Possible Issues with 11652 76, 0, 15
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hello,
Over the past week, the client on this Windows 10, 4-core/8GB homemade computer has been locking up; and/or becoming inaccessible via the FAH Client or Web Client. I have the client installed as a Service, under my account who is the administrator of our family computer. It is running at the lowest speed to keep the computer from overheating. Am using the CPU only. The graphics card is too old to contribute. Was getting ~10-15K points per day, but not as much as can be seen as of late. http://folding.extremeoverclocking.com/ ... =&u=655841 I am not certain, but my recent problem seems be related to the one noted under Current Software / v7.4.4 Public Release Windows/Linux/MacOS X as viewtopic.php?f=96&t=28715
I've noticed a few times that Project 11652, Run 76, Clone 0, Gen 15 may be a cause of issues with FAH on this system. Before this week, all has been running as designed with no outside help needed. Tried a few restarts, even tried to shut down FAH via the Task Manager. It sometimes came back but still was working on 11652. I think another job that did not go out properly may have been part of the problem too. Anyway got tired of problems with 11652, so restarted in SAFE mode, then deleted both jobs in sub-subdirectories 00 and 01 under the /work directory. The system appears to be working fine with a new job of 11637 1, 347, 5 as of this writing with an ETA of 11 hours (likely faster once I close the browser and other items needed to compose this).
Below are two clips from the logs showing what transpired for parts of the week.
Regards,
Robby
Below is the last time 11652 appeared to successfully complete (but apparently not get transmitted to you) starting May 5th at 2253Z ending May 6th around 13Z
*********************** Log Started 2016-05-05T23:53:23Z ***********************
23:53:23:************************* Folding@home Client *************************
23:53:23:      Website: http://folding.stanford.edu/
23:53:23:    Copyright: (c) 2009-2014 Stanford University
23:53:23:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:53:23:         Args:
23:53:23:       Config: C:/Users/Robby/AppData/Roaming/FAHClient/config.xml
23:53:23:******************************** Build ********************************
23:53:23:      Version: 7.4.4
23:53:23:         Date: Mar 4 2014
23:53:23:         Time: 20:26:54
23:53:23:      SVN Rev: 4130
23:53:23:       Branch: fah/trunk/client
23:53:23:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:53:23:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:53:23:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:53:23:     Platform: win32 XP
23:53:23:         Bits: 32
23:53:23:         Mode: Release
23:53:23:******************************* System ********************************
23:53:23:          CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
23:53:23:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
23:53:23:         CPUs: 8
23:53:23:       Memory: 7.88GiB
23:53:23:  Free Memory: 5.27GiB
23:53:23:      Threads: WINDOWS_THREADS
23:53:23:   OS Version: 6.2
23:53:23:  Has Battery: false
23:53:23:   On Battery: false
23:53:23:   UTC Offset: -5
23:53:23:          PID: 1084
23:53:23:          CWD: C:/WINDOWS/system32
23:53:23:           OS: Windows 10 Home
23:53:23:      OS Arch: AMD64
23:53:23:         GPUs: 0
23:53:23:         CUDA: Not detected
23:53:23:Win32 Service: true
23:53:23:***********************************************************************
23:53:23:<config>
23:53:23:  <!-- Folding Slot Configuration -->
23:53:23:  <cause v='ALZHEIMERS'/>
23:53:23:
23:53:23:  <!-- Network -->
23:53:23:  <proxy v=':8080'/>
23:53:23:
23:53:23:  <!-- Slot Control -->
23:53:23:  <power v='light'/>
23:53:23:
23:53:23:  <!-- User Information -->
23:53:23:  <passkey v='********************************'/>
23:53:23:  <team v='341'/>
23:53:23:  <user v='Robby'/>
23:53:23:
23:53:23:  <!-- Folding Slots -->
23:53:23:  <slot id='0' type='CPU'/>
23:53:23:</config>
23:53:23:Trying to access database...
23:53:23:Successfully acquired database lock
23:53:23:Enabled folding slot 00: READY cpu:4
23:53:23:WU01:FS00:Starting
23:53:23:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1084 -checkpoint 15 -np 4 -service
23:53:23:WU01:FS00:Started FahCore on PID 7796
23:53:24:WU01:FS00:Core PID:7864
23:53:24:WU01:FS00:FahCore 0xa4 started
23:53:24:WU01:FS00:0xa4:
23:53:24:WU01:FS00:0xa4:*------------------------------*
23:53:24:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
23:53:24:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
23:53:24:WU01:FS00:0xa4:Preparing to commence simulation
23:53:24:WU01:FS00:0xa4:- Ensuring status. Please wait.
23:53:33:WU01:FS00:0xa4:- Looking at optimizations...
23:53:33:WU01:FS00:0xa4:- Working with standard loops on this execution.
23:53:33:WU01:FS00:0xa4:- Previous termination of core was improper.
23:53:33:WU01:FS00:0xa4:- Files status OK
23:53:33:WU01:FS00:0xa4:- Expanded 1658727 -> 3106984 (decompressed 187.3 percent)
23:53:33:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1658727 data_size=3106984, decompressed_data_size=3106984 diff=0
23:53:33:WU01:FS00:0xa4:- Digital signature verified
23:53:33:WU01:FS00:0xa4:Project: 11652 (Run 76, Clone 0, Gen 15)
23:53:33:WU01:FS00:0xa4:Entering M.D.
