Unable to download new WU's
For some time now, my 8-core Mac Pro has not been assigned any projects. I tried changing the CPU setting from -1 to other positive values, but to no avail. Also tried reinstalling FAHControl 7.4.4, but still nothing. Any ideas?
Re: Unable to download new WU's
Here's the front end of the log file, in case that helps.
Mod edit: added Code tags to log file
*********************** Log Started 2016-07-01T23:57:18Z ***********************
23:57:18:************************* Folding@home Client *************************
23:57:18: Website: http://folding.stanford.edu/
23:57:18: Copyright: (c) 2009-2014 Stanford University
23:57:18: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:57:18: Args: --child --lifeline 1337 --respawn
23:57:18: Config: /Library/Application Support/FAHClient/config.xml
23:57:18:******************************** Build ********************************
23:57:18: Version: 7.4.4
23:57:18: Date: Mar 4 2014
23:57:18: Time: 20:27:54
23:57:18: SVN Rev: 4130
23:57:18: Branch: fah/trunk/client
23:57:18: Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
23:57:18: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
23:57:18: -fno-unsafe-math-optimizations -msse3 -arch x86_64
23:57:18: -mmacosx-version-min=10.6
23:57:18: Platform: darwin 10.8.0
23:57:18: Bits: 64
23:57:18: Mode: Release
23:57:18:******************************* System ********************************
23:57:18: CPU: Intel(R) Xeon(R) CPU X5472 @ 3.00GHz
23:57:18: CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
23:57:18: CPUs: 8
23:57:18: Memory: 12.00GiB
23:57:18:Free Memory: 351.68MiB
23:57:18: Threads: POSIX_THREADS
23:57:18: OS Version: 10.11
23:57:18:Has Battery: false
23:57:18: On Battery: false
23:57:18: UTC Offset: -7
23:57:18: PID: 1481
23:57:18: CWD: /Library/Application Support/FAHClient
23:57:18: OS: Darwin 15.5.0 x86_64
23:57:18: OS Arch: AMD64
23:57:18: GPUs: 1
23:57:18: GPU 0: ATI:4 Juniper [Radeon HD 5700 Series]
23:57:18: CUDA: Not detected
23:57:18:***********************************************************************
23:57:18:<config>
23:57:18: <!-- Network -->
23:57:18: <proxy v=':8080'/>
23:57:18:
23:57:18: <!-- Slot Control -->
23:57:18: <pause-on-battery v='false'/>
23:57:18:
23:57:18: <!-- User Information -->
23:57:18: <passkey v='********************************'/>
23:57:18: <team v='1971'/>
23:57:18: <user v='walkerca'/>
23:57:18:
23:57:18: <!-- Folding Slots -->
23:57:18: <slot id='0' type='CPU'/>
23:57:18:</config>
23:57:18:Trying to access database...
23:57:19:Successfully acquired database lock
23:57:19:Enabled folding slot 00: READY cpu:7
23:57:20:WU00:FS00:Connecting to 171.67.108.45:8080
23:57:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:57:21:WU00:FS00:Connecting to 171.64.65.35:80
23:57:21:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
23:57:21:ERROR:WU00:FS00:Exception: Could not get an assignment
23:57:21:WU00:FS00:Connecting to 171.67.108.45:8080
23:57:22:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:57:22:WU00:FS00:Connecting to 171.64.65.35:80
23:57:23:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
23:57:23:ERROR:WU00:FS00:Exception: Could not get an assignment
23:57:38:13:127.0.0.1:New Web connection
23:58:22:WU00:FS00:Connecting to 171.67.108.45:8080
23:58:22:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:58:22:WU00:FS00:Connecting to 171.64.65.35:80
23:58:22:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
23:58:22:ERROR:WU00:FS00:Exception: Could not get an assignment
23:59:59:WU00:FS00:Connecting to 171.67.108.45:8080
23:59:59:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
23:59:59:WU00:FS00:Connecting to 171.64.65.35:80
00:00:00:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:00:00:ERROR:WU00:FS00:Exception: Could not get an assignment
00:00:23:Removing old file 'configs/config-20140202-053416.xml'
00:00:23:Saving configuration to config.xml
00:00:23:<config>
00:00:23: <!-- Network -->
00:00:23: <proxy v=':8080'/>
00:00:23:
00:00:23: <!-- Slot Control -->
00:00:23: <pause-on-battery v='false'/>
00:00:23:
00:00:23: <!-- User Information -->
00:00:23: <passkey v='********************************'/>
00:00:23: <team v='36120'/>
00:00:23: <user v='walkerca'/>
00:00:23:
00:00:23: <!-- Folding Slots -->
00:00:23: <slot id='0' type='CPU'/>
00:00:23:</config>
00:02:36:WU00:FS00:Connecting to 171.67.108.45:8080
00:02:36:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:02:36:WU00:FS00:Connecting to 171.64.65.35:80
00:02:36:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:02:36:ERROR:WU00:FS00:Exception: Could not get an assignment
00:06:50:WU00:FS00:Connecting to 171.67.108.45:8080
