Not Getting Credit for completed WU's
Bigfan3
Post by Bigfan3 »
Finshed 1500 units and that was a week ago.
I gave it time to update but still don't see it...
Ready to finish another 1500 and wondering if I'll get credit for that.
team: 90718 User: Bigfan3
Small team but we are in a heated race, and this should put me ahead.
mhuahah!
Thanks
Can we have the project/run/gen/clone of the missing WU :?:
gwildperson
Post by gwildperson »
To report missing credits, you need to give the Moderators the numbers for Project, Run, Clone, and Gen (at least). It can also be helpful to give the time & date that the WU was downloaded and the time-date of the upload message starting with the words "Thank you" but they can tell a lot from the P R C G.
Look for the file called FAHlog.txt or FAHlog-Prev.txt
Bigfan3
Post by Bigfan3 »
Sorry for the lack of info.
I think this is it. About 99% sure it is.
Folding@Home Gromacs Simulated Tempering Core
Version 1.10 (Oct 4, 2007)
Preparing to commence simulation
- Ensuring status. Please wait.
- User disabled assembly optimizations.
- Previous termination of core was improper.
- Files status OK
- Expanded 359337 -> 2160354 (decompressed 601.2 percent)
Project: 4111 (Run 40, Clone 13, Gen 0)
Entering M.D.
(Starting from checkpoint)
Protein: p4111_ntl9_unf_Amber03_Extended
Writing local files
Completed 1077684 out of 1500000 steps (72%)
Writing local files
Completed 1080000 out of 1500000 steps (72%)
Writing local files
Completed 1095000 out of 1500000 steps (73%)
Writing local files
Completed 1110000 out of 1500000 steps (74%)
Writing local files
Completed 1125000 out of 1500000 steps (75%)
Writing local files
Completed 1140000 out of 1500000 steps (76%)
Writing local files
Completed 1155000 out of 1500000 steps (77%)
Writing local files
Completed 1170000 out of 1500000 steps (78%)
Writing local files
Completed 1185000 out of 1500000 steps (79%)
Writing local files
Completed 1200000 out of 1500000 steps (80%)
Writing local files
Completed 1215000 out of 1500000 steps (81%)
Writing local files
Completed 1230000 out of 1500000 steps (82%)
Writing local files
Completed 1245000 out of 1500000 steps (83%)
Writing local files
Completed 1260000 out of 1500000 steps (84%)
Writing local files
Completed 1275000 out of 1500000 steps (85%)
Writing local files
Completed 1290000 out of 1500000 steps (86%)
Writing local files
Completed 1305000 out of 1500000 steps (87%)
Writing local files
Completed 1320000 out of 1500000 steps (88%)
Writing local files
Completed 1335000 out of 1500000 steps (89%)
Writing local files
Completed 1350000 out of 1500000 steps (90%)
Writing local files
Completed 1365000 out of 1500000 steps (91%)
Writing local files
Completed 1380000 out of 1500000 steps (92%)
Writing local files
Completed 1395000 out of 1500000 steps (93%)
Writing local files
Completed 1410000 out of 1500000 steps (94%)
Writing local files
Completed 1425000 out of 1500000 steps (95%)
Writing local files
Completed 1440000 out of 1500000 steps (96%)
Writing local files
Completed 1455000 out of 1500000 steps (97%)
Writing local files
Completed 1470000 out of 1500000 steps (98%)
Writing local files
Completed 1485000 out of 1500000 steps (99%)
Writing local files
Completed 1500000 out of 1500000 steps (100%)
Writing final coordinates.
Past main M.D. loop
Finished Work Unit:
- Reading up to 356664 from "work/wudata_08.arc": Read 356664
- Reading up to 3873692 from "work/wudata_08.xtc": Read 3873692
goefile size: 0
logfile size: 83013
Leaving Run
- Writing 4965363 bytes of core data to disk...
Done: 4964851 -> 4218033 (compressed to 84.9 percent)
... Done.
- Shutting down core
Folding@home Core Shutdown: FINISHED_UNIT
There is no record of Project: 4111 (Run 40, Clone 13, Gen 0) being returned.
In the log that you posted, you show the WU being finished but you do not show that it was uploaded. What happened after the last part that you posted? Did you see an upload and then a "Thank you ...." message? Perhaps the data is still on your system and was never uploaded.
ChelseaOilman
Post by ChelseaOilman »
Bigfan3 wrote:- User disabled assembly optimizations.
I think the log you posted is from one of the files in the work folder, instead of the FAHlog.txt or FAHlog-Prev.txt files in the main F@H folder. We need the info from FAHlog.txt or FAHlog-Prev.txt as gwildperson mentioned.
It appears you need to reconfigure your client to allow assembly optimizations to be used. WUs will finish much faster.
While your reconfiguring your client you might want to change the setting to use IE Settings from "Yes" to "No".
that will prevent your client from continually resubmitting the same finished WU multiple times.
Hi Bigfan3 (team 90718),
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-19 17:13:14 for 174 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-19 17:13:14 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-20 17:13:00 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-21 10:13:30 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-21 16:12:51 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-21 19:12:54 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-23 12:13:11 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-24 00:12:50 for 0 points of credit.
Your WU (P891 R2 C211 G2) was added to the stats database on 2007-11-24 05:12:47 for 0 points of credit.
This continues on 14 more times. :(
Bigfan3
Post by Bigfan3 »
This Only goes back to the 10th, and I think that's when the 2nd batch of 1500 started.
(FAHlog-Prev)
--- Opening Log file [December 10 20:19:11]
# Windows Graphical Edition ###################################################
Folding@Home Client Version 5.03
http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[20:19:11] - Ask before connecting: Yes
[20:19:11] - Use IE connection settings: Yes
[20:19:11] - User name: Bigfan3 (Team 90718)
[20:19:11] - User ID: 1CFCEBF12F398EF8
[20:19:11] - Machine ID: 1
[20:19:11]
[20:19:11] Loaded queue successfully.
[20:19:11] Initialization complete
[20:19:11] + Benchmarking ...
[20:19:15]
[20:19:15] + Processing work unit
[20:19:15] + Attempting to send results
[20:19:15] Core required: FahCore_81.exe
[20:19:15] Core found.
[20:19:15] Working on Unit 09 [December 10 20:19:15]
[20:19:15] + Working ...
[20:19:16] - Presenting message box asking to network.
[20:19:16]
[20:19:16] *------------------------------*
[20:19:16] Folding@Home Gromacs Simulated Tempering Core
[20:19:16] Version 1.10 (Oct 4, 2007)
[20:19:16]
[20:19:16] Preparing to commence simulation
[20:19:16] - Ensuring status. Please wait.
[20:19:19] Couldn't send HTTP request to server (wininet)
[20:19:19] + Could not connect to Work Server (results)
[20:19:19] (171.65.103.162:8080)
[20:19:19] - Error: Could not transmit unit 00 (completed November 14) to work server.
[20:19:19] + Attempting to send results
[20:19:20] Couldn't send HTTP request to server (wininet)
[20:19:20] + Could not connect to Work Server (results)
[20:19:20] (171.65.103.100:8080)
[20:19:20] Could not transmit unit 00 to Collection server; keeping in queue.
[20:19:20] + Attempting to send results
[20:19:21] Couldn't send HTTP request to server (wininet)
[20:19:21] + Could not connect to Work Server (results)
[20:19:21] (171.65.103.162:8080)
[20:19:21] - Error: Could not transmit unit 01 (completed November 20) to work server.
[20:19:21] + Attempting to send results
[20:19:22] Couldn't send HTTP request to server (wininet)
[20:19:22] + Could not connect to Work Server (results)
[20:19:22] (171.65.103.100:8080)
[20:19:22] Could not transmit unit 01 to Collection server; keeping in queue.
[20:19:22] + Attempting to send results
[20:19:23] Couldn't send HTTP request to server (wininet)
[20:19:23] + Could not connect to Work Server (results)
[20:19:23] (171.65.103.162:8080)
[20:19:23] - Error: Could not transmit unit 02 (completed November 17) to work server.
[20:19:23] + Attempting to send results
[20:19:24] Couldn't send HTTP request to server (wininet)
[20:19:24] + Could not connect to Work Server (results)
[20:19:24] (171.65.103.100:8080)
[20:19:24] Could not transmit unit 02 to Collection server; keeping in queue.
[20:19:24] + Attempting to send results
[20:19:25] Couldn't send HTTP request to server (wininet)
[20:19:25] + Could not connect to Work Server (results)
[20:19:25] (171.65.103.162:8080)
[20:19:25] - Error: Could not transmit unit 03 (completed November 23) to work server.
[20:19:25] + Attempting to send results
[20:19:26] Couldn't send HTTP request to server (wininet)
[20:19:26] + Could not connect to Work Server (results)
[20:19:26] (171.65.103.100:8080)
[20:19:26] Could not transmit unit 03 to Collection server; keeping in queue.
[20:19:26] + Attempting to send results
[20:19:27] Couldn't send HTTP request to server (wininet)
[20:19:27] + Could not connect to Work Server (results)
[20:19:27] (130.49.240.81:80)
[20:19:27] - Error: Could not transmit unit 04 (completed November 18) to work server.
