FAHcore 0x21 slows down Windows/NVidia PC
Everything is fine with other types of core (it's mainly 0x18), but with 0x21 everything on my system just becomes slow and laggy. Any way to restrict which core type i'm folding?
My system specs:
gtx980, 4790k
My system specs:
gtx980, 4790k
Re: FAHcore 0x21 slows down my PC
If you've set client-type to Advanced or Beta, remove that setting. If you still have problems, report which WU it is.
Setting idle=true in the GPU slot can help, too.
Please post the information mentioned in my sig.
We need to see the log, it might also be the slowdown bug that leads to bad states detected on GPU ...
bruce wrote:If you've set client-type to Advanced or Beta, remove that setting. If you still have problems, report which WU it is.
I don't know how to check for client-type. If it wasn't set so by default, i don't remember setting it myself.
I set idle=true in gpu slot, but if i understand this correctly, all that this does is idle the folding while PC is in use? I spend a lot of time in front of PC, that's not really an option for me.
I'm on 0x21 again, it's laggy again, even using windows explorer is noticeably slower, especially since i'm on SSD.
WU info: PRCG 9704 (25, 9, 99)
Btw, i removed CPU folding slot. Since i use mainly CPU, and GPU is mostly free when i'm not gaming.
with 0x18 i can even do light gaming, like hearthstone. With 0x21 i can't even browse the web, it's really bad. I have set folding power on Medium.toTOW wrote:We need to see the log, it might also be the slowdown bug that leads to bad states detected on GPU ...
Copied over the log:
16:51:22:Removing old file 'configs/config-20151025-130721.xml'
16:51:22:Saving configuration to config.xml
16:51:22:<config>
16:51:22: <!-- Network -->
16:51:22: <proxy v=':8080'/>
16:51:22:
16:51:22: <!-- User Information -->
16:51:22: <passkey v='********************************'/>
16:51:22: <team v='223518'/>
16:51:22: <user v='Fobus'/>
16:51:22:
16:51:22: <!-- Folding Slots -->
16:51:22: <slot id='1' type='GPU'/>
16:51:22:</config>
16:51:22:WU00:FS01:Starting
16:51:22:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Vaidas/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 7520 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:51:22:WU00:FS01:Started FahCore on PID 11280
16:51:22:WU00:FS01:Core PID:23172
16:51:22:WU00:FS01:FahCore 0x21 started
16:51:22:WU00:FS01:0x21:*********************** Log Started 2015-10-27T16:51:22Z ***********************
16:51:22:WU00:FS01:0x21:Project: 9704 (Run 25, Clone 9, Gen 99)
16:51:22:WU00:FS01:0x21:Unit: 0x0000009fab404162553ebf99afa492a1
16:51:22:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
16:51:22:WU00:FS01:0x21:Machine: 1
16:51:22:WU00:FS01:0x21:Digital signatures verified
16:51:22:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
16:51:22:WU00:FS01:0x21:Version 0.0.11
16:51:22:WU00:FS01:0x21: Found a checkpoint file
16:52:15:Removing old file 'configs/config-20151025-145002.xml'
16:52:15:Saving configuration to config.xml
16:52:15:<config>
16:52:15: <!-- Network -->
16:52:15: <proxy v=':8080'/>
16:52:15:
16:52:15: <!-- User Information -->
16:52:15: <passkey v='********************************'/>
16:52:15: <team v='223518'/>
16:52:15: <user v='Fobus'/>
16:52:15:
16:52:15: <!-- Folding Slots -->
16:52:15: <slot id='1' type='GPU'/>
16:52:15:</config>
16:53:04:WU00:FS01:0x21:Completed 80000 out of 640000 steps (12%)
16:53:04:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:54:27:WU00:FS01:0x21:Completed 83200 out of 640000 steps (13%)
16:55:07:FS01:Paused
16:55:07:FS01:Shutting core down
16:55:07:WU00:FS01:0x21:WARNING:Console control signal 1 on PID 23172
16:55:07:WU00:FS01:0x21:Exiting, please wait. . .
