Need setup help
Need setup help
I just got a brand new system, and was folding well, but the software was pushing my video cards too hard causing them to get very hot. The CPU was working fine and utilizing all six cores of my old processor. I had a major system malfunction, which caused me to have to ship the whole system back to the factory. They replaced the entire system, as well as a few upgrades while it was in the shop. I purposely upgraded the processor to accommodate higher performance for folding, as I feel this is a most worthwhile endeavor. I want to do what I can to help, but I sure don't want to break this new system by doing so.
At present, the FAH Local app shows the video cards working just fine, but it shows a yellow button (Inactive) state for the main CPU. I spent the money to use this thing, all of it. But I also want it to last a few years too. Here is what I have built into this thing......
ORIGIN MILLENIUM CASE
Orientation: Standard
Standard Color: Red/White Interior
The ORIGIN Difference: ORIGIN PC Millennium- The Best Gaming Experience Guaranteed
Variable Mounting: Standard
Case Lighting: Remote Controlled Multi-Colored LED
Case Fans: ORIGIN High-Performance Ultra Silent Fans - Black
Keyboard: ORIGIN PC Black Widow Chroma
Motherboard: MSI X99A Godlike Gaming
System Cooling: ORIGIN FROSTBYTE 360 Sealed Liquid Cooling System for 1151 Socket
Processors: Intel Core i7 5930K Hex-Core 3.5GHz REVISED Intel Extreme Core i7 5960X Oct a-Core 3.0GHz (3.5GHz Turbo-boost)
ORIGIN Professional Processor Overclocking: ORIGIN Professional Processor Overclocking
Thermal Compound: GELID GC-Extreme CPU Application
Power Supply: 1000 Watt EVGA SuperNOVA G2
Power Supply Sleeved Cable Color: Red Individually Sleeved Cables
Graphic Cards: Dual 6GB NVIDIA GTX 980Ti in SLI
ORIGIN Professional Graphics Card Overclocking: ORIGIN PC Professional Graphics Card Overclocking
Memory: 32GB ORIGIN PC DDR4 Powered by Kingston 2666MHz (4 X 8GB)
Operating System: MS Windows 10 Professional
Operating System Drive #1 (Primary): 512GB Samsung 950 Pro PCIe m.2 NVMe
Accessory Drive #1: 500GB Samsung 850 Evo Series STILL INSTALLED
Accessory Drive #2: 500GB Samsung 850 Evo Series STILL INSTALLED
Accessory Drive #3: 500GB Samsung 850 Evo Series STILL INSTALLED
Accessory Drive #4: 500GB Samsung 850 Evo Series STILL INSTALLED
Raid Hard Drive Cage: 5 Bay Hot-Swap Cage REVISED w/5 Western Digital 3TB Green Drives
Four Drives in RAID 10 w/spare
Optical Drive One: 12X Blu-ray Reader and DVD Combo
Optical Drive Two: 12X Blu-ray Reader and DVD Combo
Media Reader: 40-in-1 Media Card Reader Prime
Audio: On Board High Definition 8-Channel Audio
Networking: Onboard Dual Killer Ethernet and Wireless
Software: CyberLink PowerDVD 15 Ultra
Software: MS Office Home & Business
Accessory: Logitech C310 HD Webcam
Monitor: ASUS 28" PB287Q 4K UHD LED Monitor
As you can see, this thing was built to be a beast of a machine. So why is the FAH software only using it so lightly? The Windows resource monitor show it using just a few of the cores, and only to a limited level. The browser software doesn't even show as using the main CPU. I could use some help in anyone has the knowledge and the time to offer. I'd like to get started right, so this machine can do the work I bought it to do.
You can contact me at kaylward@aol.com
I'll also check back here as I have time to see any replies.
Thank You,
Kevin Aylward
Thank You,
Kevin Aylward
Re: Need setup help
If you could post the first 100 or so lines of your log file that includes the system info and folding configuration as the client sees it, that would be useful. Directions on how to do so are found in the Welcome to the Forum topic.