23:53:39:WU01:FS00:0xa4:Using Gromacs checkpoints
23:53:39:WU01:FS00:0xa4:Mapping NT from 4 to 4
23:53:40:WU01:FS00:0xa4:Resuming from checkpoint
23:53:40:WU01:FS00:0xa4:Verified 01/wudata_01.log
23:53:40:WU01:FS00:0xa4:Verified 01/wudata_01.trr
23:53:40:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
23:53:40:WU01:FS00:0xa4:Verified 01/wudata_01.edr
23:53:40:WU01:FS00:0xa4:Completed 106980 out of 1250000 steps  (8%)
23:57:33:WU01:FS00:0xa4:Completed 112500 out of 1250000 steps  (9%)
00:06:14:WU01:FS00:0xa4:Completed 125000 out of 1250000 steps  (10%)
00:14:55:WU01:FS00:0xa4:Completed 137500 out of 1250000 steps  (11%)
00:23:32:WU01:FS00:0xa4:Completed 150000 out of 1250000 steps  (12%)
00:32:09:WU01:FS00:0xa4:Completed 162500 out of 1250000 steps  (13%)
00:40:51:WU01:FS00:0xa4:Completed 175000 out of 1250000 steps  (14%)
00:49:29:WU01:FS00:0xa4:Completed 187500 out of 1250000 steps  (15%)
00:58:14:WU01:FS00:0xa4:Completed 200000 out of 1250000 steps  (16%)
01:06:59:WU01:FS00:0xa4:Completed 212500 out of 1250000 steps  (17%)
01:15:42:WU01:FS00:0xa4:Completed 225000 out of 1250000 steps  (18%)
01:24:22:WU01:FS00:0xa4:Completed 237500 out of 1250000 steps  (19%)
01:33:02:WU01:FS00:0xa4:Completed 250000 out of 1250000 steps  (20%)
01:41:41:WU01:FS00:0xa4:Completed 262500 out of 1250000 steps  (21%)
01:51:01:WU01:FS00:0xa4:Completed 275000 out of 1250000 steps  (22%)
01:59:46:WU01:FS00:0xa4:Completed 287500 out of 1250000 steps  (23%)
02:08:34:WU01:FS00:0xa4:Completed 300000 out of 1250000 steps  (24%)
02:17:14:WU01:FS00:0xa4:Completed 312500 out of 1250000 steps  (25%)
02:25:56:WU01:FS00:0xa4:Completed 325000 out of 1250000 steps  (26%)
02:34:33:WU01:FS00:0xa4:Completed 337500 out of 1250000 steps  (27%)
02:43:08:WU01:FS00:0xa4:Completed 350000 out of 1250000 steps  (28%)
02:51:43:WU01:FS00:0xa4:Completed 362500 out of 1250000 steps  (29%)
03:00:19:WU01:FS00:0xa4:Completed 375000 out of 1250000 steps  (30%)
03:08:56:WU01:FS00:0xa4:Completed 387500 out of 1250000 steps  (31%)
03:17:33:WU01:FS00:0xa4:Completed 400000 out of 1250000 steps  (32%)
03:26:10:WU01:FS00:0xa4:Completed 412500 out of 1250000 steps  (33%)
03:34:47:WU01:FS00:0xa4:Completed 425000 out of 1250000 steps  (34%)
03:43:25:WU01:FS00:0xa4:Completed 437500 out of 1250000 steps  (35%)
03:52:03:WU01:FS00:0xa4:Completed 450000 out of 1250000 steps  (36%)
04:00:40:WU01:FS00:0xa4:Completed 462500 out of 1250000 steps  (37%)
04:09:17:WU01:FS00:0xa4:Completed 475000 out of 1250000 steps  (38%)
04:17:54:WU01:FS00:0xa4:Completed 487500 out of 1250000 steps  (39%)
04:26:30:WU01:FS00:0xa4:Completed 500000 out of 1250000 steps  (40%)
04:35:06:WU01:FS00:0xa4:Completed 512500 out of 1250000 steps  (41%)
04:43:42:WU01:FS00:0xa4:Completed 525000 out of 1250000 steps  (42%)
04:52:18:WU01:FS00:0xa4:Completed 537500 out of 1250000 steps  (43%)
05:00:54:WU01:FS00:0xa4:Completed 550000 out of 1250000 steps  (44%)
05:09:31:WU01:FS00:0xa4:Completed 562500 out of 1250000 steps  (45%)
05:18:07:WU01:FS00:0xa4:Completed 575000 out of 1250000 steps  (46%)
05:26:44:WU01:FS00:0xa4:Completed 587500 out of 1250000 steps  (47%)
05:35:20:WU01:FS00:0xa4:Completed 600000 out of 1250000 steps  (48%)
05:43:56:WU01:FS00:0xa4:Completed 612500 out of 1250000 steps  (49%)
05:52:33:WU01:FS00:0xa4:Completed 625000 out of 1250000 steps  (50%)
******************************* Date: 2016-05-06 *******************************
06:01:09:WU01:FS00:0xa4:Completed 637500 out of 1250000 steps  (51%)
06:09:45:WU01:FS00:0xa4:Completed 650000 out of 1250000 steps  (52%)
06:18:21:WU01:FS00:0xa4:Completed 662500 out of 1250000 steps  (53%)
06:26:57:WU01:FS00:0xa4:Completed 675000 out of 1250000 steps  (54%)
06:35:33:WU01:FS00:0xa4:Completed 687500 out of 1250000 steps  (55%)
06:44:10:WU01:FS00:0xa4:Completed 700000 out of 1250000 steps  (56%)
06:52:45:WU01:FS00:0xa4:Completed 712500 out of 1250000 steps  (57%)
07:01:22:WU01:FS00:0xa4:Completed 725000 out of 1250000 steps  (58%)
07:09:59:WU01:FS00:0xa4:Completed 737500 out of 1250000 steps  (59%)
07:18:35:WU01:FS00:0xa4:Completed 750000 out of 1250000 steps  (60%)
07:27:12:WU01:FS00:0xa4:Completed 762500 out of 1250000 steps  (61%)
07:35:48:WU01:FS00:0xa4:Completed 775000 out of 1250000 steps  (62%)
07:44:26:WU01:FS00:0xa4:Completed 787500 out of 1250000 steps  (63%)
07:53:03:WU01:FS00:0xa4:Completed 800000 out of 1250000 steps  (64%)
08:01:41:WU01:FS00:0xa4:Completed 812500 out of 1250000 steps  (65%)
08:10:31:WU01:FS00:0xa4:Completed 825000 out of 1250000 steps  (66%)
08:19:21:WU01:FS00:0xa4:Completed 837500 out of 1250000 steps  (67%)
08:28:11:WU01:FS00:0xa4:Completed 850000 out of 1250000 steps  (68%)
08:36:59:WU01:FS00:0xa4:Completed 862500 out of 1250000 steps  (69%)
08:45:46:WU01:FS00:0xa4:Completed 875000 out of 1250000 steps  (70%)
08:54:33:WU01:FS00:0xa4:Completed 887500 out of 1250000 steps  (71%)
09:03:22:WU01:FS00:0xa4:Completed 900000 out of 1250000 steps  (72%)
09:12:10:WU01:FS00:0xa4:Completed 912500 out of 1250000 steps  (73%)
09:20:59:WU01:FS00:0xa4:Completed 925000 out of 1250000 steps  (74%)
09:29:46:WU01:FS00:0xa4:Completed 937500 out of 1250000 steps  (75%)
09:38:33:WU01:FS00:0xa4:Completed 950000 out of 1250000 steps  (76%)
09:47:20:WU01:FS00:0xa4:Completed 962500 out of 1250000 steps  (77%)
09:56:08:WU01:FS00:0xa4:Completed 975000 out of 1250000 steps  (78%)
10:05:02:WU01:FS00:0xa4:Completed 987500 out of 1250000 steps  (79%)
10:13:50:WU01:FS00:0xa4:Completed 1000000 out of 1250000 steps  (80%)
10:22:38:WU01:FS00:0xa4:Completed 1012500 out of 1250000 steps  (81%)
10:31:24:WU01:FS00:0xa4:Completed 1025000 out of 1250000 steps  (82%)
10:40:08:WU01:FS00:0xa4:Completed 1037500 out of 1250000 steps  (83%)
10:48:50:WU01:FS00:0xa4:Completed 1050000 out of 1250000 steps  (84%)
10:57:35:WU01:FS00:0xa4:Completed 1062500 out of 1250000 steps  (85%)
11:06:24:WU01:FS00:0xa4:Completed 1075000 out of 1250000 steps  (86%)
11:15:10:WU01:FS00:0xa4:Completed 1087500 out of 1250000 steps  (87%)
11:23:52:WU01:FS00:0xa4:Completed 1100000 out of 1250000 steps  (88%)
11:32:34:WU01:FS00:0xa4:Completed 1112500 out of 1250000 steps  (89%)
11:41:31:WU01:FS00:0xa4:Completed 1125000 out of 1250000 steps  (90%)
11:50:20:WU01:FS00:0xa4:Completed 1137500 out of 1250000 steps  (91%)
11:59:04:WU01:FS00:0xa4:Completed 1150000 out of 1250000 steps  (92%)
12:07:48:WU01:FS00:0xa4:Completed 1162500 out of 1250000 steps  (93%)
12:16:32:WU01:FS00:0xa4:Completed 1175000 out of 1250000 steps  (94%)
12:25:20:WU01:FS00:0xa4:Completed 1187500 out of 1250000 steps  (95%)
12:34:01:WU01:FS00:0xa4:Completed 1200000 out of 1250000 steps  (96%)
12:42:43:WU01:FS00:0xa4:Completed 1212500 out of 1250000 steps  (97%)
12:51:26:WU01:FS00:0xa4:Completed 1225000 out of 1250000 steps  (98%)
13:00:11:WU01:FS00:0xa4:Completed 1237500 out of 1250000 steps  (99%)
13:08:55:WU01:FS00:0xa4:Completed 1250000 out of 1250000 steps  (100%)
13:08:56:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:09:05:WU01:FS00:0xa4:
13:09:05:WU01:FS00:0xa4:Finished Work Unit:
13:09:05:WU01:FS00:0xa4:- Reading up to 5199732 from "01/wudata_01.trr": Read 5199732
13:09:05:WU01:FS00:0xa4:trr file hash check passed.
