WU Stuck On Send
StarOfDoom
WU Stuck On Send
Post by StarOfDoom »
Hello all!
I recently started up F&H again after taking quite a long break, but I have a slight issue. For whatever reason, my first GPU WU refuses to send. It has 14 attempts, and just sits there at 100% (It's not the smallest WU either, took about 30 hours to complete). Is there any way to fix this? Thanks
Re: WU Stuck On Send
We need additional information to be able to help with your upload problem. The Welcome topic - viewtopic.php?f=61&t=26036 - provides information on how to access and post relevant portions of your log file. In particular, the first 100 or so lines of the log showing your client and system configuration plus a section showing the completion and attempted upload of the WU should be posted.
PieterPatrick
Post by PieterPatrick »
Hi, I'm new here,
Don't know if I should reply here or start a new tread.
I've also got a WU that wont send.....
It is a big WU
LOG:
18:22:59:Removing old file 'configs/config-20160229-174829.xml'
18:22:59:Saving configuration to config.xml
18:22:59:<config>
18:22:59:  <!-- Folding Core -->
18:22:59:  <checkpoint v='30'/>
18:22:59:  <core-priority v='low'/>
18:22:59:
18:22:59:  <!-- Folding Slot Configuration -->
18:22:59:  <cause v='CANCER'/>
18:22:59:
18:22:59:  <!-- Network -->
18:22:59:  <proxy v=':8080'/>
18:22:59:
18:22:59:  <!-- Slot Control -->
18:22:59:  <power v='full'/>
18:22:59:
18:22:59:  <!-- User Information -->
18:22:59:  <passkey v='********************************'/>
18:22:59:  <user v='PieterPatrick'/>
18:22:59:
18:22:59:  <!-- Folding Slots -->
18:22:59:  <slot id='1' type='GPU'/>
18:22:59:  <slot id='2' type='GPU'/>
18:22:59:</config>
18:23:00:WU02:FS02:Upload 80.38%
18:23:06:WU02:FS02:Upload 97.53%
18:23:07:WU02:FS02:Upload complete
18:23:07:WU02:FS02:Server responded PLEASE_WAIT (464)
18:23:07:WARNING:WU02:FS02:Failed to send results, will try again later
18:23:28:WU03:FS01:0x21:Completed 98800 out of 520000 steps (19%)
18:23:50:Removing old file 'configs/config-20160229-183658.xml'
18:23:50:Saving configuration to config.xml
18:23:50:<config>
18:23:50:  <!-- Folding Core -->
18:23:50:  <checkpoint v='30'/>
18:23:50:  <core-priority v='low'/>
18:23:50:
18:23:50:  <!-- Folding Slot Configuration -->
18:23:50:  <cause v='CANCER'/>
18:23:50:
18:23:50:  <!-- Network -->
18:23:50:  <proxy v=':8080'/>
18:23:50:
18:23:50:  <!-- Slot Control -->
18:23:50:  <power v='full'/>
18:23:50:
18:23:50:  <!-- User Information -->
18:23:50:  <passkey v='********************************'/>
18:23:50:  <user v='PieterPatrick'/>
18:23:50:
18:23:50:  <!-- Folding Slots -->
18:23:50:  <slot id='1' type='GPU'/>
18:23:50:  <slot id='2' type='GPU'/>
18:23:50:</config>
18:24:30:WU03:FS01:0x21:Completed 104000 out of 520000 steps (20%)
Mod edit: Added Code tags to log file
@PieterPatrick
As mentioned in my response to the first post, please include the first section of the log. Also, the extract showing the upload should include the beginning portion showing the WU being uploaded and the WS IP address being used for the upload.
I think this is similar to this report : viewtopic.php?f=18&t=28353
We may have a problem with a WS ... :(
PieterPatrick
Ok, I not fully understand what is requested (English not the best)
But I'll try... :-)
Work server:
http://fah-web.stanford.edu/logs/171.64.65.104.log.html
Colection Server:
http://fah-web.stanford.edu/logs/171.65 ... 0.log.html
  *********************** Log Started 2016-03-12T18:36:27Z ***********************
18:36:27:************************* Folding@home Client *************************
18:36:27:      Website: http://folding.stanford.edu/
18:36:27:    Copyright: (c) 2009-2014 Stanford University
18:36:27:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:36:27:         Args: --open-web-control
18:36:27:       Config: C:/ProgramData/FAHClient/config.xml
18:36:27:******************************** Build ********************************
18:36:27:      Version: 7.4.4
18:36:27:         Date: Mar 4 2014
18:36:27:         Time: 20:26:54
18:36:27:      SVN Rev: 4130
18:36:27:       Branch: fah/trunk/client
18:36:27:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:36:27:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:36:27:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:36:27:     Platform: win32 XP
18:36:27:         Bits: 32
18:36:27:         Mode: Release
18:36:27:******************************* System ********************************
18:36:27:          CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
18:36:27:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:36:27:         CPUs: 4
18:36:27:       Memory: 15.95GiB
18:36:27:  Free Memory: 13.78GiB
18:36:27:      Threads: WINDOWS_THREADS
18:36:27:   OS Version: 6.2
18:36:27:  Has Battery: false
18:36:27:   On Battery: false
18:36:27:   UTC Offset: 1
18:36:27:          PID: 2352
18:36:27:          CWD: C:/ProgramData/FAHClient
18:36:27:           OS: Windows 10 Home
18:36:27:      OS Arch: AMD64
18:36:27:         GPUs: 2
18:36:27:        GPU 0: NVIDIA:5 GM204 [GeForce GTX 970]
18:36:27:        GPU 1: NVIDIA:5 GM204 [GeForce GTX 970]
18:36:27:         CUDA: 5.2
18:36:27:  CUDA Driver: 8000
18:36:27:Win32 Service: false
18:36:27:***********************************************************************
18:36:27:<config>
18:36:27:  <service-description v='Folding@home Client'/>
18:36:27:  <service-restart v='true'/>
18:36:27:  <service-restart-delay v='5000'/>
18:36:27:
18:36:27:  <!-- Client Control -->
18:36:27:  <client-threads v='6'/>
18:36:27:  <cycle-rate v='4'/>
18:36:27:  <cycles v='-1'/>
18:36:27:  <data-directory v='.'/>
18:36:27:  <disable-sleep-when-active v='true'/>
18:36:27:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
18:36:27:  <exit-when-done v='false'/>
18:36:27:  <fold-anon v='false'/>
18:36:27:  <open-web-control v='true'/>
18:36:27:
18:36:27:  <!-- Configuration -->
18:36:27:  <config-rotate v='true'/>
18:36:27:  <config-rotate-dir v='configs'/>
18:36:27:  <config-rotate-max v='16'/>
18:36:27:
18:36:27:  <!-- Debugging -->
18:36:27:  <assignment-servers>
18:36:27:    assign3.stanford.edu:8080 assign4.stanford.edu:80
18:36:27:  </assignment-servers>
18:36:27:  <auth-as v='true'/>
18:36:27:  <capture-directory v='capture'/>
18:36:27:  <capture-on-error v='false'/>
18:36:27:  <capture-packets v='false'/>
18:36:27:  <capture-requests v='false'/>
18:36:27:  <capture-responses v='false'/>
18:36:27:  <capture-sockets v='false'/>
18:36:27:  <core-exec v='FahCore_$type'/>
18:36:27:  <core-wrapper-exec v='FAHCoreWrapper'/>
18:36:27:  <debug-sockets v='false'/>
18:36:27:  <exception-locations v='true'/>
18:36:27:  <gpu-assignment-servers>
18:36:27:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
18:36:27:  </gpu-assignment-servers>
18:36:27:  <stack-traces v='false'/>
18:36:27:
18:36:27:  <!-- Error Handling -->
18:36:27:  <max-slot-errors v='10'/>
18:36:27:  <max-unit-errors v='5'/>
18:36:27:
18:36:27:  <!-- Folding Core -->
18:36:27:  <checkpoint v='30'/>
18:36:27:  <core-dir v='cores'/>
18:36:27:  <core-priority v='low'/>
18:36:27:  <cpu-affinity v='false'/>
18:36:27:  <cpu-usage v='100'/>
18:36:27:  <gpu-usage v='100'/>
18:36:27:  <no-assembly v='false'/>
18:36:27:
18:36:27:  <!-- Folding Slot Configuration -->
18:36:27:  <cause v='CANCER'/>
18:36:27:  <client-subtype v='STDCLI'/>
18:36:27:  <client-type v='normal'/>
18:36:27:  <cpu-species v='X86_PENTIUM_II'/>
18:36:27:  <cpu-type v='AMD64'/>
18:36:27:  <cpus v='-1'/>
18:36:27:  <gpu v='true'/>
18:36:27:  <max-packet-size v='normal'/>
18:36:27:  <os-species v='UNKNOWN'/>
18:36:27:  <os-type v='WIN32'/>
18:36:27:  <project-key v='0'/>
18:36:27:  <smp v='true'/>
18:36:27:
18:36:27:  <!-- GUI -->
18:36:27:  <gui-enabled v='true'/>
18:36:27:
18:36:27:  <!-- HTTP Server -->
18:36:27:  <allow v='127.0.0.1'/>
18:36:27:  <connection-timeout v='60'/>
18:36:27:  <deny v='0/0'/>
18:36:27:  <http-addresses v='0:7396'/>
18:36:27:  <https-addresses v=''/>
18:36:27:  <max-connect-time v='900'/>
18:36:27:  <max-connections v='800'/>
18:36:27:  <max-request-length v='52428800'/>
18:36:27:  <min-connect-time v='300'/>
18:36:27:  <threads v='4'/>
18:36:27:
18:36:27:  <!-- Logging -->
18:36:27:  <log v='log.txt'/>
18:36:27:  <log-color v='false'/>
18:36:27:  <log-crlf v='true'/>
18:36:27:  <log-date v='false'/>
18:36:27:  <log-date-periodically v='21600'/>
18:36:27:  <log-debug v='true'/>
18:36:27:  <log-domain v='false'/>
18:36:27:  <log-header v='true'/>
18:36:27:  <log-level v='true'/>
18:36:27:  <log-no-info-header v='true'/>
18:36:27:  <log-redirect v='false'/>
18:36:27:  <log-rotate v='true'/>
18:36:27:  <log-rotate-dir v='logs'/>
18:36:27:  <log-rotate-max v='16'/>
18:36:27:  <log-short-level v='false'/>
18:36:27:  <log-simple-domains v='true'/>
18:36:27:  <log-thread-id v='false'/>
18:36:27:  <log-thread-prefix v='true'/>
18:36:27:  <log-time v='true'/>
18:36:27:  <log-to-screen v='true'/>
18:36:27:  <log-truncate v='false'/>
18:36:27:  <verbosity v='5'/>
18:36:27:
18:36:27:  <!-- Network -->
18:36:27:  <proxy v=':8080'/>
18:36:27:  <proxy-enable v='false'/>
18:36:27:  <proxy-pass v=''/>
18:36:27:  <proxy-user v=''/>
18:36:27:
18:36:27:  <!-- Process Control -->
18:36:27:  <child v='false'/>
18:36:27:  <daemon v='false'/>
18:36:27:  <pid v='false'/>
18:36:27:  <pid-file v='Folding@home Client.pid'/>
18:36:27:  <respawn v='false'/>
18:36:27:  <service v='false'/>
18:36:27:
18:36:27:  <!-- Remote Command Server -->
18:36:27:  <command-address v='0.0.0.0'/>
18:36:27:  <command-allow-no-pass v='127.0.0.1'/>
18:36:27:  <command-deny-no-pass v='0/0'/>
18:36:27:  <command-enable v='true'/>
18:36:27:  <command-port v='36330'/>
18:36:27:
18:36:27:  <!-- Slot Control -->
18:36:27:  <idle v='false'/>
18:36:27:  <max-shutdown-wait v='60'/>
18:36:27:  <pause-on-battery v='true'/>
18:36:27:  <pause-on-start v='false'/>
18:36:27:  <paused v='false'/>
18:36:27:  <power v='full'/>
18:36:27:
18:36:27:  <!-- User Information -->
18:36:27:  <machine-id v='0'/>
18:36:27:  <passkey v='********************************'/>
18:36:27:  <team v='0'/>
18:36:27:  <user v='PieterPatrick'/>
18:36:27:
18:36:27:  <!-- Web Server -->
18:36:27:  <web-allow v='127.0.0.1'/>
18:36:27:  <web-deny v='0/0'/>
18:36:27:  <web-enable v='true'/>
18:36:27:
18:36:27:  <!-- Web Server Sessions -->
18:36:27:  <session-cookie v='sid'/>
18:36:27:  <session-lifetime v='86400'/>
18:36:27:  <session-timeout v='3600'/>
18:36:27:
18:36:27:  <!-- Work Unit Control -->
18:36:27:  <dump-after-deadline v='true'/>
18:36:27:  <max-queue v='16'/>
18:36:27:  <max-units v='0'/>
18:36:27:  <next-unit-percentage v='99'/>
18:36:27:  <stall-detection-enabled v='false'/>
18:36:27:  <stall-percent v='5'/>
18:36:27:  <stall-timeout v='1800'/>
18:36:27:
18:36:27:  <!-- Folding Slots -->
18:36:27:  <slot id='1' type='GPU'/>
18:36:27:  <slot id='2' type='GPU'/>
18:36:27:</config>
18:36:27:Trying to access database...