Also, did you reinstall the F@H client after the changes made during the repair and upgrade? The client may be basing its usage on the prior hardware configuration if you did.
Re: Need setup help
Hi Joe,
TY for the help. Yes, I did uninstall the software, and did a new install. It is ready the equipment for what it is, it just isn't utilizing it very much. I'll see if I can find that other information and post it back here asap.
Re: Need setup help
*********************** Log Started 2016-06-08T05:41:50Z ***********************
05:41:50:************************* Folding@home Client *************************
05:41:50: Website: http://folding.stanford.edu/
05:41:50: Copyright: (c) 2009-2014 Stanford University
05:41:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:41:50: Args: --open-web-control
05:41:50: Config: C:/Users/Kevin Aylward/AppData/Roaming/FAHClient/config.xml
05:41:50:******************************** Build ********************************
05:41:50: Version: 7.4.4
05:41:50: Date: Mar 4 2014
05:41:50: Time: 20:26:54
05:41:50: SVN Rev: 4130
05:41:50: Branch: fah/trunk/client
05:41:50: Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:41:50: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:41:50: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:41:50: Platform: win32 XP
05:41:50: Bits: 32
05:41:50: Mode: Release
05:41:50:******************************* System ********************************
05:41:50: CPU: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
05:41:50: CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
05:41:50: CPUs: 16
05:41:50: Memory: 31.90GiB
05:41:50: Free Memory: 29.24GiB
05:41:50: Threads: WINDOWS_THREADS
05:41:50: OS Version: 6.2
05:41:50: Has Battery: false
05:41:50: On Battery: false
05:41:50: UTC Offset: -4
05:41:50: PID: 10868
05:41:50: CWD: C:/Users/Kevin Aylward/AppData/Roaming/FAHClient
05:41:50: OS: Windows 10 Home
05:41:50: OS Arch: AMD64
05:41:50: GPUs: 2
05:41:50: GPU 0: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
05:41:50: GPU 1: NVIDIA:5 GM200 [GeForce GTX 980 Ti]
05:41:50: CUDA: 5.2
05:41:50: CUDA Driver: 8000
05:41:50:Win32 Service: false
05:41:50:***********************************************************************
05:41:50:<config>
05:41:50: <!-- Network -->
05:41:50: <proxy v=':8080'/>
05:41:50:
05:41:50: <!-- Slot Control -->
05:41:50: <power v='FULL'/>
05:41:50:
05:41:50: <!-- User Information -->
05:41:50: <passkey v='********************************'/>
05:41:50: <user v='kaylward'/>
05:41:50:
05:41:50: <!-- Folding Slots -->
05:41:50: <slot id='0' type='CPU'>
05:41:50: <paused v='true'/>
05:41:50: </slot>
05:41:50: <slot id='1' type='GPU'>
05:41:50: </slot>
05:41:50: <slot id='2' type='GPU'>
05:41:50: </slot>
05:41:50:</config>
05:41:50:Trying to access database...
