Lubuntu GPU folding - not working
New install latest Lubuntu. I installed drivers from AMD site. Works fine except FAH. FAH configured and downloads work unit, then returns bad work unit. Also, CPU usage at 100%. It will run for about 10 min before bad work unit message. Same computer on Win7 runs same video card fine. HELP
Radeon NANO
MSI A88XM Gaming
Kaveri APU
Radeon NANO
MSI A88XM Gaming
Kaveri APU
Re: Lubuntu GPU folding - not working
First, we need to see the logs from the client ...
davidcoton
Here is last log:
Mod edit: added Code tags to log file
*********************** Log Started 2016-01-23T15:45:10Z ***********************
15:45:10:************************* Folding@home Client *************************
15:45:10: Website: http://folding.stanford.edu/
15:45:10: Copyright: (c) 2009-2014 Stanford University
15:45:10: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:45:10: Args: --child --lifeline 652 /etc/fahclient/config.xml --run-as fahclient
15:45:10: --pid-file=/var/run/fahclient.pid --daemon
15:45:10: Config: /etc/fahclient/config.xml
15:45:10:******************************** Build ********************************
15:45:10: Version: 7.4.4
15:45:10: Date: Mar 4 2014
15:45:10: Time: 12:02:38
15:45:10: SVN Rev: 4130
15:45:10: Branch: fah/trunk/client
15:45:10: Compiler: GNU 4.4.7
15:45:10: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
15:45:10: -fno-unsafe-math-optimizations -msse2
15:45:10: Platform: linux2 3.2.0-1-amd64
15:45:10: Bits: 64
15:45:10: Mode: Release
15:45:10:******************************* System ********************************
15:45:10: CPU: AMD A10-7850K Radeon R7, 12 Compute Cores 4C+8G
15:45:10: CPU ID: AuthenticAMD Family 21 Model 48 Stepping 1
15:45:10: CPUs: 4
15:45:10: Memory: 7.82GiB
15:45:10:Free Memory: 7.58GiB
15:45:10: Threads: POSIX_THREADS
15:45:10: OS Version: 4.2
15:45:10:Has Battery: false
15:45:10: On Battery: false
15:45:10: UTC Offset: -5
15:45:10: PID: 654
15:45:10: CWD: /var/lib/fahclient
15:45:10: OS: Linux 4.2.0-25-generic x86_64
15:45:10: OS Arch: AMD64
15:45:10: GPUs: 1
15:45:10: GPU 0: ATI:5 Fiji XT [Radeon R9 Fury X]
15:45:10: CUDA: Not detected
15:45:10:***********************************************************************
15:45:10:<config>
15:45:10: <!-- Client Control -->
15:45:10: <fold-anon v='true'/>
15:45:10:
15:45:10: <!-- Network -->
15:45:10: <proxy v=':8080'/>
15:45:10:
15:45:10: <!-- Folding Slots -->
15:45:10: <slot id='0' type='CPU'/>
15:45:10:</config>
15:45:10:Switching to user fahclient
15:45:10:Trying to access database...
15:45:10:Successfully acquired database lock
15:45:10:Enabled folding slot 00: READY cpu:3
15:45:10:WU00:FS00:Starting
15:45:10:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -np 3
15:45:10:WU00:FS00:Started FahCore on PID 667
15:45:10:WU00:FS00:Core PID:671
15:45:10:WU00:FS00:FahCore 0xa4 started
15:45:10:WU00:FS00:0xa4:
15:45:10:WU00:FS00:0xa4:*------------------------------*
15:45:10:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
15:45:10:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:45:10:WU00:FS00:0xa4:Preparing to commence simulation
15:45:10:WU00:FS00:0xa4:- Looking at optimizations...