[20:19:27] + Attempting to send results
[20:19:28] Couldn't send HTTP request to server (wininet)
[20:19:28] + Could not connect to Work Server (results)
[20:19:28] (130.49.240.77:80)
[20:19:28] Could not transmit unit 04 to Collection server; keeping in queue.
[20:19:28] + Attempting to send results
[20:19:29] Couldn't send HTTP request to server (wininet)
[20:19:29] + Could not connect to Work Server (results)
[20:19:29] (171.65.103.162:8080)
[20:19:29] - Error: Could not transmit unit 05 (completed November 25) to work server.
[20:19:29] + Attempting to send results
[20:19:30] Couldn't send HTTP request to server (wininet)
[20:19:30] + Could not connect to Work Server (results)
[20:19:30] (171.65.103.100:8080)
[20:19:30] Could not transmit unit 05 to Collection server; keeping in queue.
[20:19:30] + Attempting to send results
[20:19:32] Couldn't send HTTP request to server (wininet)
[20:19:32] + Could not connect to Work Server (results)
[20:19:32] (171.65.103.162:8080)
[20:19:32] - Error: Could not transmit unit 06 (completed December 1) to work server.
[20:19:32] + Attempting to send results
[20:19:33] Couldn't send HTTP request to server (wininet)
[20:19:33] + Could not connect to Work Server (results)
[20:19:33] (171.65.103.100:8080)
[20:19:33] Could not transmit unit 06 to Collection server; keeping in queue.
[20:19:33] + Attempting to send results
[20:19:33] - User disabled assembly optimizations.
[20:19:33] - Previous termination of core was improper.
[20:19:33] - Files status OK
[20:19:34] - Expanded 736600 -> 3703559 (decompressed 502.7 percent)
[20:19:34] Couldn't send HTTP request to server (wininet)
[20:19:34] + Could not connect to Work Server (results)
[20:19:34] (171.64.65.65:8080)
[20:19:34] - Error: Could not transmit unit 07 (completed December 4) to work server.
[20:19:34] + Attempting to send results
[20:19:35]
[20:19:35] Project: 4113 (Run 89, Clone 19, Gen 2)
[20:19:35]
[20:19:35] Entering M.D.
[20:19:35] Couldn't send HTTP request to server (wininet)
[20:19:35] + Could not connect to Work Server (results)
[20:19:35] (171.65.103.100:8080)
[20:19:35] Could not transmit unit 07 to Collection server; keeping in queue.
[20:19:35] + Attempting to send results
[20:19:36] Couldn't send HTTP request to server (wininet)
[20:19:36] + Could not connect to Work Server (results)
[20:19:36] (171.64.65.111:8080)
[20:19:36] - Error: Could not transmit unit 08 (completed December 8) to work server.
[20:19:36] + Attempting to send results
[20:19:37] Couldn't send HTTP request to server (wininet)
[20:19:37] + Could not connect to Work Server (results)
[20:19:37] (171.64.122.76:8080)
[20:19:37] Could not transmit unit 08 to Collection server; keeping in queue.
[20:19:56] (Starting from checkpoint)
[20:19:56] Protein: p4113_villinwt_big_folded_Amber03_Native
[20:19:56]
[20:19:56] Writing local files
[20:19:56] Completed 395774 out of 1500000 steps (26)
[20:52:10] Writing local files
[20:52:10] Completed 405000 out of 1500000 steps (27)
[21:44:58] Writing local files
[21:44:58] Completed 420000 out of 1500000 steps (28)
[22:38:03] Writing local files
[22:38:03] Completed 435000 out of 1500000 steps (29)
[23:30:20] Writing local files
[23:30:20] Completed 450000 out of 1500000 steps (30)
--- Opening Log file [December 11 02:16:00]
[02:16:00] - Ask before connecting: Yes
[02:16:00] - Use IE connection settings: Yes
[02:16:00] - User name: Bigfan3 (Team 90718)
[02:16:00] - User ID: 1CFCEBF12F398EF8
[02:16:00] - Machine ID: 1
[02:16:00]
[02:16:00] Loaded queue successfully.
[02:16:00] Initialization complete
[02:16:00] + Benchmarking ...
[02:16:04]
[02:16:04] + Processing work unit
[02:16:04] + Attempting to send results
[02:16:04] Core required: FahCore_81.exe
[02:16:04] Core found.
[02:16:04] Working on Unit 09 [December 11 02:16:04]
[02:16:04] + Working ...
[02:16:06] - Presenting message box asking to network.
[02:16:07]
[02:16:07] *------------------------------*
[02:16:07] Folding@Home Gromacs Simulated Tempering Core
[02:16:07] Version 1.10 (Oct 4, 2007)
[02:16:07]
[02:16:07] Preparing to commence simulation
[02:16:07] - Ensuring status. Please wait.
[02:16:11] Couldn't send HTTP request to server (wininet)
[02:16:11] + Could not connect to Work Server (results)
[02:16:11] (171.65.103.162:8080)
[02:16:11] - Error: Could not transmit unit 00 (completed November 14) to work server.
[02:16:11] + Attempting to send results
[02:16:12] Couldn't send HTTP request to server (wininet)
[02:16:12] + Could not connect to Work Server (results)
[02:16:12] (171.65.103.100:8080)
[02:16:12] Could not transmit unit 00 to Collection server; keeping in queue.
[02:16:12] + Attempting to send results
[02:16:13] Couldn't send HTTP request to server (wininet)
[02:16:13] + Could not connect to Work Server (results)
[02:16:13] (171.65.103.162:8080)
[02:16:13] - Error: Could not transmit unit 01 (completed November 20) to work server.
[02:16:13] + Attempting to send results
[02:16:15] Couldn't send HTTP request to server (wininet)
[02:16:15] + Could not connect to Work Server (results)
[02:16:15] (171.65.103.100:8080)
[02:16:15] Could not transmit unit 01 to Collection server; keeping in queue.
[02:16:15] + Attempting to send results
[02:16:16] Couldn't send HTTP request to server (wininet)
[02:16:16] + Could not connect to Work Server (results)
[02:16:16] (171.65.103.162:8080)
[02:16:16] - Error: Could not transmit unit 02 (completed November 17) to work server.
[02:16:16] + Attempting to send results
[02:16:17] Couldn't send HTTP request to server (wininet)
[02:16:17] + Could not connect to Work Server (results)
[02:16:17] (171.65.103.100:8080)
[02:16:17] Could not transmit unit 02 to Collection server; keeping in queue.
[02:16:17] + Attempting to send results
[02:16:18] Couldn't send HTTP request to server (wininet)
[02:16:18] + Could not connect to Work Server (results)
[02:16:18] (171.65.103.162:8080)
[02:16:18] - Error: Could not transmit unit 03 (completed November 23) to work server.
[02:16:18] + Attempting to send results
[02:16:19] Couldn't send HTTP request to server (wininet)
[02:16:19] + Could not connect to Work Server (results)
[02:16:19] (171.65.103.100:8080)
[02:16:19] Could not transmit unit 03 to Collection server; keeping in queue.
[02:16:19] + Attempting to send results
[02:16:20] Couldn't send HTTP request to server (wininet)
[02:16:20] + Could not connect to Work Server (results)
[02:16:20] (130.49.240.81:80)
[02:16:20] - Error: Could not transmit unit 04 (completed November 18) to work server.
[02:16:20] + Attempting to send results
[02:16:21] Couldn't send HTTP request to server (wininet)
[02:16:21] + Could not connect to Work Server (results)
[02:16:21] (130.49.240.77:80)
[02:16:21] Could not transmit unit 04 to Collection server; keeping in queue.
[02:16:21] + Attempting to send results
[02:16:22] Couldn't send HTTP request to server (wininet)
[02:16:22] + Could not connect to Work Server (results)
[02:16:22] (171.65.103.162:8080)
[02:16:22] - Error: Could not transmit unit 05 (completed November 25) to work server.
[02:16:22] + Attempting to send results
[02:16:23] Couldn't send HTTP request to server (wininet)
[02:16:23] + Could not connect to Work Server (results)
[02:16:23] (171.65.103.100:8080)
[02:16:23] Could not transmit unit 05 to Collection server; keeping in queue.
[02:16:23] + Attempting to send results
[02:16:24] Couldn't send HTTP request to server (wininet)
[02:16:24] + Could not connect to Work Server (results)
[02:16:24] (171.65.103.162:8080)
[02:16:24] - Error: Could not transmit unit 06 (completed December 1) to work server.
[02:16:24] + Attempting to send results
[02:16:24] - User disabled assembly optimizations.
[02:16:25] - Previous termination of core was improper.
[02:16:25] - Files status OK
[02:16:25] Couldn't send HTTP request to server (wininet)
[02:16:25] + Could not connect to Work Server (results)
[02:16:25] (171.65.103.100:8080)
[02:16:25] Could not transmit unit 06 to Collection server; keeping in queue.
