Project: 9752 (Run 4614, Clone 0, Gen 269)
SKeptical_Thinker
Hardware configuration: XP-32 Pro SP-3
Antec NSK-2480 with two Thermaltake 120mm Smart Fans
Gigabyte ga-ma78gm-s2h 780G IGP
BE-2350 with 10.5 x multiplier, 1.250V in BIOS, clock at 272 (2.856GHz)
EVGA 8800 GS
Ninja Mini CPU HS
GeIL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
Seagate 500GB SATA hard drive
ASUS 18X DVD±R DVD Burner PATA Model DRW-1814BL
Post by SKeptical_Thinker »
The client hung after finishing this WU. I paused and restarted and it started processing the new WU but the finished WU didn't upload.
Edit: I rebooted the system after upgrades and the referenced WU disappeared from the control status window but isn't logged as being uploaded.
*********************** Log Started 2016-02-05T21:32:18Z ***********************
21:32:18:************************* Folding@home Client *************************
21:32:18:    Website: http://folding.stanford.edu/
21:32:18:  Copyright: (c) 2009-2014 Stanford University
21:32:18:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:32:18:       Args: --child --lifeline 1117 /etc/fahclient/config.xml --run-as
21:32:18:             fahclient --pid-file=/var/run/fahclient.pid --daemon
21:32:18:     Config: /etc/fahclient/config.xml
21:32:18:******************************** Build ********************************
21:32:18:    Version: 7.4.4
21:32:18:       Date: Mar 4 2014
21:32:18:       Time: 12:02:38
21:32:18:    SVN Rev: 4130
21:32:18:     Branch: fah/trunk/client
21:32:18:   Compiler: GNU 4.4.7
21:32:18:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
21:32:18:             -fno-unsafe-math-optimizations -msse2
21:32:18:   Platform: linux2 3.2.0-1-amd64
21:32:18:       Bits: 64
21:32:18:       Mode: Release
21:32:18:******************************* System ********************************
21:32:18:        CPU: AMD Phenom(tm) II X6 1045T Processor
21:32:18:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
21:32:18:       CPUs: 6
21:32:18:     Memory: 7.55GiB
21:32:18:Free Memory: 6.91GiB
21:32:18:    Threads: POSIX_THREADS
21:32:18: OS Version: 3.13
21:32:18:Has Battery: false
21:32:18: On Battery: false
21:32:18: UTC Offset: -5
21:32:18:        PID: 1119
21:32:18:        CWD: /var/lib/fahclient
21:32:18:         OS: Linux 3.13.0-32-generic x86_64
21:32:18:    OS Arch: AMD64
21:32:18:       GPUs: 1
21:32:18:      GPU 0: UNSUPPORTED: RS880 [Radeon HD 4250]
21:32:18:       CUDA: Not detected
21:32:18:***********************************************************************
21:32:18:<config>
21:32:18:  <!-- Client Control -->
21:32:18:  <fold-anon v='true'/>
21:32:18:
21:32:18:  <!-- Folding Core -->
21:32:18:  <checkpoint v='30'/>
21:32:18:
21:32:18:  <!-- Folding Slot Configuration -->
21:32:18:  <client-type v='advanced'/>
21:32:18:
21:32:18:  <!-- HTTP Server -->
21:32:18:  <allow v='127.0.0.1 192.168.1.0/24'/>
21:32:18:
21:32:18:  <!-- Network -->
21:32:18:  <proxy v=':8080'/>
21:32:18:
21:32:18:  <!-- Remote Command Server -->
21:32:18:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
21:32:18:
21:32:18:  <!-- Slot Control -->
21:32:18:  <power v='full'/>
21:32:18:
21:32:18:  <!-- User Information -->
21:32:18:  <passkey v='********************************'/>
21:32:18:  <team v='31574'/>
21:32:18:  <user v='SKeptical_Thinker'/>
21:32:18:
21:32:18:  <!-- Work Unit Control -->
21:32:18:  <next-unit-percentage v='100'/>
21:32:18:
21:32:18:  <!-- Folding Slots -->
21:32:18:  <slot id='0' type='CPU'/>
21:32:18:</config>
21:32:18:Switching to user fahclient
21:32:18:Trying to access database...