05:41:50:Successfully acquired database lock
05:41:50:Enabled folding slot 00: PAUSED cpu:14 (by user)
05:41:50:Enabled folding slot 01: PAUSED gpu:0:GM200 [GeForce GTX 980 Ti] (by user)
05:41:50:Enabled folding slot 02: PAUSED gpu:1:GM200 [GeForce GTX 980 Ti] (by user)
05:41:54:17:127.0.0.1:New Web connection
05:42:11:FS00:Unpaused
05:42:11:FS01:Unpaused
05:42:11:FS02:Unpaused
05:42:11:WU00:FS01:Starting
05:42:11:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Kevin Aylward/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe" -dir 00 -suffix 01 -version 704 -lifeline 10868 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:42:11:WU00:FS01:Started FahCore on PID 11096
05:42:11:WU00:FS01:Core PID:8764
05:42:11:WU00:FS01:FahCore 0x18 started
05:42:11:WU02:FS02:Starting
05:42:11:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Kevin Aylward/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe" -dir 02 -suffix 01 -version 704 -lifeline 10868 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
05:42:11:WU02:FS02:Started FahCore on PID 10112
05:42:11:WU02:FS02:Core PID:9368
05:42:11:WU02:FS02:FahCore 0x18 started
05:42:11:WU00:FS01:0x18:*********************** Log Started 2016-06-08T05:42:11Z ***********************
05:42:11:WU00:FS01:0x18:Project: 9161 (Run 121, Clone 0, Gen 268)
05:42:11:WU00:FS01:0x18:Unit: 0x00000135ab40415c567466416c8cb755
05:42:11:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
05:42:11:WU00:FS01:0x18:Machine: 1
05:42:11:WU00:FS01:0x18:Digital signatures verified
05:42:11:WU00:FS01:0x18:Folding@home GPU core18
05:42:12:WU00:FS01:0x18:Version 0.0.4
05:42:12:WU00:FS01:0x18: Found a checkpoint file
05:42:12:WU01:FS00:Connecting to 171.67.108.45:8080
05:42:12:WU02:FS02:0x18:*********************** Log Started 2016-06-08T05:42:11Z ***********************
05:42:12:WU02:FS02:0x18:Project: 10486 (Run 0, Clone 112, Gen 217)
05:42:12:WU02:FS02:0x18:Unit: 0x0000011c538b3dbb54aecc1c781940f6
05:42:12:WU02:FS02:0x18:CPU: 0x00000000000000000000000000000000
05:42:12:WU02:FS02:0x18:Machine: 2
05:42:12:WU02:FS02:0x18:Digital signatures verified
05:42:12:WU02:FS02:0x18:Folding@home GPU core18
05:42:12:WU02:FS02:0x18:Version 0.0.4
05:42:12:WU02:FS02:0x18: Found a checkpoint file
05:42:12:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:42:12:WU01:FS00:Connecting to 171.64.65.35:80
05:42:12:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:42:12:ERROR:WU01:FS00:Exception: Could not get an assignment
05:42:13:WU01:FS00:Connecting to 171.67.108.45:8080
05:42:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:42:13:WU01:FS00:Connecting to 171.64.65.35:80
05:42:13:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:42:13:ERROR:WU01:FS00:Exception: Could not get an assignment
05:42:26:WU00:FS01:0x18:Completed 900000 out of 2500000 steps (36%)
05:42:26:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:42:36:WU02:FS02:0x18:Completed 500000 out of 5000000 steps (10%)
05:42:36:WU02:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:42:51:Removing old file 'configs/config-20160427-143123.xml'
05:42:51:Saving configuration to config.xml
05:42:51:<config>
05:42:51: <!-- Network -->
05:42:51: <proxy v=':8080'/>
05:42:51:
05:42:51: <!-- Slot Control -->
05:42:51: <power v='FULL'/>
05:42:51:
05:42:51: <!-- User Information -->
05:42:51: <passkey v='********************************'/>
05:42:51: <user v='kaylward'/>
05:42:51:
05:42:51: <!-- Folding Slots -->
05:42:51: <slot id='0' type='CPU'/>