[02:16:25] + Attempting to send results
[02:16:25] - Expanded 736600 -> 3703559 (decompressed 502.7 percent)
[02:16:27]
[02:16:27] Project: 4113 (Run 89, Clone 19, Gen 2)
[02:16:27]
[02:16:27] Entering M.D.
[02:16:28] Couldn't send HTTP request to server (wininet)
[02:16:28] + Could not connect to Work Server (results)
[02:16:28] (171.64.65.65:8080)
[02:16:28] - Error: Could not transmit unit 07 (completed December 4) to work server.
[02:16:28] + Attempting to send results
[02:16:29] Couldn't send HTTP request to server (wininet)
[02:16:29] + Could not connect to Work Server (results)
[02:16:29] (171.65.103.100:8080)
[02:16:29] Could not transmit unit 07 to Collection server; keeping in queue.
[02:16:29] + Attempting to send results
[02:16:30] Couldn't send HTTP request to server (wininet)
[02:16:30] + Could not connect to Work Server (results)
[02:16:30] (171.64.65.111:8080)
[02:16:30] - Error: Could not transmit unit 08 (completed December 8) to work server.
[02:16:30] + Attempting to send results
[02:16:31] Couldn't send HTTP request to server (wininet)
[02:16:31] + Could not connect to Work Server (results)
[02:16:31] (171.64.122.76:8080)
[02:16:31] Could not transmit unit 08 to Collection server; keeping in queue.
[02:16:48] (Starting from checkpoint)
[02:16:48] Protein: p4113_villinwt_big_folded_Amber03_Native
[02:16:48]
[02:16:48] Writing local files
[02:16:48] Completed 456604 out of 1500000 steps (30)
[02:46:07] Writing local files
[02:46:07] Completed 465000 out of 1500000 steps (31)
[03:38:15] Writing local files
[03:38:15] Completed 480000 out of 1500000 steps (32)
[04:30:23] Writing local files
[04:30:23] Completed 495000 out of 1500000 steps (33)
[05:22:31] Writing local files
[05:22:31] Completed 510000 out of 1500000 steps (34)
[06:14:39] Writing local files
[06:14:39] Completed 525000 out of 1500000 steps (35)
[07:06:47] Writing local files
[07:06:47] Completed 540000 out of 1500000 steps (36)
[07:58:56] Writing local files
[07:58:56] Completed 555000 out of 1500000 steps (37)
[08:16:31] + Attempting to send results
[08:17:00] Error: Got status code 504 from server
[08:17:00] + Could not connect to Work Server (results)
[08:17:00] (171.65.103.162:8080)
[08:17:00] - Error: Could not transmit unit 00 (completed November 14) to work server.
[08:17:00] + Attempting to send results
[08:17:21] Error: Got status code 504 from server
[08:17:21] + Could not connect to Work Server (results)
[08:17:21] (171.65.103.100:8080)
[08:17:21] Could not transmit unit 00 to Collection server; keeping in queue.
[08:17:21] + Attempting to send results
[08:17:40] Error: Got status code 503 from server
[08:17:40] + Could not connect to Work Server (results)
[08:17:40] (171.65.103.162:8080)
[08:17:40] - Error: Could not transmit unit 01 (completed November 20) to work server.
[08:17:40] + Attempting to send results
[08:17:49] Error: Got status code 503 from server
[08:17:49] + Could not connect to Work Server (results)
[08:17:49] (171.65.103.100:8080)
[08:17:49] Could not transmit unit 01 to Collection server; keeping in queue.
[08:17:49] + Attempting to send results
[08:18:18] Error: Got status code 504 from server
[08:18:18] + Could not connect to Work Server (results)
[08:18:18] (171.65.103.162:8080)
[08:18:18] - Error: Could not transmit unit 02 (completed November 17) to work server.
[08:18:18] + Attempting to send results
[08:18:31] Error: Got status code 503 from server
[08:18:31] + Could not connect to Work Server (results)
[08:18:31] (171.65.103.100:8080)
[08:18:31] Could not transmit unit 02 to Collection server; keeping in queue.
[08:18:31] + Attempting to send results
[08:19:01] Couldn't send HTTP request to server (wininet)
[08:19:01] + Could not connect to Work Server (results)
[08:19:01] (171.65.103.162:8080)
[08:19:01] - Error: Could not transmit unit 03 (completed November 23) to work server.
[08:19:01] + Attempting to send results
[08:19:32] Couldn't send HTTP request to server (wininet)
[08:19:32] + Could not connect to Work Server (results)
[08:19:32] (171.65.103.100:8080)
[08:19:32] Could not transmit unit 03 to Collection server; keeping in queue.
[08:19:32] + Attempting to send results
[08:20:02] Couldn't send HTTP request to server (wininet)
[08:20:02] + Could not connect to Work Server (results)
[08:20:02] (130.49.240.81:80)
[08:20:02] - Error: Could not transmit unit 04 (completed November 18) to work server.
[08:20:02] + Attempting to send results
[08:20:33] Couldn't send HTTP request to server (wininet)
[08:20:33] + Could not connect to Work Server (results)
[08:20:33] (130.49.240.77:80)
[08:20:33] Could not transmit unit 04 to Collection server; keeping in queue.
[08:20:33] + Attempting to send results
[08:21:04] Couldn't send HTTP request to server (wininet)
[08:21:04] + Could not connect to Work Server (results)
[08:21:04] (171.65.103.162:8080)
[08:21:04] - Error: Could not transmit unit 05 (completed November 25) to work server.
[08:21:04] + Attempting to send results
[08:21:25] Error: Got status code 504 from server
[08:21:25] + Could not connect to Work Server (results)
[08:21:25] (171.65.103.100:8080)
[08:21:25] Could not transmit unit 05 to Collection server; keeping in queue.
[08:21:25] + Attempting to send results
[08:21:46] Error: Got status code 504 from server
[08:21:46] + Could not connect to Work Server (results)
[08:21:46] (171.65.103.162:8080)
[08:21:46] - Error: Could not transmit unit 06 (completed December 1) to work server.
[08:21:46] + Attempting to send results
[08:22:46] Couldn't send HTTP request to server (wininet)
[08:22:46] + Could not connect to Work Server (results)
[08:22:46] (171.65.103.100:8080)
[08:22:46] Could not transmit unit 06 to Collection server; keeping in queue.
[08:22:46] + Attempting to send results
[08:23:46] Couldn't send HTTP request to server (wininet)
[08:23:46] + Could not connect to Work Server (results)
[08:23:46] (171.64.65.65:8080)
[08:23:46] - Error: Could not transmit unit 07 (completed December 4) to work server.
[08:23:46] + Attempting to send results
[08:24:46] Couldn't send HTTP request to server (wininet)
[08:24:46] + Could not connect to Work Server (results)
[08:24:46] (171.65.103.100:8080)
[08:24:46] Could not transmit unit 07 to Collection server; keeping in queue.
[08:24:46] + Attempting to send results
[08:25:46] Couldn't send HTTP request to server (wininet)
[08:25:46] + Could not connect to Work Server (results)
[08:25:46] (171.64.65.111:8080)
[08:25:46] - Error: Could not transmit unit 08 (completed December 8) to work server.
[08:25:46] + Attempting to send results
[08:26:46] Couldn't send HTTP request to server (wininet)
[08:26:46] + Could not connect to Work Server (results)
[08:26:46] (171.64.122.76:8080)
[08:26:46] Could not transmit unit 08 to Collection server; keeping in queue.
[08:51:07] Writing local files
[08:51:07] Completed 570000 out of 1500000 steps (38)
[09:43:21] Writing local files
[09:43:21] Completed 585000 out of 1500000 steps (39)
[10:35:34] Writing local files
[10:35:34] Completed 600000 out of 1500000 steps (40)
[11:27:41] Writing local files
[11:27:41] Completed 615000 out of 1500000 steps (41)
[12:19:47] Writing local files
[12:19:47] Completed 630000 out of 1500000 steps (42)
[13:11:52] Writing local files
[13:11:52] Completed 645000 out of 1500000 steps (43)
[14:03:57] Writing local files
[14:03:57] Completed 660000 out of 1500000 steps (44)
[14:26:46] + Attempting to send results
[14:28:46] Couldn't send HTTP request to server (wininet)
[14:28:46] + Could not connect to Work Server (results)
[14:28:46] (171.65.103.162:8080)
[14:28:46] - Error: Could not transmit unit 00 (completed November 14) to work server.
[14:28:46] + Attempting to send results
[14:30:46] Couldn't send HTTP request to server (wininet)
[14:30:46] + Could not connect to Work Server (results)
[14:30:46] (171.65.103.100:8080)
[14:30:46] Could not transmit unit 00 to Collection server; keeping in queue.
[14:30:46] + Attempting to send results
[14:31:46] Couldn't send HTTP request to server (wininet)
[14:31:46] + Could not connect to Work Server (results)
[14:31:46] (171.65.103.162:8080)
[14:31:46] - Error: Could not transmit unit 01 (completed November 20) to work server.