18:36:27:Successfully acquired database lock
18:36:27:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 970]
18:36:27:Enabled folding slot 02: READY gpu:1:GM204 [GeForce GTX 970]
18:36:27:Started thread 5 on PID 2352
18:36:27:Started thread 4 on PID 2352
18:36:27:Started thread 7 on PID 2352
18:36:27:Started thread 6 on PID 2352
18:36:27:Started thread 8 on PID 2352
18:36:27:Started thread 9 on PID 2352
18:36:27:WU00:FS02:Starting
18:36:27:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 2352 -checkpoint 30 -gpu 1 -gpu-vendor nvidia
18:36:27:WU00:FS02:Started FahCore on PID 680
18:36:27:Started thread 10 on PID 2352
18:36:27:WU00:FS02:Core PID:3624
18:36:27:WU00:FS02:FahCore 0x18 started
18:36:27:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:36:27:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:36:27:WU03:FS01:Starting
18:36:27:WU02:FS02:Connecting to 171.64.65.104:8080
18:36:27:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 2352 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
18:36:27:WU03:FS01:Started FahCore on PID 4312
18:36:27:Started thread 11 on PID 2352
18:36:27:WU03:FS01:Core PID:3824
18:36:27:WU03:FS01:FahCore 0x21 started
18:36:27:WU00:FS02:0x18:*********************** Log Started 2016-03-12T18:36:27Z ***********************
18:36:27:WU00:FS02:0x18:Project: 10473 (Run 0, Clone 230, Gen 201)
18:36:27:WU00:FS02:0x18:Unit: 0x0000011b538b3dbb53bec59c2a4d7caf
18:36:27:WU00:FS02:0x18:CPU: 0x00000000000000000000000000000000
18:36:27:WU00:FS02:0x18:Machine: 2
18:36:27:WU00:FS02:0x18:Digital signatures verified
18:36:27:WU00:FS02:0x18:Folding@home GPU core18
18:36:27:WU00:FS02:0x18:Version 0.0.4
18:36:27:WU00:FS02:0x18:  Found a checkpoint file
18:36:27:WU03:FS01:0x21:*********************** Log Started 2016-03-12T18:36:27Z ***********************
18:36:27:WU03:FS01:0x21:Project: 13106 (Run 5, Clone 26, Gen 7)
18:36:27:WU03:FS01:0x21:Unit: 0x00000007ab436c9056be69273e76e4b0
18:36:27:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:36:27:WU03:FS01:0x21:Machine: 1
18:36:27:WU03:FS01:0x21:Digital signatures verified
18:36:27:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:36:27:WU03:FS01:0x21:Version 0.0.17
18:36:27:WU03:FS01:0x21:  Found a checkpoint file
18:36:28:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:36:28:WU02:FS02:Connecting to 171.64.65.104:80
18:36:30:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:36:30:WU02:FS02:Trying to send results to collection server
18:36:30:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:36:30:WU02:FS02:Connecting to 171.65.103.160:8080
18:36:36:WU02:FS02:Upload 13.93%
18:36:42:WU02:FS02:Upload 30.72%
18:36:47:WU03:FS01:0x21:Completed 160000 out of 520000 steps (30%)
18:36:47:WU03:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:36:48:WU02:FS02:Upload 47.51%
18:36:54:WU02:FS02:Upload 64.66%
18:36:54:Started thread 12 on PID 2352
18:36:55:WU00:FS02:0x18:Completed 4625000 out of 5000000 steps (92%)
18:36:55:WU00:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:37:00:WU02:FS02:Upload 81.45%
18:37:02:WU03:FS01:0x21:Completed 161200 out of 520000 steps (31%)
18:37:06:WU02:FS02:Upload 98.24%
18:37:07:WU02:FS02:Upload complete
18:37:07:WU02:FS02:Server responded PLEASE_WAIT (464)
18:37:07:WARNING:WU02:FS02:Failed to send results, will try again later
18:37:07:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:37:07:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:37:07:WU02:FS02:Connecting to 171.64.65.104:8080
18:37:08:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:37:08:WU02:FS02:Connecting to 171.64.65.104:80
18:37:10:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:37:10:WU02:FS02:Trying to send results to collection server
18:37:10:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:37:10:WU02:FS02:Connecting to 171.65.103.160:8080
18:37:16:WU02:FS02:Upload 14.65%
18:37:22:WU02:FS02:Upload 31.44%
18:37:28:WU02:FS02:Upload 48.23%
18:37:34:WU02:FS02:Upload 65.02%
18:37:40:WU02:FS02:Upload 82.17%
18:37:46:WU02:FS02:Upload 98.96%
18:37:47:WU02:FS02:Upload complete
18:37:47:WU02:FS02:Server responded PLEASE_WAIT (464)
18:37:47:WARNING:WU02:FS02:Failed to send results, will try again later
18:38:04:WU03:FS01:0x21:Completed 166400 out of 520000 steps (32%)
18:38:07:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:38:07:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:38:07:WU02:FS02:Connecting to 171.64.65.104:8080
18:38:09:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:38:09:WU02:FS02:Connecting to 171.64.65.104:80
18:38:10:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:38:10:WU02:FS02:Trying to send results to collection server
18:38:10:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:38:10:WU02:FS02:Connecting to 171.65.103.160:8080
18:38:16:WU02:FS02:Upload 13.22%
18:38:22:WU02:FS02:Upload 30.37%
18:38:28:WU02:FS02:Upload 47.16%
18:38:34:WU02:FS02:Upload 63.95%
18:38:40:WU02:FS02:Upload 81.09%
18:38:46:WU02:FS02:Upload 97.88%
18:38:47:WU02:FS02:Upload complete
18:38:47:WU02:FS02:Server responded PLEASE_WAIT (464)
18:38:47:WARNING:WU02:FS02:Failed to send results, will try again later
18:39:06:WU03:FS01:0x21:Completed 171600 out of 520000 steps (33%)
18:39:39:WU00:FS02:0x18:Completed 4650000 out of 5000000 steps (93%)
18:39:44:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:39:44:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:39:44:WU02:FS02:Connecting to 171.64.65.104:8080
18:39:46:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:39:46:WU02:FS02:Connecting to 171.64.65.104:80
18:39:47:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:39:47:WU02:FS02:Trying to send results to collection server
18:39:47:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:39:47:WU02:FS02:Connecting to 171.65.103.160:8080
18:39:53:WU02:FS02:Upload 13.93%
18:39:59:WU02:FS02:Upload 30.72%
18:40:05:WU02:FS02:Upload 47.51%
18:40:08:WU03:FS01:0x21:Completed 176800 out of 520000 steps (34%)
18:40:11:WU02:FS02:Upload 64.30%
18:40:17:WU02:FS02:Upload 81.45%
18:40:23:WU02:FS02:Upload 98.24%
18:40:24:WU02:FS02:Upload complete
18:40:24:WU02:FS02:Server responded PLEASE_WAIT (464)
18:40:24:WARNING:WU02:FS02:Failed to send results, will try again later
18:41:10:WU03:FS01:0x21:Completed 182000 out of 520000 steps (35%)
18:42:12:WU03:FS01:0x21:Completed 187200 out of 520000 steps (36%)
18:42:21:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:42:21:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:42:21:WU02:FS02:Connecting to 171.64.65.104:8080
18:42:23:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:42:23:WU02:FS02:Connecting to 171.64.65.104:80
18:42:24:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:42:24:WU02:FS02:Trying to send results to collection server
18:42:24:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:42:24:WU02:FS02:Connecting to 171.65.103.160:8080
18:42:30:WU02:FS02:Upload 13.22%
18:42:36:WU02:FS02:Upload 30.01%
18:42:42:WU02:FS02:Upload 47.16%
18:42:48:WU02:FS02:Upload 63.95%
18:42:54:WU02:FS02:Upload 80.74%
18:43:00:WU02:FS02:Upload 97.88%
18:43:01:WU02:FS02:Upload complete
18:43:01:WU02:FS02:Server responded PLEASE_WAIT (464)
18:43:01:WARNING:WU02:FS02:Failed to send results, will try again later
18:43:14:WU03:FS01:0x21:Completed 192400 out of 520000 steps (37%)
18:44:15:WU03:FS01:0x21:Completed 197600 out of 520000 steps (38%)
18:44:46:WU00:FS02:0x18:Completed 4700000 out of 5000000 steps (94%)
18:45:22:WU03:FS01:0x21:Completed 202800 out of 520000 steps (39%)
18:46:23:WU03:FS01:0x21:Completed 208000 out of 520000 steps (40%)
18:46:36:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:46:36:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:46:36:WU02:FS02:Connecting to 171.64.65.104:8080
18:46:37:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:46:37:WU02:FS02:Connecting to 171.64.65.104:80
18:46:39:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:46:39:WU02:FS02:Trying to send results to collection server
18:46:39:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:46:39:WU02:FS02:Connecting to 171.65.103.160:8080
18:46:45:WU02:FS02:Upload 14.65%
18:46:51:WU02:FS02:Upload 31.44%
18:46:57:WU02:FS02:Upload 48.59%
18:47:03:WU02:FS02:Upload 65.38%
18:47:09:WU02:FS02:Upload 82.17%
18:47:15:WU02:FS02:Upload 99.31%
18:47:15:WU02:FS02:Upload complete
18:47:16:WU02:FS02:Server responded PLEASE_WAIT (464)
18:47:16:WARNING:WU02:FS02:Failed to send results, will try again later
18:47:25:WU03:FS01:0x21:Completed 213200 out of 520000 steps (41%)
18:48:26:WU03:FS01:0x21:Completed 218400 out of 520000 steps (42%)
18:49:28:WU03:FS01:0x21:Completed 223600 out of 520000 steps (43%)
18:49:53:WU00:FS02:0x18:Completed 4750000 out of 5000000 steps (95%)
18:50:30:WU03:FS01:0x21:Completed 228800 out of 520000 steps (44%)
18:51:31:WU03:FS01:0x21:Completed 234000 out of 520000 steps (45%)
18:52:33:WU03:FS01:0x21:Completed 239200 out of 520000 steps (46%)
18:53:27:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
18:53:27:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
18:53:27:WU02:FS02:Connecting to 171.64.65.104:8080
18:53:29:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:53:29:WU02:FS02:Connecting to 171.64.65.104:80
18:53:30:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
18:53:30:WU02:FS02:Trying to send results to collection server
18:53:30:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
18:53:30:WU02:FS02:Connecting to 171.65.103.160:8080
18:53:36:WU02:FS02:Upload 12.50%
18:53:40:WU03:FS01:0x21:Completed 244400 out of 520000 steps (47%)
18:53:42:WU02:FS02:Upload 29.65%
18:53:48:WU02:FS02:Upload 46.44%
18:53:54:WU02:FS02:Upload 63.59%
18:54:00:WU02:FS02:Upload 80.38%
18:54:06:WU02:FS02:Upload 97.17%
18:54:07:WU02:FS02:Upload complete
18:54:07:WU02:FS02:Server responded PLEASE_WAIT (464)
18:54:07:WARNING:WU02:FS02:Failed to send results, will try again later
18:54:41:WU03:FS01:0x21:Completed 249600 out of 520000 steps (48%)
18:55:10:WU00:FS02:0x18:Completed 4800000 out of 5000000 steps (96%)
18:55:43:WU03:FS01:0x21:Completed 254800 out of 520000 steps (49%)
18:56:45:WU03:FS01:0x21:Completed 260000 out of 520000 steps (50%)
18:57:46:WU03:FS01:0x21:Completed 265200 out of 520000 steps (51%)
18:58:48:WU03:FS01:0x21:Completed 270400 out of 520000 steps (52%)
18:59:49:WU03:FS01:0x21:Completed 275600 out of 520000 steps (53%)
19:00:16:WU00:FS02:0x18:Completed 4850000 out of 5000000 steps (97%)
19:00:55:WU03:FS01:0x21:Completed 280800 out of 520000 steps (54%)
19:01:56:WU03:FS01:0x21:Completed 286000 out of 520000 steps (55%)
19:02:58:WU03:FS01:0x21:Completed 291200 out of 520000 steps (56%)
19:04:00:WU03:FS01:0x21:Completed 296400 out of 520000 steps (57%)
19:04:33:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9208 run:0 clone:70 gen:59 core:0x21 unit:0x000000b8664f2dd055edd39957ad93c5
19:04:33:WU02:FS02:Uploading 17.50MiB to 171.64.65.104
19:04:33:WU02:FS02:Connecting to 171.64.65.104:8080
19:04:34:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
19:04:34:WU02:FS02:Connecting to 171.64.65.104:80
19:04:36:WARNING:WU02:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
19:04:36:WU02:FS02:Trying to send results to collection server
19:04:36:WU02:FS02:Uploading 17.50MiB to 171.65.103.160
19:04:36:WU02:FS02:Connecting to 171.65.103.160:8080
19:04:42:WU02:FS02:Upload 15.00%
19:04:48:WU02:FS02:Upload 32.15%
19:04:54:WU02:FS02:Upload 48.94%
19:05:00:WU02:FS02:Upload 65.73%
19:05:01:WU03:FS01:0x21:Completed 301600 out of 520000 steps (58%)
19:05:06:WU02:FS02:Upload 82.52%
19:05:12:WU02:FS02:Upload 99.67%
19:05:12:WU02:FS02:Upload complete
19:05:12:WU02:FS02:Server responded PLEASE_WAIT (464)
19:05:12:WARNING:WU02:FS02:Failed to send results, will try again later
19:05:34:WU00:FS02:0x18:Completed 4900000 out of 5000000 steps (98%)
19:06:03:WU03:FS01:0x21:Completed 306800 out of 520000 steps (59%)
19:07:05:WU03:FS01:0x21:Completed 312000 out of 520000 steps (60%)
19:08:07:WU03:FS01:0x21:Completed 317200 out of 520000 steps (61%)
PieterPatrick
toTOW wrote:I think this is similar to this report : viewtopic.php?f=18&t=28353
Could be...
