Im having problems with usage dropout
sic
Post by sic »
It stays 100 then drops to 0 and then back to 100, i have a amd 390 with new crimson drivers, tho it did the same thing with older drivers as well. Any ideas of how to stop it?
Re: Im having problems with usage dropout
This may be normal. The newer GPU folding cores - 17, 18 & 21 - all pause periodically to write a checkpoint and also run a data validation on the WU in progress using the CPU. If this is the case, then you do not need to do anything.
Otherwise more information would be needed from you about your setup. One place to start is by posting the first 100 or so lines of the log file. Directions for locating and posting the file can be found under the Welcome topic - viewtopic.php?f=81&t=26036.
sic
Post by sic »
*********************** Log Started 2015-11-29T06:03:53Z ***********************
06:03:53:************************* Folding@home Client *************************
06:03:53:      Website: http://folding.stanford.edu/
06:03:53:    Copyright: (c) 2009-2014 Stanford University
06:03:53:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:03:53:         Args:
06:03:53:       Config: C:/Users/ben/AppData/Roaming/FAHClient/config.xml
06:03:53:******************************** Build ********************************
06:03:53:      Version: 7.4.4
06:03:53:         Date: Mar 4 2014
06:03:53:         Time: 20:26:54
06:03:53:      SVN Rev: 4130
06:03:53:       Branch: fah/trunk/client
06:03:53:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:03:53:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:03:53:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:03:53:     Platform: win32 XP
06:03:53:         Bits: 32
06:03:53:         Mode: Release
06:03:53:******************************* System ********************************
06:03:53:          CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
06:03:53:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:03:53:         CPUs: 4
06:03:53:       Memory: 11.87GiB
06:03:53:  Free Memory: 10.71GiB
06:03:53:      Threads: WINDOWS_THREADS
06:03:53:   OS Version: 6.1
06:03:53:  Has Battery: false
06:03:53:   On Battery: false
06:03:53:   UTC Offset: -5
06:03:53:          PID: 2156
06:03:53:          CWD: C:/Users/ben/AppData/Roaming/FAHClient
06:03:53:           OS: Windows 7 Home Premium
06:03:53:      OS Arch: AMD64
06:03:53:         GPUs: 1
06:03:53:        GPU 0: ATI:5 Hawaii [Radeon R9 200/300 Series]
06:03:53:         CUDA: Not detected
06:03:53:Win32 Service: false
06:03:53:***********************************************************************
06:03:53:<config>
06:03:53:  <!-- Folding Core -->
06:03:53:  <core-priority v='low'/>
06:03:53:
06:03:53:  <!-- Folding Slot Configuration -->
06:03:53:  <cause v='PARKINSONS'/>
06:03:53:
06:03:53:  <!-- Network -->
06:03:53:  <proxy v=':8080'/>
06:03:53:
06:03:53:  <!-- Slot Control -->
06:03:53:  <power v='full'/>
06:03:53:
06:03:53:  <!-- User Information -->
06:03:53:  <passkey v='********************************'/>
06:03:53:  <team v='165'/>
06:03:53:  <user v='P.Henry'/>
06:03:53:
06:03:53:  <!-- Folding Slots -->
06:03:53:  <slot id='0' type='GPU'/>
06:03:53:</config>
06:03:53:Trying to access database...