21:32:18:Successfully acquired database lock
21:32:18:Enabled folding slot 00: READY cpu:6
21:32:18:WU00:FS00:Starting
12:17:08:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:17:08:WU00:FS00:Connecting to 171.67.108.45:8080
12:17:10:WU00:FS00:Assigned to work server 171.64.65.99
12:17:10:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.64.65.99
12:17:10:WU00:FS00:Connecting to 171.64.65.99:8080
12:17:14:WU00:FS00:Downloading 6.22MiB
12:17:18:WU01:FS00:0xa4:
12:17:18:WU01:FS00:0xa4:Finished Work Unit:
12:17:18:WU01:FS00:0xa4:- Reading up to 811440 from "01/wudata_01.trr": Read 811440
12:17:18:WU01:FS00:0xa4:trr file hash check passed.
12:17:18:WU01:FS00:0xa4:- Reading up to 746120 from "01/wudata_01.xtc": Read 746120
12:17:18:WU01:FS00:0xa4:xtc file hash check passed.
12:17:18:WU01:FS00:0xa4:edr file hash check passed.
12:17:18:WU01:FS00:0xa4:logfile size: 22662
12:17:18:WU01:FS00:0xa4:Leaving Run
12:17:20:WU00:FS00:Download 6.03%
12:17:21:WU01:FS00:0xa4:- Writing 1582710 bytes of core data to disk...
12:17:21:WU01:FS00:0xa4:Done: 1582198 -> 1537997 (compressed to 97.2 percent)
12:17:21:WU01:FS00:0xa4:  ... Done.
12:17:27:WU00:FS00:Download 11.05%
12:17:41:WU00:FS00:Download 15.07%
12:17:48:WU00:FS00:Download 20.10%
12:17:55:WU00:FS00:Download 24.11%
12:18:02:WU00:FS00:Download 29.14%
12:18:08:WU00:FS00:Download 36.17%
12:18:15:WU00:FS00:Download 41.20%
12:18:22:WU00:FS00:Download 46.22%
12:18:23:WU01:FS00:0xa4:- Shutting down core
12:18:23:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
12:18:28:WU00:FS00:Download 52.25%
12:18:29:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:18:30:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9039 run:585 clone:0 gen:49 core:0xa4 unit:0x00000032ab436c9e569827e1f0f5b34f
12:18:30:WU01:FS00:Uploading 1.47MiB to 171.67.108.158
12:18:30:WU01:FS00:Connecting to 171.67.108.158:8080
12:18:36:WU01:FS00:Upload 42.60%
12:18:43:WU01:FS00:Upload 85.19%
12:18:47:WU01:FS00:Upload complete
12:18:48:WU01:FS00:Server responded WORK_ACK (400)
12:18:48:WU01:FS00:Final credit estimate, 1582.00 points
12:18:48:WU01:FS00:Cleaning up
12:18:52:WU00:FS00:Download 56.27%
12:18:59:WU00:FS00:Download 63.30%
12:19:05:WU00:FS00:Download 68.32%
12:19:11:WU00:FS00:Download 71.34%
12:19:17:WU00:FS00:Download 77.37%
12:19:25:WU00:FS00:Download 81.39%
12:19:31:WU00:FS00:Download 87.41%
12:19:40:WU00:FS00:Download 91.43%
12:19:46:WU00:FS00:Download 96.46%
12:19:50:WU00:FS00:Download complete
12:19:51:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9752 run:4614 clone:0 gen:269 core:0xa4 unit:0x00000145ab4041635541774eeed8f83e
12:19:51:WU00:FS00:Starting
12:19:51:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 1119 -checkpoint 30 -np 6
12:19:51:WU00:FS00:Started FahCore on PID 3726
12:19:51:WU00:FS00:Core PID:3730
12:19:51:WU00:FS00:FahCore 0xa4 started
12:19:51:WU00:FS00:0xa4:
12:19:51:WU00:FS00:0xa4:*------------------------------*
12:19:51:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
12:19:51:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
12:19:51:WU00:FS00:0xa4:Preparing to commence simulation
12:19:51:WU00:FS00:0xa4:- Looking at optimizations...
