171.67.108.52 Dumping Multiple Units
kwerboom
171.67.108.52: Server did not like results, dumping
Post by kwerboom »
Hi. I have a work unit that gave me an odd error. Could someone explain it to me? Thank you.
*********************** Log Started 2015-12-06T00:40:22Z ***********************
00:40:22:************************* Folding@home Client *************************
00:40:22:      Website: http://folding.stanford.edu/
00:40:22:    Copyright: (c) 2009-2014 Stanford University
00:40:22:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:40:22:         Args:
00:40:22:       Config: C:/Users/Keith/AppData/Roaming/FAHClient/config.xml
00:40:22:******************************** Build ********************************
00:40:22:      Version: 7.4.4
00:40:22:         Date: Mar 4 2014
00:40:22:         Time: 20:26:54
00:40:22:      SVN Rev: 4130
00:40:22:       Branch: fah/trunk/client
00:40:22:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:40:22:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:40:22:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:40:22:     Platform: win32 XP
00:40:22:         Bits: 32
00:40:22:         Mode: Release
00:40:22:******************************* System ********************************
00:40:22:          CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
00:40:22:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
00:40:22:         CPUs: 8
00:40:22:       Memory: 15.94GiB
00:40:22:  Free Memory: 12.39GiB
00:40:22:      Threads: WINDOWS_THREADS
00:40:22:   OS Version: 6.2
00:40:22:  Has Battery: false
00:40:22:   On Battery: false
00:40:22:   UTC Offset: -6
00:40:22:          PID: 608
00:40:22:          CWD: C:/Users/Keith/AppData/Roaming/FAHClient
00:40:22:           OS: Windows 10 Pro
00:40:22:      OS Arch: AMD64
00:40:22:         GPUs: 1
00:40:22:        GPU 0: ATI:5 Tahiti PRO [Radeon R9 280/HD 7900/8950]
00:40:22:         CUDA: Not detected
00:40:22:Win32 Service: false
00:40:22:***********************************************************************
00:40:22:<config>
00:40:22:  <service-description v='Folding@home Client'/>
00:40:22:  <service-restart v='true'/>
00:40:22:  <service-restart-delay v='5000'/>
00:40:22:
00:40:22:  <!-- Client Control -->
00:40:22:  <client-threads v='6'/>
00:40:22:  <cycle-rate v='4'/>
00:40:22:  <cycles v='-1'/>
00:40:22:  <data-directory v='.'/>
00:40:22:  <disable-sleep-when-active v='true'/>
00:40:22:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
00:40:22:  <exit-when-done v='false'/>
00:40:22:  <fold-anon v='false'/>
00:40:22:  <open-web-control v='false'/>
00:40:22:
00:40:22:  <!-- Configuration -->
00:40:22:  <config-rotate v='true'/>
00:40:22:  <config-rotate-dir v='configs'/>
00:40:22:  <config-rotate-max v='16'/>
00:40:22:
00:40:22:  <!-- Debugging -->
00:40:22:  <assignment-servers>
00:40:22:    assign3.stanford.edu:8080 assign4.stanford.edu:80
00:40:22:  </assignment-servers>
00:40:22:  <auth-as v='true'/>
00:40:22:  <capture-directory v='capture'/>
00:40:22:  <capture-on-error v='false'/>
00:40:22:  <capture-packets v='false'/>
00:40:22:  <capture-requests v='false'/>
00:40:22:  <capture-responses v='false'/>
00:40:22:  <capture-sockets v='false'/>
00:40:22:  <core-exec v='FahCore_$type'/>
00:40:22:  <core-wrapper-exec v='FAHCoreWrapper'/>
00:40:22:  <debug-sockets v='false'/>
00:40:22:  <exception-locations v='true'/>
00:40:22:  <gpu-assignment-servers>
00:40:22:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
00:40:22:  </gpu-assignment-servers>
00:40:22:  <stack-traces v='false'/>
00:40:22:
00:40:22:  <!-- Error Handling -->
00:40:22:  <max-slot-errors v='10'/>
00:40:22:  <max-unit-errors v='5'/>
00:40:22:
00:40:22:  <!-- Folding Core -->
00:40:22:  <checkpoint v='9'/>
00:40:22:  <core-dir v='cores'/>
00:40:22:  <core-priority v='low'/>
00:40:22:  <cpu-affinity v='false'/>
00:40:22:  <cpu-usage v='100'/>
00:40:22:  <gpu-usage v='100'/>
00:40:22:  <no-assembly v='false'/>
00:40:22:
00:40:22:  <!-- Folding Slot Configuration -->
00:40:22:  <cause v='ANY'/>
00:40:22:  <client-subtype v='STDCLI'/>
00:40:22:  <client-type v='normal'/>
00:40:22:  <cpu-species v='X86_PENTIUM_II'/>
00:40:22:  <cpu-type v='AMD64'/>
00:40:22:  <cpus v='-1'/>
00:40:22:  <gpu v='true'/>
00:40:22:  <max-packet-size v='normal'/>
00:40:22:  <os-species v='UNKNOWN'/>
00:40:22:  <os-type v='WIN32'/>
00:40:22:  <project-key v='0'/>
00:40:22:  <smp v='true'/>
00:40:22:
00:40:22:  <!-- GUI -->
00:40:22:  <gui-enabled v='true'/>
00:40:22:
00:40:22:  <!-- HTTP Server -->
00:40:22:  <allow v='127.0.0.1'/>
00:40:22:  <connection-timeout v='60'/>
00:40:22:  <deny v='0/0'/>
00:40:22:  <http-addresses v='0:7396'/>
00:40:22:  <https-addresses v=''/>
00:40:22:  <max-connect-time v='900'/>
00:40:22:  <max-connections v='800'/>
00:40:22:  <max-request-length v='52428800'/>
00:40:22:  <min-connect-time v='300'/>
00:40:22:  <threads v='8'/>
00:40:22:
00:40:22:  <!-- Logging -->
00:40:22:  <log v='log.txt'/>
00:40:22:  <log-color v='false'/>
00:40:22:  <log-crlf v='true'/>
00:40:22:  <log-date v='false'/>
00:40:22:  <log-date-periodically v='21600'/>
00:40:22:  <log-debug v='true'/>
00:40:22:  <log-domain v='false'/>
00:40:22:  <log-header v='true'/>
00:40:22:  <log-level v='true'/>
00:40:22:  <log-no-info-header v='true'/>