00:06:50:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:06:50:WU00:FS00:Connecting to 171.64.65.35:80
00:06:51:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:06:51:ERROR:WU00:FS00:Exception: Could not get an assignment
00:09:03:Removing old file 'configs/config-20140729-045941.xml'
00:09:03:Saving configuration to config.xml
00:09:03:<config>
00:09:03: <!-- Network -->
00:09:03: <proxy v=':8080'/>
00:09:03:
00:09:03: <!-- Slot Control -->
00:09:03: <pause-on-battery v='false'/>
00:09:03:
00:09:03: <!-- User Information -->
00:09:03: <passkey v='********************************'/>
00:09:03: <team v='36120'/>
00:09:03: <user v='walkerca'/>
00:09:03:
00:09:03: <!-- Folding Slots -->
00:09:03: <slot id='0' type='CPU'>
00:09:03: <cpus v='2'/>
00:09:03: </slot>
00:09:03:</config>
00:09:31:Removing old file 'configs/config-20141206-172812.xml'
00:09:31:Saving configuration to config.xml
00:09:31:<config>
00:09:31: <!-- Network -->
00:09:31: <proxy v=':8080'/>
00:09:31:
00:09:31: <!-- Slot Control -->
00:09:31: <pause-on-battery v='false'/>
00:09:31:
00:09:31: <!-- User Information -->
00:09:31: <passkey v='********************************'/>
00:09:31: <team v='36120'/>
00:09:31: <user v='walkerca'/>
00:09:31:
00:09:31: <!-- Folding Slots -->
00:09:31: <slot id='0' type='CPU'>
00:09:31: <cpus v='2'/>
00:09:31: </slot>
00:09:31:</config>
00:12:59:Removing old file 'configs/config-20141212-080744.xml'
00:13:01:Saving configuration to config.xml
00:13:01:<config>
00:13:01: <!-- Network -->
00:13:01: <proxy v=':8080'/>
00:13:01:
00:13:01: <!-- Slot Control -->
00:13:01: <pause-on-battery v='false'/>
00:13:01:
00:13:01: <!-- User Information -->
00:13:01: <passkey v='********************************'/>
00:13:01: <team v='36120'/>
00:13:01: <user v='walkerca'/>
00:13:01:
00:13:01: <!-- Folding Slots -->
00:13:01: <slot id='0' type='CPU'/>
00:13:01:</config>
00:13:35:Removing old file 'configs/config-20150429-140653.xml'
00:13:36:Saving configuration to config.xml
00:13:36:<config>
00:13:36: <!-- Network -->
00:13:36: <proxy v=':8080'/>
00:13:36:
00:13:36: <!-- Slot Control -->
00:13:36: <pause-on-battery v='false'/>
00:13:36:
00:13:36: <!-- User Information -->
00:13:36: <passkey v='********************************'/>
00:13:36: <team v='36120'/>
00:13:36: <user v='walkerca'/>
00:13:36:
00:13:36: <!-- Folding Slots -->
00:13:36: <slot id='0' type='CPU'/>
00:13:36:</config>
00:13:42:WU00:FS00:Connecting to 171.67.108.45:8080
00:13:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:13:43:WU00:FS00:Connecting to 171.64.65.35:80
00:13:43:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:13:43:ERROR:WU00:FS00:Exception: Could not get an assignment
00:24:47:WU00:FS00:Connecting to 171.67.108.45:8080
00:24:48:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
00:24:48:WU00:FS00:Connecting to 171.64.65.35:80
00:24:48:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
00:24:48:ERROR:WU00:FS00:Exception: Could not get an assignmentRe: Unable to download new WU's
Change the -1 to 6. There are no more WUs being assigned that support 7 threads which is what you'll get with an 8 threaded CPU and a GPU.
I see where you changed the CPU count to 2 and still did not get a WU assigned. However the slot never paused, so it is possible it was still trying to get a WU based on the -1 resulting in a request for 7 CPU threads. My suggestion would be to pause the folding slot and check the log to make certain the download attempts also stopped. Then change to a CPU count of 6 or another number besides 7 and start the folding slot again.
If the slot does not stop attempting a download, you may need to restart the FAHClient process. It can be done from the command line, but is easier to do by rebooting your Mac Pro. First change the CPU setting before the restart.
Since you don't have a supported GPU to drive in your Mac, you can also choose to set it to 8 threads.
Thanks guys! Setting the CPU to 6 solved the problem! Many thanks again!!
If you don't mind the heat, setting to 8 will work too with better performance ...
ChristianVirtual
Keep 6 as setting, problem solved
A permanent fix will require an updated client. Dr. Pande has announced that was being worked on, but no date has yet been announced for release. Before full release there will be a public beta of a new client based on past releases. The V7 archive topic - viewforum.php?f=90 - has the discussions of the prior public beta tests.Adam A. Wanderer wrote:Was this problem ever solved to where we can use the "default, -1" setting, or must we still use the 6 setting???mmonnin wrote:Change the -1 to 6. There are no more WUs being assigned that support 7 threads which is what you'll get with an 8 threaded CPU and a GPU.
Thanks.
