Core21 upgrade from 0.0.11 to 0.0.12 and now many fauls.
ChrisSpeaker
Post by ChrisSpeaker »
Everything was working great for a couple of months under Arch Linux with both core17 and core21 (v0.0.11) however since
Core21 upgraded from version 0.0.11 to 0.0.12 and now I have many faulty projects. Log as follows:
08:30:14:WU02:FS00:Connecting to 171.67.108.45:80
08:30:15:WU02:FS00:Assigned to work server 171.64.65.104
08:30:15:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Cayman XT [Radeon HD 6900 Series] from 171.64.65.104
08:30:15:WU02:FS00:Connecting to 171.64.65.104:8080
08:30:15:WU02:FS00:Downloading 10.04MiB
08:30:20:WU02:FS00:Download complete
08:30:20:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9212 run:0 clone:21 gen:41 core:0x21 unit:0x00000041664f2dd055ee436a2e83e959
08:40:11:WU01:FS01:0x21:Completed 1460000 out of 2000000 steps (73%)
08:42:52:WU00:FS00:0x21:Completed 2000000 out of 2000000 steps (100%)
08:43:11:WU00:FS00:0x21:Saving result file logfile_01.txt
08:43:11:WU00:FS00:0x21:Saving result file checkpointState.xml
08:43:11:WU00:FS00:0x21:Saving result file checkpt.crc
08:43:11:WU00:FS00:0x21:Saving result file log.txt
08:43:11:WU00:FS00:0x21:Saving result file positions.xtc
08:43:11:WU00:FS00:0x21:Folding@home Core Shutdown: FINISHED_UNIT
08:43:12:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:43:12:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9641 run:1 clone:26 gen:28 core:0x21 unit:0x00000025ab436c9b5609bee4b27faaeb
08:43:12:WU00:FS00:Uploading 19.20MiB to 171.67.108.155
08:43:12:WU00:FS00:Connecting to 171.67.108.155:8080
08:43:12:WU02:FS00:Starting
08:43:12:WU02:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:43:12:WU02:FS00:Started FahCore on PID 19638
08:43:12:WU02:FS00:Core PID:19642
08:43:12:WU02:FS00:FahCore 0x21 started
08:43:12:WU02:FS00:0x21:*********************** Log Started 2015-11-10T08:43:12Z ***********************
08:43:12:WU02:FS00:0x21:Project: 9212 (Run 0, Clone 21, Gen 41)
08:43:12:WU02:FS00:0x21:Unit: 0x00000041664f2dd055ee436a2e83e959
08:43:12:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
08:43:12:WU02:FS00:0x21:Machine: 0
08:43:12:WU02:FS00:0x21:Reading tar file core.xml
08:43:12:WU02:FS00:0x21:Reading tar file system.xml
08:43:14:WU02:FS00:0x21:Reading tar file integrator.xml
08:43:14:WU02:FS00:0x21:Reading tar file state.xml
08:43:16:WU02:FS00:0x21:Digital signatures verified
08:43:16:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
08:43:16:WU02:FS00:0x21:Version 0.0.12
08:43:18:WU00:FS00:Upload 21.81%
08:43:24:WU00:FS00:Upload 43.94%
08:43:30:WU00:FS00:Upload 66.39%
08:43:36:WU00:FS00:Upload 88.20%
08:43:39:WU00:FS00:Upload complete
08:43:39:WU00:FS00:Server responded WORK_ACK (400)
08:43:39:WU00:FS00:Final credit estimate, 16181.00 points
08:43:39:WU00:FS00:Cleaning up
08:43:58:WU02:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
08:43:58:WU02:FS00:0x21:Saving result file logfile_01.txt
08:43:58:WU02:FS00:0x21:Saving result file log.txt
08:43:58:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
08:43:58:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:43:58:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9212 run:0 clone:21 gen:41 core:0x21 unit:0x00000041664f2dd055ee436a2e83e959
08:43:58:WU02:FS00:Uploading 2.43KiB to 171.64.65.104
08:43:58:WU02:FS00:Connecting to 171.64.65.104:8080
08:43:58:WU02:FS00:Upload complete
08:43:58:WU02:FS00:Server responded WORK_ACK (400)
08:43:58:WU02:FS00:Cleaning up
08:43:58:WU00:FS00:Connecting to 171.67.108.45:80
08:43:59:WU00:FS00:Assigned to work server 171.64.65.104
08:43:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Cayman XT [Radeon HD 6900 Series] from 171.64.65.104
08:43:59:WU00:FS00:Connecting to 171.64.65.104:8080
08:44:00:WU00:FS00:Downloading 10.04MiB
08:44:05:WU00:FS00:Download complete
08:44:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9208 run:0 clone:42 gen:22 core:0x21 unit:0x0000003b664f2dd055edd3759272afbc
08:44:05:WU00:FS00:Starting
08:44:05:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:44:05:WU00:FS00:Started FahCore on PID 19648