15:45:10:WU00:FS00:0xa4:- Files status OK
15:45:10:WU00:FS00:0xa4:- Expanded 826119 -> 1403472 (decompressed 169.8 percent)
15:45:10:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826119 data_size=1403472, decompressed_data_size=1403472 diff=0
15:45:10:WU00:FS00:0xa4:- Digital signature verified
15:45:10:WU00:FS00:0xa4:Project: 9037 (Run 169, Clone 1, Gen 14)
15:45:10:WU00:FS00:0xa4:Assembly optimizations on if available.
15:45:10:WU00:FS00:0xa4:Entering M.D.
15:45:16:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
15:45:45:Adding folding slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X]
15:45:45:Saving configuration to /etc/fahclient/config.xml
15:45:45:<config>
15:45:45: <!-- Client Control -->
15:45:45: <fold-anon v='true'/>
15:45:45:
15:45:45: <!-- Network -->
15:45:45: <proxy v=':8080'/>
15:45:45:
15:45:45: <!-- Folding Slots -->
15:45:45: <slot id='0' type='CPU'/>
15:45:45: <slot id='1' type='GPU'/>
15:45:45:</config>
15:45:45:FS00:Shutting core down
15:45:46:WU01:FS01:Connecting to 171.67.108.45:80
15:45:46:WU01:FS01:Assigned to work server 140.163.4.245
15:45:46:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X] from 140.163.4.245
15:45:46:WU01:FS01:Connecting to 140.163.4.245:8080
15:45:46:WU01:FS01:Downloading 20.68MiB
15:45:50:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:45:50:WU00:FS00:Starting
[93m15:45:50:WARNING:WU00:FS00:Changed SMP threads from 3 to 2 this can cause some work units to fail[0m
15:45:50:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -np 2
15:45:50:WU00:FS00:Started FahCore on PID 1063
15:45:50:WU00:FS00:Core PID:1067
15:45:50:WU00:FS00:FahCore 0xa4 started
15:45:51:WU00:FS00:0xa4:
15:45:51:WU00:FS00:0xa4:*------------------------------*
15:45:51:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
15:45:51:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:45:51:WU00:FS00:0xa4:Preparing to commence simulation
15:45:51:WU00:FS00:0xa4:- Looking at optimizations...
15:45:51:WU00:FS00:0xa4:- Files status OK
15:45:51:WU00:FS00:0xa4:- Expanded 826119 -> 1403472 (decompressed 169.8 percent)
15:45:51:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826119 data_size=1403472, decompressed_data_size=1403472 diff=0
15:45:51:WU00:FS00:0xa4:- Digital signature verified
15:45:51:WU00:FS00:0xa4:Project: 9037 (Run 169, Clone 1, Gen 14)
15:45:51:WU00:FS00:0xa4:Assembly optimizations on if available.
15:45:51:WU00:FS00:0xa4:Entering M.D.
15:45:52:WU01:FS01:Download 63.46%
15:45:54:WU01:FS01:Download complete
15:45:54:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10494 run:8 clone:19 gen:32 core:0x21 unit:0x0000002a8ca304f555de93ff307dd5eb
15:45:54:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah
15:45:54:WU01:FS01:Connecting to web.stanford.edu:80
15:45:55:WU01:FS01:FahCore 21: Downloading 3.23MiB
15:45:57:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
15:45:59:WU01:FS01:FahCore 21: Download complete
15:45:59:WU01:FS01:Valid core signature
15:45:59:WU01:FS01:Unpacked 7.94MiB to cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21
15:45:59:WU01:FS01:Starting
15:45:59:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -gpu 0 -gpu-vendor ati
15:45:59:WU01:FS01:Started FahCore on PID 1075
15:45:59:WU01:FS01:Core PID:1079
15:45:59:WU01:FS01:FahCore 0x21 started