[14:31:46] + Attempting to send results
[14:32:46] Couldn't send HTTP request to server (wininet)
[14:32:46] + Could not connect to Work Server (results)
[14:32:46] (171.65.103.100:8080)
[14:32:46] Could not transmit unit 01 to Collection server; keeping in queue.
[14:32:46] + Attempting to send results
[14:33:46] Couldn't send HTTP request to server (wininet)
[14:33:46] + Could not connect to Work Server (results)
[14:33:46] (171.65.103.162:8080)
[14:33:46] - Error: Could not transmit unit 02 (completed November 17) to work server.
[14:33:46] + Attempting to send results
[14:34:46] Couldn't send HTTP request to server (wininet)
[14:34:46] + Could not connect to Work Server (results)
[14:34:46] (171.65.103.100:8080)
[14:34:46] Could not transmit unit 02 to Collection server; keeping in queue.
[14:34:46] + Attempting to send results
[14:35:46] Couldn't send HTTP request to server (wininet)
[14:35:46] + Could not connect to Work Server (results)
[14:35:46] (171.65.103.162:8080)
[14:35:46] - Error: Could not transmit unit 03 (completed November 23) to work server.
[14:35:46] + Attempting to send results
[14:36:46] Couldn't send HTTP request to server (wininet)
[14:36:46] + Could not connect to Work Server (results)
[14:36:46] (171.65.103.100:8080)
[14:36:46] Could not transmit unit 03 to Collection server; keeping in queue.
[14:36:46] + Attempting to send results
[14:37:46] Couldn't send HTTP request to server (wininet)
[14:37:46] + Could not connect to Work Server (results)
[14:37:46] (130.49.240.81:80)
[14:37:46] - Error: Could not transmit unit 04 (completed November 18) to work server.
[14:37:46] + Attempting to send results
[14:38:46] Couldn't send HTTP request to server (wininet)
[14:38:46] + Could not connect to Work Server (results)
[14:38:46] (130.49.240.77:80)
[14:38:46] Could not transmit unit 04 to Collection server; keeping in queue.
[14:38:46] + Attempting to send results
[14:39:46] Couldn't send HTTP request to server (wininet)
[14:39:46] + Could not connect to Work Server (results)
[14:39:46] (171.65.103.162:8080)
[14:39:46] - Error: Could not transmit unit 05 (completed November 25) to work server.
[14:39:46] + Attempting to send results
[14:40:46] Couldn't send HTTP request to server (wininet)
[14:40:46] + Could not connect to Work Server (results)
[14:40:46] (171.65.103.100:8080)
[14:40:46] Could not transmit unit 05 to Collection server; keeping in queue.
[14:40:46] + Attempting to send results
[14:41:46] Couldn't send HTTP request to server (wininet)
[14:41:46] + Could not connect to Work Server (results)
[14:41:46] (171.65.103.162:8080)
[14:41:46] - Error: Could not transmit unit 06 (completed December 1) to work server.
[14:41:46] + Attempting to send results
[14:42:46] Couldn't send HTTP request to server (wininet)
[14:42:46] + Could not connect to Work Server (results)
[14:42:46] (171.65.103.100:8080)
[14:42:46] Could not transmit unit 06 to Collection server; keeping in queue.
[14:42:46] + Attempting to send results
[14:43:46] Couldn't send HTTP request to server (wininet)
[14:43:46] + Could not connect to Work Server (results)
[14:43:46] (171.64.65.65:8080)
[14:43:46] - Error: Could not transmit unit 07 (completed December 4) to work server.
[14:43:46] + Attempting to send results
[14:44:46] Couldn't send HTTP request to server (wininet)
[14:44:46] + Could not connect to Work Server (results)
[14:44:46] (171.65.103.100:8080)
[14:44:46] Could not transmit unit 07 to Collection server; keeping in queue.
[14:44:46] + Attempting to send results
[14:45:46] Couldn't send HTTP request to server (wininet)
[14:45:46] + Could not connect to Work Server (results)
[14:45:46] (171.64.65.111:8080)
[14:45:46] - Error: Could not transmit unit 08 (completed December 8) to work server.
[14:45:46] + Attempting to send results
[14:46:46] Couldn't send HTTP request to server (wininet)
[14:46:46] + Could not connect to Work Server (results)
[14:46:46] (171.64.122.76:8080)
[14:46:46] Could not transmit unit 08 to Collection server; keeping in queue.
[14:56:30] Writing local files
[14:56:30] Completed 675000 out of 1500000 steps (45)
[15:07:06] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
Folding@Home Client Shutdown.
--- Opening Log file [December 11 15:07:42]
[15:07:42] - Ask before connecting: Yes
[15:07:42] - Use IE connection settings: Yes
[15:07:42] - User name: Bigfan3 (Team 90718)
[15:07:42] - User ID: 1CFCEBF12F398EF8
[15:07:42] - Machine ID: 1
[15:07:42]
[15:07:42] Loaded queue successfully.
[15:07:42] Initialization complete
[15:07:42] + Benchmarking ...
[15:07:46]
[15:07:46] + Processing work unit
[15:07:46] + Attempting to send results
[15:07:46] Core required: FahCore_81.exe
[15:07:46] Core found.
[15:07:46] Working on Unit 09 [December 11 15:07:46]
[15:07:46] + Working ...
[15:07:46] - Presenting message box asking to network.
[15:07:47]
[15:07:47] *------------------------------*
[15:07:47] Folding@Home Gromacs Simulated Tempering Core
[15:07:47] Version 1.10 (Oct 4, 2007)
[15:07:47]
[15:07:47] Preparing to commence simulation
[15:07:47] - User disabled assembly optimizations.
[15:07:47] - Files status OK
[15:07:47] - Expanded 736600 -> 3703559 (decompressed 502.7 percent)
[15:07:47]
[15:07:47] Project: 4113 (Run 89, Clone 19, Gen 2)
[15:07:47]
[15:07:47] Entering M.D.
[15:07:48] Error: Got status code 503 from server
[15:07:48] + Could not connect to Work Server (results)
[15:07:48] (171.65.103.162:8080)
[15:07:48] - Error: Could not transmit unit 00 (completed November 14) to work server.
[15:07:48] + Attempting to send results
[15:07:49] Error: Got status code 503 from server
[15:07:49] + Could not connect to Work Server (results)
[15:07:49] (171.65.103.100:8080)
[15:07:49] Could not transmit unit 00 to Collection server; keeping in queue.
[15:07:49] + Attempting to send results
[15:07:50] Error: Got status code 503 from server
[15:07:50] + Could not connect to Work Server (results)
[15:07:50] (171.65.103.162:8080)
[15:07:50] - Error: Could not transmit unit 01 (completed November 20) to work server.
[15:07:50] + Attempting to send results
[15:07:51] Error: Got status code 503 from server
[15:07:51] + Could not connect to Work Server (results)
[15:07:51] (171.65.103.100:8080)
[15:07:51] Could not transmit unit 01 to Collection server; keeping in queue.
[15:07:51] + Attempting to send results
[15:08:08] (Starting from checkpoint)
[15:08:08] Protein: p4113_villinwt_big_folded_Amber03_Native
[15:08:08]
[15:08:08] Writing local files
[15:08:08] Completed 677820 out of 1500000 steps (45)
[15:08:22] Couldn't send HTTP request to server (wininet)
[15:08:22] + Could not connect to Work Server (results)
[15:08:22] (171.65.103.162:8080)
[15:08:22] - Error: Could not transmit unit 02 (completed November 17) to work server.
[15:08:22] + Attempting to send results
[15:08:52] Couldn't send HTTP request to server (wininet)
[15:08:52] + Could not connect to Work Server (results)
[15:08:52] (171.65.103.100:8080)
[15:08:52] Could not transmit unit 02 to Collection server; keeping in queue.
[15:08:52] + Attempting to send results
[15:09:02] Error: Got status code 503 from server
[15:09:02] + Could not connect to Work Server (results)
[15:09:02] (171.65.103.162:8080)
[15:09:02] - Error: Could not transmit unit 03 (completed November 23) to work server.
[15:09:02] + Attempting to send results
[15:09:12] Error: Got status code 503 from server
[15:09:12] + Could not connect to Work Server (results)
[15:09:12] (171.65.103.100:8080)
[15:09:12] Could not transmit unit 03 to Collection server; keeping in queue.
[15:09:12] + Attempting to send results
[15:09:43] Couldn't send HTTP request to server (wininet)
[15:09:43] + Could not connect to Work Server (results)
[15:09:43] (130.49.240.81:80)
[15:09:43] - Error: Could not transmit unit 04 (completed November 18) to work server.
[15:09:43] + Attempting to send results
[15:10:14] Couldn't send HTTP request to server (wininet)
[15:10:14] + Could not connect to Work Server (results)
[15:10:14] (130.49.240.77:80)
[15:10:14] Could not transmit unit 04 to Collection server; keeping in queue.
[15:10:14] + Attempting to send results
[15:10:44] Couldn't send HTTP request to server (wininet)
[15:10:44] + Could not connect to Work Server (results)
[15:10:44] (171.65.103.162:8080)
[15:10:44] - Error: Could not transmit unit 05 (completed November 25) to work server.
