No work for GPU [ GTX560 Ti]
new08
Hardware configuration: Hewlett-Packard 1494 Win10 Build 1836
GeForce [MSI] GTX 950
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
I've been doing good work on GPU some time and for a while no work coming through.
Any ideas?
Client will get CPU work but I don't normally run these.
     ******** Log Started 2016-06-27T04:06:19Z ***********************
04:06:19:************************* Folding@home Client *************************
04:06:19:      Website: http://folding.stanford.edu/
04:06:19:    Copyright: (c) 2009-2014 Stanford University
04:06:19:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:06:19:         Args:
04:06:19:       Config: C:/Program Files/FAHClient/config.xml
04:06:19:******************************** Build ********************************
04:06:19:      Version: 7.4.4
04:06:19:         Date: Mar 4 2014
04:06:19:         Time: 20:26:54
04:06:19:      SVN Rev: 4130
04:06:19:       Branch: fah/trunk/client
04:06:19:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:06:19:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:06:19:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:06:19:     Platform: win32 XP
04:06:19:         Bits: 32
04:06:19:         Mode: Release
04:06:19:******************************* System ********************************
04:06:19:          CPU: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
04:06:19:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
04:06:19:         CPUs: 2
04:06:19:       Memory: 2.00GiB
04:06:19:  Free Memory: 1.14GiB
04:06:19:      Threads: WINDOWS_THREADS
04:06:19:   OS Version: 5.1
04:06:19:  Has Battery: false
04:06:19:   On Battery: false
04:06:19:   UTC Offset: 1
04:06:19:          PID: 2444
04:06:19:          CWD: C:/Program Files/FAHClient
04:06:19:           OS: Microsoft Windows XP Service Pack 3
04:06:19:      OS Arch: X86
04:06:19:         GPUs: 1
04:06:19:        GPU 0: NVIDIA:2 GF114 [GeForce GTX 560 Ti]
04:06:19:         CUDA: 2.1
04:06:19:  CUDA Driver: 7050
04:06:19:Win32 Service: false
04:06:19:***********************************************************************
04:06:19:<config>
04:06:19:  <!-- Folding Slot Configuration -->
04:06:19:  <client-type v='beta'/>
04:06:19:
04:06:19:  <!-- Network -->
04:06:19:  <proxy v=':8080'/>
04:06:19:
04:06:19:  <!-- Slot Control -->
04:06:19:  <pause-on-battery v='false'/>
04:06:19:
04:06:19:  <!-- User Information -->
04:06:19:  <passkey v='********************************'/>
04:06:19:  <team v='39340'/>
04:06:19:  <user v='new08'/>
04:06:19:
04:06:19:  <!-- Folding Slots -->
04:06:19:  <slot id='1' type='GPU'>
04:06:19:    <paused v='true'/>
04:06:19:  </slot>
04:06:19:</config>
04:06:19:Trying to access database...
04:06:19:Successfully acquired database lock
04:06:19:Enabled folding slot 01: PAUSED gpu:0:GF114 [GeForce GTX 560 Ti] (by user)
04:06:31:FS01:Unpaused
04:06:32:WU00:FS01:Connecting to 171.67.108.45:80
04:06:32:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:06:32:WU00:FS01:Connecting to 171.67.108.204:80
04:06:34:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: No connection could be made because the target machine actively refused it.
04:06:34:ERROR:WU00:FS01:Exception: Could not get an assignment
04:06:34:WU00:FS01:Connecting to 171.67.108.45:80
04:06:34:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:06:34:WU00:FS01:Connecting to 171.67.108.204:80
04:06:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: No connection could be made because the target machine actively refused it.