15:46:00:WU01:FS01:0x21:*********************** Log Started 2016-01-23T15:45:59Z ***********************
15:46:00:WU01:FS01:0x21:Project: 10494 (Run 8, Clone 19, Gen 32)
15:46:00:WU01:FS01:0x21:Unit: 0x0000002a8ca304f555de93ff307dd5eb
15:46:00:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:46:00:WU01:FS01:0x21:Machine: 1
15:46:00:WU01:FS01:0x21:Reading tar file core.xml
15:46:00:WU01:FS01:0x21:Reading tar file system.xml
15:46:01:WU01:FS01:0x21:Reading tar file integrator.xml
15:46:01:WU01:FS01:0x21:Reading tar file state.xml
15:46:04:WU01:FS01:0x21:Digital signatures verified
15:46:04:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:46:04:WU01:FS01:0x21:Version 0.0.17
15:46:11:Saving configuration to /etc/fahclient/config.xml
15:46:11:<config>
15:46:11: <!-- Client Control -->
15:46:11: <fold-anon v='true'/>
15:46:11:
15:46:11: <!-- Network -->
15:46:11: <proxy v=':8080'/>
15:46:11:
15:46:11: <!-- Folding Slots -->
15:46:11: <slot id='0' type='CPU'/>
15:46:11: <slot id='1' type='GPU'/>
15:46:11:</config>
15:46:48:WU01:FS01:0x21:Completed 0 out of 1000000 steps (0%)
15:46:48:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:47:11:FS00:Paused
15:47:11:FS00:Shutting core down
15:47:12:Saving configuration to /etc/fahclient/config.xml
15:47:12:<config>
15:47:12: <!-- Client Control -->
15:47:12: <fold-anon v='true'/>
15:47:12:
15:47:12: <!-- Network -->
15:47:12: <proxy v=':8080'/>
15:47:12:
15:47:12: <!-- Folding Slots -->
15:47:12: <slot id='0' type='CPU'>
15:47:12: <paused v='true'/>
15:47:12: </slot>
15:47:12: <slot id='1' type='GPU'/>
15:47:12:</config>
15:47:15:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
15:53:22:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
15:53:32:Saving configuration to /etc/fahclient/config.xml
15:53:32:<config>
15:53:32: <!-- Client Control -->
15:53:32: <fold-anon v='true'/>
15:53:32:
15:53:32: <!-- Network -->
15:53:32: <proxy v=':8080'/>
15:53:32:
15:53:32: <!-- Folding Slots -->
15:53:32: <slot id='0' type='CPU'>
15:53:32: <paused v='true'/>
15:53:32: </slot>
15:53:32:</config>
15:53:33:FS01:Shutting core down
15:53:33:WU01:FS01:0x21:Caught signal SIGINT(2) on PID 1079
15:53:33:WU01:FS01:0x21:Exiting, please wait. . .
15:53:47:FS00:Unpaused
15:53:48:WU00:FS00:Starting
[93m15:53:48:WARNING:WU00:FS00:Changed SMP threads from 2 to 4 this can cause some work units to fail[0m
15:53:48:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -np 4
15:53:48:WU00:FS00:Started FahCore on PID 1103
15:53:48:WU00:FS00:Core PID:1107
15:53:48:WU00:FS00:FahCore 0xa4 started
15:53:48:WU00:FS00:0xa4:
15:53:48:WU00:FS00:0xa4:*------------------------------*
15:53:48:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
15:53:48:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:53:48:WU00:FS00:0xa4:Preparing to commence simulation
15:53:48:WU00:FS00:0xa4:- Looking at optimizations...
15:53:48:WU00:FS00:0xa4:- Files status OK
15:53:48:WU00:FS00:0xa4:- Expanded 826119 -> 1403472 (decompressed 169.8 percent)
15:53:48:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826119 data_size=1403472, decompressed_data_size=1403472 diff=0
15:53:48:WU00:FS00:0xa4:- Digital signature verified
15:53:48:WU00:FS00:0xa4:Project: 9037 (Run 169, Clone 1, Gen 14)
15:53:48:WU00:FS00:0xa4:Assembly optimizations on if available.
15:53:48:WU00:FS00:0xa4:Entering M.D.