08:44:05:WU00:FS00:Core PID:19652
08:44:05:WU00:FS00:FahCore 0x21 started
08:44:06:WU00:FS00:0x21:*********************** Log Started 2015-11-10T08:44:05Z ***********************
08:44:06:WU00:FS00:0x21:Project: 9208 (Run 0, Clone 42, Gen 22)
08:44:06:WU00:FS00:0x21:Unit: 0x0000003b664f2dd055edd3759272afbc
08:44:06:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
08:44:06:WU00:FS00:0x21:Machine: 0
08:44:06:WU00:FS00:0x21:Reading tar file core.xml
08:44:06:WU00:FS00:0x21:Reading tar file system.xml
08:44:07:WU00:FS00:0x21:Reading tar file integrator.xml
08:44:07:WU00:FS00:0x21:Reading tar file state.xml
08:44:09:WU00:FS00:0x21:Digital signatures verified
08:44:09:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
08:44:09:WU00:FS00:0x21:Version 0.0.12
08:44:50:WU00:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
08:44:50:WU00:FS00:0x21:Saving result file logfile_01.txt
08:44:50:WU00:FS00:0x21:Saving result file log.txt
08:44:50:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
08:44:51:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:44:51:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9208 run:0 clone:42 gen:22 core:0x21 unit:0x0000003b664f2dd055edd3759272afbc
08:44:51:WU00:FS00:Uploading 2.45KiB to 171.64.65.104
08:44:51:WU00:FS00:Connecting to 171.64.65.104:8080
08:44:51:WU00:FS00:Upload complete
08:44:51:WU00:FS00:Server responded WORK_ACK (400)
08:44:51:WU02:FS00:Connecting to 171.67.108.45:80
08:44:51:WU00:FS00:Cleaning up
08:44:52:WU02:FS00:Assigned to work server 171.64.65.104
08:44:52:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Cayman XT [Radeon HD 6900 Series] from 171.64.65.104
08:44:52:WU02:FS00:Connecting to 171.64.65.104:8080
08:44:53:WU02:FS00:Downloading 10.03MiB
08:44:58:WU02:FS00:Download complete
08:44:58:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9210 run:0 clone:54 gen:5 core:0x21 unit:0x00000012664f2dd055ee0bae9c3f0236
08:44:58:WU02:FS00:Starting
08:44:58:WU02:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:44:58:WU02:FS00:Started FahCore on PID 19657
08:44:58:WU02:FS00:Core PID:19661
08:44:58:WU02:FS00:FahCore 0x21 started
08:44:59:WU02:FS00:0x21:*********************** Log Started 2015-11-10T08:44:58Z ***********************
08:44:59:WU02:FS00:0x21:Project: 9210 (Run 0, Clone 54, Gen 5)
08:44:59:WU02:FS00:0x21:Unit: 0x00000012664f2dd055ee0bae9c3f0236
08:44:59:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
08:44:59:WU02:FS00:0x21:Machine: 0
08:44:59:WU02:FS00:0x21:Reading tar file core.xml
08:44:59:WU02:FS00:0x21:Reading tar file system.xml
08:45:00:WU02:FS00:0x21:Reading tar file integrator.xml
08:45:00:WU02:FS00:0x21:Reading tar file state.xml
08:45:02:WU02:FS00:0x21:Digital signatures verified
08:45:02:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
08:45:02:WU02:FS00:0x21:Version 0.0.12
08:45:43:WU02:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
08:45:43:WU02:FS00:0x21:Saving result file logfile_01.txt
08:45:43:WU02:FS00:0x21:Saving result file log.txt
08:45:43:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
08:45:44:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:45:44:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9210 run:0 clone:54 gen:5 core:0x21 unit:0x00000012664f2dd055ee0bae9c3f0236
08:45:44:WU02:FS00:Uploading 2.44KiB to 171.64.65.104
08:45:44:WU02:FS00:Connecting to 171.64.65.104:8080
08:45:44:WU00:FS00:Connecting to 171.67.108.45:80
08:45:44:WU02:FS00:Upload complete
08:45:44:WU02:FS00:Server responded WORK_ACK (400)
08:45:44:WU02:FS00:Cleaning up
08:45:45:WU00:FS00:Assigned to work server 171.64.65.104
08:45:45:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Cayman XT [Radeon HD 6900 Series] from 171.64.65.104
08:45:45:WU00:FS00:Connecting to 171.64.65.104:8080
08:45:46:WU00:FS00:Downloading 10.03MiB
08:45:51:WU00:FS00:Download complete
08:45:51:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9213 run:0 clone:59 gen:3 core:0x21 unit:0x0000000f664f2dd055ee6033f0f45126
08:45:51:WU00:FS00:Starting
08:45:51:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:45:51:WU00:FS00:Started FahCore on PID 19668