So..... Now this will go furter in that tread?
And I'll wait and hope for the best?
Applefreak
Hardware configuration: MSI B550-A-Pro
AMD Ryzen 5 5600 with Noctua NH-U12P (AM4 Kit)
32 GB G.Skill Ripjaws V SD-DDR4 3200 CL16 (4x8)
MSI RTX 4060 Gaming X
Crucial BX200 480GB SSD
2 TB Seagate SSHD
3 TB WD Green
12 GB ZFS NAS
ASUS BW16-D1HT
2x JBL LSR2380P
AOC 2757 FH
CoolerMaster ATCS 840 case
Windows 10 64
Connection:
VDSL with 80 Mbps down and 15 Mbps up.
Latency to Stanford ~156 ms
Folding:
Interstellar Shipping & Storage (179802)
Post by Applefreak »
I have the same problem with the server.
22:30:14:WU01:FS01:Trying to send results to collection server
22:30:14:WU01:FS01:Uploading 17.15MiB to 171.65.103.160
22:30:14:WU01:FS01:Connecting to 171.65.103.160:8080
22:30:20:WU01:FS01:Upload 10.21%
22:30:26:WU01:FS01:Upload 21.51%
22:30:32:WU01:FS01:Upload 32.08%
22:30:38:WU01:FS01:Upload 43.37%
22:30:44:WU01:FS01:Upload 55.40%
22:30:50:WU01:FS01:Upload 66.34%
22:30:56:WU01:FS01:Upload 78.00%
22:31:02:WU01:FS01:Upload 90.03%
22:31:08:WU01:FS01:Upload 98.78%
22:31:09:WU01:FS01:Upload complete
22:31:09:WU01:FS01:Server responded PLEASE_WAIT (464)
Andmanpro
WU not sending
Post by Andmanpro »
Hi ther i have 2 work units not sending. 9212 and 9213. Both are fully complete and the server seems to reject them. i have 2xgtx960s and a gt710, one WU was on a 960 and another was on the 710, however both GPUs have started and completed serveral WUs since.
20:25:00:WU03:FS01:Connecting to 171.64.65.104:80
20:25:00:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:25:00:WU00:FS02:Connecting to 171.64.65.104:80
20:25:01:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:25:01:WU03:FS01:Trying to send results to collection server
20:25:01:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:25:01:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:25:01:WU03:FS01:Connecting to 171.65.103.160:8080
20:25:01:WU00:FS02:Trying to send results to collection server
20:25:01:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:25:01:WU00:FS02:Connecting to 171.65.103.160:8080
20:25:07:WU00:FS02:Upload 4.29%
20:25:07:WU03:FS01:Upload 7.50%
20:25:13:WU03:FS01:Upload 25.36%
20:25:13:WU00:FS02:Upload 20.00%
20:25:19:WU03:FS01:Upload 37.51%
20:25:19:WU00:FS02:Upload 30.36%
20:25:25:WU00:FS02:Upload 43.22%
20:25:25:WU03:FS01:Upload 51.08%
20:25:31:WU03:FS01:Upload 61.79%
20:25:31:WU00:FS02:Upload 51.43%
20:25:37:WU00:FS02:Upload 66.07%
20:25:37:WU03:FS01:Upload 76.44%
20:25:43:WU00:FS02:Upload 78.22%
20:25:44:WU03:FS01:Upload 88.94%
20:25:48:WU03:FS01:Upload complete
20:25:49:WU00:FS02:Upload 91.43%
20:25:49:WU03:FS01:Server responded PLEASE_WAIT (464)
20:25:49:WARNING:WU03:FS01:Failed to send results, will try again later
20:25:49:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:25:49:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:25:49:WU03:FS01:Connecting to 171.64.65.104:8080
20:25:50:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:25:50:WU03:FS01:Connecting to 171.64.65.104:80
20:25:51:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:25:51:WU03:FS01:Trying to send results to collection server
20:25:51:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:25:51:WU03:FS01:Connecting to 171.65.103.160:8080
20:25:52:WU00:FS02:Upload complete
20:25:52:WU00:FS02:Server responded PLEASE_WAIT (464)
20:25:52:WARNING:WU00:FS02:Failed to send results, will try again later
20:25:53:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:25:53:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:25:53:WU00:FS02:Connecting to 171.64.65.104:8080
20:25:54:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:25:54:WU00:FS02:Connecting to 171.64.65.104:80
20:25:55:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:25:55:WU00:FS02:Trying to send results to collection server
20:25:55:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:25:55:WU00:FS02:Connecting to 171.65.103.160:8080
20:25:57:WU03:FS01:Upload 17.15%
20:26:01:WU00:FS02:Upload 12.50%
20:26:03:WU03:FS01:Upload 33.22%
20:26:07:WU00:FS02:Upload 26.79%
20:26:09:WU03:FS01:Upload 48.58%
20:26:13:WU00:FS02:Upload 41.07%
20:26:15:WU03:FS01:Upload 66.80%
20:26:19:WU00:FS02:Upload 55.72%
20:26:21:WU03:FS01:Upload 83.23%
20:26:25:WU00:FS02:Upload 64.64%
20:26:27:WU03:FS01:Upload 96.80%
20:26:29:WU03:FS01:Upload complete
20:26:29:WU03:FS01:Server responded PLEASE_WAIT (464)
20:26:29:WARNING:WU03:FS01:Failed to send results, will try again later
20:26:32:WU00:FS02:Upload 80.36%
20:26:36:WU00:FS02:Upload complete
20:26:36:WU00:FS02:Server responded PLEASE_WAIT (464)
20:26:36:WARNING:WU00:FS02:Failed to send results, will try again later
20:26:49:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:26:49:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:26:49:WU03:FS01:Connecting to 171.64.65.104:8080
20:26:50:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:26:50:WU03:FS01:Connecting to 171.64.65.104:80
20:26:51:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:26:51:WU03:FS01:Trying to send results to collection server
20:26:51:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:26:51:WU03:FS01:Connecting to 171.65.103.160:8080
20:26:53:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:26:53:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:26:53:WU00:FS02:Connecting to 171.64.65.104:8080
20:26:54:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:26:54:WU00:FS02:Connecting to 171.64.65.104:80
20:26:55:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:26:55:WU00:FS02:Trying to send results to collection server
20:26:55:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:26:55:WU00:FS02:Connecting to 171.65.103.160:8080
20:26:57:WU03:FS01:Upload 18.57%
20:27:01:WU00:FS02:Upload 8.21%
20:27:03:WU03:FS01:Upload 28.22%
20:27:07:WU00:FS02:Upload 18.57%
20:27:09:WU03:FS01:Upload 45.72%
20:27:13:WU00:FS02:Upload 33.21%
20:27:14:FS00:Unpaused
20:27:14:FS01:Unpaused
20:27:14:FS02:Unpaused
20:27:14:FS03:Unpaused
20:27:14:WU01:FS00:Starting
20:27:14:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15
20:27:14:WU01:FS00:Started FahCore on PID 10092
20:27:14:WU01:FS00:Core PID:10084
20:27:14:WU01:FS00:FahCore 0xa4 started
20:27:14:WU01:FS00:0xa4:
20:27:14:WU01:FS00:0xa4:*------------------------------*
20:27:14:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
20:27:14:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
20:27:14:WU01:FS00:0xa4:Preparing to commence simulation
20:27:14:WU01:FS00:0xa4:- Looking at optimizations...
20:27:14:WU01:FS00:0xa4:- Files status OK
20:27:14:WU01:FS00:0xa4:- Expanded 826063 -> 1403472 (decompressed 169.8 percent)
20:27:14:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826063 data_size=1403472, decompressed_data_size=1403472 diff=0
20:27:14:WU01:FS00:0xa4:- Digital signature verified
20:27:14:WU01:FS00:0xa4:Project: 9037 (Run 890, Clone 0, Gen 53)
20:27:14:WU01:FS00:0xa4:Assembly optimizations on if available.
20:27:14:WU01:FS00:0xa4:Entering M.D.
20:27:15:WU03:FS01:Upload 54.29%
20:27:19:WU00:FS02:Upload 46.79%
20:27:20:WU01:FS00:0xa4:Using Gromacs checkpoints
20:27:20:WU01:FS00:0xa4:Mapping NT from 1 to 1
20:27:20:WU01:FS00:0xa4:Resuming from checkpoint
20:27:20:WU01:FS00:0xa4:Verified 01/wudata_01.log
20:27:20:WU01:FS00:0xa4:Verified 01/wudata_01.trr
20:27:20:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
20:27:20:WU01:FS00:0xa4:Verified 01/wudata_01.edr
20:27:20:WU01:FS00:0xa4:Completed 23015 out of 250000 steps  (9%)
20:27:21:WU03:FS01:Upload 73.58%
20:27:25:WU00:FS02:Upload 58.93%
20:27:27:WU03:FS01:Upload 82.87%
20:27:31:WU00:FS02:Upload 77.50%
20:27:33:WU03:FS01:Upload complete
20:27:33:WU03:FS01:Server responded PLEASE_WAIT (464)
20:27:33:WARNING:WU03:FS01:Failed to send results, will try again later
20:27:37:WU00:FS02:Upload 92.86%
20:27:38:WU00:FS02:Upload complete
20:27:39:WU00:FS02:Server responded PLEASE_WAIT (464)
20:27:39:WARNING:WU00:FS02:Failed to send results, will try again later
20:27:49:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:27:49:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:27:49:WU03:FS01:Connecting to 171.64.65.104:8080
20:27:50:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:27:50:WU03:FS01:Connecting to 171.64.65.104:80
20:27:51:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:27:51:WU03:FS01:Trying to send results to collection server
20:27:51:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:27:51:WU03:FS01:Connecting to 171.65.103.160:8080
20:27:53:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:27:53:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:27:53:WU00:FS02:Connecting to 171.64.65.104:8080
20:27:54:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:27:54:WU00:FS02:Connecting to 171.64.65.104:80
20:27:55:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:27:55:WU00:FS02:Trying to send results to collection server
20:27:55:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:27:55:WU00:FS02:Connecting to 171.65.103.160:8080
20:27:57:WU03:FS01:Upload 8.57%
20:28:01:WU00:FS02:Upload 7.14%
20:28:02:Removing old file 'configs/config-20160311-221342.xml'
20:28:02:Saving configuration to config.xml
20:28:02:<config>
20:28:02:  <!-- Network -->
20:28:02:  <proxy v=':8080'/>
20:28:02:
20:28:02:  <!-- Slot Control -->
20:28:02:  <power v='light'/>
20:28:02:
20:28:02:  <!-- User Information -->
20:28:02:  <passkey v='********************************'/>
20:28:02:  <team v='111065'/>
20:28:02:  <user v='Andmanpro'/>
20:28:02:
20:28:02:  <!-- Folding Slots -->
20:28:02:  <slot id='0' type='CPU'/>
20:28:02:  <slot id='1' type='GPU'/>
20:28:02:  <slot id='2' type='GPU'/>
20:28:02:  <slot id='3' type='GPU'/>
20:28:02:</config>
20:28:03:WU03:FS01:Upload 14.29%
20:28:07:WU00:FS02:Upload 13.57%
20:28:09:WU03:FS01:Upload 23.93%
20:28:13:WU00:FS02:Upload 22.14%
20:28:15:WU03:FS01:Upload 37.15%
20:28:19:WU00:FS02:Upload 36.43%
20:28:21:WU03:FS01:Upload 51.79%
20:28:25:WU00:FS02:Upload 47.86%
20:28:27:WU03:FS01:Upload 65.72%
20:28:31:WU00:FS02:Upload 64.29%
20:28:33:WU03:FS01:Upload 82.51%
20:28:37:WU00:FS02:Upload 75.36%
20:28:40:WU03:FS01:Upload complete
20:28:40:WU03:FS01:Server responded PLEASE_WAIT (464)
20:28:40:WARNING:WU03:FS01:Failed to send results, will try again later
20:28:43:WU00:FS02:Upload 94.64%
20:28:45:WU00:FS02:Upload complete
20:28:45:WU00:FS02:Server responded PLEASE_WAIT (464)
20:28:45:WARNING:WU00:FS02:Failed to send results, will try again later
20:29:26:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:29:26:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:29:26:WU03:FS01:Connecting to 171.64.65.104:8080
20:29:27:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:29:27:WU03:FS01:Connecting to 171.64.65.104:80
20:29:29:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:29:29:WU03:FS01:Trying to send results to collection server
20:29:29:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:29:29:WU03:FS01:Connecting to 171.65.103.160:8080
20:29:30:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:29:30:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:29:30:WU00:FS02:Connecting to 171.64.65.104:8080
20:29:31:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:29:31:WU00:FS02:Connecting to 171.64.65.104:80
20:29:32:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:29:32:WU00:FS02:Trying to send results to collection server
20:29:32:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:29:32:WU00:FS02:Connecting to 171.65.103.160:8080
20:29:35:WU03:FS01:Upload 10.72%
20:29:38:WU00:FS02:Upload 13.57%
20:29:41:WU03:FS01:Upload 28.93%
20:29:44:WU00:FS02:Upload 26.79%
20:29:47:WU03:FS01:Upload 42.15%
20:29:50:WU00:FS02:Upload 37.50%
20:29:53:WU03:FS01:Upload 57.87%
20:29:56:WU00:FS02:Upload 51.79%
20:29:59:WU03:FS01:Upload 73.22%
20:30:02:WU00:FS02:Upload 59.64%
20:30:06:WU03:FS01:Upload 89.66%
20:30:08:WU00:FS02:Upload 72.14%
20:30:11:WU03:FS01:Upload complete
20:30:11:WU03:FS01:Server responded PLEASE_WAIT (464)
20:30:11:WARNING:WU03:FS01:Failed to send results, will try again later
20:30:15:WU00:FS02:Upload 86.43%
20:30:20:WU00:FS02:Upload complete
20:30:20:WU00:FS02:Server responded PLEASE_WAIT (464)
20:30:20:WARNING:WU00:FS02:Failed to send results, will try again later
