debs3759
Posts: 134 Joined: Fri Oct 07, 2011 3:29 am
Post
by debs3759 » Sat Dec 19, 2015 9:31 pm
I'm unable to run Core21 work units. My system i:
AMD A8-3870K
8 GB RAM
2 x GTX 580
The log file shows:
21:20:04:WU01:FS00:Connecting to 171.67.108.45:80
21:20:05:WU01:FS00:Assigned to work server 140.163.4.241
21:20:05:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:1:GF110 [GeForce GTX 580] from 140.163.4.241
21:20:05:WU01:FS00:Connecting to 140.163.4.241:8080
21:20:05:WU01:FS00:Downloading 3.77MiB
21:20:08:WU01:FS00:Download complete
21:20:08:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11411 run:2 clone:0 gen:28 core:0x21 unit:0x000000208ca304f1565a241b4a83a8b7
21:20:30:WU01:FS00:Starting
21:20:30:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Debs/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:20:30:WU01:FS00:Started FahCore on PID 9336
21:20:31:WU01:FS00:Core PID:9360
21:20:31:WU01:FS00:FahCore 0x21 started
21:20:37:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:20:37:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741701 = 0xc000007b)
21:20:38:WU01:FS00:Starting
21:20:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Debs/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:20:38:WU01:FS00:Started FahCore on PID 6604
21:20:38:WU01:FS00:Core PID:8280
21:20:38:WU01:FS00:FahCore 0x21 started
21:20:40:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:20:40:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741701 = 0xc000007b)
21:21:38:WU01:FS00:Starting
21:21:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Debs/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:21:38:WU01:FS00:Started FahCore on PID 9124
21:21:38:WU01:FS00:Core PID:11056
21:21:38:WU01:FS00:FahCore 0x21 started
21:21:41:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:21:41:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741701 = 0xc000007b)
21:22:38:WU01:FS00:Starting
21:22:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Debs/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:22:38:WU01:FS00:Started FahCore on PID 10380
21:22:38:WU01:FS00:Core PID:7880
21:22:38:WU01:FS00:FahCore 0x21 started
21:22:41:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:22:41:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741701 = 0xc000007b)
21:23:38:WU01:FS00:Starting
21:23:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Debs/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 7236 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
21:23:38:WU01:FS00:Started FahCore on PID 10784
21:23:38:WU01:FS00:Core PID:10372
21:23:38:WU01:FS00:FahCore 0x21 started
21:23:41:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
21:23:41:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741701 = 0xc000007b)
21:23:41:WARNING:WU01:FS00:Too many errors, failing
21:23:41:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:11411 run:2 clone:0 gen:28 core:0x21 unit:0x000000208ca304f1565a241b4a83a8b7
21:23:41:WU01:FS00:Connecting to 140.163.4.241:8080
21:23:42:WU01:FS00:Server responded WORK_ACK (400)
21:23:42:WU01:FS00:Cleaning up
The same happens every time FahCore 0x21 is started. it's fine once the wu is rejected and a core 0x18 project downloads.