05:42:51: <slot id='1' type='GPU'/>
05:42:51: <slot id='2' type='GPU'/>
05:42:51:</config>
05:43:13:WU01:FS00:Connecting to 171.67.108.45:8080
05:43:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:43:13:WU01:FS00:Connecting to 171.64.65.35:80
05:43:13:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:43:13:ERROR:WU01:FS00:Exception: Could not get an assignment
05:43:38:WU00:FS01:0x18:Completed 925000 out of 2500000 steps (37%)
05:44:46:WU00:FS01:0x18:Completed 950000 out of 2500000 steps (38%)
05:44:50:WU01:FS00:Connecting to 171.67.108.45:8080
05:44:50:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:44:50:WU01:FS00:Connecting to 171.64.65.35:80
05:44:51:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:44:51:ERROR:WU01:FS00:Exception: Could not get an assignment
05:45:55:WU00:FS01:0x18:Completed 975000 out of 2500000 steps (39%)
05:46:07:WU02:FS02:0x18:Completed 550000 out of 5000000 steps (11%)
05:47:04:WU00:FS01:0x18:Completed 1000000 out of 2500000 steps (40%)
05:47:27:WU01:FS00:Connecting to 171.67.108.45:8080
05:47:28:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:47:28:WU01:FS00:Connecting to 171.64.65.35:80
05:47:28:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:47:28:ERROR:WU01:FS00:Exception: Could not get an assignment
05:48:18:WU00:FS01:0x18:Completed 1025000 out of 2500000 steps (41%)
05:49:27:WU00:FS01:0x18:Completed 1050000 out of 2500000 steps (42%)
05:49:30:WU02:FS02:0x18:Completed 600000 out of 5000000 steps (12%)
05:50:36:WU00:FS01:0x18:Completed 1075000 out of 2500000 steps (43%)
05:51:41:WU01:FS00:Connecting to 171.67.108.45:8080
05:51:42:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:51:42:WU01:FS00:Connecting to 171.64.65.35:80
05:51:42:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:51:42:ERROR:WU01:FS00:Exception: Could not get an assignment
05:51:45:WU00:FS01:0x18:Completed 1100000 out of 2500000 steps (44%)
05:52:59:WU00:FS01:0x18:Completed 1125000 out of 2500000 steps (45%)
05:53:04:WU02:FS02:0x18:Completed 650000 out of 5000000 steps (13%)
05:54:08:WU00:FS01:0x18:Completed 1150000 out of 2500000 steps (46%)
05:55:17:WU00:FS01:0x18:Completed 1175000 out of 2500000 steps (47%)
05:56:25:WU00:FS01:0x18:Completed 1200000 out of 2500000 steps (48%)
05:56:28:WU02:FS02:0x18:Completed 700000 out of 5000000 steps (14%)
05:57:40:WU00:FS01:0x18:Completed 1225000 out of 2500000 steps (49%)
05:58:33:WU01:FS00:Connecting to 171.67.108.45:8080
05:58:33:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
05:58:33:WU01:FS00:Connecting to 171.64.65.35:80
05:58:34:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
05:58:34:ERROR:WU01:FS00:Exception: Could not get an assignment
05:58:48:WU00:FS01:0x18:Completed 1250000 out of 2500000 steps (50%)
05:59:51:WU02:FS02:0x18:Completed 750000 out of 5000000 steps (15%)
05:59:56:WU00:FS01:0x18:Completed 1275000 out of 2500000 steps (51%)
06:01:04:WU00:FS01:0x18:Completed 1300000 out of 2500000 steps (52%)
06:02:17:WU00:FS01:0x18:Completed 1325000 out of 2500000 steps (53%)
06:03:26:WU00:FS01:0x18:Completed 1350000 out of 2500000 steps (54%)
06:03:26:WU02:FS02:0x18:Completed 800000 out of 5000000 steps (16%)
06:04:34:WU00:FS01:0x18:Completed 1375000 out of 2500000 steps (55%)
06:05:42:WU00:FS01:0x18:Completed 1400000 out of 2500000 steps (56%)
06:06:49:WU02:FS02:0x18:Completed 850000 out of 5000000 steps (17%)
06:06:55:WU00:FS01:0x18:Completed 1425000 out of 2500000 steps (57%)