00:40:22:  <log-redirect v='false'/>
00:40:22:  <log-rotate v='true'/>
00:40:22:  <log-rotate-dir v='logs'/>
00:40:22:  <log-rotate-max v='16'/>
00:40:22:  <log-short-level v='false'/>
00:40:22:  <log-simple-domains v='true'/>
00:40:22:  <log-thread-id v='false'/>
00:40:22:  <log-thread-prefix v='true'/>
00:40:22:  <log-time v='true'/>
00:40:22:  <log-to-screen v='true'/>
00:40:22:  <log-truncate v='false'/>
00:40:22:  <verbosity v='5'/>
00:40:22:
00:40:22:  <!-- Network -->
00:40:22:  <proxy v=':8080'/>
00:40:22:  <proxy-enable v='false'/>
00:40:22:  <proxy-pass v=''/>
00:40:22:  <proxy-user v=''/>
00:40:22:
00:40:22:  <!-- Process Control -->
00:40:22:  <child v='false'/>
00:40:22:  <daemon v='false'/>
00:40:22:  <pid v='false'/>
00:40:22:  <pid-file v='Folding@home Client.pid'/>
00:40:22:  <respawn v='false'/>
00:40:22:  <service v='false'/>
00:40:22:
00:40:22:  <!-- Remote Command Server -->
00:40:22:  <command-address v='0.0.0.0'/>
00:40:22:  <command-allow-no-pass v='127.0.0.1'/>
00:40:22:  <command-deny-no-pass v='0/0'/>
00:40:22:  <command-enable v='true'/>
00:40:22:  <command-port v='36330'/>
00:40:22:
00:40:22:  <!-- Slot Control -->
00:40:22:  <idle v='false'/>
00:40:22:  <max-shutdown-wait v='60'/>
00:40:22:  <pause-on-battery v='false'/>
00:40:22:  <pause-on-start v='false'/>
00:40:22:  <paused v='false'/>
00:40:22:  <power v='medium'/>
00:40:22:
00:40:22:  <!-- User Information -->
00:40:22:  <machine-id v='0'/>
00:40:22:  <passkey v='********************************'/>
00:40:22:  <team v='50959'/>
00:40:22:  <user v='kwerboom'/>
00:40:22:
00:40:22:  <!-- Web Server -->
00:40:22:  <web-allow v='127.0.0.1'/>
00:40:22:  <web-deny v='0/0'/>
00:40:22:  <web-enable v='true'/>
00:40:22:
00:40:22:  <!-- Web Server Sessions -->
00:40:22:  <session-cookie v='sid'/>
00:40:22:  <session-lifetime v='86400'/>
00:40:22:  <session-timeout v='3600'/>
00:40:22:
00:40:22:  <!-- Work Unit Control -->
00:40:22:  <dump-after-deadline v='true'/>
00:40:22:  <max-queue v='16'/>
00:40:22:  <max-units v='0'/>
00:40:22:  <next-unit-percentage v='99'/>
00:40:22:  <stall-detection-enabled v='false'/>
00:40:22:  <stall-percent v='5'/>
00:40:22:  <stall-timeout v='1800'/>
00:40:22:
00:40:22:  <!-- Folding Slots -->
00:40:22:  <slot id='1' type='GPU'>
00:40:22:    <paused v='true'/>
00:40:22:  </slot>
00:40:22:</config>
00:40:22:Trying to access database...
00:40:22:Successfully acquired database lock
00:40:22:Enabled folding slot 01: PAUSED gpu:0:Tahiti PRO [Radeon R9 280/HD 7900/8950] (by user)
00:40:22:Started thread 4 on PID 608
00:40:22:Started thread 5 on PID 608
00:40:22:Started thread 7 on PID 608
00:40:22:Started thread 9 on PID 608
00:40:22:Started thread 8 on PID 608
00:40:22:Started thread 6 on PID 608
00:41:02:Started thread 10 on PID 608
00:41:04:FS01:Unpaused
00:41:04:WU00:FS01:Starting
00:41:04:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Keith/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 608 -checkpoint 9 -gpu 0 -gpu-vendor ati
00:41:04:WU00:FS01:Started FahCore on PID 9592
00:41:04:Started thread 11 on PID 608
00:41:04:WU00:FS01:Core PID:6640
00:41:04:WU00:FS01:FahCore 0x17 started
00:41:05:WU00:FS01:0x17:*********************** Log Started 2015-12-06T00:41:04Z ***********************
00:41:05:WU00:FS01:0x17:Project: 9201 (Run 852, Clone 3, Gen 369)
00:41:05:WU00:FS01:0x17:Unit: 0x000002146652edc45399f78cb80dac42
00:41:05:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
00:41:05:WU00:FS01:0x17:Machine: 1
00:41:05:WU00:FS01:0x17:Digital signatures verified
00:41:05:WU00:FS01:0x17:Folding@home GPU core17
00:41:05:WU00:FS01:0x17:Version 0.0.52
00:41:05:WU00:FS01:0x17:  Found a checkpoint file
00:41:21:WU00:FS01:0x17:Completed 4150000 out of 5000000 steps (83%)
00:41:21:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:41:23:Removing old file 'configs/config-20151130-064130.xml'
00:41:23:Saving configuration to config.xml
00:41:23:<config>
00:41:23:  <!-- Folding Core -->
00:41:23:  <checkpoint v='9'/>
00:41:23:  <core-priority v='low'/>
00:41:23:
00:41:23:  <!-- Logging -->
00:41:23:  <verbosity v='5'/>
00:41:23:
00:41:23:  <!-- Network -->
00:41:23:  <proxy v=':8080'/>
00:41:23:
00:41:23:  <!-- Slot Control -->
00:41:23:  <pause-on-battery v='false'/>
00:41:23:
00:41:23:  <!-- User Information -->
00:41:23:  <passkey v='********************************'/>
00:41:23:  <team v='50959'/>
00:41:23:  <user v='kwerboom'/>
00:41:23:
00:41:23:  <!-- Folding Slots -->
00:41:23:  <slot id='1' type='GPU'/>
00:41:23:</config>
00:44:31:WU00:FS01:0x17:Completed 4200000 out of 5000000 steps (84%)
00:47:45:WU00:FS01:0x17:Completed 4250000 out of 5000000 steps (85%)
00:50:57:WU00:FS01:0x17:Completed 4300000 out of 5000000 steps (86%)
00:54:15:WU00:FS01:0x17:Completed 4350000 out of 5000000 steps (87%)
00:57:32:WU00:FS01:0x17:Completed 4400000 out of 5000000 steps (88%)
01:00:50:WU00:FS01:0x17:Completed 4450000 out of 5000000 steps (89%)
01:04:08:WU00:FS01:0x17:Completed 4500000 out of 5000000 steps (90%)
01:07:25:WU00:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
01:09:04:FS01:Paused
01:09:04:FS01:Shutting core down
01:09:04:WU00:FS01:0x17:WARNING:Console control signal 1 on PID 6640
01:09:04:WU00:FS01:0x17:Exiting, please wait. . .
