Low PPD for geforce 1070
beer
Post by beer »
Hi
I am a new owner of a geforce 1070. It seems that I have a low PPD (at least lower that I expected). At the beginning I got around 450.000 for the current WU. I did find found out that Folding@home did to tricker the boost 3.0 (eg the GPU clock was stocked at 1506). Have any other seen this issue?
I have found a workaround for this. If I have the 3d mark window open then the clock speed pf the GPU would be around 1775-1800. That boosted the PPD for current WU to app 540.000 PPD but it is still lower that expected. Does this this sounds fiar to you and is there another solution to the problem with missing boost?
*********************** Log Started 2016-07-01T14:49:08Z ***********************
14:49:08:************************* Folding@home Client *************************
14:49:08:      Website: http://folding.stanford.edu/
14:49:08:    Copyright: (c) 2009-2014 Stanford University
14:49:08:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:49:08:         Args:
14:49:08:       Config: C:/Users/vejli/AppData/Roaming/FAHClient/config.xml
14:49:08:******************************** Build ********************************
14:49:08:      Version: 7.4.4
14:49:08:         Date: Mar 4 2014
14:49:08:         Time: 20:26:54
14:49:08:      SVN Rev: 4130
14:49:08:       Branch: fah/trunk/client
14:49:08:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:49:08:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:49:08:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:49:08:     Platform: win32 XP
14:49:08:         Bits: 32
14:49:08:         Mode: Release
14:49:08:******************************* System ********************************
14:49:08:          CPU: Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz
14:49:08:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:49:08:         CPUs: 8
14:49:08:       Memory: 7.94GiB
14:49:08:  Free Memory: 5.78GiB
14:49:08:      Threads: WINDOWS_THREADS
14:49:08:   OS Version: 6.2
14:49:08:  Has Battery: false
14:49:08:   On Battery: false
14:49:08:   UTC Offset: 2
14:49:08:          PID: 6756
14:49:08:          CWD: C:/Users/vejli/AppData/Roaming/FAHClient
14:49:08:           OS: Windows 10 Pro
14:49:08:      OS Arch: AMD64
14:49:08:         GPUs: 2
14:49:08:        GPU 0: UNSUPPORTED: NV3 [PCI]
14:49:08:        GPU 1: NVIDIA:5 GP104 [GeForce GTX 1070]
14:49:08:         CUDA: 6.1
14:49:08:  CUDA Driver: 8000
14:49:08:Win32 Service: false
14:49:08:***********************************************************************
14:49:08:<config>
14:49:08:  <!-- Folding Core -->
14:49:08:  <core-priority v='low'/>
14:49:08:
14:49:08:  <!-- Network -->
14:49:08:  <proxy v=':8080'/>
14:49:08:
14:49:08:  <!-- User Information -->
14:49:08:  <passkey v='********************************'/>
14:49:08:  <user v='jonasvejlin'/>
14:49:08:
14:49:08:  <!-- Folding Slots -->
14:49:08:  <slot id='0' type='CPU'/>
14:49:08:  <slot id='1' type='GPU'/>
14:49:08:</config>
15:06:36:WU01:FS01:Connecting to 171.67.108.45:80
15:06:36:WU01:FS01:Assigned to work server 140.163.4.245
15:06:36:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
15:06:36:WU01:FS01:Connecting to 140.163.4.245:8080
15:06:37:WU01:FS01:Downloading 5.13MiB
15:06:41:WU01:FS01:Download complete
15:06:41:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10495 run:6 clone:56 gen:36 core:0x21 unit:0x000000328ca304f556ba6345d1684573
15:06:41:WU01:FS01:Starting
15:06:41:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/vejli/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6756 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
15:06:41:WU01:FS01:Started FahCore on PID 9420
15:06:41:WU01:FS01:Core PID:9720
15:06:41:WU01:FS01:FahCore 0x21 started
15:06:41:WU01:FS01:0x21:*********************** Log Started 2016-07-01T15:06:41Z ***********************
15:06:41:WU01:FS01:0x21:Project: 10495 (Run 6, Clone 56, Gen 36)
15:06:41:WU01:FS01:0x21:Unit: 0x000000328ca304f556ba6345d1684573
15:06:41:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:06:41:WU01:FS01:0x21:Machine: 1
15:06:41:WU01:FS01:0x21:Reading tar file core.xml
15:06:41:WU01:FS01:0x21:Reading tar file system.xml
15:06:41:WU01:FS01:0x21:Reading tar file integrator.xml
