'/>
07:51:29:  <exit-when-done v='false'/>
07:51:29:  <fold-anon v='false'/>
07:51:29:  <open-web-control v='false'/>
07:51:29:
07:51:29:  <!-- Configuration -->
07:51:29:  <config-rotate v='true'/>
07:51:29:  <config-rotate-dir v='configs'/>
07:51:29:  <config-rotate-max v='16'/>
07:51:29:
07:51:29:  <!-- Debugging -->
07:51:29:  <assignment-servers>
07:51:29:    assign3.stanford.edu:8080 assign4.stanford.edu:80
07:51:29:  </assignment-servers>
07:51:29:  <auth-as v='true'/>
07:51:29:  <capture-directory v='capture'/>
07:51:29:  <capture-on-error v='false'/>
07:51:29:  <capture-packets v='false'/>
07:51:29:  <capture-requests v='false'/>
07:51:29:  <capture-responses v='false'/>
07:51:29:  <capture-sockets v='false'/>
07:51:29:  <core-exec v='FahCore_$type'/>
07:51:29:  <core-wrapper-exec v='FAHCoreWrapper'/>
07:51:29:  <debug-sockets v='false'/>
07:51:29:  <exception-locations v='true'/>
07:51:29:  <gpu-assignment-servers>
07:51:29:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
07:51:29:  </gpu-assignment-servers>
07:51:29:  <stack-traces v='false'/>
07:51:29:
07:51:29:  <!-- Error Handling -->
07:51:29:  <max-slot-errors v='10'/>
07:51:29:  <max-unit-errors v='5'/>
07:51:29:
07:51:29:  <!-- Folding Core -->
07:51:29:  <checkpoint v='15'/>
07:51:29:  <core-dir v='cores'/>
07:51:29:  <core-priority v='idle'/>
07:51:29:  <cpu-affinity v='false'/>
07:51:29:  <cpu-usage v='100'/>
07:51:29:  <gpu-usage v='100'/>
07:51:29:  <no-assembly v='false'/>
07:51:29:
07:51:29:  <!-- Folding Slot Configuration -->
07:51:29:  <cause v='ANY'/>
07:51:29:  <client-subtype v='STDCLI'/>
07:51:29:  <client-type v='normal'/>
07:51:29:  <cpu-species v='UNKNOWN'/>
07:51:29:  <cpu-type v='X86'/>
07:51:29:  <cpus v='-1'/>
07:51:29:  <gpu v='true'/>
07:51:29:  <max-packet-size v='normal'/>
07:51:29:  <os-species v='WIN_XP'/>
07:51:29:  <os-type v='WIN32'/>
07:51:29:  <project-key v='0'/>
07:51:29:  <smp v='true'/>
07:51:29:
07:51:29:  <!-- GUI -->
07:51:29:  <gui-enabled v='true'/>
07:51:29:
07:51:29:  <!-- HTTP Server -->
07:51:29:  <allow v='127.0.0.1'/>
07:51:29:  <connection-timeout v='60'/>
07:51:29:  <deny v='0/0'/>
07:51:29:  <http-addresses v='0:7396'/>
07:51:29:  <https-addresses v=''/>
07:51:29:  <max-connect-time v='900'/>
07:51:29:  <max-connections v='800'/>
07:51:29:  <max-request-length v='52428800'/>
07:51:29:  <min-connect-time v='300'/>
07:51:29:  <threads v='2'/>
07:51:29:
07:51:29:  <!-- Logging -->
07:51:29:  <log v='log.txt'/>
07:51:29:  <log-color v='false'/>
07:51:29:  <log-crlf v='true'/>
07:51:29:  <log-date v='false'/>
07:51:29:  <log-date-periodically v='21600'/>
07:51:29:  <log-debug v='true'/>
07:51:29:  <log-domain v='false'/>
07:51:29:  <log-header v='true'/>
07:51:29:  <log-level v='true'/>
07:51:29:  <log-no-info-header v='true'/>
07:51:29:  <log-redirect v='false'/>
07:51:29:  <log-rotate v='true'/>
07:51:29:  <log-rotate-dir v='logs'/>
07:51:29:  <log-rotate-max v='16'/>
07:51:29:  <log-short-level v='false'/>
07:51:29:  <log-simple-domains v='true'/>
07:51:29:  <log-thread-id v='false'/>
07:51:29:  <log-thread-prefix v='true'/>
07:51:29:  <log-time v='true'/>
07:51:29:  <log-to-screen v='true'/>
07:51:29:  <log-truncate v='false'/>
