running two different gpu's 1 only runs at 1/3 speed (idle)
jeremy_gunnells
Post by jeremy_gunnells »
I am running a
asus crosshair formula iv MB
amd 1100t Processor
gigabyte r9 290 gpu1
xfx Radeon HD6870 gpu 2
Corsair 1050wat power supply
8 gig of corsair vengeance ram
Windows 10 pro
I just started folding@home and I had just recently upgraded my Gpu to the r9 290. Once I heard you could run multiple gpu's with Folding@Home with out them being in crossfire since my two gpu's will not crossfire I decided to try it out. The GPU's run on different drivers and I wonder if that is were my problem lies. I have uninstalled all the graphics drivers and reinstalled them. The r9 290 works fine folding at close to 100%. My cpu folds fine as well. The second Gpu only folds at the idle speed of the HD6870. I tried changing the index settings in Folding@home slots. For two days the 2nd gpu only ran at maybe 1/4 it's potential. Then yesterday I left my computer alone for about 18hr while it was folding. when I got back on it I looked at the 2nd GPU and it was folding at 100%. I have no clue why it just suddenly started working. but then later in the day I attepted to play a video game and the computer crashed. When I restarted it everything went back to folding but the 2nd gpu was back at the 1/4 of it's potential. Someone please help me get it going. I know it is an older GPU but it was a rockstar of it's time and should have several years of folding left in it. I would love to see it get some use other than me just selling it to someone else to play games on. :e(
Re: running two different gpu's 1 only runs at 1/3 speed (id
Post by foldy »
If you play a video game you need to pause folding or else they get in conflict.
If you play in Internet Browser or watch videos you need to disable Browser and Flash HW video acceleration or else it will lag.
How do you see your 2nd GPU is at 1/4 of it's potential?
Your GPUs should have one cpu core to support them, so CPU folding should leave 2 cores idle.
Both GPUs can run with the same driver AMD 15.7.1
Can you post the logfile?
mmonnin
Post by mmonnin »
What core clock is the 2nd GPU at when you seeing folding slow?
I'm not up-to-date on AMD/ATI drivers, but it's possible that both a Radeon HD6870 and a Radeon R9 290 will run on the same driver version -- and possible that they won't.
I've had a couple of NVidia GPUs which require different driver versions and they certainly have not been happy together. (I finally moved one to another machine.) Somebody else will have to figure out whether my experience applies to AMD or not, but I though I'd mention it anyway.
Mixing two radically different architectures (VLIW for the 6870 and GCN for the 290) has always been complicated and is not guaranteed to work fine ...
jeremy_gunnells
Thank you for your help. I was seeing the gpu through the radion settings, gaming, global settings. the card was only running at 300mhz vs its potential of 900mhz. I ended up giving the card to my step bro and getting a r9 280 used. it is folding fine with the r9 290 so I will have to say it was a driver issue.
The card at 300 MHz instead of 900 MHz is clearly an unused card ... what was the GPU load % ?
The 280 and the 290 are using GCN architecture, so they should be playing better together :)
mike9o
Post by mike9o »
I have a similar problem running two 390x's in a duel GPU Z170 Intel system. Per the Folding web control display, GPU 0 is earning 31k ppd and GPU 1 is earning 292k ppd. I deleted the CPU slot because I thought that the one GPU slot wasn't getting any CPU support. I have other dual GPU systems which don't have this problem. Any ideas?
Post by foldy »
mike9o
Post by mike9o »
Thanks for your help.
edit: It wasn't a Z170 system, but the previous gen Intel chipset.
********************** Log Started 2016-12-31T02:01:34Z ***********************
02:01:34:************************* Folding@home Client *************************
02:01:34:      Website: http://folding.stanford.edu/
02:01:34:    Copyright: (c) 2009-2014 Stanford University
02:01:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:01:34:         Args:
02:01:34:       Config: C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/config.xml
02:01:34:******************************** Build ********************************
02:01:34:      Version: 7.4.4
02:01:34:         Date: Mar 4 2014
02:01:34:         Time: 20:26:54
02:01:34:      SVN Rev: 4130
02:01:34:       Branch: fah/trunk/client
02:01:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:01:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:01:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:01:34:     Platform: win32 XP
02:01:34:         Bits: 32
02:01:34:         Mode: Release
02:01:34:******************************* System ********************************
02:01:34:          CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
02:01:34:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:01:34:         CPUs: 8
02:01:34:       Memory: 15.94GiB
02:01:34:  Free Memory: 14.22GiB
02:01:34:      Threads: WINDOWS_THREADS
02:01:34:   OS Version: 6.2
02:01:34:  Has Battery: false
02:01:34:   On Battery: false
02:01:34:   UTC Offset: -8
02:01:34:          PID: 7288
02:01:34:          CWD: C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient
02:01:34:           OS: Windows 10 Home
02:01:34:      OS Arch: AMD64
02:01:34:         GPUs: 2
02:01:34:        GPU 0: ATI:5 Hawaii [Radeon R9 200/300X Series]
02:01:34:        GPU 1: ATI:5 Hawaii [Radeon R9 200/300X Series]
02:01:34:         CUDA: Not detected
02:01:34:Win32 Service: false
02:01:34:***********************************************************************
02:01:34:<config>
02:01:34:  <!-- Network -->
02:01:34:  <proxy v=':8080'/>
02:01:34:
02:01:34:  <!-- Slot Control -->
02:01:34:  <power v='FULL'/>
02:01:34:
02:01:34:  <!-- User Information -->
02:01:34:  <passkey v='********************************'/>
02:01:34:  <team v='198'/>
02:01:34:  <user v='mike9o'/>
02:01:34:
02:01:34:  <!-- Folding Slots -->
02:01:34:  <slot id='1' type='GPU'/>
02:01:34:  <slot id='2' type='GPU'/>
02:01:34:</config>
02:01:34:Trying to access database...
