Dear all,
now, my systems are running since Weeks without problems, bit today i found a poor thing.
My GTX 980ti @ 1450MHz Core eating an WU 9158 from Server 171.64.65.84 since 3 hours. TPF is 6.00 Min. No mistakes, driver is running. For this job i will earn only 38.000 PPDs. Is that normal. I cant belive that.
Please, let me now, what is the reason.
Regards
brooker
WU 9158 - only 38000 PPDs on GTX 980ti
Re: WU 9158 - only 38000 PPDs on GTX 980ti
I bet your GPU is only running at 405 MHz if you check it. Restart your computer to reset it to your normal clocks.
If the GPU is only running at 405 MHz, it probably crashed and attempted to recover (and failed to do so). Please post your FAH log (How to ...).
If it actually crashed, you need to lower your overclock.
