IP of all FAH servers
jabacrack
Post by jabacrack »
Hi,
Can I anywere get full IPs list of assignment, work and collection servers?
Re: IP of all FAH servers
Click on the Server Status link in the header of the forum ...
Also, Project Summary link will show which server hosts which FAH project ...
jabacrack
Post by jabacrack »
Thank you. I right understand, that servers ip I can get only from Project Summary page?
davidcoton
Post by davidcoton »
All the WS IPs used to be listed on the Server Status page, but that seems to have been removed -- only the server name is now shown. The Project Summary shows the WS IP but not the name. AS and CS don't seem to be listed at all -- AS are easy to find from your log, CS might be shown for a project you run.
Out of curiosity, why do you want all the IPs? It seems the sort of info needed for a DOS attack, and not relevant to normal folding.
What exactly is the reason you want the server IP's? Any information you can get from the status pages will be incomplete, and subject to change. Better is to understand that the FAHClient process just needs to be given http or https access to incoming and outgoing data over ports 80 and/or 8080. That is the same access needed for a web browser.
Currently the Server Status page shows server names instead of IP addresses in the IP column, don't know when or if that will get fixed. What addresses are listed on the Project Summary page are only for current projects, and a few recently completed or changed projects. Not included there are a number of other servers that may need to be contacted in the course of running the folding client.
jabacrack
Post by jabacrack »
I think I'm banned, because I'm from Crimea. When I route all my traffic via vpn in Europe all work fine. Otherwise client cannot connect and download new Work Unit.
I have three solutions route all request to FAH servers via vpn, setup proxy only for FAH client, route all my traffic via vpn. In this moment I'm preffer first solution.
How I'm see there several ip pools. I try to route its and look how it works.
As far as I know, there are no bans in place on the folding server sites based on location. There are contributors to folding from all over including Russia, China and a few more known for restrictive firewalls on their connections to the rest of the Internet. You may be running into problems with firewalls set up by ISP's in your country.
jabacrack
Post by jabacrack »
Yes your ips may be banned in Russia if its host sites with illegal content, is it? But solution is one - vpn. Little later I try to investigate who ban me.
jabacrack
Post by jabacrack »
No, this is not my ISP firewall.
There traceroute to 171.67.108.45 (one of FAH ip)
traceroute to 171.67.108.45 (171.67.108.45), 30 hops max, 38 byte packets
 1  10.10.1.120 (10.10.1.120)  21.287 ms  17.252 ms  13.621 ms
 2  gw1.sevstar.net (109.110.64.1)  6.668 ms  5.990 ms  13.659 ms
 3  ae5-535.SVSL-00-AR1.miranda-media.net (185.64.47.165)  0.993 ms  0.894 ms  0.843 ms
 4  ae4-0.SMFL-04-CR2.miranda-media.net (185.64.45.66)  8.488 ms  ae4-0.SMFL-04-CR1.miranda-media.net (185.64.45.64)  2.064 ms  ae4-0.SMFL-04-CR2.miranda-media.net (185.64.45.66)  6.590 ms
 5  rostelecom-b-gw.miranda-media.net (185.64.45.5)  13.570 ms  13.579 ms  rostelecom-a-gw.miranda-media.net (185.64.45.3)  26.602 ms
 6  87.226.133.80 (87.226.133.80)  70.579 ms  *  72.465 ms
 7  87.226.228.42 (87.226.228.42)  58.610 ms  48.532 ms  48.654 ms
 8  10ge12-6.core1.ams1.he.net (72.52.92.45)  107.179 ms  106.430 ms  82.237 ms
 9  100ge9-1.core1.lon2.he.net (72.52.92.213)  76.520 ms  100ge5-2.core1.par2.he.net (72.52.92.13)  74.288 ms  83.356 ms
10  100ge7-1.core1.nyc4.he.net (184.105.81.77)  145.243 ms  152.882 ms  150.197 ms
11  100ge15-2.core1.sjc2.he.net (184.105.81.213)  215.223 ms  215.699 ms  211.168 ms
12  10ge3-3.core1.pao1.he.net (72.52.92.69)  213.909 ms  213.137 ms  210.237 ms
13  216.218.209.118 (216.218.209.118)  208.630 ms  204.623 ms  208.650 ms
14  west-rtr-vlan8.SUNet (171.64.255.193)  209.994 ms  203.667 ms  208.042 ms
15  *  *  *
etc.
Without vpn I get timeout error when try to connect to this ip (open it in browser, for example).
_r2w_ben
Post by _r2w_ben »
Your traceroute fails at *.SUNet, which is similar to a donor from Brazil. This is the first hop onto Stanford's network. I suspect but have no way to confirm that either your exact IP or a range of IPs is being blocked by Stanford's firewall. The previous person your ISP assigned the IP to may have used it to send spam or launch a DDoS attack. Since FAH staff do not have access to the university's firewall rules, it's difficult to get confirmation.
Does your current IP show up on any blacklists? If you power cycle your networking equipment and get a different IP, does the traceroute change?
jabacrack
Post by jabacrack »
Yep, my ip in 4 blacklist: BARRACUDA, Protected Sky, SORBS DUHL, Spamhaus ZEN. My ISP doesn't often change clients ip and reconnect doesn't help with it.
I don't know what Protected Sky, SORBS DUHL and Spamhaus ZEN are used for, but my IP is listed in the 3 lists ... So I wouldn't trust these results a lot : I'm from France and have no problem to access Stanford servers.
Do you have access to the server in your browser using all possible combinations (IP only vs host name, http vs https, 80 vs 8080) ?
jabacrack
Post by jabacrack »
I don't know what host correspond this ip, but any suggested combination for ip doesn't work.
From the Los Angeles area:
>tracert vsp11.stanford.edu
Tracing route to vsp11.stanford.edu [171.67.108.45]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 10 ms 13 ms 10 ms 208.127.217.1
3 15 ms 13 ms 10 ms lax1_cr1_3_0_306.dslextreme.com [66.51.202.17]
4 122 ms 81 ms 109 ms hurricane-electric.as6939.any2ix.coresite.com [206.72.210.122]
5 18 ms 24 ms 24 ms 100ge8-2.core1.pao1.he.net [184.105.81.237]
6 26 ms 21 ms 18 ms 216.218.209.118
7 19 ms 19 ms 19 ms west-rtr-vlan8.SUNet [171.64.255.193]
8 18 ms 18 ms 18 ms VSP11.stanford.edu [171.67.108.45]
Trace complete.
_r2w_ben
Post by _r2w_ben »
toTOW wrote:I don't know what Protected Sky, SORBS DUHL and Spamhaus ZEN are used for, but my IP is listed in the 3 lists ... So I wouldn't trust these results a lot : I'm from France and have no problem to access Stanford servers.
There are descriptions for most of the blacklists.
