Earlier this month, Core 15 WUs could be downloaded and processed.
But now, the FAH systray (version 6.41r2) client keeps saying Attempting to get work packet.
When will Core 15 WUs become available for download again?
Or has Core 15 been deprecated for good? (I've read about Core 15 WUs going to be discontinued anytime)
Is Core 15 still active?
Re: Is Core 15 still active?
Checking the logs for the Core_15 WS, I see WU returns over the last several days. The logs don't show information that could let me definitely determine how many assignments are being made, but it appears that some are occurring.
Do you have your client configured with the max-packet size set to small and also set to request beta WU's? Those settings are being looked for by the Assignment Servers to direct requests to the Core_15 projects that remain.
There might also be issues connected with use of the V6 client. The latest versions of the assignment code still support some requests from V6 clients, but there have been some problems seen.
The V6 GPU systray client is still unable to download work, even after setting small WU size and -betateam.
Tried the V7 client, Core 15 GPU folding works.
But V7 service installation and GPU folding do not go together.
With those settings, the V7 client will get only Core 15 for the GPU and nothing else?Joe_H wrote:Do you have your client configured with the max-packet size set to small and also set to request beta WU's? Those settings are being looked for by the Assignment Servers to direct requests to the Core_15 projects that remain.
Yes it should.
And yes, GPU folding is not supported if the client has been installed as a service : this is a Microsoft limitation
Core 15 worked for a short while on v7, then stopped working again.
Not able to get a Core 15 WU.
Under work queue in FAHControl, the status for the GPU keeps stating download but no work gets downloaded.
I'm getting the message Empty work server assignment which meeans there are no Work Servers which can supply the type of WU you're seeking. I suspect that they've finally finished all the projects that use Core_15, so in essence, those ancient GPUs should be listed as "unsupported"
Thanks for the reply.bruce wrote:I'm getting the message Empty work server assignment which meeans there are no Work Servers which can supply the type of WU you're seeking. I suspect that they've finally finished all the projects that use Core_15, so in essence, those ancient GPUs should be listed as "unsupported"
What I liked about Core 15 is that it had low RAM requirements, and didn't cause screen jerkiness during GPU folding.
Looking at the log entries for the server that had Core_15 projects using the link on the Server Status page, it does look like few if any WU's are available for assignment. The log entries only show a few WU's returned each day over the past week, a couple weeks ago it was in the range of 1 to 2 dozen WU's a day. Some days it appears that no WU's were returned at all.
