only one of my folding tabs is on.
Azul_Drake
Post by Azul_Drake »
I seem to be encountering a problem with my folding, although since I'm a new user, it's probably just PEBKAC.
in my folding @ home web control, I have two folding stuff going on (in theory). The right tab seems to be working fine. However, the left tab is not. I have a yellow circle, next to a line that says CPU: 3 and a bar that says 0.00% . Below, is this writing:
ready	--				        0 (0, 0, 0) 			0.00 secs 				0
Ready.	Points per day	Work Unit (PRCG) 	Work Unit (ETA) 	Estimated Points
My computer has unknown time to complete this work unit.
How do I fix it, so that both my tabs are running.
I am running windows 10, F@H version 7.44
P.S. Sorry about the bad vocabulary. It's been a long day, and I don't know the jargon.
Re: only one of my folding tabs is on.
We will need additional information about your system and its folding setup to help you. That can be provided by posting the first 100 or so lines of your log file. Directions for how to do that are in the Welcome topic - viewtopic.php?f=61&t=26036.
Azul_Drake
Here's the first 200 lines, assuming the windows 8 method of posting log files works on windows 10.
Note that I edited several lines to get rid of my computer name, and replaced it with '[name]', for privacy purposes.
*********************** Log Started 2016-02-05T16:51:52Z ***********************
16:51:52:************************* Folding@home Client *************************
16:51:52:      Website: http://folding.stanford.edu/
16:51:52:    Copyright: (c) 2009-2014 Stanford University
16:51:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:51:52:         Args:
16:51:52:       Config: C:/Users/[name]/AppData/Roaming/FAHClient/config.xml
16:51:52:******************************** Build ********************************
16:51:52:      Version: 7.4.4
16:51:52:         Date: Mar 4 2014
16:51:52:         Time: 20:26:54
16:51:52:      SVN Rev: 4130
16:51:52:       Branch: fah/trunk/client
16:51:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:51:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:51:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:51:52:     Platform: win32 XP
16:51:52:         Bits: 32
16:51:52:         Mode: Release
16:51:52:******************************* System ********************************
16:51:52:          CPU: Intel(R) Core(TM) i5-4210U CPU @ 1.70GHz
16:51:52:       CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
16:51:52:         CPUs: 4
16:51:52:       Memory: 7.93GiB
16:51:52:  Free Memory: 6.45GiB
16:51:52:      Threads: WINDOWS_THREADS
16:51:52:   OS Version: 6.2
16:51:52:  Has Battery: true
16:51:52:   On Battery: false
16:51:52:   UTC Offset: 13
16:51:52:          PID: 6560
16:51:52:          CWD: C:/Users/[name]/AppData/Roaming/FAHClient
16:51:52:           OS: Windows 10 Home
16:51:52:      OS Arch: AMD64
16:51:52:         GPUs: 1
16:51:52:        GPU 0: NVIDIA:4 GM107 [GeForce 830M]
16:51:52:         CUDA: 5.0
16:51:52:  CUDA Driver: 7050
16:51:52:Win32 Service: false
16:51:52:***********************************************************************
16:51:52:<config>
16:51:52:  <!-- Slot Control -->
16:51:52:  <power v='FULL'/>
16:51:52:
16:51:52:  <!-- User Information -->
16:51:52:  <passkey v='********************************'/>
16:51:52:  <user v='Azul_Drake'/>
16:51:52:
16:51:52:  <!-- Folding Slots -->
16:51:52:  <slot id='0' type='CPU'/>
16:51:52:  <slot id='1' type='GPU'/>
16:51:52:</config>
16:51:52:Trying to access database...
16:51:55:Successfully acquired database lock
16:51:55:Enabled folding slot 00: READY cpu:3
16:51:55:Enabled folding slot 01: READY gpu:0:GM107 [GeForce 830M]
16:51:55:WU01:FS01:Starting
16:51:55:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/[name]/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6560 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:51:58:WU01:FS01:Started FahCore on PID 5584
16:51:59:WU01:FS01:Core PID:6732
16:51:59:WU01:FS01:FahCore 0x21 started
16:52:00:WU02:FS00:Starting
16:52:00:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/[name]/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 6560 -checkpoint 15 -np 3
16:52:00:WU02:FS00:Started FahCore on PID 5036
16:52:02:WU02:FS00:Core PID:7108
16:52:02:WU02:FS00:FahCore 0xa4 started
16:52:02:WU01:FS01:0x21:*********************** Log Started 2016-02-05T16:52:02Z ***********************
16:52:02:WU01:FS01:0x21:Project: 9208 (Run 0, Clone 17, Gen 109)
16:52:02:WU01:FS01:0x21:Unit: 0x000000ca664f2dd055edd359b2ebd0af
16:52:02:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:52:02:WU01:FS01:0x21:Machine: 1
16:52:02:WU01:FS01:0x21:Digital signatures verified
16:52:02:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:52:02:WU01:FS01:0x21:Version 0.0.17
16:52:03:WU02:FS00:0xa4:
16:52:03:WU02:FS00:0xa4:*------------------------------*
16:52:03:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
16:52:03:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:52:03:WU02:FS00:0xa4:Preparing to commence simulation
16:52:03:WU02:FS00:0xa4:- Ensuring status. Please wait.