[15:10:44] + Attempting to send results
[15:11:15] Couldn't send HTTP request to server (wininet)
[15:11:15] + Could not connect to Work Server (results)
[15:11:15] (171.65.103.100:8080)
[15:11:15] Could not transmit unit 05 to Collection server; keeping in queue.
[15:11:15] + Attempting to send results
[15:11:45] Couldn't send HTTP request to server (wininet)
[15:11:45] + Could not connect to Work Server (results)
[15:11:45] (171.65.103.162:8080)
[15:11:45] - Error: Could not transmit unit 06 (completed December 1) to work server.
[15:11:45] + Attempting to send results
[15:12:16] Couldn't send HTTP request to server (wininet)
[15:12:16] + Could not connect to Work Server (results)
[15:12:16] (171.65.103.100:8080)
[15:12:16] Could not transmit unit 06 to Collection server; keeping in queue.
[15:12:16] + Attempting to send results
[15:12:46] Couldn't send HTTP request to server (wininet)
[15:12:46] + Could not connect to Work Server (results)
[15:12:46] (171.64.65.65:8080)
[15:12:46] - Error: Could not transmit unit 07 (completed December 4) to work server.
[15:12:46] + Attempting to send results
[15:13:17] Couldn't send HTTP request to server (wininet)
[15:13:17] + Could not connect to Work Server (results)
[15:13:17] (171.65.103.100:8080)
[15:13:17] Could not transmit unit 07 to Collection server; keeping in queue.
[15:13:17] + Attempting to send results
[15:13:48] Couldn't send HTTP request to server (wininet)
[15:13:48] + Could not connect to Work Server (results)
[15:13:48] (171.64.65.111:8080)
[15:13:48] - Error: Could not transmit unit 08 (completed December 8) to work server.
[15:13:48] + Attempting to send results
[15:14:18] Couldn't send HTTP request to server (wininet)
[15:14:18] + Could not connect to Work Server (results)
[15:14:18] (171.64.122.76:8080)
[15:14:18] Could not transmit unit 08 to Collection server; keeping in queue.
[15:50:31] Writing local files
[15:50:31] Completed 690000 out of 1500000 steps (46)
[16:42:39] Writing local files
[16:42:39] Completed 705000 out of 1500000 steps (47)
[17:34:47] Writing local files
[17:34:47] Completed 720000 out of 1500000 steps (48)
[18:26:56] Writing local files
[18:26:56] Completed 735000 out of 1500000 steps (49)
[19:19:05] Writing local files
[19:19:05] Completed 750000 out of 1500000 steps (50)
[20:11:13] Writing local files
[20:11:13] Completed 765000 out of 1500000 steps (51)
[21:03:21] Writing local files
[21:03:21] Completed 780000 out of 1500000 steps (52)
[21:14:18] + Attempting to send results
[21:14:49] Couldn't send HTTP request to server (wininet)
[21:14:49] + Could not connect to Work Server (results)
[21:14:49] (171.65.103.162:8080)
[21:14:49] - Error: Could not transmit unit 00 (completed November 14) to work server.
[21:14:49] + Attempting to send results
[21:15:19] Couldn't send HTTP request to server (wininet)
[21:15:19] + Could not connect to Work Server (results)
[21:15:19] (171.65.103.100:8080)
[21:15:19] Could not transmit unit 00 to Collection server; keeping in queue.
[21:15:19] + Attempting to send results
[21:15:50] Couldn't send HTTP request to server (wininet)
[21:15:50] + Could not connect to Work Server (results)
[21:15:50] (171.65.103.162:8080)
[21:15:50] - Error: Could not transmit unit 01 (completed November 20) to work server.
[21:15:50] + Attempting to send results
[21:16:21] Couldn't send HTTP request to server (wininet)
[21:16:21] + Could not connect to Work Server (results)
[21:16:21] (171.65.103.100:8080)
[21:16:21] Could not transmit unit 01 to Collection server; keeping in queue.
[21:16:21] + Attempting to send results
[21:16:51] Couldn't send HTTP request to server (wininet)
[21:16:51] + Could not connect to Work Server (results)
[21:16:51] (171.65.103.162:8080)
[21:16:51] - Error: Could not transmit unit 02 (completed November 17) to work server.
[21:16:51] + Attempting to send results
[21:17:22] Couldn't send HTTP request to server (wininet)
[21:17:22] + Could not connect to Work Server (results)
[21:17:22] (171.65.103.100:8080)
[21:17:22] Could not transmit unit 02 to Collection server; keeping in queue.
[21:17:22] + Attempting to send results
[21:17:52] Couldn't send HTTP request to server (wininet)
[21:17:52] + Could not connect to Work Server (results)
[21:17:52] (171.65.103.162:8080)
[21:17:52] - Error: Could not transmit unit 03 (completed November 23) to work server.
[21:17:52] + Attempting to send results
[21:18:18] Error: Got status code 504 from server
[21:18:18] + Could not connect to Work Server (results)
[21:18:18] (171.65.103.100:8080)
[21:18:18] Could not transmit unit 03 to Collection server; keeping in queue.
[21:18:18] + Attempting to send results
[21:18:48] Couldn't send HTTP request to server (wininet)
[21:18:48] + Could not connect to Work Server (results)
[21:18:48] (130.49.240.81:80)
[21:18:48] - Error: Could not transmit unit 04 (completed November 18) to work server.
[21:18:48] + Attempting to send results
[21:19:19] Couldn't send HTTP request to server (wininet)
[21:19:19] + Could not connect to Work Server (results)
[21:19:19] (130.49.240.77:80)
[21:19:19] Could not transmit unit 04 to Collection server; keeping in queue.
[21:19:19] + Attempting to send results
[21:19:50] Couldn't send HTTP request to server (wininet)
[21:19:50] + Could not connect to Work Server (results)
[21:19:50] (171.65.103.162:8080)
[21:19:50] - Error: Could not transmit unit 05 (completed November 25) to work server.
[21:19:50] + Attempting to send results
[21:20:20] Couldn't send HTTP request to server (wininet)
[21:20:20] + Could not connect to Work Server (results)
[21:20:20] (171.65.103.100:8080)
[21:20:20] Could not transmit unit 05 to Collection server; keeping in queue.
[21:20:20] + Attempting to send results
[21:20:41] Error: Got status code 503 from server
[21:20:41] + Could not connect to Work Server (results)
[21:20:41] (171.65.103.162:8080)
[21:20:41] - Error: Could not transmit unit 06 (completed December 1) to work server.
[21:20:41] + Attempting to send results
[21:21:41] Couldn't send HTTP request to server (wininet)
[21:21:41] + Could not connect to Work Server (results)
[21:21:41] (171.65.103.100:8080)
[21:21:41] Could not transmit unit 06 to Collection server; keeping in queue.
[21:21:41] + Attempting to send results
[21:22:41] Couldn't send HTTP request to server (wininet)
[21:22:41] + Could not connect to Work Server (results)
[21:22:41] (171.64.65.65:8080)
[21:22:41] - Error: Could not transmit unit 07 (completed December 4) to work server.
[21:22:41] + Attempting to send results
[21:23:41] Couldn't send HTTP request to server (wininet)
[21:23:41] + Could not connect to Work Server (results)
[21:23:41] (171.65.103.100:8080)
[21:23:41] Could not transmit unit 07 to Collection server; keeping in queue.
[21:23:41] + Attempting to send results
[21:24:41] Couldn't send HTTP request to server (wininet)
[21:24:41] + Could not connect to Work Server (results)
[21:24:41] (171.64.65.111:8080)
[21:24:41] - Error: Could not transmit unit 08 (completed December 8) to work server.
[21:24:41] + Attempting to send results
[21:25:41] Couldn't send HTTP request to server (wininet)
[21:25:41] + Could not connect to Work Server (results)
[21:25:41] (171.64.122.76:8080)
[21:25:41] Could not transmit unit 08 to Collection server; keeping in queue.
[21:55:31] Writing local files
[21:55:31] Completed 795000 out of 1500000 steps (53)
[22:35:41] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[22:47:49] Writing local files
[22:47:49] Completed 810000 out of 1500000 steps (54)
[23:13:15] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[23:21:01] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[23:40:36] Writing local files
[23:40:36] Completed 825000 out of 1500000 steps (55)
[23:45:36] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[23:48:06] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[00:33:37] Writing local files
[00:33:37] Completed 840000 out of 1500000 steps (56)
[00:34:33] Opening http://www.folding.org/...
[00:34:34] Opening http://www.folding.org/...
[00:35:15] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[01:26:11] Writing local files
[01:26:11] Completed 855000 out of 1500000 steps (57)
[02:20:28] Writing local files
[02:20:28] Completed 870000 out of 1500000 steps (58)
[03:15:11] Writing local files
[03:15:11] Completed 885000 out of 1500000 steps (59)
[03:25:41] + Attempting to send results
[03:27:41] Couldn't send HTTP request to server (wininet)
[03:27:41] + Could not connect to Work Server (results)
[03:27:41] (171.65.103.162:8080)
[03:27:41] - Error: Could not transmit unit 00 (completed November 14) to work server.
