Core 21 Bad Work Unit issues
Ton80
Hardware configuration: MSI Z97M-G43, i7-4790K, GTX 960
Post by Ton80 »
Card is Gigabyte's 4 gig memory version
nVidia driver 361.43 from nVidia website
*********************** Log Started 2016-01-17T04:19:18Z ***********************
04:19:18:************************* Folding@home Client *************************
04:19:18:      Website: http://folding.stanford.edu/
04:19:18:    Copyright: (c) 2009-2014 Stanford University
04:19:18:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:19:18:         Args:
04:19:18:       Config: C:/Users/FOHTon80/AppData/Roaming/FAHClient/config.xml
04:19:18:******************************** Build ********************************
04:19:18:      Version: 7.4.4
04:19:18:         Date: Mar 4 2014
04:19:18:         Time: 20:26:54
04:19:18:      SVN Rev: 4130
04:19:18:       Branch: fah/trunk/client
04:19:18:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:19:18:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:19:18:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:19:18:     Platform: win32 XP
04:19:18:         Bits: 32
04:19:18:         Mode: Release
04:19:18:******************************* System ********************************
04:19:18:          CPU: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz
04:19:18:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
04:19:18:         CPUs: 2
04:19:18:       Memory: 7.95GiB
04:19:18:  Free Memory: 6.05GiB
04:19:18:      Threads: WINDOWS_THREADS
04:19:18:   OS Version: 6.1
04:19:18:  Has Battery: false
04:19:18:   On Battery: false
04:19:18:   UTC Offset: -5
04:19:18:          PID: 4352
04:19:18:          CWD: C:/Users/FOHTon80/AppData/Roaming/FAHClient
04:19:18:           OS: Windows 7 Home Premium
04:19:18:      OS Arch: AMD64
04:19:18:         GPUs: 1
04:19:18:        GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
04:19:18:         CUDA: 5.2
04:19:18:  CUDA Driver: 8000
04:19:18:Win32 Service: false
04:19:18:***********************************************************************
04:19:18:<config>
04:19:18:  <!-- Folding Core -->
04:19:18:  <checkpoint v='10'/>
04:19:18:
04:19:18:  <!-- Network -->
04:19:18:  <proxy v=':8080'/>
04:19:18:
04:19:18:  <!-- Slot Control -->
04:19:18:  <pause-on-battery v='false'/>
04:19:18:
04:19:18:  <!-- User Information -->
04:19:18:  <passkey v='********************************'/>
04:19:18:  <user v='Ton80'/>
04:19:18:
04:19:18:  <!-- Folding Slots -->
04:19:18:  <slot id='1' type='GPU'>
04:19:18:    <paused v='true'/>
04:19:18:  </slot>
04:19:18:</config>
04:19:18:Trying to access database...
04:19:18:Successfully acquired database lock
04:19:18:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] (by user)
06:51:00:FS01:Unpaused
06:51:00:WU01:FS01:Starting
06:51:00:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:51:00:WU01:FS01:Started FahCore on PID 6872
06:51:01:WU01:FS01:Core PID:6980
06:51:01:WU01:FS01:FahCore 0x18 started
06:51:01:WU01:FS01:0x18:*********************** Log Started 2016-01-17T06:51:01Z ***********************
13:02:39:WU01:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
13:02:40:WU00:FS01:Connecting to 171.67.108.45:80
13:02:41:WU00:FS01:Assigned to work server 140.163.4.242
13:02:41:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM206 [GeForce GTX 960] from 140.163.4.242
13:02:41:WU00:FS01:Connecting to 140.163.4.242:8080
13:02:42:WU00:FS01:Downloading 5.32MiB
13:02:42:WU00:FS01:Download complete
13:02:42:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11406 run:7 clone:49 gen:6 core:0x21 unit:0x000000068ca304f25686b2083e276b4a
13:08:40:WU01:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
13:08:43:WU01:FS01:0x18:Saving result file logfile_01.txt
13:08:43:WU01:FS01:0x18:Saving result file checkpointState.xml
13:08:43:WU01:FS01:0x18:Saving result file checkpt.crc
13:08:43:WU01:FS01:0x18:Saving result file log.txt
13:08:43:WU01:FS01:0x18:Saving result file positions.xtc
13:08:45:WU01:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
13:08:46:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:08:46:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9413 run:394 clone:3 gen:6 core:0x18 unit:0x00000008ab40413a554112f38d968ec5
13:08:46:WU01:FS01:Uploading 13.70MiB to 171.64.65.58
13:08:46:WU00:FS01:Starting
13:08:46:WU01:FS01:Connecting to 171.64.65.58:8080
13:08:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:08:46:WU00:FS01:Started FahCore on PID 6472
13:08:47:WU00:FS01:Core PID:5768
13:08:47:WU00:FS01:FahCore 0x21 started
13:08:48:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:08:48:WU00:FS01:Starting
13:08:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:08:48:WU00:FS01:Started FahCore on PID 5420
13:08:48:WU00:FS01:Core PID:4848
13:08:48:WU00:FS01:FahCore 0x21 started
13:08:49:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:08:52:WU01:FS01:Upload 6.84%
13:08:58:WU01:FS01:Upload 14.14%
13:09:04:WU01:FS01:Upload 20.98%
13:09:10:WU01:FS01:Upload 28.28%
13:09:16:WU01:FS01:Upload 35.12%
13:09:22:WU01:FS01:Upload 42.42%
13:09:28:WU01:FS01:Upload 49.26%
13:09:34:WU01:FS01:Upload 56.56%
13:09:40:WU01:FS01:Upload 63.40%
13:09:46:WU01:FS01:Upload 70.24%
13:09:48:WU00:FS01:Starting
13:09:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:09:48:WU00:FS01:Started FahCore on PID 5180
13:09:48:WU00:FS01:Core PID:6860
13:09:48:WU00:FS01:FahCore 0x21 started
13:09:49:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:09:52:WU01:FS01:Upload 77.54%
13:09:58:WU01:FS01:Upload 84.84%
13:10:04:WU01:FS01:Upload 91.68%
13:10:10:WU01:FS01:Upload 98.98%
13:10:14:WU01:FS01:Upload complete
13:10:14:WU01:FS01:Server responded WORK_ACK (400)
13:10:14:WU01:FS01:Final credit estimate, 48201.00 points
13:10:14:WU01:FS01:Cleaning up
13:10:48:WU00:FS01:Starting
13:10:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:10:48:WU00:FS01:Started FahCore on PID 6500
13:10:50:WU00:FS01:Core PID:6124
