CPU 1 Projects
silverpulser
CPU 1 Projects
Are CPU-1 projects not available at the moment, only my CPU slot is showing as "Ready" but no WU is installed. The Advanced Control shows the attempt (assignment?) as 19?
Ricky
- Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system. - Location: New Mexico
Re: CPU 1 Projects
silverpulser.
How many logical cores do you have? Running CPU:8 slots works, but there seems to be a problem with CPU:24 or higher. I broke my CPU:24 into three by adding folding slots. Now I am back to geting work units.
Nathan_P
Not currently folding
Re: CPU 1 Projects
AFAIK all single core projects have finished.
@Ricky CPU:24 does work - you just normally get the very crappy 7526/7527 projects which can run really slow and knock 20k PPD off what your machine is capable of. I did post a thread about it a while ago but as usual no one was listening. I don't think that cpu:24 is enough for the current "bigadv" projects 8106-8108.
Re: CPU 1 Projects
Single core WU's still are being assigned, but have been and continue to be in short supply. The main source for those WU's is currently off from assigning WU's due to problems with the WS reported elsewhere.
24 cores is the minimum set for the WS for projects 8106-8108, Linux only.
silverpulser
Re: CPU 1 Projects
Thanks for the info. I still have the GPU running ok but perhaps you can advise me, is it normal for both my processors to be running at about 50% when only one is used in conjunction with the GPU? I have no other programs running and this usage of both processors is constant.
davidcoton
Re: CPU 1 Projects
Yes, the scheduler in the OS will normally share the load between the available cores. If you get Core15 WUs on the GPU, then you could assign both cores to CPU folding (Configure| Slots|cpu|edit|CPUs:2) because Core15 has very low CPU demands.
silverpulser
Re: CPU 1 Projects
Thanks for that.Will do as suggested for future Core15 WU's/
Re: CPU 1 Projects
According to this post, 1 core folding is available again. viewtopic.php?f=66&t=28483
silverpulser
Re: CPU 1 Projects
Oh, so why am I not getting any?
Here is my log:
Mod edit: Added Code tags to log file
Here is my log:
*********************** Log Started 2016-01-12T11:39:52Z ***********************
11:39:52:************************* Folding@home Client *************************
11:39:52: Website: http://folding.stanford.edu/
11:39:52: Copyright: (c) 2009-2014 Stanford University
11:39:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:39:52: Args:
11:39:52: Config: C:/Users/User/AppData/Roaming/FAHClient/config.xml
11:39:52:******************************** Build ********************************
11:39:52: Version: 7.4.4
11:39:52: Date: Mar 4 2014
11:39:52: Time: 20:26:54
11:39:52: SVN Rev: 4130
11:39:52: Branch: fah/trunk/client
11:39:52: Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:39:52: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:39:52: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:39:52: Platform: win32 XP
11:39:52: Bits: 32
11:39:52: Mode: Release
11:39:52:******************************* System ********************************
11:39:52: CPU: Intel(R) Pentium(R) CPU G620 @ 2.60GHz
11:39:52: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
11:39:52: CPUs: 2
11:39:52: Memory: 3.98GiB
11:39:52: Free Memory: 2.60GiB
11:39:52: Threads: WINDOWS_THREADS
11:39:52: OS Version: 6.2
11:39:52: Has Battery: false
11:39:52: On Battery: false
11:39:52: UTC Offset: 0
11:39:52: PID: 660
11:39:52: CWD: C:/Users/User/AppData/Roaming/FAHClient
11:39:52: OS: Windows 10 Pro
11:39:52: OS Arch: AMD64
11:39:52: GPUs: 1
11:39:52: GPU 0: NVIDIA:2 GF119 [GeForce GT 520]
11:39:52: CUDA: 2.1
11:39:52: CUDA Driver: 8000
11:39:52:Win32 Service: false
11:39:52:***********************************************************************
11:39:53:<config>
11:39:53: <!-- Network -->
11:39:53: <proxy v=':8080'/>
11:39:53:
11:39:53: <!-- Slot Control -->
11:39:53: <power v='FULL'/>
11:39:53:
11:39:53: <!-- User Information -->
11:39:53: <passkey v='********************************'/>
11:39:53: <user v='Silverpulser'/>
11:39:53:
11:39:53: <!-- Folding Slots -->
11:39:53: <slot id='0' type='CPU'/>
11:39:53: <slot id='1' type='GPU'>
11:39:53: <client-type v='beta'/>
11:39:53: <max-packet-size v='small'/>
11:39:53: </slot>
11:39:53:</config>
11:39:53:Trying to access database...