07:51:29:  <verbosity v='4'/>
07:51:29:
07:51:29:  <!-- Network -->
07:51:29:  <proxy v=':8080'/>
07:51:29:  <proxy-enable v='false'/>
07:51:29:  <proxy-pass v=''/>
07:51:29:  <proxy-user v=''/>
07:51:29:
07:51:29:  <!-- Process Control -->
07:51:29:  <child v='false'/>
07:51:29:  <daemon v='false'/>
07:51:29:  <pid v='false'/>
07:51:29:  <pid-file v='Folding@home Client.pid'/>
07:51:29:  <respawn v='false'/>
07:51:29:  <service v='false'/>
07:51:29:
07:51:29:  <!-- Remote Command Server -->
07:51:29:  <command-address v='0.0.0.0'/>
07:51:29:  <command-allow-no-pass v='127.0.0.1'/>
07:51:29:  <command-deny-no-pass v='0/0'/>
07:51:29:  <command-enable v='true'/>
07:51:29:  <command-port v='36330'/>
07:51:29:
07:51:29:  <!-- Slot Control -->
07:51:29:  <idle v='false'/>
07:51:29:  <max-shutdown-wait v='60'/>
07:51:29:  <pause-on-battery v='false'/>
07:51:29:  <pause-on-start v='false'/>
07:51:29:  <paused v='false'/>
07:51:29:  <power v='FULL'/>
07:51:29:
07:51:29:  <!-- User Information -->
07:51:29:  <machine-id v='0'/>
07:51:29:  <passkey v='********************************'/>
07:51:29:  <team v='45'/>
07:51:29:  <user v='ThunderRd'/>
07:51:29:
07:51:29:  <!-- Web Server -->
07:51:29:  <web-allow v='127.0.0.1'/>
07:51:29:  <web-deny v='0/0'/>
07:51:29:  <web-enable v='true'/>
07:51:29:
07:51:29:  <!-- Web Server Sessions -->
07:51:29:  <session-cookie v='sid'/>
07:51:29:  <session-lifetime v='86400'/>
07:51:29:  <session-timeout v='3600'/>
07:51:29:
07:51:29:  <!-- Work Unit Control -->
07:51:29:  <dump-after-deadline v='true'/>
07:51:29:  <max-queue v='16'/>
07:51:29:  <max-units v='0'/>
07:51:29:  <next-unit-percentage v='99'/>
07:51:29:  <stall-detection-enabled v='false'/>
07:51:29:  <stall-percent v='5'/>
07:51:29:  <stall-timeout v='1800'/>
07:51:29:
07:51:29:  <!-- Folding Slots -->
07:51:29:  <slot id='0' type='CPU'>
07:51:29:    <cpus v='1'/>
07:51:29:  </slot>
07:51:29:  <slot id='1' type='GPU'/>
07:51:29:</config>
07:51:29:Trying to access database...
07:51:29:Successfully acquired database lock
07:51:29:Enabled folding slot 00: READY cpu:1
07:51:29:Enabled folding slot 01: READY gpu:0:GF108 [GeForce GT 440]
07:51:29:WU00:FS00:Starting
07:51:29:WU00:FS00:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 676 -checkpoint 15
07:51:29:WU00:FS00:Started FahCore on PID 360
07:51:29:WU00:FS00:Core PID:776
07:51:29:WU00:FS00:FahCore 0xa4 started
07:51:30:WU00:FS00:0xa4:
07:51:30:WU00:FS00:0xa4:*------------------------------*
07:51:30:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
07:51:30:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
07:51:30:WU00:FS00:0xa4:Preparing to commence simulation
07:51:30:WU00:FS00:0xa4:- Looking at optimizations...
07:51:30:WU00:FS00:0xa4:- Files status OK
07:51:30:WU00:FS00:0xa4:- Expanded 825608 -> 1401112 (decompressed 169.7 percent)
07:51:30:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825608 data_size=1401112, decompressed_data_size=1401112 diff=0
07:51:30:WU00:FS00:0xa4:- Digital signature verified
07:51:30:WU00:FS00:0xa4:Project: 9034 (Run 34, Clone 0, Gen 371)
07:51:30:WU00:FS00:0xa4:Assembly optimizations on if available.
07:51:30:WU00:FS00:0xa4:Entering M.D.
