One note do not attempt running a game in Mantle mode while folding unless you like bluescreens haven't tested it with this driver and not going to
http://support.amd.com/en-us/kb-article ... -Beta.aspx
I don't know whether you're running a CPU slot alongside you GPU one, but some projects (like p13xxx) don't like when something interfere with the core on the CPU. Try to pause your CPU slot, or free more threads (SMP 6 on a 8 threads CPU for instance).DarkFoss wrote:The 13.4.1 beta has been working well for me overall. Outside of the occasional wu that doesn't seem to stress the card enough like my current 13104 (2, 31, 51) gpu load never hits 100% always stops at 99% temps low too 48-49c, still TPF is only 4 seconds slower than the 16.3 driver. Last week I reinstalled the 16.3 then let the driver update to 16.3.1 then 16.3.2 the results for the week'
Week Points WUs
03.27.16 2,572,246 36
imo not bad for a single card. I let the driver update to the 16.4.1 on Monday so far looks to be another good week of production.
I wouldn't worry about that 1%. There's always some time spend moving data between RAM and VRAM through the bus. The time to move data actually causes a bigger percentage of wait-state on a fast card than on a slower one because the computations are faster while the data transfers don't change. The GPU will run out of work sooner until more can be supplied.DarkFoss wrote:... gpu load never hits 100% always stops at 99% temps low too 48-49c...
Okay, so... first of all, the gpu usage never goes up to 100%, it always stops at 99% (guess it depends on what program you're using)DarkFoss wrote:The 13.4.1 beta has been working well for me overall. Outside of the occasional wu that doesn't seem to stress the card enough like my current 13104 (2, 31, 51) gpu load never hits 100% always stops at 99% temps low too 48-49c, still TPF is only 4 seconds slower than the 16.3 driver. Last week I reinstalled the 16.3 then let the driver update to 16.3.1 then 16.3.2 the results for the week'
Week Points WUs
