p9206 (Run 0, Clone 2091, Gen 4) BadWU (114 = 0x72)
parkut
Post by parkut »
Ubuntu 12.04 Linux - Model Name: NVIDIA:5 GM204 [GeForce GTX 970]
Client Version: 7.4.4 - Core: FahCore_21.exe - Core Version: 0.0.12
Driver Version: 352.41 - Gpu temp: 71C
No Client-Type Flags set
Bad State on startup, then 2 more at 100%
17:33:18:WU00:FS01:0x21:*********************** Log Started 2015-11-19T17:33:18Z ***********************
17:33:18:WU00:FS01:0x21:Project: 9206 (Run 0, Clone 2091, Gen 4)
17:33:18:WU00:FS01:0x21:Unit: 0x00000014664f2dd05638204ff7719977
17:33:18:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
17:33:18:WU00:FS01:0x21:Machine: 1
17:33:18:WU00:FS01:0x21:Reading tar file core.xml
17:33:18:WU00:FS01:0x21:Reading tar file system.xml
17:33:19:WU00:FS01:0x21:Reading tar file integrator.xml
17:33:19:WU00:FS01:0x21:Reading tar file state.xml
17:33:20:WU00:FS01:0x21:Digital signatures verified
17:33:20:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
17:33:20:WU00:FS01:0x21:Version 0.0.12
17:34:13:WU00:FS01:0x21:Completed 0 out of 2500000 steps (0%)
17:34:13:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:34:21:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint
17:40:15:WU00:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
17:46:09:WU00:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
17:52:03:WU00:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
17:57:57:WU00:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
- - snip - -
03:14:21:WU00:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
03:20:16:WU00:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
03:26:12:WU00:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
03:32:07:WU00:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
03:32:19:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint
03:38:14:WU00:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
03:44:09:WU00:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
03:50:05:WU00:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
03:56:01:WU00:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
03:56:13:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint
03:56:13:WU00:FS01:0x21:Max number of retries reached. Aborting.
03:56:13:WU00:FS01:0x21:ERROR:Max Retries Reached
03:56:13:WU00:FS01:0x21:Saving result file logfile_01.txt
03:56:13:WU00:FS01:0x21:Saving result file log.txt
03:56:13:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:56:13:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:56:13:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9206 run:0 clone:2091 gen:4 core:0x21 unit:0x00000014664f2dd05638204ff7719977
03:56:13:WU00:FS01:Uploading 3.27KiB to 171.64.65.104
03:56:13:WU00:FS01:Connecting to 171.64.65.104:8080
03:56:13:WU00:FS01:Upload complete
03:56:13:WU00:FS01:Server responded WORK_ACK (400)
03:56:13:WU00:FS01:Cleaning up
Re: p9206 (Run 0, Clone 2091, Gen 4) BadWU (114 = 0x72)
This one is weird ... it's been attempted by 5 people who all failed to complete it pretty quickly (0 points awarded). You're the 6th attempt and almost completed it (it failed the final sanity check twice), but you've bee awarded credit for it :
Hi parkut (team 4),
Your WU (P9206 R0 C2091 G4) was added to the stats database on 2015-11-19 20:06:30 for 24400 points of credit.
I've reported this WU to the project owner ... maybe there's something interesting to learn from its weird behaviour.