06:03:53:Successfully acquired database lock
06:03:54:Enabled folding slot 00: READY gpu:0:Hawaii [Radeon R9 200/300 Series]
06:03:56:WU00:FS00:Starting
06:03:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ben/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 704 -lifeline 2156 -checkpoint 15 -gpu 0 -gpu-vendor ati
06:03:56:WU00:FS00:Started FahCore on PID 2288
06:03:56:WU00:FS00:Core PID:696
06:03:56:WU00:FS00:FahCore 0x17 started
06:03:57:WU00:FS00:0x17:*********************** Log Started 2015-11-29T06:03:57Z ***********************
06:03:57:WU00:FS00:0x17:Project: 10469 (Run 0, Clone 482, Gen 169)
06:03:57:WU00:FS00:0x17:Unit: 0x00000127538b3db9538f4547b50e5a73
06:03:57:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
06:03:57:WU00:FS00:0x17:Machine: 0
06:03:57:WU00:FS00:0x17:Digital signatures verified
06:03:57:WU00:FS00:0x17:Folding@home GPU core17
06:03:57:WU00:FS00:0x17:Version 0.0.52
06:04:00:WU00:FS00:0x17:  Found a checkpoint file
06:06:35:WU00:FS00:0x17:Completed 375000 out of 5000000 steps (7%)
06:06:35:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:09:28:WU00:FS00:0x17:Completed 400000 out of 5000000 steps (8%)
06:14:51:WU00:FS00:0x17:Completed 450000 out of 5000000 steps (9%)
06:20:15:WU00:FS00:0x17:Completed 500000 out of 5000000 steps (10%)
06:25:51:WU00:FS00:0x17:Completed 550000 out of 5000000 steps (11%)
06:31:14:WU00:FS00:0x17:Completed 600000 out of 5000000 steps (12%)
06:36:51:WU00:FS00:0x17:Completed 650000 out of 5000000 steps (13%)
06:42:14:WU00:FS00:0x17:Completed 700000 out of 5000000 steps (14%)
06:47:38:WU00:FS00:0x17:Completed 750000 out of 5000000 steps (15%)
06:53:14:WU00:FS00:0x17:Completed 800000 out of 5000000 steps (16%)
06:58:37:WU00:FS00:0x17:Completed 850000 out of 5000000 steps (17%)
07:04:13:WU00:FS00:0x17:Completed 900000 out of 5000000 steps (18%)
07:09:37:WU00:FS00:0x17:Completed 950000 out of 5000000 steps (19%)
07:15:00:WU00:FS00:0x17:Completed 1000000 out of 5000000 steps (20%)
07:20:36:WU00:FS00:0x17:Completed 1050000 out of 5000000 steps (21%)
07:26:00:WU00:FS00:0x17:Completed 1100000 out of 5000000 steps (22%)
07:31:36:WU00:FS00:0x17:Completed 1150000 out of 5000000 steps (23%)
07:36:59:WU00:FS00:0x17:Completed 1200000 out of 5000000 steps (24%)
07:42:23:WU00:FS00:0x17:Completed 1250000 out of 5000000 steps (25%)
07:47:59:WU00:FS00:0x17:Completed 1300000 out of 5000000 steps (26%)
07:53:22:WU00:FS00:0x17:Completed 1350000 out of 5000000 steps (27%)
07:58:59:WU00:FS00:0x17:Completed 1400000 out of 5000000 steps (28%)
08:04:21:WU00:FS00:0x17:Completed 1450000 out of 5000000 steps (29%)
08:09:45:WU00:FS00:0x17:Completed 1500000 out of 5000000 steps (30%)
08:15:21:WU00:FS00:0x17:Completed 1550000 out of 5000000 steps (31%)
08:20:44:WU00:FS00:0x17:Completed 1600000 out of 5000000 steps (32%)
08:26:21:WU00:FS00:0x17:Completed 1650000 out of 5000000 steps (33%)
08:31:44:WU00:FS00:0x17:Completed 1700000 out of 5000000 steps (34%)
08:37:08:WU00:FS00:0x17:Completed 1750000 out of 5000000 steps (35%)
08:42:45:WU00:FS00:0x17:Completed 1800000 out of 5000000 steps (36%)
08:48:08:WU00:FS00:0x17:Completed 1850000 out of 5000000 steps (37%)
08:53:45:WU00:FS00:0x17:Completed 1900000 out of 5000000 steps (38%)
08:59:08:WU00:FS00:0x17:Completed 1950000 out of 5000000 steps (39%)
09:04:32:WU00:FS00:0x17:Completed 2000000 out of 5000000 steps (40%)
09:10:08:WU00:FS00:0x17:Completed 2050000 out of 5000000 steps (41%)
09:15:32:WU00:FS00:0x17:Completed 2100000 out of 5000000 steps (42%)
09:21:08:WU00:FS00:0x17:Completed 2150000 out of 5000000 steps (43%)
09:26:32:WU00:FS00:0x17:Completed 2200000 out of 5000000 steps (44%)
09:31:56:WU00:FS00:0x17:Completed 2250000 out of 5000000 steps (45%)