[03:27:41] + Attempting to send results
[03:29:41] Couldn't send HTTP request to server (wininet)
[03:29:41] + Could not connect to Work Server (results)
[03:29:41] (171.65.103.100:8080)
[03:29:41] Could not transmit unit 00 to Collection server; keeping in queue.
[03:29:41] + Attempting to send results
[03:30:41] Couldn't send HTTP request to server (wininet)
[03:30:41] + Could not connect to Work Server (results)
[03:30:41] (171.65.103.162:8080)
[03:30:41] - Error: Could not transmit unit 01 (completed November 20) to work server.
[03:30:41] + Attempting to send results
[03:31:42] Couldn't send HTTP request to server (wininet)
[03:31:42] + Could not connect to Work Server (results)
[03:31:42] (171.65.103.100:8080)
[03:31:42] Could not transmit unit 01 to Collection server; keeping in queue.
[03:31:42] + Attempting to send results
[03:32:42] Couldn't send HTTP request to server (wininet)
[03:32:42] + Could not connect to Work Server (results)
[03:32:42] (171.65.103.162:8080)
[03:32:42] - Error: Could not transmit unit 02 (completed November 17) to work server.
[03:32:42] + Attempting to send results
[03:33:42] Couldn't send HTTP request to server (wininet)
[03:33:42] + Could not connect to Work Server (results)
[03:33:42] (171.65.103.100:8080)
[03:33:42] Could not transmit unit 02 to Collection server; keeping in queue.
[03:33:42] + Attempting to send results
[03:34:42] Couldn't send HTTP request to server (wininet)
[03:34:42] + Could not connect to Work Server (results)
[03:34:42] (171.65.103.162:8080)
[03:34:42] - Error: Could not transmit unit 03 (completed November 23) to work server.
[03:34:42] + Attempting to send results
[03:35:42] Couldn't send HTTP request to server (wininet)
[03:35:42] + Could not connect to Work Server (results)
[03:35:42] (171.65.103.100:8080)
[03:35:42] Could not transmit unit 03 to Collection server; keeping in queue.
[03:35:42] + Attempting to send results
[03:36:42] Couldn't send HTTP request to server (wininet)
[03:36:42] + Could not connect to Work Server (results)
[03:36:42] (130.49.240.81:80)
[03:36:42] - Error: Could not transmit unit 04 (completed November 18) to work server.
[03:36:42] + Attempting to send results
[03:37:42] Couldn't send HTTP request to server (wininet)
[03:37:42] + Could not connect to Work Server (results)
[03:37:42] (130.49.240.77:80)
[03:37:42] Could not transmit unit 04 to Collection server; keeping in queue.
[03:37:42] + Attempting to send results
[03:38:42] Couldn't send HTTP request to server (wininet)
[03:38:42] + Could not connect to Work Server (results)
[03:38:42] (171.65.103.162:8080)
[03:38:42] - Error: Could not transmit unit 05 (completed November 25) to work server.
[03:38:42] + Attempting to send results
[03:39:42] Couldn't send HTTP request to server (wininet)
[03:39:42] + Could not connect to Work Server (results)
[03:39:42] (171.65.103.100:8080)
[03:39:42] Could not transmit unit 05 to Collection server; keeping in queue.
[03:39:42] + Attempting to send results
[03:40:42] Couldn't send HTTP request to server (wininet)
[03:40:42] + Could not connect to Work Server (results)
[03:40:42] (171.65.103.162:8080)
[03:40:42] - Error: Could not transmit unit 06 (completed December 1) to work server.
[03:40:42] + Attempting to send results
[03:41:42] Couldn't send HTTP request to server (wininet)
[03:41:42] + Could not connect to Work Server (results)
[03:41:42] (171.65.103.100:8080)
[03:41:42] Could not transmit unit 06 to Collection server; keeping in queue.
[03:41:42] + Attempting to send results
[03:42:42] Couldn't send HTTP request to server (wininet)
[03:42:42] + Could not connect to Work Server (results)
[03:42:42] (171.64.65.65:8080)
[03:42:42] - Error: Could not transmit unit 07 (completed December 4) to work server.
[03:42:42] + Attempting to send results
[03:43:42] Couldn't send HTTP request to server (wininet)
[03:43:42] + Could not connect to Work Server (results)
[03:43:42] (171.65.103.100:8080)
[03:43:42] Could not transmit unit 07 to Collection server; keeping in queue.
[03:43:42] + Attempting to send results
[03:44:42] Couldn't send HTTP request to server (wininet)
[03:44:42] + Could not connect to Work Server (results)
[03:44:42] (171.64.65.111:8080)
[03:44:42] - Error: Could not transmit unit 08 (completed December 8) to work server.
[03:44:42] + Attempting to send results
[03:45:42] Couldn't send HTTP request to server (wininet)
[03:45:42] + Could not connect to Work Server (results)
[03:45:42] (171.64.122.76:8080)
[03:45:42] Could not transmit unit 08 to Collection server; keeping in queue.
[04:08:19] Writing local files
[04:08:19] Completed 900000 out of 1500000 steps (60)
[05:01:28] Writing local files
[05:01:28] Completed 915000 out of 1500000 steps (61)
[05:03:08] Opening http://vspx27.stanford.edu/cgi-bin/main ... me=Bigfan3...
[05:54:16] Writing local files
[05:54:16] Completed 930000 out of 1500000 steps (62)
[06:46:45] Writing local files
[06:46:45] Completed 945000 out of 1500000 steps (63)
[07:39:14] Writing local files
[07:39:14] Completed 960000 out of 1500000 steps (64)
[08:31:43] Writing local files
[08:31:43] Completed 975000 out of 1500000 steps (65)
[09:24:11] Writing local files
[09:24:11] Completed 990000 out of 1500000 steps (66)
[09:45:42] + Attempting to send results
[09:47:42] Couldn't send HTTP request to server (wininet)
[09:47:42] + Could not connect to Work Server (results)
[09:47:42] (171.65.103.162:8080)
[09:47:42] - Error: Could not transmit unit 00 (completed November 14) to work server.
[09:47:42] + Attempting to send results
[09:49:42] Couldn't send HTTP request to server (wininet)
[09:49:42] + Could not connect to Work Server (results)
[09:49:42] (171.65.103.100:8080)
[09:49:42] Could not transmit unit 00 to Collection server; keeping in queue.
[09:49:42] + Attempting to send results
[09:50:42] Couldn't send HTTP request to server (wininet)
[09:50:42] + Could not connect to Work Server (results)
[09:50:42] (171.65.103.162:8080)
[09:50:42] - Error: Could not transmit unit 01 (completed November 20) to work server.
[09:50:42] + Attempting to send results
[09:51:43] Couldn't send HTTP request to server (wininet)
[09:51:43] + Could not connect to Work Server (results)
[09:51:43] (171.65.103.100:8080)
[09:51:43] Could not transmit unit 01 to Collection server; keeping in queue.
[09:51:43] + Attempting to send results
[09:52:43] Couldn't send HTTP request to server (wininet)
[09:52:43] + Could not connect to Work Server (results)
[09:52:43] (171.65.103.162:8080)
[09:52:43] - Error: Could not transmit unit 02 (completed November 17) to work server.
[09:52:43] + Attempting to send results
[09:53:43] Couldn't send HTTP request to server (wininet)
[09:53:43] + Could not connect to Work Server (results)
[09:53:43] (171.65.103.100:8080)
[09:53:43] Could not transmit unit 02 to Collection server; keeping in queue.
[09:53:43] + Attempting to send results
[09:54:43] Couldn't send HTTP request to server (wininet)
[09:54:43] + Could not connect to Work Server (results)
[09:54:43] (171.65.103.162:8080)
[09:54:43] - Error: Could not transmit unit 03 (completed November 23) to work server.
[09:54:43] + Attempting to send results
[09:55:43] Couldn't send HTTP request to server (wininet)
[09:55:43] + Could not connect to Work Server (results)
[09:55:43] (171.65.103.100:8080)
[09:55:43] Could not transmit unit 03 to Collection server; keeping in queue.
[09:55:43] + Attempting to send results
[09:56:43] Couldn't send HTTP request to server (wininet)
[09:56:43] + Could not connect to Work Server (results)
[09:56:43] (130.49.240.81:80)
[09:56:43] - Error: Could not transmit unit 04 (completed November 18) to work server.
[09:56:43] + Attempting to send results
[09:57:43] Couldn't send HTTP request to server (wininet)
[09:57:43] + Could not connect to Work Server (results)
[09:57:43] (130.49.240.77:80)
[09:57:43] Could not transmit unit 04 to Collection server; keeping in queue.
[09:57:43] + Attempting to send results
[09:58:43] Couldn't send HTTP request to server (wininet)
[09:58:43] + Could not connect to Work Server (results)
[09:58:43] (171.65.103.162:8080)
[09:58:43] - Error: Could not transmit unit 05 (completed November 25) to work server.