07:51:30:WU01:FS01:Connecting to 171.67.108.45:80
07:51:31:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:51:31:WU01:FS01:Connecting to 171.67.108.204:80
07:51:32:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:51:32:ERROR:WU01:FS01:Exception: Could not get an assignment
07:51:32:WU01:FS01:Connecting to 171.67.108.45:80
07:51:33:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:51:33:WU01:FS01:Connecting to 171.67.108.204:80
07:51:34:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:51:34:ERROR:WU01:FS01:Exception: Could not get an assignment
07:51:36:WU00:FS00:0xa4:Mapping NT from 1 to 1
07:51:37:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
07:52:32:WU01:FS01:Connecting to 171.67.108.45:80
07:52:33:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:52:33:WU01:FS01:Connecting to 171.67.108.204:80
07:52:33:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:52:33:ERROR:WU01:FS01:Exception: Could not get an assignment
07:54:10:WU01:FS01:Connecting to 171.67.108.45:80
07:54:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:54:10:WU01:FS01:Connecting to 171.67.108.204:80
07:54:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:54:10:ERROR:WU01:FS01:Exception: Could not get an assignment
07:56:47:WU01:FS01:Connecting to 171.67.108.45:80
07:56:47:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:56:47:WU01:FS01:Connecting to 171.67.108.204:80
07:56:48:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:56:48:ERROR:WU01:FS01:Exception: Could not get an assignment
08:01:01:WU01:FS01:Connecting to 171.67.108.45:80
08:01:02:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:01:02:WU01:FS01:Connecting to 171.67.108.204:80
08:01:02:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
08:01:02:ERROR:WU01:FS01:Exception: Could not get an assignment
08:07:52:WU01:FS01:Connecting to 171.67.108.45:80
08:07:53:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
08:07:53:WU01:FS01:Connecting to 171.67.108.204:80
08:07:53:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
08:07:53:ERROR:WU01:FS01:Exception: Could not get an assignment
Re: Failed to get assignment 171.67.108.45:80 171.67.108.204
One server looks empty.
But can't tell about the other server. Don't know what's wrong with the other server giving the Bad Gateway error. I would not conclude the work units have dried up until all the servers say Empty, instead of giving an error.
It is kind of hard to tell how you have your client configured, please return logging verbosity to the default of 3. The higher verbosity level is extremely rarely useful.
As for the two servers you posted about, both are Assignments Servers and never have WU's to assign. They only serve to match up your client with suitable projects. If you look at older log files, which WS's were your client connecting to to get work from after contacting the AS's?
ThunderRd
Post by ThunderRd »
Here is verbosity 3:
*********************** Log Started 2016-07-22T05:38:40Z ***********************
05:38:40:************************* Folding@home Client *************************
05:38:40:      Website: http://folding.stanford.edu/
05:38:40:    Copyright: (c) 2009-2014 Stanford University
05:38:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:38:40:         Args:
05:38:40:       Config: C:/Documents and Settings/admin/Application
05:38:40:               Data/FAHClient/config.xml
05:38:40:******************************** Build ********************************
05:38:40:      Version: 7.4.4
05:38:40:         Date: Mar 4 2014
05:38:40:         Time: 20:26:54
05:38:40:      SVN Rev: 4130
05:38:40:       Branch: fah/trunk/client
05:38:40:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:38:40:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:38:40:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:38:40:     Platform: win32 XP
05:38:40:         Bits: 32
05:38:40:         Mode: Release
05:38:40:******************************* System ********************************
05:38:40:          CPU: Intel(R) Pentium(R) D CPU 3.00GHz
05:38:40:       CPU ID: GenuineIntel Family 15 Model 6 Stepping 5
05:38:40:         CPUs: 2
05:38:40:       Memory: 2.00GiB
05:38:40:  Free Memory: 1.07GiB
05:38:40:      Threads: WINDOWS_THREADS
05:38:40:   OS Version: 5.1
05:38:40:  Has Battery: false
05:38:40:   On Battery: false
05:38:40:   UTC Offset: 7
05:38:40:          PID: 804
05:38:40:          CWD: C:/Documents and Settings/admin/Application Data/FAHClient
05:38:40:           OS: Microsoft Windows XP Service Pack 3
05:38:40:      OS Arch: X86
05:38:40:         GPUs: 1
05:38:40:        GPU 0: NVIDIA:2 GF108 [GeForce GT 440]
05:38:40:         CUDA: 2.1
05:38:40:  CUDA Driver: 8000
05:38:40:Win32 Service: false
05:38:40:***********************************************************************
05:38:40:<config>
05:38:40:  <!-- Network -->
05:38:40:  <proxy v=':8080'/>
05:38:40:
05:38:40:  <!-- Slot Control -->
05:38:40:  <pause-on-battery v='false'/>
05:38:40:  <power v='FULL'/>
05:38:40:
05:38:40:  <!-- User Information -->
05:38:40:  <passkey v='********************************'/>
05:38:40:  <team v='45'/>
05:38:40:  <user v='ThunderRd'/>
05:38:40:
05:38:40:  <!-- Folding Slots -->
05:38:40:  <slot id='0' type='CPU'>
05:38:40:    <cpus v='1'/>
05:38:40:  </slot>
05:38:40:  <slot id='1' type='GPU'/>
05:38:40:</config>
05:38:40:Trying to access database...