09:37:33:WU00:FS00:0x17:Completed 2300000 out of 5000000 steps (46%)
09:42:56:WU00:FS00:0x17:Completed 2350000 out of 5000000 steps (47%)
09:48:33:WU00:FS00:0x17:Completed 2400000 out of 5000000 steps (48%)
09:53:56:WU00:FS00:0x17:Completed 2450000 out of 5000000 steps (49%)
09:59:20:WU00:FS00:0x17:Completed 2500000 out of 5000000 steps (50%)
10:04:56:WU00:FS00:0x17:Completed 2550000 out of 5000000 steps (51%)
10:10:20:WU00:FS00:0x17:Completed 2600000 out of 5000000 steps (52%)
10:15:56:WU00:FS00:0x17:Completed 2650000 out of 5000000 steps (53%)
10:21:20:WU00:FS00:0x17:Completed 2700000 out of 5000000 steps (54%)
10:26:44:WU00:FS00:0x17:Completed 2750000 out of 5000000 steps (55%)
10:32:20:WU00:FS00:0x17:Completed 2800000 out of 5000000 steps (56%)
10:37:44:WU00:FS00:0x17:Completed 2850000 out of 5000000 steps (57%)
10:43:20:WU00:FS00:0x17:Completed 2900000 out of 5000000 steps (58%)
10:48:44:WU00:FS00:0x17:Completed 2950000 out of 5000000 steps (59%)
10:54:08:WU00:FS00:0x17:Completed 3000000 out of 5000000 steps (60%)
10:59:44:WU00:FS00:0x17:Completed 3050000 out of 5000000 steps (61%)
11:05:08:WU00:FS00:0x17:Completed 3100000 out of 5000000 steps (62%)
11:10:44:WU00:FS00:0x17:Completed 3150000 out of 5000000 steps (63%)
11:16:08:WU00:FS00:0x17:Completed 3200000 out of 5000000 steps (64%)
11:21:31:WU00:FS00:0x17:Completed 3250000 out of 5000000 steps (65%)
11:27:08:WU00:FS00:0x17:Completed 3300000 out of 5000000 steps (66%)
11:32:31:WU00:FS00:0x17:Completed 3350000 out of 5000000 steps (67%)
11:38:08:WU00:FS00:0x17:Completed 3400000 out of 5000000 steps (68%)
11:43:32:WU00:FS00:0x17:Completed 3450000 out of 5000000 steps (69%)
11:48:55:WU00:FS00:0x17:Completed 3500000 out of 5000000 steps (70%)
11:54:32:WU00:FS00:0x17:Completed 3550000 out of 5000000 steps (71%)
11:59:56:WU00:FS00:0x17:Completed 3600000 out of 5000000 steps (72%)
******************************* Date: 2015-11-29 *******************************
12:05:32:WU00:FS00:0x17:Completed 3650000 out of 5000000 steps (73%)
12:10:56:WU00:FS00:0x17:Completed 3700000 out of 5000000 steps (74%)
12:16:19:WU00:FS00:0x17:Completed 3750000 out of 5000000 steps (75%)
12:21:56:WU00:FS00:0x17:Completed 3800000 out of 5000000 steps (76%)
12:27:19:WU00:FS00:0x17:Completed 3850000 out of 5000000 steps (77%)
12:32:56:WU00:FS00:0x17:Completed 3900000 out of 5000000 steps (78%)
12:38:19:WU00:FS00:0x17:Completed 3950000 out of 5000000 steps (79%)
12:43:43:WU00:FS00:0x17:Completed 4000000 out of 5000000 steps (80%)
12:49:19:WU00:FS00:0x17:Completed 4050000 out of 5000000 steps (81%)
12:54:43:WU00:FS00:0x17:Completed 4100000 out of 5000000 steps (82%)
13:00:19:WU00:FS00:0x17:Completed 4150000 out of 5000000 steps (83%)
13:05:43:WU00:FS00:0x17:Completed 4200000 out of 5000000 steps (84%)
13:11:06:WU00:FS00:0x17:Completed 4250000 out of 5000000 steps (85%)
13:16:43:WU00:FS00:0x17:Completed 4300000 out of 5000000 steps (86%)
13:22:07:WU00:FS00:0x17:Completed 4350000 out of 5000000 steps (87%)
13:27:43:WU00:FS00:0x17:Completed 4400000 out of 5000000 steps (88%)
13:33:07:WU00:FS00:0x17:Completed 4450000 out of 5000000 steps (89%)
13:38:31:WU00:FS00:0x17:Completed 4500000 out of 5000000 steps (90%)
13:44:07:WU00:FS00:0x17:Completed 4550000 out of 5000000 steps (91%)
13:49:31:WU00:FS00:0x17:Completed 4600000 out of 5000000 steps (92%)
13:55:12:WU00:FS00:0x17:Completed 4650000 out of 5000000 steps (93%)
14:00:39:WU00:FS00:0x17:Completed 4700000 out of 5000000 steps (94%)
14:06:03:WU00:FS00:0x17:Completed 4750000 out of 5000000 steps (95%)
14:11:40:WU00:FS00:0x17:Completed 4800000 out of 5000000 steps (96%)
14:17:04:WU00:FS00:0x17:Completed 4850000 out of 5000000 steps (97%)
14:22:40:WU00:FS00:0x17:Completed 4900000 out of 5000000 steps (98%)