13:09:06:WU01:FS00:0xa4:- Reading up to 11088984 from "01/wudata_01.xtc": Read 11088984
13:09:06:WU01:FS00:0xa4:xtc file hash check passed.
13:09:06:WU01:FS00:0xa4:edr file hash check passed.
13:09:06:WU01:FS00:0xa4:logfile size: 24981
13:09:06:WU01:FS00:0xa4:Leaving Run
13:09:10:WU01:FS00:0xa4:- Writing 16316101 bytes of core data to disk...
13:09:13:WU01:FS00:0xa4:Done: 16315589 -> 15959051 (compressed to 97.8 percent)
13:09:13:WU01:FS00:0xa4:  ... Done.
13:09:14:WU01:FS00:0xa4:Error deleting frame files
13:09:14:WU01:FS00:0xa4:- Shutting down core
13:09:14:WU01:FS00:0xa4:Folding@home Core Shutdown: FILE_IO_ERROR
From earlier this week, starting May 1st at 0228Z, ending around May 5th at 2235Z
*********************** Log Started 2016-05-01T00:02:28Z ***********************
00:02:28:************************* Folding@home Client *************************
00:02:28:      Website: http://folding.stanford.edu/
00:02:28:    Copyright: (c) 2009-2014 Stanford University
00:02:28:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:02:28:         Args:
00:02:28:       Config: C:/Users/Robby/AppData/Roaming/FAHClient/config.xml
00:02:28:******************************** Build ********************************
00:02:28:      Version: 7.4.4
00:02:28:         Date: Mar 4 2014
00:02:28:         Time: 20:26:54
00:02:28:      SVN Rev: 4130
00:02:28:       Branch: fah/trunk/client
00:02:28:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:02:28:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:02:28:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:02:28:     Platform: win32 XP
00:02:28:         Bits: 32
00:02:28:         Mode: Release
00:02:28:******************************* System ********************************
00:02:28:          CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
00:02:28:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:02:28:         CPUs: 8
00:02:28:       Memory: 7.88GiB
00:02:28:  Free Memory: 6.79GiB
00:02:28:      Threads: WINDOWS_THREADS
00:02:28:   OS Version: 6.2
00:02:28:  Has Battery: false
00:02:28:   On Battery: false
00:02:28:   UTC Offset: -5
00:02:28:          PID: 2388
00:02:28:          CWD: C:/WINDOWS/system32
00:02:28:           OS: Windows 10 Home
00:02:28:      OS Arch: AMD64
00:02:28:         GPUs: 0
00:02:28:         CUDA: Not detected
00:02:28:Win32 Service: true
00:02:28:***********************************************************************
00:02:28:<config>
00:02:28:  <!-- Network -->
00:02:28:  <proxy v=':8080'/>
00:02:28:
00:02:28:  <!-- Slot Control -->
00:02:28:  <power v='light'/>
00:02:28:
00:02:28:  <!-- User Information -->
00:02:28:  <passkey v='********************************'/>
00:02:28:  <team v='341'/>
00:02:28:  <user v='Robby'/>
00:02:28:
00:02:28:  <!-- Folding Slots -->
00:02:28:  <slot id='0' type='CPU'/>
00:02:28:</config>
00:02:28:Trying to access database...
00:02:31:Successfully acquired database lock
00:02:31:Enabled folding slot 00: READY cpu:4
00:02:33:WU00:FS00:Starting
00:02:34:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2388 -checkpoint 15 -np 4 -service
00:02:34:WU00:FS00:Started FahCore on PID 4008
00:02:37:WU00:FS00:Core PID:2508
00:02:37:WU00:FS00:FahCore 0xa4 started
00:02:39:WU00:FS00:0xa4:
00:02:39:WU00:FS00:0xa4:*------------------------------*
00:02:39:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
00:02:39:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:02:39:WU00:FS00:0xa4:Preparing to commence simulation
00:02:39:WU00:FS00:0xa4:- Looking at optimizations...
00:02:39:WU00:FS00:0xa4:- Files status OK
00:02:39:WU00:FS00:0xa4:- Expanded 1215391 -> 2902920 (decompressed 238.8 percent)
00:02:39:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1215391 data_size=2902920, decompressed_data_size=2902920 diff=0
00:02:39:WU00:FS00:0xa4:- Digital signature verified
00:02:39:WU00:FS00:0xa4:Project: 11641 (Run 1, Clone 140, Gen 22)
00:02:39:WU00:FS00:0xa4:Assembly optimizations on if available.
00:02:39:WU00:FS00:0xa4:Entering M.D.