15:06:41:WU01:FS01:0x21:Reading tar file state.xml
15:06:42:WU01:FS01:0x21:Digital signatures verified
15:06:42:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:06:42:WU01:FS01:0x21:Version 0.0.17
15:06:51:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
15:06:51:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:08:43:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
15:10:38:WU01:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
15:12:26:WU01:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
15:14:06:WU01:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
15:15:47:WU01:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
15:17:38:WU01:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
15:19:33:WU01:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
15:21:29:WU01:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
15:23:27:WU01:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
15:25:29:WU01:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
15:27:24:WU01:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
15:29:11:WU01:FS01:0x21:Completed 600000 out of 5000000 steps (12%)
15:31:04:WU01:FS01:0x21:Completed 650000 out of 5000000 steps (13%)
15:33:00:WU01:FS01:0x21:Completed 700000 out of 5000000 steps (14%)
15:34:54:WU01:FS01:0x21:Completed 750000 out of 5000000 steps (15%)
15:36:53:WU01:FS01:0x21:Completed 800000 out of 5000000 steps (16%)
15:38:44:WU01:FS01:0x21:Completed 850000 out of 5000000 steps (17%)
15:40:34:WU01:FS01:0x21:Completed 900000 out of 5000000 steps (18%)
15:42:20:WU01:FS01:0x21:Completed 950000 out of 5000000 steps (19%)
15:43:59:WU01:FS01:0x21:Completed 1000000 out of 5000000 steps (20%)
15:45:41:WU01:FS01:0x21:Completed 1050000 out of 5000000 steps (21%)
15:47:21:WU01:FS01:0x21:Completed 1100000 out of 5000000 steps (22%)
15:49:00:WU01:FS01:0x21:Completed 1150000 out of 5000000 steps (23%)
15:50:40:WU01:FS01:0x21:Completed 1200000 out of 5000000 steps (24%)
15:52:20:WU01:FS01:0x21:Completed 1250000 out of 5000000 steps (25%)
Re: Low PPD for geforce 1070
Nope... no tricks. FAH doer not manage your clock-rate. That's the responsibility of the driver provided by your GPU's manufacturer.
Post by foldy »
Did you install latest driver from nvidia?
beer
Post by beer »
http://i.imgur.com/FLxOr5j.png <- I did change the settings and now I donth have the problem with low core clock.
#Foldy yes I did. The older driver was too old to be used with the new card. I dont know if I just got a WU with low PPD.
I am the only one who gets a PPD below 600.000 on a geforce 1070?
Post by foldy »
Interesting, so you changed it to "Prefer maximum performance"?
It depends on the work units some will get 450k PPD others 750k PPD which averages to 600k PPD.
beer
Post by beer »
#foldy. I changed it to "Prefer maximum performance" and it work for a short while. ben then it went back to the base clock at 1500 so now I am back to the first workaround.
So my PPD is within reason when I apply the fix to get core clock to be around 1800.
Post by foldy »
I dont't know if it is related but my gtx 970 while folding does not run in highest performance mode but a reduced state which only effects vram which runs at 3Ghz instead of 4Ghz.
The "Prefer maximum performance" settings did not change this.
What is your gtx 1070 vendor and model?
beer
Post by beer »
I did buy this card:
https://www.proshop.dk/Grafikkort/Palit ... R5/2553898
I dont know why my card run at max speed (~1800 Mhz) when the 3d mark is open but not running (low intencety) but when I am just running folding@home then the card runs at ~1500.
I have received the 2th WU and I am getting a 675.000 PPD on it which is a bit higher than expected (based on the forums posts)
Post by foldy »
Windows 10 also has power options, maybe this makes a difference?
http://www.tenforums.com/tutorials/2843 ... -10-a.html
Did you turn off your CPU slot to test your GPU performance ?
What GPU load is reported by GPUZ while running FAH in each situations (with CPU slot running and without CPU slot running) ?
Sn1ken
Post by Sn1ken »
Use EvgaPreX or Afterburner. Then boost power limit and temp to max, and core clock +100
http://www.evga.com/precision/
https://gaming.msi.com/features/afterburner