[09:58:43] + Attempting to send results
[09:59:43] Couldn't send HTTP request to server (wininet)
[09:59:43] + Could not connect to Work Server (results)
[09:59:43] (171.65.103.100:8080)
[09:59:43] Could not transmit unit 05 to Collection server; keeping in queue.
[09:59:43] + Attempting to send results
[10:00:43] Couldn't send HTTP request to server (wininet)
[10:00:43] + Could not connect to Work Server (results)
[10:00:43] (171.65.103.162:8080)
[10:00:43] - Error: Could not transmit unit 06 (completed December 1) to work server.
[10:00:43] + Attempting to send results
[10:01:43] Couldn't send HTTP request to server (wininet)
[10:01:43] + Could not connect to Work Server (results)
[10:01:43] (171.65.103.100:8080)
[10:01:43] Could not transmit unit 06 to Collection server; keeping in queue.
[10:01:43] + Attempting to send results
[10:02:43] Couldn't send HTTP request to server (wininet)
[10:02:43] + Could not connect to Work Server (results)
[10:02:43] (171.64.65.65:8080)
[10:02:43] - Error: Could not transmit unit 07 (completed December 4) to work server.
[10:02:43] + Attempting to send results
[10:03:43] Couldn't send HTTP request to server (wininet)
[10:03:43] + Could not connect to Work Server (results)
[10:03:43] (171.65.103.100:8080)
[10:03:43] Could not transmit unit 07 to Collection server; keeping in queue.
[10:03:43] + Attempting to send results
[10:04:43] Couldn't send HTTP request to server (wininet)
[10:04:43] + Could not connect to Work Server (results)
[10:04:43] (171.64.65.111:8080)
[10:04:43] - Error: Could not transmit unit 08 (completed December 8) to work server.
[10:04:43] + Attempting to send results
[10:05:43] Couldn't send HTTP request to server (wininet)
[10:05:43] + Could not connect to Work Server (results)
[10:05:43] (171.64.122.76:8080)
[10:05:43] Could not transmit unit 08 to Collection server; keeping in queue.
[10:16:40] Writing local files
[10:16:40] Completed 1005000 out of 1500000 steps (67)
[11:09:08] Writing local files
[11:09:08] Completed 1020000 out of 1500000 steps (68)
[12:01:47] Writing local files
[12:01:47] Completed 1035000 out of 1500000 steps (69)
[12:54:14] Writing local files
[12:54:14] Completed 1050000 out of 1500000 steps (70)
[13:46:37] Writing local files
[13:46:37] Completed 1065000 out of 1500000 steps (71)
[14:39:06] Writing local files
[14:39:06] Completed 1080000 out of 1500000 steps (72)
[15:32:09] Writing local files
[15:32:09] Completed 1095000 out of 1500000 steps (73)
[16:05:43] + Attempting to send results
[16:07:43] Couldn't send HTTP request to server (wininet)
[16:07:43] + Could not connect to Work Server (results)
[16:07:43] (171.65.103.162:8080)
[16:07:43] - Error: Could not transmit unit 00 (completed November 14) to work server.
[16:07:43] + Attempting to send results
[16:09:43] Couldn't send HTTP request to server (wininet)
[16:09:43] + Could not connect to Work Server (results)
[16:09:43] (171.65.103.100:8080)
[16:09:43] Could not transmit unit 00 to Collection server; keeping in queue.
[16:09:43] + Attempting to send results
[16:10:43] Couldn't send HTTP request to server (wininet)
[16:10:43] + Could not connect to Work Server (results)
[16:10:43] (171.65.103.162:8080)
[16:10:43] - Error: Could not transmit unit 01 (completed November 20) to work server.
[16:10:43] + Attempting to send results
[16:11:43] Couldn't send HTTP request to server (wininet)
[16:11:43] + Could not connect to Work Server (results)
[16:11:43] (171.65.103.100:8080)
[16:11:43] Could not transmit unit 01 to Collection server; keeping in queue.
[16:11:43] + Attempting to send results
[16:12:43] Couldn't send HTTP request to server (wininet)
[16:12:43] + Could not connect to Work Server (results)
[16:12:43] (171.65.103.162:8080)
[16:12:43] - Error: Could not transmit unit 02 (completed November 17) to work server.
[16:12:43] + Attempting to send results
[16:13:43] Couldn't send HTTP request to server (wininet)
[16:13:43] + Could not connect to Work Server (results)
[16:13:43] (171.65.103.100:8080)
[16:13:43] Could not transmit unit 02 to Collection server; keeping in queue.
[16:13:43] + Attempting to send results
[16:14:43] Couldn't send HTTP request to server (wininet)
[16:14:43] + Could not connect to Work Server (results)
[16:14:43] (171.65.103.162:8080)
[16:14:43] - Error: Could not transmit unit 03 (completed November 23) to work server.
[16:14:43] + Attempting to send results
[16:15:43] Couldn't send HTTP request to server (wininet)
[16:15:43] + Could not connect to Work Server (results)
[16:15:43] (171.65.103.100:8080)
[16:15:43] Could not transmit unit 03 to Collection server; keeping in queue.
[16:15:43] + Attempting to send results
[16:16:43] Couldn't send HTTP request to server (wininet)
[16:16:43] + Could not connect to Work Server (results)
[16:16:43] (130.49.240.81:80)
[16:16:43] - Error: Could not transmit unit 04 (completed November 18) to work server.
[16:16:43] + Attempting to send results
[16:17:43] Couldn't send HTTP request to server (wininet)
[16:17:43] + Could not connect to Work Server (results)
[16:17:43] (130.49.240.77:80)
[16:17:43] Could not transmit unit 04 to Collection server; keeping in queue.
[16:17:43] + Attempting to send results
[16:18:43] Couldn't send HTTP request to server (wininet)
[16:18:43] + Could not connect to Work Server (results)
[16:18:43] (171.65.103.162:8080)
[16:18:43] - Error: Could not transmit unit 05 (completed November 25) to work server.
[16:18:43] + Attempting to send results
[16:19:43] Couldn't send HTTP request to server (wininet)
[16:19:43] + Could not connect to Work Server (results)
[16:19:43] (171.65.103.100:8080)
[16:19:43] Could not transmit unit 05 to Collection server; keeping in queue.
[16:19:43] + Attempting to send results
[16:20:43] Couldn't send HTTP request to server (wininet)
[16:20:43] + Could not connect to Work Server (results)
[16:20:43] (171.65.103.162:8080)
[16:20:43] - Error: Could not transmit unit 06 (completed December 1) to work server.
[16:20:43] + Attempting to send results
[16:21:43] Couldn't send HTTP request to server (wininet)
[16:21:43] + Could not connect to Work Server (results)
[16:21:43] (171.65.103.100:8080)
[16:21:43] Could not transmit unit 06 to Collection server; keeping in queue.
[16:21:43] + Attempting to send results
[16:22:43] Couldn't send HTTP request to server (wininet)
[16:22:43] + Could not connect to Work Server (results)
[16:22:43] (171.64.65.65:8080)
[16:22:43] - Error: Could not transmit unit 07 (completed December 4) to work server.
[16:22:43] + Attempting to send results
[16:23:43] Couldn't send HTTP request to server (wininet)
[16:23:43] + Could not connect to Work Server (results)
[16:23:43] (171.65.103.100:8080)
[16:23:43] Could not transmit unit 07 to Collection server; keeping in queue.
[16:23:43] + Attempting to send results
[16:24:43] Couldn't send HTTP request to server (wininet)
[16:24:43] + Could not connect to Work Server (results)
[16:24:43] (171.64.65.111:8080)
[16:24:43] - Error: Could not transmit unit 08 (completed December 8) to work server.
[16:24:43] + Attempting to send results
[16:24:57] Writing local files
[16:24:57] Completed 1110000 out of 1500000 steps (74)
[16:25:43] Couldn't send HTTP request to server (wininet)
[16:25:43] + Could not connect to Work Server (results)
[16:25:43] (171.64.122.76:8080)
[16:25:43] Could not transmit unit 08 to Collection server; keeping in queue.
[17:17:33] Writing local files
[17:17:33] Completed 1125000 out of 1500000 steps (75)
[18:10:16] Writing local files
[18:10:16] Completed 1140000 out of 1500000 steps (76)
[19:02:51] Writing local files
[19:02:51] Completed 1155000 out of 1500000 steps (77)
[19:55:07] Writing local files
[19:55:07] Completed 1170000 out of 1500000 steps (78)
[20:47:17] Writing local files
[20:47:17] Completed 1185000 out of 1500000 steps (79)
[21:39:28] Writing local files
[21:39:28] Completed 1200000 out of 1500000 steps (80)
[22:25:43] + Attempting to send results
[22:26:43] Couldn't send HTTP request to server (wininet)
[22:26:43] + Could not connect to Work Server (results)
[22:26:43] (171.65.103.162:8080)
[22:26:43] - Error: Could not transmit unit 00 (completed November 14) to work server.