00:02:46:WU00:FS00:0xa4:Using Gromacs checkpoints
00:02:46:WU00:FS00:0xa4:Mapping NT from 4 to 4
00:02:48:WU00:FS00:0xa4:Resuming from checkpoint
00:02:49:WU00:FS00:0xa4:Verified 00/wudata_01.log
00:02:50:WU00:FS00:0xa4:Verified 00/wudata_01.trr
00:02:55:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
00:02:55:WU00:FS00:0xa4:Verified 00/wudata_01.edr
00:02:56:WU00:FS00:0xa4:Completed 398550 out of 1250000 steps  (31%)
00:03:42:WU00:FS00:0xa4:Completed 400000 out of 1250000 steps  (32%)
00:10:06:WU00:FS00:0xa4:Completed 412500 out of 1250000 steps  (33%)
00:16:18:WU00:FS00:0xa4:Completed 425000 out of 1250000 steps  (34%)
00:22:25:WU00:FS00:0xa4:Completed 437500 out of 1250000 steps  (35%)
22:01:14:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11638 run:1 clone:122 gen:42 core:0xa4 unit:0x0000002e4c71bbb0569e86fed5972f61
22:01:14:WU00:FS00:Uploading 27.89MiB to 128.252.203.2
22:01:14:WU00:FS00:Connecting to 128.252.203.2:8080
22:01:14:WU01:FS00:Starting
22:01:14:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 2388 -checkpoint 15 -np 4 -service
22:01:14:WU01:FS00:Started FahCore on PID 2748
22:01:15:WU01:FS00:Core PID:22716
22:01:15:WU01:FS00:FahCore 0xa4 started
22:01:15:WU01:FS00:0xa4:
22:01:15:WU01:FS00:0xa4:*------------------------------*
22:01:15:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
22:01:15:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:01:15:WU01:FS00:0xa4:Preparing to commence simulation
22:01:15:WU01:FS00:0xa4:- Looking at optimizations...
22:01:15:WU01:FS00:0xa4:- Created dyn
22:01:15:WU01:FS00:0xa4:- Files status OK
22:01:15:WU01:FS00:0xa4:- Expanded 118788 -> 269896 (decompressed 227.2 percent)
22:01:15:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=118788 data_size=269896, decompressed_data_size=269896 diff=0
22:01:15:WU01:FS00:0xa4:- Digital signature verified
22:01:15:WU01:FS00:0xa4:Project: 6392 (Run 44, Clone 33, Gen 332)
22:01:15:WU01:FS00:0xa4:Assembly optimizations on if available.
22:01:15:WU01:FS00:0xa4:Entering M.D.
22:01:20:WU00:FS00:Upload 15.24%
22:01:21:WU01:FS00:0xa4:Mapping NT from 4 to 4
22:01:21:WU01:FS00:0xa4:Completed 0 out of 5000000 steps  (0%)
22:01:26:WU00:FS00:Upload 28.46%
22:01:32:WU00:FS00:Upload 41.24%
22:01:38:WU00:FS00:Upload 54.24%
22:01:44:WU00:FS00:Upload 67.01%
22:01:50:WU00:FS00:Upload 77.55%
22:01:56:WU00:FS00:Upload 92.34%
22:02:05:WU00:FS00:Upload complete
22:02:05:WU00:FS00:Server responded WORK_ACK (400)
22:02:05:WU00:FS00:Final credit estimate, 8094.00 points
22:02:05:WU00:FS00:Cleaning up
22:03:40:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps  (1%)
22:05:54:WU01:FS00:0xa4:Completed 100000 out of 5000000 steps  (2%)
22:08:08:WU01:FS00:0xa4:Completed 150000 out of 5000000 steps  (3%)
22:10:21:WU01:FS00:0xa4:Completed 200000 out of 5000000 steps  (4%)
22:12:36:WU01:FS00:0xa4:Completed 250000 out of 5000000 steps  (5%)
22:14:49:WU01:FS00:0xa4:Completed 300000 out of 5000000 steps  (6%)
22:17:03:WU01:FS00:0xa4:Completed 350000 out of 5000000 steps  (7%)
22:19:16:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps  (8%)
22:21:30:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps  (9%)
22:23:44:WU01:FS00:0xa4:Completed 500000 out of 5000000 steps  (10%)
22:25:59:WU01:FS00:0xa4:Completed 550000 out of 5000000 steps  (11%)
22:28:15:WU01:FS00:0xa4:Completed 600000 out of 5000000 steps  (12%)
22:30:28:WU01:FS00:0xa4:Completed 650000 out of 5000000 steps  (13%)
22:32:43:WU01:FS00:0xa4:Completed 700000 out of 5000000 steps  (14%)
22:34:57:WU01:FS00:0xa4:Completed 750000 out of 5000000 steps  (15%)
22:37:11:WU01:FS00:0xa4:Completed 800000 out of 5000000 steps  (16%)
22:39:24:WU01:FS00:0xa4:Completed 850000 out of 5000000 steps  (17%)
22:41:40:WU01:FS00:0xa4:Completed 900000 out of 5000000 steps  (18%)
22:44:04:WU01:FS00:0xa4:Completed 950000 out of 5000000 steps  (19%)
22:46:33:WU01:FS00:0xa4:Completed 1000000 out of 5000000 steps  (20%)
22:48:54:WU01:FS00:0xa4:Completed 1050000 out of 5000000 steps  (21%)
22:51:16:WU01:FS00:0xa4:Completed 1100000 out of 5000000 steps  (22%)
22:53:38:WU01:FS00:0xa4:Completed 1150000 out of 5000000 steps  (23%)
22:56:01:WU01:FS00:0xa4:Completed 1200000 out of 5000000 steps  (24%)
22:58:23:WU01:FS00:0xa4:Completed 1250000 out of 5000000 steps  (25%)
23:00:44:WU01:FS00:0xa4:Completed 1300000 out of 5000000 steps  (26%)
23:03:07:WU01:FS00:0xa4:Completed 1350000 out of 5000000 steps  (27%)
23:05:31:WU01:FS00:0xa4:Completed 1400000 out of 5000000 steps  (28%)
23:07:52:WU01:FS00:0xa4:Completed 1450000 out of 5000000 steps  (29%)
23:10:14:WU01:FS00:0xa4:Completed 1500000 out of 5000000 steps  (30%)
23:12:38:WU01:FS00:0xa4:Completed 1550000 out of 5000000 steps  (31%)
23:15:00:WU01:FS00:0xa4:Completed 1600000 out of 5000000 steps  (32%)
23:17:23:WU01:FS00:0xa4:Completed 1650000 out of 5000000 steps  (33%)
23:19:51:WU01:FS00:0xa4:Completed 1700000 out of 5000000 steps  (34%)
23:22:13:WU01:FS00:0xa4:Completed 1750000 out of 5000000 steps  (35%)
23:24:42:WU01:FS00:0xa4:Completed 1800000 out of 5000000 steps  (36%)
23:27:15:WU01:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
23:29:43:WU01:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
23:32:07:WU01:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
23:34:32:WU01:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
23:36:56:WU01:FS00:0xa4:Completed 2050000 out of 5000000 steps  (41%)
