Project: 2652 (Run 0, Clone 236, Gen 23) dodgy ?
spike09
Hardware configuration: 2 x q6600's with 2 GB pc6400 , e6400 2 Gb pc 6400, x2 3800 1Gb PC 3200, athlon 3700, 1GB pc3200, athlaon 2200 512MB pc 2700
Post by spike09 »
Hi folks can some one check if anyone else has completed this wu or not
07:15:28] Project: 2652 (Run 0, Clone 236, Gen 23)
[07:15:28]
[07:15:28] Assembly optimizations on if available.
[07:15:28] Entering M.D.
[07:15:35] Calling FAH init
[07:15:35] Writing local files
[07:15:35] Extra SSE boost OK.
[07:15:35]
[07:15:35] Read checkpoint
[07:15:35] Protein: Protein
[07:15:36] Extra SSE boost OK.
[07:15:36] Writing local files
[07:15:36] Completed 0 out of 1000000 steps  (0 percent)
[07:25:53] Writing local files
[07:25:53] Completed 10000 out of 1000000 steps  (1 percent)
[07:36:11] Writing local files
[07:36:11] Completed 20000 out of 1000000 steps  (2 percent)
[07:46:29] Writing local files
[07:46:29] Completed 30000 out of 1000000 steps  (3 percent)
[07:51:18] k forWarning:  check for stray files
[07:51:18]
[07:51:18] Folding@home Core Shutdown: EARLY_UNIT_END
[07:51:18] Finalizing output
[07:51:18] 1168 bytes of core data to disk...
[07:51:18]   ... Done.
[07:51:18] - Failed to delete work/wudata_01.sas
[07:51:18] - Failed to delete work/wudata_01.goe
[07:51:18] - Failed to delete work/wudata_01.pdo
[07:51:18] - Failed to delete work/wudata_01.xvg
[07:51:18] Warning:  check for stray files
Please just cut and paste the project numbers from the log file. The format p 2652 r 0 c 236 g 23 is barely legible. Thread title changed. 7hanks.
team 46590 :)
This will help you to submit partial results : http://www.foldingforum.org/viewtopic.php?t=191 ;)
spike09
Post by spike09 »
I checked no results file in there for some reason :(
team 46590 :)
Re: Project: 2652 (Run 0, Clone 236, Gen 23) dodgy ?
spike09 wrote:Hi folks can some one check if anyone else has completed this wu or not
It has been returned by many people but none have received the full credit of 1148 so it's likely still being redistributed. Spike09 is not on the list.
What happened after the end of the FAHlog you posted? Did it delete the WU or upload the results? If it deleted the WU did you try qfix?
spike09
Post by spike09 »
right it has been sent totow you might want to amend this line to reflect using the CD command
4- go to your FAH folder mebbe 4- CD to your fah folder. it had me going loopy until brain kicked in :oops: :lol:
team 46590 :)
I thought it was obvious :shock:
spike09
Post by spike09 »
What is obvious to one can be obfuscation to another :lol:
team 46590 :)