04:06:36:ERROR:WU00:FS01:Exception: Could not get an assignment
04:07:20:Removing old file 'configs/config-20160619-120728.xml'
04:07:20:Saving configuration to config.xml
04:07:20:<config>
04:07:20:  <!-- Folding Slot Configuration -->
04:07:20:  <client-type v='beta'/>
04:07:20:
04:07:20:  <!-- Network -->
04:07:20:  <proxy v=':8080'/>
04:07:20:
04:07:20:  <!-- Slot Control -->
04:07:20:  <pause-on-battery v='false'/>
04:07:20:
04:07:20:  <!-- User Information -->
04:07:20:  <passkey v='********************************'/>
04:07:20:  <team v='39340'/>
04:07:20:  <user v='new08'/>
04:07:20:
04:07:20:  <!-- Folding Slots -->
04:07:20:  <slot id='1' type='GPU'/>
04:07:20:</config>
04:07:34:WU00:FS01:Connecting to 171.67.108.45:80
04:07:34:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.45:80': Empty work server assignment
04:07:34:WU00:FS01:Connecting to 171.67.108.204:80
04:07:36:WARNING:WU00:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: No connection could be made because the target machine actively refused it.
04:07:36:ERROR:WU00:FS01:Exception: Could not get an assignment
Mod edit: added Code tags to log file
davidcoton
Re: No work for GPU [ GFX560 ]
Post by davidcoton »
You have the Beta flag set. Support for that is only available in the beta forum. Are you a beta team member? If so, post there. If not, remove the beta flag (which may well solve your problem).
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Thanks. It had been running with beta set for ages -though I'm not in a beta group.
I removed the beta flag to no avail, anyway.
PS: I can't remember the code tag thing -s so long since posted & no help found on it.
I see a couple of possibilities.
1) Did you install the drivers from nVida or the ones provided by Microsoft?
2) There are some limitations associated with Windows XP. I don't remember the details -- maybe somebody can help with them.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
I've tried both- current one is MS approved.
I suspect work has dried up -or policy change has been set.
I know there's little info provided direct when these thing occur.
I've moved to Boinc F/time anyway, in the meantime.
new08 wrote:PS: I can't remember the code tag thing -s so long since posted & no help found on it.
Code tags are available using the Full Editor to post. Also mentioned in the directions for log posting included in the Welcome to the Forum topic - viewtopic.php?f=61&t=26036.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Yes- I got it- should be applied now.
BTW I downloaded CPU work ok- so not a comms issue.
The newest GPU core, Core 21, isn't assigned to Windows XP 32 bit, IIRC. And there is limited availability of the older GPU core projects as they finish and get replaced by Core 21.
Microsoft quit supporting WindowsXP in 2009 though limited support was extended to 2014. The components which were released during the support period still work but components issued after support was discontinued may not.
Inexpensive copies of WIndows 7 are available from many sources or you can upgrade to later versions -- and Linux is free but generally expects more advanced knowledge.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
Yes, that makes sense. I'm not keen to upgrade whole system just to keep folding, tbh. All add ons will need upgrading at some cost.
Boinc projects are not trouble free with driver problems- but seems more stable -o I can carry on doing folding medical research etc on there.
If you find a way to deal with this XP incompatibility, please let me know in the future.
I can take a break after 8 years F@H.
CPU folding will continue on XP for a while. GPU folding on XP is almost done. IMO.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
It does seem, by inspection, that the two WS called up above are not showing any work available on their page.
I seem to remeber seeing the cores listed in the past -but can't see this now.
The only servers shown up above are Assignment Servers, not WS. They never supply the actual WU's, just read your assignment request and connect the client to a matching WS. If they do not make a match due to a WS with appropriate projects either being down, out of WU's or the projects are complete, then they cause that "Empty work server assignment" message.
new08
Runs F@H Ver7.6.21
[As of Jan 2021]
Post by new08 »
This is the attempted WS but can't determine the Core from this.
Fri May 9 11:00:10 PDT 2008 0.0.0.0 - - FAIL Reject - - - - - - - - - - - 4 - - - - - 0 - - - 0 -; ; ; ; ; 1; , 2500, 2500, 1 - - 49; , 10000000, 10000000, 49 64; , 64, 64, 64 - G; , A, F, G 80; , 8080PS, 8080PS, 8080 - - - - - - - -
Is this possible to find out?
What is the IP number of the WS you think your client tried to connect to? The IP numbers of the WS being used are listed for every project on the Project Summary page, from that which core(s) are potentially used can be determined.
