Folding on different generation cards at the same time
So I've been folding on a single GT 630 on my downloads server all this time but I just got a 9500 GT for free and would like to use it until it's dead. But the problem is the drivers for the GT 630 on windows 10 doesn't seem to support the 9500 GT and the 9500 GT drivers on windows 10 doesn't support the GT 630 either. I don't know what to do can you guys help me or point me to a driver that supports both? If I install both drivers the driver that's installed is the last one that I install not both so it doesn't work that way.
Folding on a GT 630 24/7
Re: Folding on different generation cards at the same time
Go to the NVidia driver site and see what they recommend. They may (or may not) have drivers that support both.
Please post the information described below.
I tried to find and it seems they don't have any for windows 10? I tried installing the old 9500 GT drivers first while disabling the GT 630 then I install the GT 630 drivers while disabling the 9500 GT. The 9500 GT wasn't being read properly in GPU-Z but after changing max-packet-size to small and client-type beta the GPU slot for the 9500 GT is actually running on core 15 but it says ETA is 38 days??? I don't know but is improper driver install possibly ruining the ETA? Or is it just the initial ETA and isn't accurate yet.bruce wrote:Go to the NVidia driver site and see what they recommend. They may (or may not) have drivers that support both.
Initial estimate for ETA and PPD will be off, especially if the installation is fresh and a WU from that project has not been processed before. After completing a few percent, the estimate should settle down to being more accurate.
GT 630 is a popular name and several different GPUs have used that name. Which one do you have? Does it have a GF108, a GK107 or a GK208 chip?
Apparently all support CUDA Compute Capability 3.0 but some support OpenCL 1.1 and others support OpenCL 1.2.
There MIGHT be an obsolete driver that supports the G92 at the same time.
Are you sure the GPUs are identified correctlY? FAH sometimes mixes them up. Does CPU-Z tell you which one is getting hot?
Ahh ok well you seem to be right as right now it goes down to 13 days after 3% overnight and is showing about 1K ppd which I'm pretty fine as anything helps hahahJoe_H wrote:Initial estimate for ETA and PPD will be off, especially if the installation is fresh and a WU from that project has not been processed before. After completing a few percent, the estimate should settle down to being more accurate.
I have the GK208 Kepler card with the 384 cores because I thought it should be the most powerful, so it's pretty new as being the same as a GT 730. It's both properly recognized and folding in F@H right now but my problem is I can't access the 9500GT sensors and that means I can't overclock it either. The card is a fixed clock card though so it should still be running at the factory 550MHz and now downclocking with improper drivers I think. Is 1K PPD good enough for a 9500GT? It's doing a project 7624 currently.bruce wrote:GT 630 is a popular name and several different GPUs have used that name. Which one do you have? Does it have a GF108, a GK107 or a GK208 chip?
So are you saying that both GPUs are folding, in spite of the driver discrepancies?
Yea Ive only just managed to get them to work. They are folding yes except i can't access the 9500GT sensors nor overlock it.bruce wrote:So are you saying that both GPUs are folding, in spite of the driver discrepancies?
I am suprised there are any WUs for a card as old as the 9500GT, Core_11 was designed for that generation. (Tesla) No projects have used a Core_11 WUs in 2 years. Some have reported tricking Tesla GPUs into running Core_15 WUs (Core_15 is EOL but there are still some projects using it) using a configuration trick.
Configure the following options to your 9500 GT GPU slot:
max-packet-size set to small
client-type set to beta
(these are not beta WUs, that is part of the trick)
Yep that's what I did and I got Core_15 WUs or it actually. But thanks for the help tooJimboPalmer wrote:I am suprised there are any WUs for a card as old as the 9500GT, Core_11 was designed for that generation. (Tesla) No projects have used a Core_11 WUs in 2 years. Some have reported tricking Tesla GPUs into running Core_15 WUs (Core_15 is EOL but there are still some projects using it) using a configuration trick.
