I got a great deal on a quad core AMD FX-4150 this holiday season so I've installed the Linux client and am running it anonymously. I understand it may take weeks to finish one work unit, but I have not seen any change in the progress bar and there is no ETA. How long can I expect it to register 0.01% progress, and should I register rather than work anonymously - does that have any impact on how likely the work is registered or lost?
BTW System temp and processor activity level does show the system is working locally, I just want to make sure the work is being uploaded.
Easiest way to check it's working?
wilding2004
Re: Easiest way to check it's working?
It shouldn't take weeks, not even days. How long has it been running (or not)?
If you run "top" it should show FahCore_a4 using a lot of processor time. FAHClient should also be running, but it won't be using much CPU time so it may not appear on the first page.