13:10:50:WU00:FS01:FahCore 0x21 started
13:10:51:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:11:48:WU00:FS01:Starting
13:11:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:11:48:WU00:FS01:Started FahCore on PID 7024
13:11:52:WU00:FS01:Core PID:6636
13:11:52:WU00:FS01:FahCore 0x21 started
13:11:52:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:11:52:WARNING:WU00:FS01:Too many errors, failing
13:11:52:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:11406 run:7 clone:49 gen:6 core:0x21 unit:0x000000068ca304f25686b2083e276b4a
13:11:52:WU00:FS01:Connecting to 140.163.4.242:8080
13:11:54:WU01:FS01:Connecting to 171.67.108.45:80
13:11:54:WU00:FS01:Server responded WORK_ACK (400)
13:11:54:WU00:FS01:Cleaning up
13:11:55:WU01:FS01:Assigned to work server 171.64.65.92
13:11:55:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] from 171.64.65.92
13:11:55:WU01:FS01:Connecting to 171.64.65.92:8080
13:11:56:WU01:FS01:Downloading 3.42MiB
13:11:58:WU01:FS01:Download complete
13:11:58:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9161 run:54 clone:0 gen:68 core:0x18 unit:0x0000004aab40415c5674662521637e4b
13:11:58:WU01:FS01:Starting
13:11:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 4352 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
13:11:58:WU01:FS01:Started FahCore on PID 2800
13:11:59:WU01:FS01:Core PID:5440
13:11:59:WU01:FS01:FahCore 0x18 started
13:11:59:WU01:FS01:0x18:*********************** Log Started 2016-01-17T13:11:59Z ***********************
13:11:59:WU01:FS01:0x18:Project: 9161 (Run 54, Clone 0, Gen 68)
13:11:59:WU01:FS01:0x18:Unit: 0x0000004aab40415c5674662521637e4b
13:11:59:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
13:11:59:WU01:FS01:0x18:Machine: 1
13:11:59:WU01:FS01:0x18:Reading tar file core.xml
13:11:59:WU01:FS01:0x18:Reading tar file system.xml
13:11:59:WU01:FS01:0x18:Reading tar file integrator.xml
13:11:59:WU01:FS01:0x18:Reading tar file state.xml
13:12:00:WU01:FS01:0x18:Digital signatures verified
13:12:00:WU01:FS01:0x18:Folding@home GPU core18
13:12:00:WU01:FS01:0x18:Version 0.0.4
13:12:20:WU01:FS01:0x18:Completed 0 out of 2500000 steps (0%)
13:12:20:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:15:06:WU01:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
13:17:45:WU01:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
13:20:24:WU01:FS01:0x18:Completed 75000 out of 2500000 steps (3%)
13:23:02:WU01:FS01:0x18:Completed 100000 out of 2500000 steps (4%)
13:25:49:WU01:FS01:0x18:Completed 125000 out of 2500000 steps (5%)
13:28:28:WU01:FS01:0x18:Completed 150000 out of 2500000 steps (6%)
13:31:07:WU01:FS01:0x18:Completed 175000 out of 2500000 steps (7%)
13:33:46:WU01:FS01:0x18:Completed 200000 out of 2500000 steps (8%)
13:36:33:WU01:FS01:0x18:Completed 225000 out of 2500000 steps (9%)
13:39:12:WU01:FS01:0x18:Completed 250000 out of 2500000 steps (10%)
As you can see core 18 works fine. Is there anything I can do on my end to help fix this?
Re: Core 21 Bad Work Unit issues
The issue is not yet critical : I see only one WU here (project:11406 run:7 clone:49 gen:6) that failed to start 5 times and got dumped.
We can't conclude anything yet.
Did you get some error messages while the WU attempted to start ?
I see another report of immediately failed WU for some one else, so it might only be a bad WU ...
Ton80
Post by Ton80 »
I was asleep when the above issues were created so no I didn't see any error messages
Some previous failed core 21 from log-20160116-182147.txt
*********************** Log Started 2016-01-16T07:43:15Z ***********************
07:43:15:************************* Folding@home Client *************************
07:43:15:      Website: http://folding.stanford.edu/
07:43:15:    Copyright: (c) 2009-2014 Stanford University
07:43:15:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:43:15:         Args: --open-web-control
07:43:15:       Config: C:/Users/FOHTon80/AppData/Roaming/FAHClient/config.xml
07:43:15:******************************** Build ********************************
07:43:15:      Version: 7.4.4
07:43:15:         Date: Mar 4 2014
07:43:15:         Time: 20:26:54
07:43:15:      SVN Rev: 4130
07:43:15:       Branch: fah/trunk/client
07:43:15:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
07:43:15:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
07:43:15:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
07:43:15:     Platform: win32 XP
07:43:15:         Bits: 32
07:43:15:         Mode: Release
07:43:15:******************************* System ********************************
07:43:15:          CPU: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz
07:43:15:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:43:15:         CPUs: 2
07:43:15:       Memory: 7.95GiB
07:43:15:  Free Memory: 6.04GiB
07:43:15:      Threads: WINDOWS_THREADS
07:43:15:   OS Version: 6.1
07:43:15:  Has Battery: false
07:43:15:   On Battery: false
07:43:15:   UTC Offset: -5
07:43:15:          PID: 5724
07:43:15:          CWD: C:/Users/FOHTon80/AppData/Roaming/FAHClient
07:43:15:           OS: Windows 7 Home Premium
07:43:15:      OS Arch: AMD64
07:43:15:         GPUs: 1
07:43:15:        GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
07:43:15:         CUDA: 5.2
07:43:15:  CUDA Driver: 7050
07:43:15:Win32 Service: false
07:43:15:***********************************************************************
07:43:15:<config>
07:43:15:  <!-- Folding Core -->
07:43:15:  <checkpoint v='10'/>
07:43:15:
07:43:15:  <!-- Network -->
07:43:15:  <proxy v=':8080'/>
07:43:15:
07:43:15:  <!-- Slot Control -->
07:43:15:  <pause-on-battery v='false'/>
07:43:15:
07:43:15:  <!-- User Information -->
07:43:15:  <passkey v='********************************'/>
07:43:15:  <user v='Ton80'/>
07:43:15:
07:43:15:  <!-- Folding Slots -->
07:43:15:  <slot id='1' type='GPU'/>
07:43:15:</config>
07:43:15:Trying to access database...
07:43:15:Successfully acquired database lock
07:43:15:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960]
07:43:15:WU01:FS01:Starting
07:43:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
07:43:15:WU01:FS01:Started FahCore on PID 1384
07:43:17:WU01:FS01:Core PID:6376
07:43:17:WU01:FS01:FahCore 0x21 started
******************************* Date: 2016-01-16 *******************************
17:20:59:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:20:59:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9208 run:1 clone:81 gen:2 core:0x21 unit:0x00000011664f2dd055edd42b8f8103df
17:20:59:WARNING:WU01:FS01:Produced no results, failing
17:20:59:WU01:FS01:Connecting to 171.64.65.104:8080
17:21:00:WU00:FS01:Connecting to 171.67.108.45:80
17:21:00:WU01:FS01:Server responded WORK_ACK (400)
17:21:00:WU01:FS01:Final credit estimate, 34820.00 points
17:21:00:WU01:FS01:Cleaning up
17:21:01:WU00:FS01:Assigned to work server 171.64.65.104
17:21:01:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] from 171.64.65.104
17:21:01:WU00:FS01:Connecting to 171.64.65.104:8080
17:21:02:WU00:FS01:Downloading 9.83MiB
17:21:06:WU00:FS01:Download complete
17:21:06:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9206 run:0 clone:350 gen:9 core:0x21 unit:0x00000034664f2dd055db8a78899e561a
17:21:06:WU00:FS01:Starting
17:21:06:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:21:06:WU00:FS01:Started FahCore on PID 5780
17:21:07:WU00:FS01:Core PID:3012
17:21:07:WU00:FS01:FahCore 0x21 started
17:21:07:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:21:07:WU00:FS01:Starting
17:21:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:21:07:WU00:FS01:Started FahCore on PID 4284
17:21:07:WU00:FS01:Core PID:2456
17:21:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:22:07:WU00:FS01:Starting
17:22:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:22:07:WU00:FS01:Started FahCore on PID 1188
17:22:07:WU00:FS01:Core PID:6224
17:22:07:WU00:FS01:FahCore 0x21 started
17:22:08:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:23:08:WU00:FS01:Starting
17:23:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:23:08:WU00:FS01:Started FahCore on PID 6976
17:23:09:WU00:FS01:Core PID:1192
17:23:09:WU00:FS01:FahCore 0x21 started
17:23:10:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:24:08:WU00:FS01:Starting
17:24:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:24:08:WU00:FS01:Started FahCore on PID 6420
17:24:11:WU00:FS01:Core PID:7136
17:24:11:WU00:FS01:FahCore 0x21 started
17:24:12:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
17:24:12:WARNING:WU00:FS01:Too many errors, failing
17:24:12:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:9206 run:0 clone:350 gen:9 core:0x21 unit:0x00000034664f2dd055db8a78899e561a
17:24:12:WU00:FS01:Connecting to 171.64.65.104:8080
17:24:12:WU01:FS01:Connecting to 171.67.108.45:80
17:24:13:WU00:FS01:Server responded WORK_ACK (400)
17:24:13:WU00:FS01:Cleaning up
17:24:13:WU01:FS01:Assigned to work server 171.64.65.58
17:24:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] from 171.64.65.58
17:24:13:WU01:FS01:Connecting to 171.64.65.58:8080
17:24:14:WU01:FS01:Downloading 894.29KiB
17:24:15:WU01:FS01:Download complete
17:24:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9413 run:394 clone:3 gen:6 core:0x18 unit:0x00000008ab40413a554112f38d968ec5
17:24:16:WU01:FS01:Starting
17:24:16:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 5724 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
17:24:16:WU01:FS01:Started FahCore on PID 4912
17:24:16:WU01:FS01:Core PID:6248
17:24:16:WU01:FS01:FahCore 0x18 started
17:24:17:WU01:FS01:0x18:*********************** Log Started 2016-01-16T17:24:16Z ***********************
17:24:17:WU01:FS01:0x18:Project: 9413 (Run 394, Clone 3, Gen 6)
17:24:17:WU01:FS01:0x18:Unit: 0x00000008ab40413a554112f38d968ec5
17:24:17:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
17:24:17:WU01:FS01:0x18:Machine: 1
17:24:17:WU01:FS01:0x18:Reading tar file state.xml
17:24:17:WU01:FS01:0x18:Reading tar file system.xml
17:24:17:WU01:FS01:0x18:Reading tar file integrator.xml
17:24:17:WU01:FS01:0x18:Reading tar file core.xml
17:24:17:WU01:FS01:0x18:Digital signatures verified
17:24:17:WU01:FS01:0x18:Folding@home GPU core18
17:24:17:WU01:FS01:0x18:Version 0.0.4
17:24:24:WU01:FS01:0x18:Completed 0 out of 16000000 steps (0%)
17:24:24:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:30:24:WU01:FS01:0x18:Completed 160000 out of 16000000 steps (1%)
17:36:24:WU01:FS01:0x18:Completed 320000 out of 16000000 steps (2%)
17:42:27:WU01:FS01:0x18:Completed 480000 out of 16000000 steps (3%)
17:48:30:WU01:FS01:0x18:Completed 640000 out of 16000000 steps (4%)
17:54:33:WU01:FS01:0x18:Completed 800000 out of 16000000 steps (5%)
18:00:38:WU01:FS01:0x18:Completed 960000 out of 16000000 steps (6%)
18:06:42:WU01:FS01:0x18:Completed 1120000 out of 16000000 steps (7%)
18:12:46:WU01:FS01:0x18:Completed 1280000 out of 16000000 steps (8%)
18:15:47:FS01:Paused
18:15:47:FS01:Shutting core down
18:15:47:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:16:38:Removing old file 'configs/config-20160113-192331.xml'
18:16:38:Saving configuration to config.xml
18:16:38:<config>
18:16:38:  <!-- Folding Core -->
18:16:38:  <checkpoint v='10'/>
18:16:38:
18:16:38:  <!-- Network -->
18:16:38:  <proxy v=':8080'/>
18:16:38:
18:16:38:  <!-- Slot Control -->
18:16:38:  <pause-on-battery v='false'/>
18:16:38:
18:16:38:  <!-- User Information -->
18:16:38:  <passkey v='********************************'/>
18:16:38:  <user v='Ton80'/>
18:16:38:
18:16:38:  <!-- Folding Slots -->
18:16:38:  <slot id='1' type='GPU'>
18:16:38:    <paused v='true'/>
18:16:38:  </slot>
18:16:38:</config>
That's all I can glean from previous logs.
Something is indeed wrong ... but this issue is quite weird.
As a first test, open a command prompt, cd to C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/ and then, enter FahCore_21.exe. You should see something like this printed to the screen (it will not start the core nor disturb your current WU) :
D:\FAH7_Data\cores\web.stanford.edu\~pande\Win32\AMD64\ATI\R600\Core_21.fah>FahCore_21.exe
*************************** Core21 Folding@home Core ***************************
       Type: 33
       Core: Core21
     Author: Yutong Zhao <yutong.zhao@stanford.edu>
       Args:
     Config: <none>
************************************ Build *************************************
    Version: 0.0.17
       Date: Dec 18 2015
       Time: 23:07:48
   Compiler: Visual C++ 2008
    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE2 /MT
   Platform: win32 7
       Bits: 64
       Mode: Release
************************************ System ************************************
        CPU: Unknown
     CPU ID:
       CPUs: 8
     Memory: 8.99GiB
Free Memory: 5.51GiB
 OS Version: 6.1
Has Battery: false
 On Battery: false
 UTC Offset: 1
        PID: 4524
        CWD: D:\FAH7_Data\cores\web.stanford.edu\~pande\Win32\AMD64\ATI\R600\Core_21.fah
         OS: Windows 7 Professional Service Pack 1
    OS Arch: AMD64
       GPUs: 1
      GPU 0: Bus:2 Slot:0 ATI:5 Hawaii [Radeon R9 200X Series]
       CUDA: Not detected
     OpenCL: Not detected
Do you see a similar output, or does the program fail ?