20:31:00:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
20:32:03:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:32:03:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:32:03:WU03:FS01:Connecting to 171.64.65.104:8080
20:32:05:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:32:05:WU03:FS01:Connecting to 171.64.65.104:80
20:32:06:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:32:06:WU03:FS01:Trying to send results to collection server
20:32:06:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:32:06:WU03:FS01:Connecting to 171.65.103.160:8080
20:32:07:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:32:07:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:32:07:WU00:FS02:Connecting to 171.64.65.104:8080
20:32:08:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:32:08:WU00:FS02:Connecting to 171.64.65.104:80
20:32:09:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:32:09:WU00:FS02:Trying to send results to collection server
20:32:09:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:32:09:WU00:FS02:Connecting to 171.65.103.160:8080
20:32:12:WU03:FS01:Upload 19.65%
20:32:15:WU00:FS02:Upload 11.43%
20:32:19:WU03:FS01:Upload 35.00%
20:32:21:WU00:FS02:Upload 20.00%
20:32:25:WU03:FS01:Upload 40.36%
20:32:27:WU00:FS02:Upload 28.21%
20:32:32:WU03:FS01:Upload 49.65%
20:32:33:WU00:FS02:Upload 36.07%
20:32:39:WU03:FS01:Upload 62.15%
20:32:39:WU00:FS02:Upload 44.29%
20:32:45:WU03:FS01:Upload 74.30%
20:32:45:WU00:FS02:Upload 53.22%
20:32:51:WU00:FS02:Upload 64.64%
20:32:52:WU03:FS01:Upload 87.87%
20:32:57:WU00:FS02:Upload 76.43%
20:32:57:WU03:FS01:Upload complete
20:32:57:WU03:FS01:Server responded PLEASE_WAIT (464)
20:32:57:WARNING:WU03:FS01:Failed to send results, will try again later
20:33:04:WU00:FS02:Upload 80.00%
20:33:10:WU00:FS02:Upload 83.57%
20:33:17:WU00:FS02:Upload 98.22%
20:33:19:WU00:FS02:Upload complete
20:33:19:WU00:FS02:Server responded PLEASE_WAIT (464)
20:33:19:WARNING:WU00:FS02:Failed to send results, will try again later
20:35:53:WU01:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
20:36:18:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:36:18:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:36:18:WU03:FS01:Connecting to 171.64.65.104:8080
20:36:19:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:36:19:WU03:FS01:Connecting to 171.64.65.104:80
20:36:20:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:36:20:WU03:FS01:Trying to send results to collection server
20:36:20:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:36:20:WU03:FS01:Connecting to 171.65.103.160:8080
20:36:21:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:36:21:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:36:21:WU00:FS02:Connecting to 171.64.65.104:8080
20:36:22:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:36:22:WU00:FS02:Connecting to 171.64.65.104:80
20:36:24:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:36:24:WU00:FS02:Trying to send results to collection server
20:36:24:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:36:24:WU00:FS02:Connecting to 171.65.103.160:8080
20:36:26:WU03:FS01:Upload 11.07%
20:36:30:WU00:FS02:Upload 8.57%
20:36:32:WU03:FS01:Upload 25.00%
20:36:36:WU00:FS02:Upload 20.36%
20:36:38:WU03:FS01:Upload 35.00%
20:36:42:WU00:FS02:Upload 31.79%
20:36:44:WU03:FS01:Upload 52.51%
20:36:48:WU00:FS02:Upload 46.43%
20:36:50:WU03:FS01:Upload 67.87%
20:36:54:WU00:FS02:Upload 54.29%
20:36:56:WU03:FS01:Upload 75.72%
20:37:00:WU00:FS02:Upload 65.00%
20:37:02:WU03:FS01:Upload 90.37%
20:37:06:WU00:FS02:Upload 74.64%
20:37:06:WU03:FS01:Upload complete
20:37:06:WU03:FS01:Server responded PLEASE_WAIT (464)
20:37:06:WARNING:WU03:FS01:Failed to send results, will try again later
20:37:13:WU00:FS02:Upload 95.72%
20:37:18:WU00:FS02:Upload complete
20:37:18:WU00:FS02:Server responded PLEASE_WAIT (464)
20:37:18:WARNING:WU00:FS02:Failed to send results, will try again later
20:37:41:WU06:FS01:Starting
20:37:41:WU06:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 06 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:37:41:WU06:FS01:Started FahCore on PID 9412
20:37:41:WU06:FS01:Core PID:9416
20:37:41:WU06:FS01:FahCore 0x18 started
20:37:41:WU02:FS02:Starting
20:37:41:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
20:37:41:WU02:FS02:Started FahCore on PID 9736
20:37:41:WU02:FS02:Core PID:9572
20:37:41:WU02:FS02:FahCore 0x21 started
20:37:41:WU05:FS03:Starting
20:37:41:WU05:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 05 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
20:37:41:WU05:FS03:Started FahCore on PID 10196
20:37:41:WU05:FS03:Core PID:6104
20:37:41:WU05:FS03:FahCore 0x18 started
20:37:41:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:37:41:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:37:41:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:37:41:WU03:FS01:Connecting to 171.64.65.104:8080
20:37:41:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:37:41:WU00:FS02:Connecting to 171.64.65.104:8080
20:37:41:WU06:FS01:0x18:*********************** Log Started 2016-03-13T20:37:41Z ***********************
20:37:41:WU06:FS01:0x18:Project: 9160 (Run 43, Clone 0, Gen 172)
20:37:41:WU06:FS01:0x18:Unit: 0x000000c2ab40415c56746462a384c260
20:37:41:WU06:FS01:0x18:CPU: 0x00000000000000000000000000000000
20:37:41:WU06:FS01:0x18:Machine: 1
20:37:41:WU06:FS01:0x18:Digital signatures verified
20:37:41:WU06:FS01:0x18:Folding@home GPU core18
20:37:41:WU06:FS01:0x18:Version 0.0.4
20:37:41:WU06:FS01:0x18:  Found a checkpoint file
20:37:41:WU02:FS02:0x21:*********************** Log Started 2016-03-13T20:37:41Z ***********************
20:37:41:WU02:FS02:0x21:Project: 11406 (Run 3, Clone 29, Gen 45)
20:37:41:WU02:FS02:0x21:Unit: 0x000000398ca304f25686b1c7d8911069
20:37:41:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
20:37:41:WU02:FS02:0x21:Machine: 2
20:37:41:WU02:FS02:0x21:Digital signatures verified
20:37:41:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
20:37:41:WU02:FS02:0x21:Version 0.0.17
20:37:41:WU02:FS02:0x21:  Found a checkpoint file
20:37:42:WU05:FS03:0x18:*********************** Log Started 2016-03-13T20:37:41Z ***********************
20:37:42:WU05:FS03:0x18:Project: 9156 (Run 86, Clone 0, Gen 161)
20:37:42:WU05:FS03:0x18:Unit: 0x000000bdab40415456737dd809ebcd1d
20:37:42:WU05:FS03:0x18:CPU: 0x00000000000000000000000000000000
20:37:42:WU05:FS03:0x18:Machine: 3
20:37:42:WU05:FS03:0x18:Digital signatures verified
20:37:42:WU05:FS03:0x18:Folding@home GPU core18
20:37:42:WU05:FS03:0x18:Version 0.0.4
20:37:42:WU05:FS03:0x18:  Found a checkpoint file
20:37:42:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:37:42:WU03:FS01:Connecting to 171.64.65.104:80
20:37:42:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:37:42:WU00:FS02:Connecting to 171.64.65.104:80
20:37:43:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:37:43:WU03:FS01:Trying to send results to collection server
20:37:43:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:37:43:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:37:43:WU03:FS01:Connecting to 171.65.103.160:8080
20:37:43:WU00:FS02:Trying to send results to collection server
20:37:43:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:37:43:WU00:FS02:Connecting to 171.65.103.160:8080
20:37:49:WU03:FS01:Upload 12.50%
20:37:49:WU00:FS02:Upload 9.29%
20:37:49:WU02:FS02:0x21:Completed 875000 out of 5000000 steps (17%)
20:37:49:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:37:53:WU06:FS01:0x18:Completed 1900000 out of 2500000 steps (76%)
20:37:53:WU06:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:37:53:WU05:FS03:0x18:Completed 900000 out of 2500000 steps (36%)
20:37:53:WU05:FS03:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:37:55:WU00:FS02:Upload 14.64%
20:37:55:WU03:FS01:Upload 21.43%
20:38:01:WU00:FS02:Upload 27.50%
20:38:01:WU03:FS01:Upload 38.58%
20:38:07:WU03:FS01:Upload 56.79%
20:38:07:WU00:FS02:Upload 40.72%
20:38:12:Removing old file 'configs/config-20160311-222049.xml'
20:38:12:Saving configuration to config.xml
20:38:12:<config>
20:38:12:  <!-- Network -->
20:38:12:  <proxy v=':8080'/>
20:38:12:
20:38:12:  <!-- Slot Control -->
20:38:12:  <power v='FULL'/>
20:38:12:
20:38:12:  <!-- User Information -->
20:38:12:  <passkey v='********************************'/>
20:38:12:  <team v='111065'/>
20:38:12:  <user v='Andmanpro'/>
20:38:12:
20:38:12:  <!-- Folding Slots -->
20:38:12:  <slot id='0' type='CPU'/>
20:38:12:  <slot id='1' type='GPU'/>
20:38:12:  <slot id='2' type='GPU'/>
20:38:12:  <slot id='3' type='GPU'/>
20:38:12:</config>
20:38:13:WU00:FS02:Upload 49.64%
20:38:13:WU03:FS01:Upload 71.08%
20:38:19:WU03:FS01:Upload 82.15%
20:38:19:WU00:FS02:Upload 58.57%
20:38:25:WU00:FS02:Upload 71.79%
20:38:26:WU03:FS01:Upload 100.00%
20:38:26:WU03:FS01:Upload complete
20:38:26:WU03:FS01:Server responded PLEASE_WAIT (464)
20:38:26:WARNING:WU03:FS01:Failed to send results, will try again later
20:38:31:WU00:FS02:Upload 86.07%
20:38:37:WU00:FS02:Upload complete
20:38:37:WU00:FS02:Server responded PLEASE_WAIT (464)
20:38:37:WARNING:WU00:FS02:Failed to send results, will try again later
20:39:18:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:39:18:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:39:18:WU03:FS01:Connecting to 171.64.65.104:8080
20:39:18:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:39:18:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:39:18:WU00:FS02:Connecting to 171.64.65.104:8080
20:39:20:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:39:20:WU03:FS01:Connecting to 171.64.65.104:80
20:39:20:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:39:20:WU00:FS02:Connecting to 171.64.65.104:80
20:39:21:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:39:21:WU03:FS01:Trying to send results to collection server
20:39:21:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:39:21:WU03:FS01:Connecting to 171.65.103.160:8080
20:39:21:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:39:21:WU00:FS02:Trying to send results to collection server
20:39:21:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:39:21:WU00:FS02:Connecting to 171.65.103.160:8080
20:39:27:WU00:FS02:Upload 10.71%
20:39:27:WU03:FS01:Upload 14.29%
20:39:33:WU00:FS02:Upload 21.43%
20:39:33:WU03:FS01:Upload 24.29%
20:39:39:WU00:FS02:Upload 34.64%
20:39:39:WU03:FS01:Upload 42.51%
20:39:45:WU03:FS01:Upload 57.87%
20:39:45:WU00:FS02:Upload 45.72%
20:39:51:WU00:FS02:Upload 57.50%
20:39:51:WU03:FS01:Upload 73.58%
20:39:57:WU00:FS02:Upload 70.36%
20:39:57:WU03:FS01:Upload 87.51%
20:40:02:WU03:FS01:Upload complete
20:40:02:WU03:FS01:Server responded PLEASE_WAIT (464)
20:40:02:WARNING:WU03:FS01:Failed to send results, will try again later
20:40:03:WU00:FS02:Upload 80.72%
20:40:10:WU00:FS02:Upload complete
20:40:10:WU00:FS02:Server responded PLEASE_WAIT (464)
20:40:10:WARNING:WU00:FS02:Failed to send results, will try again later
20:40:13:WU06:FS01:0x18:Completed 1925000 out of 2500000 steps (77%)
20:41:24:WU02:FS02:0x21:Completed 900000 out of 5000000 steps (18%)
20:41:55:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:41:55:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:41:55:WU03:FS01:Connecting to 171.64.65.104:8080
20:41:56:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:41:56:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:41:56:WU00:FS02:Connecting to 171.64.65.104:8080
20:41:57:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:41:57:WU03:FS01:Connecting to 171.64.65.104:80
20:41:57:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:41:57:WU00:FS02:Connecting to 171.64.65.104:80
20:41:58:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:41:58:WU03:FS01:Trying to send results to collection server
20:41:58:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:41:58:WU03:FS01:Connecting to 171.65.103.160:8080
20:41:58:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:41:58:WU00:FS02:Trying to send results to collection server
20:41:58:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:41:58:WU00:FS02:Connecting to 171.65.103.160:8080
20:42:04:WU00:FS02:Upload 11.07%
20:42:04:WU03:FS01:Upload 12.86%
20:42:10:WU03:FS01:Upload 24.29%