08:45:51:WU00:FS00:Core PID:19672
08:45:51:WU00:FS00:FahCore 0x21 started
08:45:52:WU00:FS00:0x21:*********************** Log Started 2015-11-10T08:45:51Z ***********************
08:45:52:WU00:FS00:0x21:Project: 9213 (Run 0, Clone 59, Gen 3)
08:45:52:WU00:FS00:0x21:Unit: 0x0000000f664f2dd055ee6033f0f45126
08:45:52:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
08:45:52:WU00:FS00:0x21:Machine: 0
08:45:52:WU00:FS00:0x21:Reading tar file core.xml
08:45:52:WU00:FS00:0x21:Reading tar file system.xml
08:45:53:WU00:FS00:0x21:Reading tar file integrator.xml
08:45:53:WU00:FS00:0x21:Reading tar file state.xml
08:45:55:WU00:FS00:0x21:Digital signatures verified
08:45:55:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
08:45:55:WU00:FS00:0x21:Version 0.0.12
08:46:36:WU00:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
08:46:36:WU00:FS00:0x21:Saving result file logfile_01.txt
08:46:36:WU00:FS00:0x21:Saving result file log.txt
08:46:36:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
08:46:36:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:46:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9213 run:0 clone:59 gen:3 core:0x21 unit:0x0000000f664f2dd055ee6033f0f45126
08:46:36:WU00:FS00:Uploading 2.43KiB to 171.64.65.104
08:46:36:WU00:FS00:Connecting to 171.64.65.104:8080
08:46:37:WU00:FS00:Upload complete
08:46:37:WU00:FS00:Server responded WORK_ACK (400)
08:46:37:WU02:FS00:Connecting to 171.67.108.45:80
08:46:37:WU00:FS00:Cleaning up
08:46:38:WU02:FS00:Assigned to work server 171.64.65.104
08:46:38:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Cayman XT [Radeon HD 6900 Series] from 171.64.65.104
08:46:38:WU02:FS00:Connecting to 171.64.65.104:8080
08:46:38:WU02:FS00:Downloading 10.04MiB
08:46:43:WU02:FS00:Download complete
08:46:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9208 run:0 clone:38 gen:20 core:0x21 unit:0x0000002d664f2dd055edd37c2b2ab85e
08:46:43:WU02:FS00:Starting
08:46:43:WU02:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:46:43:WU02:FS00:Started FahCore on PID 19677
08:46:43:WU02:FS00:Core PID:19681
08:46:43:WU02:FS00:FahCore 0x21 started
08:46:44:WU02:FS00:0x21:*********************** Log Started 2015-11-10T08:46:43Z ***********************
08:46:44:WU02:FS00:0x21:Project: 9208 (Run 0, Clone 38, Gen 20)
08:46:44:WU02:FS00:0x21:Unit: 0x0000002d664f2dd055edd37c2b2ab85e
08:46:44:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
08:46:44:WU02:FS00:0x21:Machine: 0
08:46:44:WU02:FS00:0x21:Reading tar file core.xml
08:46:44:WU02:FS00:0x21:Reading tar file system.xml
08:46:45:WU02:FS00:0x21:Reading tar file integrator.xml
08:46:45:WU02:FS00:0x21:Reading tar file state.xml
08:46:48:WU02:FS00:0x21:Digital signatures verified
08:46:48:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
08:46:48:WU02:FS00:0x21:Version 0.0.12
08:47:28:WU02:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)
08:47:28:WU02:FS00:0x21:Saving result file logfile_01.txt
08:47:28:WU02:FS00:0x21:Saving result file log.txt
08:47:28:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
08:47:29:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:47:29:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9208 run:0 clone:38 gen:20 core:0x21 unit:0x0000002d664f2dd055edd37c2b2ab85e
08:47:29:WU02:FS00:Uploading 2.44KiB to 171.64.65.104
08:47:29:WU02:FS00:Connecting to 171.64.65.104:8080
08:47:29:WU02:FS00:Upload complete
08:47:30:WU02:FS00:Server responded WORK_ACK (400)
08:47:30:WU00:FS00:Connecting to 171.67.108.45:80
08:47:30:WU02:FS00:Cleaning up
08:47:30:WU00:FS00:Assigned to work server 140.163.4.233
08:47:30:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Cayman XT [Radeon HD 6900 Series] from 140.163.4.233
08:47:30:WU00:FS00:Connecting to 140.163.4.233:8080
08:47:31:WU00:FS00:Downloading 4.33MiB
08:47:32:WU00:FS00:Download complete
08:47:33:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10468 run:0 clone:436 gen:243 core:0x17 unit:0x00000192538b3db9538cb58aceaca3d4
08:47:33:WU00:FS00:Starting
08:47:33:WU00:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_17.fah/FahCore_17 -dir 00 -suffix 01 -version 704 -lifeline 1062 -checkpoint 15 -gpu 1 -gpu-vendor ati
