I've got the ASUS 660 TI with the heat pipes and 3GB of GDDR5 and the boost is set at 1165 MHz, I'd like to know if I can go further without crashing the work units or the system.
So far I'm up to 1185 Mhz on the boost clock!
GTX 660 TI how hard can I overclock it?
GPU timpster
artoar_11
- Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Re: GTX 660 TI how hard can I overclock it?
For guidance only.
https://docs.google.com/spreadsheets/d/ ... /pub?gid=2
VRAM frequency by default. This is not the forum for overclocking.
davidcoton
Newer GPU folding cores are known to be less tolerant of overclocking -- the core already pushes the GPU quite hard and overclocking will often induce errors. If you try it, monitor your logs for problems and back off if the number of errors increases.