01:09:04:WU00:FS01:0x17:Lost lifeline PID 9592, exiting
01:09:04:WU00:FS01:0x17:ERROR:103: Lost client lifeline
01:09:04:WU00:FS01:0x17:Folding@home Core Shutdown: CLIENT_DIED
01:09:05:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
01:09:51:Removing old file 'configs/config-20151130-065140.xml'
01:09:51:Saving configuration to config.xml
01:09:51:<config>
01:09:51:  <!-- Folding Core -->
01:09:51:  <checkpoint v='9'/>
01:09:51:  <core-priority v='low'/>
01:09:51:
01:09:51:  <!-- Logging -->
01:09:51:  <verbosity v='5'/>
01:09:51:
01:09:51:  <!-- Network -->
01:09:51:  <proxy v=':8080'/>
01:09:51:
01:09:51:  <!-- Slot Control -->
01:09:51:  <pause-on-battery v='false'/>
01:09:51:
01:09:51:  <!-- User Information -->
01:09:51:  <passkey v='********************************'/>
01:09:51:  <team v='50959'/>
01:09:51:  <user v='kwerboom'/>
01:09:51:
01:09:51:  <!-- Folding Slots -->
01:09:51:  <slot id='1' type='GPU'>
01:09:51:    <paused v='true'/>
01:09:51:  </slot>
01:09:51:</config>
01:33:20:FS01:Unpaused
01:33:20:WU00:FS01:Starting
01:33:20:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Keith/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 608 -checkpoint 9 -gpu 0 -gpu-vendor ati
01:33:20:WU00:FS01:Started FahCore on PID 8464
01:33:20:Started thread 12 on PID 608
01:33:20:WU00:FS01:Core PID:11248
01:33:20:WU00:FS01:FahCore 0x17 started
01:33:20:WU00:FS01:0x17:*********************** Log Started 2015-12-06T01:33:20Z ***********************
01:33:20:WU00:FS01:0x17:Project: 9201 (Run 852, Clone 3, Gen 369)
01:33:20:WU00:FS01:0x17:Unit: 0x000002146652edc45399f78cb80dac42
01:33:20:WU00:FS01:0x17:CPU: 0x00000000000000000000000000000000
01:33:20:WU00:FS01:0x17:Machine: 1
01:33:20:WU00:FS01:0x17:Digital signatures verified
01:33:20:WU00:FS01:0x17:Folding@home GPU core17
01:33:20:WU00:FS01:0x17:Version 0.0.52
01:33:20:WU00:FS01:0x17:  Found a checkpoint file
01:33:36:WU00:FS01:0x17:Completed 4550000 out of 5000000 steps (91%)
01:33:36:WU00:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:34:15:Removing old file 'configs/config-20151130-084835.xml'
01:34:15:Saving configuration to config.xml
01:34:15:<config>
01:34:15:  <!-- Folding Core -->
01:34:15:  <checkpoint v='9'/>
01:34:15:  <core-priority v='low'/>
01:34:15:
01:34:15:  <!-- Logging -->
01:34:15:  <verbosity v='5'/>
01:34:15:
01:34:15:  <!-- Network -->
01:34:15:  <proxy v=':8080'/>
01:34:15:
01:34:15:  <!-- Slot Control -->
01:34:15:  <pause-on-battery v='false'/>
01:34:15:
01:34:15:  <!-- User Information -->
01:34:15:  <passkey v='********************************'/>
01:34:15:  <team v='50959'/>
01:34:15:  <user v='kwerboom'/>
01:34:15:
01:34:15:  <!-- Folding Slots -->
01:34:15:  <slot id='1' type='GPU'/>
01:34:15:</config>
01:36:51:WU00:FS01:0x17:Completed 4600000 out of 5000000 steps (92%)
01:40:05:WU00:FS01:0x17:Completed 4650000 out of 5000000 steps (93%)
01:43:21:WU00:FS01:0x17:Completed 4700000 out of 5000000 steps (94%)
01:46:36:WU00:FS01:0x17:Completed 4750000 out of 5000000 steps (95%)
01:49:47:WU00:FS01:0x17:Completed 4800000 out of 5000000 steps (96%)
01:52:58:WU00:FS01:0x17:Completed 4850000 out of 5000000 steps (97%)
01:56:09:WU00:FS01:0x17:Completed 4900000 out of 5000000 steps (98%)
01:59:20:WU00:FS01:0x17:Completed 4950000 out of 5000000 steps (99%)
02:02:30:WU00:FS01:0x17:Completed 5000000 out of 5000000 steps (100%)
02:02:33:WU00:FS01:0x17:Saving result file logfile_01.txt
02:02:33:WU00:FS01:0x17:Saving result file checkpointState.xml
02:02:33:WU00:FS01:0x17:Saving result file checkpt.crc
02:02:33:WU00:FS01:0x17:Saving result file log.txt
02:02:33:WU00:FS01:0x17:Saving result file positions.xtc
02:02:34:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
02:02:35:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:02:35:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:852 clone:3 gen:369 core:0x17 unit:0x000002146652edc45399f78cb80dac42
02:02:35:WU00:FS01:Uploading 8.36MiB to 171.67.108.52
02:02:35:WU00:FS01:Connecting to 171.67.108.52:8080
02:02:35:WU01:FS01:Starting
02:02:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Keith/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 608 -checkpoint 9 -gpu 0 -gpu-vendor ati
02:02:35:WU01:FS01:Started FahCore on PID 8924
02:02:35:Started thread 13 on PID 608
02:02:35:WU01:FS01:Core PID:7428
02:02:35:WU01:FS01:FahCore 0x17 started
02:02:35:WU01:FS01:0x17:*********************** Log Started 2015-12-06T02:02:35Z ***********************
02:02:35:WU01:FS01:0x17:Project: 9201 (Run 164, Clone 4, Gen 363)
02:02:35:WU01:FS01:0x17:Unit: 0x000002206652edc45399dc7bd4149749
02:02:35:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
02:02:35:WU01:FS01:0x17:Machine: 1
02:02:35:WU01:FS01:0x17:Reading tar file state.xml
02:02:35:WU01:FS01:0x17:Reading tar file system.xml
02:02:35:WU01:FS01:0x17:Reading tar file integrator.xml
02:02:35:WU01:FS01:0x17:Reading tar file core.xml
02:02:35:WU01:FS01:0x17:Digital signatures verified
02:02:35:WU01:FS01:0x17:Folding@home GPU core17
02:02:35:WU01:FS01:0x17:Version 0.0.52
02:02:41:WU00:FS01:Upload 8.22%
02:02:47:WU00:FS01:Upload 12.70%
02:02:52:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
02:02:52:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:02:53:WU00:FS01:Upload 17.19%
02:02:59:WU00:FS01:Upload 23.16%
02:03:05:WU00:FS01:Upload 29.14%
02:03:11:WU00:FS01:Upload 35.12%
02:03:17:WU00:FS01:Upload 41.10%
02:03:23:WU00:FS01:Upload 47.82%
02:03:29:WU00:FS01:Upload 53.80%
02:03:35:WU00:FS01:Upload 60.52%
02:03:41:WU00:FS01:Upload 66.50%
02:03:47:WU00:FS01:Upload 72.48%
02:03:53:WU00:FS01:Upload 77.71%
02:03:59:WU00:FS01:Upload 83.69%
02:04:05:WU00:FS01:Upload 90.41%
02:04:11:WU00:FS01:Upload 96.39%
02:04:17:WU00:FS01:Upload complete
02:04:17:WU00:FS01:Server responded WORK_QUIT (404)
02:04:17:WARNING:WU00:FS01:Server did not like results, dumping
02:04:17:WU00:FS01:Cleaning up
btupsx
Post by btupsx »
Looks like this server has something amiss. Have had 5 WU's, split between 3 different machines, with different hardware configurations, receive the same "Server did not like results, Dumping" error. All of the machines are AMD Pitcairn based, and it looks like the WU's were both Core17 and Core21's. After this most recent failure, seems obvious to me that it is the server.