12:19:51:WU00:FS00:0xa4:- Created dyn
12:19:51:WU00:FS00:0xa4:- Files status OK
12:19:51:WU00:FS00:0xa4:- Expanded 6522044 -> 22418284 (decompressed 343.7 percent)
12:19:51:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=6522044 data_size=22418284, decompressed_data_size=22418284 diff=0
12:19:52:WU00:FS00:0xa4:- Digital signature verified
12:19:52:WU00:FS00:0xa4:Project: 9752 (Run 4614, Clone 0, Gen 269)
12:19:52:WU00:FS00:0xa4:Assembly optimizations on if available.
12:19:52:WU00:FS00:0xa4:Entering M.D.
12:19:59:WU00:FS00:0xa4:Completed 0 out of 80000 steps  (0%)
12:21:42:WU00:FS00:0xa4:Completed 800 out of 80000 steps  (1%)
12:23:25:WU00:FS00:0xa4:Completed 1600 out of 80000 steps  (2%)
12:25:08:WU00:FS00:0xa4:Completed 2400 out of 80000 steps  (3%)
12:26:50:WU00:FS00:0xa4:Completed 3200 out of 80000 steps  (4%)
12:28:33:WU00:FS00:0xa4:Completed 4000 out of 80000 steps  (5%)
12:30:16:WU00:FS00:0xa4:Completed 4800 out of 80000 steps  (6%)
12:31:59:WU00:FS00:0xa4:Completed 5600 out of 80000 steps  (7%)
12:33:41:WU00:FS00:0xa4:Completed 6400 out of 80000 steps  (8%)
12:35:25:WU00:FS00:0xa4:Completed 7200 out of 80000 steps  (9%)
12:37:08:WU00:FS00:0xa4:Completed 8000 out of 80000 steps  (10%)
12:38:50:WU00:FS00:0xa4:Completed 8800 out of 80000 steps  (11%)
12:40:33:WU00:FS00:0xa4:Completed 9600 out of 80000 steps  (12%)
12:42:17:WU00:FS00:0xa4:Completed 10400 out of 80000 steps  (13%)
12:44:00:WU00:FS00:0xa4:Completed 11200 out of 80000 steps  (14%)
12:45:43:WU00:FS00:0xa4:Completed 12000 out of 80000 steps  (15%)
12:47:26:WU00:FS00:0xa4:Completed 12800 out of 80000 steps  (16%)
12:49:12:WU00:FS00:0xa4:Completed 13600 out of 80000 steps  (17%)
12:50:57:WU00:FS00:0xa4:Completed 14400 out of 80000 steps  (18%)
12:52:40:WU00:FS00:0xa4:Completed 15200 out of 80000 steps  (19%)
12:54:22:WU00:FS00:0xa4:Completed 16000 out of 80000 steps  (20%)
12:56:05:WU00:FS00:0xa4:Completed 16800 out of 80000 steps  (21%)
12:57:47:WU00:FS00:0xa4:Completed 17600 out of 80000 steps  (22%)
12:59:30:WU00:FS00:0xa4:Completed 18400 out of 80000 steps  (23%)
13:01:13:WU00:FS00:0xa4:Completed 19200 out of 80000 steps  (24%)
13:03:05:WU00:FS00:0xa4:Completed 20000 out of 80000 steps  (25%)
13:04:47:WU00:FS00:0xa4:Completed 20800 out of 80000 steps  (26%)
13:06:30:WU00:FS00:0xa4:Completed 21600 out of 80000 steps  (27%)
13:08:13:WU00:FS00:0xa4:Completed 22400 out of 80000 steps  (28%)
13:09:55:WU00:FS00:0xa4:Completed 23200 out of 80000 steps  (29%)
13:11:37:WU00:FS00:0xa4:Completed 24000 out of 80000 steps  (30%)
13:13:20:WU00:FS00:0xa4:Completed 24800 out of 80000 steps  (31%)
13:15:02:WU00:FS00:0xa4:Completed 25600 out of 80000 steps  (32%)
13:16:44:WU00:FS00:0xa4:Completed 26400 out of 80000 steps  (33%)
