9116 (Run 386, Clone 0, Gen 26) (102 = 0x66)
parkut
Post by parkut »
Model Name: NVIDIA:5 GM206 [GeForce GTX 960] - CntOS Linux system
Driver Version: 352.41 - Gpu temp: 68C - Client Version: 7.3.6
9116 (Run 386, Clone 0, Gen 26) INTERRUPTED (102 = 0x66) at 68%
Restarted, but found a problem with the checkpoint file
ERROR:Guru Meditation #5a8f118d6c1efeed.5e35646f5ca78f19 (10360700.10363450) '02/01/checkpointState.xml'
and :FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:03:29:WU02:FS01:0x18:Project: 9116 (Run 386, Clone 0, Gen 26)
15:03:29:WU02:FS01:0x18:Unit: 0x000000240a3b1e7854c1719e469a4c1e
15:03:29:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
15:03:29:WU02:FS01:0x18:Machine: 1
15:03:29:WU02:FS01:0x18:Reading tar file state.xml
15:03:29:WU02:FS01:0x18:Reading tar file system.xml
15:03:30:WU02:FS01:0x18:Reading tar file integrator.xml
15:03:30:WU02:FS01:0x18:Reading tar file core.xml
15:03:30:WU02:FS01:0x18:Digital signatures verified
15:03:30:WU02:FS01:0x18:Folding@home GPU core18
15:03:30:WU02:FS01:0x18:Version 0.0.4
15:03:41:WU02:FS01:0x18:Completed 0 out of 2500000 steps (0%)
15:03:41:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:06:29:WU02:FS01:0x18:Completed 25000 out of 2500000 steps (1%)
15:09:14:WU02:FS01:0x18:Completed 50000 out of 2500000 steps (2%)
... snip
18:01:31:WU02:FS01:0x18:Completed 1600000 out of 2500000 steps (64%)
18:04:20:WU02:FS01:0x18:Completed 1625000 out of 2500000 steps (65%)
18:07:06:WU02:FS01:0x18:Completed 1650000 out of 2500000 steps (66%)
18:09:52:WU02:FS01:0x18:Completed 1675000 out of 2500000 steps (67%)
18:12:38:WU02:FS01:0x18:Completed 1700000 out of 2500000 steps (68%)
18:12:41:WU02:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:12:41:WU02:FS01:Starting
18:12:41:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 02 -suffix 01 -version 703 -lifeline 1482 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
18:12:41:WU02:FS01:Started FahCore on PID 15714
18:12:41:WU02:FS01:Core PID:15718
18:12:41:WU02:FS01:FahCore 0x18 started
18:12:41:WU02:FS01:0x18:*********************** Log Started 2015-10-29T18:12:41Z ***********************
18:12:41:WU02:FS01:0x18:Project: 9116 (Run 386, Clone 0, Gen 26)
18:12:41:WU02:FS01:0x18:Unit: 0x000000240a3b1e7854c1719e469a4c1e
18:12:41:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
18:12:41:WU02:FS01:0x18:Machine: 1
18:12:41:WU02:FS01:0x18:Digital signatures verified
18:12:41:WU02:FS01:0x18:Folding@home GPU core18
18:12:41:WU02:FS01:0x18:Version 0.0.4
18:12:41:WU02:FS01:0x18:  Found a checkpoint file
18:12:43:WU02:FS01:0x18:ERROR:Guru Meditation #5a8f118d6c1efeed.5e35646f5ca78f19 (10360700.10363450) '02/01/checkpointState.xml'
18:12:43:WU02:FS01:0x18:WARNING:Unexpected exit() call
18:12:43:WU02:FS01:0x18:WARNING:Unexpected exit from science code
18:12:43:WU02:FS01:0x18:Saving result file logfile_01.txt
18:12:43:WU02:FS01:0x18:Saving result file checkpt.crc
18:12:43:WU02:FS01:0x18:Saving result file log.txt
18:12:43:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
18:12:43:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
18:12:43:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9116 run:386 clone:0 gen:26 core:0x18 unit:0x000000240a3b1e7854c1719e469a4c1e[93m
18:12:44:WU02:FS01:Uploading 4.79KiB to 171.64.65.84
18:12:50:WU02:FS01:Upload complete
Re: 9116 (Run 386, Clone 0, Gen 26) (102 = 0x66)
Someone has been able to complete this WU.