16:52:07:WU01:FS01:0x21:  Found a checkpoint file
16:52:12:WU02:FS00:0xa4:- Looking at optimizations...
16:52:12:WU02:FS00:0xa4:- Working with standard loops on this execution.
16:52:12:WU02:FS00:0xa4:- Previous termination of core was improper.
16:52:12:WU02:FS00:0xa4:- Files status OK
16:52:12:WU02:FS00:0xa4:- Expanded 119040 -> 270156 (decompressed 226.9 percent)
16:52:12:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119040 data_size=270156, decompressed_data_size=270156 diff=0
16:52:12:WU02:FS00:0xa4:- Digital signature verified
16:52:12:WU02:FS00:0xa4:Project: 6394 (Run 10, Clone 10, Gen 358)
16:52:12:WU02:FS00:0xa4:Entering M.D.
16:52:18:WU02:FS00:0xa4:Using Gromacs checkpoints
16:52:18:WU02:FS00:0xa4:Mapping NT from 3 to 3
16:52:19:WU02:FS00:0xa4:Resuming from checkpoint
16:52:19:WU02:FS00:0xa4:Verified 02/wudata_01.log
16:52:20:WU02:FS00:0xa4:Verified 02/wudata_01.trr
16:52:20:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
16:52:20:WU02:FS00:0xa4:Verified 02/wudata_01.edr
16:52:20:WU02:FS00:0xa4:Completed 1828550 out of 5000000 steps  (36%)
16:52:50:7:127.0.0.1:New Web connection
16:53:19:WU01:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
16:53:19:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:57:52:WU02:FS00:0xa4:Completed 1850000 out of 5000000 steps  (37%)
17:08:32:WU02:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
17:10:42:FS00:Shutting core down
17:10:43:WU02:FS00:0xa4:Client no longer detected. Shutting down core
17:10:43:WU02:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
17:10:43:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:10:44:WU02:FS00:Starting
17:10:44:WARNING:WU02:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail
17:10:44:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/[name]/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 6560 -checkpoint 15 -np 2
17:10:44:WU02:FS00:Started FahCore on PID 3428
17:10:44:WU02:FS00:Core PID:3484
17:10:44:WU02:FS00:FahCore 0xa4 started
17:10:44:WU02:FS00:0xa4:
17:10:44:WU02:FS00:0xa4:*------------------------------*
17:10:44:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
17:10:44:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:10:44:WU02:FS00:0xa4:Preparing to commence simulation
17:10:44:WU02:FS00:0xa4:- Looking at optimizations...
17:10:44:WU02:FS00:0xa4:- Files status OK
17:10:44:WU02:FS00:0xa4:- Expanded 119040 -> 270156 (decompressed 226.9 percent)
17:10:44:WU02:FS00:0xa4:Called DecompressByteArray: compressed_data_size=119040 data_size=270156, decompressed_data_size=270156 diff=0
17:10:44:WU02:FS00:0xa4:- Digital signature verified
17:10:44:WU02:FS00:0xa4:Project: 6394 (Run 10, Clone 10, Gen 358)
17:10:44:WU02:FS00:0xa4:Assembly optimizations on if available.
17:10:44:WU02:FS00:0xa4:Entering M.D.