15:53:55:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
15:54:19:Saving configuration to /etc/fahclient/config.xml
15:54:19:<config>
15:54:19: <!-- Client Control -->
15:54:19: <fold-anon v='true'/>
15:54:19:
15:54:19: <!-- Network -->
15:54:19: <proxy v=':8080'/>
15:54:19:
15:54:19: <!-- Slot Control -->
15:54:19: <power v='full'/>
15:54:19:
15:54:19: <!-- Folding Slots -->
15:54:19: <slot id='0' type='CPU'/>
15:54:19:</config>
[93m15:54:34:WARNING:FS01:Killing WU01[0m
15:54:34:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
[93m15:54:34:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping[0m
15:54:34:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:10494 run:8 clone:19 gen:32 core:0x21 unit:0x0000002a8ca304f555de93ff307dd5eb
15:54:34:WU01:Connecting to 140.163.4.245:8080
15:54:35:WU01:Server responded WORK_ACK (400)
15:54:35:WU01:Cleaning up
15:56:42:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
15:59:11:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
16:01:34:WU00:FS00:0xa4:Completed 7500 out of 250000 steps (3%)
16:04:22:WU00:FS00:0xa4:Completed 10000 out of 250000 steps (4%)
16:06:53:WU00:FS00:0xa4:Completed 12500 out of 250000 steps (5%)
16:09:13:WU00:FS00:0xa4:Completed 15000 out of 250000 steps (6%)
16:11:30:WU00:FS00:0xa4:Completed 17500 out of 250000 steps (7%)
16:13:47:WU00:FS00:0xa4:Completed 20000 out of 250000 steps (8%)
16:16:13:WU00:FS00:0xa4:Completed 22500 out of 250000 steps (9%)
16:19:23:WU00:FS00:0xa4:Completed 25000 out of 250000 steps (10%)
16:22:33:WU00:FS00:0xa4:Completed 27500 out of 250000 steps (11%)
16:25:18:WU00:FS00:0xa4:Completed 30000 out of 250000 steps (12%)
16:27:46:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
16:30:18:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
16:32:59:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
16:35:28:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
16:38:01:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
16:40:37:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
16:43:03:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
16:45:24:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
16:47:40:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
16:49:55:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
16:52:12:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
16:54:28:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
16:56:44:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
16:58:58:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
17:01:12:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
17:03:27:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
17:05:41:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
17:07:55:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
17:10:12:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
17:12:32:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
17:12:33:Saving configuration to /etc/fahclient/config.xml
17:12:33:<config>
17:12:33: <!-- Client Control -->
17:12:33: <fold-anon v='true'/>
17:12:33:
17:12:33: <!-- Folding Core -->
17:12:33: <core-priority v='low'/>
17:12:33:
17:12:33: <!-- Network -->
17:12:33: <proxy v=':8080'/>
17:12:33:
17:12:33: <!-- Slot Control -->
17:12:33: <power v='full'/>
17:12:33:
17:12:33: <!-- Folding Slots -->
17:12:33: <slot id='0' type='CPU'/>
17:12:33:</config>
17:12:36:Saving configuration to /etc/fahclient/config.xml
17:12:36:<config>
17:12:36: <!-- Client Control -->
17:12:36: <fold-anon v='true'/>
17:12:36:
17:12:36: <!-- Folding Core -->
17:12:36: <core-priority v='low'/>
17:12:36:
17:12:36: <!-- Network -->
17:12:36: <proxy v=':8080'/>
17:12:36:
17:12:36: <!-- Slot Control -->
17:12:36: <power v='full'/>
17:12:36:
17:12:36: <!-- Folding Slots -->
17:12:36: <slot id='0' type='CPU'/>
17:12:36:</config>
17:14:50:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
17:15:12:Adding folding slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X]
17:15:12:Saving configuration to /etc/fahclient/config.xml
17:15:12:<config>
17:15:12: <!-- Client Control -->
17:15:12: <fold-anon v='true'/>
17:15:12:
17:15:12: <!-- Folding Core -->
17:15:12: <core-priority v='low'/>
17:15:12:
17:15:12: <!-- Network -->
17:15:12: <proxy v=':8080'/>
17:15:12:
17:15:12: <!-- Slot Control -->
17:15:12: <power v='full'/>
17:15:12:
17:15:12: <!-- Folding Slots -->
17:15:12: <slot id='0' type='CPU'/>
17:15:12: <slot id='1' type='GPU'/>
17:15:12:</config>
17:15:12:FS00:Shutting core down
17:15:13:WU01:FS01:Connecting to 171.67.108.45:80
17:15:13:WU01:FS01:Assigned to work server 171.67.108.53
17:15:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X] from 171.67.108.53
17:15:13:WU01:FS01:Connecting to 171.67.108.53:8080
17:15:14:WU01:FS01:Downloading 1.36MiB
17:15:15:WU00:FS00:0xa4:Client no longer detected. Shutting down core.