02:01:34:Successfully acquired database lock
02:01:34:Enabled folding slot 01: READY gpu:0:Hawaii [Radeon R9 200/300X Series]
02:01:34:Enabled folding slot 02: READY gpu:1:Hawaii [Radeon R9 200/300X Series]
02:01:34:WU03:FS01:Starting
02:01:34:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:01:34:WU03:FS01:Started FahCore on PID 7352
02:01:34:WU03:FS01:Core PID:2540
02:01:34:WU03:FS01:FahCore 0x21 started
02:01:34:WU00:FS02:Starting
02:01:34:WU00:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 1 -gpu-vendor ati
02:01:34:WU00:FS02:Started FahCore on PID 6692
02:01:34:WU00:FS02:Core PID:6936
02:01:34:WU00:FS02:FahCore 0x21 started
02:01:34:WU03:FS01:0x21:*********************** Log Started 2016-12-31T02:01:34Z ***********************
02:01:34:WU03:FS01:0x21:Project: 11711 (Run 3, Clone 21, Gen 29)
02:01:34:WU03:FS01:0x21:Unit: 0x000000248ca304e758332b49760912ff
02:01:34:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:01:34:WU03:FS01:0x21:Machine: 1
02:01:34:WU03:FS01:0x21:Digital signatures verified
02:01:34:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:01:34:WU03:FS01:0x21:Version 0.0.17
02:01:34:WU03:FS01:0x21:  Found a checkpoint file
02:01:35:WU00:FS02:0x21:*********************** Log Started 2016-12-31T02:01:34Z ***********************
02:01:35:WU00:FS02:0x21:Project: 9189 (Run 1, Clone 9, Gen 231)
02:01:35:WU00:FS02:0x21:Unit: 0x0000017dab40415457cb2bbbd55fb65f
02:01:35:WU00:FS02:0x21:CPU: 0x00000000000000000000000000000000
02:01:35:WU00:FS02:0x21:Machine: 2
02:01:35:WU00:FS02:0x21:Digital signatures verified
02:01:35:WU00:FS02:0x21:Folding@home GPU Core21 Folding@home Core
02:01:35:WU00:FS02:0x21:Version 0.0.17
02:01:35:WU00:FS02:0x21:  Found a checkpoint file
02:01:40:WU03:FS01:0x21:Completed 6750000 out of 7500000 steps (90%)
02:01:40:WU03:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:01:40:WU00:FS02:0x21:Completed 400000 out of 2500000 steps (16%)
02:01:40:WU00:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:02:57:WU00:FS02:0x21:Completed 425000 out of 2500000 steps (17%)
02:04:14:WU00:FS02:0x21:Completed 450000 out of 2500000 steps (18%)
02:05:30:WU00:FS02:0x21:Completed 475000 out of 2500000 steps (19%)
02:06:46:WU00:FS02:0x21:Completed 500000 out of 2500000 steps (20%)
02:08:04:WU00:FS02:0x21:Completed 525000 out of 2500000 steps (21%)
02:09:20:WU00:FS02:0x21:Completed 550000 out of 2500000 steps (22%)
02:10:37:WU00:FS02:0x21:Completed 575000 out of 2500000 steps (23%)
02:11:53:WU00:FS02:0x21:Completed 600000 out of 2500000 steps (24%)
02:13:11:WU00:FS02:0x21:Completed 625000 out of 2500000 steps (25%)
02:14:27:WU00:FS02:0x21:Completed 650000 out of 2500000 steps (26%)
02:15:43:WU00:FS02:0x21:Completed 675000 out of 2500000 steps (27%)
02:17:00:WU00:FS02:0x21:Completed 700000 out of 2500000 steps (28%)
02:18:17:WU00:FS02:0x21:Completed 725000 out of 2500000 steps (29%)
02:18:54:WU03:FS01:0x21:Completed 6825000 out of 7500000 steps (91%)
02:19:34:WU00:FS02:0x21:Completed 750000 out of 2500000 steps (30%)
02:20:50:WU00:FS02:0x21:Completed 775000 out of 2500000 steps (31%)
02:22:07:WU00:FS02:0x21:Completed 800000 out of 2500000 steps (32%)
02:23:24:WU00:FS02:0x21:Completed 825000 out of 2500000 steps (33%)
02:24:40:WU00:FS02:0x21:Completed 850000 out of 2500000 steps (34%)
02:25:57:WU00:FS02:0x21:Completed 875000 out of 2500000 steps (35%)
02:27:14:WU00:FS02:0x21:Completed 900000 out of 2500000 steps (36%)
02:28:31:WU00:FS02:0x21:Completed 925000 out of 2500000 steps (37%)
02:29:48:WU00:FS02:0x21:Completed 950000 out of 2500000 steps (38%)
02:31:04:WU00:FS02:0x21:Completed 975000 out of 2500000 steps (39%)
02:32:21:WU00:FS02:0x21:Completed 1000000 out of 2500000 steps (40%)
02:33:38:WU00:FS02:0x21:Completed 1025000 out of 2500000 steps (41%)
02:34:54:WU00:FS02:0x21:Completed 1050000 out of 2500000 steps (42%)
02:36:06:WU03:FS01:0x21:Completed 6900000 out of 7500000 steps (92%)
02:36:11:WU00:FS02:0x21:Completed 1075000 out of 2500000 steps (43%)
02:37:27:WU00:FS02:0x21:Completed 1100000 out of 2500000 steps (44%)
02:38:45:WU00:FS02:0x21:Completed 1125000 out of 2500000 steps (45%)
02:40:01:WU00:FS02:0x21:Completed 1150000 out of 2500000 steps (46%)
02:41:17:WU00:FS02:0x21:Completed 1175000 out of 2500000 steps (47%)
02:42:34:WU00:FS02:0x21:Completed 1200000 out of 2500000 steps (48%)
02:43:51:WU00:FS02:0x21:Completed 1225000 out of 2500000 steps (49%)
02:45:07:WU00:FS02:0x21:Completed 1250000 out of 2500000 steps (50%)
02:46:23:WU00:FS02:0x21:Completed 1275000 out of 2500000 steps (51%)
02:47:40:WU00:FS02:0x21:Completed 1300000 out of 2500000 steps (52%)
02:48:57:WU00:FS02:0x21:Completed 1325000 out of 2500000 steps (53%)
02:50:14:WU00:FS02:0x21:Completed 1350000 out of 2500000 steps (54%)
02:51:30:WU00:FS02:0x21:Completed 1375000 out of 2500000 steps (55%)
02:52:47:WU00:FS02:0x21:Completed 1400000 out of 2500000 steps (56%)
02:53:21:WU03:FS01:0x21:Completed 6975000 out of 7500000 steps (93%)
02:54:04:WU00:FS02:0x21:Completed 1425000 out of 2500000 steps (57%)
02:55:21:WU00:FS02:0x21:Completed 1450000 out of 2500000 steps (58%)
02:56:38:WU00:FS02:0x21:Completed 1475000 out of 2500000 steps (59%)
02:57:54:WU00:FS02:0x21:Completed 1500000 out of 2500000 steps (60%)
02:59:11:WU00:FS02:0x21:Completed 1525000 out of 2500000 steps (61%)
03:00:28:WU00:FS02:0x21:Completed 1550000 out of 2500000 steps (62%)
03:01:44:WU00:FS02:0x21:Completed 1575000 out of 2500000 steps (63%)
03:03:01:WU00:FS02:0x21:Completed 1600000 out of 2500000 steps (64%)
03:04:19:WU00:FS02:0x21:Completed 1625000 out of 2500000 steps (65%)
03:05:35:WU00:FS02:0x21:Completed 1650000 out of 2500000 steps (66%)
03:06:51:WU00:FS02:0x21:Completed 1675000 out of 2500000 steps (67%)
03:08:08:WU00:FS02:0x21:Completed 1700000 out of 2500000 steps (68%)
03:09:25:WU00:FS02:0x21:Completed 1725000 out of 2500000 steps (69%)