05:38:40:Successfully acquired database lock
05:38:40:Enabled folding slot 00: READY cpu:1
05:38:40:Enabled folding slot 01: READY gpu:0:GF108 [GeForce GT 440]
05:38:40:WU00:FS00:Starting
05:38:40:WU00:FS00:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 804 -checkpoint 15
05:38:40:WU00:FS00:Started FahCore on PID 808
05:38:40:WU00:FS00:Core PID:1132
05:38:40:WU00:FS00:FahCore 0xa4 started
05:38:40:WU00:FS00:0xa4:
05:38:40:WU00:FS00:0xa4:*------------------------------*
05:38:40:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:38:40:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:38:40:WU00:FS00:0xa4:Preparing to commence simulation
05:38:40:WU00:FS00:0xa4:- Looking at optimizations...
05:38:40:WU00:FS00:0xa4:- Files status OK
05:38:40:WU00:FS00:0xa4:- Expanded 825608 -> 1401112 (decompressed 169.7 percent)
05:38:40:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825608 data_size=1401112, decompressed_data_size=1401112 diff=0
05:38:40:WU00:FS00:0xa4:- Digital signature verified
05:38:40:WU00:FS00:0xa4:Project: 9034 (Run 34, Clone 0, Gen 371)
05:38:40:WU00:FS00:0xa4:Assembly optimizations on if available.
05:38:40:WU00:FS00:0xa4:Entering M.D.
05:38:41:WU01:FS01:Connecting to 171.67.108.45:80
05:38:42:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:38:42:WU01:FS01:Connecting to 171.67.108.204:80
05:38:43:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
05:38:43:ERROR:WU01:FS01:Exception: Could not get an assignment
05:38:43:WU01:FS01:Connecting to 171.67.108.45:80
05:38:44:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
05:38:44:WU01:FS01:Connecting to 171.67.108.204:80
05:38:45:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
05:38:45:ERROR:WU01:FS01:Exception: Could not get an assignment
05:38:46:WU00:FS00:0xa4:Using Gromacs checkpoints
05:38:46:WU00:FS00:0xa4:Mapping NT from 1 to 1
05:38:47:WU00:FS00:0xa4:Resuming from checkpoint
05:38:47:WU00:FS00:0xa4:Verified 00/wudata_01.log
05:38:47:WU00:FS00:0xa4:Verified 00/wudata_01.trr
05:38:47:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
05:38:47:WU00:FS00:0xa4:Verified 00/wudata_01.edr
05:38:48:WU00:FS00:0xa4:Completed 183350 out of 250000 steps  (73%)
The relevant part of the old log in which the problem begins is here. The problem appears to be several weeks old:
02:15:36:FS00:Shutting core down
02:15:36:FS01:Shutting core down
02:15:36:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 1920
02:15:36:WU00:FS01:0x17:Exiting, please wait. . .
