Stuck on Send 99.29% WU 10488
HappyElvis
Post by HappyElvis »
This work unit took at least 30 hours to finish I didn't tally exactly.
But when I checked on it - it was sitting at 99.29% send
For safety sake I copied the actual finished Work folder with the finished 12.59MB .DAT file it has failed to upload
so all this gpu time wont be wasted if the client can't recover maybe I can send it to you manually or something.
So heres the details:
WU00 is stuck - Another WU has since started as WU01 on the same folding slot.
Heres the header of my log file:
*********************** Log Started 2016-03-14T05:26:57Z ***********************
05:26:57:************************* Folding@home Client *************************
05:26:57:      Website: http://folding.stanford.edu/
05:26:57:    Copyright: (c) 2009-2014 Stanford University
05:26:57:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:26:57:         Args: --open-web-control
05:26:57:       Config: <none>
05:26:57:******************************** Build ********************************
05:26:57:      Version: 7.4.4
05:26:57:         Date: Mar 4 2014
05:26:57:         Time: 20:26:54
05:26:57:      SVN Rev: 4130
05:26:57:       Branch: fah/trunk/client
05:26:57:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
05:26:57:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
05:26:57:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
05:26:57:     Platform: win32 XP
05:26:57:         Bits: 32
05:26:57:         Mode: Release
05:26:57:******************************* System ********************************
05:26:57:          CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
05:26:57:       CPU ID: AuthenticAMD Family 15 Model 75 Stepping 2
05:26:57:         CPUs: 2
05:26:57:       Memory: 3.00GiB
05:26:57:  Free Memory: 2.14GiB
05:26:57:      Threads: WINDOWS_THREADS
05:26:57:   OS Version: 6.1
05:26:57:  Has Battery: false
05:26:57:   On Battery: false
05:26:57:   UTC Offset: -5
05:26:57:          PID: 644
05:26:57:          CWD: C:/Users/The_Brat/AppData/Roaming/FAHClient
05:26:57:           OS: Windows 7 Ultimate
05:26:57:      OS Arch: AMD64
05:26:57:         GPUs: 3
05:26:57:        GPU 0: UNSUPPORTED: RS4xx PCI Express Port [ext gfx]
05:26:57:        GPU 1: UNSUPPORTED: RC4xx/RS4xx PCI Express Port 3
05:26:57:        GPU 2: NVIDIA:2 GF114 [GeForce GTX 560 Ti]
05:26:57:         CUDA: 2.1
05:26:57:  CUDA Driver: 8000
05:26:57:Win32 Service: false
05:26:57:***********************************************************************
05:26:57:<config>
05:26:57:  <!-- Folding Slots -->
05:26:57:</config>
05:26:57:Connecting to assign-GPU.stanford.edu:80
05:26:57:Updated GPUs.txt
05:26:57:Read GPUs.txt
05:26:57:Trying to access database...
