Hello,
Quick question:
Is it better/faster to run one WU on multiple cores of the CPU or let each core run one WU?
Thank you for your help
Greetings from Austria
Quick help with CPU settings
1 core 1WU or 1CPU 1 Wu
One WU per CPU is usually better (FAH can use all available cores to work on a single WU).
Re: Quick help with CPU settings
Thank you toTOW for the answer!