03:10:34:WU03:FS01:0x21:Completed 7050000 out of 7500000 steps (94%)
03:10:42:WU00:FS02:0x21:Completed 1750000 out of 2500000 steps (70%)
03:11:59:WU00:FS02:0x21:Completed 1775000 out of 2500000 steps (71%)
03:13:15:WU00:FS02:0x21:Completed 1800000 out of 2500000 steps (72%)
03:14:33:WU00:FS02:0x21:Completed 1825000 out of 2500000 steps (73%)
03:15:49:WU00:FS02:0x21:Completed 1850000 out of 2500000 steps (74%)
03:17:06:WU00:FS02:0x21:Completed 1875000 out of 2500000 steps (75%)
03:18:22:WU00:FS02:0x21:Completed 1900000 out of 2500000 steps (76%)
03:19:40:WU00:FS02:0x21:Completed 1925000 out of 2500000 steps (77%)
03:20:56:WU00:FS02:0x21:Completed 1950000 out of 2500000 steps (78%)
03:22:13:WU00:FS02:0x21:Completed 1975000 out of 2500000 steps (79%)
03:23:29:WU00:FS02:0x21:Completed 2000000 out of 2500000 steps (80%)
03:24:46:WU00:FS02:0x21:Completed 2025000 out of 2500000 steps (81%)
03:26:03:WU00:FS02:0x21:Completed 2050000 out of 2500000 steps (82%)
03:27:20:WU00:FS02:0x21:Completed 2075000 out of 2500000 steps (83%)
03:27:48:WU03:FS01:0x21:Completed 7125000 out of 7500000 steps (95%)
03:28:36:WU00:FS02:0x21:Completed 2100000 out of 2500000 steps (84%)
03:29:54:WU00:FS02:0x21:Completed 2125000 out of 2500000 steps (85%)
03:31:10:WU00:FS02:0x21:Completed 2150000 out of 2500000 steps (86%)
03:32:27:WU00:FS02:0x21:Completed 2175000 out of 2500000 steps (87%)
03:33:43:WU00:FS02:0x21:Completed 2200000 out of 2500000 steps (88%)
03:35:01:WU00:FS02:0x21:Completed 2225000 out of 2500000 steps (89%)
03:36:17:WU00:FS02:0x21:Completed 2250000 out of 2500000 steps (90%)
03:37:34:WU00:FS02:0x21:Completed 2275000 out of 2500000 steps (91%)
03:38:50:WU00:FS02:0x21:Completed 2300000 out of 2500000 steps (92%)
03:40:08:WU00:FS02:0x21:Completed 2325000 out of 2500000 steps (93%)
03:41:24:WU00:FS02:0x21:Completed 2350000 out of 2500000 steps (94%)
03:42:41:WU00:FS02:0x21:Completed 2375000 out of 2500000 steps (95%)
03:43:57:WU00:FS02:0x21:Completed 2400000 out of 2500000 steps (96%)
03:45:01:WU03:FS01:0x21:Completed 7200000 out of 7500000 steps (96%)
03:45:15:WU00:FS02:0x21:Completed 2425000 out of 2500000 steps (97%)
03:46:31:WU00:FS02:0x21:Completed 2450000 out of 2500000 steps (98%)
03:47:48:WU00:FS02:0x21:Completed 2475000 out of 2500000 steps (99%)
03:47:48:WU01:FS02:Connecting to 171.67.108.45:80
03:47:48:WU01:FS02:Assigned to work server 140.163.4.245
03:47:48:WU01:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Hawaii [Radeon R9 200/300X Series] from 140.163.4.245
03:47:48:WU01:FS02:Connecting to 140.163.4.245:8080
03:47:48:WU01:FS02:Downloading 6.04MiB
03:47:54:WU01:FS02:Download 36.23%
03:48:00:WU01:FS02:Download 78.68%
03:48:03:WU01:FS02:Download complete
03:48:03:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10493 run:3 clone:35 gen:290 core:0x21 unit:0x000001a38ca304f555d6168632f963dd
03:49:04:WU00:FS02:0x21:Completed 2500000 out of 2500000 steps (100%)
03:49:05:WU00:FS02:0x21:Saving result file logfile_01.txt
03:49:05:WU00:FS02:0x21:Saving result file checkpointState.xml
03:49:06:WU00:FS02:0x21:Saving result file checkpt.crc
03:49:06:WU00:FS02:0x21:Saving result file log.txt
03:49:06:WU00:FS02:0x21:Saving result file positions.xtc
03:49:06:WU00:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
03:49:07:WU00:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:49:07:WU00:FS02:Sending unit results: id:00 state:SEND error:NO_ERROR project:9189 run:1 clone:9 gen:231 core:0x21 unit:0x0000017dab40415457cb2bbbd55fb65f
03:49:07:WU00:FS02:Uploading 4.65MiB to 171.64.65.84
03:49:07:WU00:FS02:Connecting to 171.64.65.84:8080
03:49:07:WU01:FS02:Starting
03:49:07:WU01:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 1 -gpu-vendor ati
03:49:07:WU01:FS02:Started FahCore on PID 1940
03:49:07:WU01:FS02:Core PID:4392
03:49:07:WU01:FS02:FahCore 0x21 started
03:49:08:WU01:FS02:0x21:*********************** Log Started 2016-12-31T03:49:07Z ***********************
03:49:08:WU01:FS02:0x21:Project: 10493 (Run 3, Clone 35, Gen 290)
03:49:08:WU01:FS02:0x21:Unit: 0x000001a38ca304f555d6168632f963dd
03:49:08:WU01:FS02:0x21:CPU: 0x00000000000000000000000000000000
03:49:08:WU01:FS02:0x21:Machine: 2
03:49:08:WU01:FS02:0x21:Reading tar file core.xml
03:49:08:WU01:FS02:0x21:Reading tar file system.xml
03:49:08:WU01:FS02:0x21:Reading tar file integrator.xml
03:49:08:WU01:FS02:0x21:Reading tar file state.xml
03:49:08:WU01:FS02:0x21:Digital signatures verified
03:49:08:WU01:FS02:0x21:Folding@home GPU Core21 Folding@home Core
03:49:08:WU01:FS02:0x21:Version 0.0.17
03:49:13:WU00:FS02:Upload 20.15%
03:49:17:WU01:FS02:0x21:Completed 0 out of 5000000 steps (0%)
03:49:17:WU01:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:49:19:WU00:FS02:Upload 38.96%
03:49:25:WU00:FS02:Upload 56.42%
03:49:31:WU00:FS02:Upload 75.23%
03:49:37:WU00:FS02:Upload 94.03%
03:49:44:WU00:FS02:Upload complete
03:49:44:WU00:FS02:Server responded WORK_ACK (400)
03:49:44:WU00:FS02:Final credit estimate, 29447.00 points
03:49:44:WU00:FS02:Cleaning up
03:54:55:WU01:FS02:0x21:Completed 50000 out of 5000000 steps (1%)
04:00:21:WU01:FS02:0x21:Completed 100000 out of 5000000 steps (2%)
04:02:13:WU03:FS01:0x21:Completed 7275000 out of 7500000 steps (97%)
04:05:51:WU01:FS02:0x21:Completed 150000 out of 5000000 steps (3%)
04:11:14:WU01:FS02:0x21:Completed 200000 out of 5000000 steps (4%)
04:16:40:WU01:FS02:0x21:Completed 250000 out of 5000000 steps (5%)
04:19:23:WU03:FS01:0x21:Completed 7350000 out of 7500000 steps (98%)
04:22:08:WU01:FS02:0x21:Completed 300000 out of 5000000 steps (6%)
04:27:35:WU01:FS02:0x21:Completed 350000 out of 5000000 steps (7%)
04:33:02:WU01:FS02:0x21:Completed 400000 out of 5000000 steps (8%)
04:36:36:WU03:FS01:0x21:Completed 7425000 out of 7500000 steps (99%)
04:36:37:WU00:FS01:Connecting to 171.67.108.45:80
04:36:37:WU00:FS01:Assigned to work server 140.163.4.243