23:39:21:WU01:FS00:0xa4:Completed 2100000 out of 5000000 steps  (42%)
23:41:45:WU01:FS00:0xa4:Completed 2150000 out of 5000000 steps  (43%)
23:44:09:WU01:FS00:0xa4:Completed 2200000 out of 5000000 steps  (44%)
23:46:33:WU01:FS00:0xa4:Completed 2250000 out of 5000000 steps  (45%)
23:48:54:WU01:FS00:0xa4:Completed 2300000 out of 5000000 steps  (46%)
23:51:14:WU01:FS00:0xa4:Completed 2350000 out of 5000000 steps  (47%)
23:53:35:WU01:FS00:0xa4:Completed 2400000 out of 5000000 steps  (48%)
23:55:55:WU01:FS00:0xa4:Completed 2450000 out of 5000000 steps  (49%)
23:58:21:WU01:FS00:0xa4:Completed 2500000 out of 5000000 steps  (50%)
00:00:46:WU01:FS00:0xa4:Completed 2550000 out of 5000000 steps  (51%)
00:03:16:WU01:FS00:0xa4:Completed 2600000 out of 5000000 steps  (52%)
00:05:36:WU01:FS00:0xa4:Completed 2650000 out of 5000000 steps  (53%)
00:08:04:WU01:FS00:0xa4:Completed 2700000 out of 5000000 steps  (54%)
00:10:33:WU01:FS00:0xa4:Completed 2750000 out of 5000000 steps  (55%)
00:13:01:WU01:FS00:0xa4:Completed 2800000 out of 5000000 steps  (56%)
00:15:29:WU01:FS00:0xa4:Completed 2850000 out of 5000000 steps  (57%)
00:17:58:WU01:FS00:0xa4:Completed 2900000 out of 5000000 steps  (58%)
00:20:25:WU01:FS00:0xa4:Completed 2950000 out of 5000000 steps  (59%)
00:22:54:WU01:FS00:0xa4:Completed 3000000 out of 5000000 steps  (60%)
00:25:23:WU01:FS00:0xa4:Completed 3050000 out of 5000000 steps  (61%)
00:27:52:WU01:FS00:0xa4:Completed 3100000 out of 5000000 steps  (62%)
00:30:20:WU01:FS00:0xa4:Completed 3150000 out of 5000000 steps  (63%)
00:32:49:WU01:FS00:0xa4:Completed 3200000 out of 5000000 steps  (64%)
00:35:17:WU01:FS00:0xa4:Completed 3250000 out of 5000000 steps  (65%)
******************************* Date: 2016-05-05 *******************************
00:37:45:WU01:FS00:0xa4:Completed 3300000 out of 5000000 steps  (66%)
00:40:12:WU01:FS00:0xa4:Completed 3350000 out of 5000000 steps  (67%)
00:42:40:WU01:FS00:0xa4:Completed 3400000 out of 5000000 steps  (68%)
00:45:07:WU01:FS00:0xa4:Completed 3450000 out of 5000000 steps  (69%)
00:47:35:WU01:FS00:0xa4:Completed 3500000 out of 5000000 steps  (70%)
00:50:03:WU01:FS00:0xa4:Completed 3550000 out of 5000000 steps  (71%)
00:52:31:WU01:FS00:0xa4:Completed 3600000 out of 5000000 steps  (72%)
00:54:59:WU01:FS00:0xa4:Completed 3650000 out of 5000000 steps  (73%)
00:57:26:WU01:FS00:0xa4:Completed 3700000 out of 5000000 steps  (74%)
00:59:54:WU01:FS00:0xa4:Completed 3750000 out of 5000000 steps  (75%)
01:02:22:WU01:FS00:0xa4:Completed 3800000 out of 5000000 steps  (76%)
01:04:50:WU01:FS00:0xa4:Completed 3850000 out of 5000000 steps  (77%)
01:07:22:WU01:FS00:0xa4:Completed 3900000 out of 5000000 steps  (78%)
01:09:50:WU01:FS00:0xa4:Completed 3950000 out of 5000000 steps  (79%)
01:12:17:WU01:FS00:0xa4:Completed 4000000 out of 5000000 steps  (80%)
01:14:45:WU01:FS00:0xa4:Completed 4050000 out of 5000000 steps  (81%)
01:17:14:WU01:FS00:0xa4:Completed 4100000 out of 5000000 steps  (82%)
01:19:42:WU01:FS00:0xa4:Completed 4150000 out of 5000000 steps  (83%)
01:22:19:WU01:FS00:0xa4:Completed 4200000 out of 5000000 steps  (84%)
01:24:41:WU01:FS00:0xa4:Completed 4250000 out of 5000000 steps  (85%)
01:26:58:WU01:FS00:0xa4:Completed 4300000 out of 5000000 steps  (86%)
01:29:19:WU01:FS00:0xa4:Completed 4350000 out of 5000000 steps  (87%)
01:31:39:WU01:FS00:0xa4:Completed 4400000 out of 5000000 steps  (88%)
01:34:00:WU01:FS00:0xa4:Completed 4450000 out of 5000000 steps  (89%)
01:36:20:WU01:FS00:0xa4:Completed 4500000 out of 5000000 steps  (90%)
01:38:41:WU01:FS00:0xa4:Completed 4550000 out of 5000000 steps  (91%)
01:41:02:WU01:FS00:0xa4:Completed 4600000 out of 5000000 steps  (92%)
01:43:22:WU01:FS00:0xa4:Completed 4650000 out of 5000000 steps  (93%)
01:45:43:WU01:FS00:0xa4:Completed 4700000 out of 5000000 steps  (94%)
01:48:06:WU01:FS00:0xa4:Completed 4750000 out of 5000000 steps  (95%)
01:50:28:WU01:FS00:0xa4:Completed 4800000 out of 5000000 steps  (96%)
01:52:48:WU01:FS00:0xa4:Completed 4850000 out of 5000000 steps  (97%)
01:55:07:WU01:FS00:0xa4:Completed 4900000 out of 5000000 steps  (98%)
01:57:28:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps  (99%)
01:57:29:WU00:FS00:Connecting to 171.67.108.45:8080
01:57:29:WU00:FS00:Assigned to work server 171.67.108.158
01:57:29:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.158
01:57:29:WU00:FS00:Connecting to 171.67.108.158:8080
01:57:30:WU00:FS00:Downloading 806.11KiB
01:57:31:WU00:FS00:Download complete
01:57:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9031 run:191 clone:6 gen:18 core:0xa4 unit:0x00000014ab436c9e569834ea53d6f33e
01:59:52:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps  (100%)
01:59:52:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:00:02:WU01:FS00:0xa4:
02:00:02:WU01:FS00:0xa4:Finished Work Unit:
02:00:02:WU01:FS00:0xa4:- Reading up to 1254528 from "01/wudata_01.trr": Read 1254528
02:00:02:WU01:FS00:0xa4:trr file hash check passed.
02:00:02:WU01:FS00:0xa4:- Reading up to 109520 from "01/wudata_01.xtc": Read 109520
02:00:02:WU01:FS00:0xa4:xtc file hash check passed.
02:00:02:WU01:FS00:0xa4:edr file hash check passed.
02:00:02:WU01:FS00:0xa4:logfile size: 87936
02:00:02:WU01:FS00:0xa4:Leaving Run
02:00:06:WU01:FS00:0xa4:- Writing 1523884 bytes of core data to disk...
02:00:06:WU01:FS00:0xa4:Done: 1523372 -> 1289431 (compressed to 84.6 percent)
02:00:06:WU01:FS00:0xa4:  ... Done.