Brief log snippet:
05:12:58:WU01:FS01:Connecting to 171.67.108.45:80
05:12:59:WU01:FS01:Assigned to work server 171.67.108.52
05:12:59:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Pitcairn PRO [Radeon HD 7800 Series] from 171.67.108.52
05:12:59:WU01:FS01:Connecting to 171.67.108.52:8080
05:13:01:WU01:FS01:Downloading 1.52MiB
05:13:01:WU01:FS01:Download complete
05:13:01:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:879 clone:4 gen:483 core:0x17 unit:0x000002dd6652edc45399f89d2ae6720f
05:13:02:WU00:FS01:0x17:Saving result file logfile_01.txt
05:13:02:WU00:FS01:0x17:Saving result file checkpointState.xml
05:13:02:WU00:FS01:0x17:Saving result file checkpt.crc
05:13:02:WU00:FS01:0x17:Saving result file log.txt
05:13:02:WU00:FS01:0x17:Saving result file positions.xtc
05:13:04:WU00:FS01:0x17:Folding@home Core Shutdown: FINISHED_UNIT
05:13:05:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:13:05:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:807 clone:3 gen:484 core:0x17 unit:0x000002eb6652edc45399f5c8b7885a98
05:13:05:WU00:FS01:Uploading 8.35MiB to 171.67.108.52
05:13:05:WU01:FS01:Starting
05:13:05:WU00:FS01:Connecting to 171.67.108.52:8080
05:13:05:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/btupsx/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2432 -checkpoint 3 -gpu 0 -gpu-vendor ati
05:13:05:WU01:FS01:Started FahCore on PID 3608
05:13:05:WU01:FS01:Core PID:6956
05:13:05:WU01:FS01:FahCore 0x17 started
05:13:05:WU01:FS01:0x17:*********************** Log Started 2015-12-06T05:13:05Z ***********************
05:13:05:WU01:FS01:0x17:Project: 9201 (Run 879, Clone 4, Gen 483)
05:13:05:WU01:FS01:0x17:Unit: 0x000002dd6652edc45399f89d2ae6720f
05:13:05:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
05:13:05:WU01:FS01:0x17:Machine: 1
05:13:05:WU01:FS01:0x17:Reading tar file state.xml
05:13:05:WU01:FS01:0x17:Reading tar file system.xml
05:13:06:WU01:FS01:0x17:Reading tar file integrator.xml
05:13:06:WU01:FS01:0x17:Reading tar file core.xml
05:13:06:WU01:FS01:0x17:Digital signatures verified
05:13:06:WU01:FS01:0x17:Folding@home GPU core17
05:13:06:WU01:FS01:0x17:Version 0.0.52
05:13:11:WU00:FS01:Upload 9.73%
05:13:17:WU00:FS01:Upload 19.46%
05:13:23:WU00:FS01:Upload 29.18%
05:13:29:WU00:FS01:Upload 39.66%
05:13:35:WU00:FS01:Upload 49.39%
05:13:38:WU01:FS01:0x17:Completed 0 out of 5000000 steps (0%)
05:13:38:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:13:41:WU00:FS01:Upload 59.86%
05:13:47:WU00:FS01:Upload 69.59%
05:13:53:WU00:FS01:Upload 79.32%
05:13:59:WU00:FS01:Upload 89.05%
05:14:05:WU00:FS01:Upload 98.77%
05:14:06:WU00:FS01:Upload complete
05:14:06:WU00:FS01:Server responded WORK_QUIT (404)
05:14:06:WARNING:WU00:FS01:Server did not like results, dumping
05:14:06:WU00:FS01:Cleaning up
Reason: Added code tags
btupsx
Re: WARNING:WU00:FS01:Server did not like results, dumping
Post by btupsx »
It's not the WU, it seems to be the server. I've experienced the *exact* same error, on multiple different WUs, on different machines, in the past 12 hours. I started a "Problem with Server" thread here:
viewtopic.php?f=18&t=28358
kwerboom
Post by kwerboom »
btupsx wrote:It's not the WU, it seems to be the server. I've experienced the *exact* same error, on multiple different WUs, on different machines, in the past 12 hours. I started a "Problem with Server" thread here:
Thank you. But what happens to the WU that my computer worked on and got dumped by the bad server?
btupsx
Post by btupsx »
Unfortunately, what happens is that the work you did on that unit is lost, and you do not receive credit for it. Eventually the unit will be reassigned to another Donor, until it is submitted successfully.
Zebulon84
Hardware configuration: Athlon 64 X2 4600+ (Manchester, 90 nm)
8800GTS 640 (G80) @ 675/1008/1620
Gigabyte K8NF-9
2 * 1Go DDR 400
Vista 32 HP + SP1
Vista Firewall
Re: 171.67.108.52 Dumping Multiple Units
Post by Zebulon84 »
Got this error too, same server, same project, also on Pitcairn GPU
Previous WU was also same server and project, but uploaded correctly. Next one also on this server and project is still running.
*********************** Log Started 2015-12-05T03:37:34Z ***********************
03:37:34:************************* Folding@home Client *************************
03:37:34:      Website: http://folding.stanford.edu/
03:37:34:    Copyright: (c) 2009-2014 Stanford University
03:37:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:37:34:         Args:
03:37:34:       Config: C:/Users/***/AppData/Roaming/FAHClient/config.xml
03:37:34:******************************** Build ********************************
03:37:34:      Version: 7.4.4
03:37:34:         Date: Mar 4 2014
03:37:34:         Time: 20:26:54
03:37:34:      SVN Rev: 4130
03:37:34:       Branch: fah/trunk/client
03:37:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:37:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:37:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:37:34:     Platform: win32 XP
03:37:34:         Bits: 32
03:37:34:         Mode: Release
03:37:34:******************************* System ********************************
03:37:34:          CPU: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
03:37:34:       CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
03:37:34:         CPUs: 4
03:37:34:       Memory: 8.00GiB
03:37:34:  Free Memory: 6.76GiB
03:37:34:      Threads: WINDOWS_THREADS
03:37:34:   OS Version: 6.2
03:37:34:  Has Battery: false
03:37:34:   On Battery: false
03:37:34:   UTC Offset: 1
03:37:34:          PID: 5100
03:37:34:          CWD: C:/Users/***/AppData/Roaming/FAHClient
03:37:34:           OS: Windows 10 Home
03:37:34:      OS Arch: AMD64
03:37:34:         GPUs: 1
03:37:34:        GPU 0: ATI:5 Pitcairn PRO [Radeon HD 7800 Series]
03:37:34:         CUDA: Not detected
03:37:34:Win32 Service: false
03:37:34:***********************************************************************
03:37:34:<config>
03:37:34:  <!-- Network -->
03:37:34:  <proxy v=':8080'/>
03:37:34:
03:37:34:  <!-- Slot Control -->
03:37:34:  <power v='full'/>
03:37:34:
03:37:34:  <!-- User Information -->
03:37:34:  <passkey v='********************************'/>
03:37:34:  <team v='51'/>
03:37:34:  <user v='Zebulon84'/>
03:37:34:
03:37:34:  <!-- Folding Slots -->
03:37:34:  <slot id='1' type='CPU'/>
03:37:34:  <slot id='0' type='GPU'/>
03:37:34:</config>
03:37:34:Trying to access database...