08:47:33:WU00:FS00:Started FahCore on PID 19686
08:47:33:WU00:FS00:Core PID:19690
08:47:33:WU00:FS00:FahCore 0x17 started
08:47:33:WU00:FS00:0x17:*********************** Log Started 2015-11-10T08:47:33Z ***********************
08:47:33:WU00:FS00:0x17:Project: 10468 (Run 0, Clone 436, Gen 243)
08:47:33:WU00:FS00:0x17:Unit: 0x00000192538b3db9538cb58aceaca3d4
08:47:33:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
08:47:33:WU00:FS00:0x17:Machine: 0
08:47:33:WU00:FS00:0x17:Reading tar file state.xml
08:47:34:WU00:FS00:0x17:Reading tar file system.xml
08:47:34:WU00:FS00:0x17:Reading tar file integrator.xml
08:47:34:WU00:FS00:0x17:Reading tar file core.xml
08:47:34:WU00:FS00:0x17:Digital signatures verified
08:52:55:WU00:FS00:0x17:Completed 0 out of 5000000 steps (0%)
08:57:34:WU01:FS01:0x21:Completed 1480000 out of 2000000 steps (74%)
09:14:56:WU01:FS01:0x21:Completed 1500000 out of 2000000 steps (75%)
09:19:07:WU00:FS00:0x17:Completed 50000 out of 5000000 steps (1%)
09:32:36:WU01:FS01:0x21:Completed 1520000 out of 2000000 steps (76%)
09:45:04:WU00:FS00:0x17:Completed 100000 out of 5000000 steps (2%)
09:49:57:WU01:FS01:0x21:Completed 1540000 out of 2000000 steps (77%)
10:07:20:WU01:FS01:0x21:Completed 1560000 out of 2000000 steps (78%)
10:11:21:WU00:FS00:0x17:Completed 150000 out of 5000000 steps (3%)
10:24:41:WU01:FS01:0x21:Completed 1580000 out of 2000000 steps (79%)
10:37:18:WU00:FS00:0x17:Completed 200000 out of 5000000 steps (4%)
10:42:04:WU01:FS01:0x21:Completed 1600000 out of 2000000 steps (80%)
I specifically noticed the line "08:45:43:WU02:FS00:0x21:ERROR:exception: Error creating array forceBuffers: clCreateBuffer (-61)". Does this indicate that there is a problem with my drivers?
System Specs:
Intel Core 2 Due 6600
AMD Cayman XT HD 6970
AND Hawaii R7 270
Thanks for any light you can shed in advance.
Re: Core21 upgrade from 0.0.11 to 0.0.12 and now many fauls.
Do you know exactly which card is failing ? Is it the older Cayman or the newer card (note that there is no Hawaii R7 270 ... Hawaii is the chip used in R9 290(X), a R9 270(X) exists with Pitcairn chip or a R7 260X with Bonaire chip) ?
What version of the drivers do you use ?
ChrisSpeaker
Yes it's the older Cayman XT card which is failing it's WU since the core21 upgrade. It's since got a core17 WU and is working fine now.
Driver version is catalyst 15.7.
Side note: AMD Hawaii (as detected by folding at home software) is actually a r7 240. Sorry for any confusion.
Please post the part of the log showing that detection, and it may be able to be updated. However, existing chips that were simply rebranded with a new marketing name may is the source of the issue.
GregC
Post by GregC »
I am reproducing this behavior on the trusty old AMD FirePro V7900 with newest drivers and BIOS, on Windows 10 2004. It's also a TeraScale 3 product from AMD.
I am impressed you got a Core_21 to fail on.
I am less impressed you did not post a log showing the first 200 lines of configuration.
viewtopic.php?f=24&t=26036
Getting the right drivers for older Terascale based cards may be part of your issue. From reports I have seen, AMD may have removed OpenCL support from the most recent video drivers that support your card, so you may need to go back a version or two to get working drivers for your FirePro V7900.
GregC
Post by GregC »
I have all the details and logs at viewtopic.php?f=19&t=35324
In summary: latest driver works without
client-type=advanced
selected, but fails the same way as for OP with advanced option.
GregC wrote:I have all the details and logs at viewtopic.php?f=19&t=35324
Ah, rather than give the information that could help you there, you decided to spam 5 year old posts to cause confusion, I see.
JimboPalmer wrote:Ah, rather than give the information that could help you there, you decided to spam 5 year old posts to cause confusion, I see.
Oh well, he doesn't need our help. Notice that he sees a connetion with the setting client-type=advanced has something to do with his problem just like it did 5 years ago. :shock:
