No single core CPU units?
ChrisSpeaker
Post by ChrisSpeaker »
Hello everyone. I seem to be having no luck receiving work for the CPU slot. My GPU is crunching away happily though so I know it is not a communication error per say on my end. My CPU is a core2duo under Arch Linux.
20:08:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
20:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
20:08:11:ERROR:WU02:FS00:Exception: Could not get an assignment
******************************* Date: 2016-01-13 *******************************
02:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
02:08:11:ERROR:WU02:FS00:Exception: Could not get an assignment
08:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
08:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:08:11:ERROR:WU02:FS00:Exception: Could not get an assignment
14:08:10:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
14:08:11:ERROR:WU02:FS00:Exception: Could not get an assignment
20:08:11:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
******************************* Date: 2016-01-14 *******************************
08:08:12:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
08:08:12:ERROR:WU02:FS00:Exception: Could not get an assignment
12:25:30:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:25:31:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:25:31:ERROR:WU02:FS00:Exception: Could not get an assignment
12:27:07:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:27:08:WARNING:WU02:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:27:08:ERROR:WU02:FS00:Exception: Could not get an assignment
Any help would be appreciated. Thanks in advance.
ChrisSpeaker
Re: No single core CPU units?
I forgot to mention that it's now 36 retries since a successful check for work
ChristianVirtual
Post by ChristianVirtual »
Can be, short supply ... Maybe you can try the NaCL (Chrome browser); that should keep your core busy. But watch that the performance of the GPU not get impacted too much.
Ricky
Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system.
Post by Ricky »
How many cores are you set to with your CPU slot? CPU:12 or less works OK, but there seems to be an upper limit right now.
Yes, there is a short supply of WU's for single core configurations. Since you also have a GPU slot, your best chance at keeping the one core doing CPU crunching is the NaCl Chrome client. Setting it to use 50% should not overcommit the CPU.
The WS that had assignable WU's for single core setups was taken down due to problems last week. The projects are in the process of being transferred to a new WS, but not sure how long that will take before these projects are available for general assignment to the V7 client.