03:37:34:Successfully acquired database lock
03:37:34:Enabled folding slot 01: READY cpu:3
03:37:34:Enabled folding slot 00: READY gpu:0:Pitcairn PRO [Radeon HD 7800 Series]
03:37:34:WU01:FS00:Starting
03:37:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 5100 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:37:34:WU01:FS00:Started FahCore on PID 5140
03:37:35:WU01:FS00:Core PID:4868
03:37:35:WU01:FS00:FahCore 0x17 started
03:37:36:WU01:FS00:0x17:*********************** Log Started 2015-12-05T03:37:35Z ***********************
03:37:36:WU01:FS00:0x17:Project: 9201 (Run 585, Clone 0, Gen 722)
03:37:36:WU01:FS00:0x17:Unit: 0x000004276652edc45399ed03df07dd17
03:37:36:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:37:36:WU01:FS00:0x17:Machine: 0
03:37:36:WU01:FS00:0x17:Digital signatures verified
03:37:36:WU01:FS00:0x17:Folding@home GPU core17
03:37:36:WU01:FS00:0x17:Version 0.0.52
03:37:36:WU01:FS00:0x17:  Found a checkpoint file
03:38:02:WU01:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
03:38:02:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:43:02:WU01:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
03:48:05:WU01:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
03:53:06:WU01:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
03:58:08:WU01:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
04:03:09:WU01:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
04:08:13:WU01:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
04:13:14:WU01:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
04:18:16:WU01:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
04:23:17:WU01:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
04:28:19:WU01:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
04:33:21:WU01:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
04:38:22:WU01:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
04:43:24:WU01:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
04:48:26:WU01:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
04:53:29:WU01:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
04:58:35:WU01:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
05:03:37:WU01:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
05:08:40:WU01:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
05:13:42:WU01:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
05:18:44:WU01:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
05:23:45:WU01:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
05:23:46:WU02:FS00:Connecting to 171.67.108.45:80
05:23:47:WU02:FS00:Assigned to work server 171.67.108.52
05:23:47:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Pitcairn PRO [Radeon HD 7800 Series] from 171.67.108.52
05:23:47:WU02:FS00:Connecting to 171.67.108.52:8080
05:23:48:WU02:FS00:Downloading 1.52MiB
05:23:54:WU02:FS00:Download 100.00%
05:23:54:WU02:FS00:Download complete
05:23:54:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:508 clone:2 gen:593 core:0x17 unit:0x000003646652edc45399ea03a483085a
05:28:47:WU01:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
05:28:51:WU01:FS00:0x17:Saving result file logfile_01.txt
05:28:51:WU01:FS00:0x17:Saving result file checkpointState.xml
05:28:51:WU01:FS00:0x17:Saving result file checkpt.crc
05:28:51:WU01:FS00:0x17:Saving result file log.txt
05:28:51:WU01:FS00:0x17:Saving result file positions.xtc
05:28:53:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
05:28:53:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:28:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9201 run:585 clone:0 gen:722 core:0x17 unit:0x000004276652edc45399ed03df07dd17
05:28:53:WU01:FS00:Uploading 8.35MiB to 171.67.108.52
05:28:53:WU01:FS00:Connecting to 171.67.108.52:8080
05:28:53:WU02:FS00:Starting
05:28:53:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5100 -checkpoint 15 -gpu 0 -gpu-vendor ati
05:28:53:WU02:FS00:Started FahCore on PID 4876
05:28:53:WU02:FS00:Core PID:212
05:28:53:WU02:FS00:FahCore 0x17 started
05:28:54:WU02:FS00:0x17:*********************** Log Started 2015-12-05T05:28:53Z ***********************
05:28:54:WU02:FS00:0x17:Project: 9201 (Run 508, Clone 2, Gen 593)
05:28:54:WU02:FS00:0x17:Unit: 0x000003646652edc45399ea03a483085a
05:28:54:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
05:28:54:WU02:FS00:0x17:Machine: 0
05:28:54:WU02:FS00:0x17:Reading tar file state.xml
05:28:54:WU02:FS00:0x17:Reading tar file system.xml
05:28:54:WU02:FS00:0x17:Reading tar file integrator.xml
05:28:54:WU02:FS00:0x17:Reading tar file core.xml
05:28:54:WU02:FS00:0x17:Digital signatures verified
05:28:54:WU02:FS00:0x17:Folding@home GPU core17
05:28:54:WU02:FS00:0x17:Version 0.0.52
05:28:59:WU01:FS00:Upload 10.48%
05:29:05:WU01:FS00:Upload 19.47%
05:29:11:WU01:FS00:Upload 28.45%
05:29:17:WU01:FS00:Upload 37.44%
05:29:21:WU02:FS00:0x17:Completed 0 out of 5000000 steps (0%)
05:29:21:WU02:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:29:23:WU01:FS00:Upload 47.17%
05:29:29:WU01:FS00:Upload 56.16%
05:29:35:WU01:FS00:Upload 65.89%
05:29:41:WU01:FS00:Upload 74.88%
05:29:47:WU01:FS00:Upload 84.61%
05:29:53:WU01:FS00:Upload 94.34%
05:30:02:WU01:FS00:Upload complete
05:30:02:WU01:FS00:Server responded WORK_ACK (400)
05:30:02:WU01:FS00:Final credit estimate, 22067.00 points
05:30:02:WU01:FS00:Cleaning up
05:34:31:WU02:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
05:39:42:WU02:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
05:44:53:WU02:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
05:50:05:WU02:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
05:55:16:WU02:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
06:00:27:WU02:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
06:05:38:WU02:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
06:10:50:WU02:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
06:16:01:WU02:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
06:21:13:WU02:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
06:26:24:WU02:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
06:31:36:WU02:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
06:36:47:WU02:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
06:41:59:WU02:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
06:47:10:WU02:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
06:52:21:WU02:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
06:57:32:WU02:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
07:02:44:WU02:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
07:07:56:WU02:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
07:13:08:WU02:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
07:18:21:WU02:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
07:23:34:WU02:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
07:28:45:WU02:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
07:33:57:WU02:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
07:39:08:WU02:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
07:44:20:WU02:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
07:49:31:WU02:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
07:54:42:WU02:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
07:59:53:WU02:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
08:05:04:WU02:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
08:10:14:WU02:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
08:15:24:WU02:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
08:20:36:WU02:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
08:25:47:WU02:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
08:30:59:WU02:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
08:36:10:WU02:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
08:41:21:WU02:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
08:46:33:WU02:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
08:51:45:WU02:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
08:56:56:WU02:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
09:02:07:WU02:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
09:07:18:WU02:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
09:12:29:WU02:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
09:17:40:WU02:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
09:22:50:WU02:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
09:28:01:WU02:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
09:33:12:WU02:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
******************************* Date: 2015-12-05 *******************************
09:38:24:WU02:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
09:43:35:WU02:FS00:0x17:Completed 2450000 out of 5000000 steps (49%)
09:48:45:WU02:FS00:0x17:Completed 2500000 out of 5000000 steps (50%)
09:53:55:WU02:FS00:0x17:Completed 2550000 out of 5000000 steps (51%)
09:59:05:WU02:FS00:0x17:Completed 2600000 out of 5000000 steps (52%)
10:04:15:WU02:FS00:0x17:Completed 2650000 out of 5000000 steps (53%)
10:09:26:WU02:FS00:0x17:Completed 2700000 out of 5000000 steps (54%)
10:14:36:WU02:FS00:0x17:Completed 2750000 out of 5000000 steps (55%)
10:19:46:WU02:FS00:0x17:Completed 2800000 out of 5000000 steps (56%)
10:24:56:WU02:FS00:0x17:Completed 2850000 out of 5000000 steps (57%)
10:30:07:WU02:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
10:35:17:WU02:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
10:40:27:WU02:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
10:45:38:WU02:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
10:50:48:WU02:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
10:55:58:WU02:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
11:01:08:WU02:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
11:06:19:WU02:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
