Error FAULTY Projects 13105 & 13106
More Core 21 Bad Work Units. Cards are AMD R9 290X & I am not overclocking. Driver info below.
Going on now for over the last 8 Days.
BAD_WORK_UNIT
error:FAULTY project:13106 run:2 clone:42 gen:20 core:0x21
error:FAULTY project:13105 run:3 clone:8 gen:69 core:0x21
error:FAULTY project:13105 run:6 clone:18 gen:85 core:0x21
Maybe for the AMD GPUs 16.3.2 is not the best driver for Folding.
I will wait for the current tasks to complete and then update to the Hotfix Version 16.4.1.
When you remove the 16.3.2 Driver and Software is does not remove the Vulkan Drivers.
You have to do this separately under "Programs and Features" Vulkan
I removed Dope from the below line
Doh! the Driver made no Difference.
error:FAULTY project:13106 run:2 clone:21 gen:61 core:0x21
BAD_WORK_UNIT
US Army Retired | Folding@EVGA The Number One Team in the Folding@Home Community.
Re: Error FAULTY Projects 13105 & 13106
Log File:
Mod edit: added Code tags to wrap the log file
******************************* Date: 2016-04-09 ******************
07:09:44:WU02:FS00:Connecting to 171.67.108.45:80
07:09:44:WU02:FS00:Assigned to work server 171.67.108.144
07:09:44:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Hawaii [Radeon R9 200/300X Series] from 171.67.108.144
07:09:44:WU02:FS00:Connecting to 171.67.108.144:8080
07:09:58:WU02:FS00:Downloading 8.24MiB
07:10:02:WU02:FS00:Download complete
07:10:02:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13106 run:2 clone:21 gen:61 core:0x21 unit:0x00000049ab436c9056be6927d17247f0
07:12:00:WU02:FS00:Starting
07:12:00:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 3404 -checkpoint 15 -gpu 0 -gpu-vendor ati
07:12:00:WU02:FS00:Started FahCore on PID 4876
07:12:00:WU02:FS00:Core PID:4568
07:12:00:WU02:FS00:FahCore 0x21 started
07:12:00:WU02:FS00:0x21:*********************** Log Started 2016-04-09T07:12:00Z ***********************
07:12:00:WU02:FS00:0x21:Project: 13106 (Run 2, Clone 21, Gen 61)
07:12:00:WU02:FS00:0x21:Unit: 0x00000049ab436c9056be6927d17247f0
07:12:00:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
07:12:00:WU02:FS00:0x21:Machine: 0
07:12:00:WU02:FS00:0x21:Reading tar file core.xml
07:12:00:WU02:FS00:0x21:Reading tar file integrator.xml
07:12:00:WU02:FS00:0x21:Reading tar file state.xml
07:12:02:WU02:FS00:0x21:Reading tar file system.xml
07:12:02:WU02:FS00:0x21:Digital signatures verified
07:12:02:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
07:12:02:WU02:FS00:0x21:Version 0.0.17
07:12:27:WU02:FS00:0x21:Completed 0 out of 520000 steps (0%)
07:12:27:WU02:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:13:22:WU02:FS00:0x21:Completed 5200 out of 520000 steps (1%)
07:13:42:WU02:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
07:15:32:WU02:FS00:0x21:Completed 10400 out of 520000 steps (2%)
07:16:23:WU02:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
07:17:18:WU02:FS00:0x21:Completed 5200 out of 520000 steps (1%)
07:18:14:WU02:FS00:0x21:Completed 10400 out of 520000 steps (2%)
07:18:51:WU02:FS00:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
07:18:51:WU02:FS00:0x21:ERROR:Max Retries Reached
07:18:51:WU02:FS00:0x21:Saving result file logfile_01.txt
07:18:51:WU02:FS00:0x21:Saving result file badstate-0.xml
07:18:55:WU02:FS00:0x21:Saving result file badstate-1.xml
07:19:00:WU02:FS00:0x21:Saving result file badstate-2.xml
07:19:04:WU02:FS00:0x21:Saving result file log.txt
07:19:04:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
07:19:05:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:19:05:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:13106 run:2 clone:21 gen:61 core:0x21 unit:0x00000049ab436c9056be6927d17247f0
07:19:05:WU02:FS00:Uploading 24.41KiB to 171.67.108.144
07:19:05:WU02:FS00:Connecting to 171.67.108.144:8080
07:19:06:WU02:FS00:Upload complete
07:19:06:WU02:FS00:Server responded WORK_ACK (400)
07:19:06:WU02:FS00:Cleaning upUS Army Retired | Folding@EVGA The Number One Team in the Folding@Home Community.
All four of the WU's you listed have since been completed successfully by other folders.
OK and what is it that you are saying then?Joe_H wrote:All four of the WU's you listed have since been completed successfully by other folders.
http://forums.evga.com/FindPost/2467630 My Post
Other Here: http://forums.evga.com/EVGA-Folding-Yea ... px#2467630
http://forums.evga.com/FindPost/2467759
http://forums.evga.com/FindPost/2467824
It means that the issue is not in the WU, but (maybe) with your hardware or drivers ...
Sorry no it is not my hardware Only Projects 13105 & 13106 on a High End Graphics Cards Or the New Poor Drivers from AMDtoTOW wrote:It means that the issue is not in the WU, but (maybe) with your hardware or drivers ...
http://folding.extremeoverclocking.com/ ... =&u=638326
Yes we all know this, I call anything to do with Folding Stanford now.Joe_H wrote:P.S. I am not Stanford, nor are any of the moderators here.
We all had Core 21 issues before, took awhile but Stanford did come around and post as so and even pulled them back for a while.
Also last time it was Only on the NVIDIA Side and not on the AMD Side, now it seems to be on Both Sides NVIDIA & AMD/ATI.
Someone recommended DDU recently and it seemed to do what I wanted.bcavnaugh wrote:When you remove the 16.3.2 Driver and Software is does not remove the Vulkan Drivers.
When you remove the 16.3.2 Driver and Software is does not remove the Vulkan Drivers.bruce wrote:Someone recommended DDU recently and it seemed to do what I wanted.bcavnaugh wrote:When you remove the 16.3.2 Driver and Software is does not remove the Vulkan Drivers.
Dope the Driver made no Difference.
I rechecked the projects 13105, _06 listed above
We have very limited ability to check who has what hardware (in case it might have something to do with hardware or drivers) but from what I can see, they were completed by folks who have AMD GPUs. I.e. - they don't happen to work better on NV than AMD.
Some have Windows and some have Linux.
A couple were completed by your teammates, so hopefully you'll get additional information from them if they read your team forum.