20:42:10:WU00:FS02:Upload 20.00%
20:42:16:WU00:FS02:Upload 36.79%
20:42:17:WU03:FS01:Upload 45.01%
20:42:21:WU01:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
20:42:22:WU00:FS02:Upload 44.29%
20:42:24:WU03:FS01:Upload 58.58%
20:42:28:WU00:FS02:Upload 57.14%
20:42:30:WU03:FS01:Upload 77.87%
20:42:31:WU06:FS01:0x18:Completed 1950000 out of 2500000 steps (78%)
20:42:34:WU00:FS02:Upload 66.07%
20:42:36:WU03:FS01:Upload 86.08%
20:42:40:WU00:FS02:Upload 73.57%
20:42:42:WU03:FS01:Upload 97.51%
20:42:43:WU03:FS01:Upload complete
20:42:43:WU03:FS01:Server responded PLEASE_WAIT (464)
20:42:43:WARNING:WU03:FS01:Failed to send results, will try again later
20:42:46:WU00:FS02:Upload 85.00%
20:42:51:WU00:FS02:Upload complete
20:42:51:WU00:FS02:Server responded PLEASE_WAIT (464)
20:42:51:WARNING:WU00:FS02:Failed to send results, will try again later
20:44:52:WU06:FS01:0x18:Completed 1975000 out of 2500000 steps (79%)
20:46:10:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:46:10:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:46:10:WU03:FS01:Connecting to 171.64.65.104:8080
20:46:10:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:46:10:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:46:10:WU00:FS02:Connecting to 171.64.65.104:8080
20:46:11:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:46:11:WU03:FS01:Connecting to 171.64.65.104:80
20:46:11:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:46:11:WU00:FS02:Connecting to 171.64.65.104:80
20:46:12:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:46:12:WU03:FS01:Trying to send results to collection server
20:46:12:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:46:12:WU03:FS01:Connecting to 171.65.103.160:8080
20:46:12:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:46:12:WU00:FS02:Trying to send results to collection server
20:46:13:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:46:13:WU00:FS02:Connecting to 171.65.103.160:8080
20:46:18:WU03:FS01:Upload 14.64%
20:46:19:WU00:FS02:Upload 17.14%
20:46:24:WU03:FS01:Upload 28.58%
20:46:25:WU00:FS02:Upload 29.64%
20:46:30:WU03:FS01:Upload 40.72%
20:46:31:WU00:FS02:Upload 40.00%
20:46:36:WU03:FS01:Upload 54.65%
20:46:37:WU00:FS02:Upload 56.43%
20:46:42:WU03:FS01:Upload 67.51%
20:46:43:WU00:FS02:Upload 66.43%
20:46:48:WU03:FS01:Upload 82.87%
20:46:49:WU00:FS02:Upload 80.00%
20:46:54:WU03:FS01:Upload 95.37%
20:46:55:WU00:FS02:Upload 91.79%
20:46:55:WU03:FS01:Upload complete
20:46:55:WU03:FS01:Server responded PLEASE_WAIT (464)
20:46:55:WARNING:WU03:FS01:Failed to send results, will try again later
20:46:58:WU00:FS02:Upload complete
20:46:58:WU00:FS02:Server responded PLEASE_WAIT (464)
20:46:58:WARNING:WU00:FS02:Failed to send results, will try again later
20:47:11:WU06:FS01:0x18:Completed 2000000 out of 2500000 steps (80%)
20:48:35:WU02:FS02:0x21:Completed 950000 out of 5000000 steps (19%)
20:49:33:WU06:FS01:0x18:Completed 2025000 out of 2500000 steps (81%)
20:51:12:WU01:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
20:51:51:WU06:FS01:0x18:Completed 2050000 out of 2500000 steps (82%)
20:53:01:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
20:53:01:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
20:53:01:WU03:FS01:Connecting to 171.64.65.104:8080
20:53:01:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
20:53:01:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
20:53:01:WU00:FS02:Connecting to 171.64.65.104:8080
20:53:02:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
20:53:02:WU03:FS01:Connecting to 171.64.65.104:80
20:53:02:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
20:53:02:WU00:FS02:Connecting to 171.64.65.104:80
20:53:03:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:53:03:WU03:FS01:Trying to send results to collection server
20:53:03:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
20:53:03:WU03:FS01:Connecting to 171.65.103.160:8080
20:53:04:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
20:53:04:WU00:FS02:Trying to send results to collection server
20:53:04:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
20:53:04:WU00:FS02:Connecting to 171.65.103.160:8080
20:53:09:WU03:FS01:Upload 11.79%
20:53:10:WU00:FS02:Upload 10.71%
20:53:16:WU00:FS02:Upload 24.64%
20:53:16:WU03:FS01:Upload 29.65%
20:53:22:WU00:FS02:Upload 36.07%
20:53:22:WU03:FS01:Upload 41.79%
20:53:28:WU03:FS01:Upload 55.72%
20:53:28:WU00:FS02:Upload 46.79%
20:53:34:WU00:FS02:Upload 62.14%
20:53:35:WU03:FS01:Upload 72.87%
20:53:40:WU00:FS02:Upload 71.07%
20:53:41:WU03:FS01:Upload 87.87%
20:53:46:WU00:FS02:Upload 86.79%
20:53:47:WU03:FS01:Upload complete
20:53:47:WU03:FS01:Server responded PLEASE_WAIT (464)
20:53:47:WARNING:WU03:FS01:Failed to send results, will try again later
20:53:52:WU00:FS02:Upload 97.50%
20:53:52:WU00:FS02:Upload complete
20:53:52:WU00:FS02:Server responded PLEASE_WAIT (464)
20:53:52:WARNING:WU00:FS02:Failed to send results, will try again later
Mod edit: Added Code tags to log file. merged with existing topic
Re: WU Stuck On Send
See Failed to connect to 171.64.65.104:80 where the server owner has replied.
Andmanpro
Post by Andmanpro »
Went to set my control to Full before going to sleep and found that the server finally responded and dumped the files. Too bad on the Credits, but at least my OCD can rest easy without the finished WUs in my Queue
20:30:53:FS01:Shutting core down
20:30:53:FS02:Shutting core down
20:30:53:FS03:Shutting core down
20:30:53:WU05:FS03:0x18:WARNING:Console control signal 1 on PID 8936
20:30:53:WU05:FS03:0x18:Exiting, please wait. . .
20:30:54:WU01:FS02:0x17:WARNING:Console control signal 1 on PID 7584
20:30:54:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 12536
20:30:54:WU01:FS02:0x17:Exiting, please wait. . .
20:30:54:WU02:FS01:0x21:Exiting, please wait. . .
20:30:54:WU02:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
20:30:54:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:30:55:WU05:FS03:0x18:Lost lifeline PID 4536, exiting
20:30:55:WU05:FS03:0x18:ERROR:103: Lost client lifeline
20:30:55:WU05:FS03:0x18:Folding@home Core Shutdown: CLIENT_DIED
20:30:55:WU05:FS03:FahCore returned: INTERRUPTED (102 = 0x66)
20:30:56:WU01:FS02:0x17:Lost lifeline PID 4468, exiting
20:30:56:WU01:FS02:0x17:ERROR:103: Lost client lifeline
20:30:56:WU01:FS02:0x17:Folding@home Core Shutdown: CLIENT_DIED
20:30:56:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
20:31:38:Removing old file 'configs/config-20160314-020231.xml'
20:31:38:Saving configuration to config.xml
20:31:38:<config>
20:31:38:  <!-- Network -->
20:31:38:  <proxy v=':8080'/>
20:31:38:
20:31:38:  <!-- Slot Control -->
20:31:38:  <power v='light'/>
20:31:38:
20:31:38:  <!-- User Information -->
20:31:38:  <passkey v='********************************'/>
20:31:38:  <team v='111065'/>
20:31:38:  <user v='Andmanpro'/>
20:31:38:
20:31:38:  <!-- Folding Slots -->
20:31:38:  <slot id='0' type='CPU'/>
20:31:38:  <slot id='1' type='GPU'/>
20:31:38:  <slot id='2' type='GPU'/>
20:31:38:  <slot id='3' type='GPU'/>
20:31:38:</config>
20:33:10:WU04:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
20:37:56:WU04:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
20:44:56:WU04:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
20:51:14:WU04:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
20:59:14:WU04:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
21:06:43:WU04:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
21:15:13:WU04:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
21:15:58:WU05:FS03:Starting
21:15:58:WU05:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 05 -suffix 01 -version 704 -lifeline 8964 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
21:15:58:WU05:FS03:Started FahCore on PID 11792
21:15:58:WU05:FS03:Core PID:5980
21:15:58:WU05:FS03:FahCore 0x18 started
21:15:58:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:15:58:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:15:58:WU00:FS02:Connecting to 171.64.65.104:8080
21:15:59:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:15:59:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:15:59:WU03:FS01:Connecting to 171.64.65.104:8080
21:15:59:WU01:FS02:Starting
21:15:59:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 8964 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:15:59:WU01:FS02:Started FahCore on PID 11448
21:15:59:WU05:FS03:0x18:*********************** Log Started 2016-03-16T21:15:58Z ***********************
21:15:59:WU05:FS03:0x18:Project: 9156 (Run 86, Clone 0, Gen 161)
21:15:59:WU05:FS03:0x18:Unit: 0x000000bdab40415456737dd809ebcd1d
21:15:59:WU01:FS02:Core PID:11664
21:15:59:WU05:FS03:0x18:CPU: 0x00000000000000000000000000000000
21:15:59:WU01:FS02:FahCore 0x17 started
21:15:59:WU05:FS03:0x18:Machine: 3
21:15:59:WU05:FS03:0x18:Digital signatures verified
21:15:59:WU05:FS03:0x18:Folding@home GPU core18
21:15:59:WU05:FS03:0x18:Version 0.0.4
21:15:59:WU05:FS03:0x18:  Found a checkpoint file
21:15:59:WU02:FS01:Starting
21:15:59:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 8964 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
21:15:59:WU02:FS01:Started FahCore on PID 4120
21:15:59:WU02:FS01:Core PID:11860
21:15:59:WU02:FS01:FahCore 0x21 started
21:15:59:WU01:FS02:0x17:*********************** Log Started 2016-03-16T21:15:59Z ***********************
21:15:59:WU01:FS02:0x17:Project: 10469 (Run 0, Clone 368, Gen 214)
21:15:59:WU01:FS02:0x17:Unit: 0x0000017e538b3db9538f4226ef4c6c6c
21:15:59:WU01:FS02:0x17:CPU: 0x00000000000000000000000000000000
21:15:59:WU01:FS02:0x17:Machine: 2
21:15:59:WU01:FS02:0x17:Digital signatures verified
21:15:59:WU01:FS02:0x17:Folding@home GPU core17
21:15:59:WU01:FS02:0x17:Version 0.0.52
21:15:59:WU01:FS02:0x17:  Found a checkpoint file
21:16:00:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:16:00:WU00:FS02:Connecting to 171.64.65.104:80
21:16:00:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:16:00:WU03:FS01:Connecting to 171.64.65.104:80
21:16:01:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:16:01:WU00:FS02:Trying to send results to collection server
21:16:01:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:16:01:WU00:FS02:Connecting to 171.65.103.160:8080
21:16:01:WU02:FS01:0x21:*********************** Log Started 2016-03-16T21:16:00Z ***********************
21:16:01:WU02:FS01:0x21:Project: 9442 (Run 1, Clone 6, Gen 68)
21:16:01:WU02:FS01:0x21:Unit: 0x0000004fab436c9d56b485677003912f
21:16:01:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
21:16:01:WU02:FS01:0x21:Machine: 1
21:16:01:WU02:FS01:0x21:Digital signatures verified
21:16:01:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
21:16:01:WU02:FS01:0x21:Version 0.0.17
21:16:01:WU02:FS01:0x21:  Found a checkpoint file
21:16:01:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:16:01:WU03:FS01:Trying to send results to collection server
21:16:01:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:16:01:WU03:FS01:Connecting to 171.65.103.160:8080
21:16:07:WU03:FS01:Upload 14.64%
21:16:07:WU00:FS02:Upload 19.29%
21:16:07:WU02:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
21:16:07:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:16:11:WU05:FS03:0x18:Completed 2300000 out of 2500000 steps (92%)
21:16:11:WU05:FS03:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:16:13:WU03:FS01:Upload 32.50%
21:16:13:WU00:FS02:Upload 37.14%
21:16:19:WU00:FS02:Upload 53.93%
21:16:19:WU03:FS01:Upload 50.01%
21:16:22:Removing old file 'configs/config-20160314-080629.xml'
21:16:22:Saving configuration to config.xml
21:16:22:<config>
21:16:22:  <!-- Network -->
21:16:22:  <proxy v=':8080'/>
21:16:22:
21:16:22:  <!-- Slot Control -->
21:16:22:  <power v='FULL'/>
21:16:22:
21:16:22:  <!-- User Information -->
21:16:22:  <passkey v='********************************'/>
21:16:22:  <team v='111065'/>
21:16:22:  <user v='Andmanpro'/>
21:16:22:
21:16:22:  <!-- Folding Slots -->
21:16:22:  <slot id='0' type='CPU'/>
21:16:22:  <slot id='1' type='GPU'/>
21:16:22:  <slot id='2' type='GPU'/>
21:16:22:  <slot id='3' type='GPU'/>
21:16:22:</config>
21:16:25:WU00:FS02:Upload 67.86%
21:16:25:WU03:FS01:Upload 61.08%
21:16:31:WU00:FS02:Upload 86.43%
21:16:31:WU03:FS01:Upload 78.94%