11:39:55:Successfully acquired database lock
11:39:55:Enabled folding slot 00: READY cpu:1
11:39:55:Enabled folding slot 01: READY gpu:0:GF119 [GeForce GT 520]
11:39:55:WU00:FS01:Starting
11:39:55:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 00 -suffix 01 -version 704 -lifeline 660 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:39:55:WU00:FS01:Started FahCore on PID 1272
11:39:55:WU00:FS01:Core PID:1536
11:39:55:WU00:FS01:FahCore 0x18 started
11:39:57:WU01:FS00:Connecting to 171.67.108.45:8080
11:39:58:WU00:FS01:0x18:*********************** Log Started 2016-01-12T11:39:57Z ***********************
11:39:58:WU00:FS01:0x18:Project: 9156 (Run 144, Clone 0, Gen 12)
11:39:58:WU00:FS01:0x18:Unit: 0x0000000dab40415456737df23b2d526b
11:39:58:WU00:FS01:0x18:CPU: 0x00000000000000000000000000000000
11:39:58:WU00:FS01:0x18:Machine: 1
11:39:58:WU00:FS01:0x18:Digital signatures verified
11:39:58:WU00:FS01:0x18:Folding@home GPU core18
11:39:58:WU00:FS01:0x18:Version 0.0.4
11:39:58:WU00:FS01:0x18: Found a checkpoint file
11:39:58:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:39:58:WU01:FS00:Connecting to 171.67.108.204:80
11:40:00:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:40:00:ERROR:WU01:FS00:Exception: Could not get an assignment
11:40:00:WU01:FS00:Connecting to 171.67.108.45:8080
11:40:01:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:40:01:WU01:FS00:Connecting to 171.67.108.204:80
11:40:02:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:40:02:ERROR:WU01:FS00:Exception: Could not get an assignment
11:40:42:WU00:FS01:0x18:Completed 1700000 out of 2500000 steps (68%)
11:40:42:WU00:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:41:00:WU01:FS00:Connecting to 171.67.108.45:8080
11:41:01:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:41:01:WU01:FS00:Connecting to 171.67.108.204:80
11:41:02:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:41:02:ERROR:WU01:FS00:Exception: Could not get an assignment
11:41:38:21:127.0.0.1:New Web connection
11:42:37:WU01:FS00:Connecting to 171.67.108.45:8080
11:42:38:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:42:38:WU01:FS00:Connecting to 171.67.108.204:80
11:42:39:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:42:39:ERROR:WU01:FS00:Exception: Could not get an assignment
11:45:14:WU01:FS00:Connecting to 171.67.108.45:8080
11:45:15:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:45:15:WU01:FS00:Connecting to 171.67.108.204:80
11:45:16:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:45:16:ERROR:WU01:FS00:Exception: Could not get an assignment
11:49:29:WU01:FS00:Connecting to 171.67.108.45:8080
11:49:30:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:49:30:WU01:FS00:Connecting to 171.67.108.204:80
11:49:30:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:49:30:ERROR:WU01:FS00:Exception: Could not get an assignment
11:56:20:WU01:FS00:Connecting to 171.67.108.45:8080
11:56:21:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
11:56:21:WU01:FS00:Connecting to 171.67.108.204:80
11:56:22:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
11:56:22:ERROR:WU01:FS00:Exception: Could not get an assignment
12:07:26:WU01:FS00:Connecting to 171.67.108.45:8080
12:07:27:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:07:27:WU01:FS00:Connecting to 171.67.108.204:80
12:07:27:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:07:27:ERROR:WU01:FS00:Exception: Could not get an assignment
12:25:23:WU01:FS00:Connecting to 171.67.108.45:8080
12:25:24:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:25:24:WU01:FS00:Connecting to 171.67.108.204:80
12:25:24:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:25:24:ERROR:WU01:FS00:Exception: Could not get an assignment
12:41:57:WU00:FS01:0x18:Completed 1725000 out of 2500000 steps (69%)
12:54:25:WU01:FS00:Connecting to 171.67.108.45:8080
12:54:25:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:54:25:WU01:FS00:Connecting to 171.67.108.204:80
12:54:26:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
12:54:26:ERROR:WU01:FS00:Exception: Could not get an assignment
13:26:52:46:127.0.0.1:New Web connection-
Re: CPU 1 Projects
7im's wording is a bit premature. That announcement is that these projects and their WU's are being released to Beta testing. Since they are continuations of existing projects the Beta test period should be relatively short. Usually a test period like this is done to make certain a new WS is properly set up and that the projects transferred with the correct information. So these should be available in the near future to non-Beta testers.