05:26:58:Successfully acquired database lock
Since other WU have come and gone before this got stuck I'l fast forward to the end of the log:
00:06:21:WU00:FS01:0x18:Completed 0 out of 5000000 steps (0%)
00:06:21:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:09:59:Saving configuration to config.xml
00:09:59:<config>
00:09:59:  <!-- Network -->
00:09:59:  <proxy v=':8080'/>
00:09:59:
00:09:59:  <!-- Slot Control -->
00:09:59:  <power v='full'/>
00:09:59:
00:09:59:  <!-- User Information -->
00:09:59:  <passkey v='********************************'/>
00:09:59:  <team v='86565'/>
00:09:59:  <user v='Randall_Franklin_Bruno_Reagan_Kennedy'/>
00:09:59:
00:09:59:  <!-- Folding Slots -->
00:09:59:  <slot id='1' type='GPU'/>
00:09:59:</config>
00:27:22:WU00:FS01:0x18:Completed 50000 out of 5000000 steps (1%)
00:47:49:WU00:FS01:0x18:Completed 100000 out of 5000000 steps (2%)
01:08:55:WU00:FS01:0x18:Completed 150000 out of 5000000 steps (3%)
01:29:22:WU00:FS01:0x18:Completed 200000 out of 5000000 steps (4%)
01:49:48:WU00:FS01:0x18:Completed 250000 out of 5000000 steps (5%)
02:10:54:WU00:FS01:0x18:Completed 300000 out of 5000000 steps (6%)
02:31:22:WU00:FS01:0x18:Completed 350000 out of 5000000 steps (7%)
02:52:27:WU00:FS01:0x18:Completed 400000 out of 5000000 steps (8%)
03:12:54:WU00:FS01:0x18:Completed 450000 out of 5000000 steps (9%)
03:33:22:WU00:FS01:0x18:Completed 500000 out of 5000000 steps (10%)
03:54:27:WU00:FS01:0x18:Completed 550000 out of 5000000 steps (11%)
04:14:54:WU00:FS01:0x18:Completed 600000 out of 5000000 steps (12%)
04:36:00:WU00:FS01:0x18:Completed 650000 out of 5000000 steps (13%)
04:56:28:WU00:FS01:0x18:Completed 700000 out of 5000000 steps (14%)
05:16:55:WU00:FS01:0x18:Completed 750000 out of 5000000 steps (15%)
05:38:02:WU00:FS01:0x18:Completed 800000 out of 5000000 steps (16%)
05:58:30:WU00:FS01:0x18:Completed 850000 out of 5000000 steps (17%)
******************************* Date: 2016-03-16 *******************************
06:19:37:WU00:FS01:0x18:Completed 900000 out of 5000000 steps (18%)
06:40:04:WU00:FS01:0x18:Completed 950000 out of 5000000 steps (19%)
07:00:32:WU00:FS01:0x18:Completed 1000000 out of 5000000 steps (20%)
07:21:39:WU00:FS01:0x18:Completed 1050000 out of 5000000 steps (21%)
07:42:07:WU00:FS01:0x18:Completed 1100000 out of 5000000 steps (22%)
08:03:16:WU00:FS01:0x18:Completed 1150000 out of 5000000 steps (23%)
08:23:47:WU00:FS01:0x18:Completed 1200000 out of 5000000 steps (24%)
08:44:18:WU00:FS01:0x18:Completed 1250000 out of 5000000 steps (25%)
09:05:31:WU00:FS01:0x18:Completed 1300000 out of 5000000 steps (26%)
09:25:59:WU00:FS01:0x18:Completed 1350000 out of 5000000 steps (27%)
09:47:04:WU00:FS01:0x18:Completed 1400000 out of 5000000 steps (28%)
10:07:32:WU00:FS01:0x18:Completed 1450000 out of 5000000 steps (29%)
10:13:45:FS01:Finishing
10:28:00:WU00:FS01:0x18:Completed 1500000 out of 5000000 steps (30%)
10:49:06:WU00:FS01:0x18:Completed 1550000 out of 5000000 steps (31%)
11:09:33:WU00:FS01:0x18:Completed 1600000 out of 5000000 steps (32%)
11:30:38:WU00:FS01:0x18:Completed 1650000 out of 5000000 steps (33%)