17:15:15:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
17:15:15:WU01:FS01:Download complete
17:15:15:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:121 clone:63 gen:0 core:0x17 unit:0x000000066652edc5566bb74b01281dec
17:15:15:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah
17:15:15:WU01:FS01:Connecting to web.stanford.edu:80
17:15:16:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:15:16:WU01:FS01:FahCore 17: Downloading 3.01MiB
17:15:16:WU00:FS00:Starting
[93m17:15:16:WARNING:WU00:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail[0m
17:15:16:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -np 3
17:15:16:WU00:FS00:Started FahCore on PID 2502
17:15:16:WU00:FS00:Core PID:2506
17:15:16:WU00:FS00:FahCore 0xa4 started
17:15:16:WU00:FS00:0xa4:
17:15:16:WU00:FS00:0xa4:*------------------------------*
17:15:16:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
17:15:16:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:15:16:WU00:FS00:0xa4:Preparing to commence simulation
17:15:16:WU00:FS00:0xa4:- Looking at optimizations...
17:15:16:WU00:FS00:0xa4:- Files status OK
17:15:16:WU00:FS00:0xa4:- Expanded 826119 -> 1403472 (decompressed 169.8 percent)
17:15:16:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826119 data_size=1403472, decompressed_data_size=1403472 diff=0
17:15:16:WU00:FS00:0xa4:- Digital signature verified
17:15:16:WU00:FS00:0xa4:Project: 9037 (Run 169, Clone 1, Gen 14)
17:15:16:WU00:FS00:0xa4:Assembly optimizations on if available.
17:15:16:WU00:FS00:0xa4:Entering M.D.
17:15:20:WU01:FS01:FahCore 17: Download complete
17:15:20:WU01:FS01:Valid core signature
17:15:20:WU01:FS01:Unpacked 8.16MiB to cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17
17:15:20:WU01:FS01:Starting
17:15:20:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:15:20:WU01:FS01:Started FahCore on PID 2512
17:15:20:WU01:FS01:Core PID:2516
17:15:20:WU01:FS01:FahCore 0x17 started
17:15:21:WU01:FS01:0x17:*********************** Log Started 2016-01-23T17:15:20Z ***********************
17:15:21:WU01:FS01:0x17:Project: 9201 (Run 121, Clone 63, Gen 0)
17:15:21:WU01:FS01:0x17:Unit: 0x000000066652edc5566bb74b01281dec
17:15:21:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:15:21:WU01:FS01:0x17:Machine: 1
17:15:21:WU01:FS01:0x17:Reading tar file system.xml
17:15:21:WU01:FS01:0x17:Reading tar file integrator.xml
17:15:21:WU01:FS01:0x17:Reading tar file state.xml