02:00:06:WU01:FS00:0xa4:- Shutting down core
02:00:06:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:00:07:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:00:07:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6392 run:44 clone:33 gen:332 core:0xa4 unit:0x0000019b0002894b545b9f0543429874
02:00:07:WU01:FS00:Uploading 1.23MiB to 155.247.166.219
02:00:07:WU00:FS00:Starting
02:00:07:WU01:FS00:Connecting to 155.247.166.219:8080
02:00:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2388 -checkpoint 15 -np 4 -service
02:00:07:WU00:FS00:Started FahCore on PID 21868
02:00:07:WU00:FS00:Core PID:16832
02:00:07:WU00:FS00:FahCore 0xa4 started
02:00:08:WU00:FS00:0xa4:
02:00:08:WU00:FS00:0xa4:*------------------------------*
02:00:08:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:00:08:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:00:08:WU00:FS00:0xa4:Preparing to commence simulation
02:00:08:WU00:FS00:0xa4:- Looking at optimizations...
02:00:08:WU00:FS00:0xa4:- Created dyn
02:00:08:WU00:FS00:0xa4:- Files status OK
02:00:08:WU00:FS00:0xa4:- Expanded 824946 -> 1397768 (decompressed 169.4 percent)
02:00:08:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=824946 data_size=1397768, decompressed_data_size=1397768 diff=0
02:00:08:WU00:FS00:0xa4:- Digital signature verified
02:00:08:WU00:FS00:0xa4:Project: 9031 (Run 191, Clone 6, Gen 18)
02:00:08:WU00:FS00:0xa4:Assembly optimizations on if available.
02:00:08:WU00:FS00:0xa4:Entering M.D.
02:00:08:WU01:FS00:Upload complete
02:00:09:WU01:FS00:Server responded WORK_ACK (400)
02:00:09:WU01:FS00:Final credit estimate, 1947.00 points
02:00:09:WU01:FS00:Cleaning up
02:00:14:WU00:FS00:0xa4:Mapping NT from 4 to 4
02:00:14:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
02:01:58:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
02:03:42:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
02:05:26:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
02:07:10:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
02:08:53:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
02:10:37:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
02:12:22:WU00:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
02:14:12:WU00:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
02:15:57:WU00:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
02:17:37:WU00:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
02:19:20:WU00:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
02:21:02:WU00:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
02:22:44:WU00:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
02:24:24:WU00:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
02:26:07:WU00:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
02:27:52:WU00:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
02:29:38:WU00:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
02:31:27:WU00:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
02:33:14:WU00:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
02:35:05:WU00:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
02:36:46:WU00:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
02:38:28:WU00:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
02:40:09:WU00:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
02:41:48:WU00:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
02:43:28:WU00:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
02:45:11:WU00:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
02:46:56:WU00:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
02:48:39:WU00:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
02:50:21:WU00:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
02:52:03:WU00:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
02:53:45:WU00:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
02:55:28:WU00:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
02:57:12:WU00:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
02:58:55:WU00:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
03:00:37:WU00:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
03:02:20:WU00:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
03:04:03:WU00:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
03:05:47:WU00:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
03:07:28:WU00:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
03:09:10:WU00:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
03:10:52:WU00:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
03:12:35:WU00:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
03:14:19:WU00:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
03:16:02:WU00:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
03:17:45:WU00:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
03:19:26:WU00:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
03:21:08:WU00:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
03:22:49:WU00:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
03:24:30:WU00:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
03:26:12:WU00:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
03:27:53:WU00:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
03:29:35:WU00:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
03:31:16:WU00:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
03:32:59:WU00:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
03:34:41:WU00:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
03:36:25:WU00:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
03:38:05:WU00:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
03:39:46:WU00:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
03:41:27:WU00:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
03:43:10:WU00:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
03:44:51:WU00:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
03:46:32:WU00:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
03:48:15:WU00:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
03:49:57:WU00:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
03:51:39:WU00:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
03:53:21:WU00:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
03:55:03:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
03:56:44:WU00:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
03:58:26:WU00:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
04:00:08:WU00:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
04:01:52:WU00:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
04:03:33:WU00:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
04:05:15:WU00:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
04:06:55:WU00:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
04:08:36:WU00:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
04:10:17:WU00:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
04:11:59:WU00:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
04:13:39:WU00:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
04:15:21:WU00:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
04:17:04:WU00:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
04:18:46:WU00:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
04:20:29:WU00:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
04:22:11:WU00:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
04:23:51:WU00:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
04:25:32:WU00:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
04:27:13:WU00:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
04:28:54:WU00:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
04:30:37:WU00:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
04:32:20:WU00:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
04:34:09:WU00:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
04:35:49:WU00:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
04:37:29:WU00:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
04:39:09:WU00:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
04:40:50:WU00:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
04:42:30:WU00:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
04:44:11:WU00:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
04:45:53:WU00:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
04:47:36:WU00:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
04:49:18:WU00:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
04:49:19:WU01:FS00:Connecting to 171.67.108.45:8080
04:49:20:WU01:FS00:Assigned to work server 128.252.203.2
04:49:20:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.2
04:49:20:WU01:FS00:Connecting to 128.252.203.2:8080
04:49:21:WU01:FS00:Downloading 1.58MiB
04:49:21:WU01:FS00:Download complete
04:49:21:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11652 run:76 clone:0 gen:15 core:0xa4 unit:0x000000124c71bbb056f93fbc8f11e022
04:51:01:WU00:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
04:51:01:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
04:51:11:WU00:FS00:0xa4:
04:51:11:WU00:FS00:0xa4:Finished Work Unit:
04:51:11:WU00:FS00:0xa4:- Reading up to 811512 from "00/wudata_01.trr": Read 811512
04:51:11:WU00:FS00:0xa4:trr file hash check passed.
04:51:11:WU00:FS00:0xa4:- Reading up to 746120 from "00/wudata_01.xtc": Read 746120
04:51:11:WU00:FS00:0xa4:xtc file hash check passed.
04:51:11:WU00:FS00:0xa4:edr file hash check passed.
04:51:11:WU00:FS00:0xa4:logfile size: 23087
04:51:11:WU00:FS00:0xa4:Leaving Run
04:51:14:WU00:FS00:0xa4:- Writing 1583207 bytes of core data to disk...
04:51:14:WU00:FS00:0xa4:Done: 1582695 -> 1537813 (compressed to 97.1 percent)
04:51:14:WU00:FS00:0xa4:  ... Done.
04:51:14:WU00:FS00:0xa4:- Shutting down core
04:51:14:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
04:51:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:51:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9031 run:191 clone:6 gen:18 core:0xa4 unit:0x00000014ab436c9e569834ea53d6f33e
04:51:15:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
04:51:15:WU00:FS00:Connecting to 171.67.108.158:8080
04:51:15:WU01:FS00:Starting
04:51:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Robby/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 2388 -checkpoint 15 -np 4 -service
04:51:15:WU01:FS00:Started FahCore on PID 23076
04:51:15:WU01:FS00:Core PID:23340
04:51:15:WU01:FS00:FahCore 0xa4 started
04:51:16:WU01:FS00:0xa4:
04:51:16:WU01:FS00:0xa4:*------------------------------*
04:51:16:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
04:51:16:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:51:16:WU01:FS00:0xa4:Preparing to commence simulation
04:51:16:WU01:FS00:0xa4:- Looking at optimizations...
