[ask] below 20 scores
i got under 20 points several times for now, the most recent were on 30th May at 4:00 and 7:00 (according my stats page at Kakao : http://kakaostats.com/up.php?u=852289), the previous ones were 20th May 10:00 and 21st May 1:00. i'm just curious from which WUs did they come from?
ChelseaOilman
Re: [ask] below 20 scores
There are WUs with point values as low as 15 points, p4400 - p4417. Just go to the project summary page to see all the point values. The link is at the top of this page.
Though, your problem seems to be EUEs.
Hi siadi (team 1630),
Your WU (P4532 R2 C2 G8) was added to the stats database on 2008-05-16 04:05:32 for 70.5 points of credit.
Your WU (P4551 R1 C19 G3) was added to the stats database on 2008-05-29 02:05:36 for 84.69 points of credit.
Your WU (P4551 R30 C27 G5) was added to the stats database on 2008-05-29 22:05:37 for 0 points of credit.
Your WU (P4549 R67 C67 G0) was added to the stats database on 2008-05-30 02:05:36 for 119.3 points of credit.
ic ic.. well it's been a while and i already contribute more WUs than those which not finished or zero-pointed. so i think it's ok coz i don't monitor my farm 24/7 myself. thx pal!