As a second test, can you delete C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe ? It will force the download of a fresh version of the core next time you get a core 21 WU. And let us know if it helps.
Ton80
Post by Ton80 »
1st test is similar output
2nd done. It looked like it was d/led on Jan 8, 2016 if that helps any.
The first test means that everything on your system is OK to run the core ...
I'm suspecting some kind of permission issue, or maybe an antivirus program blocking the core ... let's see how it goes after a fresh download ...
Ton80
Post by Ton80 »
Has Comodo Free edition caused problems before because that is what I use.
How do I check permission? Though wouldn't that cause same problem with core 17 and 18?
JohnChodera
Pande Group Member
Post by JohnChodera »
Sorry you're having trouble here! (And thanks to toTOW for helping debug---we've been communicating about this.)
Unfortunately, the current core 21 maps a number of errors to the same "BAD_WORK_UNIT (114 = 0x72)" return value. We're working on fixing this to provide more useful information in the next revision.
If you can kill it immediately after one of these failures and see if you can find the `log.txt` file that ends up in one of the `FAHClient/work/` directories corresponding to the failure, it may have more useful debug information in it.
Alternatively, if you have project/run/clone/gen numbers for a project from my lab (the Chodera lab) that failed this way, I can check our servers to see if those files were brought back for debugging. This will likely be one of the 114xx, 117xx, or 118xx project series. Unfortunately, I don't have access to servers from other groups.
Best,
John
Ton80
Post by Ton80 »
Ok. Will do if I can catch it.
To JohnChodera: There is one that meets your criteria in my OP. That log was from Jan 17, 2016.
Ton80
Post by Ton80 »
I have just d/led one of them. Right now it's paused.
17:49:28:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11400 run:2 clone:3 gen:23 core:0x21 unit:0x000000208ca304f255de8dfc5b87c47f
I could use some guidance on troubleshooting. Just before I paused it it was acting like it might suffer from the slow bug.
How was the GPU load and temperatures while running ?
The file that John was talking about should be in C:/Users/FOHTon80/AppData/Roaming/FAHClient/work/01/01/log.txt (or something very similar, since you have only one GPU slot, it shouldn't be too hard to find it).
Ton80
Post by Ton80 »
To toTOW: I ran it for 15 minutes earlier yesterday before going in to work. No updating of progress bar. No logs in the work directory. Temp was running around 64 C. I didn't check the load.
Running it again for this post: Still no updating of progress bar.
Per GPU-Z 0.8.6: GPU Load is between 95-98%; GPU Temp around 62 C; Memory Controller load is 44-47%
CPU Load on the core is between 35-45% per Windows 7 Resource Monitor.
It looks like it's working fine on the GPU like I'd expect on core 18 but NO updating at all to the GUI interface. I've been running it now for 25 minutes still no GUI updating.
Oh Crap, I can't pause this unit without starting all over again since it isn't even saving any progress made into the work directory!
Ton80
Post by Ton80 »
Right after I posted above I saw new "Started new threads" entries to log. The log is verbosity set to 5. Hope it helps.
*********************** Log Started 2016-01-19T04:41:17Z ***********************
04:41:17:************************* Folding@home Client *************************
04:41:17:      Website: http://folding.stanford.edu/
04:41:17:    Copyright: (c) 2009-2014 Stanford University
04:41:17:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:41:17:         Args:
04:41:17:       Config: C:/Users/FOHTon80/AppData/Roaming/FAHClient/config.xml
04:41:17:******************************** Build ********************************
04:41:17:      Version: 7.4.4
04:41:17:         Date: Mar 4 2014
04:41:17:         Time: 20:26:54
04:41:17:      SVN Rev: 4130
04:41:17:       Branch: fah/trunk/client
04:41:17:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:41:17:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:41:17:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:41:17:     Platform: win32 XP
04:41:17:         Bits: 32
04:41:17:         Mode: Release
04:41:17:******************************* System ********************************
04:41:17:          CPU: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz
04:41:17:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
04:41:17:         CPUs: 2
04:41:17:       Memory: 7.95GiB
04:41:17:  Free Memory: 6.31GiB
04:41:17:      Threads: WINDOWS_THREADS
04:41:17:   OS Version: 6.1
04:41:17:  Has Battery: false
04:41:17:   On Battery: false
04:41:17:   UTC Offset: -5
04:41:17:          PID: 4304
04:41:17:          CWD: C:/Users/FOHTon80/AppData/Roaming/FAHClient
04:41:17:           OS: Windows 7 Home Premium
04:41:17:      OS Arch: AMD64
04:41:17:         GPUs: 1
04:41:17:        GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
04:41:17:         CUDA: 5.2
04:41:17:  CUDA Driver: 8000
04:41:17:Win32 Service: false
04:41:17:***********************************************************************
04:41:17:<config>
04:41:17:  <service-description v='Folding@home Client'/>
04:41:17:  <service-restart v='true'/>
04:41:17:  <service-restart-delay v='5000'/>
04:41:17:
04:41:17:  <!-- Client Control -->