11:11:29:WU02:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
11:16:39:WU02:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
11:21:50:WU02:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
11:27:00:WU02:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
11:32:10:WU02:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
11:37:21:WU02:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
11:42:31:WU02:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
11:47:41:WU02:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
11:52:51:WU02:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
11:58:01:WU02:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
12:03:12:WU02:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
12:08:22:WU02:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
12:13:33:WU02:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
12:18:43:WU02:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
12:23:54:WU02:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
12:29:04:WU02:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
12:34:15:WU02:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
12:39:25:WU02:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
12:44:35:WU02:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
12:49:45:WU02:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
12:54:55:WU02:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
13:00:06:WU02:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
13:05:16:WU02:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
13:10:26:WU02:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
13:15:36:WU02:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
13:20:46:WU02:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
13:25:56:WU02:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
13:31:07:WU02:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
13:36:17:WU02:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
13:41:27:WU02:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
13:46:38:WU02:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
13:51:48:WU02:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
13:56:58:WU02:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
14:02:08:WU02:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
14:02:09:WU00:FS00:Connecting to 171.67.108.45:80
14:02:10:WU00:FS00:Assigned to work server 171.67.108.52
14:02:10:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Pitcairn PRO [Radeon HD 7800 Series] from 171.67.108.52
14:02:10:WU00:FS00:Connecting to 171.67.108.52:8080
14:02:11:WU00:FS00:Downloading 1.53MiB
14:02:15:WU00:FS00:Download complete
14:02:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:700 clone:3 gen:471 core:0x17 unit:0x000002c96652edc45399f194bc0ac937
14:07:19:WU02:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
14:07:22:WU02:FS00:0x17:Saving result file logfile_01.txt
14:07:22:WU02:FS00:0x17:Saving result file checkpointState.xml
14:07:23:WU02:FS00:0x17:Saving result file checkpt.crc
14:07:23:WU02:FS00:0x17:Saving result file log.txt
14:07:23:WU02:FS00:0x17:Saving result file positions.xtc
14:07:25:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
14:07:25:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:07:25:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9201 run:508 clone:2 gen:593 core:0x17 unit:0x000003646652edc45399ea03a483085a
14:07:25:WU02:FS00:Uploading 8.39MiB to 171.67.108.52
14:07:25:WU02:FS00:Connecting to 171.67.108.52:8080
14:07:25:WU00:FS00:Starting
14:07:25:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5100 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:07:25:WU00:FS00:Started FahCore on PID 7964
14:07:26:WU00:FS00:Core PID:7976
14:07:26:WU00:FS00:FahCore 0x17 started
14:07:26:WU00:FS00:0x17:*********************** Log Started 2015-12-05T14:07:26Z ***********************
14:07:26:WU00:FS00:0x17:Project: 9201 (Run 700, Clone 3, Gen 471)
14:07:26:WU00:FS00:0x17:Unit: 0x000002c96652edc45399f194bc0ac937
14:07:26:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:07:26:WU00:FS00:0x17:Machine: 0
14:07:26:WU00:FS00:0x17:Reading tar file state.xml
14:07:27:WU00:FS00:0x17:Reading tar file system.xml
14:07:27:WU00:FS00:0x17:Reading tar file integrator.xml
14:07:27:WU00:FS00:0x17:Reading tar file core.xml
14:07:27:WU00:FS00:0x17:Digital signatures verified
14:07:27:WU00:FS00:0x17:Folding@home GPU core17
14:07:27:WU00:FS00:0x17:Version 0.0.52
14:07:31:WU02:FS00:Upload 10.43%
14:07:37:WU02:FS00:Upload 16.39%
14:07:43:WU02:FS00:Upload 26.07%
14:07:49:WU02:FS00:Upload 35.01%
14:07:53:WU00:FS00:0x17:Completed 0 out of 5000000 steps (0%)
14:07:53:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:07:55:WU02:FS00:Upload 44.69%
14:08:01:WU02:FS00:Upload 53.63%
14:08:07:WU02:FS00:Upload 63.31%
14:08:13:WU02:FS00:Upload 72.99%
14:08:19:WU02:FS00:Upload 81.93%
14:08:25:WU02:FS00:Upload 91.61%
14:08:35:WU02:FS00:Upload complete
14:08:35:WU02:FS00:Server responded WORK_ACK (400)
14:08:36:WU02:FS00:Final credit estimate, 21161.00 points
14:08:36:WU02:FS00:Cleaning up
14:13:01:WU00:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
14:18:10:WU00:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
14:23:18:WU00:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
14:28:26:WU00:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
14:33:35:WU00:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
14:38:44:WU00:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
14:43:52:WU00:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
14:49:01:WU00:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
14:54:10:WU00:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
14:59:18:WU00:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
15:04:26:WU00:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
15:09:36:WU00:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
15:14:44:WU00:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
15:19:53:WU00:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
15:25:02:WU00:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
15:30:11:WU00:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
15:35:19:WU00:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
15:40:28:WU00:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
15:45:36:WU00:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
15:50:45:WU00:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
15:55:54:WU00:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
16:01:03:WU00:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
16:06:11:WU00:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
16:11:20:WU00:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
16:16:29:WU00:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
16:21:38:WU00:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
16:26:46:WU00:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
16:31:55:WU00:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
16:37:03:WU00:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
16:42:12:WU00:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
16:47:21:WU00:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
16:52:30:WU00:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
16:57:38:WU00:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
17:02:47:WU00:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
17:07:56:WU00:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
17:13:04:WU00:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
17:18:13:WU00:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
17:23:22:WU00:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
17:28:31:WU00:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
17:33:40:WU00:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
17:38:49:WU00:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
17:43:59:WU00:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
17:49:10:WU00:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
17:54:20:WU00:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
17:59:30:WU00:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
18:04:40:WU00:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
18:09:50:WU00:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
18:15:00:WU00:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
18:20:10:WU00:FS00:0x17:Completed 2450000 out of 5000000 steps (49%)
18:25:21:WU00:FS00:0x17:Completed 2500000 out of 5000000 steps (50%)
18:30:30:WU00:FS00:0x17:Completed 2550000 out of 5000000 steps (51%)
18:35:40:WU00:FS00:0x17:Completed 2600000 out of 5000000 steps (52%)
18:40:50:WU00:FS00:0x17:Completed 2650000 out of 5000000 steps (53%)
18:46:00:WU00:FS00:0x17:Completed 2700000 out of 5000000 steps (54%)
18:51:10:WU00:FS00:0x17:Completed 2750000 out of 5000000 steps (55%)
18:56:20:WU00:FS00:0x17:Completed 2800000 out of 5000000 steps (56%)
19:01:30:WU00:FS00:0x17:Completed 2850000 out of 5000000 steps (57%)
19:06:41:WU00:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
19:11:50:WU00:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
19:17:00:WU00:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
19:22:09:WU00:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
19:27:18:WU00:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
19:32:27:WU00:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
19:37:36:WU00:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
19:42:46:WU00:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
19:47:56:WU00:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
19:53:06:WU00:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
19:58:16:WU00:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
20:03:26:WU00:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
20:08:36:WU00:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