17:15:21:WU01:FS01:0x17:Reading tar file core.xml
17:15:21:WU01:FS01:0x17:Digital signatures verified
17:15:22:WU00:FS00:0xa4:Using Gromacs checkpoints
17:15:22:WU00:FS00:0xa4:Resuming from checkpoint
17:15:22:WU00:FS00:0xa4:Verified 00/wudata_01.log
17:15:22:WU00:FS00:0xa4:Verified 00/wudata_01.trr
17:15:22:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
17:15:22:WU00:FS00:0xa4:Verified 00/wudata_01.edr
17:15:23:WU00:FS00:0xa4:Completed 76100 out of 250000 steps (30%)
17:15:38:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
17:15:39:Saving configuration to /etc/fahclient/config.xml
17:15:39:<config>
17:15:39: <!-- Client Control -->
17:15:39: <fold-anon v='true'/>
17:15:39:
17:15:39: <!-- Folding Core -->
17:15:39: <core-priority v='low'/>
17:15:39:
17:15:39: <!-- Network -->
17:15:39: <proxy v=':8080'/>
17:15:39:
17:15:39: <!-- Slot Control -->
17:15:39: <power v='full'/>
17:15:39:
17:15:39: <!-- Folding Slots -->
17:15:39: <slot id='0' type='CPU'/>
17:15:39: <slot id='1' type='GPU'/>
17:15:39:</config>
17:17:49:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
17:19:04:FS00:Paused
17:19:05:FS00:Shutting core down
17:19:06:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
17:19:43:Saving configuration to /etc/fahclient/config.xml
17:19:43:<config>
17:19:43: <!-- Client Control -->
17:19:43: <fold-anon v='true'/>
17:19:43:
17:19:43: <!-- Folding Core -->
17:19:43: <core-priority v='low'/>
17:19:43:
17:19:43: <!-- Network -->
17:19:43: <proxy v=':8080'/>
17:19:43:
17:19:43: <!-- Slot Control -->
17:19:43: <power v='full'/>
17:19:43:
17:19:43: <!-- Folding Slots -->
17:19:43: <slot id='0' type='CPU'>
17:19:43: <paused v='true'/>
17:19:43: </slot>
17:19:43: <slot id='1' type='GPU'/>
17:19:43:</config>
17:38:38:Saving configuration to /etc/fahclient/config.xml
17:38:38:<config>
17:38:38: <!-- Client Control -->
17:38:38: <fold-anon v='true'/>
17:38:38:
17:38:38: <!-- Folding Core -->
17:38:38: <core-priority v='low'/>
17:38:38:
17:38:38: <!-- Network -->
17:38:38: <proxy v=':8080'/>
17:38:38:
17:38:38: <!-- Slot Control -->
17:38:38: <power v='full'/>
17:38:38:
17:38:38: <!-- Folding Slots -->
17:38:38: <slot id='0' type='CPU'>
17:38:38: <paused v='true'/>
17:38:38: </slot>
17:38:38:</config>
17:38:38:FS01:Shutting core down
17:38:38:WU01:FS01:0x17:Caught signal SIGINT(2) on PID 2516
17:38:38:WU01:FS01:0x17:Exiting, please wait. . .