21:16:34:WU00:FS02:Upload complete
21:16:34:WU00:FS02:Server responded PLEASE_WAIT (464)
21:16:34:WARNING:WU00:FS02:Failed to send results, will try again later
21:16:36:WU03:FS01:Upload complete
21:16:36:WU03:FS01:Server responded PLEASE_WAIT (464)
21:16:36:WARNING:WU03:FS01:Failed to send results, will try again later
21:17:35:WU01:FS02:0x17:Completed 1750000 out of 5000000 steps (35%)
21:17:35:WU01:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:17:36:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:17:36:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:17:36:WU00:FS02:Connecting to 171.64.65.104:8080
21:17:36:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:17:36:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:17:36:WU03:FS01:Connecting to 171.64.65.104:8080
21:17:37:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:17:37:WU00:FS02:Connecting to 171.64.65.104:80
21:17:37:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:17:37:WU03:FS01:Connecting to 171.64.65.104:80
21:17:38:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:17:38:WU00:FS02:Trying to send results to collection server
21:17:38:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:17:38:WU00:FS02:Connecting to 171.65.103.160:8080
21:17:39:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:17:39:WU03:FS01:Trying to send results to collection server
21:17:39:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:17:39:WU03:FS01:Connecting to 171.65.103.160:8080
21:17:44:WU00:FS02:Upload 16.79%
21:17:45:WU03:FS01:Upload 17.15%
21:17:50:WU00:FS02:Upload 41.07%
21:17:51:WU03:FS01:Upload 38.22%
21:17:56:WU00:FS02:Upload 57.86%
21:17:57:WU03:FS01:Upload 56.44%
21:18:02:WU00:FS02:Upload 76.79%
21:18:03:WU03:FS01:Upload 72.87%
21:18:08:WU00:FS02:Upload complete
21:18:08:WU00:FS02:Server responded PLEASE_WAIT (464)
21:18:08:WARNING:WU00:FS02:Failed to send results, will try again later
21:18:09:WU03:FS01:Upload 93.94%
21:18:11:WU03:FS01:Upload complete
21:18:11:WU03:FS01:Server responded PLEASE_WAIT (464)
21:18:11:WARNING:WU03:FS01:Failed to send results, will try again later
21:19:40:WU02:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
21:20:13:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:20:13:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:20:13:WU00:FS02:Connecting to 171.64.65.104:8080
21:20:13:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:20:13:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:20:13:WU03:FS01:Connecting to 171.64.65.104:8080
21:20:14:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:20:14:WU00:FS02:Connecting to 171.64.65.104:80
21:20:14:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:20:14:WU03:FS01:Connecting to 171.64.65.104:80
21:20:15:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:20:15:WU00:FS02:Trying to send results to collection server
21:20:15:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:20:15:WU00:FS02:Connecting to 171.65.103.160:8080
21:20:16:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:20:16:WU03:FS01:Trying to send results to collection server
21:20:16:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:20:16:WU03:FS01:Connecting to 171.65.103.160:8080
21:20:21:WU00:FS02:Upload 21.07%
21:20:22:WU03:FS01:Upload 23.57%
21:20:27:WU00:FS02:Upload 35.71%
21:20:28:WU03:FS01:Upload 34.65%
21:20:33:WU00:FS02:Upload 55.36%
21:20:34:WU03:FS01:Upload 52.15%
21:20:39:WU00:FS02:Upload 78.93%
21:20:40:WU03:FS01:Upload 71.44%
21:20:45:WU00:FS02:Upload 99.29%
21:20:45:WU00:FS02:Upload complete
21:20:45:WU00:FS02:Server responded PLEASE_WAIT (464)
21:20:45:WARNING:WU00:FS02:Failed to send results, will try again later
21:20:46:WU03:FS01:Upload 93.58%
21:20:47:WU03:FS01:Upload complete
21:20:47:WU03:FS01:Server responded PLEASE_WAIT (464)
21:20:47:WARNING:WU03:FS01:Failed to send results, will try again later
21:22:34:WU04:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
21:23:00:WU02:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
21:24:27:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:24:27:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:24:27:WU00:FS02:Connecting to 171.64.65.104:8080
21:24:27:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:24:27:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:24:27:WU03:FS01:Connecting to 171.64.65.104:8080
21:24:28:WU01:FS02:0x17:Completed 1800000 out of 5000000 steps (36%)
21:24:28:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:24:28:WU00:FS02:Connecting to 171.64.65.104:80
21:24:29:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:24:29:WU03:FS01:Connecting to 171.64.65.104:80
21:24:29:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:24:29:WU00:FS02:Trying to send results to collection server
21:24:29:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:24:29:WU00:FS02:Connecting to 171.65.103.160:8080
21:24:30:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:24:30:WU03:FS01:Trying to send results to collection server
21:24:30:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:24:30:WU03:FS01:Connecting to 171.65.103.160:8080
21:24:35:WU00:FS02:Upload 16.43%
21:24:36:WU03:FS01:Upload 16.07%
21:24:41:WU00:FS02:Upload 40.72%
21:24:42:WU03:FS01:Upload 39.65%
21:24:47:WU00:FS02:Upload 59.64%
21:24:48:WU03:FS01:Upload 56.44%
21:24:53:WU00:FS02:Upload 78.22%
21:24:54:WU03:FS01:Upload 73.22%
21:24:58:WU00:FS02:Upload complete
21:24:58:WU00:FS02:Server responded PLEASE_WAIT (464)
21:24:58:WARNING:WU00:FS02:Failed to send results, will try again later
21:25:00:WU03:FS01:Upload 97.51%
21:25:02:WU03:FS01:Upload complete
21:25:02:WU03:FS01:Server responded PLEASE_WAIT (464)
21:25:02:WARNING:WU03:FS01:Failed to send results, will try again later
21:26:22:WU02:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
21:29:04:WU04:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
21:29:42:WU02:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
21:31:14:WU01:FS02:0x17:Completed 1850000 out of 5000000 steps (37%)
21:31:18:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:31:18:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:31:18:WU00:FS02:Connecting to 171.64.65.104:8080
21:31:19:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:31:19:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:31:19:WU03:FS01:Connecting to 171.64.65.104:8080
21:31:20:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:31:20:WU00:FS02:Connecting to 171.64.65.104:80
21:31:20:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:31:20:WU03:FS01:Connecting to 171.64.65.104:80
21:31:21:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:31:21:WU00:FS02:Trying to send results to collection server
21:31:21:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:31:21:WU00:FS02:Connecting to 171.65.103.160:8080
21:31:21:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:31:21:WU03:FS01:Trying to send results to collection server
21:31:21:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:31:21:WU03:FS01:Connecting to 171.65.103.160:8080
21:31:27:WU00:FS02:Upload 21.79%
21:31:27:WU03:FS01:Upload 21.07%
21:31:33:WU03:FS01:Upload 38.22%
21:31:33:WU00:FS02:Upload 41.07%
21:31:39:WU00:FS02:Upload 59.29%
21:31:39:WU03:FS01:Upload 56.08%
21:31:45:WU03:FS01:Upload 79.30%
21:31:45:WU00:FS02:Upload 83.22%
21:31:50:WU00:FS02:Upload complete
21:31:50:WU00:FS02:Server responded PLEASE_WAIT (464)
21:31:50:WARNING:WU00:FS02:Failed to send results, will try again later
21:31:51:WU03:FS01:Upload 96.44%
21:31:52:WU03:FS01:Upload complete
21:31:52:WU03:FS01:Server responded PLEASE_WAIT (464)
21:31:52:WARNING:WU03:FS01:Failed to send results, will try again later
21:33:05:WU02:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
21:35:37:WU04:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
21:36:24:WU02:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
21:38:08:WU01:FS02:0x17:Completed 1900000 out of 5000000 steps (38%)
21:39:46:WU02:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
21:41:05:WU05:FS03:0x18:Completed 2325000 out of 2500000 steps (93%)
21:42:02:WU04:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
21:42:24:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
21:42:24:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
21:42:24:WU00:FS02:Connecting to 171.64.65.104:8080
21:42:24:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
21:42:24:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
21:42:24:WU03:FS01:Connecting to 171.64.65.104:8080
21:42:25:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
21:42:25:WU00:FS02:Connecting to 171.64.65.104:80
21:42:26:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
21:42:26:WU03:FS01:Connecting to 171.64.65.104:80
21:42:26:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:42:26:WU00:FS02:Trying to send results to collection server
21:42:26:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
21:42:26:WU00:FS02:Connecting to 171.65.103.160:8080
21:42:27:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
21:42:27:WU03:FS01:Trying to send results to collection server
21:42:27:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
21:42:27:WU03:FS01:Connecting to 171.65.103.160:8080
21:42:32:WU00:FS02:Upload 21.07%
21:42:33:WU03:FS01:Upload 22.86%
21:42:38:WU00:FS02:Upload 39.64%
21:42:39:WU03:FS01:Upload 39.65%
21:42:44:WU00:FS02:Upload 61.43%
21:42:45:WU03:FS01:Upload 58.94%
21:42:50:WU00:FS02:Upload 82.50%
21:42:51:WU03:FS01:Upload 81.08%
21:42:56:WU00:FS02:Upload complete
21:42:56:WU00:FS02:Server responded PLEASE_WAIT (464)
21:42:56:WARNING:WU00:FS02:Failed to send results, will try again later
21:42:57:WU03:FS01:Upload 98.23%
21:42:57:WU03:FS01:Upload complete
21:42:57:WU03:FS01:Server responded PLEASE_WAIT (464)
21:42:57:WARNING:WU03:FS01:Failed to send results, will try again later
21:43:06:WU02:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
21:44:53:WU01:FS02:0x17:Completed 1950000 out of 5000000 steps (39%)
21:46:29:WU02:FS01:0x21:Completed 275000 out of 2500000 steps (11%)
21:48:29:WU04:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
21:49:49:WU02:FS01:0x21:Completed 300000 out of 2500000 steps (12%)
21:51:39:WU01:FS02:0x17:Completed 2000000 out of 5000000 steps (40%)
21:53:10:WU02:FS01:0x21:Completed 325000 out of 2500000 steps (13%)
21:54:59:WU04:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
21:56:31:WU02:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
21:58:33:WU01:FS02:0x17:Completed 2050000 out of 5000000 steps (41%)
21:59:53:WU02:FS01:0x21:Completed 375000 out of 2500000 steps (15%)
22:00:21:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
22:00:21:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
22:00:21:WU00:FS02:Connecting to 171.64.65.104:8080
22:00:21:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
22:00:21:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
22:00:21:WU03:FS01:Connecting to 171.64.65.104:8080
22:00:22:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
22:00:22:WU00:FS02:Connecting to 171.64.65.104:80
22:00:22:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
22:00:22:WU03:FS01:Connecting to 171.64.65.104:80
22:00:23:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
22:00:23:WU00:FS02:Trying to send results to collection server
22:00:23:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
22:00:23:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
22:00:23:WU00:FS02:Connecting to 171.65.103.160:8080
22:00:23:WU03:FS01:Trying to send results to collection server
22:00:23:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
22:00:23:WU03:FS01:Connecting to 171.65.103.160:8080
22:00:29:WU00:FS02:Upload 16.79%
22:00:29:WU03:FS01:Upload 15.00%
22:00:35:WU03:FS01:Upload 38.58%
22:00:35:WU00:FS02:Upload 40.36%
22:00:41:WU03:FS01:Upload 54.65%
22:00:41:WU00:FS02:Upload 59.29%
22:00:47:WU00:FS02:Upload 77.50%
22:00:47:WU03:FS01:Upload 72.51%
22:00:53:WU00:FS02:Upload 96.43%
22:00:53:WU03:FS01:Upload 89.30%
22:00:55:WU00:FS02:Upload complete
22:00:55:WU00:FS02:Server responded PLEASE_WAIT (464)
22:00:55:WARNING:WU00:FS02:Failed to send results, will try again later
22:00:57:WU03:FS01:Upload complete
22:00:57:WU03:FS01:Server responded PLEASE_WAIT (464)