04:41:17:  <client-threads v='6'/>
04:41:17:  <cycle-rate v='4'/>
04:41:17:  <cycles v='-1'/>
04:41:17:  <data-directory v='.'/>
04:41:17:  <disable-sleep-when-active v='true'/>
04:41:17:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
04:41:17:  <exit-when-done v='false'/>
04:41:17:  <fold-anon v='false'/>
04:41:17:  <open-web-control v='false'/>
04:41:17:
04:41:17:  <!-- Configuration -->
04:41:17:  <config-rotate v='true'/>
04:41:17:  <config-rotate-dir v='configs'/>
04:41:17:  <config-rotate-max v='16'/>
04:41:17:
04:41:17:  <!-- Debugging -->
04:41:17:  <assignment-servers>
04:41:17:    assign3.stanford.edu:8080 assign4.stanford.edu:80
04:41:17:  </assignment-servers>
04:41:17:  <auth-as v='true'/>
04:41:17:  <capture-directory v='capture'/>
04:41:17:  <capture-on-error v='false'/>
04:41:17:  <capture-packets v='false'/>
04:41:17:  <capture-requests v='false'/>
04:41:17:  <capture-responses v='false'/>
04:41:17:  <capture-sockets v='false'/>
04:41:17:  <core-exec v='FahCore_$type'/>
04:41:17:  <core-wrapper-exec v='FAHCoreWrapper'/>
04:41:17:  <debug-sockets v='false'/>
04:41:17:  <exception-locations v='true'/>
04:41:17:  <gpu-assignment-servers>
04:41:17:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
04:41:17:  </gpu-assignment-servers>
04:41:17:  <stack-traces v='false'/>
04:41:17:
04:41:17:  <!-- Error Handling -->
04:41:17:  <max-slot-errors v='10'/>
04:41:17:  <max-unit-errors v='5'/>
04:41:17:
04:41:17:  <!-- Folding Core -->
04:41:17:  <checkpoint v='10'/>
04:41:17:  <core-dir v='cores'/>
04:41:17:  <core-priority v='idle'/>
04:41:17:  <cpu-affinity v='false'/>
04:41:17:  <cpu-usage v='100'/>
04:41:17:  <gpu-usage v='100'/>
04:41:17:  <no-assembly v='false'/>
04:41:17:
04:41:17:  <!-- Folding Slot Configuration -->
04:41:17:  <cause v='ANY'/>
04:41:17:  <client-subtype v='STDCLI'/>
04:41:17:  <client-type v='normal'/>
04:41:17:  <cpu-species v='X86_PENTIUM_II'/>
04:41:17:  <cpu-type v='AMD64'/>
04:41:17:  <cpus v='-1'/>
04:41:17:  <gpu v='true'/>
04:41:17:  <max-packet-size v='normal'/>
04:41:17:  <os-species v='UNKNOWN'/>
04:41:17:  <os-type v='WIN32'/>
04:41:17:  <project-key v='0'/>
04:41:17:  <smp v='true'/>
04:41:17:
04:41:17:  <!-- GUI -->
04:41:17:  <gui-enabled v='true'/>
04:41:17:
04:41:17:  <!-- HTTP Server -->
04:41:17:  <allow v='127.0.0.1'/>
04:41:17:  <connection-timeout v='60'/>
04:41:17:  <deny v='0/0'/>
04:41:17:  <http-addresses v='0:7396'/>
04:41:17:  <https-addresses v=''/>
04:41:17:  <max-connect-time v='900'/>
04:41:17:  <max-connections v='800'/>
04:41:17:  <max-request-length v='52428800'/>
04:41:17:  <min-connect-time v='300'/>
04:41:17:  <threads v='2'/>
04:41:17:
04:41:17:  <!-- Logging -->
04:41:17:  <log v='log.txt'/>
04:41:17:  <log-color v='false'/>
04:41:17:  <log-crlf v='true'/>
04:41:17:  <log-date v='false'/>
04:41:17:  <log-date-periodically v='21600'/>
04:41:17:  <log-debug v='true'/>
04:41:17:  <log-domain v='false'/>
04:41:17:  <log-header v='true'/>
04:41:17:  <log-level v='true'/>
04:41:17:  <log-no-info-header v='true'/>
04:41:17:  <log-redirect v='false'/>
04:41:17:  <log-rotate v='true'/>
04:41:17:  <log-rotate-dir v='logs'/>
04:41:17:  <log-rotate-max v='16'/>
04:41:17:  <log-short-level v='false'/>
04:41:17:  <log-simple-domains v='true'/>
04:41:17:  <log-thread-id v='false'/>
04:41:17:  <log-thread-prefix v='true'/>
04:41:17:  <log-time v='true'/>
04:41:17:  <log-to-screen v='true'/>
04:41:17:  <log-truncate v='false'/>
04:41:17:  <verbosity v='5'/>
04:41:17:
04:41:17:  <!-- Network -->
04:41:17:  <proxy v=':8080'/>
04:41:17:  <proxy-enable v='false'/>
04:41:17:  <proxy-pass v=''/>
04:41:17:  <proxy-user v=''/>
04:41:17:
04:41:17:  <!-- Process Control -->
04:41:17:  <child v='false'/>
04:41:17:  <daemon v='false'/>
04:41:17:  <pid v='false'/>
04:41:17:  <pid-file v='Folding@home Client.pid'/>
04:41:17:  <respawn v='false'/>
04:41:17:  <service v='false'/>
04:41:17:
04:41:17:  <!-- Remote Command Server -->
04:41:17:  <command-address v='0.0.0.0'/>
04:41:17:  <command-allow-no-pass v='127.0.0.1'/>
04:41:17:  <command-deny-no-pass v='0/0'/>
04:41:17:  <command-enable v='true'/>
04:41:17:  <command-port v='36330'/>
04:41:17:
04:41:17:  <!-- Slot Control -->
04:41:17:  <idle v='false'/>
04:41:17:  <max-shutdown-wait v='60'/>
04:41:17:  <pause-on-battery v='false'/>
04:41:17:  <pause-on-start v='false'/>
04:41:17:  <paused v='false'/>
04:41:17:  <power v='medium'/>
04:41:17:
04:41:17:  <!-- User Information -->
04:41:17:  <machine-id v='0'/>
04:41:17:  <passkey v='********************************'/>
04:41:17:  <team v='0'/>
04:41:17:  <user v='Ton80'/>
04:41:17:
04:41:17:  <!-- Web Server -->
04:41:17:  <web-allow v='127.0.0.1'/>
04:41:17:  <web-deny v='0/0'/>
04:41:17:  <web-enable v='true'/>
04:41:17:
04:41:17:  <!-- Web Server Sessions -->
04:41:17:  <session-cookie v='sid'/>
04:41:17:  <session-lifetime v='86400'/>
04:41:17:  <session-timeout v='3600'/>
04:41:17:
04:41:17:  <!-- Work Unit Control -->
04:41:17:  <dump-after-deadline v='true'/>
04:41:17:  <max-queue v='16'/>
04:41:17:  <max-units v='0'/>
04:41:17:  <next-unit-percentage v='99'/>
04:41:17:  <stall-detection-enabled v='false'/>
04:41:17:  <stall-percent v='5'/>
04:41:17:  <stall-timeout v='1800'/>
04:41:17:
04:41:17:  <!-- Folding Slots -->
04:41:17:  <slot id='1' type='GPU'>
04:41:17:    <paused v='true'/>
04:41:17:  </slot>
04:41:17:</config>
04:41:17:Trying to access database...