debs3759
Post
by debs3759 » Sat Dec 19, 2015 9:34 pm
The top of the logfile, with configuration info, is:
*********************** Log Started 2015-12-18T16:17:59Z ***********************
16:17:59:************************* Folding@home Client *************************
16:17:59: Website: http://folding.stanford.edu/
16:17:59: Copyright: (c) 2009-2014 Stanford University
16:17:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:17:59: Args:
16:17:59: Config: C:/Users/Debs/AppData/Roaming/FAHClient/config.xml
16:17:59:******************************** Build ********************************
16:17:59: Version: 7.4.4
16:17:59: Date: Mar 4 2014
16:17:59: Time: 20:26:54
16:17:59: SVN Rev: 4130
16:17:59: Branch: fah/trunk/client
16:17:59: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:17:59: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:17:59: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:17:59: Platform: win32 XP
16:17:59: Bits: 32
16:17:59: Mode: Release
16:17:59:******************************* System ********************************
16:17:59: CPU: AMD A8-3870 APU with Radeon(tm) HD Graphics
16:17:59: CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
16:17:59: CPUs: 4
16:17:59: Memory: 7.99GiB
16:17:59: Free Memory: 5.40GiB
16:17:59: Threads: WINDOWS_THREADS
16:17:59: OS Version: 6.2
16:17:59: Has Battery: false
16:17:59: On Battery: false
16:17:59: UTC Offset: 0
16:17:59: PID: 7236
16:17:59: CWD: C:/Users/Debs/AppData/Roaming/FAHClient
16:17:59: OS: Windows 10 Pro
16:17:59: OS Arch: AMD64
16:17:59: GPUs: 2
16:17:59: GPU 0: NVIDIA:2 GF110 [GeForce GTX 580]
16:17:59: GPU 1: NVIDIA:2 GF110 [GeForce GTX 580]
16:17:59: CUDA: 2.0
16:17:59: CUDA Driver: 7050
16:17:59:Win32 Service: false
16:17:59:***********************************************************************
16:18:00:<config>
16:18:00: <!-- Network -->
16:18:00: <proxy v=':8080'/>
16:18:00:
16:18:00: <!-- Slot Control -->
16:18:00: <power v='full'/>
16:18:00:
16:18:00: <!-- User Information -->
16:18:00: <passkey v='********************************'/>
16:18:00: <team v='35947'/>
16:18:00: <user v='debs3759'/>
16:18:00:
16:18:00: <!-- Folding Slots -->
16:18:00: <slot id='1' type='GPU'/>
16:18:00: <slot id='0' type='GPU'/>
16:18:00:</config>
Posts: 8280 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Sat Dec 19, 2015 10:02 pm
Which version of the nVidia drivers are you using on your PC? That can make a difference, Core_21 requires fairly recent drivers.
debs3759
Post
by debs3759 » Sat Dec 19, 2015 10:13 pm
I'm downloading the latest drivers, will see if that fixes it.
Posts: 6516 Joined: Sun Dec 02, 2007 10:38 am
Post
by toTOW » Sat Dec 19, 2015 10:31 pm
debs3759 wrote: 353.82
Did you use the drivers installed automatically by Windows Update, or did you get them from NV ?
debs3759
Post
by debs3759 » Sat Dec 19, 2015 10:59 pm
I always use drivers from NVidia. Have now installed the latest. I'll know when my current jobs finish whether that has fixed it.
debs3759
Post
by debs3759 » Mon Dec 21, 2015 11:28 am
The new drivers fixed the problem, I am now folding two wu for core 0x21. Thanks for the suggestion.
Eurasia_Enne_Zahard
Posts: 3 Joined: Mon Dec 21, 2015 2:49 pm
Post
by Eurasia_Enne_Zahard » Mon Dec 21, 2015 2:56 pm
I had this problem, got new Nvidia drivers for GTX 980 on Nvidia site, things looked like they were working but I do not get the estimated bonus calculated into the WU for the GPU anymore. Before grabbing drivers from Nvidia, I did uninstall F@H including removing data folder. Reinstalled, and entered username/passkey. Does this lack of bonus points have anything to do with the uninstall and removal of data folder? Do I have to do another 10 WU on that PC before bonus is applied? Maybe it will apply a bonus after that WU on FahCore 21 completes, but doesn't show the bonus on the Advance client?
Posts: 10179 Joined: Thu Nov 29, 2007 4:30 pm
Post
by 7im » Mon Dec 21, 2015 4:31 pm
You probably missed type the Passkey or username, as those two are tied together to get the bonus. Please double check those, as they would've been removed with the uninstall.
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Mon Dec 21, 2015 7:02 pm
If that' doesn't happen to be it, look through your recent history and see if perhaps you've run into this problem:
P9201 no bonus points received