06:08:04:WU00:FS01:0x18:Completed 1450000 out of 2500000 steps (58%)
06:09:12:WU00:FS01:0x18:Completed 1475000 out of 2500000 steps (59%)
06:09:38:WU01:FS00:Connecting to 171.67.108.45:8080
06:09:39:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:09:39:WU01:FS00:Connecting to 171.64.65.35:80
06:09:39:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:09:39:ERROR:WU01:FS00:Exception: Could not get an assignment
06:10:19:WU00:FS01:0x18:Completed 1500000 out of 2500000 steps (60%)
06:10:24:WU02:FS02:0x18:Completed 900000 out of 5000000 steps (18%)
06:11:33:WU00:FS01:0x18:Completed 1525000 out of 2500000 steps (61%)
06:12:42:WU00:FS01:0x18:Completed 1550000 out of 2500000 steps (62%)
06:13:47:WU02:FS02:0x18:Completed 950000 out of 5000000 steps (19%)
06:13:51:WU00:FS01:0x18:Completed 1575000 out of 2500000 steps (63%)
06:14:59:WU00:FS01:0x18:Completed 1600000 out of 2500000 steps (64%)
06:16:12:WU00:FS01:0x18:Completed 1625000 out of 2500000 steps (65%)
06:17:10:WU02:FS02:0x18:Completed 1000000 out of 5000000 steps (20%)
06:17:21:WU00:FS01:0x18:Completed 1650000 out of 2500000 steps (66%)
06:18:30:WU00:FS01:0x18:Completed 1675000 out of 2500000 steps (67%)
06:19:37:WU00:FS01:0x18:Completed 1700000 out of 2500000 steps (68%)
06:20:42:WU02:FS02:0x18:Completed 1050000 out of 5000000 steps (21%)
06:20:51:WU00:FS01:0x18:Completed 1725000 out of 2500000 steps (69%)
06:21:59:WU00:FS01:0x18:Completed 1750000 out of 2500000 steps (70%)
06:23:05:WU00:FS01:0x18:Completed 1775000 out of 2500000 steps (71%)
06:24:02:WU02:FS02:0x18:Completed 1100000 out of 5000000 steps (22%)
06:24:12:WU00:FS01:0x18:Completed 1800000 out of 2500000 steps (72%)
06:25:25:WU00:FS01:0x18:Completed 1825000 out of 2500000 steps (73%)
06:26:31:WU00:FS01:0x18:Completed 1850000 out of 2500000 steps (74%)
06:27:33:WU02:FS02:0x18:Completed 1150000 out of 5000000 steps (23%)
06:27:35:WU01:FS00:Connecting to 171.67.108.45:8080
06:27:36:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:27:36:WU01:FS00:Connecting to 171.64.65.35:80
06:27:36:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:27:36:ERROR:WU01:FS00:Exception: Could not get an assignment
06:27:39:WU00:FS01:0x18:Completed 1875000 out of 2500000 steps (75%)
06:28:47:WU00:FS01:0x18:Completed 1900000 out of 2500000 steps (76%)
06:30:01:WU00:FS01:0x18:Completed 1925000 out of 2500000 steps (77%)
06:30:54:WU02:FS02:0x18:Completed 1200000 out of 5000000 steps (24%)
06:31:08:WU00:FS01:0x18:Completed 1950000 out of 2500000 steps (78%)
06:32:16:WU00:FS01:0x18:Completed 1975000 out of 2500000 steps (79%)
06:33:24:WU00:FS01:0x18:Completed 2000000 out of 2500000 steps (80%)
06:34:14:WU02:FS02:0x18:Completed 1250000 out of 5000000 steps (25%)
06:34:37:WU00:FS01:0x18:Completed 2025000 out of 2500000 steps (81%)
06:35:44:WU00:FS01:0x18:Completed 2050000 out of 2500000 steps (82%)
06:36:52:WU00:FS01:0x18:Completed 2075000 out of 2500000 steps (83%)
06:37:45:WU02:FS02:0x18:Completed 1300000 out of 5000000 steps (26%)
06:37:59:WU00:FS01:0x18:Completed 2100000 out of 2500000 steps (84%)
06:39:13:WU00:FS01:0x18:Completed 2125000 out of 2500000 steps (85%)
06:39:31:WU01:FS00:Connecting to 171.67.108.45:8080
06:39:32:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:39:32:WU01:FS00:Connecting to 171.64.65.35:80
06:39:32:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:39:32:ERROR:WU01:FS00:Exception: Could not get an assignment
06:39:47:Removing old file 'configs/config-20160427-143925.xml'