16:55:07:WU00:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
16:55:07:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
16:55:18:Removing old file 'configs/config-20151025-235155.xml'
16:55:18:Saving configuration to config.xml
16:55:18:<config>
16:55:18: <!-- Network -->
16:55:18: <proxy v=':8080'/>
16:55:18:
16:55:18: <!-- User Information -->
16:55:18: <passkey v='********************************'/>
16:55:18: <team v='223518'/>
16:55:18: <user v='Fobus'/>
16:55:18:
16:55:18: <!-- Folding Slots -->
16:55:18: <slot id='1' type='GPU'>
16:55:18: <paused v='true'/>
16:55:18: </slot>
16:55:18:</config>
crop from my system info tab:
The GPU has no operating system to guide it so it has no no sense of priority. The processing required to update the position of the mouse pointer or to echo typed characters on the screen often has to wait for the current FAH compute block to finish -- making updating the screen extremely sluggish. Moving the mouse SHOULD interrupt FAH's GPU processing by having priority, but no such capability exists. The mouse moves quickly only when the GPU is mostly idle hence the recommendation to set idle=true.
There are individual settings in the OS, in your browser, in your video player, etc. which lets you choose whether to use either the GPU or the CPU for screen rendering. They're often called "disable accelerated rendering" or something like that if you want to use your CPU instead. That often helps because the rendering processing CAN get priority on your CPU. Even though an idle GPU would be faster than an interrupted CPU, it's the lack of being able to interrupt the GPU that really matters.
That applies to all GPU and CPU processing. Core_21 is more efficient than Cores_17/_18 so those WUs are more difficult to interrupt.
setting idle is almost the same as pausing for me. It could fold for a few minutes there and here, but that just means i'm not folding core18 when i do use my PC. It would be really nice to have an option to choose which core type to fold, in addition to choosing particular disease. If nothing can be done about core_21, that is.bruce wrote:The GPU has no operating system to guide it so it has no no sense of priority. The processing required to update the position of the mouse pointer or to echo typed characters on the screen often has to wait for the current FAH compute block to finish -- making updating the screen extremely sluggish. Moving the mouse SHOULD interrupt FAH's GPU processing by having priority, but no such capability exists. The mouse moves quickly only when the GPU is mostly idle hence the recommendation to set idle=true.
Each project is developed around a particular FahCore. The projects that are assigned to your client are determined by Stanford, based on the characteristics of your hardware plus certain settings that you can make (such as client-type). You cannot select a specific core.
Core_21 projects are not identical. Which projects have you had trouble with. Are any acceptable? It may be possible to limit certain projects, say just those larger than K atoms or something like that. No such limitation is available today.
It's likely that once a final version of core_21 is released, new projects will no longer be released for core_17 or _18, but that shouldn't change whatever is associated with the lags you've observed (including those which you consider insignificant) or the ultimate performance of proteins similar to the ones you're currently running on _18.
To me, what Fobus is desribing is the slowdown bug : when the frames start to take an hour long, and before a bad state is detected, the UI might be terrible sluggish.
Ricky
- Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system. - Location: New Mexico
I am seeing sluggish video response with Project: 9704 (Run 6, Clone 10, Gen 132). This is folding on a GTX 960, that I use for my monitor.
06:29:38:WU05:FS02:Started FahCore on PID 720
06:29:38:WU05:FS02:Core PID:1464
06:29:38:WU05:FS02:FahCore 0x21 started
06:29:38:WU05:FS02:0x21:*********************** Log Started 2015-10-29T06:29:38Z ***********************
06:29:38:WU05:FS02:0x21:Project: 9704 (Run 6, Clone 10, Gen 132)
06:29:38:WU05:FS02:0x21:Unit: 0x000000b7ab404162553ebc96dec8fdda
06:29:38:WU05:FS02:0x21:CPU: 0x00000000000000000000000000000000
06:29:38:WU05:FS02:0x21:Machine: 2
06:29:38:WU05:FS02:0x21:Reading tar file core.xml
06:29:38:WU05:FS02:0x21:Reading tar file system.xml
06:29:43:WU05:FS02:0x21:Reading tar file integrator.xml
06:29:43:WU05:FS02:0x21:Reading tar file state.xml
06:29:44:WU04:FS02:Upload 37.95%
06:29:47:WU05:FS02:0x21:Digital signatures verified
06:29:47:WU05:FS02:0x21:Folding@home GPU Core21 Folding@home Core
06:29:47:WU05:FS02:0x21:Version 0.0.12
Re: FAHcore 0x21 slows down Windows/NVidia PC
Windows or Linux?
Include system configuration from the log or from the System Info tab.
See the link in my FIRST post in this topic.