22:00:57:WARNING:WU03:FS01:Failed to send results, will try again later
22:01:26:WU04:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
22:03:13:WU02:FS01:0x21:Completed 400000 out of 2500000 steps (16%)
22:05:19:WU01:FS02:0x17:Completed 2100000 out of 5000000 steps (42%)
22:05:55:WU05:FS03:0x18:Completed 2350000 out of 2500000 steps (94%)
22:06:35:WU02:FS01:0x21:Completed 425000 out of 2500000 steps (17%)
22:07:50:WU04:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
22:09:55:WU02:FS01:0x21:Completed 450000 out of 2500000 steps (18%)
22:12:13:WU01:FS02:0x17:Completed 2150000 out of 5000000 steps (43%)
22:13:17:WU02:FS01:0x21:Completed 475000 out of 2500000 steps (19%)
22:14:18:WU04:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
22:16:37:WU02:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
22:18:59:WU01:FS02:0x17:Completed 2200000 out of 5000000 steps (44%)
22:19:59:WU02:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
22:20:45:WU04:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
22:23:20:WU02:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
22:25:43:WU01:FS02:0x17:Completed 2250000 out of 5000000 steps (45%)
22:26:41:WU02:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
22:26:57:WU04:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
22:29:23:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
22:29:23:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
22:29:23:WU00:FS02:Connecting to 171.64.65.104:8080
22:29:23:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
22:29:23:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
22:29:23:WU03:FS01:Connecting to 171.64.65.104:8080
22:29:24:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
22:29:24:WU00:FS02:Connecting to 171.64.65.104:80
22:29:24:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
22:29:24:WU03:FS01:Connecting to 171.64.65.104:80
22:29:25:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
22:29:25:WU00:FS02:Trying to send results to collection server
22:29:25:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
22:29:25:WU00:FS02:Connecting to 171.65.103.160:8080
22:29:26:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
22:29:26:WU03:FS01:Trying to send results to collection server
22:29:26:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
22:29:26:WU03:FS01:Connecting to 171.65.103.160:8080
22:29:32:WU03:FS01:Upload 17.50%
22:29:32:WU00:FS02:Upload 19.64%
22:29:38:WU03:FS01:Upload 39.29%
22:29:38:WU00:FS02:Upload 44.29%
22:29:44:WU00:FS02:Upload 63.57%
22:29:44:WU03:FS01:Upload 56.79%
22:29:50:WU03:FS01:Upload 74.30%
22:29:50:WU00:FS02:Upload 82.14%
22:29:55:WU00:FS02:Upload complete
22:29:55:WU00:FS02:Server responded PLEASE_WAIT (464)
22:29:55:WARNING:WU00:FS02:Failed to send results, will try again later
22:29:56:WU03:FS01:Upload 96.44%
22:29:57:WU03:FS01:Upload complete
22:29:57:WU03:FS01:Server responded PLEASE_WAIT (464)
22:29:57:WARNING:WU03:FS01:Failed to send results, will try again later
22:30:01:WU02:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
22:30:43:WU05:FS03:0x18:Completed 2375000 out of 2500000 steps (95%)
22:32:33:WU01:FS02:0x17:Completed 2300000 out of 5000000 steps (46%)
22:33:11:WU04:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
22:33:23:WU02:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
22:36:43:WU02:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
22:39:16:WU01:FS02:0x17:Completed 2350000 out of 5000000 steps (47%)
22:39:20:WU04:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
22:40:05:WU02:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
22:43:25:WU02:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
22:45:38:WU04:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
22:46:06:WU01:FS02:0x17:Completed 2400000 out of 5000000 steps (48%)
22:46:47:WU02:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
22:50:07:WU02:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
22:51:47:WU04:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
22:52:49:WU01:FS02:0x17:Completed 2450000 out of 5000000 steps (49%)
22:53:29:WU02:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
22:55:33:WU05:FS03:0x18:Completed 2400000 out of 2500000 steps (96%)
22:56:49:WU02:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
22:57:59:WU04:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
22:59:31:WU01:FS02:0x17:Completed 2500000 out of 5000000 steps (50%)
23:00:10:WU02:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
23:03:30:WU02:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
23:04:08:WU04:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
23:06:22:WU01:FS02:0x17:Completed 2550000 out of 5000000 steps (51%)
23:06:52:WU02:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
23:10:12:WU02:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
23:10:17:WU04:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
23:13:05:WU01:FS02:0x17:Completed 2600000 out of 5000000 steps (52%)
23:13:34:WU02:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
23:16:22:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
23:16:22:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
23:16:22:WU00:FS02:Connecting to 171.64.65.104:8080
23:16:22:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
23:16:22:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
23:16:22:WU03:FS01:Connecting to 171.64.65.104:8080
23:16:23:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
23:16:23:WU00:FS02:Connecting to 171.64.65.104:80
23:16:23:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
23:16:23:WU03:FS01:Connecting to 171.64.65.104:80
23:16:24:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:16:24:WU00:FS02:Trying to send results to collection server
23:16:24:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
23:16:24:WU00:FS02:Connecting to 171.65.103.160:8080
23:16:25:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
23:16:25:WU03:FS01:Trying to send results to collection server
23:16:25:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
23:16:25:WU03:FS01:Connecting to 171.65.103.160:8080
23:16:30:WU00:FS02:Upload 14.64%
23:16:31:WU03:FS01:Upload 17.15%
23:16:33:WU04:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
23:16:37:WU03:FS01:Upload 35.36%
23:16:37:WU00:FS02:Upload 37.14%
23:16:43:WU03:FS01:Upload 58.58%
23:16:43:WU00:FS02:Upload 62.14%
23:16:49:WU00:FS02:Upload 80.36%
23:16:49:WU03:FS01:Upload 77.15%
23:16:54:WU02:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
23:16:55:WU00:FS02:Upload 99.29%
23:16:55:WU03:FS01:Upload 95.37%
23:16:55:WU00:FS02:Upload complete
23:16:55:WU00:FS02:Server responded PLEASE_WAIT (464)
23:16:55:WARNING:WU00:FS02:Failed to send results, will try again later
23:16:56:WU03:FS01:Upload complete
23:16:56:WU03:FS01:Server responded PLEASE_WAIT (464)
23:16:56:WARNING:WU03:FS01:Failed to send results, will try again later
23:19:55:WU01:FS02:0x17:Completed 2650000 out of 5000000 steps (53%)
23:20:16:WU02:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
23:20:26:WU05:FS03:0x18:Completed 2425000 out of 2500000 steps (97%)
23:22:44:WU04:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
23:23:36:WU02:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
23:26:38:WU01:FS02:0x17:Completed 2700000 out of 5000000 steps (54%)
23:26:58:WU02:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
23:28:58:WU04:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
23:30:18:WU02:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
23:33:23:WU01:FS02:0x17:Completed 2750000 out of 5000000 steps (55%)
23:33:41:WU02:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
23:35:22:WU04:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
23:37:01:WU02:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
23:40:17:WU01:FS02:0x17:Completed 2800000 out of 5000000 steps (56%)
23:40:23:WU02:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
23:41:55:WU04:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
23:43:43:WU02:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
23:45:16:WU05:FS03:0x18:Completed 2450000 out of 2500000 steps (98%)
23:47:03:WU01:FS02:0x17:Completed 2850000 out of 5000000 steps (57%)
23:47:06:WU02:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
23:47:51:Removing old file 'configs/config-20160314-190416.xml'
23:47:51:Saving configuration to config.xml
23:47:51:<config>
23:47:51:  <!-- Network -->
23:47:51:  <proxy v=':8080'/>
23:47:51:
23:47:51:  <!-- User Information -->
23:47:51:  <passkey v='********************************'/>
23:47:51:  <team v='111065'/>
23:47:51:  <user v='Andmanpro'/>
23:47:51:
23:47:51:  <!-- Folding Slots -->
23:47:51:  <slot id='0' type='CPU'/>
23:47:51:  <slot id='1' type='GPU'/>
23:47:51:  <slot id='2' type='GPU'/>
23:47:51:  <slot id='3' type='GPU'/>
23:47:51:</config>
23:48:35:WU04:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
23:50:28:WU02:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
23:53:53:WU02:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
23:54:05:WU01:FS02:0x17:Completed 2900000 out of 5000000 steps (58%)
23:57:16:WU04:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
23:57:16:WU06:FS00:Connecting to 171.67.108.45:8080
23:57:16:WU06:FS00:Assigned to work server 171.67.108.158
23:57:16:WU06:FS00:Requesting new work unit for slot 00: RUNNING cpu:1 from 171.67.108.158
23:57:16:WU06:FS00:Connecting to 171.67.108.158:8080
23:57:17:WU06:FS00:Downloading 807.18KiB
23:57:17:WU06:FS00:Download complete
23:57:17:WU06:FS00:Received Unit: id:06 state:DOWNLOAD error:NO_ERROR project:9038 run:140 clone:0 gen:88 core:0xa4 unit:0x0000005fab436c9e56982a2d765998f4
23:57:20:WU02:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
00:00:49:WU02:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
00:01:08:WU01:FS02:0x17:Completed 2950000 out of 5000000 steps (59%)
00:04:10:WU02:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
00:05:27:WU04:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
00:05:28:WU04:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:05:38:WU04:FS00:0xa4:
00:05:38:WU04:FS00:0xa4:Finished Work Unit:
00:05:38:WU04:FS00:0xa4:- Reading up to 811536 from "04/wudata_01.trr": Read 811536
00:05:38:WU04:FS00:0xa4:trr file hash check passed.
00:05:38:WU04:FS00:0xa4:- Reading up to 747744 from "04/wudata_01.xtc": Read 747744
00:05:38:WU04:FS00:0xa4:xtc file hash check passed.
00:05:38:WU04:FS00:0xa4:edr file hash check passed.
00:05:38:WU04:FS00:0xa4:logfile size: 21964
00:05:38:WU04:FS00:0xa4:Leaving Run
00:05:42:WU04:FS00:0xa4:- Writing 1583732 bytes of core data to disk...
00:05:42:WU04:FS00:0xa4:Done: 1583220 -> 1538823 (compressed to 97.1 percent)
00:05:42:WU04:FS00:0xa4:  ... Done.
00:05:43:WU04:FS00:0xa4:- Shutting down core
00:05:43:WU04:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
00:05:43:WU04:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:05:43:WU04:FS00:Sending unit results: id:04 state:SEND error:NO_ERROR project:9038 run:732 clone:2 gen:74 core:0xa4 unit:0x00000055ab436c9e5698292e06757991
00:05:43:WU04:FS00:Uploading 1.47MiB to 171.67.108.158
00:05:43:WU04:FS00:Connecting to 171.67.108.158:8080
00:05:43:WU06:FS00:Starting
00:05:43:WU06:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 06 -suffix 01 -version 704 -lifeline 8964 -checkpoint 15
00:05:43:WU06:FS00:Started FahCore on PID 7640
00:05:43:WU06:FS00:Core PID:8696
00:05:43:WU06:FS00:FahCore 0xa4 started
00:05:43:WU06:FS00:0xa4:
00:05:43:WU06:FS00:0xa4:*------------------------------*
00:05:43:WU06:FS00:0xa4:Folding@Home Gromacs GB Core
00:05:43:WU06:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:05:43:WU06:FS00:0xa4:Preparing to commence simulation
00:05:43:WU06:FS00:0xa4:- Looking at optimizations...
00:05:43:WU06:FS00:0xa4:- Created dyn
00:05:43:WU06:FS00:0xa4:- Files status OK
00:05:43:WU06:FS00:0xa4:- Expanded 826040 -> 1402860 (decompressed 169.8 percent)
00:05:44:WU06:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826040 data_size=1402860, decompressed_data_size=1402860 diff=0
00:05:44:WU06:FS00:0xa4:- Digital signature verified
00:05:44:WU06:FS00:0xa4:Project: 9038 (Run 140, Clone 0, Gen 88)
00:05:44:WU06:FS00:0xa4:Assembly optimizations on if available.
00:05:44:WU06:FS00:0xa4:Entering M.D.
