Script to disable NV Boost
calkapokole
Hardware configuration: Lenovo IdeaPad Y580: Chipset Intel HM76 | Socket G2 | BIOS 2.07
Display: 15.6" | 1920x1080 | LG LP156WF1-TLC1 | TN LED | glossy
CPU: Intel Core i7-3610QM | 2.3-3.3 GHz | 6 MB L3 | 22 nm | TDP 45 W
iGPU: Intel HD Graphics 4000 (GT2) | 22 nm | 16 Unified Shaders: 1100 Mhz
dGPU: NVIDIA GeForce GTX 660M (GK107) | 28 nm:
- 384 Unified Shaders: 835@1215 MHz (45.5% OC)
- 2 GB GDDR5 128 bit: 1000@1250 (5000 effective) MHz (25% OC)
RAM: Patriot | 16 GB | DDR3 1600 MHz | 11-11-11-28-1 | Dual Channel
SSD 1: Crucial MX200 | mSATA | 250 GB | Micron 16 nm 128 Gb MLC NAND
SSD 2: Crucial MX500 | 2.5" | 2 TB | Micron 256 Gb 64L 3D TLC NAND
HDD: WD Scorpio Black WD7500BPKT | 2.5" | 750 GB | 7200 RPM | 16 MB
ODD: Samsung SN-506BB | 4 MB | BD-RE XL
WiFi: Intel Centrino Wireless-N 2200
OS: Windows 10 Pro (x64) | ForceWare 425.31 WHQL
Cooler: Zalman ZM-NC2000
Post by calkapokole »
toTOW wrote:Is it even possible to disable boost function (or any dynamic management of voltage and frequency) ?
It would be so easier if we could get back to the old behaviour of the hardware ... it was easier to control what was happeing.
Yes, it is possible to disable the boost function. I fold occasionally on Windows with a GPU and I use NVIDIA Inspector to switch my GPU from a power state P0 to a lower power state P2 where the boost is not active. Then for the P2 state I set my preferred OC which is 1200 MHz and the GPU is running constantly with this frequency. I even wrote a script for a command line so I do not have to use NVIDIA Inspector's GUI.
I can share my script which supports many different Performance Levels with many frequencies:
@echo off
setlocal enableextensions
if "%~1" == "" goto missing
set nvi_inspector="C:\Program Files\NVIDIA Inspector\nvidiaInspector.exe"
set nvi_reset=%nvi_inspector% -forcePState:0,16 -setPStateLimit:0,0 -restoreAllPStates:0 -setBaseClockOffset:0,0,0 -setMemoryClockOffset:0,0,0 & timeout 2 > nul
if "%~1" == "min" (
    %nvi_reset%
    if "%~2" == "f" (
        %nvi_inspector% -forcePState:0,8
    ) else (
        %nvi_inspector% -setPStateLimit:0,8
    exit /b
if "%~1" == "medium" (
    %nvi_reset%
    if "%~2" == "f" (
        %nvi_inspector% -forcePState:0,5
    ) else (
        %nvi_inspector% -setPStateLimit:0,5
    exit /b
if "%~1" == "nvidia" (
    %nvi_reset%
    if "%~2" == "f" (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,-500 -setGPUClock:0,1,835 -setMemoryClock:0,1,2000 -forcePState:0,5
    ) else (
        %nvi_inspector% -setBaseClockOffset:0,0,-115 -setMemoryClockOffset:0,0,-500
    exit /b
if "%~1" == "oem" (
    %nvi_reset%
    if "%~2" == "f" (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,0 -setGPUClock:0,1,950 -setMemoryClock:0,1,2500 -forcePState:0,5
    exit /b
if "%~1" == "fah" (
    %nvi_reset%
    if "%~2" == "max" (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,-500 -setGPUClock:0,1,1200 -setMemoryClock:0,1,2000 -forcePState:0,5
    ) else if not "%~2" == "" (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,-500 -setGPUClock:0,1,%2 -setMemoryClock:0,1,2000 -forcePState:0,5
    ) else (
    exit /b
if "%~1" == "max" (
    %nvi_reset%
    if "%~2" == "t" (
        if not "%~3" == "" (
            %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClock:0,2,%3
        ) else (
    ) else if "%~2" == "bench" (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,200 -setGPUClock:0,1,1250 -setMemoryClock:0,1,2700 -forcePState:0,5
            %nvi_inspector% -setBaseClockOffset:0,0,135 -setMemoryClockOffset:0,0,200 -setGPUClock:0,1,%2 -setMemoryClock:0,1,%3 -forcePState:0,5
        ) else (
            %nvi_inspector% -setBaseClockOffset:0,0,135 -setGPUClock:0,1,%2 -setMemoryClock:0,1,2500 -forcePState:0,5
    ) else (
        %nvi_inspector% -setBaseClockOffset:0,0,135 -setGPUClock:0,1,1235 -setMemoryClock:0,1,2500 -forcePState:0,5
    exit /b
:unrecognized
echo Unrecognized parameter.
goto help
:missing
echo Missing parameter.