11:51:05:WU00:FS01:0x18:Completed 1700000 out of 5000000 steps (34%)
12:11:32:WU00:FS01:0x18:Completed 1750000 out of 5000000 steps (35%)
12:32:37:WU00:FS01:0x18:Completed 1800000 out of 5000000 steps (36%)
12:53:04:WU00:FS01:0x18:Completed 1850000 out of 5000000 steps (37%)
13:14:10:WU00:FS01:0x18:Completed 1900000 out of 5000000 steps (38%)
13:34:37:WU00:FS01:0x18:Completed 1950000 out of 5000000 steps (39%)
13:55:05:WU00:FS01:0x18:Completed 2000000 out of 5000000 steps (40%)
14:16:11:WU00:FS01:0x18:Completed 2050000 out of 5000000 steps (41%)
14:34:50:55:127.0.0.1:New Web connection
14:36:42:WU00:FS01:0x18:Completed 2100000 out of 5000000 steps (42%)
14:57:48:WU00:FS01:0x18:Completed 2150000 out of 5000000 steps (43%)
15:18:15:WU00:FS01:0x18:Completed 2200000 out of 5000000 steps (44%)
15:38:42:WU00:FS01:0x18:Completed 2250000 out of 5000000 steps (45%)
15:59:48:WU00:FS01:0x18:Completed 2300000 out of 5000000 steps (46%)
16:20:15:WU00:FS01:0x18:Completed 2350000 out of 5000000 steps (47%)
16:41:20:WU00:FS01:0x18:Completed 2400000 out of 5000000 steps (48%)
17:01:47:WU00:FS01:0x18:Completed 2450000 out of 5000000 steps (49%)
17:22:14:WU00:FS01:0x18:Completed 2500000 out of 5000000 steps (50%)
17:43:21:WU00:FS01:0x18:Completed 2550000 out of 5000000 steps (51%)
18:03:48:WU00:FS01:0x18:Completed 2600000 out of 5000000 steps (52%)
18:24:54:WU00:FS01:0x18:Completed 2650000 out of 5000000 steps (53%)
18:45:20:WU00:FS01:0x18:Completed 2700000 out of 5000000 steps (54%)
19:05:47:WU00:FS01:0x18:Completed 2750000 out of 5000000 steps (55%)
19:26:53:WU00:FS01:0x18:Completed 2800000 out of 5000000 steps (56%)
19:47:20:WU00:FS01:0x18:Completed 2850000 out of 5000000 steps (57%)
20:08:26:WU00:FS01:0x18:Completed 2900000 out of 5000000 steps (58%)
20:28:54:WU00:FS01:0x18:Completed 2950000 out of 5000000 steps (59%)
20:49:22:WU00:FS01:0x18:Completed 3000000 out of 5000000 steps (60%)
21:10:28:WU00:FS01:0x18:Completed 3050000 out of 5000000 steps (61%)
21:30:55:WU00:FS01:0x18:Completed 3100000 out of 5000000 steps (62%)
21:52:01:WU00:FS01:0x18:Completed 3150000 out of 5000000 steps (63%)
22:12:27:WU00:FS01:0x18:Completed 3200000 out of 5000000 steps (64%)
22:32:54:WU00:FS01:0x18:Completed 3250000 out of 5000000 steps (65%)
22:54:00:WU00:FS01:0x18:Completed 3300000 out of 5000000 steps (66%)
23:14:27:WU00:FS01:0x18:Completed 3350000 out of 5000000 steps (67%)
23:35:32:WU00:FS01:0x18:Completed 3400000 out of 5000000 steps (68%)
23:55:59:WU00:FS01:0x18:Completed 3450000 out of 5000000 steps (69%)
00:16:26:WU00:FS01:0x18:Completed 3500000 out of 5000000 steps (70%)
00:37:32:WU00:FS01:0x18:Completed 3550000 out of 5000000 steps (71%)
******************************* Date: 2016-03-17 *******************************
00:58:00:WU00:FS01:0x18:Completed 3600000 out of 5000000 steps (72%)
01:19:04:WU00:FS01:0x18:Completed 3650000 out of 5000000 steps (73%)
01:39:31:WU00:FS01:0x18:Completed 3700000 out of 5000000 steps (74%)
01:59:57:WU00:FS01:0x18:Completed 3750000 out of 5000000 steps (75%)
02:21:02:WU00:FS01:0x18:Completed 3800000 out of 5000000 steps (76%)
02:41:30:WU00:FS01:0x18:Completed 3850000 out of 5000000 steps (77%)