20:13:46:WU00:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
20:18:56:WU00:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
20:24:06:WU00:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
20:29:15:WU00:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
20:34:26:WU00:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
20:39:36:WU00:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
20:44:46:WU00:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
20:49:56:WU00:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
20:55:06:WU00:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
21:00:16:WU00:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
21:05:25:WU00:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
21:10:34:WU00:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
21:15:44:WU00:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
21:20:53:WU00:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
21:26:03:WU00:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
21:31:13:WU00:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
21:36:23:WU00:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
21:41:34:WU00:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
21:46:43:WU00:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
21:51:53:WU00:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
21:57:02:WU00:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
22:02:11:WU00:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
22:07:21:WU00:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
22:12:30:WU00:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
22:17:40:WU00:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
22:22:49:WU00:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
22:27:58:WU00:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
22:33:08:WU00:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
22:38:17:WU00:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
22:38:18:WU02:FS00:Connecting to 171.67.108.45:80
22:38:19:WU02:FS00:Assigned to work server 171.67.108.52
22:38:19:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Pitcairn PRO [Radeon HD 7800 Series] from 171.67.108.52
22:38:19:WU02:FS00:Connecting to 171.67.108.52:8080
22:38:21:WU02:FS00:Downloading 1.52MiB
22:38:27:WU02:FS00:Download 98.43%
22:38:29:WU02:FS00:Download complete
22:38:29:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9201 run:974 clone:0 gen:685 core:0x17 unit:0x000004156652edc45399fc52486ce112
22:43:27:WU00:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
22:43:31:WU00:FS00:0x17:Saving result file logfile_01.txt
22:43:31:WU00:FS00:0x17:Saving result file checkpointState.xml
22:43:31:WU00:FS00:0x17:Saving result file checkpt.crc
22:43:31:WU00:FS00:0x17:Saving result file log.txt
22:43:31:WU00:FS00:0x17:Saving result file positions.xtc
22:43:33:WU00:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
22:43:33:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:43:33:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:700 clone:3 gen:471 core:0x17 unit:0x000002c96652edc45399f194bc0ac937
22:43:33:WU00:FS00:Uploading 8.38MiB to 171.67.108.52
22:43:33:WU00:FS00:Connecting to 171.67.108.52:8080
22:43:33:WU02:FS00:Starting
22:43:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 704 -lifeline 5100 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:43:33:WU02:FS00:Started FahCore on PID 3460
22:43:33:WU02:FS00:Core PID:3136
22:43:33:WU02:FS00:FahCore 0x17 started
22:43:34:WU02:FS00:0x17:*********************** Log Started 2015-12-05T22:43:33Z ***********************
22:43:34:WU02:FS00:0x17:Project: 9201 (Run 974, Clone 0, Gen 685)
22:43:34:WU02:FS00:0x17:Unit: 0x000004156652edc45399fc52486ce112
22:43:34:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
22:43:34:WU02:FS00:0x17:Machine: 0
22:43:34:WU02:FS00:0x17:Reading tar file state.xml
22:43:34:WU02:FS00:0x17:Reading tar file system.xml
22:43:34:WU02:FS00:0x17:Reading tar file integrator.xml
22:43:34:WU02:FS00:0x17:Reading tar file core.xml
22:43:34:WU02:FS00:0x17:Digital signatures verified
22:43:34:WU02:FS00:0x17:Folding@home GPU core17
22:43:34:WU02:FS00:0x17:Version 0.0.52
22:43:39:WU00:FS00:Upload 13.43%
22:43:45:WU00:FS00:Upload 22.39%
22:43:51:WU00:FS00:Upload 31.34%
22:43:57:WU00:FS00:Upload 41.04%
22:44:00:WU02:FS00:0x17:Completed 0 out of 5000000 steps (0%)
22:44:00:WU02:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:44:03:WU00:FS00:Upload 50.75%
22:44:09:WU00:FS00:Upload 59.70%
22:44:15:WU00:FS00:Upload 69.40%
22:44:21:WU00:FS00:Upload 78.36%
22:44:27:WU00:FS00:Upload 88.06%
22:44:33:WU00:FS00:Upload 97.01%
22:44:42:WU00:FS00:Upload complete
22:44:42:WU00:FS00:Server responded WORK_ACK (400)
22:44:42:WU00:FS00:Final credit estimate, 21207.00 points
22:44:42:WU00:FS00:Cleaning up
22:49:10:WU02:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
22:54:20:WU02:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
22:59:30:WU02:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
23:04:40:WU02:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
23:09:49:WU02:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
23:14:59:WU02:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
23:20:09:WU02:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
23:25:19:WU02:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
23:30:30:WU02:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
23:35:41:WU02:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
23:40:50:WU02:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
23:46:01:WU02:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
23:51:11:WU02:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
23:56:21:WU02:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
00:01:31:WU02:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
00:06:41:WU02:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
00:11:50:WU02:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
00:17:00:WU02:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
00:22:11:WU02:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
00:27:21:WU02:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
00:32:31:WU02:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
00:37:40:WU02:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
00:42:50:WU02:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
00:48:01:WU02:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
00:53:12:WU02:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
00:58:22:WU02:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
01:03:32:WU02:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
01:08:42:WU02:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
01:13:52:WU02:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
01:19:02:WU02:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
01:24:12:WU02:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
01:29:23:WU02:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
01:34:33:WU02:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
01:39:43:WU02:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
01:44:53:WU02:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
01:50:04:WU02:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
01:55:14:WU02:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
02:00:25:WU02:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
02:05:36:WU02:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
02:10:46:WU02:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
02:15:57:WU02:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
02:21:07:WU02:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
02:26:17:WU02:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
02:31:26:WU02:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
02:36:36:WU02:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
02:41:46:WU02:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
02:46:56:WU02:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
02:52:06:WU02:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
02:57:17:WU02:FS00:0x17:Completed 2450000 out of 5000000 steps (49%)
03:02:28:WU02:FS00:0x17:Completed 2500000 out of 5000000 steps (50%)
03:07:38:WU02:FS00:0x17:Completed 2550000 out of 5000000 steps (51%)
03:12:48:WU02:FS00:0x17:Completed 2600000 out of 5000000 steps (52%)
03:17:58:WU02:FS00:0x17:Completed 2650000 out of 5000000 steps (53%)
03:23:08:WU02:FS00:0x17:Completed 2700000 out of 5000000 steps (54%)
03:28:18:WU02:FS00:0x17:Completed 2750000 out of 5000000 steps (55%)
03:33:27:WU02:FS00:0x17:Completed 2800000 out of 5000000 steps (56%)
03:38:38:WU02:FS00:0x17:Completed 2850000 out of 5000000 steps (57%)
******************************* Date: 2015-12-06 *******************************
03:43:48:WU02:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
03:48:58:WU02:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
03:54:06:WU02:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
03:59:15:WU02:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
04:04:25:WU02:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
04:09:34:WU02:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
04:14:42:WU02:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
04:19:51:WU02:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
04:25:00:WU02:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
04:30:09:WU02:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
04:35:18:WU02:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
04:40:26:WU02:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
04:45:35:WU02:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
04:50:43:WU02:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
04:55:52:WU02:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
05:01:01:WU02:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