02:15:38:WU00:FS01:0x17:Lost lifeline PID 1032, exiting
02:15:38:WU00:FS01:0x17:ERROR:103: Lost client lifeline
02:15:39:WU00:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
02:15:39:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:15:43:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:15:56:Removing old file 'configs/config-20160613-073523.xml'
02:15:56:Saving configuration to config.xml
02:15:56:<config>
02:15:56:  <!-- Logging -->
02:15:56:  <verbosity v='4'/>
02:15:56:
02:15:56:  <!-- Network -->
02:15:56:  <proxy v=':8080'/>
02:15:56:
02:15:56:  <!-- Slot Control -->
02:15:56:  <pause-on-battery v='false'/>
02:15:56:  <power v='FULL'/>
02:15:56:
02:15:56:  <!-- User Information -->
02:15:56:  <passkey v='********************************'/>
02:15:56:  <team v='45'/>
02:15:56:  <user v='ThunderRd'/>
02:15:56:
02:15:56:  <!-- Folding Slots -->
02:15:56:  <slot id='0' type='CPU'>
02:15:56:    <paused v='true'/>
02:15:56:  </slot>
02:15:56:  <slot id='1' type='GPU'>
02:15:56:  </slot>
02:15:56:</config>
02:36:31:FS00:Unpaused
02:36:31:FS01:Unpaused
02:36:31:WU00:FS01:Starting
02:36:31:WU00:FS01:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 00 -suffix 01 -version 704 -lifeline 1356 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
02:36:31:WU00:FS01:Started FahCore on PID 7840
02:36:31:WU00:FS01:Core PID:6320
02:36:31:WU00:FS01:FahCore 0x17 started
02:36:31:WU02:FS00:Starting
02:36:31:WU02:FS00:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 704 -lifeline 1356 -checkpoint 15
02:36:31:WU02:FS00:Started FahCore on PID 7856
02:36:31:WU02:FS00:Core PID:7612
02:36:31:WU02:FS00:FahCore 0xa4 started
02:36:31:WU00:FS01:0x17:*********************** Log Started 2016-06-29T02:36:31Z ***********************
02:36:31:WU00:FS01:0x17:Project: 10469 (Run 0, Clone 102, Gen 291)
02:36:31:WU00:FS01:0x17:Unit: 0x000001dd538b3db9538f3ad177295af5
02:36:31:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
02:36:31:WU00:FS01:0x17:Machine: 1
02:36:31:WU00:FS01:0x17:Digital signatures verified
02:36:31:WU00:FS01:0x17:Folding@home GPU core17
02:36:31:WU00:FS01:0x17:Version 0.0.52
02:36:31:WU00:FS01:0x17:  Found a checkpoint file
02:36:31:WU02:FS00:0xa4:
02:36:31:WU02:FS00:0xa4:*------------------------------*
02:36:31:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
02:36:31:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:36:31:WU02:FS00:0xa4:Preparing to commence simulation
02:36:31:WU02:FS00:0xa4:- Looking at optimizations...
02:36:31:WU02:FS00:0xa4:- Files status OK
02:36:31:WU02:FS00:0xa4:- Expanded 824937 -> 1398040 (decompressed 169.4 percent)
02:36:31:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=824937 data_size=1398040, decompressed_data_size=1398040 diff=0
02:36:31:WU02:FS00:0xa4:- Digital signature verified
02:36:31:WU02:FS00:0xa4:Project: 9039 (Run 855, Clone 1, Gen 310)
02:36:31:WU02:FS00:0xa4:Assembly optimizations on if available.
02:36:31:WU02:FS00:0xa4:Entering M.D.
02:36:37:WU02:FS00:0xa4:Using Gromacs checkpoints
02:36:37:WU02:FS00:0xa4:Mapping NT from 1 to 1
02:36:38:WU02:FS00:0xa4:Resuming from checkpoint
02:36:38:WU02:FS00:0xa4:Verified 02/wudata_01.log
02:36:38:WU02:FS00:0xa4:Verified 02/wudata_01.trr
02:36:38:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
02:36:38:WU02:FS00:0xa4:Verified 02/wudata_01.edr
02:36:39:WU02:FS00:0xa4:Completed 37890 out of 250000 steps  (15%)
02:37:17:Removing old file 'configs/config-20160613-075240.xml'
02:37:17:Saving configuration to config.xml
02:37:17:<config>
02:37:17:  <!-- Logging -->
02:37:17:  <verbosity v='4'/>
02:37:17:
02:37:17:  <!-- Network -->
02:37:17:  <proxy v=':8080'/>
02:37:17:
02:37:17:  <!-- Slot Control -->
02:37:17:  <pause-on-battery v='false'/>
02:37:17:  <power v='FULL'/>
02:37:17:
02:37:17:  <!-- User Information -->
02:37:17:  <passkey v='********************************'/>
02:37:17:  <team v='45'/>
02:37:17:  <user v='ThunderRd'/>
02:37:17:
02:37:17:  <!-- Folding Slots -->
02:37:17:  <slot id='0' type='CPU'/>
02:37:17:  <slot id='1' type='GPU'/>
02:37:17:</config>
02:53:40:WU00:FS01:0x17:Completed 2375000 out of 5000000 steps (47%)
02:53:40:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:54:53:WU02:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
03:16:30:WU02:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
03:38:13:WU02:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
03:41:52:WU00:FS01:0x17:Completed 2400000 out of 5000000 steps (48%)
03:59:47:WU02:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
04:21:32:WU02:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
04:43:11:WU02:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
05:04:56:WU02:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
05:15:53:WU00:FS01:0x17:Completed 2450000 out of 5000000 steps (49%)
05:26:43:WU02:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
05:48:33:WU02:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
06:10:20:WU02:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
06:32:08:WU02:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
******************************* Date: 2016-06-29 *******************************
06:49:55:WU00:FS01:0x17:Completed 2500000 out of 5000000 steps (50%)