03:02:36:WU00:FS01:0x18:Completed 3900000 out of 5000000 steps (78%)
03:23:03:WU00:FS01:0x18:Completed 3950000 out of 5000000 steps (79%)
03:43:30:WU00:FS01:0x18:Completed 4000000 out of 5000000 steps (80%)
04:04:35:WU00:FS01:0x18:Completed 4050000 out of 5000000 steps (81%)
04:25:02:WU00:FS01:0x18:Completed 4100000 out of 5000000 steps (82%)
04:46:09:WU00:FS01:0x18:Completed 4150000 out of 5000000 steps (83%)
05:06:36:WU00:FS01:0x18:Completed 4200000 out of 5000000 steps (84%)
05:27:03:WU00:FS01:0x18:Completed 4250000 out of 5000000 steps (85%)
05:48:09:WU00:FS01:0x18:Completed 4300000 out of 5000000 steps (86%)
06:08:36:WU00:FS01:0x18:Completed 4350000 out of 5000000 steps (87%)
06:29:42:WU00:FS01:0x18:Completed 4400000 out of 5000000 steps (88%)
06:50:08:WU00:FS01:0x18:Completed 4450000 out of 5000000 steps (89%)
07:10:35:WU00:FS01:0x18:Completed 4500000 out of 5000000 steps (90%)
07:31:41:WU00:FS01:0x18:Completed 4550000 out of 5000000 steps (91%)
07:52:08:WU00:FS01:0x18:Completed 4600000 out of 5000000 steps (92%)
08:13:14:WU00:FS01:0x18:Completed 4650000 out of 5000000 steps (93%)
08:33:41:WU00:FS01:0x18:Completed 4700000 out of 5000000 steps (94%)
08:54:08:WU00:FS01:0x18:Completed 4750000 out of 5000000 steps (95%)
09:15:14:WU00:FS01:0x18:Completed 4800000 out of 5000000 steps (96%)
09:35:42:WU00:FS01:0x18:Completed 4850000 out of 5000000 steps (97%)
09:56:48:WU00:FS01:0x18:Completed 4900000 out of 5000000 steps (98%)
10:17:16:WU00:FS01:0x18:Completed 4950000 out of 5000000 steps (99%)
10:37:42:WU00:FS01:0x18:Completed 5000000 out of 5000000 steps (100%)
10:38:21:WU00:FS01:0x18:Saving result file logfile_01.txt
10:38:22:WU00:FS01:0x18:Saving result file checkpointState.xml
10:38:28:WU00:FS01:0x18:Saving result file checkpt.crc
10:38:28:WU00:FS01:0x18:Saving result file log.txt
10:38:28:WU00:FS01:0x18:Saving result file positions.xtc
10:38:33:WU00:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
10:38:34:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:38:34:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:10488 run:2 clone:2 gen:228 core:0x18 unit:0x00000121538b3dbb54af0ac8b58f3fe8
10:38:34:WU00:FS01:Uploading 12.59MiB to 140.163.4.235
10:38:34:WU00:FS01:Connecting to 140.163.4.235:8080
10:38:40:WU00:FS01:Upload 9.93%
10:38:46:WU00:FS01:Upload 20.35%
10:38:52:WU00:FS01:Upload 30.78%
10:38:58:WU00:FS01:Upload 41.20%
10:39:04:WU00:FS01:Upload 52.13%
10:39:10:WU00:FS01:Upload 62.05%
10:39:16:WU00:FS01:Upload 71.49%
10:39:22:WU00:FS01:Upload 80.92%
10:39:28:WU00:FS01:Upload 90.35%
10:39:34:WU00:FS01:Upload 99.29%
Thanks, Elvis
Re: Stuck on Send 99.29% WU 10488
The folding client has either retried the WU upload since you posted your log, or the acknowledgement packet was dropped by the network somewhere between the WS and your system. The WU has been successfully submitted:
Hi Randall_Franklin_Bruno_Reagan_Kennedy (team 86565),
Your WU (P10488 R2 C2 G228) was added to the stats database on 2016-03-17 04:10:16 for 46769.2 points of credit.
HappyElvis
Thanks, it's still stuck so iquit client and removed manually.
Back to folding.