04:41:17:Successfully acquired database lock
04:41:17:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] (by user)
04:41:17:Started thread 4 on PID 4304
04:41:17:Started thread 9 on PID 4304
04:41:17:Started thread 5 on PID 4304
04:41:17:Started thread 7 on PID 4304
04:41:17:Started thread 6 on PID 4304
04:41:17:Started thread 8 on PID 4304
04:53:03:FS01:Unpaused
04:53:03:WU01:FS01:Starting
04:53:03:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4304 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
04:53:03:WU01:FS01:Started FahCore on PID 5748
04:53:03:Started thread 10 on PID 4304
04:53:04:WU01:FS01:Core PID:6124
04:53:04:WU01:FS01:FahCore 0x21 started
04:53:29:Removing old file 'configs/config-20160116-073409.xml'
04:53:29:Saving configuration to config.xml
04:53:29:<config>
04:53:29:  <!-- Folding Core -->
04:53:29:  <checkpoint v='10'/>
04:53:29:
04:53:29:  <!-- Logging -->
04:53:29:  <verbosity v='5'/>
04:53:29:
04:53:29:  <!-- Network -->
04:53:29:  <proxy v=':8080'/>
04:53:29:
04:53:29:  <!-- Slot Control -->
04:53:29:  <pause-on-battery v='false'/>
04:53:29:  <power v='FULL'/>
04:53:29:
04:53:29:  <!-- User Information -->
04:53:29:  <passkey v='********************************'/>
04:53:29:  <user v='Ton80'/>
04:53:29:
04:53:29:  <!-- Folding Slots -->
04:53:29:  <slot id='1' type='GPU'/>
04:53:29:</config>
04:53:47:Started thread 11 on PID 4304
04:54:30:Removing old file 'configs/config-20160116-074123.xml'
04:54:30:Saving configuration to config.xml
04:54:30:<config>
04:54:30:  <!-- Folding Core -->
04:54:30:  <checkpoint v='10'/>
04:54:30:
04:54:30:  <!-- Logging -->
04:54:30:  <verbosity v='5'/>
04:54:30:
04:54:30:  <!-- Network -->
04:54:30:  <proxy v=':8080'/>
04:54:30:
04:54:30:  <!-- Slot Control -->
04:54:30:  <pause-on-battery v='false'/>
04:54:30:
04:54:30:  <!-- User Information -->
04:54:30:  <passkey v='********************************'/>
04:54:30:  <user v='Ton80'/>
04:54:30:
04:54:30:  <!-- Folding Slots -->
04:54:30:  <slot id='1' type='GPU'/>
04:54:30:</config>
05:29:27:Started thread 12 on PID 4304
05:32:52:Started thread 13 on PID 4304
That's all I got. Still running it. Still no progress bar updating or logs in work directory or saved work in Windows Explorer.
Ton80
Post by Ton80 »
It started another couple threads after I uninstalled a program.
05:51:37:Started thread 14 on PID 4304
05:54:32:Started thread 15 on PID 4304
I probably should ignore those. Forgive me but I'm not a programmer. Just reporting what I see.
Still no updating of GUI, no logs in work directory, all sensors and monitors within normal range.
It looks like the core is doing what it's supposed to do except update the GUI.
I'm beginning to think that I'm not gonna get any credit for this unit if I try to finish this since no work saved hence dumping this unit.
Ton80
Post by Ton80 »
Ha! right after I dumped above unit I got another core 21 with Bad Work Unit reports with immediate fail hence no work logs.
I finally snagged a core 18.
*********************** Log Started 2016-01-19T06:10:08Z ***********************
06:10:08:************************* Folding@home Client *************************
06:10:08:      Website: http://folding.stanford.edu/
06:10:08:    Copyright: (c) 2009-2014 Stanford University
06:10:08:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:10:08:         Args: --open-web-control
06:10:08:       Config: C:/Users/FOHTon80/AppData/Roaming/FAHClient/config.xml
06:10:08:******************************** Build ********************************
06:10:08:      Version: 7.4.4
06:10:08:         Date: Mar 4 2014
06:10:08:         Time: 20:26:54
06:10:08:      SVN Rev: 4130
06:10:08:       Branch: fah/trunk/client
06:10:08:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:10:08:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:10:08:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:10:08:     Platform: win32 XP
06:10:08:         Bits: 32
06:10:08:         Mode: Release
06:10:08:******************************* System ********************************
06:10:08:          CPU: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz
06:10:08:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:10:08:         CPUs: 2
06:10:08:       Memory: 7.95GiB
06:10:08:  Free Memory: 5.95GiB
06:10:08:      Threads: WINDOWS_THREADS
06:10:08:   OS Version: 6.1
06:10:08:  Has Battery: false
06:10:08:   On Battery: false
06:10:08:   UTC Offset: -5
06:10:08:          PID: 6104
06:10:08:          CWD: C:/Users/FOHTon80/AppData/Roaming/FAHClient
06:10:08:           OS: Windows 7 Home Premium
06:10:08:      OS Arch: AMD64
06:10:08:         GPUs: 1
06:10:08:        GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
06:10:08:         CUDA: 5.2
06:10:08:  CUDA Driver: 8000
06:10:08:Win32 Service: false
06:10:08:***********************************************************************
06:10:08:<config>
06:10:08:  <service-description v='Folding@home Client'/>
06:10:08:  <service-restart v='true'/>
06:10:08:  <service-restart-delay v='5000'/>
06:10:08:
06:10:08:  <!-- Client Control -->
06:10:08:  <client-threads v='6'/>
06:10:08:  <cycle-rate v='4'/>
06:10:08:  <cycles v='-1'/>
06:10:08:  <data-directory v='.'/>
06:10:08:  <disable-sleep-when-active v='true'/>