06:54:01:WU02:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
07:15:53:WU02:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
07:37:47:WU02:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
07:59:38:WU02:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
08:21:37:WU02:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
08:25:35:WU00:FS01:0x17:Completed 2550000 out of 5000000 steps (51%)
08:42:30:WU02:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
09:02:32:WU02:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
09:22:38:WU02:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
09:42:43:WU02:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
09:59:38:WU00:FS01:0x17:Completed 2600000 out of 5000000 steps (52%)
10:02:52:WU02:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
10:22:58:WU02:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
10:43:19:WU02:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
11:03:33:WU02:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
11:23:41:WU02:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
11:35:10:WU00:FS01:0x17:Completed 2650000 out of 5000000 steps (53%)
11:43:54:WU02:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
12:04:12:WU02:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
12:24:23:WU02:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
12:44:33:WU02:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
13:04:46:WU02:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
13:09:10:WU00:FS01:0x17:Completed 2700000 out of 5000000 steps (54%)
13:25:03:WU02:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
13:45:08:WU02:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
14:05:15:WU02:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
14:25:25:WU02:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
14:43:12:WU00:FS01:0x17:Completed 2750000 out of 5000000 steps (55%)
14:45:40:WU02:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
15:05:47:WU02:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
15:26:11:WU02:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
15:46:22:WU02:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
16:06:32:WU02:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
16:18:41:WU00:FS01:0x17:Completed 2800000 out of 5000000 steps (56%)
16:26:40:WU02:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
16:46:52:WU02:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
17:07:13:WU02:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
17:27:40:WU02:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
17:47:58:WU02:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
17:52:40:WU00:FS01:0x17:Completed 2850000 out of 5000000 steps (57%)
18:08:10:WU02:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
18:28:25:WU02:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
18:48:56:WU02:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
19:09:05:WU02:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
19:28:10:WU00:FS01:0x17:Completed 2900000 out of 5000000 steps (58%)
19:29:05:WU02:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
19:49:06:WU02:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
20:09:06:WU02:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
20:29:11:WU02:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
20:49:28:WU02:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
21:02:09:WU00:FS01:0x17:Completed 2950000 out of 5000000 steps (59%)
21:09:33:WU02:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
21:29:41:WU02:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
21:49:52:WU02:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
22:09:57:WU02:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
22:30:04:WU02:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
22:36:08:WU00:FS01:0x17:Completed 3000000 out of 5000000 steps (60%)
22:50:23:WU02:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
23:10:22:WU02:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
23:30:35:WU02:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
23:51:01:WU02:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
00:11:19:WU02:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
00:11:43:WU00:FS01:0x17:Completed 3050000 out of 5000000 steps (61%)
00:31:40:WU02:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
00:51:49:WU02:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
******************************* Date: 2016-06-30 *******************************
01:12:13:WU02:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
01:32:23:WU02:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
01:45:44:WU00:FS01:0x17:Completed 3100000 out of 5000000 steps (62%)
01:52:37:WU02:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
02:12:50:WU02:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
02:33:02:WU02:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
02:37:47:FS00:Paused
02:37:47:FS01:Paused
02:37:47:FS00:Shutting core down
02:37:47:FS01:Shutting core down
02:37:47:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 6320
02:37:47:WU00:FS01:0x17:Exiting, please wait. . .
