FahCore returned: CORE_OUTDATED (110 = 0x6e)[/code]
Dr.G
Post by Dr.G »
Hello,
Just today I received the following error message:
on project:10494 run:3 clone:30 gen:0 core:0x21 unit:0x000000048ca304f555de931550fded22
Now stuck- no further downloads / progress.
Error seems similar to https://github.com/FoldingAtHome/fah-cl ... ssues/1137
ie Infinite loop: CORE_OUTDATED ( 0x6e) and missing debug info in Error msg. #1137
:e?:
PS I also noticed lots of:
WARNING:WU01:FS00:Failed to get assignment from '171.67.108.204:80': Empty work server assignment
in the earlier log
Any Suggestions??
Many thanks for your suggestions (and time)!
Log below
20:39:31:WU01:FS00:Connecting to 171.67.108.45:80
20:39:31:WU01:FS00:Assigned to work server 140.163.4.245
20:39:31:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon R9 200/HD 7900/8970] from 140.163.4.245
20:39:31:WU01:FS00:Connecting to 140.163.4.245:8080
20:39:32:WU01:FS00:Downloading 22.23MiB
20:39:38:WU01:FS00:Download 20.52%
20:39:44:WU01:FS00:Download 46.67%
20:39:50:WU01:FS00:Download 71.69%
20:39:56:WU01:FS00:Download 96.44%
20:39:56:WU01:FS00:Download complete
20:39:56:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10494 run:3 clone:30 gen:0 core:0x21 unit:0x000000048ca304f555de931550fded22
20:39:56:WU01:FS00:Starting
20:39:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 3488 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:39:56:WU01:FS00:Started FahCore on PID 8604
20:39:56:WU01:FS00:Core PID:9536
20:39:56:WU01:FS00:FahCore 0x21 started
20:39:57:WARNING:WU01:FS00:FahCore returned: CORE_OUTDATED (110 = 0x6e)
Re: FahCore returned: CORE_OUTDATED (110 = 0x6e)[/code]
The frequent EMPTY WORK SERVER ASSIGNMENT problem has been corrected.
Following a CORE_OUTDATED, you should see the client download a newer version of the core. I'm not sure why you don't see it.
Do you have a proxy or security software that's blocking certain internet connections by FAHClient?
Please post the first page of your log per the instructions below. That should answer questions like:
* Do you have a 64-bit operating system?
* What type of GPU do you have?
* How much RAM do you have?
Dr.G
Post by Dr.G »
@ bruce
Wow that was a quick reply!
No, newer core not downloading.
First page not available I'm afraid, as I'm logged in via remote access and don't get the first page of the log (log too long?).
I'll try to get the log off the computer with the problem directly tomorrow, and post it here
No proxy or security software...
Thanks!
Dr.G
Post by Dr.G »
@ bruce
did a 'refresh' to get the top of the log :wink:
GPU 0 is a 7970 (I think!?)
log and picture below-
*********************** Log Started 2015-12-01T12:19:43Z ***********************
12:19:43:************************* Folding@home Client *************************
12:19:43:      Website: http://folding.stanford.edu/
12:19:43:    Copyright: (c) 2009-2014 Stanford University
12:19:43:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:19:43:         Args:
12:19:43:       Config: C:/ProgramData/FAHClient/config.xml
12:19:43:******************************** Build ********************************
12:19:43:      Version: 7.4.4
12:19:43:         Date: Mar 4 2014
12:19:43:         Time: 20:26:54
12:19:43:      SVN Rev: 4130
12:19:43:       Branch: fah/trunk/client
12:19:43:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:19:43:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:19:43:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:19:43:     Platform: win32 XP
12:19:43:         Bits: 32
12:19:43:         Mode: Release
12:19:43:******************************* System ********************************
12:19:43:          CPU: Intel(R) Pentium(R) CPU G870 @ 3.10GHz
12:19:43:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:19:43:         CPUs: 2
12:19:43:       Memory: 3.95GiB
12:19:43:  Free Memory: 2.26GiB
12:19:43:      Threads: WINDOWS_THREADS
12:19:43:   OS Version: 6.1
12:19:43:  Has Battery: false
12:19:43:   On Battery: false
12:19:43:   UTC Offset: 0
12:19:43:          PID: 3488
12:19:43:          CWD: C:/ProgramData/FAHClient
12:19:43:           OS: Windows 7 Home Premium
12:19:43:      OS Arch: AMD64
12:19:43:         GPUs: 2
12:19:43:        GPU 0: ATI:5 Tahiti XT [Radeon R9 200/HD 7900/8970]
12:19:43:        GPU 1: ATI:5 Hawaii [Radeon R9 200/300X Series]
12:19:43:         CUDA: Not detected
12:19:43:Win32 Service: false
12:19:43:***********************************************************************
If you're running FAHControl, go to the "Log" tab. At the bottom, uncheck the Follow box (so it doesn't update while you're working) and click Refresh. Scroll to the top and post everything down to the word </config>
Wow. You got most of it before I wrote this.
bollix47
Post by bollix47 »
Fortunately, you can't update the core when it's in use. In this case your other slot is also processing a core_21 project. Right click on that slot (01) and select Pause. After the core updates you can right click on it again and select Fold.
bollix47 wrote:Fortunately, you can't update the core when it's in use. In this case your other slot is also processing a core_21 project. Right click on that slot (01) and select Pause. After the core updates you can right click on it again and select Fold.
Please note this is not the recommended way to update a core version on systems with multiple GPUs. The recommended way is to Finish the work units on all GPUs, then let the upgrade proceed.
However, the latest core revision was minor, and upgrading mid-work unit has low risk of corrupting the work units in progress.