Ricky
Bruce,
I paused and rebooted to get the configuration into the log. I don't know how to paste an image of the client system information into the forum.
*********************** Log Started 2015-10-30T01:13:38Z ***********************
01:13:38:************************* Folding@home Client *************************
01:13:38: Website: http://folding.stanford.edu/
01:13:38: Copyright: (c) 2009-2014 Stanford University
01:13:38: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:13:38: Args:
01:13:38: Config: C:/Users/win1/AppData/Roaming/FAHClient/config.xml
01:13:38:******************************** Build ********************************
01:13:38: Version: 7.4.4
01:13:38: Date: Mar 4 2014
01:13:38: Time: 20:26:54
01:13:38: SVN Rev: 4130
01:13:38: Branch: fah/trunk/client
01:13:38: Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:13:38: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:13:38: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:13:38: Platform: win32 XP
01:13:38: Bits: 32
01:13:38: Mode: Release
01:13:38:******************************* System ********************************
01:13:38: CPU: Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
01:13:38: CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
01:13:38: CPUs: 32
01:13:38: Memory: 63.90GiB
01:13:38: Free Memory: 61.63GiB
01:13:38: Threads: WINDOWS_THREADS
01:13:38: OS Version: 6.2
01:13:38: Has Battery: false
01:13:38: On Battery: false
01:13:38: UTC Offset: -6
01:13:38: PID: 6860
01:13:38: CWD: C:/Users/win1/AppData/Roaming/FAHClient
01:13:38: OS: Windows 8.1 Pro
01:13:38: OS Arch: AMD64
01:13:38: GPUs: 2
01:13:38: GPU 0: NVIDIA:5 GM204 [GeForce GTX 980]
01:13:38: GPU 1: NVIDIA:5 GM206 [GeForce GTX 960]
01:13:38: CUDA: 5.2
01:13:38: CUDA Driver: 7050
01:13:38:Win32 Service: false
01:13:38:***********************************************************************
01:13:38:<config>
01:13:38: <!-- Folding Slot Configuration -->
01:13:38: <client-type v='beta'/>
01:13:38:
01:13:38: <!-- Network -->
01:13:38: <proxy v=':8080'/>
01:13:38:
01:13:38: <!-- Slot Control -->
01:13:38: <power v='full'/>
01:13:38:
01:13:38: <!-- User Information -->
01:13:38: <passkey v='********************************'/>
01:13:38: <user v='Richard_Summers'/>
01:13:38:
01:13:38: <!-- Folding Slots -->
01:13:38: <slot id='0' type='CPU'/>
01:13:38: <slot id='1' type='GPU'/>
01:13:38: <slot id='2' type='GPU'/>
01:13:38: <slot id='3' type='CPU'/>
01:13:38: <slot id='4' type='CPU'/>
01:13:38:</config>
01:13:38:Trying to access database...
01:13:38:Successfully acquired database lock
01:13:38:Enabled folding slot 00: READY cpu:10
01:13:38:Enabled folding slot 01: READY gpu:0:GM204 [GeForce GTX 980]
01:13:39:Enabled folding slot 02: READY gpu:1:GM206 [GeForce GTX 960]
01:13:39:Enabled folding slot 03: READY cpu:10
01:13:39:Enabled folding slot 04: READY cpu:10
01:13:39:WU04:FS02:Starting
01:13:39:WU04:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/win1/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_18.fah/FahCore_18.exe -dir 04 -suffix 01 -version 704 -lifeline 6860 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
01:13:39:WU04:FS02:Started FahCore on PID 6924
01:13:39:WU04:FS02:Core PID:6944
01:13:39:WU04:FS02:FahCore 0x18 started
01:13:39:WU01:FS01:Starting
01:13:39:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/win1/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 6860 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
01:13:39:WU01:FS01:Started FahCore on PID 6952
01:13:39:WU01:FS01:Core PID:6964
01:13:39:WU01:FS01:FahCore 0x18 started
01:13:39:WU03:FS00:Starting
01:13:39:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/win1/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 6860 -checkpoint 15 -np 10