04:36:37:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.243
04:36:37:WU00:FS01:Connecting to 140.163.4.243:8080
04:36:38:ERROR:WU00:FS01:Exception: Server did not assign work unit
04:36:38:WU00:FS01:Connecting to 171.67.108.45:80
04:36:38:WU00:FS01:Assigned to work server 171.67.108.159
04:36:38:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Hawaii [Radeon R9 200/300X Series] from 171.67.108.159
04:36:38:WU00:FS01:Connecting to 171.67.108.159:8080
04:36:38:WU00:FS01:Downloading 22.90MiB
04:36:44:WU00:FS01:Download 9.83%
04:36:50:WU00:FS01:Download 20.74%
04:36:56:WU00:FS01:Download 31.93%
04:37:02:WU00:FS01:Download 42.85%
04:37:08:WU00:FS01:Download 54.04%
04:37:14:WU00:FS01:Download 64.96%
04:37:20:WU00:FS01:Download 75.87%
04:37:26:WU00:FS01:Download 86.79%
04:37:32:WU00:FS01:Download 97.71%
04:37:33:WU00:FS01:Download complete
04:37:33:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9180 run:9 clone:3 gen:218 core:0x21 unit:0x00000139ab436c9f57bdce05f269e581
04:38:29:WU01:FS02:0x21:Completed 450000 out of 5000000 steps (9%)
04:43:53:WU01:FS02:0x21:Completed 500000 out of 5000000 steps (10%)
04:49:19:WU01:FS02:0x21:Completed 550000 out of 5000000 steps (11%)
04:53:47:WU03:FS01:0x21:Completed 7500000 out of 7500000 steps (100%)
04:53:47:WU03:FS01:0x21:Saving result file logfile_01.txt
04:53:48:WU03:FS01:0x21:Saving result file checkpointState.xml
04:53:48:WU03:FS01:0x21:Saving result file checkpt.crc
04:53:48:WU03:FS01:0x21:Saving result file log.txt
04:53:48:WU03:FS01:0x21:Saving result file positions.xtc
04:53:48:WU03:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
04:53:48:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:53:48:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:11711 run:3 clone:21 gen:29 core:0x21 unit:0x000000248ca304e758332b49760912ff
04:53:48:WU03:FS01:Uploading 10.33MiB to 140.163.4.231
04:53:48:WU03:FS01:Connecting to 140.163.4.231:8080
04:53:48:WU00:FS01:Starting
04:53:48:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 0 -gpu-vendor ati
04:53:48:WU00:FS01:Started FahCore on PID 2780
04:53:48:WU00:FS01:Core PID:3712
04:53:48:WU00:FS01:FahCore 0x21 started
04:53:49:WU00:FS01:0x21:*********************** Log Started 2016-12-31T04:53:48Z ***********************
04:53:49:WU00:FS01:0x21:Project: 9180 (Run 9, Clone 3, Gen 218)
04:53:49:WU00:FS01:0x21:Unit: 0x00000139ab436c9f57bdce05f269e581
04:53:49:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:53:49:WU00:FS01:0x21:Machine: 1
04:53:49:WU00:FS01:0x21:Reading tar file core.xml
04:53:49:WU00:FS01:0x21:Reading tar file integrator.xml
04:53:49:WU00:FS01:0x21:Reading tar file state.xml
04:53:49:WU00:FS01:0x21:Reading tar file system.xml
04:53:49:WU00:FS01:0x21:Digital signatures verified
04:53:49:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:53:49:WU00:FS01:0x21:Version 0.0.17
04:53:54:WU03:FS01:Upload 12.71%
04:53:55:WU00:FS01:0x21:Completed 0 out of 2500000 steps (0%)
04:53:55:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:54:07:WU03:FS01:Upload 23.00%
04:54:13:WU03:FS01:Upload 32.08%
04:54:19:WU03:FS01:Upload 40.55%
04:54:25:WU03:FS01:Upload 49.02%
04:54:31:WU03:FS01:Upload 56.89%
04:54:37:WU03:FS01:Upload 65.36%
04:54:43:WU03:FS01:Upload 73.83%
04:54:49:WU03:FS01:Upload 82.31%
04:54:50:WU01:FS02:0x21:Completed 600000 out of 5000000 steps (12%)
04:54:55:WU03:FS01:Upload 90.17%
04:55:01:WU03:FS01:Upload 98.65%
04:55:09:WU03:FS01:Upload complete
04:55:09:WU03:FS01:Server responded WORK_ACK (400)
04:55:09:WU03:FS01:Final credit estimate, 35204.00 points
04:55:09:WU03:FS01:Cleaning up
05:00:19:WU01:FS02:0x21:Completed 650000 out of 5000000 steps (13%)
05:01:35:WU00:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
05:05:45:WU01:FS02:0x21:Completed 700000 out of 5000000 steps (14%)
05:09:17:WU00:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
05:11:13:WU01:FS02:0x21:Completed 750000 out of 5000000 steps (15%)
05:16:42:WU01:FS02:0x21:Completed 800000 out of 5000000 steps (16%)
05:16:58:WU00:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
05:22:05:WU01:FS02:0x21:Completed 850000 out of 5000000 steps (17%)
05:24:39:WU00:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
05:27:33:WU01:FS02:0x21:Completed 900000 out of 5000000 steps (18%)
05:32:24:WU00:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
05:32:58:WU01:FS02:0x21:Completed 950000 out of 5000000 steps (19%)
05:38:25:WU01:FS02:0x21:Completed 1000000 out of 5000000 steps (20%)
05:40:05:WU00:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
05:43:53:WU01:FS02:0x21:Completed 1050000 out of 5000000 steps (21%)
05:47:45:WU00:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
05:49:21:WU01:FS02:0x21:Completed 1100000 out of 5000000 steps (22%)
05:54:46:WU01:FS02:0x21:Completed 1150000 out of 5000000 steps (23%)
05:55:23:WU00:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
06:00:12:WU01:FS02:0x21:Completed 1200000 out of 5000000 steps (24%)
06:03:07:WU00:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
06:05:37:WU01:FS02:0x21:Completed 1250000 out of 5000000 steps (25%)
06:10:47:WU00:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
06:11:04:WU01:FS02:0x21:Completed 1300000 out of 5000000 steps (26%)
06:16:27:WU01:FS02:0x21:Completed 1350000 out of 5000000 steps (27%)
06:18:25:WU00:FS01:0x21:Completed 275000 out of 2500000 steps (11%)
06:21:57:WU01:FS02:0x21:Completed 1400000 out of 5000000 steps (28%)
06:26:10:WU00:FS01:0x21:Completed 300000 out of 2500000 steps (12%)
06:27:23:WU01:FS02:0x21:Completed 1450000 out of 5000000 steps (29%)
06:32:51:WU01:FS02:0x21:Completed 1500000 out of 5000000 steps (30%)
06:33:52:WU00:FS01:0x21:Completed 325000 out of 2500000 steps (13%)
06:38:19:WU01:FS02:0x21:Completed 1550000 out of 5000000 steps (31%)
06:41:33:WU00:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