06:10:08:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
06:10:08:  <exit-when-done v='false'/>
06:10:08:  <fold-anon v='false'/>
06:10:08:  <open-web-control v='true'/>
06:10:08:
06:10:08:  <!-- Configuration -->
06:10:08:  <config-rotate v='true'/>
06:10:08:  <config-rotate-dir v='configs'/>
06:10:08:  <config-rotate-max v='16'/>
06:10:08:
06:10:08:  <!-- Debugging -->
06:10:08:  <assignment-servers>
06:10:08:    assign3.stanford.edu:8080 assign4.stanford.edu:80
06:10:08:  </assignment-servers>
06:10:08:  <auth-as v='true'/>
06:10:08:  <capture-directory v='capture'/>
06:10:08:  <capture-on-error v='false'/>
06:10:08:  <capture-packets v='false'/>
06:10:08:  <capture-requests v='false'/>
06:10:08:  <capture-responses v='false'/>
06:10:08:  <capture-sockets v='false'/>
06:10:08:  <core-exec v='FahCore_$type'/>
06:10:08:  <core-wrapper-exec v='FAHCoreWrapper'/>
06:10:08:  <debug-sockets v='false'/>
06:10:08:  <exception-locations v='true'/>
06:10:08:  <gpu-assignment-servers>
06:10:08:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
06:10:08:  </gpu-assignment-servers>
06:10:08:  <stack-traces v='false'/>
06:10:08:
06:10:08:  <!-- Error Handling -->
06:10:08:  <max-slot-errors v='10'/>
06:10:08:  <max-unit-errors v='5'/>
06:10:08:
06:10:08:  <!-- Folding Core -->
06:10:08:  <checkpoint v='10'/>
06:10:08:  <core-dir v='cores'/>
06:10:08:  <core-priority v='idle'/>
06:10:08:  <cpu-affinity v='false'/>
06:10:08:  <cpu-usage v='100'/>
06:10:08:  <gpu-usage v='100'/>
06:10:08:  <no-assembly v='false'/>
06:10:08:
06:10:08:  <!-- Folding Slot Configuration -->
06:10:08:  <cause v='ANY'/>
06:10:08:  <client-subtype v='STDCLI'/>
06:10:08:  <client-type v='normal'/>
06:10:08:  <cpu-species v='X86_PENTIUM_II'/>
06:10:08:  <cpu-type v='AMD64'/>
06:10:08:  <cpus v='-1'/>
06:10:08:  <gpu v='true'/>
06:10:08:  <max-packet-size v='normal'/>
06:10:08:  <os-species v='UNKNOWN'/>
06:10:08:  <os-type v='WIN32'/>
06:10:08:  <project-key v='0'/>
06:10:08:  <smp v='true'/>
06:10:08:
06:10:08:  <!-- GUI -->
06:10:08:  <gui-enabled v='true'/>
06:10:08:
06:10:08:  <!-- HTTP Server -->
06:10:08:  <allow v='127.0.0.1'/>
06:10:08:  <connection-timeout v='60'/>
06:10:08:  <deny v='0/0'/>
06:10:08:  <http-addresses v='0:7396'/>
06:10:08:  <https-addresses v=''/>
06:10:08:  <max-connect-time v='900'/>
06:10:08:  <max-connections v='800'/>
06:10:08:  <max-request-length v='52428800'/>
06:10:08:  <min-connect-time v='300'/>
06:10:08:  <threads v='2'/>
06:10:08:
06:10:08:  <!-- Logging -->
06:10:08:  <log v='log.txt'/>
06:10:08:  <log-color v='false'/>
06:10:08:  <log-crlf v='true'/>
06:10:08:  <log-date v='false'/>
06:10:08:  <log-date-periodically v='21600'/>
06:10:08:  <log-debug v='true'/>
06:10:08:  <log-domain v='false'/>
06:10:08:  <log-header v='true'/>
06:10:08:  <log-level v='true'/>
06:10:08:  <log-no-info-header v='true'/>
06:10:08:  <log-redirect v='false'/>
06:10:08:  <log-rotate v='true'/>
06:10:08:  <log-rotate-dir v='logs'/>
06:10:08:  <log-rotate-max v='16'/>
06:10:08:  <log-short-level v='false'/>
06:10:08:  <log-simple-domains v='true'/>
06:10:08:  <log-thread-id v='false'/>
06:10:08:  <log-thread-prefix v='true'/>
06:10:08:  <log-time v='true'/>
06:10:08:  <log-to-screen v='true'/>
06:10:08:  <log-truncate v='false'/>
06:10:08:  <verbosity v='5'/>
06:10:08:
06:10:08:  <!-- Network -->
06:10:08:  <proxy v=':8080'/>
06:10:08:  <proxy-enable v='false'/>
06:10:08:  <proxy-pass v=''/>
06:10:08:  <proxy-user v=''/>
06:10:08:
06:10:08:  <!-- Process Control -->
06:10:08:  <child v='false'/>
06:10:08:  <daemon v='false'/>
06:10:08:  <pid v='false'/>
06:10:08:  <pid-file v='Folding@home Client.pid'/>
06:10:08:  <respawn v='false'/>
06:10:08:  <service v='false'/>
06:10:08:
06:10:08:  <!-- Remote Command Server -->
06:10:08:  <command-address v='0.0.0.0'/>
06:10:08:  <command-allow-no-pass v='127.0.0.1'/>
06:10:08:  <command-deny-no-pass v='0/0'/>
06:10:08:  <command-enable v='true'/>
06:10:08:  <command-port v='36330'/>
06:10:08:
06:10:08:  <!-- Slot Control -->
06:10:08:  <idle v='false'/>
06:10:08:  <max-shutdown-wait v='60'/>
06:10:08:  <pause-on-battery v='false'/>
06:10:08:  <pause-on-start v='false'/>
06:10:08:  <paused v='false'/>
06:10:08:  <power v='medium'/>
06:10:08:
06:10:08:  <!-- User Information -->
06:10:08:  <machine-id v='0'/>
06:10:08:  <passkey v='********************************'/>
06:10:08:  <team v='0'/>
06:10:08:  <user v='Ton80'/>
06:10:08:
06:10:08:  <!-- Web Server -->
06:10:08:  <web-allow v='127.0.0.1'/>
06:10:08:  <web-deny v='0/0'/>
06:10:08:  <web-enable v='true'/>
06:10:08:
06:10:08:  <!-- Web Server Sessions -->
06:10:08:  <session-cookie v='sid'/>
06:10:08:  <session-lifetime v='86400'/>
06:10:08:  <session-timeout v='3600'/>
06:10:08:
06:10:08:  <!-- Work Unit Control -->
06:10:08:  <dump-after-deadline v='true'/>
06:10:08:  <max-queue v='16'/>
06:10:08:  <max-units v='0'/>
06:10:08:  <next-unit-percentage v='99'/>
06:10:08:  <stall-detection-enabled v='false'/>
06:10:08:  <stall-percent v='5'/>
06:10:08:  <stall-timeout v='1800'/>
06:10:08:
06:10:08:  <!-- Folding Slots -->
06:10:08:  <slot id='1' type='GPU'>
06:10:08:    <paused v='true'/>
06:10:08:  </slot>
06:10:08:</config>
06:10:08:Trying to access database...
