Failed to get assignment: AS's [CPU projects]
jlp1528
Post by jlp1528 »
I have this same problem, but with my CPU slot. I have an Intel Core i5-6500, which was working fine until I checked it this morning and found the same error - even the same IP address. My cool (in more ways than one) and silent GPU (EVGA nVidia GTX 960) is still chugging away though, which is nice, as that's going to benefit the project much more than any standard CPU ever would.
Anyway, how do I fix this? Also, what is project 10488? I'm completing it just fine, getting points for it and everything, but "A description for this project does not yet exist." It appears to be a range of projects, as I believe I also got a 10487 WU with the same message, though I did once get a 10476 WU which did have a description as part of a group of projects.
jlp1528
Re: Failed to get assignment: AS's [CPU projects]
Post by jlp1528 »
As suggested, I added the following flag to my CPU slot:
Value: beta
This seems to have solved my issue. Strangely enough, however, the "beta" a4 core it downloaded is the same as the "normal" one. When I noticed the files were the same size, I ran them through HashCalc, and their hashes indeed match, so they are in fact the same file.
jlp1528
Post by jlp1528 »
I just read the "beta team info" thread, actually. Interesting. I switched the value to advanced for now.
Your post has been moved to a different topic as it is not related to the problem with older GPU's. Adding the beta flag was only recommended as a way for persons using older pre-Fermi GPU cards to get assignments. Otherwise, unless participating in beta testing the most we can recommend is using the advanced flag.
As for the A4 core, there has not been a beta test of a new version of that core in a few years. What is beta are the newer CPU projects that use it. Use of the beta flag for that purpose is only supported in the Beta Team forum. See this topic about participating - viewtopic.php?f=16&t=8.
If you post the first 100 or so lines of your log using the direction in the Welcome topic - viewtopic.php?f=16&t=26036, we can see how your system is configured and give suggestions on how to get CPU WU's.
I will notify the appropriate persons about the missing project descriptions.
jlp1528
Post by jlp1528 »
Hopefully this is enough info:
*********************** Log Started 2015-11-04T18:00:32Z ***********************
18:00:32:************************* Folding@home Client *************************
18:00:32:      Website: http://folding.stanford.edu/
18:00:32:    Copyright: (c) 2009-2014 Stanford University
18:00:32:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:00:32:         Args:
18:00:32:       Config: C:/ProgramData/FAHClient/config.xml
18:00:32:******************************** Build ********************************
18:00:32:      Version: 7.4.4
18:00:32:         Date: Mar 4 2014
18:00:32:         Time: 20:26:54
18:00:32:      SVN Rev: 4130
18:00:32:       Branch: fah/trunk/client
18:00:32:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:00:32:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:00:32:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:00:32:     Platform: win32 XP
18:00:32:         Bits: 32
18:00:32:         Mode: Release
18:00:32:******************************* System ********************************
18:00:32:          CPU: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
18:00:32:       CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
18:00:32:         CPUs: 4
18:00:32:       Memory: 7.94GiB
18:00:32:  Free Memory: 6.12GiB
18:00:32:      Threads: WINDOWS_THREADS
18:00:32:   OS Version: 6.2
18:00:32:  Has Battery: false
18:00:32:   On Battery: false
18:00:32:   UTC Offset: -6
18:00:32:          PID: 6232
18:00:32:          CWD: C:/ProgramData/FAHClient
18:00:32:           OS: Windows 10 Home
18:00:32:      OS Arch: AMD64
18:00:32:         GPUs: 1
18:00:32:        GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
18:00:32:         CUDA: 5.2
18:00:32:  CUDA Driver: 7050
18:00:32:Win32 Service: false
18:00:32:***********************************************************************