02:37:47:WU00:FS01:0x17:Lost lifeline PID 7840, exiting
02:37:47:WU00:FS01:0x17:ERROR:103: Lost client lifeline
02:37:47:WU00:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
02:37:54:Removing old file 'configs/config-20160614-031342.xml'
02:37:54:Saving configuration to config.xml
02:37:54:<config>
02:37:54:  <!-- Logging -->
02:37:54:  <verbosity v='4'/>
02:37:54:
02:37:54:  <!-- Network -->
02:37:54:  <proxy v=':8080'/>
02:37:54:
02:37:54:  <!-- Slot Control -->
02:37:54:  <pause-on-battery v='false'/>
02:37:54:  <power v='FULL'/>
02:37:54:
02:37:54:  <!-- User Information -->
02:37:54:  <passkey v='********************************'/>
02:37:54:  <team v='45'/>
02:37:54:  <user v='ThunderRd'/>
02:37:54:
02:37:54:  <!-- Folding Slots -->
02:37:54:  <slot id='0' type='CPU'>
02:37:54:    <paused v='true'/>
02:37:54:  </slot>
02:37:54:  <slot id='1' type='GPU'>
02:37:54:  </slot>
02:37:54:</config>
02:37:54:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
02:37:59:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
06:18:49:WARNING:WU00:FS01:Past final deadline 2016-06-30T06:18:48Z, dumping
06:18:49:WU00:FS01:Cleaning up
06:31:41:FS00:Unpaused
06:31:41:FS01:Unpaused
06:31:41:WU02:FS00:Starting
06:31:41:WU02:FS00:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 02 -suffix 01 -version 704 -lifeline 1356 -checkpoint 15
06:31:41:WU02:FS00:Started FahCore on PID 5360
06:31:41:WU02:FS00:Core PID:3060
06:31:41:WU02:FS00:FahCore 0xa4 started
06:31:42:WU00:FS01:Connecting to 171.67.108.45:80
06:31:42:WU02:FS00:0xa4:
06:31:42:WU02:FS00:0xa4:*------------------------------*
06:31:42:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
06:31:42:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
06:31:42:WU02:FS00:0xa4:Preparing to commence simulation
06:31:42:WU02:FS00:0xa4:- Looking at optimizations...
06:31:42:WU02:FS00:0xa4:- Files status OK
06:31:42:WU02:FS00:0xa4:- Expanded 824937 -> 1398040 (decompressed 169.4 percent)
06:31:42:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=824937 data_size=1398040, decompressed_data_size=1398040 diff=0
06:31:42:WU02:FS00:0xa4:- Digital signature verified
06:31:42:WU02:FS00:0xa4:Project: 9039 (Run 855, Clone 1, Gen 310)
06:31:42:WU02:FS00:0xa4:Assembly optimizations on if available.
06:31:42:WU02:FS00:0xa4:Entering M.D.
06:31:42:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:31:42:WU00:FS01:Connecting to 171.67.108.204:80
06:31:43:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:31:43:ERROR:WU00:FS01:Exception: Could not get an assignment
06:31:43:WU00:FS01:Connecting to 171.67.108.45:80
06:31:44:Removing old file 'configs/config-20160614-043906.xml'
06:31:44:Saving configuration to config.xml
06:31:44:<config>
06:31:44:  <!-- Logging -->
06:31:44:  <verbosity v='4'/>
06:31:44:
06:31:44:  <!-- Network -->
06:31:44:  <proxy v=':8080'/>
06:31:44:
06:31:44:  <!-- Slot Control -->
06:31:44:  <pause-on-battery v='false'/>
06:31:44:  <power v='FULL'/>
06:31:44:
06:31:44:  <!-- User Information -->
06:31:44:  <passkey v='********************************'/>
06:31:44:  <team v='45'/>
06:31:44:  <user v='ThunderRd'/>
06:31:44:
06:31:44:  <!-- Folding Slots -->
06:31:44:  <slot id='0' type='CPU'/>
06:31:44:  <slot id='1' type='GPU'/>
06:31:44:</config>
06:31:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:31:44:WU00:FS01:Connecting to 171.67.108.204:80
06:31:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:31:44:ERROR:WU00:FS01:Exception: Could not get an assignment
06:31:48:WU02:FS00:0xa4:Using Gromacs checkpoints
06:31:48:WU02:FS00:0xa4:Mapping NT from 1 to 1
06:31:48:WU02:FS00:0xa4:Resuming from checkpoint
06:31:48:WU02:FS00:0xa4:Verified 02/wudata_01.log
06:31:48:WU02:FS00:0xa4:Verified 02/wudata_01.trr
06:31:48:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
06:31:48:WU02:FS00:0xa4:Verified 02/wudata_01.edr
06:31:49:WU02:FS00:0xa4:Completed 212935 out of 250000 steps  (85%)
06:32:43:WU00:FS01:Connecting to 171.67.108.45:80
06:32:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:32:44:WU00:FS01:Connecting to 171.67.108.204:80
06:32:44:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:32:44:ERROR:WU00:FS01:Exception: Could not get an assignment
