unstable machine
Greg
unstable machine
Post by Greg »
I have been on FAH for about a month. I'm estimating about 50% of my WU have failed with the log reporting "unstable machine". Failure usually after running 2-3 days. I am not running any programs, just surfing the net and I avoid sites where problems might be expected. I do run adaware. Windows 10, intel Pentium, 3 Ghz, build 7.4.4. Any help would be appreciated.
Sn1ken
Re: unstable machine
Post by Sn1ken »
Any OC?
Info about your hardware?
Please post more detail from you log file (How to ...).
We also need more details from your hardware ... laptop ? desktop ? cooling ? ...
Greg
Post by Greg »
I am not sure about how to check temperature, but dropping from full to medium a few weeks ago seemed to help. I am running a desktop machine. Not sure what an "OC" is. I had cut info from my log file around unstable machine crash, but a thunderstorm a few minutes ago caused a shutdown and now that info is gone. Is there a way to back up or scroll up on the log file?
23:59:13: CPU: Intel(R) Pentium(R) D CPU 3.00GHz
23:59:13: CPU ID: GenuineIntel Family 15 Model 6 Stepping 5
23:59:13: CPUs: 2
23:59:13: Memory: 2.99GiB
23:59:13: Free Memory: 2.22GiB
23:59:13: Threads: WINDOWS_THREADS
23:59:13: OS Version: 6.2
23:59:13: Has Battery: false
23:59:13: On Battery: false
23:59:13: UTC Offset: -5
23:59:13: PID: 5128
23:59:13: CWD: C:/Users/Greg/AppData/Roaming/FAHClient
23:59:13: OS: Windows 10 Pro
23:59:13: OS Arch: X86
23:59:13: GPUs: 0
23:59:13: CUDA: Not detected
23:59:13:Win32 Service: false
By default the folding client keeps the last 16 log files in a folder within the same location which is shown as the CWD in your section of log file. The file name for the log.txt file is extended with a time stamp.
OC is short hand for overclock.
Greg
Post by Greg »
This may be more info than you need.
00:36:54:WU00:FS00:FahCore 0xa4 started
00:36:54:WU00:FS00:0xa4:
00:36:54:WU00:FS00:0xa4:*------------------------------*
00:36:54:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:36:54:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:36:54:WU00:FS00:0xa4:Preparing to commence simulation
00:36:54:WU00:FS00:0xa4:- Looking at optimizations...
00:36:54:WU00:FS00:0xa4:- Created dyn
00:36:54:WU00:FS00:0xa4:- Files status OK
00:36:54:WU00:FS00:0xa4:- Expanded 826023 -> 1402860 (decompressed 169.8 percent)
00:36:54:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826023 data_size=1402860, decompressed_data_size=1402860 diff=0
00:36:54:WU00:FS00:0xa4:- Digital signature verified
00:36:54:WU00:FS00:0xa4:Project: 9038 (Run 200, Clone 0, Gen 151)
00:36:54:WU00:FS00:0xa4:Assembly optimizations on if available.
00:36:55:WU00:FS00:0xa4:Entering M.D.
00:37:00:WU00:FS00:0xa4:Mapping NT from 1 to 1
00:37:01:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
00:55:15:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
01:12:57:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
01:30:37:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
01:48:18:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
02:06:04:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
02:23:44:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
02:41:27:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
02:59:09:WU00:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
03:00:31:WU00:FS00:0xa4:mdrun returned 255
03:00:31:WU00:FS00:0xa4:Going to send back what have done -- stepsTotalG=250000
03:00:31:WU00:FS00:0xa4:Work fraction=0.0808 steps=250000.
03:00:35:WU00:FS00:0xa4:logfile size=10718 infoLength=10718 edr=0 trr=25
03:00:35:WU00:FS00:0xa4:logfile size: 10718 info=10718 bed=0 hdr=25
03:00:35:WU00:FS00:0xa4:- Writing 11256 bytes of core data to disk...
03:00:35:WU00:FS00:0xa4:Done: 10744 -> 3778 (compressed to 35.1 percent)
03:00:35:WU00:FS00:0xa4:  ... Done.
03:00:35:WU00:FS00:0xa4:Folding@home Core Shutdown: UNSTABLE_MACHINE
03:00:36:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
03:00:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9038 run:200 clone:0 gen:151 core:0xa4 unit:0x000000b4ab436c9e56982a13e24dde1d
03:00:36:WU00:FS00:Uploading 4.19KiB to 171.67.108.158
03:00:36:WU00:FS00:Connecting to 171.67.108.158:8080
03:00:36:WU00:FS00:Upload complete
03:00:36:WU00:FS00:Server responded WORK_ACK (400)
03:00:36:WU00:FS00:Cleaning up
03:00:36:WU01:FS00:Connecting to 171.67.108.45:8080
03:00:37:WU01:FS00:Assigned to work server 171.67.108.158
03:00:37:WU01:FS00:Requesting new work unit for slot 00: READY cpu:1 from 171.67.108.158
03:00:37:WU01:FS00:Connecting to 171.67.108.158:8080
03:00:38:WU01:FS00:Downloading 806.85KiB
03:00:44:WU01:FS00:Download 79.32%
03:00:45:WU01:FS00:Download complete
03:00:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9034 run:73 clone:0 gen:152 core:0xa4 unit:0x000000b5ab436c9e5698307fdc3fa5c6
03:00:46:WU01:FS00:Starting
03:00:46:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Greg/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5128 -checkpoint 15
03:00:46:WU01:FS00:Started FahCore on PID 3780
03:00:46:WU01:FS00:Core PID:4392
03:00:46:WU01:FS00:FahCore 0xa4 started
03:00:46:WU01:FS00:0xa4:
03:00:46:WU01:FS00:0xa4:*------------------------------*
03:00:46:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
03:00:46:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:00:46:WU01:FS00:0xa4:Preparing to commence simulation
03:00:46:WU01:FS00:0xa4:- Looking at optimizations...
03:00:46:WU01:FS00:0xa4:- Created dyn
03:00:46:WU01:FS00:0xa4:- Files status OK
03:00:46:WU01:FS00:0xa4:- Expanded 825698 -> 1401112 (decompressed 169.6 percent)
03:00:46:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825698 data_size=1401112, decompressed_data_size=1401112 diff=0
03:00:46:WU01:FS00:0xa4:- Digital signature verified
03:00:46:WU01:FS00:0xa4:Project: 9034 (Run 73, Clone 0, Gen 152)
03:00:47:WU01:FS00:0xa4:
03:00:47:WU01:FS00:0xa4:Assembly optimizations on if available.
03:00:47:WU01:FS00:0xa4:Entering M.D.
03:00:52:WU01:FS00:0xa4:Mapping NT from 1 to 1
03:00:53:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
03:18:36:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
03:36:19:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
03:54:02:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
04:11:43:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
04:29:27:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
Mod edit: added Code tags to log file
Nathan_P
Not currently folding
Post by Nathan_P »
I think I've spotted the problem, all units these days are designed to run on 2 or more cpu cores, your WU are trying to run on just 1 core and I think that is the issue. The only way to solve it is to set the folder back to full and make sure its using 2 cores. Since my rigs are currently off I can't remember if moving the slider back to full is enough.
If you are having problems on running on 2 cores I would suggest either memory that starting to fail or a heat issue, it may be worth opening the case and cleaning out the heatsink on the cpu.
As for an OC, it means overclock, setting your CPU/graphics or RAM to run at a faster speed than it was designed to.
Also, you have a Pentium D which is known to generate a lot of heat ... so make sure you've cleaned your fans and heatsinks from dust.