06:43:44:WU01:FS02:0x21:Completed 1600000 out of 5000000 steps (32%)
06:49:11:WU01:FS02:0x21:Completed 1650000 out of 5000000 steps (33%)
06:49:14:WU00:FS01:0x21:Completed 375000 out of 2500000 steps (15%)
06:54:39:WU01:FS02:0x21:Completed 1700000 out of 5000000 steps (34%)
06:56:55:WU00:FS01:0x21:Completed 400000 out of 2500000 steps (16%)
07:00:06:WU01:FS02:0x21:Completed 1750000 out of 5000000 steps (35%)
07:04:35:WU00:FS01:0x21:Completed 425000 out of 2500000 steps (17%)
07:05:33:WU01:FS02:0x21:Completed 1800000 out of 5000000 steps (36%)
07:10:59:WU01:FS02:0x21:Completed 1850000 out of 5000000 steps (37%)
07:12:17:WU00:FS01:0x21:Completed 450000 out of 2500000 steps (18%)
07:16:26:WU01:FS02:0x21:Completed 1900000 out of 5000000 steps (38%)
07:19:59:WU00:FS01:0x21:Completed 475000 out of 2500000 steps (19%)
07:21:51:WU01:FS02:0x21:Completed 1950000 out of 5000000 steps (39%)
07:27:19:WU01:FS02:0x21:Completed 2000000 out of 5000000 steps (40%)
07:27:42:WU00:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
07:32:48:WU01:FS02:0x21:Completed 2050000 out of 5000000 steps (41%)
07:35:26:WU00:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
07:38:11:WU01:FS02:0x21:Completed 2100000 out of 5000000 steps (42%)
07:43:09:WU00:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
07:43:40:WU01:FS02:0x21:Completed 2150000 out of 5000000 steps (43%)
07:49:04:WU01:FS02:0x21:Completed 2200000 out of 5000000 steps (44%)
07:50:51:WU00:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
07:54:28:WU01:FS02:0x21:Completed 2250000 out of 5000000 steps (45%)
07:58:30:WU00:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
07:59:55:WU01:FS02:0x21:Completed 2300000 out of 5000000 steps (46%)
******************************* Date: 2016-12-31 *******************************
08:05:21:WU01:FS02:0x21:Completed 2350000 out of 5000000 steps (47%)
08:06:10:WU00:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
08:10:48:WU01:FS02:0x21:Completed 2400000 out of 5000000 steps (48%)
08:13:48:WU00:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
08:16:15:WU01:FS02:0x21:Completed 2450000 out of 5000000 steps (49%)
08:21:26:WU00:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
08:21:39:WU01:FS02:0x21:Completed 2500000 out of 5000000 steps (50%)
08:27:05:WU01:FS02:0x21:Completed 2550000 out of 5000000 steps (51%)
08:29:05:WU00:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
08:32:29:WU01:FS02:0x21:Completed 2600000 out of 5000000 steps (52%)
08:36:45:WU00:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
08:37:55:WU01:FS02:0x21:Completed 2650000 out of 5000000 steps (53%)
08:43:20:WU01:FS02:0x21:Completed 2700000 out of 5000000 steps (54%)
08:44:27:WU00:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
08:48:46:WU01:FS02:0x21:Completed 2750000 out of 5000000 steps (55%)
08:52:08:WU00:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
08:54:14:WU01:FS02:0x21:Completed 2800000 out of 5000000 steps (56%)
08:59:43:WU01:FS02:0x21:Completed 2850000 out of 5000000 steps (57%)
08:59:49:WU00:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
09:05:14:WU01:FS02:0x21:Completed 2900000 out of 5000000 steps (58%)
09:07:33:WU00:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
09:10:39:WU01:FS02:0x21:Completed 2950000 out of 5000000 steps (59%)
09:15:15:WU00:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
09:16:07:WU01:FS02:0x21:Completed 3000000 out of 5000000 steps (60%)
09:21:36:WU01:FS02:0x21:Completed 3050000 out of 5000000 steps (61%)
09:22:54:WU00:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
09:27:03:WU01:FS02:0x21:Completed 3100000 out of 5000000 steps (62%)
09:30:35:WU00:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
09:32:32:WU01:FS02:0x21:Completed 3150000 out of 5000000 steps (63%)
09:38:00:WU01:FS02:0x21:Completed 3200000 out of 5000000 steps (64%)
09:38:18:WU00:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
09:43:27:WU01:FS02:0x21:Completed 3250000 out of 5000000 steps (65%)
09:46:00:WU00:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
09:48:55:WU01:FS02:0x21:Completed 3300000 out of 5000000 steps (66%)
09:53:42:WU00:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
09:54:22:WU01:FS02:0x21:Completed 3350000 out of 5000000 steps (67%)
09:59:50:WU01:FS02:0x21:Completed 3400000 out of 5000000 steps (68%)
10:01:25:WU00:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
10:05:14:WU01:FS02:0x21:Completed 3450000 out of 5000000 steps (69%)
10:09:08:WU00:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
10:10:38:WU01:FS02:0x21:Completed 3500000 out of 5000000 steps (70%)
10:16:08:WU01:FS02:0x21:Completed 3550000 out of 5000000 steps (71%)
10:16:48:WU00:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
10:21:33:WU01:FS02:0x21:Completed 3600000 out of 5000000 steps (72%)
10:24:31:WU00:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
10:27:00:WU01:FS02:0x21:Completed 3650000 out of 5000000 steps (73%)
10:32:10:WU00:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
10:32:23:WU01:FS02:0x21:Completed 3700000 out of 5000000 steps (74%)
10:37:53:WU01:FS02:0x21:Completed 3750000 out of 5000000 steps (75%)
10:39:51:WU00:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
10:43:25:WU01:FS02:0x21:Completed 3800000 out of 5000000 steps (76%)
10:47:31:WU00:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
10:48:49:WU01:FS02:0x21:Completed 3850000 out of 5000000 steps (77%)
10:54:20:WU01:FS02:0x21:Completed 3900000 out of 5000000 steps (78%)
10:55:12:WU00:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
10:59:46:WU01:FS02:0x21:Completed 3950000 out of 5000000 steps (79%)
11:02:51:WU00:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
11:05:12:WU01:FS02:0x21:Completed 4000000 out of 5000000 steps (80%)
11:10:32:WU00:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