14:28:04:WU00:FS00:0x17:Completed 4950000 out of 5000000 steps (99%)
14:33:28:WU00:FS00:0x17:Completed 5000000 out of 5000000 steps (100%)
14:33:29:WU01:FS00:Connecting to 171.67.108.45:80
14:33:30:WU01:FS00:Assigned to work server 171.67.108.52
14:33:30:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Hawaii [Radeon R9 200/300 Series] from 171.67.108.52
14:33:30:WU01:FS00:Connecting to 171.67.108.52:8080
14:33:30:WU01:FS00:Downloading 1.52MiB
14:33:32:WU01:FS00:Download complete
14:33:32:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9201 run:509 clone:2 gen:546 core:0x17 unit:0x0000032d6652edc45399ea0dc7931e3f
14:33:41:WU00:FS00:0x17:Saving result file logfile_01.txt
14:33:42:WU00:FS00:0x17:Saving result file checkpointState.xml
14:33:43:WU00:FS00:0x17:Saving result file checkpt.crc
14:33:43:WU00:FS00:0x17:Saving result file log.txt
14:33:43:WU00:FS00:0x17:Saving result file positions.xtc
14:33:46:WU00:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
14:33:46:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:33:46:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10469 run:0 clone:482 gen:169 core:0x17 unit:0x00000127538b3db9538f4547b50e5a73
14:33:46:WU00:FS00:Uploading 15.04MiB to 140.163.4.233
14:33:46:WU01:FS00:Starting
14:33:46:WU00:FS00:Connecting to 140.163.4.233:8080
14:33:46:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/ben/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 704 -lifeline 2156 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:33:46:WU01:FS00:Started FahCore on PID 3704
14:33:46:WU01:FS00:Core PID:2760
14:33:46:WU01:FS00:FahCore 0x17 started
14:33:47:WU01:FS00:0x17:*********************** Log Started 2015-11-29T14:33:46Z ***********************
14:33:47:WU01:FS00:0x17:Project: 9201 (Run 509, Clone 2, Gen 546)
14:33:47:WU01:FS00:0x17:Unit: 0x0000032d6652edc45399ea0dc7931e3f
14:33:47:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:33:47:WU01:FS00:0x17:Machine: 0
14:33:47:WU01:FS00:0x17:Reading tar file state.xml
14:33:47:WU01:FS00:0x17:Reading tar file system.xml
14:33:47:WU01:FS00:0x17:Reading tar file integrator.xml
14:33:47:WU01:FS00:0x17:Reading tar file core.xml
14:33:47:WU01:FS00:0x17:Digital signatures verified
14:33:47:WU01:FS00:0x17:Folding@home GPU core17
14:33:47:WU01:FS00:0x17:Version 0.0.52
14:33:52:WU00:FS00:Upload 8.73%
14:33:58:WU00:FS00:Upload 17.46%
14:34:04:WU00:FS00:Upload 26.60%
14:34:08:WU01:FS00:0x17:Completed 0 out of 5000000 steps (0%)
14:34:08:WU01:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:34:10:WU00:FS00:Upload 35.74%
14:34:16:WU00:FS00:Upload 44.88%
14:34:22:WU00:FS00:Upload 53.61%
14:34:28:WU00:FS00:Upload 62.76%
14:34:34:WU00:FS00:Upload 71.07%
14:34:40:WU00:FS00:Upload 79.38%
14:34:46:WU00:FS00:Upload 88.52%
14:34:52:WU00:FS00:Upload 97.67%
14:35:04:WU00:FS00:Upload complete
14:35:04:WU00:FS00:Server responded WORK_ACK (400)
14:35:04:WU00:FS00:Final credit estimate, 85357.00 points
Mod edit: added Code tags to log
I don't see any issues with the setup or processing looking at the information in the log. The TPF appears to be fairly consistent throughout, about 5:30 on average leading to a PPD of approximately 228K. Someone with an AMD 390 would have to comment on how that compares.
So, as I mentioned earlier, if the drop in GPU utilization happens in a periodic manner that coincides with processing a consistent percentage of the WU, it is normal. While doing the validation steps and checkpoint creation the processing is done on your CPU, and the GPU will be idle for a short period.
If monitoring shows this happening more frequently, it might be related to data being transferred to the GPU for processing. Or it could point to your GPU being throttled for other reasons.