06:34:20:WU00:FS01:Connecting to 171.67.108.45:80
06:34:21:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:34:21:WU00:FS01:Connecting to 171.67.108.204:80
06:34:22:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:34:22:ERROR:WU00:FS01:Exception: Could not get an assignment
06:36:58:WU00:FS01:Connecting to 171.67.108.45:80
06:36:58:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:36:58:WU00:FS01:Connecting to 171.67.108.204:80
06:36:59:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:36:59:ERROR:WU00:FS01:Exception: Could not get an assignment
06:41:12:WU00:FS01:Connecting to 171.67.108.45:80
06:41:13:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:41:13:WU00:FS01:Connecting to 171.67.108.204:80
06:41:14:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:41:14:ERROR:WU00:FS01:Exception: Could not get an assignment
06:48:03:WU00:FS01:Connecting to 171.67.108.45:80
06:48:04:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:48:04:WU00:FS01:Connecting to 171.67.108.204:80
06:48:05:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:48:05:ERROR:WU00:FS01:Exception: Could not get an assignment
06:50:03:WU02:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
06:59:09:WU00:FS01:Connecting to 171.67.108.45:80
06:59:09:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
06:59:09:WU00:FS01:Connecting to 171.67.108.204:80
06:59:10:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
06:59:10:ERROR:WU00:FS01:Exception: Could not get an assignment
07:11:34:WU02:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
07:17:06:WU00:FS01:Connecting to 171.67.108.45:80
07:17:07:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
07:17:07:WU00:FS01:Connecting to 171.67.108.204:80
07:17:08:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': 10001: Server responded: HTTP_BAD_GATEWAY
07:17:08:ERROR:WU00:FS01:Exception: Could not get an assignment
07:33:07:WU02:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
I see a prior WU from the server indicated here, 140.163.4.233:
01:50:24:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GF108 [GeForce GT 440] from 140.163.4.233
01:50:24:WU02:FS01:Connecting to 140.163.4.233:8080
01:50:26:WU02:FS01:Downloading 4.28MiB
01:50:32:WU02:FS01:Download 21.90%
01:50:38:WU02:FS01:Download 49.64%
01:50:44:WU02:FS01:Download 77.38%
01:50:48:WU02:FS01:Download complete
01:50:49:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10467 run:0 clone:134 gen:316 core:0x17 unit:0x00000200538b3db9538bbd4042702c6e
01:51:51:WU01:FS01:0x17:Saving result file logfile_01.txt
01:51:51:WU01:FS01:0x17:Saving result file checkpointState.xml
01:52:00:WU01:FS01:0x17:Saving result file checkpt.crc
01:52:00:WU01:FS01:0x17:Saving result file log.txt
01:52:01:WU01:FS01:0x17:Saving result file positions.xtc
01:52:11:WU01:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
01:52:12:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:52:12:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:10467 run:0 clone:495 gen:337 core:0x17 unit:0x00000218538b3db9538bc5ea2342914b
01:52:12:WU01:FS01:Uploading 13.07MiB to 140.163.4.233
01:52:12:WU01:FS01:Connecting to 140.163.4.233:8080
01:52:12:WU02:FS01:Starting
01:52:12:WU02:FS01:Running FahCore: "d:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/admin/Application Data/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe" -dir 02 -suffix 01 -version 704 -lifeline 1120 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
01:52:12:WU02:FS01:Started FahCore on PID 1168
01:52:12:WU02:FS01:Core PID:1984
01:52:12:WU02:FS01:FahCore 0x17 started
I would have to do some more checking, but the group of projects those came from were completed a few weeks ago, and their WS's were set to just accept returns. The announcement was here - viewtopic.php?f=24&t=28914.
There may be some more Core_17 or Core_18 projects available, but they are finishing up and getting replaced with Core_21 projects. Core_21 will not run on Win XP.
ThunderRd
Post by ThunderRd »
OK, that seems to be a reasonable explanation.
Joe, do the core_21 projects run on this GPU, if it's Win7? I would consider upgrading the OS.
Yes.
Are you behind a proxy or on a corporate/university network ?