13:18:27:WU00:FS00:0xa4:Completed 27200 out of 80000 steps  (34%)
13:20:10:WU00:FS00:0xa4:Completed 28000 out of 80000 steps  (35%)
13:21:52:WU00:FS00:0xa4:Completed 28800 out of 80000 steps  (36%)
13:23:35:WU00:FS00:0xa4:Completed 29600 out of 80000 steps  (37%)
13:25:17:WU00:FS00:0xa4:Completed 30400 out of 80000 steps  (38%)
13:27:00:WU00:FS00:0xa4:Completed 31200 out of 80000 steps  (39%)
13:28:43:WU00:FS00:0xa4:Completed 32000 out of 80000 steps  (40%)
13:30:25:WU00:FS00:0xa4:Completed 32800 out of 80000 steps  (41%)
13:32:08:WU00:FS00:0xa4:Completed 33600 out of 80000 steps  (42%)
13:33:50:WU00:FS00:0xa4:Completed 34400 out of 80000 steps  (43%)
13:35:33:WU00:FS00:0xa4:Completed 35200 out of 80000 steps  (44%)
13:37:16:WU00:FS00:0xa4:Completed 36000 out of 80000 steps  (45%)
13:38:59:WU00:FS00:0xa4:Completed 36800 out of 80000 steps  (46%)
13:40:41:WU00:FS00:0xa4:Completed 37600 out of 80000 steps  (47%)
13:42:24:WU00:FS00:0xa4:Completed 38400 out of 80000 steps  (48%)
13:44:06:WU00:FS00:0xa4:Completed 39200 out of 80000 steps  (49%)
13:45:48:WU00:FS00:0xa4:Completed 40000 out of 80000 steps  (50%)
13:47:31:WU00:FS00:0xa4:Completed 40800 out of 80000 steps  (51%)
13:49:13:WU00:FS00:0xa4:Completed 41600 out of 80000 steps  (52%)
13:50:56:WU00:FS00:0xa4:Completed 42400 out of 80000 steps  (53%)
13:52:39:WU00:FS00:0xa4:Completed 43200 out of 80000 steps  (54%)
13:54:22:WU00:FS00:0xa4:Completed 44000 out of 80000 steps  (55%)
13:56:04:WU00:FS00:0xa4:Completed 44800 out of 80000 steps  (56%)
13:57:47:WU00:FS00:0xa4:Completed 45600 out of 80000 steps  (57%)
13:59:30:WU00:FS00:0xa4:Completed 46400 out of 80000 steps  (58%)
14:01:13:WU00:FS00:0xa4:Completed 47200 out of 80000 steps  (59%)
14:02:55:WU00:FS00:0xa4:Completed 48000 out of 80000 steps  (60%)
14:04:38:WU00:FS00:0xa4:Completed 48800 out of 80000 steps  (61%)
14:06:20:WU00:FS00:0xa4:Completed 49600 out of 80000 steps  (62%)
14:08:03:WU00:FS00:0xa4:Completed 50400 out of 80000 steps  (63%)
14:09:45:WU00:FS00:0xa4:Completed 51200 out of 80000 steps  (64%)
14:11:28:WU00:FS00:0xa4:Completed 52000 out of 80000 steps  (65%)
14:13:11:WU00:FS00:0xa4:Completed 52800 out of 80000 steps  (66%)
14:14:54:WU00:FS00:0xa4:Completed 53600 out of 80000 steps  (67%)
14:16:36:WU00:FS00:0xa4:Completed 54400 out of 80000 steps  (68%)
14:18:19:WU00:FS00:0xa4:Completed 55200 out of 80000 steps  (69%)
14:20:01:WU00:FS00:0xa4:Completed 56000 out of 80000 steps  (70%)
14:21:43:WU00:FS00:0xa4:Completed 56800 out of 80000 steps  (71%)
14:23:25:WU00:FS00:0xa4:Completed 57600 out of 80000 steps  (72%)
14:25:07:WU00:FS00:0xa4:Completed 58400 out of 80000 steps  (73%)
14:26:50:WU00:FS00:0xa4:Completed 59200 out of 80000 steps  (74%)