04:51:16:WU01:FS00:0xa4:- Created dyn
04:51:16:WU01:FS00:0xa4:- Files status OK
04:51:16:WU01:FS00:0xa4:- Expanded 1658727 -> 3106984 (decompressed 187.3 percent)
04:51:16:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1658727 data_size=3106984, decompressed_data_size=3106984 diff=0
04:51:16:WU01:FS00:0xa4:- Digital signature verified
04:51:16:WU01:FS00:0xa4:Project: 11652 (Run 76, Clone 0, Gen 15)
04:51:16:WU01:FS00:0xa4:Assembly optimizations on if available.
04:51:16:WU01:FS00:0xa4:Entering M.D.
04:51:16:WU00:FS00:Upload complete
04:51:17:WU00:FS00:Server responded WORK_ACK (400)
04:51:17:WU00:FS00:Final credit estimate, 1488.00 points
04:51:17:WU00:FS00:Cleaning up
04:51:22:WU01:FS00:0xa4:Mapping NT from 4 to 4
04:51:22:WU01:FS00:0xa4:Completed 0 out of 1250000 steps  (0%)
04:59:29:WU01:FS00:0xa4:Completed 12500 out of 1250000 steps  (1%)
05:07:30:WU01:FS00:0xa4:Completed 25000 out of 1250000 steps  (2%)
05:16:13:WU01:FS00:0xa4:Completed 37500 out of 1250000 steps  (3%)
05:24:57:WU01:FS00:0xa4:Completed 50000 out of 1250000 steps  (4%)
05:33:40:WU01:FS00:0xa4:Completed 62500 out of 1250000 steps  (5%)
05:42:21:WU01:FS00:0xa4:Completed 75000 out of 1250000 steps  (6%)
05:51:03:WU01:FS00:0xa4:Completed 87500 out of 1250000 steps  (7%)
05:59:45:WU01:FS00:0xa4:Completed 100000 out of 1250000 steps  (8%)
06:08:31:WU01:FS00:0xa4:Completed 112500 out of 1250000 steps  (9%)
06:17:17:WU01:FS00:0xa4:Completed 125000 out of 1250000 steps  (10%)
06:26:04:WU01:FS00:0xa4:Completed 137500 out of 1250000 steps  (11%)
06:34:52:WU01:FS00:0xa4:Completed 150000 out of 1250000 steps  (12%)
06:43:40:WU01:FS00:0xa4:Completed 162500 out of 1250000 steps  (13%)
06:52:25:WU01:FS00:0xa4:Completed 175000 out of 1250000 steps  (14%)
07:01:08:WU01:FS00:0xa4:Completed 187500 out of 1250000 steps  (15%)
07:10:05:WU01:FS00:0xa4:Completed 200000 out of 1250000 steps  (16%)
07:18:48:WU01:FS00:0xa4:Completed 212500 out of 1250000 steps  (17%)
07:27:31:WU01:FS00:0xa4:Completed 225000 out of 1250000 steps  (18%)
07:36:18:WU01:FS00:0xa4:Completed 237500 out of 1250000 steps  (19%)
07:45:07:WU01:FS00:0xa4:Completed 250000 out of 1250000 steps  (20%)
07:53:51:WU01:FS00:0xa4:Completed 262500 out of 1250000 steps  (21%)
08:02:41:WU01:FS00:0xa4:Completed 275000 out of 1250000 steps  (22%)
08:11:41:WU01:FS00:0xa4:Completed 287500 out of 1250000 steps  (23%)
08:20:46:WU01:FS00:0xa4:Completed 300000 out of 1250000 steps  (24%)
08:29:45:WU01:FS00:0xa4:Completed 312500 out of 1250000 steps  (25%)
08:38:43:WU01:FS00:0xa4:Completed 325000 out of 1250000 steps  (26%)
08:47:42:WU01:FS00:0xa4:Completed 337500 out of 1250000 steps  (27%)
08:56:36:WU01:FS00:0xa4:Completed 350000 out of 1250000 steps  (28%)
09:05:27:WU01:FS00:0xa4:Completed 362500 out of 1250000 steps  (29%)
09:14:20:WU01:FS00:0xa4:Completed 375000 out of 1250000 steps  (30%)
09:23:15:WU01:FS00:0xa4:Completed 387500 out of 1250000 steps  (31%)
09:32:14:WU01:FS00:0xa4:Completed 400000 out of 1250000 steps  (32%)
09:41:06:WU01:FS00:0xa4:Completed 412500 out of 1250000 steps  (33%)
09:49:59:WU01:FS00:0xa4:Completed 425000 out of 1250000 steps  (34%)
09:58:52:WU01:FS00:0xa4:Completed 437500 out of 1250000 steps  (35%)
10:07:52:WU01:FS00:0xa4:Completed 450000 out of 1250000 steps  (36%)
10:16:46:WU01:FS00:0xa4:Completed 462500 out of 1250000 steps  (37%)
10:25:38:WU01:FS00:0xa4:Completed 475000 out of 1250000 steps  (38%)
10:34:33:WU01:FS00:0xa4:Completed 487500 out of 1250000 steps  (39%)
10:43:30:WU01:FS00:0xa4:Completed 500000 out of 1250000 steps  (40%)
10:52:31:WU01:FS00:0xa4:Completed 512500 out of 1250000 steps  (41%)
11:01:37:WU01:FS00:0xa4:Completed 525000 out of 1250000 steps  (42%)
11:10:47:WU01:FS00:0xa4:Completed 537500 out of 1250000 steps  (43%)
11:19:53:WU01:FS00:0xa4:Completed 550000 out of 1250000 steps  (44%)
11:28:52:WU01:FS00:0xa4:Completed 562500 out of 1250000 steps  (45%)
11:37:43:WU01:FS00:0xa4:Completed 575000 out of 1250000 steps  (46%)
11:46:31:WU01:FS00:0xa4:Completed 587500 out of 1250000 steps  (47%)
11:55:14:WU01:FS00:0xa4:Completed 600000 out of 1250000 steps  (48%)
12:03:56:WU01:FS00:0xa4:Completed 612500 out of 1250000 steps  (49%)
12:12:40:WU01:FS00:0xa4:Completed 625000 out of 1250000 steps  (50%)
12:21:21:WU01:FS00:0xa4:Completed 637500 out of 1250000 steps  (51%)
12:30:04:WU01:FS00:0xa4:Completed 650000 out of 1250000 steps  (52%)
12:38:48:WU01:FS00:0xa4:Completed 662500 out of 1250000 steps  (53%)
12:47:31:WU01:FS00:0xa4:Completed 675000 out of 1250000 steps  (54%)
12:56:14:WU01:FS00:0xa4:Completed 687500 out of 1250000 steps  (55%)
13:04:56:WU01:FS00:0xa4:Completed 700000 out of 1250000 steps  (56%)
13:13:41:WU01:FS00:0xa4:Completed 712500 out of 1250000 steps  (57%)
13:22:22:WU01:FS00:0xa4:Completed 725000 out of 1250000 steps  (58%)
13:31:03:WU01:FS00:0xa4:Completed 737500 out of 1250000 steps  (59%)
13:39:48:WU01:FS00:0xa4:Completed 750000 out of 1250000 steps  (60%)