17:10:50:WU02:FS00:0xa4:Using Gromacs checkpoints
17:10:50:WU02:FS00:0xa4:Mapping NT from 2 to 2
17:10:50:WU02:FS00:0xa4:Resuming from checkpoint
17:10:50:WU02:FS00:0xa4:Verified 02/wudata_01.log
17:10:50:WU02:FS00:0xa4:Verified 02/wudata_01.trr
17:10:50:WU02:FS00:0xa4:Verified 02/wudata_01.xtc
17:10:50:WU02:FS00:0xa4:Verified 02/wudata_01.edr
17:10:50:WU02:FS00:0xa4:Completed 1894030 out of 5000000 steps  (37%)
17:11:14:Removing old file 'configs/config-20160203-182342.xml'
17:11:14:Saving configuration to config.xml
17:11:14:<config>
17:11:14:  <!-- Slot Control -->
17:11:14:  <power v='MEDIUM'/>
17:11:14:
17:11:14:  <!-- User Information -->
17:11:14:  <passkey v='********************************'/>
17:11:14:  <user v='Azul_Drake'/>
17:11:14:
17:11:14:  <!-- Folding Slots -->
17:11:14:  <slot id='0' type='CPU'/>
17:11:14:  <slot id='1' type='GPU'/>
17:11:14:</config>
17:12:32:WU02:FS00:0xa4:Completed 1900000 out of 5000000 steps  (38%)
17:25:30:WU02:FS00:0xa4:Completed 1950000 out of 5000000 steps  (39%)
17:35:07:WU02:FS00:0xa4:Completed 2000000 out of 5000000 steps  (40%)
17:41:57:FS01:Shutting core down
17:41:57:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 6732
17:41:57:WU01:FS01:0x21:Exiting, please wait. . .
17:42:00:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
17:42:02:FS00:Shutting core down
17:42:02:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
17:42:05:WU02:FS00:0xa4:Client no longer detected. Shutting down core
17:42:05:WU02:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
17:42:06:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:42:45:Removing old file 'configs/config-20160204-004159.xml'
17:42:45:Saving configuration to config.xml
17:42:45:<config>
17:42:45:  <!-- Slot Control -->
17:42:45:  <power v='LIGHT'/>
17:42:45:
17:42:45:  <!-- User Information -->
17:42:45:  <passkey v='********************************'/>
17:42:45:  <user v='Azul_Drake'/>
17:42:45:
17:42:45:  <!-- Folding Slots -->
17:42:45:  <slot id='0' type='CPU'>
17:42:45:    <idle v='true'/>
17:42:45:  </slot>
17:42:45:  <slot id='1' type='GPU'>
17:42:45:  </slot>
17:42:45:</config>
18:27:14:WU02:FS00:Starting
18:27:14:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/[name]/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 6560 -checkpoint 15 -np 2
18:27:14:WU02:FS00:Started FahCore on PID 6108
18:27:14:WU02:FS00:Core PID:8612
18:27:14:WU02:FS00:FahCore 0xa4 started
18:27:14:WU02:FS00:0xa4:
18:27:14:WU02:FS00:0xa4:*------------------------------*
18:27:14:WU02:FS00:0xa4:Folding@Home Gromacs GB Core
18:27:14:WU02:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
18:27:14:WU02:FS00:0xa4:Preparing to commence simulation
18:27:14:WU02:FS00:0xa4:- Looking at optimizations...
18:27:14:WU02:FS00:0xa4:- Files status OK
18:27:14:WU02:FS00:0xa4:- Expanded 119040 -> 270156 (decompressed 226.9 percent)
By default GPU folding is set to only occur when your system is Idle when using the Medium or Light slider settings. Idle is when the screen is turned off by the system or the screen saver would be active. On Full the GPU slot did process an reach 32%.
Depending on what you want your system to do, you can change the settings from the defaults. Right clicking on each slot in FAHControl will give you the choice of changing the On Idle setting. You can also change the number of cores used for CPU folding using the Configure > Slots pane in FAHControl.
Azul_Drake
Even then, slot 0 is stuck on folding project 0, even though the status is 'ready'.
Messing around with the right click options did nothing.
Move the slider to full and let it run for an hour or two. Changing settings so frequently stops and starts the client causing it to have to repeat part of the work.
Azul_Drake
The slider's been on full for a few hours, and the left folder is still on project 0, with an ETA etc. of unknown.
Sorry, I can't see the left side of your screen from my screen. Is that the CPU tab or the GPU tab? Also what does the other tab show right now?
Azul_Drake
Sorry. I know I'm not explaining this well, and odds are this is just some random PEBKAC that happens to new users occasionally.
On the advanced control, 'cpu:3' has a status of ready, is running project 0, has a work server of 155.247.166.219, with a collection server of 0.0.0.0. The work server link returns a 404.
Meanwhile, gpu:0:GM107 has a status of 'running', and it is running project 9208, and has an estimated TPF of 65 minutes.
Azul_Drake
I'm not sure what happened, but the problem seems to have fixed itself. Sorry for wasting your time.
No problem. Happy to hear it's working and you are contributing to a worthy cause.