00:05:44:WU04:FS00:Upload complete
00:05:44:WU04:FS00:Server responded WORK_ACK (400)
00:05:44:WU04:FS00:Final credit estimate, 762.00 points
00:05:44:WU04:FS00:Cleaning up
00:05:49:WU06:FS00:0xa4:Mapping NT from 1 to 1
00:05:50:WU06:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
00:07:33:WU02:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
00:07:56:WU01:FS02:0x17:Completed 3000000 out of 5000000 steps (60%)
00:10:08:WU05:FS03:0x18:Completed 2475000 out of 2500000 steps (99%)
00:10:53:WU02:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
00:12:49:WU06:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
00:14:18:WU02:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
00:14:56:WU01:FS02:0x17:Completed 3050000 out of 5000000 steps (61%)
00:17:41:WU02:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
00:21:06:WU02:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
00:21:57:WU06:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
00:21:57:WU01:FS02:0x17:Completed 3100000 out of 5000000 steps (62%)
00:24:29:WU02:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
00:27:55:WU02:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
00:29:05:WU01:FS02:0x17:Completed 3150000 out of 5000000 steps (63%)
00:31:09:WU06:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
00:31:19:WU02:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
00:32:23:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
00:32:23:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
00:32:23:WU00:FS02:Connecting to 171.64.65.104:8080
00:32:23:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
00:32:23:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
00:32:23:WU03:FS01:Connecting to 171.64.65.104:8080
00:32:24:WARNING:WU00:FS02:WorkServer connection failed on port 8080 trying 80
00:32:24:WU00:FS02:Connecting to 171.64.65.104:80
00:32:24:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
00:32:24:WU03:FS01:Connecting to 171.64.65.104:80
00:32:25:WARNING:WU00:FS02:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
00:32:25:WU00:FS02:Trying to send results to collection server
00:32:25:WU00:FS02:Uploading 17.50MiB to 171.65.103.160
00:32:25:WU00:FS02:Connecting to 171.65.103.160:8080
00:32:26:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 171.64.65.104:80: No connection could be made because the target machine actively refused it.
00:32:26:WU03:FS01:Trying to send results to collection server
00:32:26:WU03:FS01:Uploading 17.50MiB to 171.65.103.160
00:32:26:WU03:FS01:Connecting to 171.65.103.160:8080
00:32:31:WU00:FS02:Upload 16.43%
00:32:32:WU03:FS01:Upload 18.22%
00:32:37:WU00:FS02:Upload 40.00%
00:32:38:WU03:FS01:Upload 41.43%
00:32:43:WU00:FS02:Upload 57.50%
00:32:44:WU03:FS01:Upload 60.37%
00:32:49:WU00:FS02:Upload 76.07%
00:32:50:WU03:FS01:Upload 77.87%
00:32:55:WU00:FS02:Upload complete
00:32:55:WU00:FS02:Server responded PLEASE_WAIT (464)
00:32:55:WARNING:WU00:FS02:Failed to send results, will try again later
00:32:55:WU03:FS01:Upload complete
00:32:56:WU03:FS01:Server responded PLEASE_WAIT (464)
00:32:56:WARNING:WU03:FS01:Failed to send results, will try again later
00:34:46:WU02:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
00:35:01:WU05:FS03:0x18:Completed 2500000 out of 2500000 steps (100%)
00:35:02:WU04:FS03:Connecting to 171.67.108.45:80
00:35:02:WU04:FS03:Assigned to work server 171.64.65.92
00:35:02:WU04:FS03:Requesting new work unit for slot 03: RUNNING gpu:2:GM206 [GeForce GTX 960] from 171.64.65.92
00:35:02:WU04:FS03:Connecting to 171.64.65.92:8080
00:35:04:WU04:FS03:Downloading 2.87MiB
00:35:05:WU04:FS03:Download complete
00:35:05:WU04:FS03:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:9161 run:182 clone:0 gen:132 core:0x18 unit:0x00000095ab40415c5674665b6ae1361e
00:35:07:WU05:FS03:0x18:Saving result file logfile_01.txt
00:35:07:WU05:FS03:0x18:Saving result file checkpointState.xml
00:35:08:WU05:FS03:0x18:Saving result file checkpt.crc
00:35:08:WU05:FS03:0x18:Saving result file log.txt
00:35:08:WU05:FS03:0x18:Saving result file positions.xtc
00:35:09:WU05:FS03:0x18:Folding@home Core Shutdown: FINISHED_UNIT
00:35:10:WU05:FS03:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:35:10:WU05:FS03:Sending unit results: id:05 state:SEND error:NO_ERROR project:9156 run:86 clone:0 gen:161 core:0x18 unit:0x000000bdab40415456737dd809ebcd1d
00:35:10:WU05:FS03:Uploading 5.51MiB to 171.64.65.84
00:35:10:WU05:FS03:Connecting to 171.64.65.84:8080
00:35:10:WU04:FS03:Starting
00:35:10:WU04:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/andyl/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 04 -suffix 01 -version 704 -lifeline 8964 -checkpoint 15 -gpu 2 -gpu-vendor nvidia
00:35:10:WU04:FS03:Started FahCore on PID 7304
00:35:10:WU04:FS03:Core PID:6212
00:35:10:WU04:FS03:FahCore 0x18 started
00:35:10:WU04:FS03:0x18:*********************** Log Started 2016-03-17T00:35:10Z ***********************
00:35:10:WU04:FS03:0x18:Project: 9161 (Run 182, Clone 0, Gen 132)
00:35:10:WU04:FS03:0x18:Unit: 0x00000095ab40415c5674665b6ae1361e
00:35:10:WU04:FS03:0x18:CPU: 0x00000000000000000000000000000000
00:35:10:WU04:FS03:0x18:Machine: 3
00:35:10:WU04:FS03:0x18:Reading tar file core.xml
00:35:10:WU04:FS03:0x18:Reading tar file system.xml
00:35:10:WU04:FS03:0x18:Reading tar file integrator.xml
00:35:10:WU04:FS03:0x18:Reading tar file state.xml
00:35:11:WU04:FS03:0x18:Digital signatures verified
00:35:11:WU04:FS03:0x18:Folding@home GPU core18
00:35:11:WU04:FS03:0x18:Version 0.0.4
00:35:20:WU05:FS03:Upload complete
00:35:20:WU05:FS03:Server responded WORK_ACK (400)
00:35:20:WU05:FS03:Final credit estimate, 4556.00 points
00:35:20:WU05:FS03:Cleaning up
00:35:28:WU04:FS03:0x18:Completed 0 out of 2500000 steps (0%)
00:35:28:WU04:FS03:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:36:03:WU01:FS02:0x17:Completed 3200000 out of 5000000 steps (64%)
00:38:13:WU02:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
00:39:28:FS01:Shutting core down
00:39:28:FS02:Shutting core down
00:39:28:FS03:Shutting core down
00:39:28:WU02:FS01:0x21:WARNING:Console control signal 1 on PID 11860
00:39:28:WU02:FS01:0x21:Exiting, please wait. . .
00:39:28:WU01:FS02:0x17:WARNING:Console control signal 1 on PID 11664
00:39:28:WU01:FS02:0x17:Exiting, please wait. . .
00:39:28:WU01:FS02:0x17:Folding@home Core Shutdown: INTERRUPTED
00:39:28:WU04:FS03:0x18:WARNING:Console control signal 1 on PID 6212
00:39:28:WU04:FS03:0x18:Exiting, please wait. . .
00:39:28:WU04:FS03:0x18:Lost lifeline PID 7304, exiting
00:39:28:WU04:FS03:0x18:ERROR:103: Lost client lifeline
00:39:28:WU04:FS03:0x18:Folding@home Core Shutdown: CLIENT_DIED
00:39:28:WU01:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
00:39:28:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:39:28:WU04:FS03:FahCore returned: INTERRUPTED (102 = 0x66)
00:39:42:Removing old file 'configs/config-20160314-191325.xml'
00:39:42:Saving configuration to config.xml
00:39:42:<config>
00:39:42:  <!-- Network -->
00:39:42:  <proxy v=':8080'/>
00:39:42:
00:39:42:  <!-- Slot Control -->
00:39:42:  <power v='light'/>
00:39:42:
00:39:42:  <!-- User Information -->
00:39:42:  <passkey v='********************************'/>
00:39:42:  <team v='111065'/>
00:39:42:  <user v='Andmanpro'/>
00:39:42:
00:39:42:  <!-- Folding Slots -->
00:39:42:  <slot id='0' type='CPU'/>
00:39:42:  <slot id='1' type='GPU'/>
00:39:42:  <slot id='2' type='GPU'/>
00:39:42:  <slot id='3' type='GPU'/>
00:39:42:</config>
00:40:34:WU06:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
00:47:47:WU06:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
00:55:19:WU06:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
01:02:35:WU06:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
01:10:10:WU06:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
01:18:23:WU06:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
01:25:23:WU06:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
******************************* Date: 2016-03-17 *******************************
01:32:36:WU06:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
01:41:20:WU06:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
01:48:54:WU06:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
01:55:43:WU06:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
02:02:03:WU06:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
02:08:06:WU06:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
02:16:45:WU06:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
02:23:05:WU06:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
02:28:47:WU06:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
02:34:23:WU06:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
02:35:22:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:1 clone:25 gen:25 core:0x21 unit:0x00000064664f2dd055ee43f07161386d
02:35:22:WU00:FS02:Uploading 17.50MiB to 171.64.65.104
02:35:22:WU00:FS02:Connecting to 171.64.65.104:8080
02:35:23:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:9213 run:2 clone:32 gen:27 core:0x21 unit:0x0000007a664f2dd055ee6106ea83c0ec
02:35:23:WU03:FS01:Uploading 17.50MiB to 171.64.65.104
02:35:23:WU03:FS01:Connecting to 171.64.65.104:8080
02:35:28:WU00:FS02:Upload 3.21%
02:35:29:WU03:FS01:Upload 6.43%
02:35:34:WU00:FS02:Upload 7.14%
02:35:35:WU03:FS01:Upload 12.50%
02:35:40:WU00:FS02:Upload 11.43%
02:35:41:WU03:FS01:Upload 19.29%
02:35:46:WU00:FS02:Upload 15.36%
02:35:47:WU03:FS01:Upload 25.00%
02:35:52:WU00:FS02:Upload 18.93%
02:35:53:WU03:FS01:Upload 30.72%
02:35:58:WU00:FS02:Upload 21.43%
02:35:59:WU03:FS01:Upload 36.43%
02:36:04:WU00:FS02:Upload 25.36%
02:36:05:WU03:FS01:Upload 42.15%
02:36:10:WU00:FS02:Upload 28.93%
02:36:11:WU03:FS01:Upload 47.86%
02:36:16:WU00:FS02:Upload 34.64%
02:36:17:WU03:FS01:Upload 54.29%
02:36:22:WU00:FS02:Upload 37.86%
02:36:23:WU03:FS01:Upload 60.01%
02:36:28:WU00:FS02:Upload 41.79%
02:36:29:WU03:FS01:Upload 65.72%
02:36:34:WU00:FS02:Upload 45.00%
02:36:35:WU03:FS01:Upload 71.08%
02:36:40:WU00:FS02:Upload 48.22%
02:36:41:WU03:FS01:Upload 76.80%
02:36:46:WU00:FS02:Upload 52.14%
02:36:47:WU03:FS01:Upload 82.87%
02:36:52:WU00:FS02:Upload 55.72%
02:36:53:WU03:FS01:Upload 89.30%
02:36:58:WU00:FS02:Upload 58.93%
02:36:59:WU03:FS01:Upload 95.37%
02:37:04:WU00:FS02:Upload 63.57%
02:37:04:WU03:FS01:Upload complete
02:37:04:WU03:FS01:Server responded WORK_QUIT (404)
02:37:04:WARNING:WU03:FS01:Server did not like results, dumping
02:37:04:WU03:FS01:Cleaning up
02:37:10:WU00:FS02:Upload 66.79%
02:37:16:WU00:FS02:Upload 71.43%
02:37:22:WU00:FS02:Upload 75.00%
02:37:28:WU00:FS02:Upload 78.22%
02:37:34:WU00:FS02:Upload 82.14%
02:37:40:WU00:FS02:Upload 85.36%
02:37:46:WU00:FS02:Upload 88.57%
02:37:52:WU00:FS02:Upload 92.50%
02:37:58:WU00:FS02:Upload 96.43%
02:38:00:WU00:FS02:Upload complete
02:38:00:WU00:FS02:Server responded WORK_QUIT (404)
02:38:00:WARNING:WU00:FS02:Server did not like results, dumping
02:38:00:WU00:FS02:Cleaning up
02:40:14:WU06:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
02:45:56:WU06:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
02:51:51:WU06:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
02:57:46:WU06:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
03:03:21:WU06:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
03:09:13:WU06:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
03:14:44:WU06:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
03:21:32:WU06:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
03:27:58:WU06:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
03:35:35:WU06:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
03:41:41:WU06:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
03:48:11:WU06:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
03:56:52:WU06:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
04:05:43:WU06:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
04:13:17:WU06:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
04:20:13:WU06:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
04:29:26:WU06:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
04:37:30:WU06:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
04:46:28:WU06:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
04:54:09:WU06:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
05:02:28:WU06:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
05:11:54:WU06:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
05:20:51:WU06:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
05:27:09:WU06:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
05:34:16:WU06:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
05:43:24:WU06:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
05:50:56:WU06:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
06:00:18:WU06:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
06:07:46:WU06:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
06:15:54:WU06:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
06:24:49:WU06:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
06:33:53:WU06:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
06:42:10:WU06:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
06:49:26:WU06:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
06:57:41:WU06:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
07:06:19:WU06:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
07:15:11:WU06:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
07:21:51:WU06:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
07:26:32:WU06:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
07:31:11:WU06:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