13:48:32:WU01:FS00:0xa4:Completed 762500 out of 1250000 steps  (61%)
13:57:14:WU01:FS00:0xa4:Completed 775000 out of 1250000 steps  (62%)
14:05:58:WU01:FS00:0xa4:Completed 787500 out of 1250000 steps  (63%)
14:14:41:WU01:FS00:0xa4:Completed 800000 out of 1250000 steps  (64%)
14:23:24:WU01:FS00:0xa4:Completed 812500 out of 1250000 steps  (65%)
14:32:07:WU01:FS00:0xa4:Completed 825000 out of 1250000 steps  (66%)
14:40:53:WU01:FS00:0xa4:Completed 837500 out of 1250000 steps  (67%)
14:49:39:WU01:FS00:0xa4:Completed 850000 out of 1250000 steps  (68%)
14:58:21:WU01:FS00:0xa4:Completed 862500 out of 1250000 steps  (69%)
15:07:02:WU01:FS00:0xa4:Completed 875000 out of 1250000 steps  (70%)
15:15:44:WU01:FS00:0xa4:Completed 887500 out of 1250000 steps  (71%)
15:24:29:WU01:FS00:0xa4:Completed 900000 out of 1250000 steps  (72%)
15:33:19:WU01:FS00:0xa4:Completed 912500 out of 1250000 steps  (73%)
15:42:23:WU01:FS00:0xa4:Completed 925000 out of 1250000 steps  (74%)
15:51:24:WU01:FS00:0xa4:Completed 937500 out of 1250000 steps  (75%)
16:00:18:WU01:FS00:0xa4:Completed 950000 out of 1250000 steps  (76%)
16:09:09:WU01:FS00:0xa4:Completed 962500 out of 1250000 steps  (77%)
16:18:00:WU01:FS00:0xa4:Completed 975000 out of 1250000 steps  (78%)
16:26:54:WU01:FS00:0xa4:Completed 987500 out of 1250000 steps  (79%)
16:35:53:WU01:FS00:0xa4:Completed 1000000 out of 1250000 steps  (80%)
16:44:41:WU01:FS00:0xa4:Completed 1012500 out of 1250000 steps  (81%)
16:53:27:WU01:FS00:0xa4:Completed 1025000 out of 1250000 steps  (82%)
17:02:14:WU01:FS00:0xa4:Completed 1037500 out of 1250000 steps  (83%)
17:11:04:WU01:FS00:0xa4:Completed 1050000 out of 1250000 steps  (84%)
17:19:51:WU01:FS00:0xa4:Completed 1062500 out of 1250000 steps  (85%)
17:28:42:WU01:FS00:0xa4:Completed 1075000 out of 1250000 steps  (86%)
17:37:28:WU01:FS00:0xa4:Completed 1087500 out of 1250000 steps  (87%)
17:46:36:WU01:FS00:0xa4:Completed 1100000 out of 1250000 steps  (88%)
17:55:31:WU01:FS00:0xa4:Completed 1112500 out of 1250000 steps  (89%)
18:04:20:WU01:FS00:0xa4:Completed 1125000 out of 1250000 steps  (90%)
18:13:10:WU01:FS00:0xa4:Completed 1137500 out of 1250000 steps  (91%)
18:21:55:WU01:FS00:0xa4:Completed 1150000 out of 1250000 steps  (92%)
18:30:51:WU01:FS00:0xa4:Completed 1162500 out of 1250000 steps  (93%)
18:39:38:WU01:FS00:0xa4:Completed 1175000 out of 1250000 steps  (94%)
18:48:23:WU01:FS00:0xa4:Completed 1187500 out of 1250000 steps  (95%)
18:57:04:WU01:FS00:0xa4:Completed 1200000 out of 1250000 steps  (96%)
19:05:46:WU01:FS00:0xa4:Completed 1212500 out of 1250000 steps  (97%)
19:14:30:WU01:FS00:0xa4:Completed 1225000 out of 1250000 steps  (98%)
19:23:12:WU01:FS00:0xa4:Completed 1237500 out of 1250000 steps  (99%)
19:31:51:WU01:FS00:0xa4:Completed 1250000 out of 1250000 steps  (100%)
19:31:52:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
19:32:02:WU01:FS00:0xa4:
19:32:02:WU01:FS00:0xa4:Finished Work Unit:
19:32:02:WU01:FS00:0xa4:- Reading up to 5199732 from "01/wudata_01.trr": Read 5199732
19:32:02:WU01:FS00:0xa4:trr file hash check passed.
19:32:02:WU01:FS00:0xa4:- Reading up to 11171820 from "01/wudata_01.xtc": Read 11171820
19:32:02:WU01:FS00:0xa4:xtc file hash check passed.
19:32:02:WU01:FS00:0xa4:edr file hash check passed.
19:32:02:WU01:FS00:0xa4:logfile size: 24298
19:32:02:WU01:FS00:0xa4:Leaving Run
19:32:07:WU01:FS00:0xa4:- Writing 16398254 bytes of core data to disk...
19:32:10:WU01:FS00:0xa4:Done: 16397742 -> 16041018 (compressed to 97.8 percent)
19:32:10:WU01:FS00:0xa4:  ... Done.
19:32:13:WU01:FS00:0xa4:Error deleting frame files
19:32:13:WU01:FS00:0xa4:- Shutting down core
19:32:13:WU01:FS00:0xa4:Folding@home Core Shutdown: FILE_IO_ERROR
22:35:34:WARNING:Console control signal 6 on PID 2388
22:35:34:Exiting, please wait. . .
22:35:34:Service shutdown requested
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Re: Possible Issues with 11652 76, 0, 15
Probably the same issue (or a consequence of the issue) as in this thread : viewtopic.php?f=96&t=28715
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Post by artoar_11 »
Whether the problem is related to the service?
Robby_Firefox
Hi toTOW and artoar_11
Thanks for the ideas. The fixes I did appeared to stop the issue. It is early Tuesday morning ~4AM Z-time, and all appears to be fine. Given I had more time this evening here (USA Central Time), did some spring cleaning of my computer's board. Cooled the CPU down by about 10C and should make it more stable. Am considering adding more memory and a better cooling fan...
Thanks,
Robby
If you follow the linjk given by toTOW in the second post (above) you'll find a long discussion of related issues. If you are able to contribute a clear definion of the fix you applied, it would help a lot of people.
My general impression is that it is limited to a small percentage of WUs in a few projects, which makes reproducing the problem or saying the problem was fixed difficult to determine.