:help
echo Type: %0 min [f] ^| medium [f] ^| nvidia [f] ^| oem [f] ^| fah [max ^| GPU clock] ^| max [t [memory clock] ^| bench ^| GPU clock [memory clock]]
I use a mobile GPU (GTX 660M) and several parameters are not available for my card (like -setFanSpeed, -setVoltageOffset, -setPowetTarget and -setTempTarget). Anyone interested can easily adjust this script for his/her card.
calkapokole
One correction: the lower power state that I use is P5 and to be percise it is called by NVIDIA Inspector a 'Performance State'.
artoar_11
Hardware configuration: AMD R7 3700X @ 4.0 GHz; ASUS ROG STRIX X470-F GAMING; DDR4 2x8GB @ 3.0 GHz; GByte RTX 3060 Ti @ 1890 MHz; Fortron-550W 80+ bronze; Win10 Pro/64
Re: 9634 (Run 0, Clone 9, Gen 5)
Post by artoar_11 »
I will try these days Nvidia Inspector. I am sure that the GTX 970 can operate without overload on the factory OC frequency (1300 MHz) with a lower voltage. For example 1.180 to 1.190 V instead of 1.212 V (boost voltage).
Here I find guide for Nvidia Inspector for older 600 Kepler: http://www.overclock.net/t/1267918/guid ... dervolting
calkapokole
It is a good guide.
bigblock990
Post by bigblock990 »
gpu boost and adaptive clocking are not the same thing.
Adaptive clocking allows the gpu to idle down when not under load. To turn this off, select maximum performance, which just forces P0 (full 3D clocks) all the time.
GPU boost sets the clock speed for both P0 (3d) and P2 (2d) depending on a bunch of variables including load, temps ect ect. GPU boost can be disabled with a modified bios.
bigblock990 wrote:GPU boost sets the clock speed for both P0 (3d) and P2 (2d) depending on a bunch of variables including load, temps ect ect. GPU boost can be disabled with a modified bios.
So why doesn't NV incorporate enough features from that modified bios to solve the problem? They're not supporting their product.
bigblock990
Nvidia only supplies a reference vbios. The manufacturers (evga, msi, asus ect) then create their own bios from that depending on the card model, which creates varying levels of "factory OC". If you want to disable gpu boost, you have to modify your own bios or download from someone who already has. Then you must reflash your gpu. This is all done at your own risk. Nvidia doesn't support it at all.
calkapokole
In order to disable GPU Boost on Windows you can also use NVIDIA Inspector as described above and force your GPU to run with a constant frequency. It works just fine in P5-state for my GTX 660M. Another great thing that I forgot to mention earlier is that in the P5-state the PCI-E bus interface of my card switches from version 3.0 to the lower version 2.0 with a reduced bandwidth which decreases temperature of the card under load by 5 C.
Grandpa_01
Re: Script to disable NV Boost
Post by Grandpa_01 »
The default Nvidia bios on the current cards runs at P2 when you run compute software on it which lowers the memory speed from 7000Mhz to 6000Mhz I have used Inspector to raise the memory speed to the default 7000Mhz when running GPUGrid but I have not used it for much else. Unfortunately it only works on Windows which does not appear to be bothered as much by the slow down problem. It is a good tool for windows though. I wish the had a Linux version :ewink:
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Don't worry too much about the slowdown problem, it should be fixed in next version of core 21.
Does anyone noticed a reduction in bad states after playing with those scripts ?
artoar_11
Post by artoar_11 »
With NV Inspector I disable Boost. GPU load considerably decreased. GTX 970.
GPU Voltage: 1.162 V (permanently); Boost Voltage: 1.212
Core Clock: 1275 MHz (permanently); Boost Clock: 1300 MHz
I currently received WU by p11401. Will be completed after about 3h. I can report results after about 9h.