01:13:39:WU03:FS00:Started FahCore on PID 6972
01:13:39:WU03:FS00:Core PID:6984
01:13:39:WU03:FS00:FahCore 0xa4 started
01:13:39:WU02:FS03:Starting
01:13:39:WU02:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/win1/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 6860 -checkpoint 15 -np 10
01:13:39:WU02:FS03:Started FahCore on PID 7004
01:13:39:WU02:FS03:Core PID:7016
01:13:39:WU02:FS03:FahCore 0xa4 started
01:13:39:WU00:FS04:Starting
01:13:39:WU00:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/win1/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/beta/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 6860 -checkpoint 15 -np 10
01:13:39:WU00:FS04:Started FahCore on PID 7028
01:13:39:WU00:FS04:Core PID:7052
01:13:39:WU00:FS04:FahCore 0xa4 started
01:13:39:WU01:FS01:0x18:*********************** Log Started 2015-10-30T01:13:39Z ***********************
01:13:39:WU01:FS01:0x18:Project: 10489 (Run 0, Clone 170, Gen 168)
01:13:39:WU01:FS01:0x18:Unit: 0x000000c6538b3dba551f072f23fef985
01:13:39:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
01:13:39:WU01:FS01:0x18:Machine: 1
01:13:39:WU01:FS01:0x18:Digital signatures verified
01:13:39:WU01:FS01:0x18:Folding@home GPU core18
01:13:39:WU01:FS01:0x18:Version 0.0.4
01:13:39:WU01:FS01:0x18: Found a checkpoint file
01:13:39:WU03:FS00:0xa4:
01:13:39:WU03:FS00:0xa4:*------------------------------*
01:13:39:WU03:FS00:0xa4:Folding@Home Gromacs GB Core
01:13:39:WU03:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:13:39:WU03:FS00:0xa4:Preparing to commence simulation
01:13:39:WU03:FS00:0xa4:- Looking at optimizations...
01:13:39:WU03:FS00:0xa4:- Files status OK
01:13:39:WU03:FS00:0xa4:- Expanded 291703 -> 608940 (decompressed 208.7 percent)
01:13:39:WU03:FS00:0xa4:Called DecompressByteArray: compressed_data_size=291703 data_size=608940, decompressed_data_size=608940 diff=0
01:13:39:WU03:FS00:0xa4:- Digital signature verified
01:13:39:WU03:FS00:0xa4:Project: 8609 (Run 1, Clone 0, Gen 34)
01:13:39:WU03:FS00:0xa4:Assembly optimizations on if available.
01:13:39:WU03:FS00:0xa4:Entering M.D.
01:13:39:WU04:FS02:0x18:*********************** Log Started 2015-10-30T01:13:39Z ***********************
01:13:39:WU02:FS03:0xa4:
01:13:39:WU04:FS02:0x18:Project: 9430 (Run 29, Clone 8, Gen 156)
01:13:39:WU02:FS03:0xa4:*------------------------------*
01:13:39:WU04:FS02:0x18:Unit: 0x000000bdab40413855474c0d248ff1ca
01:13:39:WU02:FS03:0xa4:Folding@Home Gromacs GB Core
01:13:39:WU04:FS02:0x18:CPU: 0x00000000000000000000000000000000
01:13:39:WU02:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
01:13:39:WU04:FS02:0x18:Machine: 2
01:13:39:WU04:FS02:0x18:Digital signatures verified
01:13:39:WU02:FS03:0xa4:Preparing to commence simulation
01:13:39:WU04:FS02:0x18:Folding@home GPU core18
01:13:39:WU02:FS03:0xa4:- Looking at optimizations...
01:13:39:WU04:FS02:0x18:Version 0.0.4
01:13:39:WU02:FS03:0xa4:- Files status OK
01:13:39:WU04:FS02:0x18: Found a checkpoint file
01:13:39:WU02:FS03:0xa4:- Expanded 291438 -> 608940 (decompressed 208.9 percent)
01:13:39:WU00:FS04:0xa4:
01:13:39:WU02:FS03:0xa4:Called DecompressByteArray: compressed_data_size=291438 data_size=608940, decompressed_data_size=608940 diff=0
01:13:39:WU00:FS04:0xa4:*------------------------------*
01:13:39:WU02:FS03:0xa4:- Digital signature verified
01:13:39:WU00:FS04:0xa4:Folding@Home Gromacs GB Core
01:13:39:WU00:FS04:0xa4:Version 2.27 (Dec. 15, 2010)
01:13:39:WU02:FS03:0xa4:Project: 8609 (Run 12, Clone 1, Gen 15)
01:13:40:WU02:FS03:0xa4:
01:13:40:WU00:FS04:0xa4:Preparing to commence simulation
01:13:40:WU02:FS03:0xa4:Assembly optimizations on if available.
