I got the problem that the programm pushes the GPU to 99-100% wich results in massiv fan noise and temps of about 83 C.
Thanks in advance (:
-AuxiliusM
Nvidia GTX 550 Ti
PS3EdOlkkola
9 AMD GPU folding slots
31 Nvidia GPU folding slots
50 total folding slots
Re: Nvidia GTX 550 Ti
Welcome AuxiliusM
In actuality, the problem you describe is the expected result of running the F@h application. The intention is to fully utilize the compute performance available in your GTX 550ti, which means the GPU will be maxed out and you'll generate a good amount of heat and consequent fan noise. You can try moving the "Folding Power" slider to Medium or Light to decrease the amount of time the GPU kicks in, waiting for the computer to be idle, which is when you're most likely away from it and the noise may not bother you as much.
Unfortunately, there are no intermediate settings for a GPU. It either runs at ~99% or it's off (unlike some other parts of your computer). By running it only when the computer is idle, hopefully you'll shift the time the fans run to a time when you're not near the computer.
You ight consider improving the case ventilation. That might reduce the speed of the GPU fan, resulting in a net reduction in noise.
I would also love to undervolt or just turn down the CPU while the noise could disturb me but that probably wouldn´t meet the expiration date so the efford is pretty much useless
is there any way to pick the length of a folding process? If yes how? bec. so i could utilise about 8 hours of cpu per day. If not does it hurt to delete the gpu slot untill a reasonable tasks with a fitting timeframe appears?
Run core 15 projects which have a longer deadline.
Duce H_K_
- Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w - Location: Russia
I downvolted GTX560ti by Zotac (when I had It) with default clock remained using BIOS tweaker. That helped to reduce temperature so I could run fan slower. Due to complete imperfection of Zotac's fan I replaced it with two 60mm fans stolen from AMD BOX cooler. And started to hear PSU noise while videocard worked more silent
I might try this ^_^ thx for all the help post can be closed
