Didn't get any points
PJEC
Post by PJEC »
I'm not all that fussed about the points really, but as I'm contributing to a team I'd like to get them.
The GPU's task was must have been about 80% done but it must have cancelled and I didn't get any points? Is this because they were contributed to the team?
If not is this a regular occurrence?
i5 4690k (stock) and Gigabyte GTX 970 G1 Gaming (1505MHz)
Thanks
Piers
Re: Didn't get any points
PJEC
Post by PJEC »
Happened again today - was supposed to get around 70000 points for a large GPU WU
Extract from log:
14:27:19:WU01:FS01:0x18:Completed 14080000 out of 16000000 steps (88%)
14:31:14:WU01:FS01:0x18:Completed 14240000 out of 16000000 steps (89%)
14:35:15:WU01:FS01:0x18:Completed 14400000 out of 16000000 steps (90%)
14:39:17:WU01:FS01:0x18:Completed 14560000 out of 16000000 steps (91%)
14:43:18:WU01:FS01:0x18:Completed 14720000 out of 16000000 steps (92%)
14:47:19:WU01:FS01:0x18:Completed 14880000 out of 16000000 steps (93%)
14:51:21:WU01:FS01:0x18:Completed 15040000 out of 16000000 steps (94%)
14:55:19:WU01:FS01:0x18:Completed 15200000 out of 16000000 steps (95%)
14:59:19:WU01:FS01:0x18:Completed 15360000 out of 16000000 steps (96%)
15:03:20:WU01:FS01:0x18:Completed 15520000 out of 16000000 steps (97%)
15:07:24:WU01:FS01:0x18:Completed 15680000 out of 16000000 steps (98%)
15:11:24:WU01:FS01:0x18:Completed 15840000 out of 16000000 steps (99%)
15:11:26:WU00:FS01:Connecting to 171.67.108.45:80
15:11:26:WU00:FS01:Assigned to work server 171.64.65.104
15:11:26:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GM204 [GeForce GTX 970] from 171.64.65.104
15:11:26:WU00:FS01:Connecting to 171.64.65.104:8080
15:11:27:WU00:FS01:Downloading 9.83MiB
15:11:33:WU00:FS01:Download 59.76%
15:11:35:WU00:FS01:Download complete
15:11:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9206 run:0 clone:1275 gen:6 core:0x21 unit:0x0000002f664f2dd056202a6a5f44f383
15:15:26:WU01:FS01:0x18:Completed 16000000 out of 16000000 steps (100%)
15:15:29:WU01:FS01:0x18:Saving result file logfile_01.txt
15:15:29:WU01:FS01:0x18:Saving result file checkpointState.xml
15:15:29:WU01:FS01:0x18:Saving result file checkpt.crc
15:15:29:WU01:FS01:0x18:Saving result file log.txt
15:15:29:WU01:FS01:0x18:Saving result file positions.xtc
15:15:31:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:15:31:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9412 run:39 clone:4 gen:120 core:0x18 unit:0x0000009bab40413a5535e1d41938bec5
15:15:31:WU01:FS01:Uploading 13.54MiB to 171.64.65.58
15:15:31:WU01:FS01:Connecting to 171.64.65.58:8080
15:15:31:WU00:FS01:Starting
15:15:31:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Piers/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 7532 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
15:15:31:WU00:FS01:Started FahCore on PID 9236
15:15:32:WU00:FS01:Core PID:6912
15:15:32:WU00:FS01:FahCore 0x21 started
15:15:32:WU00:FS01:0x21:*********************** Log Started 2015-10-20T15:15:32Z ***********************
15:15:32:WU00:FS01:0x21:Project: 9206 (Run 0, Clone 1275, Gen 6)
15:15:32:WU00:FS01:0x21:Unit: 0x0000002f664f2dd056202a6a5f44f383
15:15:32:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
15:15:32:WU00:FS01:0x21:Machine: 1
15:15:32:WU00:FS01:0x21:Reading tar file core.xml
15:15:32:WU00:FS01:0x21:Reading tar file system.xml
15:15:33:WU00:FS01:0x21:Reading tar file integrator.xml
15:15:33:WU00:FS01:0x21:Reading tar file state.xml
15:15:34:WU00:FS01:0x21:Digital signatures verified
15:15:34:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
15:15:34:WU00:FS01:0x21:Version 0.0.12
15:15:37:WU01:FS01:Upload 20.78%
15:15:43:WU01:FS01:Upload 42.94%
15:15:49:WU01:FS01:Upload 90.95%
15:15:53:WU01:FS01:Upload complete
15:15:54:WU01:FS01:Server responded WORK_ACK (400)
15:15:54:WU01:FS01:Final credit estimate, 44320.00 points
15:15:54:WU01:FS01:Cleaning up
15:16:30:WU00:FS01:0x21:Completed 0 out of 2500000 steps (0%)
15:16:30:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:22:22:WU00:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
15:27:58:WU00:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
15:33:36:WU00:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
15:39:16:WU00:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
15:45:18:WU00:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
Mod edit: Added Code tags to log
The estimated points for project:9412 run:39 clone:4 gen:120 was 44,320, not 70K. But you have not yet processed enough WU's to get the Quick Return Bonus which using a passkey makes you eligible for. So just base points were awarded. The client can estimate based on the presence of a passkey, but can not check to see if it is QRB eligible.
From the Points FAQ:
The bonus is applied for users who use a passkey, have successfully returned at least 10 bonus-eligible WUs, have successfully returned 80% or more of assigned WUs, and returned the unit before its Timeout (formerly Preferred Deadline). Bonus points do not apply to partial returns.
I just checked, as of now you have returned 9 WU's and will be eligible for the bonus points after completing and turning in another WU.
wilding2004
Post by wilding2004 »
Hi PJEC,
There's nothing in the log extract to suggest anything is wrong. Why do you think you are missing points?
These 2 lines mean the server accepted your WU for an estimated 44320 points. Where did you get 70000 from? if it was the client estimate, then that is a best case figure based purely on frame times - it doesn't reflect upload/download, or any other delays.
If you post the WU info, i'm sure someone will look it up and make sure it was added to the stats database.