06:10:08:Successfully acquired database lock
06:10:08:Enabled folding slot 01: PAUSED gpu:0:GM206 [GeForce GTX 960] (by user)
06:10:08:Started thread 4 on PID 6104
06:10:08:Started thread 5 on PID 6104
06:10:08:Started thread 7 on PID 6104
06:10:08:Started thread 9 on PID 6104
06:10:08:Started thread 6 on PID 6104
06:10:08:Started thread 8 on PID 6104
06:10:08:Set client configured
06:10:19:Started thread 10 on PID 6104
06:10:25:FS01:Unpaused
06:10:26:WU00:FS01:Connecting to 171.67.108.45:80
06:10:27:WU00:FS01:Connecting to 171.67.108.45:80
06:10:28:WU00:FS01:Assigned to work server 140.163.4.245
06:10:28:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] from 140.163.4.245
06:10:28:WU00:FS01:Connecting to 140.163.4.245:8080
06:10:28:WU00:FS01:Downloading 20.67MiB
06:10:30:WU00:FS01:Download complete
06:10:31:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10494 run:8 clone:14 gen:25 core:0x21 unit:0x000000278ca304f555de93fcc95767e1
06:10:31:WU00:FS01:Starting
06:10:31:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:10:31:WU00:FS01:Started FahCore on PID 5804
06:10:31:Started thread 11 on PID 6104
06:10:33:WU00:FS01:Core PID:3276
06:10:33:WU00:FS01:FahCore 0x21 started
06:10:33:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:10:33:WU00:FS01:Starting
06:10:33:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:10:33:WU00:FS01:Started FahCore on PID 3048
06:10:33:Started thread 12 on PID 6104
06:10:34:WU00:FS01:Core PID:2980
06:10:34:WU00:FS01:FahCore 0x21 started
06:10:34:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:11:09:Removing old file 'configs/config-20160116-181638.xml'
06:11:09:Saving configuration to config.xml
06:11:09:<config>
06:11:09:  <!-- Folding Core -->
06:11:09:  <checkpoint v='10'/>
06:11:09:
06:11:09:  <!-- Logging -->
06:11:09:  <verbosity v='5'/>
06:11:09:
06:11:09:  <!-- Network -->
06:11:09:  <proxy v=':8080'/>
06:11:09:
06:11:09:  <!-- Slot Control -->
06:11:09:  <pause-on-battery v='false'/>
06:11:09:
06:11:09:  <!-- User Information -->
06:11:09:  <passkey v='********************************'/>
06:11:09:  <user v='Ton80'/>
06:11:09:
06:11:09:  <!-- Folding Slots -->
06:11:09:  <slot id='1' type='GPU'/>
06:11:09:</config>
06:11:34:WU00:FS01:Starting
06:11:34:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:11:34:WU00:FS01:Started FahCore on PID 5856
06:11:34:Started thread 13 on PID 6104
06:11:34:WU00:FS01:Core PID:5660
06:11:34:WU00:FS01:FahCore 0x21 started
06:11:34:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:12:34:WU00:FS01:Starting
06:12:34:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:12:34:WU00:FS01:Started FahCore on PID 4184
06:12:34:Started thread 14 on PID 6104
06:12:36:WU00:FS01:Core PID:6136
06:12:36:WU00:FS01:FahCore 0x21 started
06:12:36:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:12:54:FS01:Paused
06:13:11:Removing old file 'configs/config-20160116-182248.xml'
06:13:11:Saving configuration to config.xml
06:13:11:<config>
06:13:11:  <!-- Folding Core -->
06:13:11:  <checkpoint v='10'/>
06:13:11:
06:13:11:  <!-- Logging -->
06:13:11:  <verbosity v='5'/>
06:13:11:
06:13:11:  <!-- Network -->
06:13:11:  <proxy v=':8080'/>
06:13:11:
06:13:11:  <!-- Slot Control -->
06:13:11:  <pause-on-battery v='false'/>
06:13:11:
06:13:11:  <!-- User Information -->
06:13:11:  <passkey v='********************************'/>
06:13:11:  <user v='Ton80'/>
06:13:11:
06:13:11:  <!-- Folding Slots -->
06:13:11:  <slot id='1' type='GPU'>
06:13:11:    <paused v='true'/>
06:13:11:  </slot>
06:13:11:</config>
06:13:40:FS01:Unpaused
06:13:40:WU00:FS01:Starting
06:13:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:13:40:WU00:FS01:Started FahCore on PID 2780
06:13:40:Started thread 15 on PID 6104
06:13:42:WU00:FS01:Core PID:5896
06:13:42:WU00:FS01:FahCore 0x21 started
06:13:42:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:13:42:WARNING:WU00:FS01:Too many errors, failing
06:13:42:WU00:FS01:Sending unit results: id:00 state:SEND error:FAILED project:10494 run:8 clone:14 gen:25 core:0x21 unit:0x000000278ca304f555de93fcc95767e1
06:13:42:WU00:FS01:Connecting to 140.163.4.245:8080
06:13:43:WU01:FS01:Connecting to 171.67.108.45:80
06:13:43:WU00:FS01:Server responded WORK_ACK (400)
06:13:43:WU00:FS01:Cleaning up
06:13:44:WU01:FS01:Assigned to work server 140.163.4.234
06:13:44:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM206 [GeForce GTX 960] from 140.163.4.234
06:13:44:WU01:FS01:Connecting to 140.163.4.234:8080
06:13:45:WU01:FS01:Downloading 2.35MiB
06:13:47:WU01:FS01:Download complete
06:13:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10475 run:0 clone:33 gen:610 core:0x18 unit:0x00000315538b3dba53f37f57cd1d1692
06:13:47:WU01:FS01:Starting
06:13:47:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/FOHTon80/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 6104 -checkpoint 10 -gpu 0 -gpu-vendor nvidia
06:13:47:WU01:FS01:Started FahCore on PID 1524
06:13:47:Started thread 16 on PID 6104
06:13:49:WU01:FS01:Core PID:5000
06:13:49:WU01:FS01:FahCore 0x18 started
06:13:50:WU01:FS01:0x18:*********************** Log Started 2016-01-19T06:13:49Z ***********************
06:13:50:WU01:FS01:0x18:Project: 10475 (Run 0, Clone 33, Gen 610)
06:13:50:WU01:FS01:0x18:Unit: 0x00000315538b3dba53f37f57cd1d1692
06:13:50:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
06:13:50:WU01:FS01:0x18:Machine: 1
06:13:50:WU01:FS01:0x18:Reading tar file state.xml
06:13:50:WU01:FS01:0x18:Reading tar file system.xml
06:13:50:WU01:FS01:0x18:Reading tar file integrator.xml
06:13:50:WU01:FS01:0x18:Reading tar file core.xml
06:13:50:WU01:FS01:0x18:Digital signatures verified
06:13:50:WU01:FS01:0x18:Folding@home GPU core18
06:13:50:WU01:FS01:0x18:Version 0.0.4
06:14:05:WU01:FS01:0x18:Completed 0 out of 5000000 steps (0%)
06:14:05:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:14:12:Removing old file 'configs/config-20160116-212346.xml'
06:14:12:Saving configuration to config.xml
06:14:12:<config>
06:14:12:  <!-- Folding Core -->
06:14:12:  <checkpoint v='10'/>
06:14:12:
06:14:12:  <!-- Logging -->
06:14:12:  <verbosity v='5'/>
06:14:12:
06:14:12:  <!-- Network -->
06:14:12:  <proxy v=':8080'/>
06:14:12:
06:14:12:  <!-- Slot Control -->
06:14:12:  <pause-on-battery v='false'/>
06:14:12:
06:14:12:  <!-- User Information -->
06:14:12:  <passkey v='********************************'/>
06:14:12:  <user v='Ton80'/>
06:14:12:
06:14:12:  <!-- Folding Slots -->
06:14:12:  <slot id='1' type='GPU'/>
06:14:12:</config>
06:17:40:WU01:FS01:0x18:Completed 50000 out of 5000000 steps (1%)
