P9160 (890,0,0) Force RMSE error at startup
Nicolas_orleans
Post by Nicolas_orleans »
Hello,
First time I see this type of error, GTX 750 Ti, Ubuntu 14.04 / driver 346.96
19:28:48:WU00:FS02:0x18:Project: 9160 (Run 890, Clone 0, Gen 0)
19:28:48:WU00:FS02:0x18:Unit: 0x00000000ab40415c567465dc5c555885
19:28:48:WU00:FS02:0x18:CPU: 0x00000000000000000000000000000000
19:28:48:WU00:FS02:0x18:Machine: 2
19:28:48:WU00:FS02:0x18:Reading tar file core.xml
19:28:48:WU00:FS02:0x18:Reading tar file system.xml
19:28:48:WU00:FS02:0x18:Reading tar file integrator.xml
19:28:48:WU00:FS02:0x18:Reading tar file state.xml
19:28:48:WU00:FS02:0x18:Digital signatures verified
19:28:48:WU00:FS02:0x18:Folding@home GPU core18
19:28:48:WU00:FS02:0x18:Version 0.0.4
19:28:58:WU00:FS02:0x18:ERROR:exception: Force RMSE error of 6.71365 with threshold of 5
19:28:58:WU00:FS02:0x18:Saving result file logfile_01.txt
19:28:58:WU00:FS02:0x18:Saving result file log.txt
19:28:58:WU00:FS02:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
19:28:59:WARNING:WU00:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:28:59:WU00:FS02:Sending unit results: id:00 state:SEND error:FAULTY project:9160 run:890 clone:0 gen:0 core:0x18 unit:0x00000000ab40415c567465dc5c555885
MSI Z77A-GD55 - Core i5-3550 - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 570.133
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 570.169
Re: P9160 (890,0,0) Force RMSE error at startup
The RMSE error message is from the part of the FAHCore that validates that the WU is coherent and is intended to stop processing if there has been a gross error before you waste a lot of time just to have the WU discarded later. The threshold of 5 is supposed to allow for floating point truncation errors and other factors where the calculations are "close enough" vs. "Wrong"
Obviously 6.7 is only a little too much error, but you have to set a threshold somewhere.
Nicolas_orleans
Thanks for the explanation, bruce
I rechecked and can confirm there's nothing wrong with your system. Others have had the same trouble and I've marked it as a bad WU.
