What can my GPU Do/
What can my GPU Do/
all I know is I have AMD RAEDon6350 but I dont know how many points i can fold with it
Ricky
- Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system. - Location: New Mexico
Re: What can my GPU Do/
frod_haya,
I looked online at the specifications for this graphics card. I could not find evidence of CUDA cores present in the processor. I suspect that it would not be utilized by the FAH client for folding.
artoar_11
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
https://en.wikipedia.org/wiki/Radeon_HD ... .29_Series
Northern Islands (HD 6xxx) Series
All models support DirectX 11.0, OpenGL 4.3, OpenCL 1.2
Radeon HD 6350:
Config core: 80:8:4 (80 Unified shaders)
Memory Size: 512 MiB/DDR3/64 bit
This is a very, very slow GPU.
Radeon HD 6350:
I wouldn't fold on such a poor GPU
OpenCL 1.2 suggests that it's POSSIBLE to use if for folding.
80 shaders means you probably will not meet the deadlines.
[I've tried to use 80-shader GPUs and have decided it too much work for any benefit that might accrue -- except if it can be used for video only and there's a second, more powerful GPU in the system that can fold.]