01:13:40:WU00:FS04:0xa4:- Looking at optimizations...
01:13:40:WU02:FS03:0xa4:Entering M.D.
01:13:40:WU00:FS04:0xa4:- Files status OK
01:13:40:WU00:FS04:0xa4:- Expanded 825742 -> 1401112 (decompressed 169.6 percent)
01:13:40:WU00:FS04:0xa4:Called DecompressByteArray: compressed_data_size=825742 data_size=1401112, decompressed_data_size=1401112 diff=0
01:13:40:WU00:FS04:0xa4:- Digital signature verified
01:13:40:WU00:FS04:0xa4:Project: 9024 (Run 156, Clone 3, Gen 66)
01:13:40:WU00:FS04:0xa4:Assembly optimizations on if available.
01:13:40:WU00:FS04:0xa4:Entering M.D.
01:13:45:WU03:FS00:0xa4:Using Gromacs checkpoints
01:13:45:WU03:FS00:0xa4:Mapping NT from 10 to 10
01:13:45:WU00:FS04:0xa4:Using Gromacs checkpoints
01:13:45:WU02:FS03:0xa4:Using Gromacs checkpoints
01:13:45:WU00:FS04:0xa4:Mapping NT from 10 to 10
01:13:45:WU02:FS03:0xa4:Mapping NT from 10 to 10
01:13:45:WU02:FS03:0xa4:Resuming from checkpoint
01:13:45:WU02:FS03:0xa4:Verified 02/wudata_01.log
01:13:45:WU02:FS03:0xa4:Verified 02/wudata_01.trr
01:13:45:WU02:FS03:0xa4:Verified 02/wudata_01.xtc
01:13:45:WU02:FS03:0xa4:Verified 02/wudata_01.edr
01:13:45:WU02:FS03:0xa4:Completed 334140 out of 2500000 steps (13%)
01:13:45:WU03:FS00:0xa4:Resuming from checkpoint
01:13:45:WU03:FS00:0xa4:Verified 03/wudata_01.log
01:13:45:WU03:FS00:0xa4:Verified 03/wudata_01.trr
01:13:45:WU03:FS00:0xa4:Verified 03/wudata_01.xtc
01:13:45:WU03:FS00:0xa4:Verified 03/wudata_01.edr
01:13:45:WU03:FS00:0xa4:Completed 1016630 out of 2500000 steps (40%)
01:13:45:WU00:FS04:0xa4:Resuming from checkpoint
01:13:45:WU00:FS04:0xa4:Verified 00/wudata_01.log
01:13:45:WU00:FS04:0xa4:Verified 00/wudata_01.trr
01:13:45:WU00:FS04:0xa4:Verified 00/wudata_01.xtc
01:13:45:WU00:FS04:0xa4:Verified 00/wudata_01.edr
01:13:46:WU00:FS04:0xa4:Completed 31120 out of 250000 steps (12%)
01:13:53:WU04:FS02:0x18:Completed 14700000 out of 16000000 steps (91%)
01:13:53:WU04:FS02:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:14:06:WU01:FS01:0x18:Completed 625000 out of 5000000 steps (12%)
01:14:06:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:14:28:WU00:FS04:0xa4:Completed 32500 out of 250000 steps (13%)
01:14:39:WU03:FS00:0xa4:Completed 1025000 out of 2500000 steps (41%)
By using the setting <client-type v='beta'/> you have chosen to receive assignments which have a significantly higher probabilty of having problems. Removing that setting will probably fix a significant percentage of the problems you're reporting. See my instructions in my first post (above).
See also viewtopic.php?f=16&t=8
According to the last log you posted, You're running one Core_18 WU and one Core_21 WU. When project 9704 finishes, it's unlikely that you will be assigned another Core_21 WU.
Ricky
Bruce,
I happily accept sluggish video response to support core/project development. 95% of my computer usage is folding and beta testing. Should I have reported the noted behavior on the beta team thread even though the project is now released? Was this inappropriate? I am stating for observational purposes only that this project causes some sluggishness of video in my machine when running on the card that I use for my video monitor. It is rather minor, but it is there. I can live with it. By far, most core 21 projects do not have the noted sluggishness.