[22:26:43] + Attempting to send results
[22:27:43] Couldn't send HTTP request to server (wininet)
[22:27:43] + Could not connect to Work Server (results)
[22:27:43] (171.65.103.100:8080)
[22:27:43] Could not transmit unit 00 to Collection server; keeping in queue.
[22:27:43] + Attempting to send results
[22:28:43] Couldn't send HTTP request to server (wininet)
[22:28:43] + Could not connect to Work Server (results)
[22:28:43] (171.65.103.162:8080)
[22:28:43] - Error: Could not transmit unit 01 (completed November 20) to work server.
[22:28:43] + Attempting to send results
[22:29:43] Couldn't send HTTP request to server (wininet)
[22:29:43] + Could not connect to Work Server (results)
[22:29:43] (171.65.103.100:8080)
[22:29:43] Could not transmit unit 01 to Collection server; keeping in queue.
[22:29:43] + Attempting to send results
[22:30:43] Couldn't send HTTP request to server (wininet)
[22:30:43] + Could not connect to Work Server (results)
[22:30:43] (171.65.103.162:8080)
[22:30:43] - Error: Could not transmit unit 02 (completed November 17) to work server.
[22:30:43] + Attempting to send results
[22:31:43] Couldn't send HTTP request to server (wininet)
[22:31:43] + Could not connect to Work Server (results)
[22:31:43] (171.65.103.100:8080)
[22:31:43] Could not transmit unit 02 to Collection server; keeping in queue.
[22:31:43] + Attempting to send results
[22:32:10] Writing local files
[22:32:10] Completed 1215000 out of 1500000 steps (81)
[22:32:43] Couldn't send HTTP request to server (wininet)
[22:32:43] + Could not connect to Work Server (results)
[22:32:43] (171.65.103.162:8080)
[22:32:43] - Error: Could not transmit unit 03 (completed November 23) to work server.
[22:32:43] + Attempting to send results
[22:33:43] Couldn't send HTTP request to server (wininet)
[22:33:43] + Could not connect to Work Server (results)
[22:33:43] (171.65.103.100:8080)
[22:33:43] Could not transmit unit 03 to Collection server; keeping in queue.
[22:33:43] + Attempting to send results
[22:34:44] Couldn't send HTTP request to server (wininet)
[22:34:44] + Could not connect to Work Server (results)
[22:34:44] (130.49.240.81:80)
[22:34:44] - Error: Could not transmit unit 04 (completed November 18) to work server.
[22:34:44] + Attempting to send results
[22:35:44] Couldn't send HTTP request to server (wininet)
[22:35:44] + Could not connect to Work Server (results)
[22:35:44] (130.49.240.77:80)
[22:35:44] Could not transmit unit 04 to Collection server; keeping in queue.
[22:35:44] + Attempting to send results
[22:36:44] Couldn't send HTTP request to server (wininet)
[22:36:44] + Could not connect to Work Server (results)
[22:36:44] (171.65.103.162:8080)
[22:36:44] - Error: Could not transmit unit 05 (completed November 25) to work server.
[22:36:44] + Attempting to send results
[22:37:44] Couldn't send HTTP request to server (wininet)
[22:37:44] + Could not connect to Work Server (results)
[22:37:44] (171.65.103.100:8080)
[22:37:44] Could not transmit unit 05 to Collection server; keeping in queue.
[22:37:44] + Attempting to send results
[22:38:44] Couldn't send HTTP request to server (wininet)
[22:38:44] + Could not connect to Work Server (results)
[22:38:44] (171.65.103.162:8080)
[22:38:44] - Error: Could not transmit unit 06 (completed December 1) to work server.
[22:38:44] + Attempting to send results
[22:39:44] Couldn't send HTTP request to server (wininet)
[22:39:44] + Could not connect to Work Server (results)
[22:39:44] (171.65.103.100:8080)
[22:39:44] Could not transmit unit 06 to Collection server; keeping in queue.
[22:39:44] + Attempting to send results
[22:40:44] Couldn't send HTTP request to server (wininet)
[22:40:44] + Could not connect to Work Server (results)
[22:40:44] (171.64.65.65:8080)
[22:40:44] - Error: Could not transmit unit 07 (completed December 4) to work server.
[22:40:44] + Attempting to send results
[22:41:44] Couldn't send HTTP request to server (wininet)
[22:41:44] + Could not connect to Work Server (results)
[22:41:44] (171.65.103.100:8080)
[22:41:44] Could not transmit unit 07 to Collection server; keeping in queue.
[22:41:44] + Attempting to send results
[22:42:44] Couldn't send HTTP request to server (wininet)
[22:42:44] + Could not connect to Work Server (results)
[22:42:44] (171.64.65.111:8080)
[22:42:44] - Error: Could not transmit unit 08 (completed December 8) to work server.
[22:42:44] + Attempting to send results
[22:43:44] Couldn't send HTTP request to server (wininet)
[22:43:44] + Could not connect to Work Server (results)
[22:43:44] (171.64.122.76:8080)
[22:43:44] Could not transmit unit 08 to Collection server; keeping in queue.
[23:25:13] Writing local files
[23:25:13] Completed 1230000 out of 1500000 steps (82)
[00:18:44] Writing local files
[00:18:44] Completed 1245000 out of 1500000 steps (83)
[00:41:41] Quit 101 - Fatal error:
[00:41:41] Step 1251376, time 2502.75 (ps) LINCS WARNING
[00:41:41] relative constraint deviation after LINCS:
[00:41:41] max 0.002010 (between atoms 112 and 113) rms 0.000144
[00:41:41]
[00:41:41] Simulation instability has been encountered. The run has entered a
[00:41:41] state from which no further progress can be made.
[00:41:41] This may be the correct result of the simulation, however if you
[00:41:41] often see other project units terminating early like this
[00:41:41] too, you may wish to check the stability of your computer (issues
[00:41:41] such as high temperature, overclocking, etc.).
[00:41:41] Going to send back what have done.
[00:41:41] logfile size: 63636
[00:41:42] - Writing 64319 bytes of core data to disk...
[00:41:42] Done: 63807 -> 5472 (compressed to 8.5 percent)
[00:41:42] ... Done.
[00:41:42]
[00:41:42] Folding@home Core Shutdown: EARLY_UNIT_END
[00:41:46] CoreStatus = 72 (114)
[00:41:46] Sending work to server
[00:41:46] + Attempting to send results
[00:42:46] Couldn't send HTTP request to server (wininet)
[00:42:46] + Could not connect to Work Server (results)
[00:42:46] (171.64.65.111:8080)
[00:42:46] - Error: Could not transmit unit 09 (completed December 13) to work server.
[00:42:46] Keeping unit 09 in queue.
[00:42:46] + Attempting to send results
[00:43:46] Couldn't send HTTP request to server (wininet)
[00:43:46] + Could not connect to Work Server (results)
[00:43:46] (171.65.103.162:8080)
[00:43:46] - Error: Could not transmit unit 00 (completed November 14) to work server.
[00:43:46] + Attempting to send results
[00:44:46] Couldn't send HTTP request to server (wininet)
[00:44:46] + Could not connect to Work Server (results)
[00:44:46] (171.65.103.100:8080)
[00:44:46] Could not transmit unit 00 to Collection server; keeping in queue.
[00:44:46] + Attempting to send results
[00:45:46] Couldn't send HTTP request to server (wininet)
[00:45:46] + Could not connect to Work Server (results)
[00:45:46] (171.65.103.162:8080)
[00:45:46] - Error: Could not transmit unit 01 (completed November 20) to work server.
[00:45:46] + Attempting to send results
[00:46:46] Couldn't send HTTP request to server (wininet)
[00:46:46] + Could not connect to Work Server (results)
[00:46:46] (171.65.103.100:8080)
[00:46:46] Could not transmit unit 01 to Collection server; keeping in queue.
[00:46:46] + Attempting to send results
[00:47:46] Couldn't send HTTP request to server (wininet)
[00:47:46] + Could not connect to Work Server (results)
[00:47:46] (171.65.103.162:8080)
[00:47:46] - Error: Could not transmit unit 02 (completed November 17) to work server.
[00:47:46] + Attempting to send results
[00:48:46] Couldn't send HTTP request to server (wininet)
[00:48:46] + Could not connect to Work Server (results)
[00:48:46] (171.65.103.100:8080)
[00:48:46] Could not transmit unit 02 to Collection server; keeping in queue.
[00:48:46] + Attempting to send results
[20:19:11] - Use IE connection settings: Yes
Set this to NO ! (by unchecking the box in you settings)
Bigfan3
Post by Bigfan3 »
I did .. Thanks.
Also UN-Checked : Disable Highly optimized assembly code
Good plan.
Please note, the fah client was designed to run without needing to make a lot of modifications. Execept for User Name, and Team #, the default answers are the best answers in most cases.
Bigfan3
Post by Bigfan3 »
7im, toTOW, gwildperson, ChelseaOilman, bruce..
Thanks for the help. :D
Looks like you guys have it working much better :)
My Mother has a few of the illness's that are mentioned in the info on your site. I figure this couldn't hurt to maybe help find some answers to these ailments.