05:06:09:WU02:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
05:11:18:WU02:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
05:16:27:WU02:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
05:21:36:WU02:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
05:26:44:WU02:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
05:31:54:WU02:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
05:37:03:WU02:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
05:42:11:WU02:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
05:47:20:WU02:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
05:52:29:WU02:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
05:57:38:WU02:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
06:02:46:WU02:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
06:07:55:WU02:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
06:13:03:WU02:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
06:18:12:WU02:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
06:23:19:WU02:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
06:28:27:WU02:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
06:33:36:WU02:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
06:38:44:WU02:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
06:43:53:WU02:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
06:49:02:WU02:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
06:54:10:WU02:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
06:59:20:WU02:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
07:04:29:WU02:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
07:09:37:WU02:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
07:14:46:WU02:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
07:14:48:WU00:FS00:Connecting to 171.67.108.45:80
07:14:49:WU00:FS00:Assigned to work server 171.67.108.52
07:14:49:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Pitcairn PRO [Radeon HD 7800 Series] from 171.67.108.52
07:14:49:WU00:FS00:Connecting to 171.67.108.52:8080
07:14:49:WU00:FS00:Downloading 1.52MiB
07:14:57:WU00:FS00:Download 98.66%
07:15:01:WU00:FS00:Download complete
07:15:01:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9201 run:256 clone:2 gen:515 core:0x17 unit:0x000002f76652edc45399e015dbf5b8e7
07:19:56:WU02:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
07:19:59:WU02:FS00:0x17:Saving result file logfile_01.txt
07:19:59:WU02:FS00:0x17:Saving result file checkpointState.xml
07:20:00:WU02:FS00:0x17:Saving result file checkpt.crc
07:20:00:WU02:FS00:0x17:Saving result file log.txt
07:20:00:WU02:FS00:0x17:Saving result file positions.xtc
07:20:02:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
07:20:02:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:20:02:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9201 run:974 clone:0 gen:685 core:0x17 unit:0x000004156652edc45399fc52486ce112
07:20:02:WU02:FS00:Uploading 8.38MiB to 171.67.108.52
07:20:02:WU02:FS00:Connecting to 171.67.108.52:8080
07:20:02:WU00:FS00:Starting
07:20:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/***/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 5100 -checkpoint 15 -gpu 0 -gpu-vendor ati
07:20:02:WU00:FS00:Started FahCore on PID 7656
07:20:03:WU00:FS00:Core PID:1156
07:20:03:WU00:FS00:FahCore 0x17 started
07:20:04:WU00:FS00:0x17:*********************** Log Started 2015-12-06T07:20:03Z ***********************
07:20:04:WU00:FS00:0x17:Project: 9201 (Run 256, Clone 2, Gen 515)
07:20:04:WU00:FS00:0x17:Unit: 0x000002f76652edc45399e015dbf5b8e7
07:20:04:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
07:20:04:WU00:FS00:0x17:Machine: 0
07:20:04:WU00:FS00:0x17:Reading tar file state.xml
07:20:04:WU00:FS00:0x17:Reading tar file system.xml
07:20:04:WU00:FS00:0x17:Reading tar file integrator.xml
07:20:04:WU00:FS00:0x17:Reading tar file core.xml
07:20:04:WU00:FS00:0x17:Digital signatures verified
07:20:04:WU00:FS00:0x17:Folding@home GPU core17
07:20:04:WU00:FS00:0x17:Version 0.0.52
07:20:08:WU02:FS00:Upload 9.70%
07:20:14:WU02:FS00:Upload 16.41%
07:20:20:WU02:FS00:Upload 25.37%
07:20:26:WU02:FS00:Upload 35.07%
07:20:30:WU00:FS00:0x17:Completed 0 out of 5000000 steps (0%)
07:20:30:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:20:32:WU02:FS00:Upload 44.02%
07:20:38:WU02:FS00:Upload 53.72%
07:20:44:WU02:FS00:Upload 62.67%
07:20:50:WU02:FS00:Upload 72.37%
07:20:56:WU02:FS00:Upload 82.07%
07:21:02:WU02:FS00:Upload 91.03%
07:21:09:WU02:FS00:Upload complete
07:21:09:WU02:FS00:Server responded WORK_QUIT (404)
07:21:09:WARNING:WU02:FS00:Server did not like results, dumping
07:21:10:WU02:FS00:Cleaning up
07:25:29:WU00:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
07:30:29:WU00:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
07:35:30:WU00:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
07:40:30:WU00:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
07:45:31:WU00:FS00:0x17:Completed 250000 out of 5000000 steps (5%)
07:50:31:WU00:FS00:0x17:Completed 300000 out of 5000000 steps (6%)
07:55:31:WU00:FS00:0x17:Completed 350000 out of 5000000 steps (7%)
08:00:31:WU00:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
08:05:31:WU00:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
08:10:32:WU00:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
08:15:32:WU00:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
08:20:33:WU00:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
08:25:33:WU00:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
08:30:33:WU00:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
08:35:33:WU00:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
08:40:34:WU00:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
08:45:34:WU00:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
08:50:35:WU00:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
08:55:36:WU00:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
09:00:38:WU00:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
09:05:39:WU00:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
09:10:40:WU00:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
09:15:41:WU00:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
09:20:42:WU00:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
09:25:43:WU00:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
09:30:44:WU00:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
09:35:46:WU00:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
09:40:47:WU00:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
09:45:48:WU00:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
09:50:49:WU00:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
09:55:50:WU00:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
10:00:51:WU00:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
10:05:53:WU00:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
10:10:54:WU00:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
10:15:55:WU00:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
10:20:56:WU00:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
10:25:57:WU00:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
10:30:59:WU00:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
10:36:00:WU00:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
10:41:01:WU00:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
10:46:03:WU00:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
10:51:07:WU00:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
10:56:09:WU00:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
11:01:12:WU00:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
note: I haven't copied the CPU log also running
I contacted the server owner ... let's wait for his answer.
btupsx
Post by btupsx »
Suspended work slots that are associated with this server until a resolution is found.
btupsx
Post by btupsx »
Any resolution, or no word until the work week?
jadeshi
Pande Group Member
Post by jadeshi »
Apologies for the delay in response. I looked into it and the server seems to be out of space again. Until I can locate some new storage (I have contacted the relevant authorities about this) this'll keep happening. Given this, I'm taking 9201 off FAH for the time being.
btupsx
Post by btupsx »
Thanks for the response, please let us know when 9201s are back in the clear.
btupsx
Post by btupsx »
Looks like 9201s are back in the clear. Let a slot complete, and server accepted.
jadeshi
Pande Group Member
Post by jadeshi »
9201 should be up and running again now.
Mstenholm
Hardware configuration: 4 x GTX 970. Win 7.
Post by Mstenholm »
Do we have a full server for the 9430s as well (171.67.108.46)? I got the same message after completing 9430 (162, 2, 62) today at 17:17:58. This GPU did not fail since the core_21 was updated.
Duce H_K_
Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w
Re: 171.67.108.53 Dumping Multiple Units
Post by Duce H_K_ »
Didn't find a closer topic to my issue :(
01:24:45:WU00:FS00:0x17:Saving result file logfile_01.txt
01:24:45:WU00:FS00:0x17:Saving result file checkpointState.xml
01:24:46:WU00:FS00:0x17:Saving result file checkpt.crc
01:24:46:WU00:FS00:0x17:Saving result file log.txt
01:24:46:WU00:FS00:0x17:Saving result file positions.xtc
01:24:48:WU00:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
01:24:48:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:24:48:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9201 run:142 clone:91 gen:0 core:0x17 unit:0x0000000b6652edc5566bc7f6f9331777
01:24:48:WU00:FS00:Uploading 8.39MiB to 171.67.108.53
01:24:48:WU00:FS00:Connecting to 171.67.108.53:8080
01:24:54:WU00:FS00:Upload 78.26%
01:24:56:WU00:FS00:Upload complete
01:24:56:WU00:FS00:Server responded WORK_QUIT (404)
01:24:56:WARNING:WU00:FS00:Server did not like results, dumping
01:24:57:WU00:FS00:Cleaning up