14:28:32:WU00:FS00:0xa4:Completed 60000 out of 80000 steps  (75%)
14:30:15:WU00:FS00:0xa4:Completed 60800 out of 80000 steps  (76%)
14:31:58:WU00:FS00:0xa4:Completed 61600 out of 80000 steps  (77%)
14:33:41:WU00:FS00:0xa4:Completed 62400 out of 80000 steps  (78%)
14:35:23:WU00:FS00:0xa4:Completed 63200 out of 80000 steps  (79%)
14:37:06:WU00:FS00:0xa4:Completed 64000 out of 80000 steps  (80%)
14:38:49:WU00:FS00:0xa4:Completed 64800 out of 80000 steps  (81%)
14:40:32:WU00:FS00:0xa4:Completed 65600 out of 80000 steps  (82%)
14:42:15:WU00:FS00:0xa4:Completed 66400 out of 80000 steps  (83%)
14:43:58:WU00:FS00:0xa4:Completed 67200 out of 80000 steps  (84%)
14:45:41:WU00:FS00:0xa4:Completed 68000 out of 80000 steps  (85%)
14:47:25:WU00:FS00:0xa4:Completed 68800 out of 80000 steps  (86%)
14:49:08:WU00:FS00:0xa4:Completed 69600 out of 80000 steps  (87%)
14:50:50:WU00:FS00:0xa4:Completed 70400 out of 80000 steps  (88%)
14:52:32:WU00:FS00:0xa4:Completed 71200 out of 80000 steps  (89%)
14:54:14:WU00:FS00:0xa4:Completed 72000 out of 80000 steps  (90%)
14:55:56:WU00:FS00:0xa4:Completed 72800 out of 80000 steps  (91%)
14:57:38:WU00:FS00:0xa4:Completed 73600 out of 80000 steps  (92%)
14:59:20:WU00:FS00:0xa4:Completed 74400 out of 80000 steps  (93%)
15:01:02:WU00:FS00:0xa4:Completed 75200 out of 80000 steps  (94%)
15:02:44:WU00:FS00:0xa4:Completed 76000 out of 80000 steps  (95%)
15:04:26:WU00:FS00:0xa4:Completed 76800 out of 80000 steps  (96%)
15:06:08:WU00:FS00:0xa4:Completed 77600 out of 80000 steps  (97%)
15:07:50:WU00:FS00:0xa4:Completed 78400 out of 80000 steps  (98%)
15:09:32:WU00:FS00:0xa4:Completed 79200 out of 80000 steps  (99%)
15:11:16:WU00:FS00:0xa4:Completed 80000 out of 80000 steps  (100%)
15:11:16:WU01:FS00:Connecting to 171.67.108.45:8080
15:11:17:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
15:11:17:WU01:FS00:Assigned to work server 171.64.65.99
15:11:17:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 171.64.65.99
15:11:17:WU01:FS00:Connecting to 171.64.65.99:8080
15:11:20:WU01:FS00:Downloading 3.18MiB
15:11:26:WU01:FS00:Download 7.86%
15:11:27:WU00:FS00:0xa4:
15:11:27:WU00:FS00:0xa4:Finished Work Unit:
15:11:27:WU00:FS00:0xa4:- Reading up to 4110264 from "00/wudata_01.trr": Read 4110264
15:11:27:WU00:FS00:0xa4:trr file hash check passed.
15:11:27:WU00:FS00:0xa4:- Reading up to 3184168 from "00/wudata_01.xtc": Read 3184168
15:11:27:WU00:FS00:0xa4:xtc file hash check passed.
15:11:27:WU00:FS00:0xa4:edr file hash check passed.
15:11:27:WU00:FS00:0xa4:logfile size: 19536
15:11:27:WU00:FS00:0xa4:Leaving Run
15:11:27:WU00:FS00:0xa4:- Writing 7316360 bytes of core data to disk...
15:11:29:WU00:FS00:0xa4:Done: 7315848 -> 7043858 (compressed to 96.2 percent)
15:11:29:WU00:FS00:0xa4:  ... Done.