17:38:42:WU01:FS01:0x17:Lost lifeline PID 2512, exiting
17:38:42:WU01:FS01:0x17:ERROR:103: Lost client lifeline
17:38:42:WU01:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
17:38:43:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
[93m17:38:43:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping[0m
17:38:43:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:9201 run:121 clone:63 gen:0 core:0x17 unit:0x000000066652edc5566bb74b01281dec
17:38:43:WU01:Connecting to 171.67.108.53:8080
17:38:43:WU01:Server responded WORK_ACK (400)
17:38:43:WU01:Cleaning up
17:38:58:Adding folding slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X]
17:38:58:Saving configuration to /etc/fahclient/config.xml
17:38:58:<config>
17:38:58: <!-- Client Control -->
17:38:58: <fold-anon v='true'/>
17:38:58:
17:38:58: <!-- Folding Core -->
17:38:58: <core-priority v='low'/>
17:38:58:
17:38:58: <!-- Network -->
17:38:58: <proxy v=':8080'/>
17:38:58:
17:38:58: <!-- Slot Control -->
17:38:58: <power v='full'/>
17:38:58:
17:38:58: <!-- Folding Slots -->
17:38:58: <slot id='0' type='CPU'>
17:38:58: <paused v='true'/>
17:38:58: </slot>
17:38:58: <slot id='1' type='GPU'/>
17:38:58:</config>
17:38:59:WU01:FS01:Connecting to 171.67.108.45:80
17:38:59:WU01:FS01:Assigned to work server 140.163.4.233
17:38:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Fiji XT [Radeon R9 Fury X] from 140.163.4.233
17:38:59:WU01:FS01:Connecting to 140.163.4.233:8080
17:39:00:WU01:FS01:Downloading 4.94MiB
17:39:02:WU01:FS01:Download complete
17:39:02:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10469 run:0 clone:284 gen:238 core:0x17 unit:0x0000017a538b3db9538f3fd4c24b2278
17:39:02:WU01:FS01:Starting
17:39:02:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 704 -lifeline 654 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:39:02:WU01:FS01:Started FahCore on PID 2651
17:39:02:WU01:FS01:Core PID:2655
17:39:02:WU01:FS01:FahCore 0x17 started
17:39:02:WU01:FS01:0x17:*********************** Log Started 2016-01-23T17:39:02Z ***********************
17:39:02:WU01:FS01:0x17:Project: 10469 (Run 0, Clone 284, Gen 238)
17:39:02:WU01:FS01:0x17:Unit: 0x0000017a538b3db9538f3fd4c24b2278
17:39:02:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:39:02:WU01:FS01:0x17:Machine: 1
17:39:02:WU01:FS01:0x17:Reading tar file state.xml
17:39:02:WU01:FS01:0x17:Reading tar file system.xml
17:39:03:WU01:FS01:0x17:Reading tar file integrator.xml
17:39:03:WU01:FS01:0x17:Reading tar file core.xml
17:39:03:WU01:FS01:0x17:Digital signatures verified
17:41:02:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
18:13:25:Lost lifeline PID 652, exiting
18:13:26:Caught signal SIGTERM(15) on PID 654
18:13:26:Exiting, please wait. . .
18:13:26:WU01:FS01:0x17:Caught signal SIGTERM(15) on PID 2655
18:13:26:WU01:FS01:0x17:Exiting, please wait. . .
18:13:27:FS01:Shutting core down-
davidcoton
Which drivers did you install? Did you follow the Linux Install Guide?
As far as I can tell, the first GPU WU issued a (recoverable) error message, but did not recover, and after 6 minutes you deleted the slot.
Second one did nothing beyond 0%, after 23 minutes you deleted the slot.
Third one did nothing beyond 0%, after 32 minutes you shut down (?)
This suggests a problem with the drivers, but I am not familiar enough with AMD drivers to suggest how to correct it.
SOLVED - After you install AMD driver and reboot, you must run "sudo amdconfig --initial" in a terminal window. Then reboot and fahclient will work properly.
Thanx for everyones help!
This is an interesting information !
Do you know what this command does exactly ?
It initializes the xorg config file. But, after reboot I am back to square one. Problem has reemerged. High CPU usage and fahclient asking if I am overclocking. Running everything at stock. Did get to 17% done on GPU before problem.
You're not the only one having troubles with AMD GPU on Linux, see here for instance : viewtopic.php?f=96&t=28504
Is there a chance that you could try Windows on this machine to eliminate the possibility of a hardware issue ?
Same machine on WIN7 64 ran fine. Did not want to buy another windows OS. Had 2 GTX 970's running in Linux with little problem. R9 NANO in Windows was getting @ 350,00 PPD
Can you try some older release of AMD Linux drivers ?
NV Linux support has always been better than AMD one
I caved in and went back to Win 7. Thanks for the help
There is one last thing you could try : viewtopic.php?p=282991#p282991