06:39:47:Saving configuration to config.xml
06:39:47:<config>
06:39:47: <!-- Network -->
06:39:47: <proxy v=':8080'/>
06:39:47:
06:39:47: <!-- Slot Control -->
06:39:47: <power v='MEDIUM'/>
06:39:47:
06:39:47: <!-- User Information -->
06:39:47: <passkey v='********************************'/>
06:39:47: <user v='kaylward'/>
06:39:47:
06:39:47: <!-- Folding Slots -->
06:39:47: <slot id='0' type='CPU'/>
06:39:47: <slot id='1' type='GPU'/>
06:39:47: <slot id='2' type='GPU'/>
06:39:47:</config>
06:40:21:WU00:FS01:0x18:Completed 2150000 out of 2500000 steps (86%)
06:41:06:WU02:FS02:0x18:Completed 1350000 out of 5000000 steps (27%)
06:41:08:WU01:FS00:Connecting to 171.67.108.45:8080
06:41:09:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:41:09:WU01:FS00:Connecting to 171.64.65.35:80
06:41:09:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:41:09:ERROR:WU01:FS00:Exception: Could not get an assignment
06:41:29:WU00:FS01:0x18:Completed 2175000 out of 2500000 steps (87%)
06:42:37:WU00:FS01:0x18:Completed 2200000 out of 2500000 steps (88%)
06:43:46:WU01:FS00:Connecting to 171.67.108.45:8080
06:43:46:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:43:46:WU01:FS00:Connecting to 171.64.65.35:80
06:43:47:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:43:47:ERROR:WU01:FS00:Exception: Could not get an assignment
06:43:50:WU00:FS01:0x18:Completed 2225000 out of 2500000 steps (89%)
06:44:37:WU02:FS02:0x18:Completed 1400000 out of 5000000 steps (28%)
06:44:58:WU00:FS01:0x18:Completed 2250000 out of 2500000 steps (90%)
06:46:05:WU00:FS01:0x18:Completed 2275000 out of 2500000 steps (91%)
06:47:13:WU00:FS01:0x18:Completed 2300000 out of 2500000 steps (92%)Re: Need setup help
I did manage to find the fan controls, and have the video cards running at around 74C, so they are safe it seems. I'll know more when they have run for a few days.
Re: Need setup help
Okay, looking at the log file and the settings that show up there, the problem you are running into is that the CPU is a multiple of 7. Recently projects that could run at that setting of 14 ran out or were restricted from being assigned to that setting due to high error rates.
You can change the number of threads used by the CPU folding slot to 12 and start getting assignments. That would be done through editing the CPU slot in the Configure pane of FAHControl.
Re: Need setup help
I'll give it a try and let you know.
thanks for the help Joe
Re: Need setup help
Hi Joe,
If you are able to see this, your advice worked like a charm. It took off like a rocket headed to Mars. I had to down tune my computer, as the load of 15 cores running full throttle built up some serious heat, seriously fast. Being something of a newb at overclocking, I found myself in strange territory meddling in the BIOS of my system. Till now, that was always the realm of professional technicians. But it came a time real fast that I had to "get my hands dirty" or lose the whole system.
Several crashes, lots more attempts at tuning, and I finally have all the little cores playing well together. They do tend to act like another group from my youth that sounds very similar, but they wear perfume too! LOL
Thanks again for the help. Let me know if you ever have need of a laser for a personal project. I have a pretty nice one, and I believe in tit for tat.
Kevin
Kevin
Re: Need setup help
Stick to CPU counts that have factors 6 or less.
12 = 4 * 3 * 1 - good
14 = 7 * 2 * 1 - bad
15 = 5 * 3 * 1 - good