15:11:33:WU01:FS00:Download 11.79%
15:11:41:WU01:FS00:Download 13.76%
15:11:47:WU01:FS00:Download 25.55%
15:11:53:WU01:FS00:Download 33.41%
15:11:59:WU01:FS00:Download 39.31%
15:12:06:WU01:FS00:Download 47.17%
15:12:12:WU01:FS00:Download 55.03%
15:12:18:WU01:FS00:Download 62.89%
15:12:24:WU01:FS00:Download 70.76%
15:12:32:WU01:FS00:Download 76.65%
15:12:40:WU01:FS00:Download 78.62%
15:12:51:WU01:FS00:Download 82.55%
15:12:55:WU01:FS00:Download complete
15:12:55:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9762 run:20 clone:1 gen:26 core:0xa4 unit:0x00000025ab404163564a92e1c5bf1b2b
15:19:48:WU00:FS00:0xa4:- Shutting down core
15:19:48:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
15:19:53:FS00:Paused
15:19:53:FS00:Shutting core down
15:20:23:FS00:Unpaused
15:21:23:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:21:23:WU01:FS00:Starting
15:21:23:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 1119 -checkpoint 30 -np 6
15:21:23:WU01:FS00:Started FahCore on PID 4541
15:21:23:WU01:FS00:Core PID:4545
15:21:23:WU01:FS00:FahCore 0xa4 started
15:21:24:WU01:FS00:0xa4:
15:21:24:WU01:FS00:0xa4:*------------------------------*
15:21:24:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
15:21:24:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:21:24:WU01:FS00:0xa4:Preparing to commence simulation
15:21:24:WU01:FS00:0xa4:- Looking at optimizations...
15:21:24:WU01:FS00:0xa4:- Created dyn
15:21:24:WU01:FS00:0xa4:- Files status OK
15:21:24:WU01:FS00:0xa4:- Expanded 3333891 -> 14111544 (decompressed 423.2 percent)
15:21:24:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=3333891 data_size=14111544, decompressed_data_size=14111544 diff=0
15:21:24:WU01:FS00:0xa4:- Digital signature verified
15:21:24:WU01:FS00:0xa4:Project: 9762 (Run 20, Clone 1, Gen 26)
15:21:24:WU01:FS00:0xa4:Assembly optimizations on if available.
15:21:24:WU01:FS00:0xa4:Entering M.D.
15:21:31:WU01:FS00:0xa4:Completed 0 out of 160000 steps  (0%)
15:24:00:WU01:FS00:0xa4:Completed 1600 out of 160000 steps  (1%)
15:26:44:WU01:FS00:0xa4:Completed 3200 out of 160000 steps  (2%)
15:29:38:WU01:FS00:0xa4:Completed 4800 out of 160000 steps  (3%)
15:32:30:WU01:FS00:0xa4:Completed 6400 out of 160000 steps  (4%)
******************************* Date: 2016-02-06 *******************************
15:35:28:WU01:FS00:0xa4:Completed 8000 out of 160000 steps  (5%)
15:38:21:WU01:FS00:0xa4:Completed 9600 out of 160000 steps  (6%)
15:41:02:WU01:FS00:0xa4:Completed 11200 out of 160000 steps  (7%)
15:43:35:WU01:FS00:0xa4:Completed 12800 out of 160000 steps  (8%)
Re: Project: 9752 (Run 4614, Clone 0, Gen 269)
You may not have waited long enough for the folding core to finish and exit, there is only 5 seconds between the message "15:19:48:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT" and the Paused message. The folding core has not exited until you get a message like this, "FahCore returned: FINISHED_UNIT (100 = 0x64)". The previous, smaller WU took at least 6 seconds to do that final bit of core shutdown.
Pausing and restarting the folding slot may get the client to finish off the WU and upload it. Or it may take restarting the FAHClient process after pausing folding. It is possible the WU will resume at its last checkpoint, or it may get dumped if the results file was corrupted by the Pause at the wrong point in the exit processing.
The safest way to finish off a WU is to set the FINISH option for that slot. It will complete any unfinished processing, pause the slot, and upload the finished WU before sitting quietly in the paused state until something else happens.
When you pause at any point OTHER THAN between the 100% message and the FINISHED_UNIT (100 = 0x64) message, the PAUSE function works fine.
