"Empty work server assignment."
rickoic
Hardware configuration: eVga x299 DARK 2070 Super, eVGA 2080, eVga 1070, eVga 2080 Super
MSI x399 eVga 2080, eVga 1070, eVga 1070, GT970
Re: "Empty work server assignment."
Post by rickoic »
Was having same problem on 2 pc's. Both with duel 12 core AMD cpu's. Was able to begin getting wu's again when I reduced the number of cores being used by cpu to 12. Then added another cpu and because I'm also running gpu's on each I put the number of cores folding on it to 8. And now I'm getting wu's on both cpu's that are folding.
I'm folding because Dec 2005 I had radical prostate surgery.
Lost brother to spinal cancer, brother-in-law to prostate cancer.
Several 1st cousins lost and a few who have survived.
bollix47
Post by bollix47 »
If you're seeing cpu:7 in your log try editing your configuration for the cpu slot by changing the number of CPUs from -1 to 6. Others have also reported having a problem when attempting to get work for cpu:7 but have had some success by changing it to cpu:6 - viewtopic.php?p=282559#p282559
ericitaquera
Post by ericitaquera »
Mod edit: merged with existing topic
Hello.
Please could someone point me what is the problem here? I can´t fold anymore since I´m getting the "Empty work server assignment" error.
Thanks in advance
*********************** Log Started 2016-01-14T11:13:39Z ***********************
11:13:39:************************* Folding@home Client *************************
11:13:39:      Website: http://folding.stanford.edu/
11:13:39:    Copyright: (c) 2009-2014 Stanford University
11:13:39:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:13:39:         Args: --open-web-control
11:13:39:       Config: <none>
11:13:39:******************************** Build ********************************
11:13:39:      Version: 7.4.4
11:13:39:         Date: Mar 4 2014
11:13:39:         Time: 20:26:54
11:13:39:      SVN Rev: 4130
11:13:39:       Branch: fah/trunk/client
11:13:39:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:13:39:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:13:39:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:13:39:     Platform: win32 XP
11:13:39:         Bits: 32
11:13:39:         Mode: Release
11:13:39:******************************* System ********************************
11:13:39:          CPU: Intel(R) Xeon(R) CPU E5-2697 v2 @ 2.70GHz
11:13:39:       CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
11:13:39:         CPUs: 32
11:13:39:       Memory: 15.85GiB
11:13:39:  Free Memory: 11.85GiB
11:13:39:      Threads: WINDOWS_THREADS
11:13:39:   OS Version: 6.2
11:13:39:  Has Battery: false
11:13:39:   On Battery: false
11:13:39:   UTC Offset: -2
11:13:39:          PID: 7872
11:13:39:          CWD: C:/Users/Administrator/AppData/Roaming/FAHClient
11:13:39:           OS: Windows Server 2012 R2 Standard
11:13:39:      OS Arch: AMD64
11:13:39:         GPUs: 0
11:13:39:         CUDA: Not detected
11:13:39:Win32 Service: false
11:13:39:***********************************************************************
11:13:39:<config>
11:13:39:  <!-- Folding Slots -->
11:13:39:</config>
11:13:39:Connecting to assign-GPU.stanford.edu:80
11:13:40:Updated GPUs.txt
11:13:40:Read GPUs.txt
11:13:40:Trying to access database...
11:13:40:Successfully acquired database lock
11:13:40:Enabled folding slot 00: PAUSED cpu:31 (not configured)
11:13:43:16:127.0.0.1:New Web connection
11:14:05:Set client configured
11:14:06:WU00:FS00:Connecting to 171.67.108.45:8080
11:14:07:WU00:FS00:Connecting to 171.67.108.45:8080
11:14:07:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:14:07:WU00:FS00:Connecting to 171.67.108.204:80
11:14:08:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:14:08:ERROR:WU00:FS00:Exception: Could not get an assignment
11:14:09:WU00:FS00:Connecting to 171.67.108.45:8080
11:14:09:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:14:09:WU00:FS00:Connecting to 171.67.108.204:80
11:14:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:14:10:ERROR:WU00:FS00:Exception: Could not get an assignment
11:14:41:Saving configuration to config.xml
11:14:41:<config>
11:14:41:  <!-- Slot Control -->
11:14:41:  <power v='full'/>
11:14:41:
11:14:41:  <!-- User Information -->
11:14:41:  <passkey v='********************************'/>
11:14:41:  <team v='86565'/>
11:14:41:  <user v='ericitaquera'/>
11:14:41:
11:14:41:  <!-- Folding Slots -->
11:14:41:  <slot id='0' type='CPU'/>
11:14:41:</config>
11:15:09:WU00:FS00:Connecting to 171.67.108.45:8080
11:15:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:15:10:WU00:FS00:Connecting to 171.67.108.204:80
11:15:11:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:15:11:ERROR:WU00:FS00:Exception: Could not get an assignment
11:16:46:WU00:FS00:Connecting to 171.67.108.45:8080
11:16:47:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:16:47:WU00:FS00:Connecting to 171.67.108.204:80
11:16:48:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:16:48:ERROR:WU00:FS00:Exception: Could not get an assignment
11:19:23:WU00:FS00:Connecting to 171.67.108.45:8080
11:19:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:19:24:WU00:FS00:Connecting to 171.67.108.204:80
11:19:25:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:19:25:ERROR:WU00:FS00:Exception: Could not get an assignment
davidcoton
Post by davidcoton »
31 is prime, you will not get assignments for 31 cpus. Big numbers of CPUs are possibly a problem because of one server being rebuilt. You may need to set CPU:30 (or CPU:32 if you don't need a permanently free CPU) and client-type=bigadv (not sure if that is still required). Or try setting three slots for fewer cores each (eg 12:12:8, or 12:12:6 to leave two free cpus) while projects for more cpus are in short supply.
davidcoton wrote:31 is prime, you will not get assignments for 31 cpus. Big numbers of CPUs are possibly a problem because of one server being rebuilt. You may need to set CPU:30 (or CPU:32 if you don't need a permanently free CPU) and client-type=bigadv (not sure if that is still required). Or try setting three slots for fewer cores each (eg 12:12:8, or 12:12:6 to leave two free cpus) while projects for more cpus are in short supply.
As this system is running Windows, client-type=bigadv will not help. Those projects are Linux only and 24+ cores.
Currently projects for up to 12 cores are widely available, some projects will assign to higher core counts. Those are in very short supply though compared to the demand.
ericitaquera
Thank you for the clarification.
Now I understood.
I created 2 12 cpus and one 8 cpus slots and now I´m back to folding business.
Regards