11:10:40:WU01:FS02:0x21:Completed 4050000 out of 5000000 steps (81%)
11:16:07:WU01:FS02:0x21:Completed 4100000 out of 5000000 steps (82%)
11:18:17:WU00:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
11:21:37:WU01:FS02:0x21:Completed 4150000 out of 5000000 steps (83%)
11:25:58:WU00:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
11:27:02:WU01:FS02:0x21:Completed 4200000 out of 5000000 steps (84%)
11:32:29:WU01:FS02:0x21:Completed 4250000 out of 5000000 steps (85%)
11:33:38:WU00:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
11:37:56:WU01:FS02:0x21:Completed 4300000 out of 5000000 steps (86%)
11:41:20:WU00:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
11:43:23:WU01:FS02:0x21:Completed 4350000 out of 5000000 steps (87%)
11:48:49:WU01:FS02:0x21:Completed 4400000 out of 5000000 steps (88%)
11:49:01:WU00:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
11:54:12:WU01:FS02:0x21:Completed 4450000 out of 5000000 steps (89%)
11:56:42:WU00:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
11:59:38:WU01:FS02:0x21:Completed 4500000 out of 5000000 steps (90%)
12:04:21:WU00:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
12:05:06:WU01:FS02:0x21:Completed 4550000 out of 5000000 steps (91%)
12:10:33:WU01:FS02:0x21:Completed 4600000 out of 5000000 steps (92%)
12:12:00:WU00:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
12:16:01:WU01:FS02:0x21:Completed 4650000 out of 5000000 steps (93%)
12:19:41:WU00:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
12:21:26:WU01:FS02:0x21:Completed 4700000 out of 5000000 steps (94%)
12:26:50:WU01:FS02:0x21:Completed 4750000 out of 5000000 steps (95%)
12:27:23:WU00:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
12:32:15:WU01:FS02:0x21:Completed 4800000 out of 5000000 steps (96%)
12:35:02:WU00:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
12:37:42:WU01:FS02:0x21:Completed 4850000 out of 5000000 steps (97%)
12:42:40:WU00:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
12:43:07:WU01:FS02:0x21:Completed 4900000 out of 5000000 steps (98%)
12:48:30:WU01:FS02:0x21:Completed 4950000 out of 5000000 steps (99%)
12:48:31:WU02:FS02:Connecting to 171.67.108.45:80
12:48:31:WU02:FS02:Assigned to work server 140.163.4.231
12:48:31:WU02:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:Hawaii [Radeon R9 200/300X Series] from 140.163.4.231
12:48:31:WU02:FS02:Connecting to 140.163.4.231:8080
12:48:31:WU02:FS02:Downloading 16.67MiB
12:48:37:WU02:FS02:Download 13.12%
12:48:43:WU02:FS02:Download 28.49%
12:48:49:WU02:FS02:Download 43.48%
12:48:55:WU02:FS02:Download 58.85%
12:49:01:WU02:FS02:Download 73.84%
12:49:07:WU02:FS02:Download 89.21%
12:49:11:WU02:FS02:Download complete
12:49:11:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11712 run:7 clone:87 gen:9 core:0x21 unit:0x0000000a8ca304e758332b55fc0cd3bd
12:50:21:WU00:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
12:53:55:WU01:FS02:0x21:Completed 5000000 out of 5000000 steps (100%)
12:53:56:WU01:FS02:0x21:Saving result file logfile_01.txt
12:53:57:WU01:FS02:0x21:Saving result file checkpointState.xml
12:53:58:WU01:FS02:0x21:Saving result file checkpt.crc
12:53:58:WU01:FS02:0x21:Saving result file log.txt
12:53:58:WU01:FS02:0x21:Saving result file positions.xtc
12:53:59:WU01:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
12:54:00:WU01:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:54:00:WU01:FS02:Sending unit results: id:01 state:SEND error:NO_ERROR project:10493 run:3 clone:35 gen:290 core:0x21 unit:0x000001a38ca304f555d6168632f963dd
12:54:00:WU01:FS02:Uploading 16.06MiB to 140.163.4.245
12:54:00:WU01:FS02:Connecting to 140.163.4.245:8080
12:54:00:WU02:FS02:Starting
12:54:00:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 1 -gpu-vendor ati
12:54:00:WU02:FS02:Started FahCore on PID 8152
12:54:00:WU02:FS02:Core PID:8228
12:54:00:WU02:FS02:FahCore 0x21 started
12:54:01:WU02:FS02:0x21:*********************** Log Started 2016-12-31T12:54:00Z ***********************
12:54:01:WU02:FS02:0x21:Project: 11712 (Run 7, Clone 87, Gen 9)
12:54:01:WU02:FS02:0x21:Unit: 0x0000000a8ca304e758332b55fc0cd3bd
12:54:01:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
12:54:01:WU02:FS02:0x21:Machine: 2
12:54:01:WU02:FS02:0x21:Reading tar file core.xml
12:54:01:WU02:FS02:0x21:Reading tar file integrator.xml
12:54:01:WU02:FS02:0x21:Reading tar file state.xml
12:54:01:WU02:FS02:0x21:Reading tar file system.xml
12:54:01:WU02:FS02:0x21:Digital signatures verified
12:54:01:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
12:54:01:WU02:FS02:0x21:Version 0.0.17
12:54:06:WU01:FS02:Upload 8.56%
12:54:06:WU02:FS02:0x21:Completed 0 out of 7500000 steps (0%)
12:54:06:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:54:20:WU01:FS02:Upload 15.96%
12:54:26:WU01:FS02:Upload 21.79%
12:54:32:WU01:FS02:Upload 26.85%
12:54:38:WU01:FS02:Upload 32.30%
12:54:44:WU01:FS02:Upload 37.75%
12:54:50:WU01:FS02:Upload 42.81%
12:54:56:WU01:FS02:Upload 48.26%
12:55:02:WU01:FS02:Upload 53.70%
12:55:08:WU01:FS02:Upload 58.76%
12:55:14:WU01:FS02:Upload 64.21%
12:55:20:WU01:FS02:Upload 69.66%
12:55:26:WU01:FS02:Upload 74.72%
12:55:32:WU01:FS02:Upload 80.17%
12:55:38:WU01:FS02:Upload 85.61%
12:55:44:WU01:FS02:Upload 90.67%
12:55:50:WU01:FS02:Upload 96.12%
12:56:15:WU01:FS02:Upload complete
12:56:15:WU01:FS02:Server responded WORK_ACK (400)
12:56:15:WU01:FS02:Final credit estimate, 121533.00 points
12:56:15:WU01:FS02:Cleaning up
12:58:00:WU00:FS01:0x21:Completed 1575000 out of 2500000 steps (63%)
12:58:13:WU02:FS02:0x21:Completed 75000 out of 7500000 steps (1%)
13:02:20:WU02:FS02:0x21:Completed 150000 out of 7500000 steps (2%)
13:05:42:WU00:FS01:0x21:Completed 1600000 out of 2500000 steps (64%)
13:06:26:WU02:FS02:0x21:Completed 225000 out of 7500000 steps (3%)
13:10:33:WU02:FS02:0x21:Completed 300000 out of 7500000 steps (4%)
13:13:23:WU00:FS01:0x21:Completed 1625000 out of 2500000 steps (65%)
13:14:40:WU02:FS02:0x21:Completed 375000 out of 7500000 steps (5%)
13:18:46:WU02:FS02:0x21:Completed 450000 out of 7500000 steps (6%)
13:21:05:WU00:FS01:0x21:Completed 1650000 out of 2500000 steps (66%)
13:22:53:WU02:FS02:0x21:Completed 525000 out of 7500000 steps (7%)
13:27:00:WU02:FS02:0x21:Completed 600000 out of 7500000 steps (8%)
13:28:46:WU00:FS01:0x21:Completed 1675000 out of 2500000 steps (67%)
13:31:06:WU02:FS02:0x21:Completed 675000 out of 7500000 steps (9%)
13:35:12:WU02:FS02:0x21:Completed 750000 out of 7500000 steps (10%)
13:36:26:WU00:FS01:0x21:Completed 1700000 out of 2500000 steps (68%)
13:39:19:WU02:FS02:0x21:Completed 825000 out of 7500000 steps (11%)
13:43:25:WU02:FS02:0x21:Completed 900000 out of 7500000 steps (12%)
13:44:06:WU00:FS01:0x21:Completed 1725000 out of 2500000 steps (69%)
13:47:31:WU02:FS02:0x21:Completed 975000 out of 7500000 steps (13%)
13:51:38:WU02:FS02:0x21:Completed 1050000 out of 7500000 steps (14%)
13:51:48:WU00:FS01:0x21:Completed 1750000 out of 2500000 steps (70%)
13:55:45:WU02:FS02:0x21:Completed 1125000 out of 7500000 steps (15%)
13:59:29:WU00:FS01:0x21:Completed 1775000 out of 2500000 steps (71%)
13:59:51:WU02:FS02:0x21:Completed 1200000 out of 7500000 steps (16%)
14:03:58:WU02:FS02:0x21:Completed 1275000 out of 7500000 steps (17%)
14:07:10:WU00:FS01:0x21:Completed 1800000 out of 2500000 steps (72%)
14:08:05:WU02:FS02:0x21:Completed 1350000 out of 7500000 steps (18%)
14:12:11:WU02:FS02:0x21:Completed 1425000 out of 7500000 steps (19%)
14:14:50:WU00:FS01:0x21:Completed 1825000 out of 2500000 steps (73%)
14:16:17:WU02:FS02:0x21:Completed 1500000 out of 7500000 steps (20%)
14:20:24:WU02:FS02:0x21:Completed 1575000 out of 7500000 steps (21%)
14:22:33:WU00:FS01:0x21:Completed 1850000 out of 2500000 steps (74%)
14:24:30:WU02:FS02:0x21:Completed 1650000 out of 7500000 steps (22%)
14:28:36:WU02:FS02:0x21:Completed 1725000 out of 7500000 steps (23%)
14:30:16:WU00:FS01:0x21:Completed 1875000 out of 2500000 steps (75%)
14:32:44:WU02:FS02:0x21:Completed 1800000 out of 7500000 steps (24%)
14:36:50:WU02:FS02:0x21:Completed 1875000 out of 7500000 steps (25%)
14:37:56:WU00:FS01:0x21:Completed 1900000 out of 2500000 steps (76%)
14:40:56:WU02:FS02:0x21:Completed 1950000 out of 7500000 steps (26%)
14:45:03:WU02:FS02:0x21:Completed 2025000 out of 7500000 steps (27%)
14:45:42:WU00:FS01:0x21:Completed 1925000 out of 2500000 steps (77%)
14:49:10:WU02:FS02:0x21:Completed 2100000 out of 7500000 steps (28%)
14:53:17:WU02:FS02:0x21:Completed 2175000 out of 7500000 steps (29%)
14:53:23:WU00:FS01:0x21:Completed 1950000 out of 2500000 steps (78%)
14:57:23:WU02:FS02:0x21:Completed 2250000 out of 7500000 steps (30%)
15:01:02:WU00:FS01:0x21:Completed 1975000 out of 2500000 steps (79%)
15:01:30:WU02:FS02:0x21:Completed 2325000 out of 7500000 steps (31%)
15:05:37:WU02:FS02:0x21:Completed 2400000 out of 7500000 steps (32%)
15:08:47:WU00:FS01:0x21:Completed 2000000 out of 2500000 steps (80%)
15:09:43:WU02:FS02:0x21:Completed 2475000 out of 7500000 steps (33%)
15:13:50:WU02:FS02:0x21:Completed 2550000 out of 7500000 steps (34%)
15:16:29:WU00:FS01:0x21:Completed 2025000 out of 2500000 steps (81%)
15:17:56:WU02:FS02:0x21:Completed 2625000 out of 7500000 steps (35%)
15:22:03:WU02:FS02:0x21:Completed 2700000 out of 7500000 steps (36%)
15:24:10:WU00:FS01:0x21:Completed 2050000 out of 2500000 steps (82%)
15:26:10:WU02:FS02:0x21:Completed 2775000 out of 7500000 steps (37%)
15:30:16:WU02:FS02:0x21:Completed 2850000 out of 7500000 steps (38%)
15:31:51:WU00:FS01:0x21:Completed 2075000 out of 2500000 steps (83%)
15:34:22:WU02:FS02:0x21:Completed 2925000 out of 7500000 steps (39%)
15:38:29:WU02:FS02:0x21:Completed 3000000 out of 7500000 steps (40%)
15:39:30:WU00:FS01:0x21:Completed 2100000 out of 2500000 steps (84%)
15:42:36:WU02:FS02:0x21:Completed 3075000 out of 7500000 steps (41%)
15:46:42:WU02:FS02:0x21:Completed 3150000 out of 7500000 steps (42%)
15:47:14:WU00:FS01:0x21:Completed 2125000 out of 2500000 steps (85%)
15:50:48:WU02:FS02:0x21:Completed 3225000 out of 7500000 steps (43%)
15:54:54:WU00:FS01:0x21:Completed 2150000 out of 2500000 steps (86%)
15:54:55:WU02:FS02:0x21:Completed 3300000 out of 7500000 steps (44%)
15:59:02:WU02:FS02:0x21:Completed 3375000 out of 7500000 steps (45%)
16:02:36:WU00:FS01:0x21:Completed 2175000 out of 2500000 steps (87%)
16:03:08:WU02:FS02:0x21:Completed 3450000 out of 7500000 steps (46%)
16:07:15:WU02:FS02:0x21:Completed 3525000 out of 7500000 steps (47%)
16:10:15:WU00:FS01:0x21:Completed 2200000 out of 2500000 steps (88%)
16:11:21:WU02:FS02:0x21:Completed 3600000 out of 7500000 steps (48%)
16:15:28:WU02:FS02:0x21:Completed 3675000 out of 7500000 steps (49%)
16:17:59:WU00:FS01:0x21:Completed 2225000 out of 2500000 steps (89%)
16:19:34:WU02:FS02:0x21:Completed 3750000 out of 7500000 steps (50%)
16:23:41:WU02:FS02:0x21:Completed 3825000 out of 7500000 steps (51%)
16:25:42:WU00:FS01:0x21:Completed 2250000 out of 2500000 steps (90%)
16:27:48:WU02:FS02:0x21:Completed 3900000 out of 7500000 steps (52%)
16:31:54:WU02:FS02:0x21:Completed 3975000 out of 7500000 steps (53%)
16:33:25:WU00:FS01:0x21:Completed 2275000 out of 2500000 steps (91%)
16:36:02:WU02:FS02:0x21:Completed 4050000 out of 7500000 steps (54%)
16:40:08:WU02:FS02:0x21:Completed 4125000 out of 7500000 steps (55%)
16:41:07:WU00:FS01:0x21:Completed 2300000 out of 2500000 steps (92%)
16:44:15:WU02:FS02:0x21:Completed 4200000 out of 7500000 steps (56%)
16:48:22:WU02:FS02:0x21:Completed 4275000 out of 7500000 steps (57%)
16:48:50:WU00:FS01:0x21:Completed 2325000 out of 2500000 steps (93%)
16:52:28:WU02:FS02:0x21:Completed 4350000 out of 7500000 steps (58%)
16:56:31:WU00:FS01:0x21:Completed 2350000 out of 2500000 steps (94%)
16:56:35:WU02:FS02:0x21:Completed 4425000 out of 7500000 steps (59%)
17:00:41:WU02:FS02:0x21:Completed 4500000 out of 7500000 steps (60%)
17:02:04:17:127.0.0.1:New Web connection
17:04:13:WU00:FS01:0x21:Completed 2375000 out of 2500000 steps (95%)
17:04:50:WU02:FS02:0x21:Completed 4575000 out of 7500000 steps (61%)
17:08:57:WU02:FS02:0x21:Completed 4650000 out of 7500000 steps (62%)
17:11:53:WU00:FS01:0x21:Completed 2400000 out of 2500000 steps (96%)
17:13:05:WU02:FS02:0x21:Completed 4725000 out of 7500000 steps (63%)
17:17:13:WU02:FS02:0x21:Completed 4800000 out of 7500000 steps (64%)
17:19:37:WU00:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
17:21:20:WU02:FS02:0x21:Completed 4875000 out of 7500000 steps (65%)
17:25:27:WU02:FS02:0x21:Completed 4950000 out of 7500000 steps (66%)
17:27:19:WU00:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
17:29:35:WU02:FS02:0x21:Completed 5025000 out of 7500000 steps (67%)
17:33:42:WU02:FS02:0x21:Completed 5100000 out of 7500000 steps (68%)
17:34:59:WU00:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
17:35:00:WU01:FS01:Connecting to 171.67.108.45:80
17:35:00:WU01:FS01:Assigned to work server 140.163.4.243
17:35:00:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Hawaii [Radeon R9 200/300X Series] from 140.163.4.243
17:35:00:WU01:FS01:Connecting to 140.163.4.243:8080
17:35:01:WU01:FS01:Downloading 4.68MiB
17:35:07:WU01:FS01:Download 54.76%
17:35:12:WU01:FS01:Download complete
17:35:12:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11706 run:0 clone:390 gen:119 core:0x21 unit:0x000000998ca304f356ff2aec19d8b673
17:37:49:WU02:FS02:0x21:Completed 5175000 out of 7500000 steps (69%)
17:41:56:WU02:FS02:0x21:Completed 5250000 out of 7500000 steps (70%)
17:42:39:WU00:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
17:42:41:WU00:FS01:0x21:Saving result file logfile_01.txt
17:42:41:WU00:FS01:0x21:Saving result file checkpointState.xml
17:42:41:WU00:FS01:0x21:Saving result file checkpt.crc
17:42:41:WU00:FS01:0x21:Saving result file log.txt
17:42:41:WU00:FS01:0x21:Saving result file positions.xtc
17:42:41:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
17:42:42:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:42:42:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9180 run:9 clone:3 gen:218 core:0x21 unit:0x00000139ab436c9f57bdce05f269e581
17:42:42:WU00:FS01:Uploading 13.63MiB to 171.67.108.159
17:42:42:WU01:FS01:Starting
17:42:42:WU00:FS01:Connecting to 171.67.108.159:8080
17:42:42:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ASUS-Z97-AR/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7288 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:42:42:WU01:FS01:Started FahCore on PID 6856
17:42:42:WU01:FS01:Core PID:10412
17:42:42:WU01:FS01:FahCore 0x21 started
17:42:42:WU01:FS01:0x21:*********************** Log Started 2016-12-31T17:42:42Z ***********************
17:42:42:WU01:FS01:0x21:Project: 11706 (Run 0, Clone 390, Gen 119)
17:42:42:WU01:FS01:0x21:Unit: 0x000000998ca304f356ff2aec19d8b673
17:42:42:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:42:42:WU01:FS01:0x21:Machine: 1
17:42:42:WU01:FS01:0x21:Reading tar file core.xml
17:42:42:WU01:FS01:0x21:Reading tar file system.xml
17:42:42:WU01:FS01:0x21:Reading tar file integrator.xml
17:42:42:WU01:FS01:0x21:Reading tar file state.xml
17:42:43:WU01:FS01:0x21:Digital signatures verified
17:42:43:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:42:43:WU01:FS01:0x21:Version 0.0.17
17:42:48:WU00:FS01:Upload 7.79%
17:42:51:WU01:FS01:0x21:Completed 0 out of 5000000 steps (0%)
17:42:51:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:42:54:WU00:FS01:Upload 12.84%
17:43:00:WU00:FS01:Upload 17.88%
17:43:06:WU00:FS01:Upload 22.47%
17:43:12:WU00:FS01:Upload 27.05%
17:43:18:WU00:FS01:Upload 32.10%
17:43:24:WU00:FS01:Upload 37.14%
17:43:30:WU00:FS01:Upload 42.64%
17:43:36:WU00:FS01:Upload 47.23%
17:43:42:WU00:FS01:Upload 52.73%
17:43:48:WU00:FS01:Upload 57.77%
17:43:54:WU00:FS01:Upload 62.81%
17:44:00:WU00:FS01:Upload 67.86%
17:44:06:WU00:FS01:Upload 72.44%
17:44:12:WU00:FS01:Upload 77.95%
17:44:18:WU00:FS01:Upload 82.99%
17:44:24:WU00:FS01:Upload 87.57%
17:44:30:WU00:FS01:Upload 92.62%
17:44:36:WU00:FS01:Upload 97.66%
17:44:40:WU00:FS01:Upload complete
17:44:41:WU00:FS01:Server responded WORK_ACK (400)
17:44:41:WU00:FS01:Final credit estimate, 16587.00 points
17:44:41:WU00:FS01:Cleaning up
17:46:04:WU02:FS02:0x21:Completed 5325000 out of 7500000 steps (71%)
17:50:12:WU02:FS02:0x21:Completed 5400000 out of 7500000 steps (72%)
17:54:19:WU02:FS02:0x21:Completed 5475000 out of 7500000 steps (73%)
17:58:28:WU02:FS02:0x21:Completed 5550000 out of 7500000 steps (74%)
18:02:34:WU02:FS02:0x21:Completed 5625000 out of 7500000 steps (75%)
18:04:38:WU01:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
18:06:41:WU02:FS02:0x21:Completed 5700000 out of 7500000 steps (76%)
18:10:48:WU02:FS02:0x21:Completed 5775000 out of 7500000 steps (77%)
Mod edit: added Code tags to log listing, they are available from the Full Editor
Post by foldy »
FS01 looks slower than FS02 also from logs. What are the pcie slot speeds for the GPUs for your mainboard?
You can check it with GPUZ https://www.techpowerup.com/gpuz/
mike9o
Post by mike9o »
Thank you again.
One is running at PCI-Express x8 v3.0, the other at x8 v1.1.
mike9o
Post by mike9o »
Looking at the GPU-Z sensors, one is running at a core clock of 300 MHz, the other at 1070. An even greater disparity between memory speeds.
Do you know how to fix this? :)
Post by foldy »
pcie x8 v1.1 could be a little slow, does your mainboard have another faster slot?
Is any limit set for temperature or fan speed?
I once had such low clock speed and it was fixed by reboot PC.
The OS can probably recover after a GPU-fault and GPU reset but it's not uncommon for drivers to downclock a GPU after a GPURESET until you reboot.
